ossimRangeDomeTileSource.cpp
Go to the documentation of this file.
1 /*
2  * ossimRangeDomeTileSource.cpp
3  *
4  * Created on: Aug 3, 2015
5  * Author: okramer
6  */
7
10 #include <ossim/base/ossimCommon.h>
13 #include <ossim/base/ossimIpt.h>
14 #include <ossim/base/ossimDpt.h>
16 #include <ossim/base/ossimNotify.h>
20 #include <iostream>
21
22 using namespace std;
23
24 RTTI_DEF1(ossimRangeDomeTileSource, "ossimRangeDomeTileSource", ossimImageHandler);
25
27
28 ossimRangeDome::ossimRangeDome(vector<ossimString>& tokens)
29 : valid (false),
30  id (0),
31  radiusMeters (0),
32  radiusPixelsSq (0),
33  classification (UNASSIGNED),
34  startAz (0),
35  endAz (0)
36 {
37  if ((tokens.size() < 6) || (tokens[0].size() && (tokens[0].chars()[0] == '#')))
38  return;
39
40  ossim_uint32 i = 0;
41  id = tokens[i++].toUInt32();
42  centerGpt.lat = tokens[i++].toDouble();
43  centerGpt.lon = tokens[i++].toDouble();
44  centerGpt.hgt = tokens[i++].toDouble();
45  radiusMeters = tokens[i++].toDouble();
46  classification = (Classification) tokens[i++].toInt32();
47  valid = true;
48
49  if (tokens.size() >= 8)
50  {
51  startAz = tokens[i++].toDouble();
52  endAz = tokens[i++].toDouble();
53  if (endAz == 360.0)
54  endAz = 0.0;
55  }
56
57  if ( tokens.size()-i )
58  {
59  description = tokens[i];
60  description.trim();
61  }
62 }
63
65 {
67  double dlat = radiusMeters/scale.y;
68  double dlon = radiusMeters/scale.x;
69  return ossimGrect(centerGpt.lat+dlat, centerGpt.lon-dlon,
70  centerGpt.lat-dlat, centerGpt.lon+dlon);
71 }
72
74 : m_gsd(1.0, 1.0) // default GSD
75 {
76 }
77
78
80 {
81  close();
82 }
83
84
86 {
87 #if 0 /* Please wrap with traceDebug(). drb */
88  if (!theImageFile.isReadable())
89  {
90  ossimNotify(ossimNotifyLevel_WARN)<<"ossimRangeDomeTileSource::open() -- Error. Coould not"
91  " open CSV file at <"<<theImageFile<<">" << endl;
92  return false;
93  }
94 #endif
95
96  ossimString dome_spec;
98  char* magic_number = new char [ sizeOfMagic ];
99
100  // Open the CSV and check proper file type:
101  ifstream indata (theImageFile.chars());
102  if (indata.fail())
103  return false;
104  indata.read(magic_number, sizeOfMagic);
105
106  if (indata.eof() || indata.fail() || (OSSIM_RANGE_DOME_SPEC_MAGIC_NUMBER != magic_number))
107  return false;
108
109  // loop over each record/dome spec:
110  vector<ossimString> tokens;
111  while (indata.good())
112  {
113  tokens.clear();
114  getline(indata, dome_spec);
115  dome_spec.split(tokens, ",", true);
116  ossimRangeDome dome (tokens);
117  if (dome.valid)
118  m_rangeDomes.push_back(dome);
119  }
120
121  // The GSD may be incorrect, but init anyway then redo whe GSD is set:
122  initialize();
123
124  return isOpen();
125 }
126
128 {
129  if (!isOpen())
130  return;
131
132  // Establish bounding rect:
133  ossimGrect boundingRect;
134  boundingRect.makeNan();
135  vector<ossimRangeDome>::iterator dome = m_rangeDomes.begin();
136  while (dome != m_rangeDomes.end())
137  {
138  boundingRect.expandToInclude(dome->boundingRect());
139  ++dome;
140  }
141
142  // Set up the geometry:
144  mapProj->setOrigin(boundingRect.midPoint());
145  mapProj->setMetersPerPixel(m_gsd);
146  ossimDpt degPerPixel (mapProj->getDecimalDegreesPerPixel());
147  mapProj->setElevationLookupFlag(false);
148  mapProj->setUlTiePoints(boundingRect.ul());
149  ossimIpt image_size(boundingRect.width()/degPerPixel.x, boundingRect.height()/degPerPixel.y);
150  theGeometry = new ossimImageGeometry(0, mapProj.get());
151  theGeometry->setImageSize(image_size);
152
153  // Transform the domes to image space coordinates:
154  dome = m_rangeDomes.begin();
155  double r;
156  while (dome != m_rangeDomes.end())
157  {
158  theGeometry->worldToLocal(dome->centerGpt, dome->centerIpt);
159  r = dome->radiusMeters/m_gsd.x;
160  dome->radiusPixelsSq = r*r;
161  ++dome;
162  }
163 }
164
165
167 {
168  return (!m_rangeDomes.empty());
169 }
170
171
173 {
174  m_rangeDomes.clear();
175  theGeometry = 0;
176 }
177
178
180  ossim_uint32 resLevel)
181 {
183
184  tile->setImageRectangle(rect);
185  tile->initialize();
186
187  getTile(tile.get(), resLevel);
188
189  return tile;
190 }
191
192
194 {
195  if (!result || !theGeometry.valid())
196  return false;
197
198  // Start with null fill:
199  result->fill(getNullPixelValue());
200
201  // Verify intersection with dataset. Everything done in R0 space:
202  ossimIrect tile_rect (result->getImageRectangle());
203  ossim_uint32 coord_scale = resLevel + 1;
204  ossimIrect tile_rect_r0 (coord_scale*tile_rect);
205  ossimIrect boundingImgRect;
206  theGeometry->getBoundingRect(boundingImgRect);
207
208  if (!tile_rect_r0.intersects(boundingImgRect))
209  {
211  return true;
212  }
213
214  vector<ossimRangeDome>::iterator dome;
215  double d2, x0, y0, dx, dy, az;
216
217  // Nested loop over all pixels in tile:
218  for (ossim_int32 yn=tile_rect.ul().y; yn<=tile_rect.lr().y; ++yn)
219  {
220  y0 = yn * coord_scale;
221
222  for (ossim_int32 xn=tile_rect.ul().x; xn<=tile_rect.lr().x; ++xn)
223  {
224  x0 = xn * coord_scale;
225
226  // Loop over each dome in the list to see if this pixel is affected:
227  dome = m_rangeDomes.begin();
228  while (dome != m_rangeDomes.end())
229  {
230  // Check distance to center:
231  dx = x0 - dome->centerIpt.x;
232  dy = y0 - dome->centerIpt.y;
233  d2 = dx*dx + dy*dy;
234
235  if (d2 > dome->radiusPixelsSq)
236  {
237  ++dome;
238  continue;
239  }
240
241  // Passed range test, do azimuth test. First check for simple 360 dome:
242  if (dome->startAz == dome->endAz)
243  {
244  result->setValue(xn, yn, (ossim_uint8) dome->classification);
245  ++dome;
246  continue;
247  }
248
249  // Need full azimuth test:
250  az = ossim::atan2d(dx, -dy);
251  if (az < 0)
252  az += 360;
253  if (((dome->startAz < dome->endAz) && (az >= dome->startAz) && (az <= dome->endAz)) ||
254  ((dome->startAz > dome->endAz) && (
255  ((az >= dome->startAz) && (az > dome->endAz)) ||
256  ((az < dome->startAz) && (az <= dome->endAz)))))
257  {
258  result->setValue(xn, yn, (ossim_uint8) dome->classification);
259  }
260  ++dome;
261  }
262  }
263  }
264
265  result->validate();
266  return true;
267 }
268
269
271 {
272  return 1;
273 }
274
275
277 {
278  if (theGeometry.valid())
279  return ( theGeometry->getImageSize().y / (resLevel+1) );
280  return 0;
281 }
282
283
285 {
286  if (theGeometry.valid())
287  return ( theGeometry->getImageSize().x / (resLevel+1) );
288  return 0;
289 }
290
291
292 bool ossimRangeDomeTileSource::saveState(ossimKeywordlist& kwl, const char* prefix) const
293 {
294  static const char MODULE[] = "ossimRangeDomeTileSource::saveState()";
295
296  ossimImageHandler::saveState(kwl, prefix);
298  {
300  << " ERROR detected in keyword list! State not saved." << std::endl;
301  return false;
302  }
303
305
306  return true;
307 }
308
309
310 bool ossimRangeDomeTileSource::loadState(const ossimKeywordlist& kwl, const char* prefix)
311 {
312  static const char MODULE[] = "ossimRangeDomeTileSource::loadState()";
313  theDecimationFactors.clear();
314
315  ossimImageHandler::loadState(kwl, prefix);
317  {
319  << "WARNING: error detected in keyword list! State not load." << std::endl;
320  return false;
321  }
322
323  ossimDpt gsd;
325  if (!value.empty())
326  gsd.x = value.toDouble();
327
328  value = kwl.find(prefix, ossimKeywordNames::METERS_PER_PIXEL_Y_KW);
329  if (!value.empty())
330  setGSD(value.toDouble());
331
332  // The rest of the state is established by opening the file:
333  bool good_open = open();
334  return good_open;
335 }
336
337
339 {
340  if (!property.valid())
341  return;
342
343  ossimString s;
344  property->valueToString(s);
345  if (s.empty())
346  return;
347
348  // The user should select either explicit GSD or relative GSD factor, never both:
349  if ( property->getName() == ossimKeywordNames::METERS_PER_PIXEL_KW )
350  {
351  ossim_float64 gsd = s.toFloat64();
352  if (!ossim::isnan(gsd))
353  setGSD(gsd);
354  }
355  else
356  {
358  }
359 }
360
361
363 {
366  {
368  prop = new ossimStringProperty(name, value);
369  }
370  else
371  {
372  prop = ossimImageHandler::getProperty(name);
373  }
374  return prop;
375 }
376
377
378
380 {
381  gsd.x =(1.0/(resLevel+1)) * m_gsd.x;
382  gsd.y =(1.0/(resLevel+1)) * m_gsd.y;
383 }
384
385
387 {
388  if (gsd == m_gsd.x)
389  return;
390
391  m_gsd.x = gsd;
392  m_gsd.y = gsd;
393
394  initialize();
395 }
396
397
398
virtual const ossimDpt & getDecimalDegreesPerPixel() const
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing...
void fill(ossim_uint32 band, ossim_float64 value)
will fill the entire band with the value.
ossimGrect boundingRect() const
ossimRefPtr< ossimImageGeometry > theGeometry
static const ossimString OSSIM_RANGE_DOME_SPEC_MAGIC_NUMBER
virtual void setValue(ossim_int32 x, ossim_int32 y, ossim_float64 color)
ossimFilename theImageFile
const ossimIpt & getImageSize() const
virtual void setGSD(const ossim_float64 &gsd)
std::basic_ifstream< char > ifstream
Class for char input file streams.
Definition: ossimIosFwd.h:44
bool valid() const
Definition: ossimRefPtr.h:75
std::vector< ossimDpt > theDecimationFactors
void makeNan()
Definition: ossimGrect.h:284
virtual bool isOpen() const
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &rect, ossim_uint32 resLevel=0)
void getBoundingRect(ossimIrect &bounding_rect) const
Get the bounding rect of (0, 0) to (imageSize.x-1, imageSize.y-1).
ossim_float64 width() const
Returns the width of a rectangle in deg.
Definition: ossimGrect.h:247
double y
Definition: ossimDpt.h:165
virtual void setOrigin(const ossimGpt &origin)
Sets theOrigin to origin.
Numeric to string methods.
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const
Pure virtual, derived classes must implement.
ossim_float64 hgt
Height in meters above the ellipsiod.
Definition: ossimGpt.h:274
static const ossimErrorCode OSSIM_ERROR
std::istream & getline(std::istream &is, ossimString &str, char delim)
Definition: ossimString.h:916
Classification classification
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
void setImageSize(const ossimIpt &size)
static const char * METERS_PER_PIXEL_Y_KW
virtual void initialize()
Initialize the data buffer.
virtual void setMetersPerPixel(const ossimDpt &gsd)
void expandToInclude(const ossimGpt &gpt)
Expands existing rect to accommodate argument point.
Definition: ossimGrect.cpp:299
std::vector< ossimRangeDome > m_rangeDomes
double ossim_float64
ossimRangeDome(std::vector< ossimString > &tokens)
yy_size_t size
ossim_float64 lon
Definition: ossimGpt.h:266
std::string::size_type size() const
Definition: ossimString.h:405
The reader properties are: – the GSD ("meters_per_pixel")
unsigned int ossim_uint32
const char * chars() const
For backward compatibility.
Definition: ossimString.h:77
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
double toDouble() const
ossim_float64 toFloat64() const
const ossimGpt & ul() const
Definition: ossimGrect.h:252
virtual ossimIrect getImageRectangle() const
double atan2d(double y, double x)
Definition: ossimCommon.h:267
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const
ossimGpt midPoint() const
Definition: ossimGrect.h:178
bool isReadable() const
virtual void close()
initialize Does nothing in this class.
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual ossimErrorCode getErrorStatus() const
ossim_int32 y
Definition: ossimIpt.h:142
static const char * METERS_PER_PIXEL_KW
double x
Definition: ossimDpt.h:164
bool empty() const
Definition: ossimString.h:411
virtual void getGSD(ossimDpt &gsd, ossim_uint32 resLevel) const
virtual void setDataObjectStatus(ossimDataObjectStatus status) const
Full list found in ossimConstants.h.
virtual void setUlTiePoints(const ossimGpt &gpt)
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
ossimDpt metersPerDegree() const
Definition: ossimGpt.cpp:498
virtual ossim_uint32 getNumberOfInputBands() const
ossim_int32 x
Definition: ossimIpt.h:141
ossim_float64 lat
Definition: ossimGpt.h:265
ossim_float64 height() const
Returns the height of a rectangle in deg.
Definition: ossimGrect.h:242
Class used for rendering range domes (a.k.a.
void setElevationLookupFlag(bool flag)
virtual bool open()
Reads CSV file representing range domes.
unsigned char ossim_uint8
const ossimString & getName() const
int ossim_int32
bool isnan(const float &v)
Definition: ossimCommon.h:91
