Public Member Functions | Private Member Functions | Private Attributes | List of all members
ossimTransCylEquAreaProjection Class Reference
#include <ossimTransCylEquAreaProjection.h>
Inheritance diagram for ossimTransCylEquAreaProjection:
ossimMapProjection ossimProjection ossimObject ossimErrorStatusInterface ossimReferenced
 ossimTransCylEquAreaProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(6378137, 6356752.3142), const ossimGpt &origin=ossimGpt())
 ossimTransCylEquAreaProjection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin, double falseEasting, double falseNorthing, double scaleFactor)
 ~ossimTransCylEquAreaProjection ()
virtual ossimGpt inverse (const ossimDpt &eastingNorthing) const
 Will take a point in meters and convert it to ground. More...
virtual ossimDpt forward (const ossimGpt &latLon) const
 All map projections will convert the world coordinate to an easting northing (Meters). More...
virtual void update ()
void setFalseEasting (double falseEasting)
void setFalseNorthing (double falseNorthing)
void setScaleFactor (double scaleFactor)
void setFalseEastingNorthing (double falseEasting, double falseNorthing)
void setParameters (double falseEasting, double falseNorthing, double scaleFactor)
void setDefaults ()
double getFalseEasting () const
double getFalseNorthing () const
double getScaleFactor () const
virtual bool operator== (const ossimProjection &projection) const
 Returns TRUE if principal parameters are within epsilon tolerance. More...
- Public Member Functions inherited from ossimMapProjection
 ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt())
 ossimMapProjection (const ossimMapProjection &src)
virtual ossimDpt worldToLineSample (const ossimGpt &worldPoint) const
virtual void worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const
virtual ossimGpt lineSampleToWorld (const ossimDpt &projectedPoint) const
virtual void lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const
virtual void lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const
 This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More...
virtual void lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const
virtual void eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const
virtual void eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const
virtual double getStandardParallel1 () const
 Derived classes should implement as needed. More...
virtual double getStandardParallel2 () const
virtual void setPcsCode (ossim_uint32 pcsCode)
virtual ossim_uint32 getPcsCode () const
 Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More...
virtual ossimString getProjectionName () const
 Returns the projection name. More...
virtual double getA () const
 ACCESS METHODS: More...
virtual double getB () const
virtual double getF () const
virtual const ossimDptgetDecimalDegreesPerPixel () const
 Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More...
virtual const ossimDptgetUlEastingNorthing () const
virtual const ossimGptgetUlGpt () const
virtual const ossimDatumgetDatum () const
const ossimEllipsoidgetEllipsoid () const
const ossimGptgetOrigin () const
virtual bool isGeographic () const
virtual void applyScale (const ossimDpt &scale, bool recenterTiePoint)
 Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More...
virtual void setEllipsoid (const ossimEllipsoid &ellipsoid)
 SET METHODS: More...
virtual void setAB (double a, double b)
virtual void setDatum (const ossimDatum *datum)
 Sets theDatum to datum. More...
virtual void setOrigin (const ossimGpt &origin)
 Sets theOrigin to origin. More...
virtual void setMetersPerPixel (const ossimDpt &gsd)
virtual void setDecimalDegreesPerPixel (const ossimDpt &gsd)
virtual void setUlTiePoints (const ossimGpt &gpt)
virtual void setUlTiePoints (const ossimDpt &eastingNorthing)
virtual void setUlEastingNorthing (const ossimDpt &ulEastingNorthing)
virtual void setUlGpt (const ossimGpt &ulGpt)
virtual void assign (const ossimProjection &aProjection)
 Prints data members to stream. More...
virtual void computeDegreesPerPixel ()
 Computes the approximate resolution in degrees/pixel. More...
virtual void computeMetersPerPixel ()
 This will go from the ground point and give you an approximate meters per pixel. More...
void setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation)
void setMatrixScale (const ossimDpt &scale)
void setMatrixRotation (double rotation)
void setMatrixTranslation (const ossimDpt &translation)
void snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType)
 Utility method to snap the tie point to some multiple. More...
void snapTiePointToOrigin ()
void setElevationLookupFlag (bool flag)
bool getElevationLookupFlag () const
ossimUnitType getModelTransformUnitType () const
void setModelTransformUnitType (ossimUnitType unit)
bool hasModelTransform () const
void setProjectionUnits (ossimUnitType units)
ossimUnitType getProjectionUnits () const
 OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More...
 ossimProjection ()
virtual ~ossimProjection ()
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimErrorStatusInterface ()
bool hasError () const
long Set_Trans_Cyl_Eq_Area_Parameters (double a, double f, double Origin_Latitude, double Central_Meridian, double False_Easting, double False_Northing, double Scale_Factor)
void Get_Trans_Cyl_Eq_Area_Parameters (double *a, double *f, double *Origin_Latitude, double *Central_Meridian, double *False_Easting, double *False_Northing, double *Scale_Factor) const
long Convert_Geodetic_To_Trans_Cyl_Eq_Area (double Latitude, double Longitude, double *Easting, double *Northing) const
long Convert_Trans_Cyl_Eq_Area_To_Geodetic (double Easting, double Northing, double *Latitude, double *Longitude) const
Private Attributes
double Tcea_a
double Tcea_f
double es2
double es4
double es6
double es
double M0
double qp
double One_MINUS_es2
double One_OVER_2es
double a0
double a1
double a2
double b0
double b1
double b2
double b3
double c0
double c1
double c2
double c3
double Tcea_Origin_Lat
double Tcea_Origin_Long
double Tcea_False_Northing
double Tcea_False_Easting
double Tcea_Scale_Factor
double Tcea_Min_Easting
double Tcea_Max_Easting
double Tcea_Min_Northing
double Tcea_Max_Northing
Additional Inherited Members
- Protected Member Functions inherited from ossimMapProjection
virtual ~ossimMapProjection ()
void updateFromTransform ()
virtual ~ossimReferenced ()
- Protected Attributes inherited from ossimMapProjection
ossimEllipsoid theEllipsoid
 This method verifies that the projection parameters match the current pcs code. More...
ossimGpt theOrigin
const ossimDatumtheDatum
 This is only set if we want to have built in datum shifting. More...
ossimDpt theMetersPerPixel
 Holds the number of meters per pixel. More...
ossimDpt theDegreesPerPixel
 Hold the decimal degrees per pixel. More...
ossimGpt theUlGpt
 Hold tie point in decimal degrees. More...
ossimDpt theUlEastingNorthing
 Hold tie point as easting northing. More...
ossimDpt theFalseEastingNorthing
 Hold the false easting northing. More...
ossim_uint32 thePcsCode
 Projection Coordinate System(PCS) code. More...
bool theElevationLookupFlag
ossimMatrix4x4 theModelTransform
ossimMatrix4x4 theInverseModelTransform
ossimUnitType theModelTransformUnitType
ossimUnitType theProjectionUnits
 Linear units of the projection as indicated in the projection's specification: More...
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 18 of file ossimTransCylEquAreaProjection.h.
◆ ossimTransCylEquAreaProjection() [1/2]
ossimTransCylEquAreaProjection::ossimTransCylEquAreaProjection ( const ossimEllipsoid ellipsoid = ossimEllipsoid(6378137, 6356752.3142),
const ossimGpt origin = ossimGpt()
Definition at line 51 of file ossimTransCylEquAreaProjection.cpp.
References setDefaults(), and update().
53  :ossimMapProjection(ellipsoid, origin)
54 {
55  setDefaults();
56  update();
57 }
virtual ossimGpt origin() const
ossimMapProjection(const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt())
◆ ossimTransCylEquAreaProjection() [2/2]
ossimTransCylEquAreaProjection::ossimTransCylEquAreaProjection ( const ossimEllipsoid ellipsoid,
const ossimGpt origin,
double  scaleFactor
Definition at line 59 of file ossimTransCylEquAreaProjection.cpp.
References Tcea_False_Easting, Tcea_False_Northing, Tcea_Max_Easting, Tcea_Max_Northing, Tcea_Min_Easting, Tcea_Min_Northing, Tcea_Scale_Factor, and update().
64  :ossimMapProjection(ellipsoid, origin)
65 {
66  Tcea_False_Easting = falseEasting;
67  Tcea_False_Northing = falseNorthing;
68  Tcea_Scale_Factor = scaleFactor;
69  Tcea_Min_Easting = -6398628.0;
70  Tcea_Max_Easting = 6398628.0;
71  Tcea_Min_Northing = -20003931.0;
72  Tcea_Max_Northing = 20003931.0;
73
74  update();
75 }
◆ ~ossimTransCylEquAreaProjection()
ossimTransCylEquAreaProjection::~ossimTransCylEquAreaProjection ( )
inline
Definition at line 29 of file ossimTransCylEquAreaProjection.h.
29 {}
Member Function Documentation
◆ Convert_Geodetic_To_Trans_Cyl_Eq_Area()
long ossimTransCylEquAreaProjection::Convert_Geodetic_To_Trans_Cyl_Eq_Area ( double  Latitude,
double  Longitude,
double *  Easting,
double *  Northing
) const
private
The function Convert_Geodetic_To_Trans_Cyl_Eq_Area converts geodetic (latitude and longitude) coordinates to Transverse Cylindrical Equal Area projection easting, and northing coordinates, according to the current ellipsoid and Transverse Cylindrical Equal Area projection parameters. If any errors occur, the error code(s) are returned by the function, otherwise TCEA_NO_ERROR is returned.
Latitude : Latitude (phi) in radians (input) Longitude : Longitude (lambda) in radians (input) Easting : Easting (X) in meters (output) Northing : Northing (Y) in meters (output)
Definition at line 376 of file ossimTransCylEquAreaProjection.cpp.
References a0, a1, a2, c0, c1, c2, c3, es, es2, M0, M_PI, PI_OVER_2, qp, Tcea_a, TCEA_COEFF_TIMES_SIN, Tcea_False_Easting, Tcea_False_Northing, TCEA_L, TCEA_LON_WARNING, TCEA_M, TCEA_NO_ERROR, Tcea_Origin_Long, TCEA_Q, Tcea_Scale_Factor, TWO_PI, and x.
Referenced by forward(), and Set_Trans_Cyl_Eq_Area_Parameters().
380 { /* BEGIN Convert_Geodetic_To_Trans_Cyl_Eq_Area */
381 /*
382  * The function Convert_Geodetic_To_Trans_Cyl_Eq_Area converts geodetic (latitude and
383  * longitude) coordinates to Transverse Cylindrical Equal Area projection (easting and
384  * northing) coordinates, according to the current ellipsoid and Transverse Cylindrical
385  * Equal Area projection parameters. If any errors occur, the error code(s) are returned
386  * by the function, otherwise TCEA_NO_ERROR is returned.
387  *
388  * Latitude : Latitude (phi) in radians (input)
389  * Longitude : Longitude (lambda) in radians (input)
390  * Easting : Easting (X) in meters (output)
391  * Northing : Northing (Y) in meters (output)
392  */
393
394  double x;
395  double dlam; /* Longitude - Central Meridan */
396  double sin_lat = sin(Latitude);
397  double qq, qq_OVER_qp;
398  double beta, betac;
399  double sin2betac, sin4betac, sin6betac;
400  double PHIc;
401  double phi, sin2phi, sin4phi, sin6phi;
402  double sinPHIc;
403  double Mc;
404  long Error_Code = TCEA_NO_ERROR;
405
406 // if ((Latitude < -PI_OVER_2) || (Latitude > PI_OVER_2))
407 // { /* Latitude out of range */
408 // Error_Code |= TCEA_LAT_ERROR;
409 // }
410 // if ((Longitude < -M_PI) || (Longitude > TWO_PI))
411 // { /* Longitude out of range */
412 // Error_Code |= TCEA_LON_ERROR;
413 // }
414  if (!Error_Code)
415  { /* no errors */
416  dlam = Longitude - Tcea_Origin_Long;
417  if (fabs(dlam) >= (M_PI / 2.0))
418  { /* Distortion will result if Longitude is more than 90 degrees from the Central Meridian */
419  Error_Code |= TCEA_LON_WARNING;
420  }
421
422  if (dlam > M_PI)
423  {
424  dlam -= TWO_PI;
425  }
426  if (dlam < -M_PI)
427  {
428  dlam += TWO_PI;
429  }
430  if (Latitude == PI_OVER_2)
431  {
432  qq = qp;
433  qq_OVER_qp = 1.0;
434  }
435  else
436  {
437  x = es * sin_lat;
438  qq = TCEA_Q(sin_lat, x);
439  qq_OVER_qp = qq / qp;
440  }
441
442
443  if (qq_OVER_qp > 1.0)
444  qq_OVER_qp = 1.0;
445  else if (qq_OVER_qp < -1.0)
446  qq_OVER_qp = -1.0;
447
448  beta = asin(qq_OVER_qp);
449  betac = atan(tan(beta) / cos(dlam));
450
451  if ((fabs(betac) - PI_OVER_2) > 1.0e-8)
452  PHIc = betac;
453  else
454  {
455  sin2betac = TCEA_COEFF_TIMES_SIN(a0, 2.0, betac);
456  sin4betac = TCEA_COEFF_TIMES_SIN(a1, 4.0, betac);
457  sin6betac = TCEA_COEFF_TIMES_SIN(a2, 6.0, betac);
458  PHIc = TCEA_L(betac, sin2betac, sin4betac, sin6betac);
459  }
460
461  sinPHIc = sin(PHIc);
462  *Easting = Tcea_a * cos(beta) * cos(PHIc) * sin(dlam) /
463  (Tcea_Scale_Factor * cos(betac) * sqrt(1.0 - es2 *
464  sinPHIc * sinPHIc)) + Tcea_False_Easting;
465
466  phi = c0 * PHIc;
467  sin2phi = TCEA_COEFF_TIMES_SIN(c1, 2.0, PHIc);
468  sin4phi = TCEA_COEFF_TIMES_SIN(c2, 4.0, PHIc);
469  sin6phi = TCEA_COEFF_TIMES_SIN(c3, 6.0, PHIc);
470  Mc = TCEA_M(phi, sin2phi, sin4phi, sin6phi);
471
472  *Northing = Tcea_Scale_Factor * (Mc - M0) + Tcea_False_Northing;
473  }
474  return (Error_Code);
475 } /* END OF Convert_Geodetic_To_Trans_Cyl_Eq_Area */
ossim_uint32 x
#define TCEA_LON_WARNING
#define TCEA_COEFF_TIMES_SIN(coeff, x, latit)
#define M_PI
#define TCEA_M(c0lat, c1lat, c2lat, c3lat)
#define TCEA_Q(sinlat, x)
#define TCEA_L(Beta, c0lat, c1lat, c2lat)
◆ Convert_Trans_Cyl_Eq_Area_To_Geodetic()
long ossimTransCylEquAreaProjection::Convert_Trans_Cyl_Eq_Area_To_Geodetic ( double  Easting,
double  Northing,
double *  Latitude,
double *  Longitude
) const
private
The function Convert_Trans_Cyl_Eq_Area_To_Geodetic converts Transverse Cylindrical Equal Area projection easting and northing coordinates to geodetic (latitude and longitude) coordinates. coordinates, according to the current ellipsoid and Transverse Cylindrical Equal Area projection If any errors occur, the error code(s) are returned by the function, otherwise TCEA_NO_ERROR is returned.
Easting : Easting (X) in meters (input) Northing : Northing (Y) in meters (input) Latitude : Latitude (phi) in radians (output) Longitude : Longitude (lambda) in radians (output)
Definition at line 478 of file ossimTransCylEquAreaProjection.cpp.
References a0, a1, a2, b0, b1, b2, b3, c0, es, es2, M0, qp, Tcea_a, TCEA_COEFF_TIMES_SIN, Tcea_False_Easting, Tcea_False_Northing, TCEA_L, TCEA_NO_ERROR, Tcea_Origin_Long, TCEA_Q, Tcea_Scale_Factor, and x.
Referenced by inverse().
482 { /* BEGIN Convert_Trans_Cyl_Eq_Area_To_Geodetic */
483 /*
484  * The function Convert_Trans_Cyl_Eq_Area_To_Geodetic converts Transverse
485  * Cylindrical Equal Area projection (easting and northing) coordinates
486  * to geodetic (latitude and longitude) coordinates, according to the
487  * current ellipsoid and Transverse Cylindrical Equal Area projection
488  * coordinates. If any errors occur, the error code(s) are returned by the
489  * function, otherwise TCEA_NO_ERROR is returned.
490  *
491  * Easting : Easting (X) in meters (input)
492  * Northing : Northing (Y) in meters (input)
493  * Latitude : Latitude (phi) in radians (output)
494  * Longitude : Longitude (lambda) in radians (output)
495  */
496
497  double x;
498  double dx; /* Delta easting - Difference in easting (easting-FE) */
499  double dy; /* Delta northing - Difference in northing (northing-FN) */
500  double Mc;
501  double MUc;
502  double sin2mu, sin4mu, sin6mu, sin8mu;
503  double PHIc;
504  double Qc;
505  double sin_lat;
506  double beta, betac, beta_prime;
507  double sin2beta, sin4beta, sin6beta;
508  double cosbetac;
509  double Qc_OVER_qp;
510  double temp;
511
512  long Error_Code = TCEA_NO_ERROR;
513
514 // if ((Easting < (Tcea_False_Easting + Tcea_Min_Easting))
515 // || (Easting > (Tcea_False_Easting + Tcea_Max_Easting)))
516 // { /* Easting out of range */
517 // Error_Code |= TCEA_EASTING_ERROR;
518 // }
519 // if ((Northing < (Tcea_False_Northing + Tcea_Min_Northing))
520 // || (Northing > (Tcea_False_Northing + Tcea_Max_Northing)))
521 // { /* Northing out of range */
522 // Error_Code |= TCEA_NORTHING_ERROR;
523 // }
524  if (!Error_Code)
525  { /* no errors */
526  dy = Northing - Tcea_False_Northing;
527  dx = Easting - Tcea_False_Easting;
528  Mc = M0 + dy / Tcea_Scale_Factor;
529  MUc = Mc / (Tcea_a * c0);
530
531  sin2mu = TCEA_COEFF_TIMES_SIN(b0, 2.0, MUc);
532  sin4mu = TCEA_COEFF_TIMES_SIN(b1, 4.0, MUc);
533  sin6mu = TCEA_COEFF_TIMES_SIN(b2, 6.0, MUc);
534  sin8mu = TCEA_COEFF_TIMES_SIN(b3, 8.0, MUc);
535  PHIc = MUc + sin2mu + sin4mu + sin6mu + sin8mu;
536
537  sin_lat = sin(PHIc);
538  x = es * sin_lat;
539  Qc = TCEA_Q(sin_lat, x);
540  Qc_OVER_qp = Qc / qp;
541
542  if (Qc_OVER_qp < -1.0)
543  Qc_OVER_qp = -1.0;
544  else if (Qc_OVER_qp > 1.0)
545  Qc_OVER_qp = 1.0;
546
547  betac = asin(Qc_OVER_qp);
548  cosbetac = cos(betac);
549  temp = Tcea_Scale_Factor * dx * cosbetac * sqrt(1.0 -
550  es2 * sin_lat * sin_lat) / (Tcea_a * cos(PHIc));
551  if (temp > 1.0)
552  temp = 1.0;
553  else if (temp < -1.0)
554  temp = -1.0;
555  beta_prime = -asin(temp);
556  beta = asin(cos(beta_prime) * sin(betac));
557
558  sin2beta = TCEA_COEFF_TIMES_SIN(a0, 2.0, beta);
559  sin4beta = TCEA_COEFF_TIMES_SIN(a1, 4.0, beta);
560  sin6beta = TCEA_COEFF_TIMES_SIN(a2, 6.0, beta);
561  *Latitude = TCEA_L(beta, sin2beta, sin4beta, sin6beta);
562
563  *Longitude = Tcea_Origin_Long - atan(tan(beta_prime) / cosbetac);
564
565 // if (*Latitude > PI_OVER_2) /* force distorted values to 90, -90 degrees */
566 // *Latitude = PI_OVER_2;
567 // else if (*Latitude < -PI_OVER_2)
568 // *Latitude = -PI_OVER_2;
569
570 // if (*Longitude > M_PI)
571 // *Longitude -= TWO_PI;
572 // if (*Longitude < -M_PI)
573 // *Longitude += TWO_PI;
574
575 // if (*Longitude > M_PI) /* force distorted values to 180, -180 degrees */
576 // *Longitude = M_PI;
577 // else if (*Longitude < -M_PI)
578 // *Longitude = -M_PI;
579  }
580  return (Error_Code);
581 } /* END OF Convert_Trans_Cyl_Eq_Area_To_Geodetic */
ossim_uint32 x
◆ dup()
virtual ossimObject* ossimTransCylEquAreaProjection::dup ( ) const
inlinevirtual
Implements ossimProjection.
Definition at line 31 of file ossimTransCylEquAreaProjection.h.
31 {return new ossimTransCylEquAreaProjection(*this);}
ossimTransCylEquAreaProjection(const ossimEllipsoid &ellipsoid=ossimEllipsoid(6378137, 6356752.3142), const ossimGpt &origin=ossimGpt())
◆ forward()
ossimDpt ossimTransCylEquAreaProjection::forward ( const ossimGpt worldPoint) const
virtual
Definition at line 160 of file ossimTransCylEquAreaProjection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_Trans_Cyl_Eq_Area(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), and ossimMapProjection::theDatum.
161 {
162  double easting = 0.0;
163  double northing = 0.0;
164  ossimGpt gpt = latLon;
165
166  if (theDatum)
167  {
168  if (theDatum->code() != latLon.datum()->code())
169  {
170  gpt.changeDatum(theDatum); // Shift to our datum.
171  }
172  }
173
175  gpt.lonr(),
176  &easting,
177  &northing);
178
179  return ossimDpt(easting, northing);
180 }
virtual const ossimString & code() const
Definition: ossimDatum.h:57
void changeDatum(const ossimDatum *datum)
This will actually perform a shift.
Definition: ossimGpt.cpp:316
double lonr() const
Returns the longitude in radian measure.
Definition: ossimGpt.h:76
long Convert_Geodetic_To_Trans_Cyl_Eq_Area(double Latitude, double Longitude, double *Easting, double *Northing) const
double latr() const
latr().
Definition: ossimGpt.h:66
const ossimDatum * theDatum
◆ Get_Trans_Cyl_Eq_Area_Parameters()
void ossimTransCylEquAreaProjection::Get_Trans_Cyl_Eq_Area_Parameters ( double *  a,
double *  f,
double *  Origin_Latitude,
double *  Central_Meridian,
double *  False_Easting,
double *  False_Northing,
double *  Scale_Factor
) const
private
The function Get_Trans_Cyl_Eq_Area_Parameters returns the current ellipsoid parameters, Transverse Cylindrical Equal Area projection parameters, and scale factor.
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output) Origin_Latitude : Latitude in radians at which the (output) point scale factor is 1.0 Central_Meridian : Longitude in radians at the center of (output) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (output) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (output) Scale_Factor : Multiplier which reduces distances in the projection to the actual distance on the ellipsoid (output)
Definition at line 337 of file ossimTransCylEquAreaProjection.cpp.
References Tcea_a, Tcea_f, Tcea_False_Easting, Tcea_False_Northing, Tcea_Origin_Lat, Tcea_Origin_Long, and Tcea_Scale_Factor.
344 { /* BEGIN Get_Trans_Cyl_Eq_Area_Parameters */
345 /*
346  * The function Get_Trans_Cyl_Eq_Area_Parameters returns the current ellipsoid
347  * parameters, Transverse Cylindrical Equal Area projection parameters, and scale factor.
348  *
349  * a : Semi-major axis of ellipsoid, in meters (output)
350  * f : Flattening of ellipsoid (output)
351  * Origin_Latitude : Latitude in radians at which the (output)
352  * point scale factor is 1.0
353  * Central_Meridian : Longitude in radians at the center of (output)
354  * the projection
355  * False_Easting : A coordinate value in meters assigned to the
356  * central meridian of the projection. (output)
357  * False_Northing : A coordinate value in meters assigned to the
358  * origin latitude of the projection (output)
359  * Scale_Factor : Multiplier which reduces distances in the
360  * projection to the actual distance on the
361  * ellipsoid (output)
362  */
363
364  *a = Tcea_a;
365  *f = Tcea_f;
366  *Origin_Latitude = Tcea_Origin_Lat;
367  *Central_Meridian = Tcea_Origin_Long;
368  *False_Easting = Tcea_False_Easting;
369  *False_Northing = Tcea_False_Northing;
370  *Scale_Factor = Tcea_Scale_Factor;
371
372  return;
373 } /* END OF Get_Trans_Cyl_Eq_Area_Parameters */
◆ getFalseEasting()
double ossimTransCylEquAreaProjection::getFalseEasting ( ) const
inlinevirtual
Returns
The false easting.
Definition at line 66 of file ossimTransCylEquAreaProjection.h.
◆ getFalseNorthing()
double ossimTransCylEquAreaProjection::getFalseNorthing ( ) const
inlinevirtual
Returns
The false northing.
Definition at line 67 of file ossimTransCylEquAreaProjection.h.
◆ getScaleFactor()
double ossimTransCylEquAreaProjection::getScaleFactor ( ) const
inline
◆ inverse()
ossimGpt ossimTransCylEquAreaProjection::inverse ( const ossimDpt projectedPoint) const
virtual
Definition at line 147 of file ossimTransCylEquAreaProjection.cpp.
References Convert_Trans_Cyl_Eq_Area_To_Geodetic(), DEG_PER_RAD, ossimMapProjection::theDatum, ossimDpt::x, and ossimDpt::y.
148 {
149  double lat = 0.0;
150  double lon = 0.0;
151
152  Convert_Trans_Cyl_Eq_Area_To_Geodetic(eastingNorthing.x,
153  eastingNorthing.y,
154  &lat,
155  &lon);
156
157  return ossimGpt(lat*DEG_PER_RAD, lon*DEG_PER_RAD, 0.0, theDatum);
158 }
#define DEG_PER_RAD
long Convert_Trans_Cyl_Eq_Area_To_Geodetic(double Easting, double Northing, double *Latitude, double *Longitude) const
◆ loadState()
bool ossimTransCylEquAreaProjection::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 192 of file ossimTransCylEquAreaProjection.cpp.
References ossimKeywordlist::find(), ossimMapProjection::loadState(), ossimKeywordNames::SCALE_FACTOR_KW, setDefaults(), STATIC_TYPE_NAME, Tcea_False_Easting, Tcea_False_Northing, Tcea_Scale_Factor, ossimMapProjection::theFalseEastingNorthing, ossimString::toDouble(), ossimKeywordNames::TYPE_KW, update(), ossimDpt::x, and ossimDpt::y.
194 {
195  bool flag = ossimMapProjection::loadState(kwl, prefix);
196  const char* type = kwl.find(prefix, ossimKeywordNames::TYPE_KW);
197  const char* scaleFactor = kwl.find(prefix, ossimKeywordNames::SCALE_FACTOR_KW);
198
199  setDefaults();
200
202  {
205
206  if(scaleFactor)
207  {
208  Tcea_Scale_Factor = ossimString(scaleFactor).toDouble();
209  }
210  }
211
212  update();
213
214  return flag;
215 }
double y
Definition: ossimDpt.h:165
static const char * TYPE_KW
#define STATIC_TYPE_NAME(T)
Definition: ossimRtti.h:325
double toDouble() const
double x
Definition: ossimDpt.h:164
static const char * SCALE_FACTOR_KW
◆ operator==()
bool ossimTransCylEquAreaProjection::operator== ( const ossimProjection projection) const
virtual
Definition at line 586 of file ossimTransCylEquAreaProjection.cpp.
References ossim::almostEqual(), and Tcea_Scale_Factor.
587 {
588  if (!ossimMapProjection::operator==(proj))
589  return false;
590
592  dynamic_cast<const ossimTransCylEquAreaProjection*>(&proj);
593  if (!p) return false;
594
596
597  return true;
598 }
bool almostEqual(T x, T y, T tolerance=FLT_EPSILON)
Definition: ossimCommon.h:53
◆ saveState()
bool ossimTransCylEquAreaProjection::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 182 of file ossimTransCylEquAreaProjection.cpp.
References ossimKeywordlist::add(), ossimMapProjection::saveState(), ossimKeywordNames::SCALE_FACTOR_KW, and Tcea_Scale_Factor.
183 {
184  kwl.add(prefix,
187  true);
188
189  return ossimMapProjection::saveState(kwl, prefix);
190 }
◆ Set_Trans_Cyl_Eq_Area_Parameters()
long ossimTransCylEquAreaProjection::Set_Trans_Cyl_Eq_Area_Parameters ( double  a,
double  f,
double  Scale_Factor
private
Definition at line 217 of file ossimTransCylEquAreaProjection.cpp.
References a0, a1, a2, b0, b1, b2, b3, c0, c1, c2, c3, Convert_Geodetic_To_Trans_Cyl_Eq_Area(), es, es2, es4, es6, M0, M_PI, One_MINUS_es2, One_OVER_2es, PI_OVER_2, qp, Tcea_a, TCEA_COEFF_TIMES_SIN, Tcea_f, Tcea_False_Easting, Tcea_False_Northing, TCEA_M, Tcea_Max_Northing, Tcea_Min_Northing, TCEA_NO_ERROR, Tcea_Origin_Lat, Tcea_Origin_Long, TCEA_Q, Tcea_Scale_Factor, TWO_PI, and x.
Referenced by update().
224 { /* BEGIN Set_Trans_Cyl_Eq_Area_Parameters */
225 /*
226  * The function Set_Trans_Cyl_Eq_Area_Parameters receives the ellipsoid parameters and
227  * Transverse Cylindrical Equal Area projection parameters as inputs, and sets the
228  * corresponding state variables. If any errors occur, the error code(s) are returned
229  * by the function, otherwise TCEA_NO_ERROR is returned.
230  *
231  * a : Semi-major axis of ellipsoid, in meters (input)
232  * f : Flattening of ellipsoid (input)
233  * Origin_Latitude : Latitude in radians at which the (input)
234  * point scale factor is 1.0
235  * Central_Meridian : Longitude in radians at the center of (input)
236  * the projection
237  * False_Easting : A coordinate value in meters assigned to the
238  * central meridian of the projection. (input)
239  * False_Northing : A coordinate value in meters assigned to the
240  * origin latitude of the projection (input)
241  * Scale_Factor : Multiplier which reduces distances in the
242  * projection to the actual distance on the
243  * ellipsoid (input)
244  */
245
246  double sin_lat_90 = sin(PI_OVER_2);
247  double x, j, three_es4;
248  double Sqrt_One_MINUS_es2;
249  double e1, e2, e3, e4;
250  double lat, sin2lat, sin4lat, sin6lat;
251  double temp, temp_northing;
252 // double inv_f = 1 / f;
253  long Error_Code = TCEA_NO_ERROR;
254
255 // if (a <= 0.0)
256 // { /* Semi-major axis must be greater than zero */
257 // Error_Code |= TCEA_A_ERROR;
258 // }
259 // if ((inv_f < 250) || (inv_f > 350))
260 // { /* Inverse flattening must be between 250 and 350 */
261 // Error_Code |= TCEA_INV_F_ERROR;
262 // }
263 // if ((Origin_Latitude < -PI_OVER_2) || (Origin_Latitude > PI_OVER_2))
264 // { /* origin latitude out of range */
265 // Error_Code |= TCEA_ORIGIN_LAT_ERROR;
266 // }
267 // if ((Central_Meridian < -M_PI) || (Central_Meridian > TWO_PI))
268 // { /* origin longitude out of range */
269 // Error_Code |= TCEA_CENT_MER_ERROR;
270 // }
271 // if ((Scale_Factor < MIN_SCALE_FACTOR) || (Scale_Factor > MAX_SCALE_FACTOR))
272 // {
273 // Error_Code |= TCEA_SCALE_FACTOR_ERROR;
274 // }
275
276  if (!Error_Code)
277  { /* no errors */
278  Tcea_a = a;
279  Tcea_f = f;
280  Tcea_Origin_Lat = Origin_Latitude;
281  if (Central_Meridian > M_PI)
282  Central_Meridian -= TWO_PI;
283  Tcea_Origin_Long = Central_Meridian;
284  Tcea_False_Northing = False_Northing;
285  Tcea_False_Easting = False_Easting;
286  Tcea_Scale_Factor = Scale_Factor;
287
288  es2 = 2 * Tcea_f - Tcea_f * Tcea_f;
289  es = sqrt(es2);
290  One_MINUS_es2 = 1.0 - es2;
291  Sqrt_One_MINUS_es2 = sqrt(One_MINUS_es2);
292  One_OVER_2es = 1.0 / (2.0 * es);
293  es4 = es2 * es2;
294  es6 = es4 * es2;
295  x = es * sin_lat_90;
296  qp = TCEA_Q(sin_lat_90,x);
297
298  a0 = es2 / 3.0 + 31.0 * es4 / 180.0 + 517.0 * es6 / 5040.0;
299  a1 = 23.0 * es4 / 360.0 + 251.0 * es6 / 3780.0;
300  a2 = 761.0 * es6 / 45360.0;
301
302  e1 = (1.0 - Sqrt_One_MINUS_es2) / (1.0 + Sqrt_One_MINUS_es2);
303  e2 = e1 * e1;
304  e3 = e2 * e1;
305  e4 = e3 * e1;
306  b0 = 3.0 * e1 / 2.0 - 27.0 * e3 / 32.0;
307  b1 = 21.0 * e2 / 16.0 - 55.0 * e4 / 32.0;
308  b2 = 151.0 * e3 / 96.0;
309  b3 = 1097.0 * e4 / 512.0;
310
311  j = 45.0 * es6 / 1024.0;
312  three_es4 = 3.0 * es4;
313  c0 = 1.0 - es2 / 4.0 - three_es4 / 64.0 - 5.0 * es6 / 256.0;
314  c1 = 3.0 * es2 / 8.0 + three_es4 / 32.0 + j;
315  c2 = 15.0 * es4 / 256.0 + j;
316  c3 = 35.0 * es6 / 3072.0;
317  lat = c0 * Tcea_Origin_Lat;
318  sin2lat = TCEA_COEFF_TIMES_SIN(c1, 2.0, Tcea_Origin_Lat);
319  sin4lat = TCEA_COEFF_TIMES_SIN(c2, 4.0, Tcea_Origin_Lat);
320  sin6lat = TCEA_COEFF_TIMES_SIN(c3, 6.0, Tcea_Origin_Lat);
321  M0 = TCEA_M(lat, sin2lat, sin4lat, sin6lat);
322  Convert_Geodetic_To_Trans_Cyl_Eq_Area(PI_OVER_2, M_PI, &temp, &temp_northing);
323  if (temp_northing > 0)
324  {
325  Tcea_Min_Northing = temp_northing - 20003931.458986;
326  Tcea_Max_Northing = temp_northing;
327  }
328  else if (temp_northing < 0)
329  {
330  Tcea_Max_Northing = temp_northing + 20003931.458986;
331  Tcea_Min_Northing = temp_northing;
332  }
333  } /* END OF if(!Error_Code) */
334  return (Error_Code);
335 } /* END OF Set_Trans_Cyl_Eq_Area_Parameters */
ossim_uint32 x
#define M_PI
◆ setDefaults()
void ossimTransCylEquAreaProjection::setDefaults ( )
◆ setFalseEasting()
void ossimTransCylEquAreaProjection::setFalseEasting ( double  falseEasting)
Definition at line 77 of file ossimTransCylEquAreaProjection.cpp.
References Tcea_False_Easting, and update().
◆ setFalseEastingNorthing()
void ossimTransCylEquAreaProjection::setFalseEastingNorthing ( double  falseEasting,
Definition at line 92 of file ossimTransCylEquAreaProjection.cpp.
References Tcea_False_Easting, Tcea_False_Northing, and update().
◆ setFalseNorthing()
void ossimTransCylEquAreaProjection::setFalseNorthing ( double  falseNorthing)
Definition at line 85 of file ossimTransCylEquAreaProjection.cpp.
References Tcea_False_Northing, and update().
◆ setParameters()
void ossimTransCylEquAreaProjection::setParameters ( double  falseEasting,
double  scaleFactor
◆ setScaleFactor()
void ossimTransCylEquAreaProjection::setScaleFactor ( double  scaleFactor)
Definition at line 101 of file ossimTransCylEquAreaProjection.cpp.
References Tcea_Scale_Factor, and update().
102 {
103  Tcea_Scale_Factor = scaleFactor;
104
105  update();
106 }
◆ update()
void ossimTransCylEquAreaProjection::update ( )
virtual
Definition at line 130 of file ossimTransCylEquAreaProjection.cpp.
References ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), ossimGpt::latr(), ossimGpt::lonr(), Set_Trans_Cyl_Eq_Area_Parameters(), Tcea_False_Easting, Tcea_False_Northing, Tcea_Scale_Factor, ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, ossimMapProjection::theOrigin, ossimMapProjection::update(), ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), ossimTransCylEquAreaProjection(), setFalseEasting(), setFalseEastingNorthing(), setFalseNorthing(), setParameters(), and setScaleFactor().
131 {
134  theOrigin.latr(),
135  theOrigin.lonr(),
139
142
144 }
double y
const double & getA() const
double lonr() const
long Set_Trans_Cyl_Eq_Area_Parameters(double a, double f, double Origin_Latitude, double Central_Meridian, double False_Easting, double False_Northing, double Scale_Factor)
double x
double latr() const
latr().
const double & getFlattening() const
Member Data Documentation
◆ a0
double ossimTransCylEquAreaProjection::a0
mutableprivate
◆ a1
double ossimTransCylEquAreaProjection::a1
mutableprivate
◆ a2
double ossimTransCylEquAreaProjection::a2
mutableprivate
◆ b0
double ossimTransCylEquAreaProjection::b0
mutableprivate
◆ b1
double ossimTransCylEquAreaProjection::b1
mutableprivate
◆ b2
double ossimTransCylEquAreaProjection::b2
mutableprivate
◆ b3
double ossimTransCylEquAreaProjection::b3
mutableprivate
◆ c0
double ossimTransCylEquAreaProjection::c0
mutableprivate
◆ c1
double ossimTransCylEquAreaProjection::c1
mutableprivate
◆ c2
double ossimTransCylEquAreaProjection::c2
mutableprivate
◆ c3
double ossimTransCylEquAreaProjection::c3
mutableprivate
◆ es
double ossimTransCylEquAreaProjection::es
mutableprivate
◆ es2
double ossimTransCylEquAreaProjection::es2
mutableprivate
◆ es4
double ossimTransCylEquAreaProjection::es4
mutableprivate
Definition at line 92 of file ossimTransCylEquAreaProjection.h.
Referenced by Set_Trans_Cyl_Eq_Area_Parameters().
◆ es6
double ossimTransCylEquAreaProjection::es6
mutableprivate
Definition at line 93 of file ossimTransCylEquAreaProjection.h.
◆ M0
double ossimTransCylEquAreaProjection::M0
mutableprivate
◆ One_MINUS_es2
double ossimTransCylEquAreaProjection::One_MINUS_es2
mutableprivate
Definition at line 97 of file ossimTransCylEquAreaProjection.h.
◆ One_OVER_2es
double ossimTransCylEquAreaProjection::One_OVER_2es
mutableprivate
Definition at line 98 of file ossimTransCylEquAreaProjection.h.
◆ qp
double ossimTransCylEquAreaProjection::qp
mutableprivate
◆ Tcea_a
double ossimTransCylEquAreaProjection::Tcea_a
mutableprivate
◆ Tcea_f
double ossimTransCylEquAreaProjection::Tcea_f
mutableprivate
◆ Tcea_False_Easting
double ossimTransCylEquAreaProjection::Tcea_False_Easting
mutableprivate
◆ Tcea_False_Northing
double ossimTransCylEquAreaProjection::Tcea_False_Northing
mutableprivate
◆ Tcea_Max_Easting
double ossimTransCylEquAreaProjection::Tcea_Max_Easting
mutableprivate
◆ Tcea_Max_Northing
double ossimTransCylEquAreaProjection::Tcea_Max_Northing
mutableprivate
◆ Tcea_Min_Easting
double ossimTransCylEquAreaProjection::Tcea_Min_Easting
mutableprivate
◆ Tcea_Min_Northing
double ossimTransCylEquAreaProjection::Tcea_Min_Northing
mutableprivate
◆ Tcea_Origin_Lat
double ossimTransCylEquAreaProjection::Tcea_Origin_Lat
mutableprivate
◆ Tcea_Origin_Long
double ossimTransCylEquAreaProjection::Tcea_Origin_Long
mutableprivate
◆ Tcea_Scale_Factor
double ossimTransCylEquAreaProjection::Tcea_Scale_Factor
mutableprivate
