Public Member Functions | Private Member Functions | Private Attributes | List of all members
ossimplugins::ossimRadarSat2TiffReader Class Reference
#include <ossimRadarSat2TiffReader.h>
Inheritance diagram for ossimplugins::ossimRadarSat2TiffReader:
ossimTiffTileSource ossimImageHandler ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
 ossimRadarSat2TiffReader ()
 default constructor More...
virtual ~ossimRadarSat2TiffReader ()
 virtual destructor More...
virtual bool open (const ossimFilename &file)
 This open take the product xml file. More...
virtual void close ()
 Close method. More...
- Public Member Functions inherited from ossimTiffTileSource
 ossimTiffTileSource ()
bool open (std::shared_ptr< ossim::istream > &str, const std::string &connectionString)
 This open takes a stream and stores/captures the shared pointer on success. More...
 Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More...
 Method to get a tile. More...
 Returns the number of bands in the image. More...
 Initializes bandList to the zero based order of output bands. More...
virtual ossim_uint32 getNumberOfLines (ossim_uint32 resLevel=0) const
 Returns the number of lines in the image. More...
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 resLevel=0) const
 Returns the number of samples in the image. More...
virtual ossim_uint32 getNumberOfDirectories () const
 Returns the number of image file directories in the tiff image. More...
 Returns the number of reduced resolution data sets (rrds). More...
virtual bool isOpen () const
 Returns the output pixel type of the tile source. More...
 Returns the width of the output tile. More...
 Returns the height of the output tile. More...
bool hasR0 () const
 Returns true if the first directory of the tiff image did not have the reduced resolution file type set. More...
virtual ossim_float64 getMinPixelValue (ossim_uint32 band=0) const
virtual ossim_float64 getMaxPixelValue (ossim_uint32 band=0) const
virtual ossim_float64 getNullPixelValue (ossim_uint32 band=0) const
virtual bool isValidRLevel (ossim_uint32 resLevel) const
void setApplyColorPaletteFlag (bool flag)
bool getApplyColorPaletteFlag () const
bool isColorMapped () const
virtual std::ostream & print (std::ostream &os) const
TIFFtiffPtr ()
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual void initialize ()
virtual bool openOverview ()
virtual void closeOverview ()
 Opens the image file. More...
 Sets the filename. More...
 Returns the filename. More...
 Connection rule. More...
virtual bool hasLut () const
virtual void loadMetaData ()
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
bool isRadarSat2ProductFile (const ossimFilename &file) const
 Method to check file to see if it's a RS2 product xml file. More...
bool isRadarSat2ProductFile (const ossimXmlDocument *xdoc) const
Private Attributes
ossimFilename theProductXmlFile
Additional Inherited Members
- Public Types inherited from ossimTiffTileSource
enum  ReadMethod {
  UNKNOWN, READ_RGBA_U8_TILE, READ_RGBA_U8_STRIP, READ_RGBA_U8A_STRIP,
  READ_SCAN_LINE, READ_TILE, READ_U16_STRIP
- Protected Member Functions inherited from ossimTiffTileSource
virtual ~ossimTiffTileSource ()
bool open ()
 Returns true if no errors initializing object. More...
virtual void completeOpen ()
virtual ~ossimReferenced ()
- Protected Attributes inherited from ossimTiffTileSource
TIFFtheTiffPtr
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 24 of file ossimRadarSat2TiffReader.h.
◆ ossimRadarSat2TiffReader()
ossimplugins::ossimRadarSat2TiffReader::ossimRadarSat2TiffReader ( )
default constructor
Definition at line 44 of file ossimRadarSat2TiffReader.cpp.
References ossimNotify(), and ossimNotifyLevel_DEBUG.
45  :
47 {
48  if (traceDebug())
49  {
51  << "ossimplugins::ossimRadarSat2TiffReader::ossimRadarSat2TiffReader entered...\n";
52 #ifdef OSSIM_ID_ENABLED
54  << "OSSIM_ID: " << OSSIM_ID << std::endl;
55 #endif
56  }
57 }
◆ ~ossimRadarSat2TiffReader()
ossimplugins::ossimRadarSat2TiffReader::~ossimRadarSat2TiffReader ( )
virtual
virtual destructor
Definition at line 59 of file ossimRadarSat2TiffReader.cpp.
60 {
61 }
Member Function Documentation
◆ close()
void ossimplugins::ossimRadarSat2TiffReader::close ( )
virtual
Close method.
Reimplemented from ossimTiffTileSource.
Definition at line 195 of file ossimRadarSat2TiffReader.cpp.
References ossimTiffTileSource::close().
196 {
199 }
void clear()
Erases the entire container.
Definition: ossimString.h:432
virtual void close()
◆ getImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimplugins::ossimRadarSat2TiffReader::getImageGeometry ( )
virtual
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 201 of file ossimRadarSat2TiffReader.cpp.
References ossimImageGeometryRegistry::extendGeometry(), and ossimImageGeometryRegistry::instance().
202 {
203  if ( !theGeometry )
204  {
205  //---
206  // Check for external geom:
207  //---
209
210  if ( !theGeometry )
211  {
212  // Check the internal geometry first to avoid a factory call.
214
215  // At this point it is assured theGeometry is set.
216
217  //---
218  // WARNING:
219  // Must create/set theGeometry at this point or the next call to
220  // ossimImageGeometryRegistry::extendGeometry will put us in an infinite loop
221  // as it does a recursive call back to ossimImageHandler::getImageGeometry().
222  //---
223
224  // Check for set projection.
225  if ( !theGeometry->getProjection() )
226  {
227  // Try factories for projection.
229  }
230  }
231
232  // Set image things the geometry object should know about.
234  }
235
236  return theGeometry;
237 }
static ossimImageGeometryRegistry * instance()
ossimRefPtr< ossimImageGeometry > theGeometry
virtual bool extendGeometry(ossimImageHandler *handler) const
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
Returns the image geometry object associated with this tile source or NULL if non defined...
virtual ossimRefPtr< ossimImageGeometry > getInternalImageGeometry() const
◆ getInternalImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimplugins::ossimRadarSat2TiffReader::getInternalImageGeometry ( ) const
virtual
Parameters
Methodto get geometry from the xml file or internal geotiff tags.
Definition at line 240 of file ossimRadarSat2TiffReader.cpp.
References ossimRefPtr< T >::get(), ossimplugins::ossimRadarSat2Model::open(), ossimXmlDocument::openFile(), ossimNotify(), ossimNotifyLevel_DEBUG, and ossimImageGeometry::setProjection().
241 {
242  static const char MODULE[] = "ossimplugins::ossimRadarSat2TiffReader::getInternalImageGeometry";
243  if (traceDebug())
244  {
245  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
246  }
247
249
250  ossimXmlDocument* xdoc = new ossimXmlDocument();
251  if ( xdoc->openFile(theProductXmlFile) )
252  {
253  ossimRefPtr<ossimRadarSat2Model> model = new ossimRadarSat2Model();
254
255  if ( model->open(theProductXmlFile) )
256  {
257  // Assign the model to our ossimImageGeometry object.
258  geom->setProjection( model.get() );
259  }
260  else
261  {
262  if (traceDebug())
263  {
264  ossimNotify(ossimNotifyLevel_DEBUG) << "WARNING: Unhandled projection: " << std::endl;
265  }
266  }
267  } // matches: if ( xdoc->openFile(theProductXmlFile) )
268
269  delete xdoc;
270  xdoc = 0;
271
272  if (traceDebug())
273  {
274  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited..." << std::endl;
275  }
276
277  return geom;
278 }
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
bool openFile(const ossimFilename &filename)
◆ getLongName()
ossimString ossimplugins::ossimRadarSat2TiffReader::getLongName ( ) const
virtual
Returns
"ossim RadarSAT-2 tiff reader"
Definition at line 129 of file ossimRadarSat2TiffReader.cpp.
130 {
131  return ossimString("ossim RadarSAT-2 tiff reader");
132 }
◆ getShortName()
ossimString ossimplugins::ossimRadarSat2TiffReader::getShortName ( ) const
virtual
Returns
"ossim_radarsat2_tiff_reader"
Definition at line 124 of file ossimRadarSat2TiffReader.cpp.
125 {
126  return ossimString("ossim_radarsat2_tiff_reader");
127 }
◆ isRadarSat2ProductFile() [1/2]
bool ossimplugins::ossimRadarSat2TiffReader::isRadarSat2ProductFile ( const ossimFilename file) const
private
Parameters
fileThe file to check.
Returns
Definition at line 280 of file ossimRadarSat2TiffReader.cpp.
References ossimString::downcase(), ossimFilename::ext(), and ossimXmlDocument::openFile().
282 {
283  bool result = false;
284
285  // Check extension to see if it's xml.
286  if ( file.ext().downcase() == "xml" )
287  {
288  ossimXmlDocument* xdoc = new ossimXmlDocument();
289
290  if ( xdoc->openFile(file) )
291  {
292  result = isRadarSat2ProductFile(xdoc);
293  }
294
295  delete xdoc;
296  xdoc = 0;
297  }
298
299  return result;
300 }
bool isRadarSat2ProductFile(const ossimFilename &file) const
Method to check file to see if it&#39;s a RS2 product xml file.
ossimString ext() const
◆ isRadarSat2ProductFile() [2/2]
bool ossimplugins::ossimRadarSat2TiffReader::isRadarSat2ProductFile ( const ossimXmlDocument xdoc) const
private
Parameters
xdocXML document opened up to product.xml file.
Returns
Definition at line 302 of file ossimRadarSat2TiffReader.cpp.
References ossimplugins::ossimRadarSat2ProductDoc::isRadarSat2().
304 {
305  bool result = false;
306
307  if (xdoc)
308  {
309  ossimRadarSat2ProductDoc helper;
310
311  // See if it's a TerraSAR-X product xml file.
312  result = helper.isRadarSat2(xdoc);
313  }
314
315  return result;
316 }
◆ loadState()
bool ossimplugins::ossimRadarSat2TiffReader::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 81 of file ossimRadarSat2TiffReader.cpp.
References ossimKeywordlist::find(), ossimTiffTileSource::loadState(), ossimNotify(), and ossimNotifyLevel_DEBUG.
83 {
84  static const char MODULE[] = "ossimplugins::ossimRadarSat2TiffReader::loadState";
85
86  if (traceDebug())
87  {
89  << MODULE << " entered...\n";
90  }
91
92  bool result = false;
93
94  // Get the product.xml file name.
95  const char* lookup = kwl.find(prefix, PRODUCT_XML_FILE_KW);
96  if (lookup)
97  {
98  theProductXmlFile = lookup;
100  {
101  //---
102  // Although we can open any tiff here we only do if we have matching
103  // RS2 product.xml.
104  //---
105  result = ossimTiffTileSource::loadState(kwl, prefix);
106  }
107  }
108
109  if (!result)
110  {
112  }
113
114  if (traceDebug())
115  {
117  << MODULE << " exit status = " << (result?"true":"false\n")
118  << std::endl;
119  }
120
121  return result;
122 }
void clear()
◆ open()
bool ossimplugins::ossimRadarSat2TiffReader::open ( const ossimFilename file)
virtual
Parameters
fileFile to open.
Returns
Definition at line 134 of file ossimRadarSat2TiffReader.cpp.
References ossimFilename::dirCat(), ossimString::downcase(), ossimFilename::expand(), ossimFilename::ext(), ossimplugins::ossimRadarSat2ProductDoc::getImageFile(), ossimTiffTileSource::open(), ossimXmlDocument::openFile(), ossimNotify(), ossimNotifyLevel_DEBUG, and ossimFilename::path().
135 {
136  static const char MODULE[] = "ossimplugins::ossimRadarSat2TiffReader::open";
137
138  if (traceDebug())
139  {
141  << MODULE << " entered...\n"
142  << "file: " << file << "\n";
143  }
144
145  bool result = false;
146
147  if ( isOpen() )
148  {
149  close();
150  }
151
152  // Check extension to see if it's xml.
153  if ( file.ext().downcase() == "xml" )
154  {
155  ossimXmlDocument* xdoc = new ossimXmlDocument();
156  if ( xdoc->openFile(file) )
157  {
158  // See if it's a TerraSAR-X product xml file.
159  if ( isRadarSat2ProductFile(xdoc) )
160  {
161  ossimString s;
162  ossimRadarSat2ProductDoc helper;
163
164  if ( helper.getImageFile(xdoc, s) )
165  {
166  ossimFilename imageFile = file.expand().path();
167  imageFile = imageFile.dirCat(s);
168
169  setFilename(imageFile);
170
171  result = ossimTiffTileSource::open();
172  if (result)
173  {
174  theProductXmlFile = file;
175  completeOpen();
176  }
177  }
178  }
179  }
180  delete xdoc;
181  xdoc = 0;
182
183  } // matches: if ( file.ext().downcase() == "xml" )
184
185  if (traceDebug())
186  {
188  << MODULE << " exit status = " << (result?"true":"false\n")
189  << std::endl;
190  }
191
192  return result;
193 }
bool open()
virtual bool isOpen() const
ossimFilename expand() const
Method to do file name expansion.
virtual void setFilename(const ossimFilename &filename)
Sets the filename.
virtual void completeOpen()
Will complete the opening process.
ossimFilename dirCat(const ossimFilename &file) const
ossimFilename path() const
◆ saveState()
bool ossimplugins::ossimRadarSat2TiffReader::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 63 of file ossimRadarSat2TiffReader.cpp.
References ossimKeywordlist::add(), ossimNotify(), ossimNotifyLevel_DEBUG, and ossimTiffTileSource::saveState().
65 {
66  static const char MODULE[] = "ossimplugins::ossimRadarSat2TiffReader::saveState";
67
68  if (traceDebug())
69  {
71  << MODULE << " entered...\n";
72  }
73
74  // Save our state:
75  kwl.add(prefix, PRODUCT_XML_FILE_KW, theProductXmlFile.c_str());
76
77  // Save the base:
78  return ossimTiffTileSource::saveState(kwl, prefix);
79 }
const char * c_str() const
Definition: ossimString.h:396
Member Data Documentation
◆ theProductXmlFile
ossimFilename ossimplugins::ossimRadarSat2TiffReader::theProductXmlFile
private
Definition at line 98 of file ossimRadarSat2TiffReader.h.
