| ossimSrtmTileSource () |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual bool | open () |
| Pure virtual open. More...
virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
| Returns the image geometry object associated with this tile source or NULL if not defined. More...
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
| Method to save the state of an object to a keyword list. More...
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| Method to the load (recreate) the state of an object from a keyword list. More...
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
| Gets a property. More...
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
| Adds property names to array. More...
| ossimGeneralRasterTileSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tile_rect, ossim_uint32 resLevel=0) |
| Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More...
virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel=0) |
| Method to get a tile. More...
virtual ossim_uint32 | getNumberOfInputBands () const |
| Returns the number of bands in the image. More...
virtual ossim_uint32 | getNumberOfOutputBands () const |
| Returns the number of bands in a tile returned from this TileSource. More...
virtual ossim_uint32 | getNumberOfLines (ossim_uint32 reduced_res_level=0) const |
| Returns the number of lines in the image. More...
virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 reduced_res_level=0) const |
| Returns the number of samples in the image. More...
virtual ossimScalarType | getOutputScalarType () const |
| Returns the output pixel type of the tile source. More...
virtual ossim_uint32 | getTileWidth () const |
| Returns the width of the output tile. More...
virtual ossim_uint32 | getTileHeight () const |
| Returns the height of the output tile. More...
virtual ossim_uint32 | getImageTileWidth () const |
| Returns the tile width of the image or 0 if the image is not tiled. More...
virtual ossim_uint32 | getImageTileHeight () const |
bool | isValidRLevel (ossim_uint32 reduced_res_level) const |
| Determines if the passed in reslution level is valid. More...
virtual void | close () |
| Deletes the overview and clears the valid image vertices. More...
virtual bool | isOpen () const |
| Derived classes must implement this method to be concrete. More...
virtual bool | open (const ossimGeneralRasterInfo &info) |
virtual double | getNullPixelValue (ossim_uint32 band=0) const |
| Override base getXXXXPixValue methods since the null/min/max can be set to something different. More...
virtual double | getMinPixelValue (ossim_uint32 band=0) const |
| Retuns the min pixel value. More...
virtual double | getMaxPixelValue (ossim_uint32 band=0) const |
| Returns the max pixel of the band. More...
virtual bool | isBandSelector () const |
| Indicates whether or not the image handler can control output band selection via the setOutputBandList method. More...
virtual bool | setOutputBandList (const std::vector< ossim_uint32 > &band_list) |
| If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled. More...
virtual void | getOutputBandList (std::vector< ossim_uint32 > &bandList) const |
| Initializes bandList to the zero based order of output bands. More...
Public Member Functions inherited from ossimImageHandler |
| ossimImageHandler () |
| Constructor (default): More...
virtual | ~ossimImageHandler () |
| Destructor: Derived classes should implement. More...
virtual void | initialize () |
| initialize Does nothing in this class. More...
virtual bool | openOverview () |
| Searches for an overview. More...
virtual bool | openOverview (const ossimFilename &overview_file) |
| Calls closeOverview(), then attempts to open the overview_file. More...
virtual void | closeOverview () |
| If theOverview is initialized it will be deleted and set to NULL. More...
virtual const ossimImageHandler * | getOverview () const |
virtual bool | hasOverviews () const |
virtual ossimFilename | createDefaultOverviewFilename () const |
virtual ossimFilename | createDefaultGeometryFilename () const |
virtual ossimFilename | createDefaultMetadataFilename () const |
virtual ossimFilename | createDefaultHistogramFilename () const |
virtual ossimFilename | createDefaultValidVerticesFilename () const |
virtual bool | writeValidImageVertices (const std::vector< ossimIpt > &vertices, const ossimFilename &file=ossimFilename("")) |
| Outputs vertices to file and updates the internal vertex array variable "theValidImageVertices". More...
virtual bool | openValidVertices (const ossimFilename &vertices_file) |
| Opens the valid image vertices file and sets theValidImageVerticesFile variable. More...
virtual bool | openValidVertices () |
| Creates vertices file name based on image, then tries to open. More...
virtual bool | open (const ossimFilename &imageFile, ossim_uint32 entryIndex) |
| Opens the image file. More...
virtual bool | open (const ossimFilename &imageFile) |
virtual bool | open (std::shared_ptr< ossim::ImageHandlerState > state) |
virtual bool | buildHistogram (int numberOfRLevels=0, ossimHistogramMode mode=OSSIM_HISTO_MODE_NORMAL) |
| Build a histogram for image file. More...
virtual bool | buildAllHistograms (int numberOfRLevels=0, ossimHistogramMode mode=OSSIM_HISTO_MODE_NORMAL) |
| Build a histograms for all image entries. More...
virtual bool | buildOverview (ossimImageHandlerOverviewCompressionType compressionType=OSSIM_OVERVIEW_COMPRESSION_NONE, ossim_uint32 quality=75, ossimFilterResampler::ossimFilterResamplerType resampleType=ossimFilterResampler::ossimFilterResampler_BOX, bool includeFullResFlag=false) |
| Will build over file for theImageFile. More...
virtual bool | buildAllOverviews (ossimImageHandlerOverviewCompressionType compressionType=OSSIM_OVERVIEW_COMPRESSION_NONE, ossim_uint32 quality=75, ossimFilterResampler::ossimFilterResamplerType resampleType=ossimFilterResampler::ossimFilterResampler_BOX, bool includeFullResFlag=false) |
| Will build over file for all image entries. More...
virtual bool | buildOverview (const ossimFilename &filename, ossimImageHandlerOverviewCompressionType compressionType=OSSIM_OVERVIEW_COMPRESSION_NONE, ossim_uint32 quality=75, ossimFilterResampler::ossimFilterResamplerType resampleType=ossimFilterResampler::ossimFilterResampler_BOX, bool includeFullResFlag=false) |
| Will build an over file for filename. More...
ossimRefPtr< ossimMultiResLevelHistogram > | getImageHistogram () const |
| Fetches the current entry image's histogram. More...
virtual void | setImageGeometry (ossimImageGeometry *geom) |
| Sets the image geometry object. More...
virtual void | saveImageGeometry () const |
| Saves the image geometry to a file that will be made based on the image file name. More...
virtual void | saveImageGeometry (const ossimFilename &geometry_file) const |
virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| Returns zero-based bounding rectangle of the image. More...
virtual ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
virtual void | getDecimationFactor (ossim_uint32 resLevel, ossimDpt &result) const |
virtual void | getDecimationFactors (vector< ossimDpt > &decimations) const |
| This returns all decimation for all levels. More...
virtual ossim_uint32 | getNumberOfDecimationLevels () const |
| This returns the total number of decimation levels. More...
virtual ossim_uint32 | getNumberOfReducedResSets () const |
| This method is obsolete. More...
virtual void | setFilename (const ossimFilename &filename) |
| Sets the filename. More...
virtual const ossimFilename & | getFilename () const |
| Returns the filename. More...
bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| Connection rule. More...
virtual void | getValidImageVertices (vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
| ordering specifies how the vertices should be arranged. More...
virtual bool | setOutputToInputBandList () |
| If the image handler "isBandSeletor()" then the band selection of the output are set to input or identity. More...
virtual bool | isIdentityBandList (const std::vector< ossim_uint32 > &bandList) const |
| Convenience method to see if band list is identity. More...
virtual bool | isImageTiled () const |
| Indicates whether or not the image is tiled internally. More...
virtual bool | hasMetaData () const |
virtual ossimRefPtr< ossimNBandLutDataObject > | getLut () const |
virtual bool | hasLut () const |
virtual void | loadMetaData () |
| There is an external file with an omd extension. More...
virtual void | setMinPixelValue (ossim_uint32 band, const ossim_float64 &pix) |
| convenience method to set min pixel value. More...
virtual void | setMaxPixelValue (ossim_uint32 band, const ossim_float64 &pix) |
| convenience method to set max pixel value. More...
virtual void | setNullPixelValue (ossim_uint32 band, const ossim_float64 &pix) |
| convenience method to set null pixel value. More...
virtual ossim_uint32 | getCurrentEntry () const |
virtual ossim_uint32 | getNumberOfEntries () const |
virtual void | getEntryName (ossim_uint32 entryIdx, std::string &name) const |
| Get the name of entry as a string. More...
virtual void | getEntryList (std::vector< ossim_uint32 > &entryList) const |
virtual void | getEntryNames (std::vector< ossimString > &entryNames) const |
bool | useEntryIndex () const |
| Convenience method to determine if entry index should be used for support files, e.g. More...
ossimFilename | getOverviewFile () const |
virtual bool | setCurrentEntry (ossim_uint32 entryIdx) |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
ossimFilename | getFilenameWithThisExtension (const ossimString &ext, bool set_e0_prefix=false) const |
| Returns the image file with extension set using supplentary directory for dirname if set. More...
void | getFilenameWithThisExt (const ossimString &ext, ossimFilename &f) const |
ossim_uint32 | getStartingResLevel () const |
void | setStartingResLevel (ossim_uint32 level) |
bool | getOpenOverviewFlag () const |
void | setOpenOverviewFlag (bool flag) |
| Sets theOpenOverviewFlag. More...
virtual void | setSupplementaryDirectory (const ossimFilename &dir) |
| Sets the supplementary directory. More...
virtual const ossimFilename & | getSupplementaryDirectory () const |
| Returns the supplementary directory. More...
const ossimString & | getImageID () const |
| Fetches the image ID. More...
void | setImageID (const ossimString &id) |
| Sets the image ID in case it is externally generated. More...
ossimPixelType | getPixelType () const |
| Returns the raster pixel alignment type. More...
virtual bool | getRgbBandList (std::vector< ossim_uint32 > &bandList) const |
| Convenience method to get the zero based rgb output band list. More...
template<class T > |
std::shared_ptr< T > | getStateAs () |
std::shared_ptr< const T > | getStateAs () const |
std::shared_ptr< ossim::ImageHandlerState > | getState () |
std::shared_ptr< const ossim::ImageHandlerState > | getState () const |
void | setState (std::shared_ptr< ossim::ImageHandlerState > state) |
| ossimImageSource (ossimObject *owner=0) |
| ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) |
virtual | ~ossimImageSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIpt &origin, ossim_uint32 resLevel=0) |
virtual ossimObject * | getObject () |
| For RTTI support. More...
virtual const ossimObject * | getObject () const |
virtual void | getDecimationFactors (std::vector< ossimDpt > &decimations) const |
| Will return an array of all decimations for each resolution level. More...
virtual void | getBoundingRect (ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Gets the bounding rectangle of the source. More...
virtual void | getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
virtual void | setImageGeometry (const ossimImageGeometry *geom) |
| Default implementation sets geometry of the first input to the geometry specified. More...
virtual bool | isIndexedData () const |
| ossimSource (ossimObject *owner=0) |
| ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual std::ostream & | print (std::ostream &out) const |
| Outputs theErrorStatus as an ossimErrorCode and an ossimString. More...
| ossimConnectableObject (ossimObject *owner=0) |
| Base constructor of this object. More...
| ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
| All connectable objects will have id's. More...
const ossimId & | getId () const |
| Will allow us to get this object's id. More...
const ossimObject * | getOwner () const |
| Fetches the current owner, most likely a container but not limited to one. More...
virtual void | changeOwner (ossimObject *owner) |
| Permits changing the object's owner. More...
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
| will check the direction specified to see if all slots are full. More...
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
| Return a valid index of the input list if the passed in object is found else return -1. More...
virtual ossim_int32 | findInputIndex (const ossimId &id) |
| Return a valid index of the input list if the passed id is found else return -1. More...
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
| Return a valid index of the output list if the passed in object is found else return -1. More...
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
| Should return the first available index to connect to. More...
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
| default implementation is to allow anyone to connect to us. More...
virtual void | disconnect (ossimConnectableObject *object=0) |
| Will disconnect the object passed in. More...
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
| Will disconnect the object at the given input index and generate a connection event. More...
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
| Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More...
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
| Will disconnect the object at the given output index and generate a connection event. More...
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
| Will disconnect the output object. More...
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
| Will disconnect all of the input objects. More...
virtual void | disconnectAllOutputs () |
| Will disconnect all of the output objects. More...
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
| Will try to connect this objects input to the passed in object. More...
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
| Will connect the specified input to the passed in object. More...
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
| Will try to connect this objects output to the passed in object. More...
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
| Will disconnect itself from all inputs and reset to the passed in input list. More...
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
| Will disconnect itself from all outputs and reset to the passed in output list. More...
virtual ossim_uint32 | getNumberOfInputs () const |
| Returns the number of input objects. More...
virtual ossim_uint32 | getNumberOfOutputs () const |
| Return the number of output objects. More...
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
| returns the object at the specified index. More...
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
| Will set the number of inputs. More...
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
| Will set the number of outputs. More...
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
| OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) |
| OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
| Save the state of all inputs to a keyword list. More...
virtual bool | fillContainer (ossimConnectableContainer &container) |
| Inserts this object and all of its children and inputs into the container provided. More...
bool | moveInputUp (const ossimId &id) |
| Moves the input connection matching id up one in the connection list. More...
bool | moveInputDown (const ossimId &id) |
| Moves the input connection matching id down one in the connection list. More...
bool | moveInputToTop (const ossimId &id) |
| Moves the input connection matching id to the top of the connection list. More...
bool | moveInputToBottom (const ossimId &id) |
| Moves the input connection matching id to the bottom of the connection list. More...
virtual void | accept (ossimVisitor &visitor) |
| We will add a visitor interface for all connectable objects. More...
| ossimObject () |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
| ossimReferenced () |
| ossimReferenced (const ossimReferenced &) |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
| increment the reference count by one, indicating that this object has another pointer which is referencing it. More...
void | unref () const |
| decrement the reference count by one, indicating that a pointer to this object is referencing it. More...
void | unref_nodelete () const |
int | referenceCount () const |
| ossimListenerManager () |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
| ossimPropertyInterface () |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
| ossimErrorStatusInterface () |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
