32 static ossimTrace traceDebug(
"ossimFgdcFileWriter:debug");
40 theSourceImageFilename()
53 <<
"ossimFgdcFileWriter::writeFile no filename set!" << endl;
60 <<
"ossimFgdcFileWriter::writeFile no input connection!" << endl;
68 <<
79 <<
"ossimFgdcFileWriter::writeFile Not map projected." 86 os <<
"<?xml version=\"1.0\" encoding=\"ISO-8859-1\" ?>\n" 87 <<
"<?xml-stylesheet type=\"text/xsl\" href=\"/common/fgdc_classic.xsl\" ?>\n";
116 os <<
find(
ossimString(
"/metadata/idinfo/citation/citeinfo/serinfo/sername"));
128 os <<
find(
ossimString(
"/metadata/idinfo/citation/citeinfo/pubinfo/pubplace"));
132 os <<
find(
ossimString(
"/metadata/idinfo/citation/citeinfo/pubinfo/publish"));
160 os <<
find(
ossimString(
"/metadata/idinfo/timeperd/timeinfo/sngdate/caldate"));
258 os <<
find(
ossimString(
"/metadata/idinfo/ptcontac/cntinfo/cntperp/cntper"));
265 os <<
find(
ossimString(
"/metadata/idinfo/ptcontac/cntinfo/cntaddr/addrtype"));
269 os <<
find(
ossimString(
"/metadata/idinfo/ptcontac/cntinfo/cntaddr/address"));
273 os <<
find(
ossimString(
"/metadata/idinfo/ptcontac/cntinfo/cntaddr/city"));
277 os <<
find(
ossimString(
"/metadata/idinfo/ptcontac/cntinfo/cntaddr/state"));
281 os <<
find(
ossimString(
"/metadata/idinfo/ptcontac/cntinfo/cntaddr/postal"));
285 os <<
find(
ossimString(
"/metadata/idinfo/ptcontac/cntinfo/cntaddr/country"));
328 os <<
find(
ossimString(
"/metadata/distinfo/distrib/cntinfo/cntperp/cntper"));
336 os <<
find(
ossimString(
"/metadata/distinfo/distrib/cntinfo/cntaddr/addrtype"));
340 os <<
find(
ossimString(
"/metadata/distinfo/distrib/cntinfo/cntaddr/address"));
344 os <<
find(
ossimString(
"/metadata/distinfo/distrib/cntinfo/cntaddr/city"));
348 os <<
find(
ossimString(
"/metadata/distinfo/distrib/cntinfo/cntaddr/state"));
352 os <<
find(
ossimString(
"/metadata/distinfo/distrib/cntinfo/cntaddr/postal"));
356 os <<
find(
ossimString(
"/metadata/distinfo/distrib/cntinfo/cntaddr/country"));
362 os <<
find(
ossimString(
"/metadata/distinfo/distrib/cntinfo/cntvoice"));
370 os <<
find(
ossimString(
"/metadata/distinfo/distrib/cntinfo/cntemail"));
389 os <<
find(
ossimString(
"/metadata/distinfo/stdorder/digform/digtinfo/formname"));
400 os <<
find(
ossimString(
"/metadata/distinfo/stdorder/digform/digtopt/onlinopt/computer/networka/networkr"));
427 os <<
find(
ossimString(
"/metadata/metainfo/metc/cntinfo/cntperp/cntper"));
435 os <<
find(
ossimString(
"/metadata/metainfo/metc/cntinfo/cntaddr/addrtype"));
439 os <<
find(
ossimString(
"/metadata/metainfo/metc/cntinfo/cntaddr/address"));
443 os <<
find(
ossimString(
"/metadata/metainfo/metc/cntinfo/cntaddr/city"));
447 os <<
find(
ossimString(
"/metadata/metainfo/metc/cntinfo/cntaddr/state"));
451 os <<
find(
ossimString(
"/metadata/metainfo/metc/cntinfo/cntaddr/postal"));
455 os <<
find(
ossimString(
"/metadata/metainfo/metc/cntinfo/cntaddr/country"));
497 <<
"ossimFgdcFileWriter::writeTemplate Could not open: " << file
502 os <<
"<?xml version=\"1.0\" encoding=\"ISO-8859-1\" ?>\n" 503 <<
818 <<
"Wrote file: " << file.
c_str() << endl;
827 const char* lookup = kwl.
find(prefix,
"template");
832 lookup = kwl.
find(prefix,
"source_image_filename");
837 lookup = kwl.
find(prefix,
"tab_string");
842 lookup = kwl.
find(prefix,
"fgdc_template_doc");
886 os <<
"<" << tag.
c_str() <<
897 bool decrementLevel)
const 910 os <<
"</" << tag.
c_str() <<
">\n";
932 vector< ossimRefPtr<ossimXmlNode> > xml_nodes;
935 if (xml_nodes.size())
937 if (xml_nodes[0].valid())
939 result = xml_nodes[0]->getText();
946 std::vector<ossimString>& metadatatypeList)
const 948 metadatatypeList.push_back(
ossimString(
"ossim_fgdc"));
954 return (metadataType ==
"ossim_fgdc");
ossimString getTabString() const
ossimXmlDocument theTemplate
This will return the bounding rect of the source.
static const ossimFilename NIL
This was taken from Wx widgets for performing touch and access date stamps.
ossimString find(const ossimString &xpath) const
ossim_uint32 theIndentionLevel
Class to write out meta data in a Federal Geographic Data Committe (FGDC) format. ...
Numeric to string methods.
virtual bool isGeographic() const
void setTemplate(const ossimFilename &xmlTemplateFile)
void setIndentionLevel(ossim_uint32 level)
Sets the current indentation level.
ossim_uint32 getIndentionLevel() const
bool openFile(const ossimFilename &filename)
bool writeTemplate(const ossimFilename &file) const
void setTabString(const ossimString &tabString)
Sets the tab string.
std::string::size_type size() const
unsigned int ossim_uint32
virtual ~ossimFgdcFileWriter()
destructor
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
virtual bool writeFile()
Writes file to disk.
constructor
virtual ossimErrorCode getErrorStatus() const
ossimFilename theSourceImageFilename
const char * c_str() const
Returns a pointer to a null-terminated array of characters representing the string's contents...
virtual void getMetadatatypeList(std::vector< ossimString > &metadatatypeList) const
Satisfies pure virtual from ossimMetadataWriter base.
void closeTag(std::ostream &os, const ossimString &tag, bool decrementLevel) const
Closes tag decrementing indentation.
void openTag(std::ostream &os, const ossimString &tag, bool newLine) const
Writes openning tag adding any indentation and brackets.
std::basic_ofstream< char > ofstream
Class for char output file streams.
void findNodes(const ossimString &xpath, std::vector< ossimRefPtr< ossimXmlNode > > &nodelist) const
Appends any matching nodes to the list supplied (should be empty):
#define RTTI_DEF1(cls, name, b1)
virtual bool hasMetadataType(const ossimString &metadataType) const
std::basic_ostream< char > ostream
Base class for char output streams.
Method to load the state from a keyword list.
