ossimVertexExtractor Class Reference
Class ossimVertexExtractor. More...
#include <ossimVertexExtractor.h>
Inheritance diagram for ossimVertexExtractor:
ossimOutputSource ossimProcessInterface ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimVertexExtractor (ossimImageSource *inputSource=NULL)
void setAreaOfInterest (const ossimIrect &rect)
virtual void setOutputName (const ossimString &filename)
virtual bool isOpen () const
virtual bool open ()
virtual void close ()
virtual bool execute ()
virtual ossimObjectgetObjectInterface ()
virtual ossimListenerManagergetListenerManagerInterface ()
bool canConnectMyInputTo (ossim_int32, const ossimConnectableObject *object) const
const vector< ossimIpt > & getVertices () const
- Public Member Functions inherited from ossimOutputSource
 ossimOutputSource (ossimObject *owner=NULL)
 ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true)
virtual ~ossimOutputSource ()
virtual bool open (const ossimString &outputName)
virtual const ossimStringgetOutputName ()
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
virtual void initialize ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
- Public Member Functions inherited from ossimProcessInterface
 ossimProcessInterface ()
virtual void abort ()
bool needsAborting () const
bool isAborted () const
bool isExecuting () const
void enableEvents ()
void disableEvents ()
Protected Member Functions
virtual ~ossimVertexExtractor ()
bool scanForEdges ()
bool extractVertices ()
template<class T1 >
void getMinAndIndex (T1 *start, T1 *end, T1 &minValue, ossim_int32 &offsetFromStart)
template<class T2 >
void getMaxAndIndex (T2 *start, T2 *end, T2 &maxValue, ossim_int32 &offsetFromStart)
bool writeVertices ()
 ossimVertexExtractor (const ossimVertexExtractor &)
 Disallow copy constructor and operator=. More...
const ossimVertexExtractoroperator= (const ossimVertexExtractor &rhs)
virtual ~ossimReferenced ()
Protected Attributes
ossimIrect theAreaOfInterest
ossimFilename theFilename
std::ofstream theFileStream
vector< ossimIpttheVertice
ossim_int32theLeftEdge
ossim_int32theRightEdge
- Protected Attributes inherited from ossimOutputSource
ossimString theOutputName
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
- Protected Attributes inherited from ossimProcessInterface
double thePercentComplete
ossimString theMessage
bool theEventFlag
Additional Inherited Members
- Public Types inherited from ossimProcessInterface
enum  ossimProcessStatus {
Detailed Description
Class designed to scan the area of interest and detect the valid vertices of non null image data.
Definition at line 31 of file ossimVertexExtractor.h.
◆ ossimVertexExtractor() [1/2]
ossimVertexExtractor::ossimVertexExtractor ( ossimImageSource inputSource = NULL)
Definition at line 25 of file ossimVertexExtractor.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimIrect::makeNan(), ossimNotify(), ossimNotifyLevel_WARN, and theAreaOfInterest.
26  :
27  ossimOutputSource(0, // owner
28  1,
29  0,
30  true,
31  true),
35  theFileStream(),
36  theVertice(4),
37  theLeftEdge(0),
38  theRightEdge(0)
39 {
40  if (inputSource == 0)
41  {
42  ossimNotify(ossimNotifyLevel_WARN) << "ossimVertexExtractor::ossimVertexExtractor ERROR"
43  << "\nNULL input image source passed to constructor!"
44  << std::endl;
45  }
46
47  connectMyInputTo(0, inputSource);
48 // theInputObjectList[0] = inputSource;
50 }
static const ossimFilename NIL
This was taken from Wx widgets for performing touch and access date stamps.
Definition: ossimFilename.h:40
ossimOutputSource(ossimObject *owner=NULL)
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
vector< ossimIpt > theVertice
void makeNan()
Definition: ossimIrect.h:329
◆ ~ossimVertexExtractor()
ossimVertexExtractor::~ossimVertexExtractor ( )
protectedvirtual
Definition at line 52 of file ossimVertexExtractor.cpp.
References theLeftEdge, and theRightEdge.
53 {
54  if (theLeftEdge)
55  {
56  delete [] theLeftEdge;
57  theLeftEdge = 0;
58  }
59  if (theRightEdge)
60  {
61  delete [] theRightEdge;
62  theRightEdge = 0;
63  }
64 }
◆ ossimVertexExtractor() [2/2]
ossimVertexExtractor::ossimVertexExtractor ( const ossimVertexExtractor )
inlineprotected
Definition at line 152 of file ossimVertexExtractor.h.
152 : theLeftEdge(0), theRightEdge(0) {}
Member Function Documentation
◆ canConnectMyInputTo()
bool ossimVertexExtractor::canConnectMyInputTo ( ossim_int32  myInputIndex,
const ossimConnectableObject object
) const
inlinevirtual
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 105 of file ossimVertexExtractor.h.
References PTR_CAST.
107  {
108
109  return (object&& PTR_CAST(ossimImageSource, object));
110  }
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
◆ close()
void ossimVertexExtractor::close ( )
virtual
Closes "theFileStream".
Implements ossimOutputSource.
Definition at line 1903 of file ossimVertexExtractor.cpp.
References isOpen(), and theFileStream.
Referenced by open(), and setOutputName().
1904 {
1905  if (isOpen()) theFileStream.close();
1906 }
virtual bool isOpen() const
◆ execute()
bool ossimVertexExtractor::execute ( )
virtual
Calls protected methods scanForEdges, extractVertices, and writeVertices. Will error out if "theFilename" or "theAreaOfInterest has not been set or "theFilename" could not be opened.
Implements ossimProcessInterface.
Definition at line 66 of file ossimVertexExtractor.cpp.
Referenced by ossimVerticesFinderTool::execute().
67 {
68  static const char MODULE[] = "ossimVertexExtractor::execute";
69
70  if (traceDebug()) CLOG << " Entered..." << endl;
71
73  {
74  ossimNotify(ossimNotifyLevel_WARN) << "ossimVertexExtractor::execute WARNING:"
75  << "\nOutput file name is empty. Use setFilename method..."
76  << std::endl;
77  return false;
78  }
79
81  {
82  ossimNotify(ossimNotifyLevel_NOTICE) << MODULE << " NOTICE ossimVertexExtractor::execute:"
83  << "\nArea of interest is not set. Use setAreaOfInterest method..."
84  << "\nDefaulting to bounding rectangle of input source."
85  << std::endl;
86  ossimImageSource* src = reinterpret_cast<ossimImageSource*>(getInput(0));
88  }
89
91
92  if (scanForEdges())
93  {
94  if (extractVertices())
95  {
96  writeVertices();
97  }
98  else
99  {
100  return false;
101  }
102  }
103  else
104  {
105  return false;
106  }
107
109
110  if (traceDebug()) CLOG << " Exited..." << endl;
111
112  return true;
113 }
This will return the bounding rect of the source.
#define CLOG
Definition: ossimTrace.h:23
virtual void setProcessStatus(ossimProcessStatus processStatus)
bool isNan() const
Definition: ossimIrect.h:342
◆ extractVertices()
bool ossimVertexExtractor::extractVertices ( )
protected
Extracts the vertices of the source. Uses "theLeftEdge" and "theRightEdge" data members. Returns true on success, false on error.
Definition at line 311 of file ossimVertexExtractor.cpp.
312 {
313  //***
314  // This method returns the non-null vertexes of the image corners.
315  // This can be used to initialize the "ValidImageVertices" for an
316  // image.
317  // This method does not handle images that have more than four vertexes.
318  //***
319  static const char MODULE[] = "ossimVertexExtractor::extractVertices";
320
321  if (traceDebug()) CLOG << " Entered..." << endl;
322
323  if (!theLeftEdge || !theRightEdge)
324  {
325  ossimNotify(ossimNotifyLevel_WARN) << "ERROR ossimVertexExtractor::extractVertices():"
326  << "\nEdges not initialized!" << std::endl;
327  return false;
328  }
329
330  // Image must be quadrilateral (i.e. 4 sided polygon)
331
332  ossim_int32 total_lines = theAreaOfInterest.height();
333
334  ossim_int32 topLine = 0;
335  ossim_int32 bottomLine = 0;
336
337  ossim_int32 firstLeftSample = 0;
338  ossim_int32 firstRightSample = 0;
339
340  ossim_int32 lastLeftSample = 0;
341  ossim_int32 lastRightSample = 0;
342
343  ossim_int32 leftMostSample = 0;
344  ossim_int32 leftMostSampleLine = 0;
345
346  ossim_int32 rightMostSample = 0;
347  ossim_int32 rightMostSampleLine = 0;
348
349  ossim_int32 leftCorner_A = 0;
350  ossim_int32 leftCornerLine_A = 0;
351  ossim_int32 leftCorner_B = 0;
352  ossim_int32 leftCornerLine_B = 0;
353
354  ossim_int32 rightCorner_A = 0;
355  ossim_int32 rightCornerLine_A = 0;
356  ossim_int32 rightCorner_B = 0;
357  ossim_int32 rightCornerLine_B = 0;
358
359
360  bool found_first_non_null_line = 0;
361  bool found_last_non_null_line = 0;
362
363  bool rhombus = false;
364  bool square = false;
365  bool left = false;
366  bool right = false;
367
368  ossim_int32 first_non_null_line = 0;
369  ossim_int32 last_non_null_line = 0;
370
371  ossim_int32 i = 0;
372  while(found_last_non_null_line == 0)
373  {
374  // Look for the first row with a valid DN
375  // Nulls are negative
376
377  if( (theLeftEdge[i] >= 0)
378  && (found_first_non_null_line == 0) )
379  {
380  // Found first valid pixel at row i
381  found_first_non_null_line = 1;
382  first_non_null_line = i;
383
384  // Finish walking down the rows of the image
385  while( (found_first_non_null_line == 1)
386  && (theLeftEdge[i] >= 0)
387  && (found_last_non_null_line == 0)
388  && (i <= total_lines) )
389  {
390  i = i+1;
391  }
392  found_last_non_null_line = 1;
393  last_non_null_line = i-1;
394  }
395
396  i = i+1;
397
398  }//end while "found_last_non_null_line == 0"
399
400  last_non_null_line = last_non_null_line -1;
401
402  topLine = first_non_null_line;
403  bottomLine = last_non_null_line;
404
405  // Record the slope searching from the right edge
406  ossim_int32 k = 0;
407  ossim_int32 start = first_non_null_line;
408  ossim_int32 end = last_non_null_line;
409  ossim_int32 sizeDeltaSlope = last_non_null_line - first_non_null_line;
410  double* rightSlope = new double[sizeDeltaSlope];
411
412  for(ossim_int32 i = start; i <= (end - 100); i += 100)
413  {
414  ossim_int32 run = theRightEdge[i] - theRightEdge[i + 100];
415  if(run != 0)
416  {
417  rightSlope[k] = 100.0 / run;
418  }
419  else
420  {
421  rightSlope[k]= OSSIM_INT_NAN;
422  }
423
424  k = k + 1;
425  }
426  if (traceDebug())
427  {
428  CLOG << "DEBUG:" << endl;
429  for (ossim_int32 i=0; i<= k-1; i++)
430  {
431  ossimNotify(ossimNotifyLevel_DEBUG)<< setprecision(15) << "rightSlope[" << i << "]: "
432  << rightSlope[i]
433  << std::endl;
434  }
435  }
436
437  // Record the slope searching from the left edge
438  k = 0;
439  double* leftSlope = new double[sizeDeltaSlope];
440
441  for(ossim_int32 i = start; i <= (end - 100); i += 100)
442  {
443  ossim_int32 run = theLeftEdge[i] - theLeftEdge[i + 100];
444  if(run != 0)
445  {
446  leftSlope[k] = 100.0 / run;
447  }
448  else
449  {
450  leftSlope[k] = OSSIM_INT_NAN;
451  }
452
453  k = k + 1;
454  }
455  if (traceDebug())
456  {
457  CLOG << "DEBUG:" << endl;
458  for (ossim_int32 i=0; i<= k-1; i++)
459  {
460  ossimNotify(ossimNotifyLevel_DEBUG) << setprecision(15) << "leftSlope[" << i << "]: "
461  << leftSlope[i]
462  << std::endl;
463  }
464  }
465  ossim_int32 sizeOftheSlope = k-1;
466  ossim_int32 counter = 0;
467
468
469  // Find the right most sample
470  ossim_int32 rightMostEdgeTemp = theRightEdge[topLine];
471  ossim_int32 rightMostEdgeTempLine = 0;
472
473  for(ossim_int32 i= (topLine+1); i<bottomLine; i++)
474  {
475  if(theRightEdge[i] >= rightMostEdgeTemp)
476  {
477  rightMostEdgeTemp = theRightEdge[i];
478  rightMostEdgeTempLine = i;
479  }
480  }
481  rightMostSample = rightMostEdgeTemp;
482  rightMostSampleLine = rightMostEdgeTempLine-1;
483  lastLeftSample = theLeftEdge[bottomLine];
484
485  // Find the left most sample
486  ossim_int32 leftMostEdgeTemp = theLeftEdge[topLine];
487  ossim_int32 leftMostEdgeTempLine = 0;
488
489  for(ossim_int32 i= (topLine+1); i<bottomLine; i++)
490  {
491  if(theLeftEdge[i] <= leftMostEdgeTemp)
492  {
493  leftMostEdgeTemp = theLeftEdge[i];
494  leftMostEdgeTempLine = i;
495  }
496  }
497  leftMostSample = leftMostEdgeTemp;
498  leftMostSampleLine = leftMostEdgeTempLine-1;
499  firstLeftSample = theLeftEdge[topLine];
500
501  // Case: Check for square
502  for(ossim_int32 i=0; i < sizeOftheSlope; ++i)
503  {
504  if(leftSlope[i]==rightSlope[i])
505  {
506  counter = counter + 1;
507  }
508  }
509
510  if(counter == sizeOftheSlope)
511  {
512  if (traceDebug())
513  {
514  ossimNotify(ossimNotifyLevel_DEBUG)<<"\n\n***Case = SQUARE***"<<endl<<endl;
515  }
516
517  square = 1;
518
519  leftCornerLine_A = topLine;
520  //leftCorner_A = theLeftEdge[topLine]; //0
521  leftCorner_A = leftMostSample;
522
523  rightCornerLine_A = topLine;
524  //rightCorner_A = theRightEdge[topLine]; //1
525  rightCorner_A = rightMostSample; //1
526
527  rightCornerLine_B = bottomLine;
528  //rightCorner_B = theRightEdge[bottomLine]; //2
529  rightCorner_B = rightMostSample;
530
531  leftCornerLine_B = bottomLine;
532  //leftCorner_B = theLeftEdge[bottomLine]; //3
533  leftCorner_B = leftMostSample;
534  }
535
536  firstRightSample = theRightEdge[topLine];
537  lastRightSample = theRightEdge[bottomLine];
538
539
540
541  ossim_int32 halfsamps = (rightMostSample - leftMostSample ) / 2;
542
543  if(square == 0)
544  {
545  if( (firstRightSample - firstLeftSample) > halfsamps )
546  {
547  // Case is rhombus (clipped or not clipped)
548
549  rhombus = 1;
550  if (traceDebug())
551  {
552  ossimNotify(ossimNotifyLevel_DEBUG)<<"\n\n***Case = RHOMBUS***"<<endl;
553  ossimNotify(ossimNotifyLevel_DEBUG)<<"here"<<endl;
554  }
555
556  leftCornerLine_A = topLine;
557  leftCorner_A = firstLeftSample; //0
558
559  rightCornerLine_A = topLine;
560  rightCorner_A= firstRightSample; //1
561
562  rightCornerLine_B = bottomLine;
563  rightCorner_B = lastRightSample; //2
564
565  leftCornerLine_B = bottomLine;
566  leftCorner_B = lastLeftSample; //3
567
568  }
569  }
570
571
572  if(square == 0 && rhombus == 0)
573  {//if not square or rhombus
574
575  if(firstLeftSample < lastLeftSample)
576  {//if tilted right
577
578  if (traceDebug())
579  {
580  ossimNotify(ossimNotifyLevel_DEBUG)<<"\n\n***Case = TILTED RIGHT***"<<endl<<endl;
581  }
582
583  right = true;
584
585  // Regression line 2 is the right side
586  // Regression line 4 is the left side
587  // These are handled differently
588  // These sides may be 'uneven' or 'torn' or 'louvered'
589  // This code finds the best regression line that 'cuts off'
590  // this edge fringe
591
592  //Regression Line 1
593
594  ossim_int32 line1_pt4 = rightMostSampleLine;
595  ossim_int32 line1_pt0 = topLine;
596  ossim_int32 line1_pt2 = (line1_pt0 + line1_pt4)/2;
597  ossim_int32 line1_pt1 = (line1_pt2 + line1_pt0)/2;
598  ossim_int32 line1_pt3 = (line1_pt2 + line1_pt4)/2;
599
600  double line1RegPtsSamples[] = { static_cast<double>(theRightEdge[line1_pt1]),
601  static_cast<double>(theRightEdge[line1_pt2]),
602  static_cast<double>(theRightEdge[line1_pt3]) };
603  double line1RegPtsLines[] = { static_cast<double>(-line1_pt1),
604  static_cast<double>(-line1_pt2),
605  static_cast<double>(-line1_pt3) };
606
607  double sum_xy_line1 = 0.0;
608  double sum_x_line1 = 0.0;
609  double sum_y_line1 = 0.0;
610  double mean_x_line1 = 0.0;
611  double mean_y_line1 = 0.0;
612  double sum_x_squared_line1 = 0.0;
613  double sum_squared_x_line1 = 0.0;
614  double b_line1;
615  double a_line1;
616  double num_elements_line1 = 3.0;
617
618  for(ossim_int32 i = 0; i < num_elements_line1; ++i)
619  {
620  sum_xy_line1 = sum_xy_line1
621  + (line1RegPtsSamples[i]*line1RegPtsLines[i]);
622
623  sum_x_line1 = sum_x_line1 + line1RegPtsSamples[i];
624  sum_y_line1 = sum_y_line1 + line1RegPtsLines[i];
625
626  sum_squared_x_line1 = sum_squared_x_line1
627  + line1RegPtsSamples[i]*line1RegPtsSamples[i];
628  }
629
630  sum_x_squared_line1 = sum_x_line1*sum_x_line1;
631  mean_y_line1 = sum_y_line1/num_elements_line1;
632  mean_x_line1 = sum_x_line1/num_elements_line1;
633  b_line1 = (sum_xy_line1 - (sum_x_line1*sum_y_line1)/num_elements_line1)
634  / (sum_squared_x_line1 - (sum_x_squared_line1/num_elements_line1));
635  a_line1 = mean_y_line1 - b_line1*mean_x_line1;
636
637  if(traceDebug())
638  {
639  ossimNotify(ossimNotifyLevel_DEBUG)<<" a_line1: "<< a_line1 <<std::endl;
640  ossimNotify(ossimNotifyLevel_DEBUG)<<" b_line1: "<< b_line1 <<std::endl;
641
642
643  for(ossim_int32 i = 0; i < num_elements_line1; ++i)
644  {
645
646  ossimNotify(ossimNotifyLevel_DEBUG) << setprecision(15) << "line1RegPtsLines[" << i
647  << "]: " <<line1RegPtsLines[i]
648  << "\nline1RegPtsSamples[" << i << "]: "
649  <<line1RegPtsSamples[i]
650  << std::endl;
651
652  }
653  }
654
655  //Regression Line 2
656  ossim_int32 line2_pt0 = rightMostSampleLine;
657  ossim_int32 line2_pt4 = bottomLine;
658  ossim_int32 line2_pt2 = (line2_pt0 + line2_pt4)/2;
659  ossim_int32 line2_pt1 = (line2_pt2 + line2_pt0)/2;
660  ossim_int32 line2_pt3 = (line2_pt2 + line2_pt4)/2;
661
662
663  ossim_int32 minValuePt1;
664  ossim_int32 minOffsetPt1;
665  getMinAndIndex(&theRightEdge[line2_pt1-100],
666  &theRightEdge[line2_pt1+100],
667  minValuePt1, minOffsetPt1 );
668  line2_pt1 = line2_pt1-100 + minOffsetPt1;
669
670  ossim_int32 minValuePt2;
671  ossim_int32 minOffsetPt2;
672  getMinAndIndex(&theRightEdge[line2_pt2-100],
673  &theRightEdge[line2_pt2+100],
674  minValuePt2, minOffsetPt2 );
675  line2_pt2 = line2_pt2-100 + minOffsetPt2;
676
677
678  ossim_int32 minValuePt3;
679  ossim_int32 minOffsetPt3;
680  getMinAndIndex(&theRightEdge[line2_pt3-100],&theRightEdge[line2_pt3+100],
681  minValuePt3, minOffsetPt3 );
682  line2_pt3 = line2_pt3-100 + minOffsetPt3;
683
684  //---
685  // Find the line within 100 lines of line2_ptx that has the
686  // minimum sample. This will cut off the 'fringe'
687  //---
688  double line2RegPtsSamples[] = { static_cast<double>(theRightEdge[line2_pt1]),
689  static_cast<double>(theRightEdge[line2_pt2]),
690  static_cast<double>(theRightEdge[line2_pt3]) };
691  double line2RegPtsLines[] = { static_cast<double>(-line2_pt1),
692  static_cast<double>(-line2_pt2),
693  static_cast<double>(-line2_pt3) };
694
695  double sum_xy_line2 = 0.0;
696  double sum_x_line2 = 0.0;
697  double sum_y_line2 = 0.0;
698  double mean_x_line2 = 0.0;
699  double mean_y_line2 = 0.0;
700  double sum_x_squared_line2 = 0.0;
701  double sum_squared_x_line2 = 0.0;
702  double b_line2;
703  double a_line2;
704  double num_elements_line2 = 3.0;
705
706  for(ossim_int32 i = 0; i < num_elements_line2; ++i)
707  {
708  sum_xy_line2 = sum_xy_line2
709  + (line2RegPtsSamples[i]*line2RegPtsLines[i]);
710
711  sum_x_line2 = sum_x_line2 + line2RegPtsSamples[i];
712  sum_y_line2 = sum_y_line2 + line2RegPtsLines[i];
713
714  sum_squared_x_line2 = sum_squared_x_line2
715  + line2RegPtsSamples[i]*line2RegPtsSamples[i];
716  }
717
718  sum_x_squared_line2 = sum_x_line2*sum_x_line2;
719  mean_y_line2 = sum_y_line2/num_elements_line2;
720  mean_x_line2 = sum_x_line2/num_elements_line2;
721  b_line2 = (sum_xy_line2 - (sum_x_line2*sum_y_line2)/num_elements_line2)
722  / (sum_squared_x_line2 - (sum_x_squared_line2/num_elements_line2));
723  a_line2 = mean_y_line2 - b_line2*mean_x_line2;
724
725  if(traceDebug())
726  {
727  for(ossim_int32 i = 0; i < num_elements_line2; ++i)
728  {
729  ossimNotify(ossimNotifyLevel_DEBUG) << setprecision(15) << "line2RegPtsLines[" << i << "]: "
730  <<line2RegPtsLines[i]
731  << "\nline2RegPtsSamples[" << i << "]: "
732  <<line2RegPtsSamples[i]
733  <<std::endl;
734  }
735  ossimNotify(ossimNotifyLevel_DEBUG) << "\na_line2: " << a_line2
736  << "\nb_line2: " << b_line2 << std::endl;
737
738  }
739
740  //End regression line2
741
742  //Intersect lines 1 and 2 to get the ur corner vertex
743
744  double ur_x = (a_line1 - a_line2)/(b_line2 - b_line1);
745  double ur_y = -(a_line1 + b_line1*ur_x);
746
747  //Regression Line 3
748
749  ossim_int32 line3_pt0 = leftMostSampleLine;
750  ossim_int32 line3_pt4 = bottomLine;
751  ossim_int32 line3_pt2 = (line3_pt0 + line3_pt4)/2;
752  ossim_int32 line3_pt1 = (line3_pt2 + line3_pt0)/2;
753  ossim_int32 line3_pt3 = (line3_pt2 + line3_pt4)/2;
754
755  double line3RegPtsSamples[] = { static_cast<double>(theLeftEdge[line3_pt1]),
756  static_cast<double>(theLeftEdge[line3_pt2]),
757  static_cast<double>(theLeftEdge[line3_pt3]) };
758  double line3RegPtsLines[] = { static_cast<double>(-line3_pt1),
759  static_cast<double>(-line3_pt2),
760  static_cast<double>(-line3_pt3) };
761
762  double sum_xy_line3 = 0.0;
763  double sum_x_line3 = 0.0;
764  double sum_y_line3 = 0.0;
765  double mean_x_line3 = 0.0;
766  double mean_y_line3 = 0.0;
767  double sum_x_squared_line3 = 0.0;
768  double sum_squared_x_line3 = 0.0;
769  double b_line3;
770  double a_line3;
771  double num_elements_line3 = 3.0;
772
773  for(ossim_int32 i = 0; i < num_elements_line3; ++i)
774  {
775  sum_xy_line3 = sum_xy_line3
776  + (line3RegPtsSamples[i]*line3RegPtsLines[i]);
777
778  sum_x_line3 = sum_x_line3 + line3RegPtsSamples[i];
779  sum_y_line3 = sum_y_line3 + line3RegPtsLines[i];
780
781  sum_squared_x_line3 = sum_squared_x_line3
782  + line3RegPtsSamples[i]*line3RegPtsSamples[i];
783
784  }
785
786  sum_x_squared_line3 = sum_x_line3*sum_x_line3;
787  mean_y_line3 = sum_y_line3/num_elements_line3;
788  mean_x_line3 = sum_x_line3/num_elements_line3;
789  b_line3 = (sum_xy_line3 - (sum_x_line3*sum_y_line3)/num_elements_line3)
790  / (sum_squared_x_line3 - (sum_x_squared_line3/num_elements_line3));
791  a_line3 = mean_y_line3 - b_line3*mean_x_line3;
792
793  if(traceDebug())
794  {
795  ossimNotify(ossimNotifyLevel_DEBUG) << "\n\n a_line3: " << a_line3 <<std::endl;
796  ossimNotify(ossimNotifyLevel_DEBUG) << " b_line3: " << b_line3 <<std::endl;
797
798
799  for(ossim_int32 i = 0; i < num_elements_line3; ++i)
800  {
801
802  ossimNotify(ossimNotifyLevel_DEBUG) << setprecision(15) << "line3RegPtsLines[" << i << "]: "
803  <<line3RegPtsLines[i]
804  << "\nline3RegPtsSamples[" << i << "]: "
805  <<line3RegPtsSamples[i]
806  << std::endl;
807  }
808  }
809  //End regression line3
810
811  //Intersect lines 2 and 3 to get the lr corner vertex
812
813  double lr_x = (a_line3 - a_line2)/(b_line2 - b_line3);
814  double lr_y = -(a_line3 + b_line3*lr_x);
815
816  //End Regression Line3
817
818  //Regression Line 4
819
820  ossim_int32 line4_pt0 = leftMostSampleLine;
821  ossim_int32 line4_pt4 = topLine;
822  ossim_int32 line4_pt2 = (line4_pt0 + line4_pt4)/2;
823  ossim_int32 line4_pt1 = (line4_pt2 + line4_pt0)/2;
824  ossim_int32 line4_pt3 = (line4_pt2 + line4_pt4)/2;
825
826 // //***
827 // // Find the line within 100 lines of line2_ptx that has the maximum
828 // // sample. This will cut off the 'fringe'.
829 // //***
830
831  ossim_int32 maxValueLine4Pt1;
832  ossim_int32 maxOffsetLine4Pt1;
833  getMaxAndIndex(&theLeftEdge[line4_pt1-100],&theLeftEdge[line4_pt1+100],
834  maxValueLine4Pt1, maxOffsetLine4Pt1 );
835  line4_pt1 = line4_pt1-100 + maxOffsetLine4Pt1;
836
837
838  ossim_int32 maxValueLine4Pt2;
839  ossim_int32 maxOffsetLine4Pt2;
840  getMaxAndIndex(&theLeftEdge[line4_pt2-100],&theLeftEdge[line4_pt2+100],
841  maxValueLine4Pt2, maxOffsetLine4Pt2 );
842  line4_pt2 = line4_pt2-100 + maxOffsetLine4Pt2;
843
844
845  ossim_int32 maxValueLine4Pt3;
846  ossim_int32 maxOffsetLine4Pt3;
847  getMaxAndIndex(&theLeftEdge[line4_pt3-100],&theLeftEdge[line4_pt3+100],
848  maxValueLine4Pt3, maxOffsetLine4Pt3 );
849  line4_pt3 = line4_pt3-100 + maxOffsetLine4Pt3;
850
851
852
853
854  double line4RegPtsSamples[] = { static_cast<double>(theLeftEdge[line4_pt1]),
855  static_cast<double>(theLeftEdge[line4_pt2]),
856  static_cast<double>(theLeftEdge[line4_pt3]) };
857  double line4RegPtsLines[] = { static_cast<double>(-line4_pt1),
858  static_cast<double>(-line4_pt2),
859  static_cast<double>(-line4_pt3) };
860
861  double sum_xy_line4 = 0.0;
862  double sum_x_line4 = 0.0;
863  double sum_y_line4 = 0.0;
864  double mean_x_line4 = 0.0;
865  double mean_y_line4 = 0.0;
866  double sum_x_squared_line4 = 0.0;
867  double sum_squared_x_line4 = 0.0;
868  double b_line4;
869  double a_line4;
870  double num_elements_line4 = 3.0;
871  for(ossim_int32 i = 0; i < num_elements_line4; ++i)
872  {
873  sum_xy_line4 = sum_xy_line4
874  + (line4RegPtsSamples[i]*line4RegPtsLines[i]);
875
876  sum_x_line4 = sum_x_line4 + line4RegPtsSamples[i];
877  sum_y_line4 = sum_y_line4 + line4RegPtsLines[i];
878
879  sum_squared_x_line4 = sum_squared_x_line4
880  + line4RegPtsSamples[i]*line4RegPtsSamples[i];
881
882
883  }
884
885  sum_x_squared_line4 = sum_x_line4*sum_x_line4;
886  mean_y_line4 = sum_y_line4/num_elements_line4;
887  mean_x_line4 = sum_x_line4/num_elements_line4;
888  b_line4 = (sum_xy_line4 - (sum_x_line4*sum_y_line4)/num_elements_line4)
889  / (sum_squared_x_line4 - (sum_x_squared_line4/num_elements_line4));
890  a_line4 = mean_y_line4 - b_line4*mean_x_line4;
891
892  if(traceDebug())
893  {
894  ossimNotify(ossimNotifyLevel_DEBUG)<<"\na_line4: "<< a_line4
895  <<"\nb_line4: "<< b_line4 <<std::endl;
896
897  for(ossim_int32 i = 0; i < num_elements_line4; ++i)
898  {
899
900  ossimNotify(ossimNotifyLevel_DEBUG) << setprecision(15) << "line4RegPtsLines[" << i << "]: "
901  <<line4RegPtsLines[i]
902  << "\nline4RegPtsSamples[" << i << "]: "
903  <<line4RegPtsSamples[i]
904  << std::endl;
905
906  }
907  }
908  //End regression line4
909
910  //Intersect lines 3 and 4 to get the ll corner vertex
911
912  double ll_x = (a_line4 - a_line3)/(b_line3 - b_line4);
913  double ll_y = -(a_line4 + b_line4*ll_x);
914
915  //End Regression Line4
916
917  //Intersect lines 4 and 1 to get the ul corner vertex
918
919  double ul_x = (a_line4 - a_line1)/(b_line1 - b_line4);
920  double ul_y = -(a_line4 + b_line4*ul_x);
921
922  if (traceDebug())
923  {
924  ossimNotify(ossimNotifyLevel_DEBUG)<<"\n\nInitial corners for tilted right: "
925  <<"\ncorner0: ("<<ul_x<<", "<<ul_y<<")"
926  <<"\ncorner1: ("<<ur_x<<", "<<ur_y<<")"
927  <<"\ncorner2: ("<<lr_x<<", "<<lr_y<<")"
928  <<"\ncorner3: ("<<ll_x<<", "<<ll_y<<")"<<std::endl<<std::endl;
929  }
930
931  leftCornerLine_A = (ossim_int32)ul_y;
932  leftCorner_A = (ossim_int32)ul_x; //0
933
934  rightCornerLine_A = (ossim_int32)ur_y;
935  rightCorner_A = (ossim_int32)ur_x; //1
936
937  rightCornerLine_B = (ossim_int32)lr_y;
938  rightCorner_B =(ossim_int32)lr_x; //2
939
940  leftCornerLine_B = (ossim_int32)ll_y;
941  leftCorner_B =(ossim_int32)ll_x; //3
942
943
944  // Check for bad corner points due to irregular shape image
945
946  //for corner 0 (ul), sample should be between left and right most samples
947  // line can go negative due to jagged edges
948
949  //for corner 1 (ur), sample can go > than num samples
950  // line should be between top and bottom lines
951
952  //for corner 2 (lr), line should be between top and bottom line + 200
953  // sample should be between left and right most sample
954
955  //for corner 3 (ll), line should be between top and bottom line
956  // sample should can go negative due to jagged edges
957
958  if( (leftCornerLine_A < (topLine - 300))
959  || (leftCornerLine_A > total_lines)
960  || (leftCorner_A > rightMostSample)
961  || (leftCorner_A < leftMostSample)
962
963  || (rightCornerLine_A < topLine)
964  || (rightCornerLine_A > bottomLine)
965  || (rightCorner_A < leftMostSample)
966  || (rightCorner_A > (rightMostSample + 200))
967
968
969  || (rightCornerLine_B < topLine)
970  || (rightCornerLine_B > (bottomLine + 200))
971  || (rightCorner_B < leftMostSample)
972  || (rightCorner_B > rightMostSample)
973
974  || (leftCornerLine_B > bottomLine)
975  || (leftCornerLine_B < topLine)
976  || (leftCorner_B > rightMostSample)
977  || (leftCorner_B < (leftMostSample - 200)) )
978
979
980
981  {
982  right = false;
983  if (traceDebug())
984  {
985  ossimNotify(ossimNotifyLevel_DEBUG) <<"\n\n***Case = NOT TILTED RIGHT...***"<<std::endl;
986  }
987  }
988  }
989
990  //tilted left
991  if(firstRightSample > lastRightSample)
992  {//begin tilted left
993
994  if (traceDebug())
995  {
996  ossimNotify(ossimNotifyLevel_DEBUG) <<"\n\n***Case = TILTED LEFT***"<<std::endl;
997  }
998  left = true;
999
1000  // Regression line 1 is the right side
1001  // Regression line 3 is the left side
1002  // These are handled differently
1003  // These sides may be 'uneven' or 'torn' or 'louvered'
1004  // This code finds the best regression line that 'cuts off' this edge fringe
1005
1006
1007  //Regression Line 1
1008
1009  ossim_int32 line1_pt4 = rightMostSampleLine;
1010  ossim_int32 line1_pt0 = topLine;
1011  ossim_int32 line1_pt2 = (line1_pt0 + line1_pt4)/2;
1012  ossim_int32 line1_pt1 = (line1_pt2 + line1_pt0)/2;
1013  ossim_int32 line1_pt3 = (line1_pt2 + line1_pt4)/2;
1014
1015  if (traceDebug())
1016  {
1017  ossimNotify(ossimNotifyLevel_DEBUG)<<" line1_pt1: "<<line1_pt0<<std::endl;
1018  ossimNotify(ossimNotifyLevel_DEBUG)<<" line1_pt2: "<<line1_pt1<<std::endl;
1019  ossimNotify(ossimNotifyLevel_DEBUG)<<" line1_pt3: "<<line1_pt2<<std::endl;
1020  ossimNotify(ossimNotifyLevel_DEBUG)<<" line1_pt4: "<<line1_pt3<<std::endl;
1021  }
1022
1023  ossim_int32 minValueLine1Pt1;
1024  ossim_int32 minOffsetLine1Pt1;
1025  getMinAndIndex(&theLeftEdge[line1_pt1-100],&theLeftEdge[line1_pt1+100],
1026  minValueLine1Pt1, minOffsetLine1Pt1 );
1027  line1_pt1 = line1_pt1-100 + minOffsetLine1Pt1;
1028
1029  if (traceDebug())
1030  {
1031  ossimNotify(ossimNotifyLevel_DEBUG) << " line1_pt1: "<< line1_pt1
1032  <<" minValueLine1Pt1: "<<minValueLine1Pt1<<"\n\n";
1033  }
1034
1035  ossim_int32 minValueLine1Pt2;
1036  ossim_int32 minOffsetLine1Pt2;
1037  getMinAndIndex(&theLeftEdge[line1_pt2-100],&theLeftEdge[line1_pt2+100],
1038  minValueLine1Pt2, minOffsetLine1Pt2 );
1039  line1_pt2 = line1_pt2-100 + minOffsetLine1Pt2;
1040
1041  if (traceDebug())
1042  {
1043  ossimNotify(ossimNotifyLevel_DEBUG) << " line1_pt2: "<< line1_pt2
1044  <<" minValueLine1Pt2: "<<minValueLine1Pt2<<"\n\n";
1045  }
1046
1047
1048  ossim_int32 minValueLine1Pt3;
1049  ossim_int32 minOffsetLine1Pt3;
1050  getMinAndIndex(&theLeftEdge[line1_pt3-100],&theLeftEdge[line1_pt3+100],
1051  minValueLine1Pt3, minOffsetLine1Pt3 );
1052  line1_pt3 = line1_pt3-100 + minOffsetLine1Pt3;
1053
1054  if (traceDebug())
1055  {
1056  ossimNotify(ossimNotifyLevel_DEBUG) << " line1_pt3: "<< line1_pt3
1057  <<" minValueLine1Pt3: "<<minValueLine1Pt3<<std::endl<<std::endl;
1058  }
1059
1060  double line1RegPtsSamples[] = { static_cast<double>(theRightEdge[line1_pt1]),
1061  static_cast<double>(theRightEdge[line1_pt2]),
1062  static_cast<double>(theRightEdge[line1_pt3])};
1063  double line1RegPtsLines[] = { static_cast<double>(-line1_pt1),
1064  static_cast<double>(-line1_pt2),
1065  static_cast<double>(-line1_pt3) };
1066
1067  double sum_xy_line1 = 0.0;
1068  double sum_x_line1 = 0.0;
1069  double sum_y_line1 = 0.0;
1070  double mean_x_line1 = 0.0;
1071  double mean_y_line1 = 0.0;
1072  double sum_x_squared_line1 = 0.0;
1073  double sum_squared_x_line1 = 0.0;
1074  double b_line1;
1075  double a_line1;
1076  double num_elements_line1 = 3.0;
1077
1078  for(ossim_int32 i = 0; i < num_elements_line1; ++i)
1079  {
1080  sum_xy_line1 = sum_xy_line1
1081  + (line1RegPtsSamples[i]*line1RegPtsLines[i]);
1082
1083  sum_x_line1 = sum_x_line1 + line1RegPtsSamples[i];
1084  sum_y_line1 = sum_y_line1 + line1RegPtsLines[i];
1085
1086  sum_squared_x_line1 = sum_squared_x_line1
1087  + line1RegPtsSamples[i]*line1RegPtsSamples[i];
1088
1089
1090  }
1091
1092  sum_x_squared_line1 = sum_x_line1*sum_x_line1;
1093  mean_y_line1 = sum_y_line1/num_elements_line1;
1094  mean_x_line1 = sum_x_line1/num_elements_line1;
1095  b_line1 = (sum_xy_line1 - (sum_x_line1*sum_y_line1)/num_elements_line1)
1096  / (sum_squared_x_line1 - (sum_x_squared_line1/num_elements_line1));
1097  a_line1 = mean_y_line1 - b_line1*mean_x_line1;
1098
1099  if(traceDebug())
1100  {
1101  ossimNotify(ossimNotifyLevel_DEBUG)<<"a_line1: "<< a_line1
1102  <<"\nb_line1: "<< b_line1 <<std::endl;
1103
1104  for(ossim_int32 i = 0; i < num_elements_line1; ++i)
1105  {
1106
1107  ossimNotify(ossimNotifyLevel_DEBUG) << setprecision(15) << "line1RegPtsLines[" << i << "]: "
1108  <<line1RegPtsLines[i]
1109  << "\nline1RegPtsSamples[" << i << "]: "
1110  <<line1RegPtsSamples[i]
1111  << std::endl;
1112  }
1113  }
1114
1115
1116  //Regression Line 2
1117
1118  ossim_int32 line2_pt0 = rightMostSampleLine;
1119  ossim_int32 line2_pt4 = bottomLine;
1120  ossim_int32 line2_pt2 = (line2_pt0 + line2_pt4)/2;
1121  ossim_int32 line2_pt1 = (line2_pt2 + line2_pt0)/2;
1122  ossim_int32 line2_pt3 = (line2_pt2 + line2_pt4)/2;
1123
1124  double line2RegPtsSamples[] = { static_cast<double>(theRightEdge[line2_pt1]),
1125  static_cast<double>(theRightEdge[line2_pt2]),
1126  static_cast<double>(theRightEdge[line2_pt3]) };
1127  double line2RegPtsLines[] = { static_cast<double>(-line2_pt1),
1128  static_cast<double>(-line2_pt2),
1129  static_cast<double>(-line2_pt3) };
1130
1131  double sum_xy_line2 = 0.0;
1132  double sum_x_line2 = 0.0;
1133  double sum_y_line2 = 0.0;
1134  double mean_x_line2 = 0.0;
1135  double mean_y_line2 = 0.0;
1136  double sum_x_squared_line2 = 0.0;
1137  double sum_squared_x_line2 = 0.0;
1138  double b_line2;
1139  double a_line2;
1140  double num_elements_line2 = 3.0;
1141  for(ossim_int32 i = 0; i < num_elements_line2; ++i)
1142  {
1143  sum_xy_line2 = sum_xy_line2
1144  + (line2RegPtsSamples[i]*line2RegPtsLines[i]);
1145
1146  sum_x_line2 = sum_x_line2 + line2RegPtsSamples[i];
1147  sum_y_line2 = sum_y_line2 + line2RegPtsLines[i];
1148
1149  sum_squared_x_line2 = sum_squared_x_line2
1150  + line2RegPtsSamples[i]*line2RegPtsSamples[i];
1151  }
1152
1153  sum_x_squared_line2 = sum_x_line2*sum_x_line2;
1154  mean_y_line2 = sum_y_line2/num_elements_line2;
1155  mean_x_line2 = sum_x_line2/num_elements_line2;
1156  b_line2 = (sum_xy_line2 - (sum_x_line2*sum_y_line2)/num_elements_line2)
1157  / (sum_squared_x_line2 - (sum_x_squared_line2/num_elements_line2));
1158  a_line2 = mean_y_line2 - b_line2*mean_x_line2;
1159
1160  if(traceDebug())
1161  {
1162  ossimNotify(ossimNotifyLevel_DEBUG) << "a_line2: "<< a_line2
1163  << "\nb_line2: "<< b_line2 <<std::endl;
1164
1165  for(ossim_int32 i = 0; i < num_elements_line2; ++i)
1166  {
1167
1168  ossimNotify(ossimNotifyLevel_DEBUG) << setprecision(15) << "line2RegPtsLines[" << i << "]: "
1169  <<line2RegPtsLines[i]
1170  << "\nline2RegPtsSamples[" << i << "]: "
1171  <<line2RegPtsSamples[i]
1172  << std::endl;
1173  }
1174  }
1175  //End regression line2
1176
1177  //Intersect lines 1 and 2 to get the lr corner vertex
1178
1179  double lr_x = (a_line1 - a_line2)/(b_line2 - b_line1);
1180  double lr_y = -(a_line1 + b_line1*lr_x);
1181
1182  //Regression Line 3
1183
1184  ossim_int32 line3_pt0 = leftMostSampleLine;
1185  ossim_int32 line3_pt4 = bottomLine;
1186  ossim_int32 line3_pt2 = (line3_pt0 + line3_pt4)/2;
1187  ossim_int32 line3_pt1 = (line3_pt2 + line3_pt0)/2;
1188  ossim_int32 line3_pt3 = (line3_pt2 + line3_pt4)/2;
1189
1190  ossim_int32 maxValueLine3Pt1;
1191  ossim_int32 maxOffsetLine3Pt1;
1192  getMaxAndIndex(&theLeftEdge[line3_pt1-100],&theLeftEdge[line3_pt1+100],
1193  maxValueLine3Pt1, maxOffsetLine3Pt1 );
1194  line3_pt1 = line3_pt1-100 + maxOffsetLine3Pt1;
1195
1196
1197  ossim_int32 maxValueLine3Pt2;
1198  ossim_int32 maxOffsetLine3Pt2;
1199  getMaxAndIndex(&theLeftEdge[line3_pt2-100],&theLeftEdge[line3_pt2+100],
1200  maxValueLine3Pt2, maxOffsetLine3Pt2 );
1201  line3_pt2 = line3_pt2-100 + maxOffsetLine3Pt2;
1202
1203
1204  ossim_int32 maxValueLine3Pt3;
1205  ossim_int32 maxOffsetLine3Pt3;
1206  getMaxAndIndex(&theLeftEdge[line3_pt3-100],&theLeftEdge[line3_pt3+100],
1207  maxValueLine3Pt3, maxOffsetLine3Pt3 );
1208  line3_pt3 = line3_pt3-100 + maxOffsetLine3Pt3;
1209
1210
1211  double line3RegPtsSamples[] = { static_cast<double>(theLeftEdge[line3_pt1]),
1212  static_cast<double>(theLeftEdge[line3_pt2]),
1213  static_cast<double>(theLeftEdge[line3_pt3]) };
1214  double line3RegPtsLines[] = { static_cast<double>(-line3_pt1),
1215  static_cast<double>(-line3_pt2),
1216  static_cast<double>(-line3_pt3) };
1217
1218  double sum_xy_line3 = 0.0;
1219  double sum_x_line3 = 0.0;
1220  double sum_y_line3 = 0.0;
1221  double mean_x_line3 = 0.0;
1222  double mean_y_line3 = 0.0;
1223  double sum_x_squared_line3 = 0.0;
1224  double sum_squared_x_line3 = 0.0;
1225  double b_line3;
1226  double a_line3;
1227  double num_elements_line3 = 3.0;
1228  for(ossim_int32 i = 0; i < num_elements_line3; ++i)
1229  {
1230  sum_xy_line3 = sum_xy_line3
1231  + (line3RegPtsSamples[i]*line3RegPtsLines[i]);
1232
1233  sum_x_line3 = sum_x_line3 + line3RegPtsSamples[i];
1234  sum_y_line3 = sum_y_line3 + line3RegPtsLines[i];
1235
1236  sum_squared_x_line3 = sum_squared_x_line3
1237  + line3RegPtsSamples[i]*line3RegPtsSamples[i];
1238
1239
1240  }
1241
1242  sum_x_squared_line3 = sum_x_line3*sum_x_line3;
1243  mean_y_line3 = sum_y_line3/num_elements_line3;
1244  mean_x_line3 = sum_x_line3/num_elements_line3;
1245  b_line3 = (sum_xy_line3 - (sum_x_line3*sum_y_line3)/num_elements_line3)
1246  / (sum_squared_x_line3 - (sum_x_squared_line3/num_elements_line3));
1247  a_line3 = mean_y_line3 - b_line3*mean_x_line3;
1248
1249  if(traceDebug())
1250  {
1251  ossimNotify(ossimNotifyLevel_DEBUG)<<"\n\n a_line3: "<< a_line3 <<std::endl
1252  <<" b_line3: "<< b_line3 <<endl;
1253  for(ossim_int32 i = 0; i < num_elements_line3; ++i)
1254  {
1255
1256  ossimNotify(ossimNotifyLevel_DEBUG) << setprecision(15) << "line3RegPtsLines[" << i << "]: "
1257  << line3RegPtsLines[i]
1258  << "\nline3RegPtsSamples[" << i << "]: "
1259  << line3RegPtsSamples[i]
1260  << std::endl;
1261  }
1262  }
1263  //End regression line3
1264
1265  //Intersect lines 2 and 3 to get the ll corner vertex
1266
1267  double ll_x = (a_line3 - a_line2)/(b_line2 - b_line3);
1268  double ll_y = -(a_line3 + b_line3*ll_x);
1269
1270  //End Regression Line3
1271
1272  //Regression Line 4
1273
1274  ossim_int32 line4_pt0 = leftMostSampleLine;
1275  ossim_int32 line4_pt4 = topLine;
1276  ossim_int32 line4_pt2 = (line4_pt0 + line4_pt4)/2;
1277  ossim_int32 line4_pt1 = (line4_pt2 + line4_pt0)/2;
1278  ossim_int32 line4_pt3 = (line4_pt2 + line4_pt4)/2;
1279
1280
1281  double line4RegPtsSamples[] = { static_cast<double>(theLeftEdge[line4_pt1]),
1282  static_cast<double>(theLeftEdge[line4_pt2]),
1283  static_cast<double>(theLeftEdge[line4_pt3])};
1284  double line4RegPtsLines[] = { static_cast<double>(-line4_pt1),
1285  static_cast<double>(-line4_pt2),
1286  static_cast<double>(-line4_pt3) };
1287
1288  double sum_xy_line4 = 0.0;
1289  double sum_x_line4 = 0.0;
1290  double sum_y_line4 = 0.0;
1291  double mean_x_line4 = 0.0;
1292  double mean_y_line4 = 0.0;
1293  double sum_x_squared_line4 = 0.0;
1294  double sum_squared_x_line4 = 0.0;
1295  double b_line4;
1296  double a_line4;
1297  double num_elements_line4 = 3.0;
1298  for(ossim_int32 i = 0; i < num_elements_line4; ++i)
1299  {
1300  sum_xy_line4 = sum_xy_line4
1301  + (line4RegPtsSamples[i]*line4RegPtsLines[i]);
1302
1303  sum_x_line4 = sum_x_line4 + line4RegPtsSamples[i];
1304  sum_y_line4 = sum_y_line4 + line4RegPtsLines[i];
1305
1306  sum_squared_x_line4 = sum_squared_x_line4
1307  + line4RegPtsSamples[i]*line4RegPtsSamples[i];
1308
1309
1310  }
1311
1312  sum_x_squared_line4 = sum_x_line4*sum_x_line4;
1313  mean_y_line4 = sum_y_line4/num_elements_line4;
1314  mean_x_line4 = sum_x_line4/num_elements_line4;
1315  b_line4 = (sum_xy_line4 - (sum_x_line4*sum_y_line4)/num_elements_line4)
1316  / (sum_squared_x_line4 - (sum_x_squared_line4/num_elements_line4));
1317  a_line4 = mean_y_line4 - b_line4*mean_x_line4;
1318
1319  if(traceDebug())
1320  {
1321  ossimNotify(ossimNotifyLevel_DEBUG)<< "\n\n a_line4: "<< a_line4 <<std::endl;
1322  ossimNotify(ossimNotifyLevel_DEBUG)<< " b_line4: "<< b_line4 <<std::endl;
1323
1324  for(ossim_int32 i = 0; i < num_elements_line4; ++i)
1325  {
1326  ossimNotify(ossimNotifyLevel_DEBUG) << setprecision(15) << "line4RegPtsLines[" << i << "]: "
1327  <<line4RegPtsLines[i]
1328  << "\nline4RegPtsSamples[" << i << "]: "
1329  <<line4RegPtsSamples[i]
1330  << std::endl;
1331  }
1332
1333  }
1334  //End regression line 4
1335
1336  //Intersect lines 3 and 4 to get the ul corner vertex
1337
1338  double ul_x = (a_line4 - a_line3)/(b_line3 - b_line4);
1339  double ul_y = -(a_line4 + b_line4*ul_x);
1340  //End Regression Line4
1341
1342  //Intersect lines 4 and 1 to get the ur corner vertex
1343
1344  double ur_x = (a_line4 - a_line1)/(b_line1 - b_line4);
1345  double ur_y = -(a_line4 + b_line4*ur_x);
1346
1347  if (traceDebug())
1348  {
1349  ossimNotify(ossimNotifyLevel_DEBUG) <<"Initial corners for tilted left: "
1350  <<"\ncorner0: ("<<ul_x<<", "<<ul_y<<")"
1351  <<"\ncorner1: ("<<ur_x<<", "<<ur_y<<")"
1352  <<"\ncorner2: ("<<lr_x<<", "<<lr_y<<")"
1353  <<"\ncorner3: ("<<ll_x<<", "<<ll_y<<")" <<std::endl;
1354  }
1355
1356  leftCornerLine_A = (ossim_int32)ul_y;
1357  leftCorner_A = (ossim_int32)ul_x; //0
1358
1359  rightCornerLine_A = (ossim_int32)ur_y;
1360  rightCorner_A = (ossim_int32)ur_x; //1
1361
1362  rightCornerLine_B = (ossim_int32)lr_y;
1363  rightCorner_B =(ossim_int32)lr_x; //2
1364
1365  leftCornerLine_B = (ossim_int32)ll_y;
1366  leftCorner_B =(ossim_int32)ll_x; //3
1367
1368  // Check for bad corner points due to irregular shape image
1369
1370  //for corner 0 (ul), line should be between top and bottom line
1371  // sample should can go negative due to jagged edges
1372
1373  //for corner 1 (ur), sample should be between left and right most samples
1374  // line can go negative due to jagged edges
1375
1376  //for corner 2 (lr), line should be between top and bottom lines
1377  // sample can be greater than rightMost samp due to jagged edges
1378
1379  //for corner 3 (ll), line should be between top and bottom line + 200
1380  // sample should be between left and right most sample
1381  if( (leftCornerLine_A > bottomLine)
1382  || (leftCornerLine_A < topLine)
1383  || (leftCorner_A > rightMostSample)
1384  || (leftCorner_A < (leftMostSample - 300))
1385
1386  || (rightCornerLine_A < (topLine - 300))
1387  || (rightCornerLine_A > total_lines)
1388  || (rightCorner_A > rightMostSample)
1389  || (rightCorner_A < leftMostSample)
1390
1391
1392  || (rightCornerLine_B < topLine)
1393  || (rightCornerLine_B > bottomLine)
1394  || (rightCorner_B < leftMostSample)
1395  || (rightCorner_B > (rightMostSample + 200))
1396
1397  || (leftCornerLine_B > (bottomLine + 200))
1398  || (leftCornerLine_B < topLine)
1399  || (leftCorner_B < leftMostSample)
1400  || (leftCorner_B > rightMostSample) )
1401
1402  {
1403  left = false;
1404
1405  if (traceDebug())
1406  {
1407  ossimNotify(ossimNotifyLevel_DEBUG) <<"\n\n***Case = NOT TILTED LEFT..***"<<std::endl;
1408  }
1409  }
1410  }
1411  }
1412
1413  if( (square == 0) && (rhombus == 0) && (right == 0) && (left == 0))
1414  {
1415  if (traceDebug())
1416  {
1417  ossimNotify(ossimNotifyLevel_DEBUG)<<"\nDefault case"<<std::endl;
1418  }
1419
1420  //Suboptimal UL Corner:
1421  leftCornerLine_A = (topLine);
1422  leftCorner_A =(leftMostSample); //0
1423
1424  //Look for non-null starting at topLine and going down
1425  //Starting at left most samp and moving right
1426
1427  bool foundULcornera = false;
1428  bool foundULcornerb = false;
1429  ossimImageHandler* src = reinterpret_cast<ossimImageHandler*>(getInput(0));
1430
1431  ossimIrect tileRectUL(leftMostSample,
1432  topLine,
1433  leftMostSample+50,
1434  (topLine + 50) );
1435
1436  ossimRefPtr<ossimImageData> dataUL = src->getTile(tileRectUL);
1437  // ossimIrect imageRectangleUL = dataUL->getImageRectangle();
1438
1439  ossim_int32 tempSamp_corner0a = 0;
1440  ossim_int32 tempLine_corner0a = 0;
1441  if (dataUL.valid())
1442  {
1443  for (ossim_int32 line = tileRectUL.ul().y; line <= tileRectUL.lr().y; ++line)
1444  {
1445  for (ossim_int32 samp = tileRectUL.ul().x; samp <=tileRectUL.ur().x; ++samp)
1446  {
1447  // uses band 0 corner points
1448  if(!(dataUL->isNull(ossimIpt(samp,line),0)))
1449  {
1450
1451  foundULcornera = true;
1452
1453  //Optimal Corner:
1454  leftCornerLine_A = line;//0
1455  leftCorner_A = samp;
1456  tempLine_corner0a = line;
1457  tempSamp_corner0a = samp;
1458
1459  if (traceDebug())
1460  {
1462  <<"\nFound non null in ul corner pass 1 "<<std::endl
1463  <<"line: "<<line<<std::endl
1464  <<"samp: "<<samp<<std::endl;
1465  }
1466  }
1467  if(foundULcornera == true){break;}
1468  }
1469  if(foundULcornera == true){break;}
1470  }
1471
1472  // Search in the other direction to handle the case of 'jaggered' edges.
1473  ossim_int32 tempSamp_corner0b = 0;
1474  ossim_int32 tempLine_corner0b = 0;
1475  for (ossim_int32 samp = tileRectUL.ul().x; samp <=tileRectUL.ur().x; ++samp)
1476  {
1477  for (ossim_int32 line = tileRectUL.ul().y; line <= tileRectUL.lr().y; ++line)
1478  {
1479  // uses band 0 corner points
1480  if(!(dataUL->isNull(ossimIpt(samp,line),0)))
1481  {
1482
1483  foundULcornerb = true;
1484
1485  //Optimal Corner:
1486  leftCornerLine_A = line;//0
1487  leftCorner_A = samp;
1488  tempLine_corner0b = line;
1489  tempSamp_corner0b = samp;
1490
1491  if (traceDebug())
1492  {
1494  <<"\nFound non null in ul corner pass 2 "<<std::endl
1495  <<"line: "<<line<<std::endl
1496  <<"samp: "<<samp<<std::endl;
1497  }
1498  }
1499  if(foundULcornerb == true){break;}
1500  }
1501  if(foundULcornerb == true){break;}
1502  }
1503
1504  //Better corner
1505  if(foundULcornerb == true && foundULcornera ==true)
1506  {
1507  leftCornerLine_B = (tempLine_corner0a + tempLine_corner0b)/2;
1508  leftCorner_B = (tempSamp_corner0a + tempSamp_corner0b)/2;
1509  }
1510
1511
1512  // Suboptimal UR corner:
1513  rightCornerLine_A = (topLine);
1514  rightCorner_A = (rightMostSample); //1
1515
1516  }
1517  //Look for non-null starting at topLine and going down
1518  //Starting at right most samp and moving left
1519
1520  bool foundURcornera = false;
1521  bool foundURcornerb = false;
1522
1523  ossimIrect tileRectUR((rightMostSample - 50),
1524  topLine,
1525  rightMostSample,
1526  (topLine + 50) );
1527
1528  ossimRefPtr<ossimImageData> dataUR = src->getTile(tileRectUR);
1529  // ossimIrect imageRectangleUR = dataUR->getImageRectangle();
1530
1531  ossim_int32 tempSamp_corner1a = 0;
1532  ossim_int32 tempLine_corner1a = 0;
1533
1534  if (dataUR.valid())
1535  {
1536  for (ossim_int32 line = tileRectUR.ul().y; line <= tileRectUR.lr().y; ++line)
1537  {
1538  for (ossim_int32 samp = tileRectUR.ur().x; samp > tileRectUR.ul().x; --samp)
1539  {
1540
1541  if(!(dataUR->isNull(ossimIpt(samp,line),0)))
1542  {
1543
1544  foundURcornera = true;
1545  rightCornerLine_A = line;
1546  rightCorner_A = samp;
1547  tempLine_corner1a = line;
1548  tempSamp_corner1a = samp;
1549
1550  if (traceDebug())
1551  {
1553  <<"\nFound non null in ur corner pass 1 "<<std::endl
1554  <<"line: "<<line<<std::endl
1555  <<"samp: "<<samp<<std::endl;
1556  }
1557  }
1558  if(foundURcornera == true){break;}
1559  }
1560  if(foundURcornera == true){break;}
1561  }
1562
1563  // Search in the other direction to handle the case of 'jaggered' edges.
1564  ossim_int32 tempSamp_corner1b = 0;
1565  ossim_int32 tempLine_corner1b = 0;
1566
1567  for (ossim_int32 samp = tileRectUR.ur().x; samp > tileRectUR.ul().x; --samp)
1568  {
1569  for (ossim_int32 line = tileRectUR.ul().y; line <= tileRectUR.lr().y; ++line)
1570
1571  {
1572  if(!(dataUR->isNull(ossimIpt(samp,line),0)))
1573  {
1574
1575  foundURcornerb = true;
1576  rightCornerLine_A = line;
1577  rightCorner_A = samp;
1578  tempLine_corner1b = line;
1579  tempSamp_corner1b = samp;
1580
1581  if (traceDebug())
1582  {
1584  <<"\nFound non null in ur corner pass 2 "<<std::endl
1585  <<"line: "<<line<<std::endl
1586  <<"samp: "<<samp<<std::endl;
1587  }
1588  }
1589  if(foundURcornerb == true){break;}
1590  }
1591  if(foundURcornerb == true){break;}
1592  }
1593
1594  //Better corner
1595  if(foundURcornerb == true && foundURcornera ==true)
1596  {
1597  rightCornerLine_B = (tempLine_corner1a + tempLine_corner1b)/2;
1598  rightCorner_B = (tempSamp_corner1a + tempSamp_corner1b)/2;
1599  }
1600
1601  // Suboptimal LR corner:
1602  rightCornerLine_B = (bottomLine);
1603  rightCorner_B = (rightMostSample); //2
1604
1605  }
1606
1607  //Look for non-null starting at bottomLine and going up
1608  //Starting at right most samp and moving left
1609
1610  bool foundLRcornera = false;
1611  bool foundLRcornerb = false;
1612
1613  ossimIrect tileRectLR((rightMostSample - 50),
1614  bottomLine - 50,
1615  rightMostSample,
1616  (bottomLine) );
1617
1618  ossimRefPtr<ossimImageData> dataLR = src->getTile(tileRectLR);
1619  // ossimIrect imageRectangleLR = dataLR->getImageRectangle();
1620
1621  ossim_int32 tempSamp_corner2a = 0;
1622  ossim_int32 tempLine_corner2a = 0;
1623
1624  if (dataLR.valid())
1625  {
1626  for (ossim_int32 line = tileRectLR.lr().y; line >= tileRectLR.ur().y; --line)
1627  {
1628  for (ossim_int32 samp = tileRectLR.lr().x; samp > tileRectLR.ul().x; --samp)
1629  {
1630
1631  if(!(dataLR->isNull(ossimIpt(samp,line),0)))
1632  {
1633
1634  foundLRcornera = true;
1635  rightCornerLine_B = line;
1636  rightCorner_B = samp;
1637  tempLine_corner2a = line;
1638  tempSamp_corner2a = samp;
1639
1640  if (traceDebug())
1641  {
1643  <<"\nFound non null in lr corner pass 1 "<<std::endl
1644  <<"line: "<<line<<std::endl
1645  <<"samp: "<<samp<<std::endl;
1646  }
1647  }
1648  if(foundLRcornera == true){break;}
1649  }
1650  if(foundLRcornera == true){break;}
1651  }
1652  // Search in the other direction to handle the case of 'jaggered' edges.
1653
1654  ossim_int32 tempSamp_corner2b = 0;
1655  ossim_int32 tempLine_corner2b = 0;
1656
1657  for (ossim_int32 samp = tileRectLR.lr().x; samp > tileRectLR.ul().x; --samp)
1658  {
1659  for (ossim_int32 line = tileRectLR.lr().y; line >= tileRectLR.ur().y; --line)
1660  {
1661  if(!(dataLR->isNull(ossimIpt(samp,line),0)))
1662  {
1663
1664  foundLRcornerb = true;
1665  rightCornerLine_B = line;
1666  rightCorner_B = samp;
1667  tempLine_corner2b = line;
1668  tempSamp_corner2b = samp;
1669
1670  if (traceDebug())
1671  {
1673  <<"\nFound non null in lr corner pass 2"<<std::endl
1674  <<"line: "<<line<<std::endl
1675  <<"samp: "<<samp<<std::endl;
1676  }
1677  }
1678  if(foundLRcornerb == true){break;}
1679  }
1680  if(foundLRcornerb == true){break;}
1681  }
1682  //Better corner
1683  if(foundLRcornerb == true && foundLRcornera ==true)
1684  {
1685  rightCornerLine_B = (tempLine_corner2a + tempLine_corner2b)/2;
1686  rightCorner_B = (tempSamp_corner2a + tempSamp_corner2b)/2;
1687  }
1688  // Suboptimal LL corner:
1689  leftCornerLine_B = (bottomLine);
1690  leftCorner_B = (leftMostSample); //3
1691
1692  }
1693
1694  //Look for non-null starting at bottomLine and going up
1695  //Starting at left most samp and moving right
1696
1697  bool foundLLcornera = false;
1698  bool foundLLcornerb = false;
1699
1700  ossimIrect tileRectLL((leftMostSample),
1701  (bottomLine - 50),
1702  (leftMostSample +50),
1703  (bottomLine) );
1704
1705  ossimRefPtr<ossimImageData> dataLL = src->getTile(tileRectLL);
1706  // ossimIrect imageRectangleLL = dataLL->getImageRectangle();
1707
1708  ossim_int32 tempSamp_corner3a = 0;
1709  ossim_int32 tempLine_corner3a = 0;
1710
1711  if (dataLL.valid())
1712  {
1713  for (ossim_int32 samp = tileRectLL.ul().x; samp <= tileRectLL.ur().x; ++samp)
1714  {
1715
1716  for (ossim_int32 line = tileRectLL.lr().y; line >= tileRectLL.ul().y; --line)
1717
1718  {
1719
1720  if(!(dataLL->isNull(ossimIpt(samp,line),0)))
1721  {
1722
1723  foundLLcornera = true;
1724  leftCornerLine_B = line;
1725  leftCorner_B = samp;
1726  tempLine_corner3a = line;
1727  tempSamp_corner3a = samp;
1728
1729  if (traceDebug())
1730  {
1732  <<"\nFound non null in ll corner pass 1"<<std::endl
1733  <<"line: "<<line<<std::endl
1734  <<"samp: "<<samp<<std::endl;
1735  }
1736  }
1737  if(foundLLcornera == true){break;}
1738  }
1739  if(foundLLcornera == true){break;}
1740  }
1741
1742  // Search in the other direction to handle the case of 'jaggered' edges.
1743
1744  ossim_int32 tempSamp_corner3b = 0;
1745  ossim_int32 tempLine_corner3b = 0;
1746  for (ossim_int32 line = tileRectLL.lr().y; line >= tileRectLL.ul().y; --line)
1747  {
1748
1749  for (ossim_int32 samp = tileRectLL.ul().x; samp <= tileRectLL.ur().x; ++samp)
1750
1751  {
1752
1753  if(!(dataLL->isNull(ossimIpt(samp,line),0)))
1754  {
1755
1756  foundLLcornerb = true;
1757  leftCornerLine_B = line;
1758  leftCorner_B = samp;
1759  tempLine_corner3b = line;
1760  tempSamp_corner3b = samp;
1761
1762  if (traceDebug())
1763  {
1765  <<"\nFound non null in ll corner pass 2 "<<std::endl
1766  <<"line: "<<line<<std::endl
1767  <<"samp: "<<samp<<std::endl;
1768  }
1769  }
1770  if(foundLLcornerb == true){break;}
1771  }
1772  if(foundLLcornerb == true){break;}
1773  }
1774
1775  //Better corner
1776  if(foundLLcornerb == true && foundLLcornera ==true)
1777  {
1778  leftCornerLine_B = (tempLine_corner3a + tempLine_corner3b)/2;
1779  leftCorner_B = (tempSamp_corner3a + tempSamp_corner3b)/2;
1780  }
1781  }
1782  }
1783
1784  theVertice[0].x = leftCorner_A;
1785  theVertice[0].y = leftCornerLine_A;
1786
1787  theVertice[1].x = rightCorner_A;
1788  theVertice[1].y = rightCornerLine_A;
1789
1790  theVertice[3].x = leftCorner_B;
1791  theVertice[3].y = leftCornerLine_B;
1792
1793  theVertice[2].x = rightCorner_B;
1794  theVertice[2].y = rightCornerLine_B;
1795
1796  if (leftSlope)
1797  {
1798  delete [] leftSlope;
1799  leftSlope = 0;
1800  }
1801  if (rightSlope)
1802  {
1803  delete [] rightSlope;
1804  rightSlope = 0;
1805  }
1806
1807  if(traceDebug())
1808  {
1809  ossimNotify(ossimNotifyLevel_DEBUG)<<"\nleftMostSample: " << leftMostSample
1810  <<"\nleftMostSampleLine: " << leftMostSampleLine
1811  <<"\n\nrightMostSample: " << rightMostSample
1812  <<"\nrightMostSampleLine: " << rightMostSampleLine
1813
1814  <<"\n\nfirstLeftSample: " << firstLeftSample
1815  <<"\nfirstRightSample: " << firstRightSample
1816
1817  <<"\n\nlastLeftSample: " << lastLeftSample
1818  <<"\nlastRightSample: " << lastRightSample
1819
1820  <<"\n\ntopLine: " << topLine
1821  <<"\nbottomLine: " << bottomLine
1822  <<"\ntotal_lines: " << total_lines
1823
1824  << "\n\n\ntheVertice[0]: " << theVertice[0]
1825  << "\ntheVertice[1]: " << theVertice[1]
1826  << "\ntheVertice[2]: " << theVertice[2]
1827  << "\ntheVertice[3]: " << theVertice[3]
1828  << "\n\nreturning..." << std::endl;
1829  }
1830
1831  return true;
1832 }
#define CLOG
bool valid() const
Definition: ossimRefPtr.h:75
ossim_uint32 height() const
Definition: ossimIrect.h:487
#define OSSIM_INT_NAN
T square(T x)
Definition: ossimCommon.h:334
bool isNull(ossim_uint32 offset) const
This class defines an abstract Handler which all image handlers(loaders) should derive from...
void getMaxAndIndex(T2 *start, T2 *end, T2 &maxValue, ossim_int32 &offsetFromStart)
void getMinAndIndex(T1 *start, T1 *end, T1 &minValue, ossim_int32 &offsetFromStart)
int ossim_int32
◆ getListenerManagerInterface()
virtual ossimListenerManager* ossimVertexExtractor::getListenerManagerInterface ( )
inlinevirtual
Definition at line 91 of file ossimVertexExtractor.h.
92  {
93  return this;
94  }
◆ getMaxAndIndex()
template<class T2 >
void ossimVertexExtractor::getMaxAndIndex ( T2 *  start,
T2 *  end,
T2 &  maxValue,
ossim_int32 offsetFromStart
protected
Definition at line 1930 of file ossimVertexExtractor.cpp.
1932 {
1933
1934  offsetFromStart =0;
1935  ossim_int32 currentOffset = 0;
1936  maxValue = *start;
1937  while(start < end)
1938  {
1939  if(*start > maxValue)
1940  {
1941  maxValue = *start;
1942  offsetFromStart = currentOffset;
1943  }
1944  ++start;
1945  ++currentOffset;
1946  }
1947 }
int ossim_int32
◆ getMinAndIndex()
template<class T1 >
void ossimVertexExtractor::getMinAndIndex ( T1 *  start,
T1 *  end,
T1 &  minValue,
protected
Definition at line 1909 of file ossimVertexExtractor.cpp.
1911 {
1912
1913  offsetFromStart =0;
1914  ossim_int32 currentOffset = 0;
1915  minValue = *start;
1916  while(start < end)
1917  {
1918  if(*start < minValue)
1919  {
1920
1921  minValue = *start;
1922  offsetFromStart = currentOffset;
1923  }
1924  ++start;
1925  ++currentOffset;
1926  }
1927 }
int ossim_int32
◆ getObject() [1/2]
virtual ossimObject* ossimVertexExtractor::getObject ( )
inlinevirtual
Definition at line 38 of file ossimVertexExtractor.h.
39  {
40  return this;
41  }
◆ getObject() [2/2]
virtual const ossimObject* ossimVertexExtractor::getObject ( ) const
inlinevirtual
Definition at line 42 of file ossimVertexExtractor.h.
43  {
44  return this;
45  }
◆ getObjectInterface()
virtual ossimObject* ossimVertexExtractor::getObjectInterface ( )
inlinevirtual
Definition at line 89 of file ossimVertexExtractor.h.
89 { return this; }
◆ getVertices()
const vector<ossimIpt>& ossimVertexExtractor::getVertices ( ) const
inline
Definition at line 112 of file ossimVertexExtractor.h.
112 { return theVertice; }
◆ isOpen()
bool ossimVertexExtractor::isOpen ( ) const
virtual
Returns true if "theFileStream" is open, false if not.
Definition at line 1878 of file ossimVertexExtractor.cpp.
References theFileStream.
Referenced by close(), open(), and setOutputName().
1879 {
1880  return const_cast<ofstream*>(&theFileStream)->is_open();
1881 }
std::basic_ofstream< char > ofstream
Class for char output file streams.
Definition: ossimIosFwd.h:47
◆ open()
bool ossimVertexExtractor::open ( )
virtual
Opens "theFilename" for output. Returns true on success, false on error. Notes:
  • If the file was previously open then it will close it and re-opens the file.
  • Returns false if "theFilename" has not been set.
Definition at line 1883 of file ossimVertexExtractor.cpp.
References ossimString::c_str(), close(), isOpen(), ossimFilename::NIL, ossimNotify(), ossimNotifyLevel_WARN, theFilename, and theFileStream.
1884 {
1885  if(isOpen())
1886  {
1887  close();
1888  }
1889
1891  {
1892  ossimNotify(ossimNotifyLevel_WARN) << "ossimVertexExtractor::open WARNING:"
1893  << "\nOutput file has not been set. Call setFilename() method..."
1894  << std::endl;
1895  return false;
1896  }
1897
1899
1900  return theFileStream.good();
1901 }
const char * c_str() const
Definition: ossimString.h:396
◆ operator=()
const ossimVertexExtractor& ossimVertexExtractor::operator= ( const ossimVertexExtractor rhs)
inlineprotected
Definition at line 153 of file ossimVertexExtractor.h.
154  {return rhs;}
◆ scanForEdges()
bool ossimVertexExtractor::scanForEdges ( )
protected
Walks each line from left and right side detecting first non null pixel. Returns true on success, false on error.
Definition at line 115 of file ossimVertexExtractor.cpp.
116 {
117  static const char MODULE[] = "ossimVertexExtractor::scanForEdges";
118
119  if (traceDebug()) CLOG << " Entered..." << endl;
120
121  ossimImageSource* src = reinterpret_cast<ossimImageSource*>(getInput(0));
122  if (!src)
123  {
125  << "WARN ossimVertexExtractor::scanForEdges():"
126  << "\nInput source is null. Returning..." << std::endl;
127  return false;
128  }
129
130  // Allocate the arrays to hold the edges.
131  if (theLeftEdge) delete [] theLeftEdge;
132  if (theRightEdge) delete [] theRightEdge;
135  for (ossim_int32 i=0; i<(int)theAreaOfInterest.height(); ++i)
136  {
139  }
140
141  // Some constants needed throughout...
142  const ossim_int32 TILE_HEIGHT = src->getTileHeight();
143  const ossim_int32 TILE_WIDTH = src->getTileWidth();
144  const ossim_int32 START_LINE = theAreaOfInterest.ul().y;
145  const ossim_int32 STOP_LINE = theAreaOfInterest.lr().y;
146  const ossim_int32 START_SAMP = theAreaOfInterest.ul().x;
147  const ossim_int32 STOP_SAMP = theAreaOfInterest.lr().x;
148
149  // For percent complete status.
150  double total_tiles_y_dir = theAreaOfInterest.height() / TILE_HEIGHT;
151  if (theAreaOfInterest.height() % TILE_HEIGHT) total_tiles_y_dir += 1.0;
152  double tiles_processed = 0.0;
153
154  // Set the status message to be "scanning source for edges..."
155  ossimNotify(ossimNotifyLevel_INFO) << "Scanning image source for edges..." << std::endl;
156
157  // Start off with a percent complete at 0...
158  setPercentComplete(0.0);
159
160  // Start of loop to get the left edges.
161
162  // Tile loop in line direction through area of interest.
163
164  for (ossim_int32 line = START_LINE; line < STOP_LINE; line += TILE_HEIGHT)
165  {
166  const ossim_int32 START_INDEX = line - START_LINE;
167  const ossim_int32 STOP_INDEX = ( (line+TILE_HEIGHT-1) < STOP_LINE ) ?
168  (START_INDEX+TILE_HEIGHT-1) :
170  const ossim_int32 TILE_LINE_STOP = ((line+TILE_HEIGHT-1) < STOP_LINE) ?
171  (line+TILE_HEIGHT-1) : STOP_LINE;
172
173  // See if all the edges have been found for these tile lines.
174  bool all_edges_found = true;
175  for (ossim_int32 i = START_INDEX; i <= STOP_INDEX; ++i)
176  {
177  if (theLeftEdge[i] == OSSIM_INT_NAN)
178  {
179  all_edges_found = false;
180  break;
181  }
182  }
183
184  // Extract the left edges...
185  if (all_edges_found == false)
186  {
187  //***
188  // Tile loop in sample direction through area of interest
189  // (left edges).
190  //***
191  for (ossim_int32 samp = START_SAMP; samp < STOP_SAMP; samp += TILE_WIDTH)
192  {
193  // Get the tile.
195  src->getTile(ossimIpt(samp, line));
196
197  if (!id.valid() || id->getDataObjectStatus() == OSSIM_NULL ||
198  id->getDataObjectStatus() == OSSIM_EMPTY)
199  {
200  continue; // Nothing to do...
201  }
202
203  // Line loop through tile.
204  const ossim_int32 TILE_SAMP_STOP = ((samp+TILE_WIDTH-1) < STOP_SAMP) ?
205  (samp+TILE_WIDTH-1) : STOP_SAMP;
206
207  for (ossim_int32 y = line; y <= TILE_LINE_STOP; ++y)
208  {
209  ossim_int32 edge_index = y - START_LINE;
210  if (theLeftEdge[edge_index] == OSSIM_INT_NAN)
211  {
212  for (ossim_int32 x = samp; x <= TILE_SAMP_STOP; ++x)
213  {
214  if (! (id->isNull(ossimIpt(x,y))))
215  {
216  // Capture the first valid pixel.
217  theLeftEdge[edge_index] = x - START_SAMP;
218  break;
219  }
220  }
221  }
222  }
223  } // End of tile loop in sample direction through area of interest.
224  } // End of (all_lines_checked == false) (left edges)
225
226  // See if all the right edges have been found for these tile lines.
227  all_edges_found = true;
228  for (ossim_int32 i = START_INDEX; i <= STOP_INDEX; ++i)
229  {
230  if (theRightEdge[i] == OSSIM_INT_NAN)
231  {
232  all_edges_found = false;
233  break;
234  }
235  }
236
237  // Extract the right edges...
238  if (all_edges_found == false)
239  {
240  //***
241  // Tile loop in sample direction through area of interest
242  // (right edges).
243  //***
244
245  // Get the x origin of the last tile in a row.
246  const ossim_int32 END_TILE_X = START_SAMP + ((theAreaOfInterest.width()/
247  TILE_WIDTH)*TILE_WIDTH);
248
249
250  for (ossim_int32 samp = END_TILE_X; samp >= START_SAMP; samp -= TILE_WIDTH)
251  {
252  // Get the tile.
254  src->getTile(ossimIpt(samp, line));
255
256  if (!id.valid() || id->getDataObjectStatus() == OSSIM_NULL ||
257  id->getDataObjectStatus() == OSSIM_EMPTY)
258  {
259  continue; // Nothing to do...
260  }
261
262  // Line loop through tile.
263  const ossim_int32 TILE_SAMP_STOP = ((samp+TILE_WIDTH-1) < STOP_SAMP) ?
264  (samp+TILE_WIDTH-1) : STOP_SAMP;
265
266  for (ossim_int32 y = line; y <= TILE_LINE_STOP; ++y)
267  {
268  ossim_int32 edge_index = y - START_LINE;
269  if (theRightEdge[edge_index] == OSSIM_INT_NAN)
270  {
271  for (ossim_int32 x = TILE_SAMP_STOP; x >= samp; --x)
272  {
273  if (! (id->isNull(ossimIpt(x,y))))
274  {
275  // Capture the first valid pixel.
276  theRightEdge[edge_index] = x - START_SAMP;
277  break;
278  }
279  }
280  }
281  }
282
283  } // End of tile loop in sample direction through area of interest.
284
285  } // End of (all_lines_checked == false)
286
287  // Set the percent complete.
288  tiles_processed += 1.0;
289  setPercentComplete(tiles_processed/total_tiles_y_dir*100.0);
290  } // End of loop through tiles in line direction.
291
292  setPercentComplete(100.0);
293
294  if (traceDebug())
295  {
296  CLOG << "DEBUG:" << endl;
297  for (ossim_int32 i=0; i<(int)theAreaOfInterest.height(); ++i)
298  {
299  ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG: left[" << i << "]: "
300  << theLeftEdge[i]
301  << " right[" << i << "]: "
302  << theRightEdge[i]
303  << std::endl;
304  }
305  }
306
307
308  return true;
309 }
ossim_uint32 x
#define CLOG
virtual void setPercentComplete(double percentComplete)
ossim_uint32 y
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
const ossimIpt & ul() const
Definition: ossimIrect.h:274
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
const ossimIpt & lr() const
Definition: ossimIrect.h:276
ossim_uint32 width() const
Definition: ossimIrect.h:500
ossim_int32 y
Definition: ossimIpt.h:142
ossim_int32 x
Definition: ossimIpt.h:141
int ossim_int32
◆ setAreaOfInterest()
void ossimVertexExtractor::setAreaOfInterest ( const ossimIrect rect)
Sets the area of interest in the source to extract the vertices from.
Parameters
rectossimIrec representing source area of interest.
Definition at line 1873 of file ossimVertexExtractor.cpp.
References theAreaOfInterest.
1874 {
1875  theAreaOfInterest = rect;
1876 }
◆ setOutputName()
void ossimVertexExtractor::setOutputName ( const ossimString filename)
virtual
Sets the name of the output keyword list file which the vertices will be dumped to.
Parameters
filenameossimFilename representing the output file.
Note:
  • If "theFileStream" is open it will be closed.
Reimplemented from ossimOutputSource.
Definition at line 1864 of file ossimVertexExtractor.cpp.
References close(), isOpen(), ossimOutputSource::setOutputName(), and theFilename.
1865 {
1867
1868  if (isOpen()) close();
1869
1870  theFilename = filename;
1871 }
virtual void setOutputName(const ossimString &outputName)
◆ setPercentComplete()
virtual void ossimVertexExtractor::setPercentComplete ( double  percentComplete)
inlinevirtual
Reimplemented from ossimProcessInterface.
Definition at line 97 of file ossimVertexExtractor.h.
References ossimListenerManager::fireEvent(), and ossimProcessInterface::setPercentComplete().
98  {
100  ossimProcessProgressEvent event(this,
101  percentComplete);
102  fireEvent(event);
103  }
virtual void fireEvent(ossimEvent &event)
◆ writeVertices()
bool ossimVertexExtractor::writeVertices ( )
protected
Writes the result to the output file (theFilename). Returns true on success, false on error.
Definition at line 1834 of file ossimVertexExtractor.cpp.
1835 {
1836  static const char MODULE[] = "ossimVertexExtractor::writeVertices";
1837
1838  if (traceDebug()) CLOG << " Entered..." << endl;
1839
1840  if (!isOpen())
1841  {
1842  // Try to open.
1843  if (!open()) return false;
1844  }
1845
1846  // Write the points...
1847  theFileStream << "point0.x: " << theVertice[0].x
1848  << "\npoint0.y: " << theVertice[0].y
1849  << "\npoint1.x: " << theVertice[1].x
1850  << "\npoint1.y: " << theVertice[1].y
1851  << "\npoint2.x: " << theVertice[2].x
1852  << "\npoint2.y: " << theVertice[2].y
1853  << "\npoint3.x: " << theVertice[3].x
1854  << "\npoint3.y: " << theVertice[3].y
1855  << endl;
1856
1857  // Close the file...
1858  close();
1859
1860  return true;
1861 }
#define CLOG
virtual bool isOpen() const
vector< ossimIpt > theVertice
Member Data Documentation
◆ theAreaOfInterest
ossimIrect ossimVertexExtractor::theAreaOfInterest
protected
Definition at line 144 of file ossimVertexExtractor.h.
Referenced by ossimVertexExtractor(), and setAreaOfInterest().
◆ theFilename
ossimFilename ossimVertexExtractor::theFilename
protected
Definition at line 145 of file ossimVertexExtractor.h.
Referenced by open(), and setOutputName().
◆ theFileStream
std::ofstream ossimVertexExtractor::theFileStream
protected
Definition at line 146 of file ossimVertexExtractor.h.
Referenced by close(), isOpen(), and open().
◆ theLeftEdge
ossim_int32* ossimVertexExtractor::theLeftEdge
protected
Definition at line 148 of file ossimVertexExtractor.h.
Referenced by ~ossimVertexExtractor().
◆ theRightEdge
ossim_int32* ossimVertexExtractor::theRightEdge
protected
Definition at line 149 of file ossimVertexExtractor.h.
◆ theVertice
vector<ossimIpt> ossimVertexExtractor::theVertice
protected
Definition at line 147 of file ossimVertexExtractor.h.
