ossimImageHandlerMtAdaptor.cpp
Go to the documentation of this file.
1 //**************************************************************************************************
2 // OSSIM -- Open Source Software Image Map
3 //
4 // LICENSE: See top level LICENSE.txt file.
5 //
6 // AUTHOR: Oscar Kramer
7 //
10 //
11 //**************************************************************************************************
12 // $Id$
15  // #include <ossim/parallel/ossimMtDebug.h>
16 #include <ossim/base/ossimCommon.h>
17 #include <ossim/base/ossimTimer.h>
18 #include <ossim/base/ossimTrace.h>
19 #include <cstdio>
20 #include <ctime>
21 // #include <sys/time.h>
22
23 RTTI_DEF1(ossimImageHandlerMtAdaptor, "ossimImageHandlerMtAdaptor", ossimImageHandler);
24
25 const char* ossimImageHandlerMtAdaptor::ADAPTEE_ID_KW = "adaptee_id";
26 static ossimTrace traceDebug = ossimTrace("ossimImageHandlerMtAdaptor:debug");
27
28 //**************************************************************************************************
29 // Constructor
30 //**************************************************************************************************
32  : d_getTileT (0),
33  d_cacheTileSize(1024),
34  m_adaptedHandler (0),
35  m_cache (0),
36  d_useCache (false),
37  d_useFauxTile (false)
38 {
39  //###### DEBUG ############
40  // ossimMtDebug* mt_debug = ossimMtDebug::instance();
41  //d_useCache = mt_debug->handlerCacheEnabled;
42  //d_useFauxTile = mt_debug->handlerUseFauxTile;
43  //###### END DEBUG ############
44
45  setUseCache(use_cache);
46  setCacheTileSize(cache_tile_size);
47  setAdaptee(adaptee);
48 }
49
50 //**************************************************************************************************
51 // Destructor
52 //**************************************************************************************************
54 {
55  m_adaptedHandler = 0;
56  m_cache = 0;
57  d_fauxTile = 0;
58 }
59
60 //**************************************************************************************************
62 //**************************************************************************************************
64 {
65  m_adaptedHandler = handler;
66  if (handler == NULL)
67  return;
68
69  // Fetch the adaptee's output list and make it our own:
70  ConnectableObjectList output_list = handler->getOutputList();
71
72  if (d_useCache)
73  {
74  // Create the cache and connect this adaptor as its output:
77  m_cache->connectMyOutputTo(this, true, false);
78  m_cache->changeOwner(this);
79  //m_cache->connectMyOutputTo(this, true, false);
80  handler->disconnectMyOutputs(output_list, true, false);
81  handler->connectMyOutputTo(m_cache.get(), true, true);
82  }
83  else
84  {
85  handler->disconnectMyOutputs(output_list, true, false);
86  handler->connectMyOutputTo(this, true, false);
87  }
88
89  // Finally connect the adaptee's outputs to this and fire connection events:
90  connectMyOutputTo(output_list, true, true);
91  handler->changeOwner(this);
92
93  if (d_useFauxTile)
94  {
95  d_fauxTile = (ossimImageData*) handler->getTile(ossimIpt(0,0), 0)->dup();
96  //d_fauxTile = new ossimImageData(this,
97  // handler->getOutputScalarType(),
98  // handler->getNumberOfOutputBands(),
99  // handler->getTileWidth(),
100  // handler->getTileHeight());
101  //d_fauxTile->fill(128.0);
102  }
103 }
104
105 //**************************************************************************************************
107 //**************************************************************************************************
109  const ossimConnectableObject* obj) const
110 {
111  const ossimImageHandler* h = dynamic_cast<const ossimImageHandler*>(obj);
112  if ((inputIndex == 0) && (h != NULL))
113  return true;
114  return false;
115 }
116
117
118 //**************************************************************************************************
121 //**************************************************************************************************
124 {
125  if (!m_adaptedHandler.valid())
126  return NULL;
127
128  // Establish tile rect to call overloaded getTile(tile_rect):
131  ossimIpt lr (origin.x + w - 1, origin.y + h - 1);
132  ossimIrect tile_rect (origin, lr);
133
134  // Need to unlock to prevent freezing in the called getTile():
135  return getTile(tile_rect, rLevel);
136 }
137
138 //**************************************************************************************************
141 //**************************************************************************************************
144 {
145  if (traceDebug())
146  {
147  std::cout << "TILE: " << tile_rect << std::endl;
148  }
149
150  if (d_useFauxTile)
151  {
153  ftile->setOrigin(tile_rect.ul());
154  return ftile;
155  }
156
157  if (!m_adaptedHandler.valid())
158  return NULL;
159
160  // The sole purpose of the adapter is this mutex lock around the actual handler getTile:
161  //std::lock_guard<std::mutex> lock(m_mutex);
162
164  ossimRefPtr<ossimImageData> temp_tile = 0;
165  double dt = ossimTimer::instance()->time_s();
166
167  //writeTime();
168  if (traceDebug())
169  {
170  std::cout << "WAIT LOCK: " << tile_rect << std::endl;
171  }
172  std::lock_guard<std::mutex> lock(m_mutex);
173
174  if (traceDebug())
175  {
176  std::cout << "START LOCK: " << tile_rect << std::endl;
177  }
178
179  if (d_useCache)
180  temp_tile = m_cache->getTile(tile_rect, rLevel);
181  else
182  temp_tile = m_adaptedHandler->getTile(tile_rect, rLevel);
184
185  // We make our own instance of a tile and copy the adaptee's returned tile to it. This avoids
186  // the product tile from changing while being processed up the chain. The adaptee's tile can
187  // change as soon as the mutex lock is released:
188
189  if (temp_tile.valid())
190  *tile = *(temp_tile.get());
191  else
192  tile = NULL;
193
194  //writeTime();
195  if (traceDebug())
196  {
197  std::cout << "END LOCK: " << tile_rect << std::endl;
198  }
199  if (traceDebug())
200  {
201  std::cout << "END TILE: " << tile_rect << std::endl;
202  }
203
204  return tile;
205 }
206
207 //**************************************************************************************************
210 //**************************************************************************************************
212 {
213  if ((!m_adaptedHandler.valid()) || (tile == NULL))
214  return false;
215
216  // The sole purpose of the adapter is this mutex lock around the actual handler getTile:
217  std::lock_guard<std::mutex> lock(m_mutex);
218
219  // This is effectively a copy of ossimImageSource::getTile(ossimImageData*). It is reimplemented
220  // here to save two additional function calls:
221  tile->ref();
222  bool status = true;
223  ossimIrect tile_rect = tile->getImageRectangle();
224
225  ossimRefPtr<ossimImageData> temp_tile = 0;
226  if (d_useCache)
227  temp_tile = m_cache->getTile(tile_rect, rLevel);
228  else
229  temp_tile = m_adaptedHandler->getTile(tile_rect, rLevel);
230
231  if (temp_tile.valid())
232  *tile = *(temp_tile.get());
233  else
234  status = false;
235  tile->unref();
236
237  return status;
238 }
239
240 //**************************************************************************************************
243 //**************************************************************************************************
244 bool ossimImageHandlerMtAdaptor::saveState(ossimKeywordlist& kwl, const char* prefix)const
245 {
246  if (!m_adaptedHandler.valid())
247  return false;
248
249  // Skip the ossimImageHandler::saveState() since it is not necessary here:
250  ossimImageSource::saveState(kwl, prefix);
251
252  kwl.add(prefix, ADAPTEE_ID_KW, m_adaptedHandler->getId().getId());
253
254  return true;
255 }
256
257 //**************************************************************************************************
260 //**************************************************************************************************
261 bool ossimImageHandlerMtAdaptor::loadState(const ossimKeywordlist& kwl, const char* prefix)
262 {
263  m_adaptedHandler = 0;
264
265  // Skip the ossimImageHandler::loadState() since it is not necessary here:
266  if (!ossimImageSource::loadState(kwl, prefix))
267  return false;
268
269  // The adaptee's ID at least will be in the KWL:
270  ossimString value = kwl.find(prefix, ADAPTEE_ID_KW);
271  if (value.empty())
272  return false;
273
274  return true;
275 }
276
277 //**************************************************************************************************
278 // The following are virtuals in the base class. Implemented here as pass-through to adaptee
279 //**************************************************************************************************
281 {
282  if (m_adaptedHandler.valid())
284  return 0;
285 }
286
288 {
289  if (m_adaptedHandler.valid())
290  return m_adaptedHandler->isOpen();
291  return false;
292 }
293
295 {
296  if (m_adaptedHandler.valid())
297  return m_adaptedHandler->open();
298  return false;
299 }
300
302 {
303  if (m_adaptedHandler.valid())
304  return m_adaptedHandler->getNumberOfLines(resLevel);
305  return 0;
306 }
307
309 {
310  if (m_adaptedHandler.valid())
311  return m_adaptedHandler->getNumberOfSamples(resLevel);
312  return 0;
313 }
314
316 {
317  if (m_adaptedHandler.valid())
319  return 0;
320 }
321
323 {
324  if (m_adaptedHandler.valid())
326  return 0;
327 }
328
330 {
331  if (m_adaptedHandler.valid())
332  return m_adaptedHandler->getLongName();
333  return ossimString();
334 }
335
337 {
338  if (m_adaptedHandler.valid())
339  return m_adaptedHandler->getShortName();
340  return ossimString();
341 }
342
344 {
346  this->disconnectAllOutputs();
347  m_cache = 0;
348  if (m_adaptedHandler.valid())
349  {
352  }
353  d_fauxTile = 0;
354 }
355
357 {
358  if (m_adaptedHandler.valid())
360  return 0;
361 }
362
364 {
365  d_useCache = use_cache;
366 }
367
369 {
370  d_cacheTileSize = cache_tile_size;
371 }
372
374 {
375  if (m_adaptedHandler.valid())
377  return 0;
378 }
379
381 {
382 #if 0 /* not portable (drb) */
383  struct timeval tv;
384  struct timezone tz;
385  struct tm *tm;
386  gettimeofday(&tv, &tz);
387  tm=localtime(&tv.tv_sec);
388  printf("%d:%02d:%02d.%ld ", tm->tm_hour, tm->tm_min,tm->tm_sec,tv.tv_usec);
389 #endif
390  // Sorry no usecs...
391  time_t rawTime = (time_t)ossim::getTime();
392  char buf[9];
393  strftime(buf, 9, "%H:%M:%S", gmtime(&rawTime));
394  cerr << buf << std::endl;
395 }
396
398 {
399  if (m_adaptedHandler.valid())
401  return OSSIM_SCALAR_UNKNOWN;
402 }
403
405 {
406  if (m_adaptedHandler.valid())
407  return m_adaptedHandler->getTileWidth();
408  return 0;
409 }
410
412 {
413  if (m_adaptedHandler.valid())
415  return 0;
416 }
417
419 {
420  if (m_adaptedHandler.valid())
421  return m_adaptedHandler->getMinPixelValue(band);
422  return 0.0;
423 }
424
426 {
427  if (m_adaptedHandler.valid())
428  return m_adaptedHandler->getMaxPixelValue(band);
429  return 0.0;
430 }
431
433 {
434  if (m_adaptedHandler.valid())
435  return m_adaptedHandler->getNullPixelValue(band);
436  return 0.0;
437 }
438
virtual bool open()=0
Pure virtual open.
virtual ossim_uint32 getImageTileWidth() const
ossimRefPtr< ossimImageHandler > m_adaptedHandler
OSSIM_DLL ossim_int64 getTime()
Gets the current time.
virtual void disconnectAllOutputs()
Will disconnect all of the output objects.
virtual bool isOpen() const
Intended mainly to provide a mechanism for mutex-locking access to a shared resource during a getTile...
virtual ossim_uint32 getImageTileHeight() const
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
virtual ~ossimImageHandlerMtAdaptor()
Protected destructor forces using reference pointer for instantiation.
virtual ossim_float64 getNullPixelValue(ossim_uint32 band=0) const
virtual ossimString getLongName() const
const ossimIpt & ul() const
Definition: ossimIrect.h:274
void setAdaptee(ossimImageHandler *handler)
Sets the handler being adapted.
virtual void closeOverview()
If theOverview is initialized it will be deleted and set to NULL.
virtual ossim_float64 getMaxPixelValue(ossim_uint32 band=0) const
virtual bool canConnectMyInputTo(ossim_int32 i, const ossimConnectableObject *obj) const
Only an ossimImageHandler is allowed as input here.
virtual bool open()
Pure virtual open.
ossim_int64 getId() const
Definition: ossimId.h:29
virtual ossimString getShortName() const
Definition: ossimObject.cpp:48
ossimImageHandlerMtAdaptor(ossimImageHandler *adaptee=0, bool use_cache=false, ossim_uint32 cache_tile_size=64)
void ref() const
increment the reference count by one, indicating that this object has another pointer which is refere...
virtual ossimObject * dup() const
virtual ossim_uint32 getNumberOfDecimationLevels() const
This returns the total number of decimation levels.
virtual bool isOpen() const =0
Retuns the min pixel value.
double ossim_float64
std::vector< ossimRefPtr< ossimConnectableObject > > ConnectableObjectList
virtual void changeOwner(ossimObject *owner)
Permits changing the object&#39;s owner.
virtual ossim_float64 getMinPixelValue(ossim_uint32 band=0) const
const ossimId & getId() const
Will allow us to get this object&#39;s id.
static ossimTimer * instance()
Definition: ossimTimer.cpp:19
virtual ossim_uint32 getImageTileHeight() const =0
double time_s() const
Get elapsed time in seconds.
Definition: ossimTimer.h:33
unsigned int ossim_uint32
Cache Tile Source.
void setTileSize(const ossimIpt &size)
Set the tile size.
virtual ossimIrect getImageRectangle() const
Definition: ossimObject.cpp:53
virtual void close()
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const
ossimScalarType
void unref() const
decrement the reference count by one, indicating that a pointer to this object is referencing it...
virtual void setOrigin(const ossimIpt &origin)
return status
const ConnectableObjectList & getOutputList() const
virtual ossim_uint32 getImageTileWidth() const =0
virtual ossim_int32 connectMyOutputTo(ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true)
Will try to connect this objects output to the passed in object.
ossimRefPtr< ossimCacheTileSource > m_cache
This class defines an abstract Handler which all image handlers(loaders) should derive from...
ossim_int32 y
Definition: ossimIpt.h:142
virtual ossim_uint32 getNumberOfInputBands() const
bool empty() const
Definition: ossimString.h:411
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
ossim_int32 x
Definition: ossimIpt.h:141
virtual ossim_uint32 getNumberOfInputBands() const =0
Intercepts the getTile call intended for the adaptee and sets a mutex lock around the adaptee&#39;s getTi...
ossimRefPtr< ossimImageData > d_fauxTile
int ossim_int32
virtual void disconnectMyOutputs(ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true)
void setCacheTileSize(ossim_uint32 cache_tile_size)
virtual bool removeListener(ossimListener *listener)
