ossimTrimFilter Class Reference
#include <ossimTrimFilter.h>
Inheritance diagram for ossimTrimFilter:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimTrimFilter ()
ossimRefPtr< ossimImageDatagetTile (const ossimIrect &rect, ossim_uint32 resLevel=0)
virtual void initialize ()
virtual bool saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const
 Set property. More...
 Adds this objects properties to the list. More...
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
virtual ~ossimTrimFilter ()
virtual ~ossimReferenced ()
Protected Attributes
double theLeftPercent
double theRightPercent
double theTopPercent
double theBottomPercent
std::vector< ossimIpttheValidVertices
ossimRefPtr< ossimPolyCuttertheCutter
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Additional Inherited Members
Detailed Description
Definition at line 17 of file ossimTrimFilter.h.
◆ ossimTrimFilter()
ossimTrimFilter::ossimTrimFilter ( )
Definition at line 25 of file ossimTrimFilter.cpp.
References theCutter.
27  theLeftPercent(0.0),
28  theRightPercent(0.0),
29  theTopPercent(0.0),
30  theBottomPercent(0.0)
31 {
33 }
ossimImageSourceFilter(ossimObject *owner=NULL)
ossimRefPtr< ossimPolyCutter > theCutter
◆ ~ossimTrimFilter()
ossimTrimFilter::~ossimTrimFilter ( )
protectedvirtual
Definition at line 35 of file ossimTrimFilter.cpp.
36 {
37  theCutter = 0;
38 }
Member Function Documentation
◆ getBoundingRect()
ossimIrect ossimTrimFilter::getBoundingRect ( ossim_uint32  resLevel = 0) const
virtual
This will return the bounding rect of the source.
We can have several sources which are in a chain to modify the bounding image rect. lets say you are next to an image handler then it will return the bounding rect for that image. If you are at the right side of a resampler then you will get a bounding rect along the image view plane. This is going to be a very import method for both image writers, mosaics or anything that needs to operate only within the bounds of an image.
Definition at line 204 of file ossimTrimFilter.cpp.
References getValidImageVertices(), ossimIrect::makeNan(), and OSSIM_CLOCKWISE_ORDER.
205 {
206
207  vector<ossimIpt> validVertices;
208  ossimIrect result;
209  result.makeNan();
210  getValidImageVertices(validVertices, OSSIM_CLOCKWISE_ORDER, resLevel);
211
212  if(validVertices.size())
213  {
214  result = ossimIrect(validVertices);
215  }
216
217  return result;
218 }
virtual void getValidImageVertices(vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const
void makeNan()
Definition: ossimIrect.h:329
◆ getProperty()
ossimRefPtr< ossimProperty > ossimTrimFilter::getProperty ( const ossimString name) const
virtual
Definition at line 287 of file ossimTrimFilter.cpp.
References ossimImageSourceFilter::getProperty(), ossimProperty::setFullRefreshBit(), theBottomPercent, theLeftPercent, theRightPercent, theTopPercent, and ossimString::toString().
288 {
289  ossimProperty* prop = 0;
290  if(name == "left_percent")
291  {
292  prop = new ossimNumericProperty(name,
294  0.0, 1.0);
295  prop->setFullRefreshBit();
296  }
297  else if(name == "right_percent")
298  {
299  prop = new ossimNumericProperty(name,
301  0.0, 1.0);
302  prop->setFullRefreshBit();
303  }
304  else if(name == "top_percent")
305  {
306  prop = new ossimNumericProperty(name,
308  0.0, 1.0);
309  prop->setFullRefreshBit();
310  }
311  else if(name == "bottom_percent")
312  {
313  prop = new ossimNumericProperty(name,
315  0.0, 1.0);
316  prop->setFullRefreshBit();
317  }
318
319  if(prop) return prop;
320
322 }
Numeric to string methods.
void setFullRefreshBit()
◆ getPropertyNames()
void ossimTrimFilter::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Parameters
propertyNamesArray to add to.
Note
This method does not clear propertyNames prior to adding it's names.
Definition at line 351 of file ossimTrimFilter.cpp.
352 {
353  propertyNames.push_back("left_percent");
354  propertyNames.push_back("right_percent");
355  propertyNames.push_back("top_percent");
356  propertyNames.push_back("bottom_percent");
357 }
◆ getTile()
ossimRefPtr< ossimImageData > ossimTrimFilter::getTile ( const ossimIrect rect,
virtual
Returns
Definition at line 40 of file ossimTrimFilter.cpp.
References ossimDataObject::getDataObjectStatus(), ossimPolyCutter::getTile(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), OSSIM_EMPTY, OSSIM_NULL, theCutter, ossimImageSourceFilter::theInputConnection, theValidVertices, and ossimRefPtr< T >::valid().
43 {
45  {
46  return NULL;
47  }
48
49  if(!theValidVertices.size())
50  {
51  return ossimImageSourceFilter::getTile(rect, resLevel);
52  }
53
55  theCutter->getTile(rect, resLevel);
56
57  if(!isSourceEnabled()||!tile.valid())
58  {
59  return tile;
60  }
61  if(tile->getDataObjectStatus() == OSSIM_NULL ||
63  {
64  return tile;
65  }
66
67  return theCutter->getTile(rect, resLevel);
68 // theTile->setImageRectangle(rect);
69 // theTile->setDataObjectStatus(OSSIM_FULL);
70
71 // theTile->makeBlank();
72 // ossimIrect boundingRect = getBoundingRect(resLevel);
73 // ossimIrect tileRect = tile->getImageRectangle();
74 // ossimIrect clipRect = boundingRect.clipToRect(tileRect);
75
76 // theTile->loadTile(tile->getBuf(),
77 // tile->getImageRectangle(),
78 // clipRect,
79 // OSSIM_BSQ);
80
81 // theTile->validate();
82
83 }
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
std::vector< ossimIpt > theValidVertices
◆ getValidImageVertices()
void ossimTrimFilter::getValidImageVertices ( vector< ossimIpt > &  validVertices,
ossimVertexOrdering  ordering = OSSIM_CLOCKWISE_ORDER,
) const
virtual
Definition at line 85 of file ossimTrimFilter.cpp.
References FLT_EPSILON, ossimImageSource::getValidImageVertices(), ossimDpt::length(), theBottomPercent, theLeftPercent, theRightPercent, theTopPercent, ossimDpt::x, and ossimDpt::y.
Referenced by getBoundingRect(), and initialize().
89 {
91  ordering,
92  resLevel);
93  if(validVertices.size()==4)
94  {
95  ossimDpt averagePt((ossimDpt(validVertices[0])+
96  ossimDpt(validVertices[1])+
97  ossimDpt(validVertices[2])+
98  ossimDpt(validVertices[3]))*.25);
99  ossimDpt averageTop( ( ossimDpt(validVertices[0]+
100  validVertices[1])*.5) );
101  ossimDpt averageBottom( ( ossimDpt(validVertices[2]+
102  validVertices[3])*.5 ) );
103  ossimDpt averageLeft( (ossimDpt(validVertices[0]+
104  validVertices[3])*.5) );
105  ossimDpt averageRight( (ossimDpt(validVertices[1]+
106  validVertices[2])*.5) );
107
108  ossimDpt topAxis = (averageTop-averagePt);
109  ossimDpt rightAxis = (averageRight-averagePt);
110  ossimDpt leftAxis = (averageLeft-averagePt);
111  ossimDpt bottomAxis = (averageBottom-averagePt);
112
113  double topLen = topAxis.length();
114  double bottomLen = bottomAxis.length();
115  double rightLen = rightAxis.length();
116  double leftLen = leftAxis.length();
117
118  if((topLen > FLT_EPSILON)&&
119  (bottomLen > FLT_EPSILON)&&
120  (leftLen > FLT_EPSILON)&&
121  (rightLen > FLT_EPSILON))
122  {
123  topAxis = topAxis*(1.0/topLen);
124  bottomAxis = bottomAxis*(1.0/bottomLen);
125  leftAxis = leftAxis*(1.0/leftLen);
126  rightAxis = rightAxis*(1.0/rightLen);
127
128  ossim_uint32 idx = 0;
129  ossim_uint32 count = 0;
130  for(idx = 0; idx < validVertices.size(); ++idx)
131  {
132  ossimDpt axis[2];
133  double axisLen[2];
134  ossimDpt diff = validVertices[idx]-averagePt;
135  double testLen = (topAxis.x*diff.x+
136  topAxis.y*diff.y);
137  count = 0;
138  if(testLen >= -FLT_EPSILON)
139  {
140  axis[count] = topAxis;
141  axisLen[count] = testLen*(1.0-theTopPercent);
142  ++count;
143  }
144
145  if(count < 2)
146  {
147  testLen = (bottomAxis.x*diff.x+
148  bottomAxis.y*diff.y);
149  if(testLen >= -FLT_EPSILON)
150  {
151  axis[count] = bottomAxis;
152  axisLen[count] = testLen*(1.0-theBottomPercent);
153  ++count;
154  }
155  }
156  if(count < 2)
157  {
158  testLen = (leftAxis.x*diff.x+
159  leftAxis.y*diff.y);
160  if(testLen >= -FLT_EPSILON)
161  {
162  axis[count] = leftAxis;
163  axisLen[count] = testLen*(1.0-theLeftPercent);
164  ++count;
165  }
166  }
167  if(count < 2)
168  {
169  testLen = (rightAxis.x*diff.x+
170  rightAxis.y*diff.y);
171  if(testLen >= -FLT_EPSILON)
172  {
173  axis[count] = rightAxis;
174  axisLen[count] = testLen*(1.0-theRightPercent);
175  ++count;
176  }
177  }
178  if(count == 2)
179  {
180  validVertices[idx] = (averagePt + (axis[0]*axisLen[0] +
181  axis[1]*axisLen[1]));
182  }
183  }
184  }
185  }
186 // ossimIrect rect = getBoundingRect();
187
188 // if(ordering == OSSIM_CLOCKWISE_ORDER)
189 // {
190 // validVertices.push_back(rect.ul());
191 // validVertices.push_back(rect.ur());
192 // validVertices.push_back(rect.lr());
193 // validVertices.push_back(rect.ll());
194 // }
195 // else
196 // {
197 // validVertices.push_back(rect.ul());
198 // validVertices.push_back(rect.ll());
199 // validVertices.push_back(rect.lr());
200 // validVertices.push_back(rect.ur());
201 // }
202 }
double y
Definition: ossimDpt.h:165
double length() const
Definition: ossimDpt.h:81
#define FLT_EPSILON
virtual void getValidImageVertices(std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const
ordering specifies how the vertices should be arranged.
unsigned int ossim_uint32
double x
Definition: ossimDpt.h:164
◆ initialize()
void ossimTrimFilter::initialize ( )
virtual
Definition at line 220 of file ossimTrimFilter.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnectMyInput(), ossimConnectableObject::getInput(), getValidImageVertices(), ossimPolyCutter::initialize(), ossimPolyCutter::setNumberOfPolygons(), ossimPolyCutter::setPolygon(), theCutter, ossimImageSourceFilter::theInputConnection, and theValidVertices.
221 {
223  {
224  theCutter->disconnectMyInput(0, false, false);
225  if(getInput())
226  {
228  }
233  }
234 }
virtual ossimRefPtr< ossimConnectableObject > disconnectMyInput(ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true)
Will disconnect the object at the given input index and generate a connection event.
virtual void setPolygon(const vector< ossimDpt > &polygon, ossim_uint32 i=0)
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
virtual void initialize()
virtual void setNumberOfPolygons(ossim_uint32 count)
◆ loadState()
bool ossimTrimFilter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = NULL
virtual
Definition at line 259 of file ossimTrimFilter.cpp.
References ossimKeywordlist::find(), ossimImageSourceFilter::loadState(), theBottomPercent, theLeftPercent, theRightPercent, theTopPercent, and ossimString::toDouble().
261 {
262  const char* leftPerc = kwl.find(prefix, "left_percent");
263  const char* rightPerc = kwl.find(prefix, "right_percent");
264  const char* topPerc = kwl.find(prefix, "top_percent");
265  const char* bottomPerc = kwl.find(prefix, "bottom_percent");
266
267  if(leftPerc)
268  {
269  theLeftPercent = ossimString(leftPerc).toDouble();
270  }
271  if(rightPerc)
272  {
273  theRightPercent = ossimString(rightPerc).toDouble();
274  }
275  if(topPerc)
276  {
277  theTopPercent = ossimString(topPerc).toDouble();
278  }
279  if(bottomPerc)
280  {
281  theBottomPercent = ossimString(bottomPerc).toDouble();
282  }
283
284  return ossimImageSourceFilter::loadState(kwl, prefix);
285 }
double toDouble() const
◆ saveState()
bool ossimTrimFilter::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 236 of file ossimTrimFilter.cpp.
References ossimKeywordlist::add(), ossimImageSourceFilter::saveState(), theBottomPercent, theLeftPercent, theRightPercent, and theTopPercent.
238 {
239  kwl.add(prefix,
240  "left_percent",
242  true);
243  kwl.add(prefix,
244  "right_percent",
246  true);
247  kwl.add(prefix,
248  "top_percent",
250  true);
251  kwl.add(prefix,
252  "bottom_percent",
254  true);
255
256  return ossimImageSourceFilter::saveState(kwl, prefix);
257 }
◆ setProperty()
void ossimTrimFilter::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Set property.
Parameters
propertyProperty to set if property->getName() matches a property name of this object.
Definition at line 324 of file ossimTrimFilter.cpp.
References ossimImageSourceFilter::setProperty(), theBottomPercent, theLeftPercent, theRightPercent, theTopPercent, and ossimRefPtr< T >::valid().
325 {
326  if(!property.valid())return;
327  ossimString name = property->getName();
328
329  if(name == "left_percent")
330  {
331  theLeftPercent = property->valueToString().toDouble();
332  }
333  else if(name == "right_percent")
334  {
335  theRightPercent = property->valueToString().toDouble();
336  }
337  else if(name == "top_percent")
338  {
339  theTopPercent = property->valueToString().toDouble();
340  }
341  else if(name == "bottom_percent")
342  {
343  theBottomPercent = property->valueToString().toDouble();
344  }
345  else
346  {
347  return ossimImageSourceFilter::setProperty(property);
348  }
349 }
bool valid() const
Member Data Documentation
◆ theBottomPercent
double ossimTrimFilter::theBottomPercent
protected
◆ theCutter
ossimRefPtr<ossimPolyCutter> ossimTrimFilter::theCutter
protected
Definition at line 66 of file ossimTrimFilter.h.
Referenced by getTile(), initialize(), ossimTrimFilter(), and ~ossimTrimFilter().
◆ theLeftPercent
double ossimTrimFilter::theLeftPercent
protected
◆ theRightPercent
double ossimTrimFilter::theRightPercent
protected
◆ theTopPercent
double ossimTrimFilter::theTopPercent
protected
◆ theValidVertices
std::vector<ossimIpt> ossimTrimFilter::theValidVertices
protected
Definition at line 65 of file ossimTrimFilter.h.
Referenced by getTile(), and initialize().
