26 static ossimTrace traceDebug(
"ossimBandSelector:debug");
35 m_withinRangeFlag(ossimBandSelectorWithinRangeFlagState_NOT_SET),
36 m_passThroughFlag(false),
37 m_delayLoadRgbFlag(false),
38 m_inputIsSelectable(false)
121 bool disablePassThru)
123 if ( outputBandList.size() )
127 if ( !disablePassThru )
129 bool setBands =
false;
142 if ( setBands ==
false )
370 const char* prefix)
const 416 if ( (bs ==
"rgb" ) || (bs ==
"default"))
433 long numberOfBands = (long)keys.size();
435 std::vector<int>::size_type idx = 0;
436 std::vector<int> numberList(numberOfBands);
437 for(idx = 0; idx < keys.size();++idx)
441 numberList[idx] = numberStr.
toInt();
443 std::sort(numberList.begin(), numberList.end());
444 for(idx=0;idx < numberList.size();++idx)
446 const char* bandValue =
469 std::vector<ossim_uint32> inputList;
476 std::vector<ossim_uint32>::size_type i = 0;
496 "Method called prior to initialization!\n";
518 <<
"ossimBandSelector::outputBandsWithinInputRange() ERROR:" 519 <<
"Output band greater than highest input band. " 533 <<
"ossimBandSelector::outputBandsWithinInputRange() ERROR:" 534 <<
"Method called prior to initialization!" << std::endl;
558 return ossimString(
"Band Selector, maps an input band to the output band.");
568 if( property.
valid() )
570 if(property->
getName() ==
"bands")
572 std::vector<ossim_uint32> selection;
579 else if(property->
getName() ==
"bandSelection")
582 std::vector<ossimString> str_vec;
583 std::vector<ossim_uint32> int_vec;
585 str.
split( str_vec,
589 if(!str_vec[i].empty())
591 int_vec.push_back( str_vec[i].toUInt32() );
605 if( name ==
"bands" )
618 else if( name ==
"bandSelection" )
620 std::vector<ossim_uint32> bands;
624 std::vector<ossimString> bandNames;
633 str.
join( bandNames,
650 propertyNames.push_back(
"bands");
674 if(bandSelectorVisitor.
getObjects().size() < 1)
virtual void valueToString(ossimString &valueResult) const =0
void checkPassThrough()
Will check all combinations of the band list to see if its.
ossimRefPtr< ossimImageData > m_tile
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
virtual ossim_uint32 getNumberOfInputBands() const
const ossimString & join(const std::vector< ossimString > &stringList, const ossimString &separator)
Numeric to string methods.
void toSimpleStringList(ossimString &result, const std::vector< T > &valuesList)
This will output a vector of values inst a string.
void allocate()
Called on first getTile, will initialize all data needed.
virtual void setReadOnlyFlag(bool flag)
virtual void initialize()
Initialize the data buffer.
ossimRefPtr< ossimImageHandler > getBandSelectableImageHandler() const
Finds and returns band selectable image handler.
bool toSimpleVector(std::vector< T > &result, const ossimString &stringOfPoints)
virtual void assignBand(const ossimImageData *data, ossim_uint32 source_band, ossim_uint32 output_band)
virtual ~ossimBandSelector()
virtual ossimString getShortName() const
virtual void getOutputBandList(std::vector< ossim_uint32 > &bandList) const
Initializes bandList.
virtual ossimString getLongName() const
Returns the number of input bands.
unsigned int ossim_uint32
static const char * NUMBER_OUTPUT_BANDS_KW
virtual bool getRgbBandList(std::vector< ossim_uint32 > &bandList) const
Convenience method to get the zero based rgb output band list.
virtual bool saveState(ossimKeywordlist &kwl, const char *prefix=NULL) const
static const char * BANDS_KW
virtual bool isBandSelector() const
Indicates whether or not the image handler can control output band selection via the setOutputBandLis...
ossimBandSelectorWithinRangeFlagState m_withinRangeFlag
std::vector< ossimString > getSubstringKeyList(const ossimString ®ularExpression) const
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual void makeBlank()
T * getObjectAs(ossim_uint32 idx=0)
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual void setThreeBandRgb()
Will set to three bands (rgb) out.
virtual void setOutputBandList(const vector< ossim_uint32 > &outputBandList, bool disablePassThru=false)
Sets the output band list.
Attempts to derive rgb bands from image handler to the left of the band selector. ...
std::vector< ossim_uint32 > m_outputBandList
virtual void accept(ossimVisitor &visitor)
We will add a visitor interface for all connectable objects.
#define RTTI_DEF1(cls, name, b1)
Initializes bandList to the zero based order of output bands.
bool outputBandsWithinInputRange() const
virtual ossim_uint32 getNumberOfInputBands() const =0
virtual bool setOutputBandList(const std::vector< ossim_uint32 > &band_list)
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled...
Override base class so that a disableSource event does not reinitialize the object and enable itself...
void setCacheRefreshBit()
const ossimString & getName() const
