ossimTiledImageHandler.cpp
Go to the documentation of this file.
1 //*************************************************************************************************
2 //
3 // License: LGPL
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Author: Oscar Kramer
8 //
9 // Description:
10 //
11 // Image handler used for tile-files when the full image is distributed across multiple files,
12 // as is the case for tiled Quickbird imagery. This is not for use with band-separate formats,
13 // but only "spatially-separate" schemes.
14 //
15 //*************************************************************************************************
16 // $Id: ossimTiledImageHandler.cpp 2644 2011-05-26 15:20:11Z oscar.kramer $
17
18 #include <algorithm>
19
23 #include <ossim/base/ossimRegExp.h>
24 #include <ossim/base/ossimRefPtr.h>
28 #include <ossim/base/ossimNotify.h>
31 #include <ossim/base/ossimTrace.h>
34
35 RTTI_DEF1(ossimTiledImageHandler, "ossimTiledImageHandler", ossimImageHandler)
36
37 // Static trace for debugging
38 static ossimTrace traceDebug("ossimTiledImageHandler:debug");
39
40 //*************************************************************************************************
42 //*************************************************************************************************
44  : m_tileFiles(0),
45  m_tile(0),
46  m_fullImgRect(),
48  m_startOvrResLevel(-1),
49  m_lockSubOvrs(false)
50 #else
51  m_startOvrResLevel(1)
52 #endif
53 {
54 }
55
56 //*************************************************************************************************
58 //*************************************************************************************************
60 {
61  close();
62 }
63
64 //*************************************************************************************************
67 //*************************************************************************************************
69 {
70  vector<ossimTileFile>::iterator iter = m_tileFiles.begin();
71  while (iter != m_tileFiles.end())
72  {
73  (*iter).imageHandler->close();
74  ++iter;
75  }
76  m_tileFiles.clear();
77 }
78
79 //*************************************************************************************************
82 //*************************************************************************************************
84 {
85  if (m_tileFiles.size() > 0)
86  return true;
87
88  return false;
89 }
90
91 //*************************************************************************************************
93 //*************************************************************************************************
95 {
96  m_tile = 0;
97  if ((m_tileFiles.size() == 0))
98  return;
99
100  // Just copy the image data tile of the first tile-file:
101  ossimRefPtr<ossimImageHandler> h0 = m_tileFiles[0].imageHandler;
102  ossimIrect rect (h0->getBoundingRect());
103  rect.set_lr(rect.ul() + ossimIpt(h0->getTileWidth()-1, h0->getTileHeight()-1));
104  ossimRefPtr<ossimImageData> source_tile = m_tileFiles[0].imageHandler->getTile(rect);
105  if (!source_tile.valid())
106  {
107  ossimNotify(ossimNotifyLevel_FATAL) << "ossimTiledImageHandler::allocate() -- Could not"
108  "determine file-tile image data for allocating image tile. Aborting."<<endl;
109  return;
110  }
111
112  m_tile = (ossimImageData*) source_tile->dup();
113 }
114
115 //*************************************************************************************************
117 //*************************************************************************************************
119  ossim_uint32 resLevel)
120 {
121  // First verify that there are file-tiles available:
122  if (m_tileFiles.size() == 0)
124
125  // Allocate data tile if needed:
126  if(!m_tile.valid())
127  {
128  allocate();
129  if(!m_tile.valid())
131  }
132
133  // Check if res level represents data inside the overall scene overview:
134  if (theOverview.valid() && (resLevel >= m_startOvrResLevel))
135  return theOverview->getTile(tile_rect, resLevel);
136
137  // Loop over all tile-files to find which intersect the requested image rect. This necessarily
138  // needs to be done at full res coordinates, so need to adjust by res level requested:
139  ossimDpt decimation_factor;
140  // const ossim_uint32 BANDS = m_tile->getNumberOfBands();
141  // const ossim_uint32 PPB = m_tile->getSizePerBand(); // pixels per band
142  // bool none_found = true;
143
144
145  // ossim_uint32 wd, hd, ws, hs;
146  // m_tile->getWidthHeight(wd, hd);
147
148  // Always start with blank tile.
149  m_tile->makeBlank();
150
151  //---
152  // Add in the sub image offset if any for the rest of this method to work
153  // correctly.
154  //---
155  ossimIrect adjusted_tile_rect = tile_rect + m_fullImgRect.ul();
156
157  // See if any point of the requested tile is in the image.
158  if ( adjusted_tile_rect.intersects( m_fullImgRect ) )
159  {
160  // This need to set for loadTile to work off the full image rect.
161  m_tile->setImageRectangle(adjusted_tile_rect);
162
163  vector<ossimTileFile>::iterator tf_iter = m_tileFiles.begin();
164  ossimRefPtr<ossimImageData> source_tile = 0;
165  while (tf_iter != m_tileFiles.end())
166  {
167  if (( (*tf_iter).subImageRects.size() > resLevel) &&
168  adjusted_tile_rect.intersects((*tf_iter).subImageRects[resLevel]))
169  {
170  //---
171  // Current image handler lies within requested rect, need to adjust
172  // this rect to be relative to this subimage offset before fetching
173  // the tile:
174  //---
175  ossimIrect full_image_clip_rect =
176  adjusted_tile_rect.clipToRect( (*tf_iter).subImageRects[resLevel]);
177
178  // Subtract the sub image offset to make zero base image rect.
179  ossimIrect relative_clip_rect( full_image_clip_rect -
180  (*tf_iter).subImageRects[resLevel].ul());
181
182  source_tile = (*tf_iter).imageHandler->getTile(relative_clip_rect, resLevel);
183  if ( source_tile.valid() )
184  {
185  if ( (source_tile->getDataObjectStatus() != OSSIM_NULL) &&
186  (source_tile->getDataObjectStatus() != OSSIM_EMPTY) )
187  {
188  // Give the loadTile the clip rect relative to the full image.
189  m_tile->loadTile( source_tile->getBuf(),
190  full_image_clip_rect,
191  OSSIM_BSQ);
192  m_tile->validate();
194  {
195  break;
196  }
197  }
198  }
199  }
200  ++tf_iter;
201  }
202
203  } // Matches: if ( adjusted_tile_rect.intersects( m_fullImgRect ) )
204
205  // Set back to zero based rect.
206  m_tile->setImageRectangle(tile_rect);
207
208  return m_tile;
209 }
210
211 // Below code was core dumping on tiled DG data. drb - 20160822
212 #if 0
213
214  ossimIrect relative_rect (tile_rect - (*tf_iter).subImageRects[resLevel].ul());
215  std::cout << "reletive_rect: " << relative_rect << std::endl;
216  source_tile = (*tf_iter).imageHandler->getTile(relative_rect, resLevel);
217
218  // Quick check to see if a full tile was returned, in which case we can just return that
219  // tile instead of looping below:
220  //if (source_tile->getDataObjectStatus() == OSSIM_FULL)
221  //{
222  // source_tile->setImageRectangle(tile_rect);
223  // return source_tile;
224  //}
225
226  // Set the tile's rect back to full image space before saving to the list:
227  source_tile->getWidthHeight(ws, hs);
228  std::cout << "ws: " << ws << " hs: " << hs << " wd: " << wd << " hd: " << hd
229  << std::endl;
230  for (ossim_uint32 band = 0; band < BANDS; ++band)
231  {
232  const ossim_uint16 null_pixel = (ossim_uint16) m_tile->getNullPix(band);
233  const ossim_uint16* s = (const ossim_uint16*) source_tile->getBuf(band);
234  ossim_uint16* d = (ossim_uint16*) m_tile->getBuf(band);
235  ossim_uint32 is = 0;
236  ossim_uint32 id = 0;
237  for (ossim_uint32 y=0; (y<hd)&&(y<hs); ++y)
238  {
239  for (ossim_uint32 x=0; x<wd; ++x)
240  {
241  if (x < ws)
242  {
243  // cout << "is: " << is << endl;
244  if (s[is] != null_pixel)
245  d[id] = s[is];
246  ++is;
247  }
248  ++id;
249  }
250  }
251  }
252
253
254  }
255  ++tf_iter;
256  }
257
258  m_tile->validate();
259
260  } // Matches: if ( tile_rect.intersects( m_fullImgRect ) )
261
262  return m_tile;
263 }
264 #endif
265
266 //*************************************************************************************************
270 //*************************************************************************************************
272 {
273  if (m_fullImgRect.hasNans())
274  return 0;
275
276  // Using simple decimation by powers of 2:
277  ossim_uint32 numlines = m_fullImgRect.height() >> resLevel;
278  return numlines;
279 }
280
281 //*************************************************************************************************
285 //*************************************************************************************************
287 {
288  if (m_fullImgRect.hasNans())
289  return 0;
290
291  // Using simple decimation by powers of 2:
292  ossim_uint32 numsamps = m_fullImgRect.width() >> resLevel;
293  return numsamps;
294 }
295
296 //*************************************************************************************************
299 //*************************************************************************************************
300 bool ossimTiledImageHandler::saveState(ossimKeywordlist& kwl, const char* prefix) const
301 {
302  return ossimImageHandler::saveState(kwl, prefix);
303 }
304
305 //*************************************************************************************************
308 //*************************************************************************************************
309 bool ossimTiledImageHandler::loadState(const ossimKeywordlist& kwl, const char* prefix)
310 {
311  if (!ossimImageHandler::loadState(kwl, prefix))
312  return false;
313
314  return open();
315 }
316
317 //*************************************************************************************************
323 //*************************************************************************************************
325 {
326  return true;
327 }
328
329 //*************************************************************************************************
330 // Returns the number of bands of the first tile since all tiles need to have the same pixel type.
331 //*************************************************************************************************
333 {
334  if ((m_tileFiles.size() == 0) || (!m_tileFiles[0].imageHandler.valid()))
335  return 0;
336
337  return m_tileFiles[0].imageHandler->getNumberOfInputBands();
338 }
339
340 //*************************************************************************************************
345 //*************************************************************************************************
347 {
348  if ((m_tileFiles.size() == 0) || (!m_tileFiles[0].imageHandler.valid()))
349  return 0;
350
351  if (m_tileFiles[0].imageHandler->isImageTiled())
352  return m_tileFiles[0].imageHandler->getImageTileWidth();
353
354  return m_tileFiles[0].imageHandler->getNumberOfSamples();
355 }
356
357 //*************************************************************************************************
362 //*************************************************************************************************
364 {
365  if ((m_tileFiles.size() == 0) || (!m_tileFiles[0].imageHandler.valid()))
366  return 0;
367
368  if (m_tileFiles[0].imageHandler->isImageTiled())
369  return m_tileFiles[0].imageHandler->getImageTileHeight();
370
371  return m_tileFiles[0].imageHandler->getNumberOfLines();
372 }
373
374 //*************************************************************************************************
376 //*************************************************************************************************
378 {
379  if ((m_tileFiles.size() == 0) || (!m_tileFiles[0].imageHandler.valid()))
380  return OSSIM_SCALAR_UNKNOWN;
381
382  return m_tileFiles[0].imageHandler->getOutputScalarType();
383 }
384
385 //*************************************************************************************************
387 //*************************************************************************************************
389 {
390  //---
391  // Note: Rectangle should be zero based. Sub image offset handled in
392  // getTile and getImageGeometry. drb
393  //---
395  if ( resLevel > 0 )
396  {
397  ossimDpt decimation;
398  getDecimationFactor(resLevel, decimation);
399
400  rect = rect*decimation;
401  }
402  return rect;
403
404 #if 0
405  if (resLevel == 0)
406  return m_fullImgRect;
407
408  ossimDpt decimation;
409  getDecimationFactor(resLevel, decimation);
410
411  return m_fullImgRect*decimation;
412 #endif
413 }
414
415
416 #if USING_SUB_OVRS
417 //*************************************************************************************************
418 // Overrides base class
419 //*************************************************************************************************
421 {
422  openOverview();
424 }
425
426 //*************************************************************************************************
430 //*************************************************************************************************
431 bool ossimTiledImageHandler::buildOverview(ossimImageHandlerOverviewCompressionType ctype,
432  ossim_uint32 qual,
434  bool ifr_flag)
435 {
436  if (m_tileFiles.size() == 0)
437  return false;
438
439  bool all_ok = true;
440  vector<ossimTileFile>::iterator iter = m_tileFiles.begin();
441  while ((iter != m_tileFiles.end()) && all_ok)
442  {
443  if (!(*iter).imageHandler->hasOverviews())
444  {
445  ossimNotify(ossimNotifyLevel_INFO)<<"\nBuilding overview for <"
446  <<(*iter).imageHandler->getFilename()<<">"<<std::endl;
447
448  all_ok = (*iter).imageHandler->buildOverview(ctype, qual, rtype, ifr_flag);
449  }
450  ++iter;
451  }
452
453  // Overviews for subimage tile-files have been processed. However, we need to check the
454  // preferences for the overview stop dimension to see if we need additional decimation of the
455  // overall scene to achieve the final desired dimension.
456  ossimString stop_dim_str =
458  if (!stop_dim_str.empty())
459  {
460  ossim_uint32 stop_dim = stop_dim_str.toUInt32();
461  ossimDpt decimation = theDecimationFactors.back();
462  ossim_uint32 nlines = decimation.y * m_fullImgRect.height();
463  ossim_uint32 nsamps = decimation.x * m_fullImgRect.width();
464  if ((nlines > stop_dim) || (nsamps > stop_dim))
465  {
466  // Need to continue decimating. These decimations are stored in an overall scene file.
467  // Need subimage OVRs open for this next operation:
468  openOverview();
469
471  tob.setInputSource(this);
473
474  // This magically takes over where we left off in decimating:
476  {
477  // Overview was successfully written, now open it:
479  all_ok = openOverview();
480  }
481  }
482  }
483
484  return all_ok;
485 }
486
487 //*************************************************************************************************
488 // Will open overview files for all tile files. Actually, the tile-files will already have opened
489 // their individual overviews, so this method only verifies the fact and initializes the
490 // associated subimage rects at all decimation levels.
491 //*************************************************************************************************
493 {
494  if (m_tileFiles.size() == 0)
495  return false;
496
497  theDecimationFactors.clear();
498  bool all_ok = true;
499  ossimRefPtr<ossimImageHandler> handler = 0;
500  vector<ossimDpt> factors;
501  ossim_uint32 min_num_rlevels = 999;
502
503  // Loop over all tile-files to verify their OVR was opened and to calculate the associated
504  // subimage rects at each res level:
505  vector<ossimTileFile>::iterator iter = m_tileFiles.begin();
506  while ((iter != m_tileFiles.end()) && all_ok)
507  {
508  handler = (*iter).imageHandler;
509  if (!handler.valid())
510  {
511  ++iter;
512  continue;
513  }
514
515  if ((*iter).subImageRects.size() == 0)
516  {
517  ossimNotify(ossimNotifyLevel_INFO)<<"\nBounding image rectangle not defined for <"
518  <<(*iter).imageHandler->getFilename()<<">! Cannot proceed with overviews."<<std::endl;
519  all_ok = false;
520  }
521
522  else if (handler->getOverview())
523  {
524  // Only verified that overview for tile-file was opened. Check number of decimation levels
525  // to latch minimum:
526  (*iter).overviewIsOpen = true;
527  handler->getDecimationFactors(factors);
528
529  if (factors.size() < min_num_rlevels)
530  min_num_rlevels = (ossim_uint32) factors.size();
531
532  // Need to determine the sub image rects at each decimation level:
533  ossimIrect subRectR0 ((*iter).subImageRects[0]);
534  for (ossim_uint32 i=1; i<(ossim_uint32)factors.size(); i++)
535  {
536  ossimIrect r (factors[i].x * subRectR0.ul().x, factors[i].y * subRectR0.ul().y,
537  factors[i].x * subRectR0.lr().x, factors[i].y * subRectR0.lr().y);
538  (*iter).subImageRects.push_back(r);
539  }
540  }
541  else
542  {
543  ossimNotify(ossimNotifyLevel_INFO)<<"\nNo overview available for <"
544  <<(*iter).imageHandler->getFilename()<<">"<<std::endl;
545  all_ok = false;
546  }
547  ++iter;
548  }
549
550  // Assuming here that the first tile will always provide a good representation of the decimations
551  // for all res levels in all tile-files. This may not be true.
552  if (m_tileFiles.size() && m_tileFiles[0].imageHandler.valid())
553  {
554  m_tileFiles[0].imageHandler->getDecimationFactors(theDecimationFactors);
555  theDecimationFactors.resize(min_num_rlevels);
556  }
557
558  // Check for overall scene overview file, that takes over where the individual tile-file
559  // overviews leave off:
561  if (!theOverviewFile.exists())
563  if (theOverviewFile.exists())
564  {
565  m_lockSubOvrs = true; // prevent closing and reopening of subimage ovrs
567  m_lockSubOvrs = false; // reset
568  if (theOverview.valid())
569  {
570  vector<ossimDpt> extra_decimations;
571  theOverview->getDecimationFactors(extra_decimations);
572  if (extra_decimations.size())
573  {
574  // Obtain the decimations and add it to our decimation list:
576  ossimDpt start_decimation (theDecimationFactors.back() * 0.5);
577  ossimDpt decimation;
578  for (ossim_uint32 i=0; i<extra_decimations.size(); i++)
579  {
580  decimation.x = start_decimation.x*extra_decimations[i].x;
581  decimation.y = start_decimation.y*extra_decimations[i].y;
582  theDecimationFactors.push_back(decimation);
583  }
584  }
585  }
586  }
587
588  return all_ok;
589 }
590
591 //*************************************************************************************************
593 //*************************************************************************************************
595 {
596  if (theOverview.valid())
597  theOverview = 0;
598
599  if (m_lockSubOvrs == false)
600  {
601  vector<ossimTileFile>::iterator iter = m_tileFiles.begin();
602  while ((iter != m_tileFiles.end()))
603  {
604  if ((*iter).imageHandler.valid())
605  (*iter).imageHandler->closeOverview();
606
607  ++iter;
608  }
609  }
610 }
611
612 //*************************************************************************************************
614 //*************************************************************************************************
616 {
617  bool all_have_ovrs = true;
618  vector<ossimTileFile>::const_iterator iter = m_tileFiles.begin();
619  while ((iter != m_tileFiles.end()) && all_have_ovrs)
620  {
621  if (((*iter).imageHandler.valid()) && !((*iter).imageHandler->hasOverviews()))
622  all_have_ovrs = false;
623  ++iter;
624  }
625  return all_have_ovrs;
626 }
627
628 //*************************************************************************************************
631 //*************************************************************************************************
633 {
634  return (ossim_uint32) theDecimationFactors.size();
635 }
636
637 #endif /* #if USING_SUB_OVRS */
638
ossim_uint32 x
virtual void getDecimationFactors(vector< ossimDpt > &decimations) const
This returns all decimation for all levels.
virtual ossim_uint32 getImageTileWidth() const
virtual bool buildOverview(ossimImageHandlerOverviewCompressionType compressionType=OSSIM_OVERVIEW_COMPRESSION_NONE, ossim_uint32 quality=75, ossimFilterResampler::ossimFilterResamplerType resampleType=ossimFilterResampler::ossimFilterResampler_BOX, bool includeFullResFlag=false)
Will build over file for theImageFile.
void allocate()
Initialize tile buffer to match image datatype.
ossim_uint32 y
bool valid() const
Definition: ossimRefPtr.h:75
std::vector< ossimDpt > theDecimationFactors
double y
Definition: ossimDpt.h:165
ossim_uint32 height() const
Definition: ossimIrect.h:487
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
virtual const ossimImageHandler * getOverview() const
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns overall bounding rect in image space.
const ossimIpt & ul() const
Definition: ossimIrect.h:274
ossim_uint32 toUInt32() const
virtual void getDecimationFactor(ossim_uint32 resLevel, ossimDpt &result) const
virtual void closeOverview()
If theOverview is initialized it will be deleted and set to NULL.
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
unsigned short ossim_uint16
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const
virtual bool openOverview()
Searches for an overview.
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
virtual ossimObject * dup() const
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual ossim_uint32 getNumberOfDecimationLevels() const
This returns the total number of decimation levels.
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &rect, ossim_uint32 resLevel)
Fills the requested tile by pulling pixels from multiple file tiles as needed.
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
virtual ossim_uint32 getNumberOfInputBands() const
virtual ~ossimTiledImageHandler()
Destructor:
virtual bool open()=0
const char * findPreference(const char *key) const
*virtual void close()
bool exists() const
virtual bool setInputSource(ossimImageHandler *imageSource)
Sets the input to the builder.
unsigned int ossim_uint32
virtual ossim_uint32 getImageTileHeight() const
Returns the tile height of the image or 0 if the image is not tiled.
virtual bool isOpen() const
virtual bool isImageTiled() const
Indicates whether or not the image is tiled internally.
Constructor (default):
ossim_uint32 width() const
Definition: ossimIrect.h:500
virtual bool openValidVertices()
Creates vertices file name based on image, then tries to open.
static ossimPreferences * instance()
ossimScalarType
Returns scalar type of first tile (should be the same for all tiles)
#define USING_SUB_OVRS
virtual void makeBlank()
virtual void completeOpen()
Will complete the opening process.
if(yy_init)
ossimRefPtr< ossimImageHandler > theOverview
void set_lr(const ossimIpt &pt)
Definition: ossimIrect.h:623
double x
Definition: ossimDpt.h:164
bool empty() const
Definition: ossimString.h:411
ossimFilename theOverviewFile
bool hasNans() const
Definition: ossimIrect.h:337
vector< ossimTileFile > m_tileFiles
virtual bool hasOverviews() const
Returns zero-based bounding rectangle of the image.
#define RTTI_DEF1(cls, name, b1)
Definition: ossimRtti.h:485
bool buildOverview(const ossimFilename &overview_file, bool copy_all=false)
Builds overview file and sets "theOutputFile" to that of the overview_file.
static const char * OVERVIEW_STOP_DIMENSION_KW
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const
ossimFilename getFilenameWithThisExtension(const ossimString &ext, bool set_e0_prefix=false) const
Returns the image file with extension set using supplentary directory for dirname if set...
ossimRefPtr< ossimImageData > m_tile
