Public Member Functions | Protected Member Functions | Private Member Functions | Private Attributes | List of all members
ossimFgdcFileWriter Class Reference
Class to write out meta data in a Federal Geographic Data Committe (FGDC) format. More...
#include <ossimFgdcFileWriter.h>
Inheritance diagram for ossimFgdcFileWriter:
ossimMetadataFileWriter ossimConnectableObject ossimProcessInterface ossimConnectableObjectListener ossimObject ossimListenerManager ossimPropertyInterface ossimListener ossimReferenced
 ossimFgdcFileWriter ()
 constructor More...
 Method to load the state from a keyword list. More...
virtual void getMetadatatypeList (std::vector< ossimString > &metadatatypeList) const
 Satisfies pure virtual from ossimMetadataWriter base. More...
virtual bool hasMetadataType (const ossimString &metadataType) const
ossim_uint32 getIndentionLevel () const
void setIndentionLevel (ossim_uint32 level)
 Sets the current indentation level. More...
ossimString getTabString () const
void setTabString (const ossimString &tabString)
 Sets the tab string. More...
void setTitle (const ossimString &pubDate)
void setTemplate (const ossimFilename &xmlTemplateFile)
ossimString find (const ossimString &xpath) const
bool writeTemplate (const ossimFilename &file) const
- Public Member Functions inherited from ossimMetadataFileWriter
 ossimMetadataFileWriter ()
virtual void initialize ()
virtual bool execute ()
virtual void setFilename (const ossimFilename &file)
const ossimFilenamegetFilename () const
virtual void setPixelType (ossimPixelType pixelType)
 Ossim uses a concept of "pixel is point" internally. More...
virtual ossimPixelType getPixelType () const
virtual void setAreaOfInterest (const ossimIrect &areaOfInterest)
 Sets the area of interest to write the meta data for. More...
virtual ossimIrect getAreaOfInterest () const
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
- Public Member Functions inherited from ossimProcessInterface
 ossimProcessInterface ()
virtual void abort ()
bool needsAborting () const
bool isAborted () const
bool isExecuting () const
void enableEvents ()
void disableEvents ()
 ProcessEvent. More...
virtual void refreshEvent (ossimRefreshEvent &)
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
virtual ~ossimFgdcFileWriter ()
 destructor More...
virtual bool writeFile ()
 Writes file to disk. More...
- Protected Member Functions inherited from ossimMetadataFileWriter
virtual ~ossimMetadataFileWriter ()
virtual ~ossimReferenced ()
void openTag (std::ostream &os, const ossimString &tag, bool newLine) const
 Writes openning tag adding any indentation and brackets. More...
void closeTag (std::ostream &os, const ossimString &tag, bool decrementLevel) const
 Closes tag decrementing indentation. More...
Private Attributes
ossim_uint32 theIndentionLevel
ossimString theTabString
ossimXmlDocument theTemplate
ossimFilename theSourceImageFilename
Additional Inherited Members
- Public Types inherited from ossimProcessInterface
enum  ossimProcessStatus {
- Protected Attributes inherited from ossimMetadataFileWriter
ossimFilename theFilename
ossimPixelType thePixelType
ossimIrect theAreaOfInterest
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
- Protected Attributes inherited from ossimProcessInterface
double thePercentComplete
ossimString theMessage
bool theEventFlag
bool theListenerEnableFlag
Detailed Description
Definition at line 26 of file ossimFgdcFileWriter.h.
◆ ossimFgdcFileWriter()
ossimFgdcFileWriter::ossimFgdcFileWriter ( )
constructor
Definition at line 35 of file ossimFgdcFileWriter.cpp.
36  :
38  theTabString("\t"),
39  theTemplate(),
41 {
42 }
◆ ~ossimFgdcFileWriter()
ossimFgdcFileWriter::~ossimFgdcFileWriter ( )
protectedvirtual
destructor
Definition at line 44 of file ossimFgdcFileWriter.cpp.
45 {
46 }
Member Function Documentation
◆ closeTag()
void ossimFgdcFileWriter::closeTag ( std::ostream &  os,
const ossimString tag,
bool  decrementLevel
) const
private
e.g.: <metadata>
Parameters
osotream to write to.
tagString representing tag with no brackets.
decrementLevelIf true indentation level is decremented.
Definition at line 895 of file ossimFgdcFileWriter.cpp.
References ossimString::c_str(), ossimString::size(), theIndentionLevel, and theTabString.
Referenced by writeFile(), and writeTemplate().
898 {
899  if ( decrementLevel && (theIndentionLevel > 1) && theTabString.size() )
900  {
901  ossimString tab;
902  for (ossim_uint32 i = 0; i < theIndentionLevel-1; ++i)
903  {
904  tab += theTabString;
905  }
906
907  os << tab.c_str();
908  }
909
910  os << "</" << tag.c_str() << ">\n";
911
912  if (theIndentionLevel && decrementLevel)
913  {
915  }
916 }
std::string::size_type size() const
Definition: ossimString.h:405
unsigned int ossim_uint32
const char * c_str() const
Definition: ossimString.h:396
◆ find()
ossimString ossimFgdcFileWriter::find ( const ossimString xpath) const
Definition at line 923 of file ossimFgdcFileWriter.cpp.
References ossimXmlDocument::findNodes(), ossimErrorStatusInterface::getErrorStatus(), and theTemplate.
Referenced by writeFile().
924 {
925  ossimString result;
926
928  {
929  return result;
930  }
931
932  vector< ossimRefPtr<ossimXmlNode> > xml_nodes;
933  theTemplate.findNodes(xpath, xml_nodes);
934
935  if (xml_nodes.size())
936  {
937  if (xml_nodes[0].valid())
938  {
939  result = xml_nodes[0]->getText();
940  }
941  }
942  return result;
943 }
virtual ossimErrorCode getErrorStatus() const
void findNodes(const ossimString &xpath, std::vector< ossimRefPtr< ossimXmlNode > > &nodelist) const
Appends any matching nodes to the list supplied (should be empty):
◆ getIndentionLevel()
ossim_uint32 ossimFgdcFileWriter::getIndentionLevel ( ) const
Returns
Returns the current indentation level.
Definition at line 851 of file ossimFgdcFileWriter.cpp.
References theIndentionLevel.
852 {
853  return theIndentionLevel;
854 }
◆ getMetadatatypeList()
void ossimFgdcFileWriter::getMetadatatypeList ( std::vector< ossimString > &  metadatatypeList) const
virtual
Appends the writers image types to the "metadatatypeList".
Parameters
metadatatypeListstl::vector<ossimString> list to append to.
Note
Appends to the list, does not clear it first.
Implements ossimMetadataFileWriter.
Definition at line 945 of file ossimFgdcFileWriter.cpp.
947 {
948  metadatatypeList.push_back(ossimString("ossim_fgdc"));
949 }
◆ getTabString()
ossimString ossimFgdcFileWriter::getTabString ( ) const
Returns
The current tab string e.g.: "\t".
Definition at line 861 of file ossimFgdcFileWriter.cpp.
References theTabString.
862 {
863  return theTabString;
864 }
◆ hasMetadataType()
bool ossimFgdcFileWriter::hasMetadataType ( const ossimString metadataType) const
virtual
Parameters
imageTypestring representing image type.
Returns
true if "metadataType" is supported by writer.
Definition at line 951 of file ossimFgdcFileWriter.cpp.
953 {
954  return (metadataType == "ossim_fgdc");
955 }
◆ loadState()
bool ossimFgdcFileWriter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Parameters
kwlKeyword list to load state from.
prefixPrefix to attatch to keyword (like "object1."). default=NULL
Returns
true if ok or false on error.
Keywords picked up by this loadState:
source_image_filename: foo.ntf tab_string: "\t" fgdc_template_doc: fgdc_template.xml
Reimplemented from ossimMetadataFileWriter.
Definition at line 824 of file ossimFgdcFileWriter.cpp.
References ossimKeywordlist::find(), ossimMetadataFileWriter::loadState(), setTemplate(), theSourceImageFilename, and theTabString.
826 {
827  const char* lookup = kwl.find(prefix, "template");
828  if (lookup)
829  {
830  setTemplate(ossimFilename(lookup));
831  }
832  lookup = kwl.find(prefix, "source_image_filename");
833  if (lookup)
834  {
835  theSourceImageFilename = lookup;
836  }
837  lookup = kwl.find(prefix, "tab_string");
838  if (lookup)
839  {
840  theTabString = lookup;
841  }
842  lookup = kwl.find(prefix, "fgdc_template_doc");
843  if (lookup)
844  {
845  setTemplate(ossimFilename(lookup));
846  }
847
848  return ossimMetadataFileWriter::loadState(kwl, prefix);
849 }
void setTemplate(const ossimFilename &xmlTemplateFile)
Load state method:
◆ openTag()
void ossimFgdcFileWriter::openTag ( std::ostream &  os,
bool  newLine
) const
private
Increments indentation level.
Parameters
tagString representing tag with no brackets, i.e. "metadata".
newLineIf true a new line "\n" is added.
Definition at line 871 of file ossimFgdcFileWriter.cpp.
874 {
876  {
877  ossimString tab;
878  for (ossim_uint32 i = 0; i < theIndentionLevel; ++i)
879  {
880  tab += theTabString;
881  }
882
883  os << tab.c_str();
884  }
885
886  os << "<" << tag.c_str() << ">";
887
888  if (newLine)
889  {
890  os << "\n";
892  }
893 }
◆ setIndentionLevel()
void ossimFgdcFileWriter::setIndentionLevel ( ossim_uint32  level)
Parameters
levelIndentation level. "0" equals no indentation.
Definition at line 856 of file ossimFgdcFileWriter.cpp.
857 {
858  theIndentionLevel = level;
859 }
◆ setTabString()
void ossimFgdcFileWriter::setTabString ( const ossimString tabString)
Usually "\t" or spaces " ".
Parameters
tabStringString to use for indentation.
Definition at line 866 of file ossimFgdcFileWriter.cpp.
867 {
868  theTabString = tabString;
869 }
◆ setTemplate()
void ossimFgdcFileWriter::setTemplate ( const ossimFilename xmlTemplateFile)
Definition at line 918 of file ossimFgdcFileWriter.cpp.
References ossimXmlDocument::openFile(), and theTemplate.
Referenced by loadState().
919 {
920  theTemplate.openFile(xmlTemplateFile);
921 }
bool openFile(const ossimFilename &filename)
◆ setTitle()
void ossimFgdcFileWriter::setTitle ( const ossimString pubDate)
Parameters
titleTile of data usually the image file name.
◆ writeFile()
bool ossimFgdcFileWriter::writeFile ( )
protectedvirtual
Returns
true on success, false on failure.
Definition at line 48 of file ossimFgdcFileWriter.cpp.
References ossimString::c_str(), closeTag(), find(), ossimImageSource::getBoundingRect(), ossimImageSource::getImageGeometry(), ossimImageGeometry::getProjection(), ossimMapProjection::isGeographic(), ossimFilename::NIL, openTag(), ossimNotify(), ossimNotifyLevel_WARN, PTR_CAST, ossimMetadataFileWriter::theFilename, ossimMetadataFileWriter::theInputConnection, theSourceImageFilename, ossimString::toString(), and ossimRefPtr< T >::valid().
49 {
51  {
53  << "ossimFgdcFileWriter::writeFile no filename set!" << endl;
54  return false;
55  }
56
57  if( !theInputConnection )
58  {
60  << "ossimFgdcFileWriter::writeFile no input connection!" << endl;
61  return false;
62  }
63
65  if (!os)
66  {
68  << "ossimFgdcFileWriter::writeFile no input connection!" << endl;
69  return false;
70  }
71
72  // Get the geometry from the input.
73  ossimMapProjection* mapProj = 0;
75  if ( inputGeom.valid() ) mapProj = PTR_CAST(ossimMapProjection, inputGeom->getProjection());
76  if (!mapProj)
77  {
79  << "ossimFgdcFileWriter::writeFile Not map projected."
80  << endl;
81  return false;
82  }
83
85
86  os << "<?xml version=\"1.0\" encoding=\"ISO-8859-1\" ?>\n"
87  << "<?xml-stylesheet type=\"text/xsl\" href=\"/common/fgdc_classic.xsl\" ?>\n";
88  openTag(os, ossimString("metadata"), true);
89  openTag(os, ossimString("idinfo"), true);
90  openTag(os, ossimString("citation"), true);
91  openTag(os, ossimString("citeinfo"), true);
92
93  openTag(os, ossimString("origin"), false);
94  os << find(ossimString("/metadata/idinfo/citation/citeinfo/origin"));
95  closeTag(os, ossimString("origin"), false);
96
97  openTag(os, ossimString("pubdate"), false);
98  os << find(ossimString("/metadata/idinfo/citation/citeinfo/pubdate"));
99  closeTag(os, ossimString("pubdate"), false);
100
101  openTag(os, ossimString("title"), false);
102  // os << find(ossimString("/metadata/idinfo/citation/citeinfo/title"));
104  closeTag(os, ossimString("title"), false);
105
106  openTag(os, ossimString("edition"), false);
107  os << find(ossimString("/metadata/idinfo/citation/citeinfo/edition"));
108  closeTag(os, ossimString("edition"), false);
109
110  openTag(os, ossimString("geoform"), false);
111  os << find(ossimString("/metadata/idinfo/citation/citeinfo/geoform"));
112  closeTag(os, ossimString("geoform"), false);
113
114  openTag(os, ossimString("serinfo"), true);
115  openTag(os, ossimString("sername"), false);
116  os << find(ossimString("/metadata/idinfo/citation/citeinfo/serinfo/sername"));
117  closeTag(os, ossimString("sername"), false);
118
119  openTag(os, ossimString("issue"), false);
121  closeTag(os, ossimString("issue"), false);
122
123  closeTag(os, ossimString("serinfo"), true);
124
125  openTag(os, ossimString("pubinfo"), true);
126
127  openTag(os, ossimString("pubplace"), false);
128  os << find(ossimString("/metadata/idinfo/citation/citeinfo/pubinfo/pubplace"));
129  closeTag(os, ossimString("pubplace"), false);
130
131  openTag(os, ossimString("publish"), false);
132  os << find(ossimString("/metadata/idinfo/citation/citeinfo/pubinfo/publish"));
133  closeTag(os, ossimString("publish"), false);
134
135  closeTag(os, ossimString("pubinfo"), true);
136  closeTag(os, ossimString("citeinfo"), true);
137  closeTag(os, ossimString("citation"), true);
138
139  openTag(os, ossimString("descript"), true);
140
141  openTag(os, ossimString("abstract"), false);
142  os << find(ossimString("/metadata/idinfo/descript/abstract"));
143  closeTag(os, ossimString("abstract"), false);
144
145  openTag(os, ossimString("purpose"), false);
146  os << find(ossimString("/metadata/idinfo/descript/purpose"));
147  closeTag(os, ossimString("purpose"), false);
148
149  openTag(os, ossimString("supplinf"), false);
150  os << find(ossimString("/metadata/idinfo/descript/supplinf"));
151  closeTag(os, ossimString("supplinf"), false);
152
153  closeTag(os, ossimString("descript"), true);
154
155  openTag(os, ossimString("timeperd"), true);
156  openTag(os, ossimString("timeinfo"), true);
157  openTag(os, ossimString("sngdate"), true);
158
159  openTag(os, ossimString("caldate"), false);
160  os << find(ossimString("/metadata/idinfo/timeperd/timeinfo/sngdate/caldate"));
161  closeTag(os, ossimString("caldate"), false);
162
163  closeTag(os, ossimString("sngdate"), true);
164  closeTag(os, ossimString("timeinfo"), true);
165
166
167  openTag(os, ossimString("current"), false);
168  os << find(ossimString("/metadata/idinfo/timeperd/current"));
169  closeTag(os, ossimString("current"), false);
170
171  closeTag(os, ossimString("timeperd"), true);
172
173  openTag(os, ossimString("status"), true);
174
175  openTag(os, ossimString("progress"), false);
176  os << find(ossimString("/metadata/idinfo/status/progress"));
177  closeTag(os, ossimString("progress"), false);
178
179  openTag(os, ossimString("update"), false);
180  os << find(ossimString("/metadata/idinfo/status/update"));
181  closeTag(os, ossimString("update"), false);
182
183  closeTag(os, ossimString("status"), true);
184
185  openTag(os, ossimString("spdom"), true);
186  openTag(os, ossimString("bounding"), true);
187
188  if (mapProj->isGeographic())
189  {
190  openTag(os, ossimString("westbc"), false);
191  os << ossimString::toString(mpi.ulGroundPt().lon);
192  closeTag(os, ossimString("westbc"), false);
193
194  openTag(os, ossimString("eastbc"), false);
195  os << ossimString::toString(mpi.lrGroundPt().lon);
196  closeTag(os, ossimString("eastbc"), false);
197
198  openTag(os, ossimString("northbc"), false);
199  os << ossimString::toString(mpi.ulGroundPt().lat);
200  closeTag(os, ossimString("northbc"), false);
201
202  openTag(os, ossimString("southbc"), false);
203  os << ossimString::toString(mpi.lrGroundPt().lat);
204  closeTag(os, ossimString("southbc"), false);
205  }
206  else
207  {
208  openTag(os, ossimString("westbc"), false);
209  os << ossimString::toString(mpi.ulEastingNorthingPt().x);
210  closeTag(os, ossimString("westbc"), false);
211
212  openTag(os, ossimString("eastbc"), false);
213  os << ossimString::toString(mpi.lrEastingNorthingPt().x);
214  closeTag(os, ossimString("eastbc"), false);
215
216  openTag(os, ossimString("northbc"), false);
217  os << ossimString::toString(mpi.ulEastingNorthingPt().y);
218  closeTag(os, ossimString("northbc"), false);
219
220  openTag(os, ossimString("southbc"), false);
221  os << ossimString::toString(mpi.ulEastingNorthingPt().y);
222  closeTag(os, ossimString("southbc"), false);
223  }
224
225  closeTag(os, ossimString("bounding"), true);
226  closeTag(os, ossimString("spdom"), true);
227
228  openTag(os, ossimString("keywords"), true);
229
230  openTag(os, ossimString("theme"), true);
231
232  openTag(os, ossimString("themekt"), false);
233  os << find(ossimString("/metadata/idinfo/keywords/theme/themekt"));
234  closeTag(os, ossimString("themekt"), false);
235
236  openTag(os, ossimString("themekey"), false);
237  os << find(ossimString("/metadata/idinfo/keywords/theme/themekey"));
238  closeTag(os, ossimString("themekey"), false);
239
240  closeTag(os, ossimString("theme"), true);
241
242  closeTag(os, ossimString("keywords"), true);
243
244  openTag(os, ossimString("accconst"), false);
245  os << find(ossimString("/metadata/idinfo/accconst"));
246  closeTag(os, ossimString("accconst"), false);
247
248  openTag(os, ossimString("useconst"), false);
249  os << find(ossimString("/metadata/idinfo/useconst"));
250  closeTag(os, ossimString("useconst"), false);
251
252  openTag(os, ossimString("ptcontac"), true);
253
254  openTag(os, ossimString("cntinfo"), true);
255
256  openTag(os, ossimString("cntperp"), true);
257  openTag(os, ossimString("cntper"), false);
258  os << find(ossimString("/metadata/idinfo/ptcontac/cntinfo/cntperp/cntper"));
259  closeTag(os, ossimString("cntper"), false);
260  closeTag(os, ossimString("cntperp"), true);
261
262  openTag(os, ossimString("cntaddr"), true);
263
264  openTag(os, ossimString("addrtype"), false);
265  os << find(ossimString("/metadata/idinfo/ptcontac/cntinfo/cntaddr/addrtype"));
266  closeTag(os, ossimString("addrtype"), false);
267
268  openTag(os, ossimString("address"), false);
269  os << find(ossimString("/metadata/idinfo/ptcontac/cntinfo/cntaddr/address"));
270  closeTag(os, ossimString("address"), false);
271
272  openTag(os, ossimString("city"), false);
273  os << find(ossimString("/metadata/idinfo/ptcontac/cntinfo/cntaddr/city"));
274  closeTag(os, ossimString("city"), false);
275
276  openTag(os, ossimString("state"), false);
277  os << find(ossimString("/metadata/idinfo/ptcontac/cntinfo/cntaddr/state"));
278  closeTag(os, ossimString("state"), false);
279
280  openTag(os, ossimString("postal"), false);
281  os << find(ossimString("/metadata/idinfo/ptcontac/cntinfo/cntaddr/postal"));
282  closeTag(os, ossimString("postal"), false);
283
284  openTag(os, ossimString("country"), false);
285  os << find(ossimString("/metadata/idinfo/ptcontac/cntinfo/cntaddr/country"));
286  closeTag(os, ossimString("country"), false);
287
288  closeTag(os, ossimString("cntaddr"), true);
289
290  openTag(os, ossimString("cntvoice"), false);
291  os << find(ossimString("/metadata/idinfo/ptcontac/cntinfo/cntvoice"));
292  closeTag(os, ossimString("cntvoice"), false);
293
294  openTag(os, ossimString("cntfax"), false);
295
296  os << find(ossimString("/metadata/idinfo/ptcontac/cntinfo/cntfax"));
297  closeTag(os, ossimString("cntfax"), false);
298
299  openTag(os, ossimString("cntemail"), false);
300  os << find(ossimString("/metadata/idinfo/ptcontac/cntinfo/cntemail"));
301  closeTag(os, ossimString("cntemail"), false);
302
303  closeTag(os, ossimString("cntinfo"), true);
304  closeTag(os, ossimString("ptcontac"), true);
305
306  openTag(os, ossimString("secinfo"), true);
307
308  openTag(os, ossimString("secclass"), false);
309  os << find(ossimString("/metadata/idinfo/secinfo/secclass"));
310  closeTag(os, ossimString("secclass"), false);
311
312  openTag(os, ossimString("secsys"), false);
313  os << find(ossimString("/metadata/idinfo/secinfo/secsys"));
314  closeTag(os, ossimString("secsys"), false);
315
316  openTag(os, ossimString("sechandl"), false);
317  os << find(ossimString("/metadata/idinfo/secinfo/sechandl"));
318  closeTag(os, ossimString("sechandl"), false);
319
320  closeTag(os, ossimString("secinfo"), true);
321  closeTag(os, ossimString("idinfo"), true);
322
323  openTag(os, ossimString("distinfo"), true);
324  openTag(os, ossimString("distrib"), true);
325  openTag(os, ossimString("cntinfo"), true);
326  openTag(os, ossimString("cntperp"), true);
327  openTag(os, ossimString("cntper"), false);
328  os << find(ossimString("/metadata/distinfo/distrib/cntinfo/cntperp/cntper"));
329
330  closeTag(os, ossimString("cntper"), false);
331  closeTag(os, ossimString("cntperp"), true);
332
333  openTag(os, ossimString("cntaddr"), true);
334
335  openTag(os, ossimString("addrtype"), false);
336  os << find(ossimString("/metadata/distinfo/distrib/cntinfo/cntaddr/addrtype"));
337  closeTag(os, ossimString("addrtype"), false);
338
339  openTag(os, ossimString("address"), false);
340  os << find(ossimString("/metadata/distinfo/distrib/cntinfo/cntaddr/address"));
341  closeTag(os, ossimString("address"), false);
342
343  openTag(os, ossimString("city"), false);
344  os << find(ossimString("/metadata/distinfo/distrib/cntinfo/cntaddr/city"));
345  closeTag(os, ossimString("city"), false);
346
347  openTag(os, ossimString("state"), false);
348  os << find(ossimString("/metadata/distinfo/distrib/cntinfo/cntaddr/state"));
349  closeTag(os, ossimString("state"), false);
350
351  openTag(os, ossimString("postal"), false);
352  os << find(ossimString("/metadata/distinfo/distrib/cntinfo/cntaddr/postal"));
353  closeTag(os, ossimString("postal"), false);
354
355  openTag(os, ossimString("country"), false);
356  os << find(ossimString("/metadata/distinfo/distrib/cntinfo/cntaddr/country"));
357  closeTag(os, ossimString("country"), false);
358
359  closeTag(os, ossimString("cntaddr"), true);
360
361  openTag(os, ossimString("cntvoice"), false);
362  os << find(ossimString("/metadata/distinfo/distrib/cntinfo/cntvoice"));
363  closeTag(os, ossimString("cntvoice"), false);
364
365  openTag(os, ossimString("cntfax"), false);
366  os << find(ossimString("/metadata/distinfo/distrib/cntinfo/cntfax"));
367  closeTag(os, ossimString("cntfax"), false);
368
369  openTag(os, ossimString("cntemail"), false);
370  os << find(ossimString("/metadata/distinfo/distrib/cntinfo/cntemail"));
371  closeTag(os, ossimString("cntemail"), false);
372
373  closeTag(os, ossimString("cntinfo"), true);
374  closeTag(os, ossimString("distrib"), true);
375
376  openTag(os, ossimString("resdesc"), false);
377  os << find(ossimString("/metadata/distinfo/resdesc"));
378  closeTag(os, ossimString("resdesc"), false);
379
380  openTag(os, ossimString("distliab"), false);
381  os << find(ossimString("/metadata/distinfo/distliab"));
382  closeTag(os, ossimString("distliab"), false);
383
384  openTag(os, ossimString("stdorder"), true);
385  openTag(os, ossimString("digform"), true);
386  openTag(os, ossimString("digtinfo"), true);
387
388  openTag(os, ossimString("formname"), false);
389  os << find(ossimString("/metadata/distinfo/stdorder/digform/digtinfo/formname"));
390  closeTag(os, ossimString("formname"), false);
391
392  closeTag(os, ossimString("digtinfo"), true);
393
394  openTag(os, ossimString("digtopt"), true);
395  openTag(os, ossimString("onlinopt"), true);
396  openTag(os, ossimString("computer"), true);
397  openTag(os, ossimString("networka"), true);
398
399  openTag(os, ossimString("networkr"), false);
400  os << find(ossimString("/metadata/distinfo/stdorder/digform/digtopt/onlinopt/computer/networka/networkr"));
401  closeTag(os, ossimString("networkr"), false);
402
403  closeTag(os, ossimString("networka"), true);
404  closeTag(os, ossimString("computer"), true);
405  closeTag(os, ossimString("onlinopt"), true);
406  closeTag(os, ossimString("digtopt"), true);
407  closeTag(os, ossimString("digform"), true);
408
409  openTag(os, ossimString("fees"), false);
410  os << find(ossimString("/metadata/distinfo/stdorder/fees"));
411  closeTag(os, ossimString("fees"), false);
412
413  closeTag(os, ossimString("stdorder"), true);
414  closeTag(os, ossimString("distinfo"), true);
415
416  openTag(os, ossimString("metainfo"), true);
417
418  openTag(os, ossimString("metd"), false);
419  os << find(ossimString("/metadata/metainfo/metd"));
420  closeTag(os, ossimString("metd"), false);
421
422  openTag(os, ossimString("metc"), true);
423  openTag(os, ossimString("cntinfo"), true);
424  openTag(os, ossimString("cntperp"), true);
425
426  openTag(os, ossimString("cntper"), false);
427  os << find(ossimString("/metadata/metainfo/metc/cntinfo/cntperp/cntper"));
428  closeTag(os, ossimString("cntper"), false);
429
430  closeTag(os, ossimString("cntperp"), true);
431
432  openTag(os, ossimString("cntaddr"), true);
433
434  openTag(os, ossimString("addrtype"), false);
435  os << find(ossimString("/metadata/metainfo/metc/cntinfo/cntaddr/addrtype"));
436  closeTag(os, ossimString("addrtype"), false);
437
438  openTag(os, ossimString("address"), false);
439  os << find(ossimString("/metadata/metainfo/metc/cntinfo/cntaddr/address"));
440  closeTag(os, ossimString("address"), false);
441
442  openTag(os, ossimString("city"), false);
443  os << find(ossimString("/metadata/metainfo/metc/cntinfo/cntaddr/city"));
444  closeTag(os, ossimString("city"), false);
445
446  openTag(os, ossimString("state"), false);
447  os << find(ossimString("/metadata/metainfo/metc/cntinfo/cntaddr/state"));
448  closeTag(os, ossimString("state"), false);
449
450  openTag(os, ossimString("postal"), false);
451  os << find(ossimString("/metadata/metainfo/metc/cntinfo/cntaddr/postal"));
452  closeTag(os, ossimString("postal"), false);
453
454  openTag(os, ossimString("country"), false);
455  os << find(ossimString("/metadata/metainfo/metc/cntinfo/cntaddr/country"));
456  closeTag(os, ossimString("country"), false);
457
458  closeTag(os, ossimString("cntaddr"), true);
459
460  openTag(os, ossimString("cntvoice"), false);
461  os << find(ossimString("/metadata/metainfo/metc/cntinfo/cntvoice"));
462  closeTag(os, ossimString("cntvoice"), false);
463
464  openTag(os, ossimString("cntfax"), false);
465  os << find(ossimString("/metadata/metainfo/metc/cntinfo/cntfax"));
466  closeTag(os, ossimString("cntfax"), false);
467
468  openTag(os, ossimString("cntemail"), false);
469  os << find(ossimString("/metadata/metainfo/metc/cntinfo/cntemail"));
470  closeTag(os, ossimString("cntemail"), false);
471
472  closeTag(os, ossimString("cntinfo"), true);
473  closeTag(os, ossimString("metc"), true);
474
475  openTag(os, ossimString("metstdn"), false);
476  os << find(ossimString("/metadata/metainfo/metstdn"));
477  closeTag(os, ossimString("metstdn"), false);
478
479  openTag(os, ossimString("metstdv"), false);
480  os << find(ossimString("/metadata/metainfo/metstdv"));
481  closeTag(os, ossimString("metstdv"), false);
482
483  closeTag(os, ossimString("metainfo"), true);
484  closeTag(os, ossimString("metadata"), true);
485
486  os.close();
487
488  return true;
489 }
This will return the bounding rect of the source.
static const ossimFilename NIL
This was taken from Wx widgets for performing touch and access date stamps.
Definition: ossimFilename.h:40
ossimString find(const ossimString &xpath) const
bool valid() const
Definition: ossimRefPtr.h:75
Numeric to string methods.
virtual bool isGeographic() const
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
void closeTag(std::ostream &os, const ossimString &tag, bool decrementLevel) const
void openTag(std::ostream &os, const ossimString &tag, bool newLine) const
std::basic_ofstream< char > ofstream
Class for char output file streams.
Definition: ossimIosFwd.h:47
◆ writeTemplate()
bool ossimFgdcFileWriter::writeTemplate ( const ossimFilename file) const
Definition at line 491 of file ossimFgdcFileWriter.cpp.
References ossimString::c_str(), closeTag(), openTag(), ossimNotify(), and ossimNotifyLevel_WARN.
492 {
493  ofstream os(file.c_str());
494  if (!os)
495  {
497  << "ossimFgdcFileWriter::writeTemplate Could not open: " << file
498  << endl;
499  return false;
500  }
501
502  os << "<?xml version=\"1.0\" encoding=\"ISO-8859-1\" ?>\n"
503  << "<?xml-stylesheet type=\"text/xsl\" href=\"/common/fgdc_classic.xsl\" ?>\n";
504  openTag(os, ossimString("metadata"), true);
505  openTag(os, ossimString("idinfo"), true);
506  openTag(os, ossimString("citation"), true);
507  openTag(os, ossimString("citeinfo"), true);
508
509  openTag(os, ossimString("origin"), false);
510  closeTag(os, ossimString("origin"), false);
511
512  openTag(os, ossimString("pubdate"), false);
513  closeTag(os, ossimString("pubdate"), false);
514
515  openTag(os, ossimString("title"), false);
516  closeTag(os, ossimString("title"), false);
517
518  openTag(os, ossimString("edition"), false);
519  closeTag(os, ossimString("edition"), false);
520
521  openTag(os, ossimString("geoform"), false);
522  closeTag(os, ossimString("geoform"), false);
523
524  openTag(os, ossimString("serinfo"), true);
525  openTag(os, ossimString("sername"), false);
526
527  closeTag(os, ossimString("sername"), false);
528
529  openTag(os, ossimString("issue"), false);
530  closeTag(os, ossimString("issue"), false);
531
532  closeTag(os, ossimString("serinfo"), true);
533
534  openTag(os, ossimString("pubinfo"), true);
535
536  openTag(os, ossimString("pubplace"), false);
537
538  closeTag(os, ossimString("pubplace"), false);
539
540  openTag(os, ossimString("publish"), false);
541  closeTag(os, ossimString("publish"), false);
542
543  closeTag(os, ossimString("pubinfo"), true);
544  closeTag(os, ossimString("citeinfo"), true);
545  closeTag(os, ossimString("citation"), true);
546
547  openTag(os, ossimString("descript"), true);
548
549  openTag(os, ossimString("abstract"), false);
550  closeTag(os, ossimString("abstract"), false);
551
552  openTag(os, ossimString("purpose"), false);
553  closeTag(os, ossimString("purpose"), false);
554
555  openTag(os, ossimString("supplinf"), false);
556  closeTag(os, ossimString("supplinf"), false);
557
558  closeTag(os, ossimString("descript"), true);
559
560  openTag(os, ossimString("timeperd"), true);
561  openTag(os, ossimString("timeinfo"), true);
562  openTag(os, ossimString("sngdate"), true);
563
564  openTag(os, ossimString("caldate"), false);
565  closeTag(os, ossimString("caldate"), false);
566
567  closeTag(os, ossimString("sngdate"), true);
568  closeTag(os, ossimString("timeinfo"), true);
569
570
571  openTag(os, ossimString("current"), false);
572  closeTag(os, ossimString("current"), false);
573
574  closeTag(os, ossimString("timeperd"), true);
575
576  openTag(os, ossimString("status"), true);
577
578  openTag(os, ossimString("progress"), false);
579  closeTag(os, ossimString("progress"), false);
580
581  openTag(os, ossimString("update"), false);
582  closeTag(os, ossimString("update"), false);
583
584  closeTag(os, ossimString("status"), true);
585
586  openTag(os, ossimString("spdom"), true);
587  openTag(os, ossimString("bounding"), true);
588
589  openTag(os, ossimString("westbc"), false);
590  closeTag(os, ossimString("westbc"), false);
591  openTag(os, ossimString("eastbc"), false);
592
593  closeTag(os, ossimString("eastbc"), false);
594  openTag(os, ossimString("northbc"), false);
595
596  closeTag(os, ossimString("northbc"), false);
597  openTag(os, ossimString("southbc"), false);
598
599  closeTag(os, ossimString("southbc"), false);
600
601  closeTag(os, ossimString("bounding"), true);
602  closeTag(os, ossimString("spdom"), true);
603
604  openTag(os, ossimString("keywords"), true);
605
606  openTag(os, ossimString("theme"), true);
607
608  openTag(os, ossimString("themekt"), false);
609  closeTag(os, ossimString("themekt"), false);
610
611  openTag(os, ossimString("themekey"), false);
612  closeTag(os, ossimString("themekey"), false);
613
614  closeTag(os, ossimString("theme"), true);
615
616  closeTag(os, ossimString("keywords"), true);
617
618  openTag(os, ossimString("accconst"), false);
619  closeTag(os, ossimString("accconst"), false);
620
621  openTag(os, ossimString("useconst"), false);
622  closeTag(os, ossimString("useconst"), false);
623
624  openTag(os, ossimString("ptcontac"), true);
625
626  openTag(os, ossimString("cntinfo"), true);
627
628  openTag(os, ossimString("cntperp"), true);
629  openTag(os, ossimString("cntper"), false);
630  closeTag(os, ossimString("cntper"), false);
631  closeTag(os, ossimString("cntperp"), true);
632
633  openTag(os, ossimString("cntaddr"), true);
634
635  openTag(os, ossimString("addrtype"), false);
636  closeTag(os, ossimString("addrtype"), false);
637
638  openTag(os, ossimString("address"), false);
639  closeTag(os, ossimString("address"), false);
640
641  openTag(os, ossimString("city"), false);
642  closeTag(os, ossimString("city"), false);
643
644  openTag(os, ossimString("state"), false);
645  closeTag(os, ossimString("state"), false);
646
647  openTag(os, ossimString("postal"), false);
648  closeTag(os, ossimString("postal"), false);
649
650  openTag(os, ossimString("country"), false);
651  closeTag(os, ossimString("country"), false);
652
653  closeTag(os, ossimString("cntaddr"), true);
654
655  openTag(os, ossimString("cntvoice"), false);
656  closeTag(os, ossimString("cntvoice"), false);
657
658  openTag(os, ossimString("cntfax"), false);
659  closeTag(os, ossimString("cntfax"), false);
660
661  openTag(os, ossimString("cntemail"), false);
662  closeTag(os, ossimString("cntemail"), false);
663
664  closeTag(os, ossimString("cntinfo"), true);
665
666  closeTag(os, ossimString("ptcontac"), true);
667
668  openTag(os, ossimString("secinfo"), true);
669  openTag(os, ossimString("secclass"), false);
670  closeTag(os, ossimString("secclass"), false);
671  openTag(os, ossimString("secsys"), false);
672  closeTag(os, ossimString("secsys"), false);
673  openTag(os, ossimString("sechandl"), false);
674  closeTag(os, ossimString("sechandl"), false);
675  closeTag(os, ossimString("secinfo"), true);
676
677  closeTag(os, ossimString("idinfo"), true);
678
679  openTag(os, ossimString("distinfo"), true);
680  openTag(os, ossimString("distrib"), true);
681  openTag(os, ossimString("cntinfo"), true);
682  openTag(os, ossimString("cntperp"), true);
683  openTag(os, ossimString("cntper"), false);
684  closeTag(os, ossimString("cntper"), false);
685  closeTag(os, ossimString("cntperp"), true);
686
687  openTag(os, ossimString("cntaddr"), true);
688
689  openTag(os, ossimString("addrtype"), false);
690  closeTag(os, ossimString("addrtype"), false);
691
692  openTag(os, ossimString("address"), false);
693  closeTag(os, ossimString("address"), false);
694
695  openTag(os, ossimString("city"), false);
696  closeTag(os, ossimString("city"), false);
697
698  openTag(os, ossimString("state"), false);
699  closeTag(os, ossimString("state"), false);
700
701  openTag(os, ossimString("postal"), false);
702  closeTag(os, ossimString("postal"), false);
703
704  openTag(os, ossimString("country"), false);
705  closeTag(os, ossimString("country"), false);
706
707  closeTag(os, ossimString("cntaddr"), true);
708
709  openTag(os, ossimString("cntvoice"), false);
710  closeTag(os, ossimString("cntvoice"), false);
711
712  openTag(os, ossimString("cntfax"), false);
713  closeTag(os, ossimString("cntfax"), false);
714
715  openTag(os, ossimString("cntemail"), false);
716  closeTag(os, ossimString("cntemail"), false);
717
718  closeTag(os, ossimString("cntinfo"), true);
719  closeTag(os, ossimString("distrib"), true);
720
721  openTag(os, ossimString("resdesc"), false);
722  closeTag(os, ossimString("resdesc"), false);
723
724  openTag(os, ossimString("distliab"), false);
725  closeTag(os, ossimString("distliab"), false);
726
727  openTag(os, ossimString("stdorder"), true);
728  openTag(os, ossimString("digform"), true);
729  openTag(os, ossimString("digtinfo"), true);
730
731  openTag(os, ossimString("formname"), false);
732  closeTag(os, ossimString("formname"), false);
733
734  closeTag(os, ossimString("digtinfo"), true);
735
736  openTag(os, ossimString("digtopt"), true);
737  openTag(os, ossimString("onlinopt"), true);
738  openTag(os, ossimString("computer"), true);
739  openTag(os, ossimString("networka"), true);
740
741  openTag(os, ossimString("networkr"), false);
742  closeTag(os, ossimString("networkr"), false);
743
744  closeTag(os, ossimString("networka"), true);
745  closeTag(os, ossimString("computer"), true);
746  closeTag(os, ossimString("onlinopt"), true);
747  closeTag(os, ossimString("digtopt"), true);
748  closeTag(os, ossimString("digform"), true);
749
750  openTag(os, ossimString("fees"), false);
751  closeTag(os, ossimString("fees"), false);
752
753  closeTag(os, ossimString("stdorder"), true);
754  closeTag(os, ossimString("distinfo"), true);
755
756  openTag(os, ossimString("metainfo"), true);
757
758  openTag(os, ossimString("metd"), false);
759  closeTag(os, ossimString("metd"), false);
760
761  openTag(os, ossimString("metc"), true);
762  openTag(os, ossimString("cntinfo"), true);
763  openTag(os, ossimString("cntperp"), true);
764
765  openTag(os, ossimString("cntper"), false);
766  closeTag(os, ossimString("cntper"), false);
767
768  closeTag(os, ossimString("cntperp"), true);
769
770  openTag(os, ossimString("cntaddr"), true);
771
772  openTag(os, ossimString("addrtype"), false);
773  closeTag(os, ossimString("addrtype"), false);
774
775  openTag(os, ossimString("address"), false);
776  closeTag(os, ossimString("address"), false);
777
778  openTag(os, ossimString("city"), false);
779  closeTag(os, ossimString("city"), false);
780
781  openTag(os, ossimString("state"), false);
782  closeTag(os, ossimString("state"), false);
783
784  openTag(os, ossimString("postal"), false);
785  closeTag(os, ossimString("postal"), false);
786
787  openTag(os, ossimString("country"), false);
788  closeTag(os, ossimString("country"), false);
789
790  closeTag(os, ossimString("cntaddr"), true);
791
792  openTag(os, ossimString("cntvoice"), false);
793  closeTag(os, ossimString("cntvoice"), false);
794
795  openTag(os, ossimString("cntfax"), false);
796  closeTag(os, ossimString("cntfax"), false);
797
798  openTag(os, ossimString("cntemail"), false);
799  closeTag(os, ossimString("cntemail"), false);
800
801  closeTag(os, ossimString("cntinfo"), true);
802  closeTag(os, ossimString("metc"), true);
803
804  openTag(os, ossimString("metstdn"), false);
805  closeTag(os, ossimString("metstdn"), false);
806
807  openTag(os, ossimString("metstdv"), false);
808  closeTag(os, ossimString("metstdv"), false);
809
810  closeTag(os, ossimString("metainfo"), true);
811  closeTag(os, ossimString("metadata"), true);
812
813  os.close();
814
815  if(traceDebug())
816  {
818  << "Wrote file: " << file.c_str() << endl;
819  }
820
821  return true;
822 }
Member Data Documentation
◆ theIndentionLevel
ossim_uint32 ossimFgdcFileWriter::theIndentionLevel
mutableprivate
Definition at line 149 of file ossimFgdcFileWriter.h.
Referenced by closeTag(), getIndentionLevel(), openTag(), and setIndentionLevel().
◆ theSourceImageFilename
ossimFilename ossimFgdcFileWriter::theSourceImageFilename
private
Definition at line 152 of file ossimFgdcFileWriter.h.
Referenced by loadState(), and writeFile().
◆ theTabString
ossimString ossimFgdcFileWriter::theTabString
private
Definition at line 150 of file ossimFgdcFileWriter.h.
Referenced by closeTag(), getTabString(), loadState(), openTag(), and setTabString().
◆ theTemplate
ossimXmlDocument ossimFgdcFileWriter::theTemplate
private
Definition at line 151 of file ossimFgdcFileWriter.h.
Referenced by find(), and setTemplate().
