Cache Tile Source. More...
#include <ossimCacheTileSource.h>
Public Types | |
typedef std::vector< ossimAppFixedTileCache::ossimAppFixedCacheId > | RLevelCacheList |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
ossimCacheTileSource () | |
Will construct a new Application cache. More... | |
virtual | ~ossimCacheTileSource () |
virtual ossimString | getLongName () const |
virtual ossimString | getShortName () const |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
virtual void | initialize () |
virtual void | flush () |
virtual void | setCachingEnabledFlag (bool value) |
virtual void | setEventProgressFlag (bool value) |
void | getTileSize (ossimIpt &size) const |
void | setTileSize (const ossimIpt &size) |
Set the tile size. More... | |
virtual ossim_uint32 | getTileWidth () const |
Returns the default processing tile width. More... | |
virtual ossim_uint32 | getTileHeight () const |
Returns the default processing tile height. More... | |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
Method to the load (recreate) the state of an object from a keyword list. More... | |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
Method to save the state of an object to a keyword list. More... | |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
ossimImageSourceFilter (ossimObject *owner=NULL) | |
ossimImageSourceFilter (ossimImageSource *inputSource) | |
ossimImageSourceFilter (ossimObject *owner, ossimImageSource *inputSource) | |
virtual void | getOutputBandList (std::vector< ossim_uint32 > &bandList) const |
virtual ossim_uint32 | getNumberOfInputBands () const |
bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
required to be overriden by derived classes More... | |
virtual void | connectInputEvent (ossimConnectionEvent &event) |
virtual void | disconnectInputEvent (ossimConnectionEvent &event) |
virtual void | propertyEvent (ossimPropertyEvent &event) |
virtual void | refreshEvent (ossimRefreshEvent &event) |
ossimImageSource (ossimObject *owner=0) | |
ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimImageSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIpt &origin, ossim_uint32 resLevel=0) |
virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel=0) |
Method to get a tile. More... | |
virtual ossimObject * | getObject () |
For RTTI support. More... | |
virtual const ossimObject * | getObject () const |
virtual void | getDecimationFactor (ossim_uint32 resLevel, ossimDpt &result) const |
Will return the decimation factor for the given resolution level. More... | |
virtual void | getDecimationFactors (std::vector< ossimDpt > &decimations) const |
Will return an array of all decimations for each resolution level. More... | |
virtual ossim_uint32 | getNumberOfDecimationLevels () const |
Will return the number of resolution levels. More... | |
virtual ossim_uint32 | getNumberOfOutputBands () const |
Returns the number of bands in a tile returned from this TileSource. More... | |
virtual ossimScalarType | getOutputScalarType () const |
This will be used to query the output pixel type of the tile source. More... | |
virtual double | getNullPixelValue (ossim_uint32 band=0) const |
Each band has a null pixel associated with it. More... | |
virtual double | getMinPixelValue (ossim_uint32 band=0) const |
Returns the min pixel of the band. More... | |
virtual double | getMaxPixelValue (ossim_uint32 band=0) const |
Returns the max pixel of the band. More... | |
virtual ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
This will return the bounding rect of the source. More... | |
virtual void | getBoundingRect (ossimIrect &rect, ossim_uint32 resLevel=0) const |
Gets the bounding rectangle of the source. More... | |
virtual void | getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
ordering specifies how the vertices should be arranged. More... | |
virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
Returns the image geometry object associated with this tile source or NULL if not defined. More... | |
virtual void | setImageGeometry (const ossimImageGeometry *geom) |
Default implementation sets geometry of the first input to the geometry specified. More... | |
virtual void | saveImageGeometry () const |
Default method to call input's saveImageGeometry. More... | |
virtual void | saveImageGeometry (const ossimFilename &geometry_file) const |
virtual bool | isIndexedData () const |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
ossimConnectableObjectListener () | |
virtual | ~ossimConnectableObjectListener () |
virtual void | processEvent (ossimEvent &event) |
ProcessEvent. More... | |
virtual void | objectDestructingEvent (ossimObjectDestructingEvent &) |
virtual void | connectionEvent (ossimConnectionEvent &) |
virtual void | disconnectOutputEvent (ossimConnectionEvent &) |
virtual void | connectOutputEvent (ossimConnectionEvent &) |
virtual void | addObjectEvent (ossimContainerEvent &) |
virtual void | removeObjectEvent (ossimContainerEvent &) |
virtual void | containerEvent (ossimContainerEvent &) |
ossimListener () | |
virtual | ~ossimListener () |
void | enableListener () |
void | disableListener () |
void | setListenerEnableFlag (bool flag) |
bool | isListenerEnabled () const |
bool | getListenerEnableFlag () const |
Cache Tile Source.
Definition at line 19 of file ossimCacheTileSource.h.
typedef std::vector<ossimAppFixedTileCache::ossimAppFixedCacheId> ossimCacheTileSource::RLevelCacheList |
Definition at line 22 of file ossimCacheTileSource.h.
ossimCacheTileSource::ossimCacheTileSource | ( | ) |
Definition at line 30 of file ossimCacheTileSource.cpp.
References ossim::defaultTileSize(), theFixedTileSize, and theTileSizeXY.
Definition at line 44 of file ossimCacheTileSource.cpp.
References deleteRlevelCache().
protected |
Definition at line 71 of file ossimCacheTileSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimImageSourceFilter::theInputConnection, and theTile.
protected |
Definition at line 646 of file ossimCacheTileSource.cpp.
References ossimAppFixedTileCache::deleteCache(), ossimAppFixedTileCache::instance(), and theRLevelCacheList.
Referenced by initializeRlevelCache(), loadState(), and ~ossimCacheTileSource().
protectedvirtual |
Definition at line 264 of file ossimCacheTileSource.cpp.
References ossimAppFixedTileCache::addTile(), ossimIrect::clipToRect(), fireProgressEvent(), ossimRefPtr< T >::get(), ossimImageSource::getBoundingRect(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageSource::getTile(), ossimAppFixedTileCache::getTile(), ossimAppFixedTileCache::getTileSize(), ossimIrect::hasNans(), ossimIrect::height(), ossimAppFixedTileCache::instance(), ossimImageData::loadTile(), ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_NULL, ossimDataObject::setDataObjectStatus(), ossimImageData::setImageRectangle(), ossimIrect::stretchToTileBoundary(), theCachingEnabled, theFixedTileSize, ossimImageSourceFilter::theInputConnection, theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
protectedvirtual |
Definition at line 595 of file ossimCacheTileSource.cpp.
References ossimListenerManager::fireEvent(), and theEventProgressFlag.
Referenced by fillTile().
Definition at line 53 of file ossimCacheTileSource.cpp.
References ossimAppFixedTileCache::flush(), ossimAppFixedTileCache::instance(), and theRLevelCacheList.
Referenced by initialize(), and setCachingEnabledFlag().
protected |
Definition at line 604 of file ossimCacheTileSource.cpp.
References ossimImageSource::getBoundingRect(), ossimImageSource::getTileHeight(), ossimImageSource::getTileWidth(), ossimIrect::height(), initializeRlevelCache(), ossimAppFixedTileCache::instance(), ossim::max(), ossim::min(), ossimAppFixedTileCache::newTileCache(), ossimIrect::stretchToTileBoundary(), theFixedTileSize, ossimImageSourceFilter::theInputConnection, theRLevelCacheList, theTileSizeXY, theUseInputTileSizeFlag, ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Definition at line 555 of file ossimCacheTileSource.cpp.
Definition at line 474 of file ossimCacheTileSource.cpp.
Definition at line 545 of file ossimCacheTileSource.cpp.
Definition at line 560 of file ossimCacheTileSource.cpp.
Definition at line 81 of file ossimCacheTileSource.cpp.
Referenced by ossimImageHandlerMtAdaptor::getTile().
Definition at line 415 of file ossimCacheTileSource.cpp.
References theFixedTileSize, and ossimIpt::y.
void ossimCacheTileSource::getTileSize | ( | ossimIpt & | size | ) | const |
Definition at line 579 of file ossimCacheTileSource.cpp.
References size, and theFixedTileSize.
Definition at line 410 of file ossimCacheTileSource.cpp.
References theFixedTileSize, and ossimIpt::x.
Definition at line 64 of file ossimCacheTileSource.cpp.
References flush(), ossimImageSourceFilter::initialize(), and theTile.
protected |
Definition at line 656 of file ossimCacheTileSource.cpp.
References deleteRlevelCache(), ossimImageSource::getNumberOfDecimationLevels(), and theRLevelCacheList.
Referenced by getCacheId(), and setTileSize().
Definition at line 420 of file ossimCacheTileSource.cpp.
References deleteRlevelCache(), ossimKeywordNames::ENABLE_CACHE_KW, ossimKeywordlist::find(), theCachingEnabled, and ossimString::toBool().
Definition at line 455 of file ossimCacheTileSource.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::ENABLE_CACHE_KW, and theCachingEnabled.
Definition at line 574 of file ossimCacheTileSource.cpp.
References theEventProgressFlag.
Definition at line 503 of file ossimCacheTileSource.cpp.
void ossimCacheTileSource::setTileSize | ( | const ossimIpt & | size | ) |
Set the tile size.
This changes underlying cache tile size.
Size | of cache tile. |
Definition at line 584 of file ossimCacheTileSource.cpp.
References initializeRlevelCache(), size, theFixedTileSize, and theTile.
Referenced by ossimSingleImageChain::createRenderedChain(), and ossimImageHandlerMtAdaptor::setAdaptee().
protected |
Definition at line 80 of file ossimCacheTileSource.h.
Referenced by fillTile(), loadState(), saveState(), and setCachingEnabledFlag().
protected |
Definition at line 81 of file ossimCacheTileSource.h.
Referenced by fireProgressEvent(), and setEventProgressFlag().
protected |
Definition at line 79 of file ossimCacheTileSource.h.
Referenced by fillTile(), getCacheId(), getTileHeight(), getTileSize(), getTileWidth(), ossimCacheTileSource(), and setTileSize().
protected |
Definition at line 83 of file ossimCacheTileSource.h.
Referenced by deleteRlevelCache(), flush(), getCacheId(), and initializeRlevelCache().
protected |
Definition at line 78 of file ossimCacheTileSource.h.
Referenced by allocate(), fillTile(), initialize(), and setTileSize().
protected |
Definition at line 84 of file ossimCacheTileSource.h.
Referenced by getCacheId(), and ossimCacheTileSource().
protected |
Definition at line 82 of file ossimCacheTileSource.h.
Referenced by getCacheId().
