ossimRadarSat2TiffReader.cpp
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // License: See top level LICENSE.txt file
4 //
5 // Author: John Stastny
6 //
7 // Description: Image handelr for RadarSAT-2 data that is TIFF based.
8 //
9 //----------------------------------------------------------------------------
10 // $Id$
11
12 #include <cstdlib>
13
16 #include <ossimRadarSat2Model.h>
21 #include <ossim/base/ossimTrace.h>
22 #include <ossim/base/ossimNotify.h>
27
28 // Keyword constants:
29 static const char PRODUCT_XML_FILE_KW[] = "product_xml_filename";
30
31 namespace ossimplugins
32 {
33 RTTI_DEF1(ossimRadarSat2TiffReader,
34  "ossimRadarSat2TiffReader",
36 }
37
38 #ifdef OSSIM_ID_ENABLED
39  static const char OSSIM_ID[] = "$Id$";
40 #endif
41
42 static ossimTrace traceDebug("ossimRadarSat2TiffReader:degug");
43
45  :
47 {
48  if (traceDebug())
49  {
51  << "ossimplugins::ossimRadarSat2TiffReader::ossimRadarSat2TiffReader entered...\n";
52 #ifdef OSSIM_ID_ENABLED
54  << "OSSIM_ID: " << OSSIM_ID << std::endl;
55 #endif
56  }
57 }
58
60 {
61 }
62
64  ossimKeywordlist& kwl, const char* prefix) const
65 {
66  static const char MODULE[] = "ossimplugins::ossimRadarSat2TiffReader::saveState";
67
68  if (traceDebug())
69  {
71  << MODULE << " entered...\n";
72  }
73
74  // Save our state:
75  kwl.add(prefix, PRODUCT_XML_FILE_KW, theProductXmlFile.c_str());
76
77  // Save the base:
78  return ossimTiffTileSource::saveState(kwl, prefix);
79 }
80
82  const ossimKeywordlist& kwl, const char* prefix)
83 {
84  static const char MODULE[] = "ossimplugins::ossimRadarSat2TiffReader::loadState";
85
86  if (traceDebug())
87  {
89  << MODULE << " entered...\n";
90  }
91
92  bool result = false;
93
94  // Get the product.xml file name.
95  const char* lookup = kwl.find(prefix, PRODUCT_XML_FILE_KW);
96  if (lookup)
97  {
98  theProductXmlFile = lookup;
99  if ( isRadarSat2ProductFile(theProductXmlFile) )
100  {
101  //---
102  // Although we can open any tiff here we only do if we have matching
103  // RS2 product.xml.
104  //---
105  result = ossimTiffTileSource::loadState(kwl, prefix);
106  }
107  }
108
109  if (!result)
110  {
111  theProductXmlFile.clear();
112  }
113
114  if (traceDebug())
115  {
117  << MODULE << " exit status = " << (result?"true":"false\n")
118  << std::endl;
119  }
120
121  return result;
122 }
123
125 {
126  return ossimString("ossim_radarsat2_tiff_reader");
127 }
128
130 {
131  return ossimString("ossim RadarSAT-2 tiff reader");
132 }
133
135 {
136  static const char MODULE[] = "ossimplugins::ossimRadarSat2TiffReader::open";
137
138  if (traceDebug())
139  {
141  << MODULE << " entered...\n"
142  << "file: " << file << "\n";
143  }
144
145  bool result = false;
146
147  if ( isOpen() )
148  {
149  close();
150  }
151
152  // Check extension to see if it's xml.
153  if ( file.ext().downcase() == "xml" )
154  {
155  ossimXmlDocument* xdoc = new ossimXmlDocument();
156  if ( xdoc->openFile(file) )
157  {
158  // See if it's a TerraSAR-X product xml file.
159  if ( isRadarSat2ProductFile(xdoc) )
160  {
161  ossimString s;
163
164  if ( helper.getImageFile(xdoc, s) )
165  {
166  ossimFilename imageFile = file.expand().path();
167  imageFile = imageFile.dirCat(s);
168
169  setFilename(imageFile);
170
171  result = ossimTiffTileSource::open();
172  if (result)
173  {
174  theProductXmlFile = file;
175  completeOpen();
176  }
177  }
178  }
179  }
180  delete xdoc;
181  xdoc = 0;
182
183  } // matches: if ( file.ext().downcase() == "xml" )
184
185  if (traceDebug())
186  {
188  << MODULE << " exit status = " << (result?"true":"false\n")
189  << std::endl;
190  }
191
192  return result;
193 }
194
196 {
197  theProductXmlFile.clear();
199 }
200
202 {
203  if ( !theGeometry )
204  {
205  //---
206  // Check for external geom:
207  //---
208  theGeometry = getExternalImageGeometry();
209
210  if ( !theGeometry )
211  {
212  // Check the internal geometry first to avoid a factory call.
213  theGeometry = getInternalImageGeometry();
214
215  // At this point it is assured theGeometry is set.
216
217  //---
218  // WARNING:
219  // Must create/set theGeometry at this point or the next call to
220  // ossimImageGeometryRegistry::extendGeometry will put us in an infinite loop
221  // as it does a recursive call back to ossimImageHandler::getImageGeometry().
222  //---
223
224  // Check for set projection.
225  if ( !theGeometry->getProjection() )
226  {
227  // Try factories for projection.
229  }
230  }
231
232  // Set image things the geometry object should know about.
233  initImageParameters( theGeometry.get() );
234  }
235
236  return theGeometry;
237 }
238
241 {
242  static const char MODULE[] = "ossimplugins::ossimRadarSat2TiffReader::getInternalImageGeometry";
243  if (traceDebug())
244  {
245  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
246  }
247
249
250  ossimXmlDocument* xdoc = new ossimXmlDocument();
251  if ( xdoc->openFile(theProductXmlFile) )
252  {
254
255  if ( model->open(theProductXmlFile) )
256  {
257  // Assign the model to our ossimImageGeometry object.
258  geom->setProjection( model.get() );
259  }
260  else
261  {
262  if (traceDebug())
263  {
264  ossimNotify(ossimNotifyLevel_DEBUG) << "WARNING: Unhandled projection: " << std::endl;
265  }
266  }
267  } // matches: if ( xdoc->openFile(theProductXmlFile) )
268
269  delete xdoc;
270  xdoc = 0;
271
272  if (traceDebug())
273  {
274  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited..." << std::endl;
275  }
276
277  return geom;
278 }
279
281  const ossimFilename& file) const
282 {
283  bool result = false;
284
285  // Check extension to see if it's xml.
286  if ( file.ext().downcase() == "xml" )
287  {
288  ossimXmlDocument* xdoc = new ossimXmlDocument();
289
290  if ( xdoc->openFile(file) )
291  {
292  result = isRadarSat2ProductFile(xdoc);
293  }
294
295  delete xdoc;
296  xdoc = 0;
297  }
298
299  return result;
300 }
301
303  const ossimXmlDocument* xdoc) const
304 {
305  bool result = false;
306
307  if (xdoc)
308  {
310
311  // See if it's a TerraSAR-X product xml file.
312  result = helper.isRadarSat2(xdoc);
313  }
314
315  return result;
316 }
static ossimImageGeometryRegistry * instance()
bool open(const ossimFilename &file)
Method to intantial model from a file.
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
bool open()
Returns true if no errors initializing object.
RTTI_DEF1(ossimAlosPalsarModel, "ossimAlosPalsarModel", ossimGeometricSarSensorModel)
ossimFilename expand() const
Method to do file name expansion.
Class to encapsulate parsing RadarSat2 product.xml file.
bool getImageFile(const ossimXmlDocument *xdoc, ossimString &s) const
virtual bool extendGeometry(ossimImageHandler *handler) const
bool isRadarSat2(const ossimXmlDocument *xdoc) const
Checks for node /product/sourceAttributes/satellite containing RADARSAT-2.
bool openFile(const ossimFilename &filename)
bool isRadarSat2ProductFile(const ossimFilename &file) const
Method to check file to see if it&#39;s a RS2 product xml file.
virtual void close()
This class allows for direct localisation and indirect localisation using the RadarSat2 sensor model...
ossimFilename dirCat(const ossimFilename &file) const
ossimString ext() const
virtual ossimRefPtr< ossimImageGeometry > getInternalImageGeometry() const
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
ossimFilename path() const
virtual ~ossimRadarSat2TiffReader()
virtual destructor
