ATP::ossimCorrelationSource Class Reference
Finds auto-tie-points using the corss-correlation-based matching algorithm. More...
#include <ossimCorrelationSource.h>
Inheritance diagram for ATP::ossimCorrelationSource:
ATP::AtpTileSource ossimImageCombiner ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimCorrelationSource ()
 ossimCorrelationSource (ossimConnectableObject::ConnectableObjectList &inputSources)
 ossimCorrelationSource (AtpGenerator *generator)
virtual ~ossimCorrelationSource ()
virtual void initialize ()
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &origin, ossim_uint32 rLevel=0)
 Derived classes implement their particular tiepoint matching algorithms for the requested tile. More...
unsigned int getNominalCmpPatchSize () const
 For engineering use in annotating CMP image. More...
- Public Member Functions inherited from ATP::AtpTileSource
 AtpTileSource (AtpGenerator *generator)
virtual ~AtpTileSource ()
AtpListgetTiePoints ()
 This list resets with every getTile() call , so make sure tiepoints from previous getTile() calls are being accumulated. More...
void filterPoints ()
void setTiePoints (ossim::TiePointList &atpList)
 Used for testing. More...
- Public Member Functions inherited from ossimImageCombiner
 ossimImageCombiner ()
 ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag)
 ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources)
virtual bool saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const
virtual void updateRects ()
 This will go through and precompute the bounding rects of each input image. More...
 Returns the number of bands available from the input. More...
virtual ossim_uint32 getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const
 Used to retrieve the number of overlapping images withint the given rect. More...
virtual void getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const
 Used to populate the result with the index of the overlapping images. More...
virtual ossimRefPtr< ossimImageDatagetNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual ossimRefPtr< ossimImageDatagetNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual bool getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0)
virtual ossimRefPtr< ossimImageDatagetNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual ossimRefPtr< ossimImageDatagetNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual bool canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const
virtual bool hasDifferentInputs () const
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
void findFeatures (const ossimImageData *data, std::vector< ossimIpt > &featurePts)
 Given an image tile, locates prominent features in that tile. Use. More...
bool correlate (std::shared_ptr< AutoTiePoint > atp)
bool OpenCVCorrelation (std::shared_ptr< AutoTiePoint > atp, const ossimImageData *refpatch, const ossimImageData *cmppatch)
- Protected Member Functions inherited from ATP::AtpTileSource
 AtpTileSource ()
 AtpTileSource (ossimConnectableObject::ConnectableObjectList &inputSources)
virtual void allocate ()
void filterWithParallax ()
void computeParallax ()
void computeParallaxStatistics ()
void filterWithoutParallax ()
void pruneList ()
 Caps the max number of TPs given the list, which is the list of filtered TPs for the tile. More...
void initializeStaticMembers ()
- Protected Member Functions inherited from ossimImageCombiner
virtual ~ossimImageCombiner ()
void precomputeBounds () const
virtual ~ossimReferenced ()
Protected Attributes
unsigned int m_nominalCmpPatchSize
- Protected Attributes inherited from ATP::AtpTileSource
std::shared_ptr< AtpGeneratorm_generator
AtpList m_tiePoints
ParallaxInfo m_paxInfo
bool m_considerParallax
- Protected Attributes inherited from ossimImageCombiner
ossim_uint32 theLargestNumberOfInputBands
ossim_uint32 theInputToPassThrough
bool theHasDifferentInputs
ossimRefPtr< ossimImageDatatheNormTile
std::vector< ossimIrecttheFullResBounds
bool theComputeFullResBoundsFlag
ossim_uint32 theCurrentIndex
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Additional Inherited Members
- Static Protected Attributes inherited from ATP::AtpTileSource
static double s_minVectorResDiff = 0
static double s_maxDiffRatio = 1.0
static double s_cosMaxAngleDiff = 0
static double s_maxPaxDev = 1.0
static double s_maxPaxPix = 2.0
static unsigned int s_minNumConsistent = 3
static unsigned int s_percentConsistent = 50
static unsigned int s_numTpsPerTile = 2
static bool s_useRasterMode = false
static bool s_initialized = false
static unsigned int s_numFilterIterations = 0
Detailed Description
Definition at line 21 of file ossimCorrelationSource.h.
◆ ossimCorrelationSource() [1/3]
ATP::ossimCorrelationSource::ossimCorrelationSource ( )
Definition at line 19 of file ossimCorrelationSource.cpp.
21 {
22  // PRIVATE, SHOULD NEVER BE CALLED. WOULD NEED TO CALL INITIALIZE
23 }
◆ ossimCorrelationSource() [2/3]
ATP::ossimCorrelationSource::ossimCorrelationSource ( ossimConnectableObject::ConnectableObjectList inputSources)
Definition at line 25 of file ossimCorrelationSource.cpp.
References initialize().
26 : AtpTileSource(inputSources),
28 {
29  initialize();
30 }
◆ ossimCorrelationSource() [3/3]
ATP::ossimCorrelationSource::ossimCorrelationSource ( AtpGenerator generator)
Definition at line 32 of file ossimCorrelationSource.cpp.
33 : AtpTileSource(generator),
35 {
36  // PRIVATE, SHOULD NEVER BE CALLED. WOULD NEED TO CALL INITIALIZE
37 }
◆ ~ossimCorrelationSource()
ATP::ossimCorrelationSource::~ossimCorrelationSource ( )
virtual
Definition at line 39 of file ossimCorrelationSource.cpp.
40 {
41 }
Member Function Documentation
◆ correlate()
bool ATP::ossimCorrelationSource::correlate ( std::shared_ptr< AutoTiePoint atp)
protected
Definition at line 275 of file ossimCorrelationSource.cpp.
References ossim::JsonParam::asUint(), CINFO, CWARN, ossim::JsonConfig::diagnosticLevel(), ossim::JsonConfig::getParameter(), ATP::AtpConfig::instance(), ATP::AtpTileSource::m_generator, m_nominalCmpPatchSize, max, min, OpenCVCorrelation(), and OSSIM_FULL.
Referenced by getTile().
276 {
277  // This method returns TRUE if a match was found
278
279  const ossimString MODULE("ossimCorrelationSource::correlate() -- ");
280  AtpConfig& config = AtpConfig::instance();
281
282  // Establish the REF patch rect centered on the viewpoint and the CMP patch rect sized by image
283  // error and offset by prior residuals:
284  unsigned int refPatchSize = AtpConfig::instance().getParameter("corrWindowSize").asUint();
285  ossimDpt refViewPt;
286  atp->getRefViewPoint(refViewPt);
287  ossimIrect refPatchRect(refViewPt, refPatchSize, refPatchSize);
288  ossimIrect cmpPatchRect(refViewPt, m_nominalCmpPatchSize, m_nominalCmpPatchSize);
289
290  // Grab the image patches from the cmp and ref images.
291  ossimRefPtr<ossimImageData> refpatch (m_generator->getRefChain()->getTile(refPatchRect, 0));
292  if (!refpatch.valid())
293  {
294  CWARN << MODULE << "Error getting ref patch image data." << endl;
295  return false;
296  }
297
298  if (config.diagnosticLevel(5))
299  {
300  ossimDpt refImgPt, cmpImgPt;
301  m_generator->getRefIVT()->viewToImage(refViewPt, refImgPt);
302  m_generator->getCmpIVT()->viewToImage(refViewPt, cmpImgPt);
303  CINFO<<"\nFeature view pt: "<<refViewPt
304  <<"\n REF img pt: "<<refImgPt
305  <<"\n CMP img pt: "<<cmpImgPt<<endl;
306  refpatch->write("REF_PATCH.RAS");
307
308  vector<double> min, max;
309  refpatch->computeMinMaxPix(min, max);
310  if (min.size() && max.size())
311  CINFO<<" REF min, max: "<<(int)min[0]<<", "<<(int)max[0]<<endl;
312  }
313
314  ossimDataObjectStatus stat = refpatch->getDataObjectStatus();
315  if (stat != OSSIM_FULL)
316  {
317  if (config.diagnosticLevel(5))
318  CINFO<<MODULE << "REF patch contained a null pixel. Skipping this point..."<<endl;
319  return false;
320  }
321
322  ossimRefPtr<ossimImageData> cmppatch (m_generator->getCmpChain()->getTile(cmpPatchRect, 0));
323  if (!cmppatch.valid())
324  {
325  CWARN << MODULE << "Error getting cmp patch image data." << endl;
326  return false;
327  }
328  if (cmppatch->getDataObjectStatus() != OSSIM_FULL)
329  {
330  if (config.diagnosticLevel(5))
331  CINFO<<MODULE << "CMP patch contained a null pixel. Skipping this point..."<<endl;
332  return false;
333  }
334
335  if (config.diagnosticLevel(5))
336  {
337  cmppatch->write("CMP_PATCH.RAS");
338  vector<double> min, max;
339  cmppatch->computeMinMaxPix(min, max);
340  if (min.size() && max.size())
341  CINFO << " CMP min, max: " << (int) min[0] << ", " << (int) max[0]<< "\n" << endl;
342  }
343
344  // Invoke the proper correlation code to arive at the peak collection for this TP:
345  bool corr_ok;
346  corr_ok = OpenCVCorrelation(atp, refpatch.get(), cmppatch.get());
347  int numMatches = atp->getNumMatches();
348
349  // The peaks for the given patch pair have been established and stored in the TPs.
350  if (corr_ok)
351  {
352  if (config.diagnosticLevel(4))
353  {
354  if (numMatches)
355  {
356  double corr_value;
357  atp->getConfidenceMeasure(corr_value);
358  CINFO<<MODULE<<"Match found for TP "<<atp->getTiePointId()<<" = "<<corr_value<<endl;
359  }
360  else
361  CINFO<<MODULE<<"No match found for TP "<<atp->getTiePointId()<<endl;
362  }
363  }
364  else // Correlation problem occurred
365  {
366  CWARN << MODULE << "Error encountered during correlation. Aborting correlation." << endl;
367  return false;
368  }
369
370  if (config.diagnosticLevel(5))
371  {
372  ossimDpt cmpimgpt,refimgpt,refviewpt,cmpviewpt;
373  ossimGpt refGpt;
374  atp->getRefImagePoint(refimgpt);
375  atp->getRefViewPoint(refviewpt);
376  atp->getCmpImagePoint(cmpimgpt);
377  atp->getCmpViewPoint(cmpviewpt);
378  atp->getRefGroundPoint(refGpt);
379  if(numMatches>0)
380  {
381  double val=0;
382  ossimDpt residual;
383  atp->getConfidenceMeasure(val);
384  atp->getVectorResidual(residual);
385  CINFO<<"AutoTiePoint: ("<<atp->getTiePointId()<<") has "<<numMatches<<" matches,\n"
386  << " best: (" << val << ") residual: " << residual <<"\n"
387  << " ref gpt: "<<refGpt<<"\n"
388  << " cmpimg center: "<<cmpimgpt<<"\n"
389  << " refimg center: "<<refimgpt<<"\n"
390  << " cmpview center: "<<cmpviewpt<<"\n"
391  << " refview center: "<<refviewpt<<endl;
392  CINFO<<endl;
393  }
394  else {
395  CINFO<<"AutoTiePoint: (" << atp->getTiePointId() << ") has no peaks.\n"
396  << " ref gpt: "<<refGpt<<"\n"
397  << " refimg center: "<<refimgpt<<"\n"
398  << " refview center: "<<refviewpt<<endl;
399  }
400  }
401
402  if (numMatches)
403  return true;
404  return false;
405 }
JsonParam & getParameter(const char *paramName)
Returns a parameter (might be a null parameter if paramName not found in the configuration.
Definition: JsonConfig.cpp:377
std::shared_ptr< AtpGenerator > m_generator
Definition: AtpTileSource.h:85
bool OpenCVCorrelation(std::shared_ptr< AutoTiePoint > atp, const ossimImageData *refpatch, const ossimImageData *cmppatch)
unsigned int asUint() const
Definition: JsonConfig.cpp:264
#define max(a, b)
Definition: auxiliary.h:76
static AtpConfig & instance()
Singleton implementation.
Definition: AtpConfig.cpp:20
#define CWARN
Definitions for data object status.
#define CINFO
#define min(a, b)
Definition: auxiliary.h:75
◆ findFeatures()
void ATP::ossimCorrelationSource::findFeatures ( const ossimImageData data,
std::vector< ossimIpt > &  featurePts
protected
Definition at line 169 of file ossimCorrelationSource.cpp.
References ossim::JsonParam::asBool(), ossim::JsonParam::asFloat(), ossim::JsonParam::asUint(), CFATAL, CINFO, ATP::convertToIpl(), CWARN, ossimDataObject::getDataObjectStatus(), ossimImageData::getImageRectangle(), ossimImageData::getNullPix(), ossim::JsonConfig::getParameter(), ossimImageData::getPix(), ATP::AtpConfig::instance(), OSSIM_EMPTY, OSSIM_PARTIAL, ossimIrect::ul(), x, and y.
171 {
172  const char* MODULE = "ossimCorrelationSource::findFeatures() -- ";
173
174  feature_points.clear();
175  if (!imageChip || (imageChip->getDataObjectStatus() == OSSIM_EMPTY))
176  {
177  CWARN<<MODULE<<"WARNING: NULL or empty image data passed in."<<endl;
178  return;
179  }
180
181  // THE FOLLOWING ARE CRITICAL VALUES AND MAYBE SHOULD BE READ FROM KWL:
182  AtpConfig& config = AtpConfig::instance();
183  double refPatchSize = (double) config.getParameter("corrWindowSize").asUint(); // min distance between points
184  static const double quality = config.getParameter("minFeatureStrength").asFloat();
185  static const int use_harris= (int) config.getParameter("useHarrisCorner").asBool();
186  static const double harris_k = config.getParameter("harrisKFactor").asFloat();
187  const int averaging_block_size = (int) refPatchSize;
188
189 // imageChip->write("imageChip.ras");//### TODO REMOVE
190  IplImage *ipl_image = convertToIpl(imageChip);
191  if(!ipl_image)
192  {
193  CFATAL<<MODULE << "ERROR: Got null IplImage pointer converting from ossimImageData*!";
194  return;
195  }
196 // cvNamedWindow("ipl_image", 1); //###
197 // cvShowImage("ipl_image", ipl_image); //###
198
199  // Need to mask pixels outside of intersection:
200  ossimIpt tileUL (imageChip->getImageRectangle().ul());
201  IplImage* mask = 0;
202  double null_pixel = imageChip->getNullPix(0);
203  if (imageChip->getDataObjectStatus() == OSSIM_PARTIAL)
204  {
205  CvSize bufsize = cvGetSize(ipl_image);
206  mask = cvCreateImage(bufsize, IPL_DEPTH_8U, 1 );
207  ossimDpt pt;
208  long offset = 0;
209  for (int y=0; y<bufsize.height; y++)
210  {
211  for (int x=0; x<=bufsize.width-1; x++)
212  {
213  if (imageChip->getPix(offset) != null_pixel)
214  mask->imageData[offset] = (unsigned char) 0xFF;
215  else
216  mask->imageData[offset] = (unsigned char) 0;
217  ++offset;
218  }
219  }
220  }
221
222  // Use CV to find features in the patch:
223  // Adjust the number of features to look for if we are doing adaptive correlation thresholding
224  // (ACT). This would be more appropriate to call "secondary feature consideration":
225 // IplImage* harris = cvCreateImage(cvGetSize(ipl_image), 32, 1 );
226 // cvCornerHarris(ipl_image, harris, 10, 5);
227 // cvNamedWindow("Harris", CV_WINDOW_AUTOSIZE);
228 // cvShowImage ("Harris", harris);
229 // cvWaitKey();
230
231  int num_pts = (int) config.getParameter("numFeaturesPerTile").asUint();
232  CvPoint2D32f* points = (CvPoint2D32f*)cvAlloc(num_pts*sizeof(CvPoint2D32f));
233  cvGoodFeaturesToTrack(ipl_image, 0, 0, points, &num_pts, quality, refPatchSize, mask,
234  averaging_block_size, use_harris, harris_k);
235
236  // Loop over all features found in this patch and assign a feature point at that view
237  // point. IMPORTANT NOTE: it is assumed that the ordering of the points[] array is by
238  // descending strength of feature.
239  unsigned int num_added = 0;
240  for(int i=0; i<num_pts; i++)
241  {
242  // Correct point for the view-space offset of the search patch since points are relative to
243  // patch upper left:
244  CvPoint pt=cvPointFrom32f(points[i]);
245  ossimDpt viewPt (pt.x, pt.y);
246  viewPt += tileUL;
247
248  // TODO REMOVE
249 // ossimDpt imagePt;
250 // m_generator->getRefIVT()->viewToImage(viewPt, imagePt);
251 // CINFO<<" Feature REF image point: "<<imagePt<<endl;
252
253  // Good feature found, set the feature point's attributes and save to list:
254  feature_points.push_back(viewPt);
255  ++num_added;
256  }
257
258  if (AtpConfig::instance().diagnosticLevel(2))
259  {
260  if (num_added)
261  CINFO<<MODULE<<"Number of features found in search patch: "<<num_added<<endl;
262  else
263  CINFO<<MODULE<<"No features found."<<endl;
264  }
265
266  // Cleanup mem use:
267 // cvReleaseImage(&harris);
268  cvReleaseImage(&mask);
269  cvReleaseImage(&ipl_image);
270  cvFree((void**)&points);
271
272  return;
273 }
ossim_uint32 x
ossim_uint32 y
IplImage * convertToIpl(const ossimImageData *data)
Converts an ossimImageData pointer to an IplImage for use in OpenCV.
Definition: AtpOpenCV.cpp:25
#define CFATAL
#define CWARN
#define CINFO
◆ getNominalCmpPatchSize()
unsigned int ATP::ossimCorrelationSource::getNominalCmpPatchSize ( ) const
inline
Definition at line 35 of file ossimCorrelationSource.h.
◆ getTile()
ossimRefPtr< ossimImageData > ATP::ossimCorrelationSource::getTile ( const ossimIrect origin,
ossim_uint32  rLevel = 0
virtual
It is not clear what the output tile needs to be, since the product of this filter is the list of tiepoints (available through the getTiePoints() method). Recommend simply passing through the corresponding REF image tile.
Implements ATP::AtpTileSource.
Definition at line 79 of file ossimCorrelationSource.cpp.
References ATP::AtpTileSource::allocate(), ossim::JsonParam::asBool(), ossim::JsonParam::asUint(), CINFO, correlate(), ossim::JsonConfig::diagnosticLevel(), ATP::AtpTileSource::filterPoints(), findFeatures(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimConnectableObject::getNumberOfInputs(), ossim::JsonConfig::getParameter(), ATP::AtpConfig::instance(), ossimIrect::lr(), ATP::AtpTileSource::m_generator, ATP::AtpTileSource::m_tiePoints, ATP::AtpTileSource::m_tile, OSSIM_EMPTY, ossim::JsonConfig::paramExists(), ossimImageData::setImageRectangle(), ossimIrect::ul(), ossimIpt::x, x, ossimIpt::y, and y.
81 {
82  static const char* MODULE = "ossimCorrelationSource::getTile() ";
83  AtpConfig& config = AtpConfig::instance();
84  if (config.diagnosticLevel(2))
85  CINFO<<"\n\nossimCorrelationSource::getTile() -- tileRect UL: "<<tileRect.ul()<<endl;
86  m_tiePoints.clear();
87
88  if(getNumberOfInputs() < 2)
89  return 0;
90  if (!m_tile)
91  allocate();
92
93  // The tile rect (in view space) is referenced by the tiepoint filtering code:
94  m_tile->setImageRectangle(tileRect);
95
96  string sid(""); // Leave blank to have it auto-assigned by AutoTiePoint constructor
97  if (!config.getParameter("useRasterMode").asBool())
98  {
99  m_tile = m_generator->getRefChain()->getTile(tileRect, resLevel);
101  return m_tile;
102
103  // Need to search for features in the REF tile first, then consider only those locations
104  // for correlating:
105  vector<ossimIpt> featurePoints;
107
108  findFeatures(tileptr.get(), featurePoints);
109  if (featurePoints.empty())
110  return m_tile;
111
112  // Loop over features to perform correlations:
113  for (size_t i=0; i<featurePoints.size(); ++i)
114  {
115  shared_ptr<ATP::AutoTiePoint> atp (new ATP::AutoTiePoint(m_generator, sid));
116  atp->setRefViewPt(featurePoints[i]);
117
118  // Trick here to keep using the same ID until a good correlation is found:
119  if (!correlate(atp))
120  {
121  sid = atp->getTiePointId();
122  //atp->setTiePointId("NP");
123  //m_tiePoints.push_back(atp);
124  }
125  else
126  {
127  m_tiePoints.push_back(atp);
128  sid.clear();
129  }
130  }
131  if (config.diagnosticLevel(2))
132  CINFO<<MODULE<<"Before filtering: num matches in tile = "<<m_tiePoints.size()<<endl;
133  }
134  else // raster mode
135  {
136  // Scan raster-fashion along REF tile and correlate at intervals:
137  unsigned int num_attempts = 0;
138  int corrStepSize = 1;
139  if (config.paramExists("corrStepSize"))
140  corrStepSize = (int) config.getParameter("corrStepSize").asUint();
141  for (int y = tileRect.ul().y; y < tileRect.lr().y; y += corrStepSize)
142  {
143  for (int x = tileRect.ul().x; x < tileRect.lr().x; x += corrStepSize)
144  {
145  ++num_attempts;
146  shared_ptr<AutoTiePoint> atp (new AutoTiePoint(m_generator, sid));
147  atp->setRefViewPt(ossimDpt(x,y));
148
149  // Trick here to keep using the same ID until a good correlation is found:
150  if (!correlate(atp))
151  sid = atp->getTiePointId();
152  else
153  {
154  m_tiePoints.push_back(atp);
155  sid.clear();
156  }
157  }
158  }
159  if (config.diagnosticLevel(2))
160  CINFO<<MODULE<<"Tile match ratio: "<<m_tiePoints.size()<<" / "<<num_attempts<<endl;
161
162  }
163
164  filterPoints();
165
166  return m_tile;
167 }
ossim_uint32 x
Base class for all automatic tiepoints.
Definition: AutoTiePoint.h:30
ossim_uint32 y
ossimRefPtr< ossimImageData > m_tile
Definition: AtpTileSource.h:87
bool correlate(std::shared_ptr< AutoTiePoint > atp)
void findFeatures(const ossimImageData *data, std::vector< ossimIpt > &featurePts)
virtual ossim_uint32 getNumberOfInputs() const
Returns the number of input objects.
virtual void allocate()
#define CINFO
◆ initialize()
void ATP::ossimCorrelationSource::initialize ( )
virtual
Reimplemented from ATP::AtpTileSource.
Definition at line 43 of file ossimCorrelationSource.cpp.
References ossim::JsonParam::asUint(), ossimSensorModel::getNominalPosError(), ossim::JsonConfig::getParameter(), ATP::AtpTileSource::initialize(), ATP::AtpConfig::instance(), ATP::AtpTileSource::m_generator, m_nominalCmpPatchSize, ossimDpt::x, and ossimDpt::y.
Referenced by ossimCorrelationSource().
44 {
45  // The base class sets up the input (image-space) protion of the chain:
47
48  unsigned int refPatchSize = AtpConfig::instance().getParameter("corrWindowSize").asUint(); // min distance between points
49  m_nominalCmpPatchSize = DEFAULT_CMP_PATCH_SIZING_FACTOR*refPatchSize;
50  double total_error = 0;
51  auto refIVT = m_generator->getRefIVT();
52  auto cmpIVT = m_generator->getCmpIVT();
53  if (refIVT.valid() && cmpIVT.valid())
54  {
55  ossimDpt gsd = refIVT->getOutputMetersPerPixel();
56  double nominalGsd = (gsd.x + gsd.y)/2.0;
57
58  // Fetch the CE90 of both images to determine cmp image search patch size:
59  ossimSensorModel* ref_sm = dynamic_cast<ossimSensorModel*>(
60  refIVT->getImageGeometry()->getProjection());
61  ossimSensorModel* cmp_sm = dynamic_cast<ossimSensorModel*>(
62  cmpIVT->getImageGeometry()->getProjection());
63  if (ref_sm && cmp_sm)
64  {
65  double ref_ce = ref_sm->getNominalPosError();
66  double cmp_ce = cmp_sm->getNominalPosError();
67  total_error = ref_ce + cmp_ce; // meters -- being conservative here and not doing rss
68  double searchSizePixels = 2.0 * total_error / nominalGsd;
69  m_nominalCmpPatchSize = refPatchSize + searchSizePixels;
70  }
71  if (total_error == 0)
72  {
73  double searchSizePixels = 2.0*DEFAULT_NOMINAL_POSITION_ERROR/nominalGsd;
74  m_nominalCmpPatchSize = refPatchSize + searchSizePixels;
75  }
76  }
77 }
virtual const double & getNominalPosError() const
Returns the estimated Absolute horizontal position error (CE90) of the sensor model.
double y
Definition: ossimDpt.h:165
virtual void initialize()
double x
Definition: ossimDpt.h:164
◆ OpenCVCorrelation()
bool ATP::ossimCorrelationSource::OpenCVCorrelation ( std::shared_ptr< AutoTiePoint atp,
const ossimImageData refpatch,
const ossimImageData cmppatch
protected
Definition at line 407 of file ossimCorrelationSource.cpp.
References ossim::JsonParam::asFloat(), ossim::JsonParam::asUint(), ATP::convertToIpl32(), ATP::copyIpl32ToOid(), ossimImageDataFactory::create(), CWARN, ossim::JsonConfig::diagnosticLevel(), ossimRefPtr< T >::get(), ossimImageData::getImageRectangle(), ossim::JsonConfig::getParameter(), ossimImageData::getWidth(), ossimImageData::initialize(), ATP::AtpConfig::instance(), ossimImageDataFactory::instance(), OSSIM_UINT8, ossim::JsonConfig::paramExists(), ossimIrect::ul(), ossimImageData::write(), ossimIpt::x, and ossimIpt::y.
Referenced by correlate().
410 {
411  static const char* MODULE = "ossimCorrelationSource::OpenCVCorrelation() -- ";
412
413  int ref_patch_size = refpatch->getWidth();
414  int refPatchOffset = ref_patch_size / 2; // assumes square patch
415
416  IplImage *cmpimage, *refimage, *result;
417  int method;
418
419  // Convert image data to CV IPL form:
420  cmpimage = convertToIpl32(cmppatch);
421  refimage = convertToIpl32(refpatch);
422  if (!cmpimage || !refimage)
423  {
424  CWARN << MODULE << "Error encountered creating IPL image tiles. Aborting..." << endl;
425  return false;
426  }
427
428  // Assign the peak threshold depending on whether it is same collect or diff collect:
429  AtpConfig& config = AtpConfig::instance();
430  double peak_threshold = config.getParameter("peakThreshold").asFloat();
431
432  CvSize resdim;
433  resdim.height = cmpimage->height - refimage->height + 1;
434  resdim.width = cmpimage->width - refimage->width + 1;
435  result = cvCreateImage(resdim, IPL_DEPTH_32F, 1);
436  if (!result)
437  {
438  CWARN << MODULE << "Error encountered creating IPL image tile (result). Aborting..." << endl;
439  return false;
440  }
441
442  // Do the actual correlation:
443  unsigned int corrMethod = config.getParameter("correlationMethod").asUint();
444  cvMatchTemplate(cmpimage, refimage, result, (int) corrMethod);
445
446  if (config.diagnosticLevel(5) )
447  {
448  //refpatch->write("ref.ras");
449  //cmppatch->write("cmp.ras");
450  ossimRefPtr<ossimImageData> resultPatch =
451  ossimImageDataFactory::instance()->create(this, OSSIM_UINT8, 1, resdim.width, resdim.height);
452  resultPatch->initialize();
453  copyIpl32ToOid(result, resultPatch.get());
454  resultPatch->write("CORR.RAS");
455  }
456  ossimIpt cmpPeakLocV;
457  float corrCoef;
458
459  // Search through all the peaks and the tiepoint object will track which is best.
460  multimap<float /* corr_coef */, ossimIpt /* loc */, greater<float> > peaks_map;
461  ossimIpt cmpPatchLocV (cmppatch->getImageRectangle().ul());
462  for (int dy = 0; dy < result->height; dy++)
463  {
464  for (int dx = 0; dx < result->width; dx++)
465  {
466  // Fetch the pixel's corr coef and insert in map to order by strongest peak:
467  corrCoef = ((float*) (result->imageData + result->widthStep * dy))[dx];
468  if (corrCoef >= peak_threshold)
469  {
470  cmpPeakLocV.x = cmpPatchLocV.x + refPatchOffset + dx;
471  cmpPeakLocV.y = cmpPatchLocV.y + refPatchOffset + dy;
472  peaks_map.insert(pair<float, ossimIpt>(corrCoef, cmpPeakLocV));
473  }
474  }
475  }
476
477  if (peaks_map.size() > 0)
478  {
479  // The peaks are in order by greatest correlation value. Send the best to the CTP:
480  multimap<float, ossimIpt, greater<float> >::iterator peak = peaks_map.begin();
481  unsigned int maxNumPeaks = AtpConfig::instance().getParameter("maxNumMatchesPerFeature").asUint();
482  if (config.paramExists("maxNumPeaksPerFeature")) // support legacy keywords
483  maxNumPeaks = config.getParameter("maxNumPeaksPerFeature").asUint();
484  for (unsigned int i = 0; (i < maxNumPeaks) && (peak != peaks_map.end()); i++)
485  {
486  cmpPeakLocV = peak->second;
487  corrCoef = peak->first;
488  atp->addViewMatch(cmpPeakLocV, corrCoef);
489  peak++;
490  }
491  }
492
493  cvReleaseImage(&result);
494  cvReleaseImage(&refimage);
495  cvReleaseImage(&cmpimage);
496
497  return true;
498 }
IplImage * convertToIpl32(const ossimImageData *data)
Definition: AtpOpenCV.cpp:77
const ossimIpt & ul() const
Definition: ossimIrect.h:274
Initialize the data buffer.
void copyIpl32ToOid(IplImage *ipl, ossimImageData *oid)
Definition: AtpOpenCV.cpp:90
virtual bool write(const ossimFilename &f) const
Writes tile to stream.
virtual ossimIrect getImageRectangle() const
ossim_int32 y
Definition: ossimIpt.h:142
ossim_int32 x
Definition: ossimIpt.h:141
8 bit unsigned integer
#define CWARN
Member Data Documentation
◆ m_nominalCmpPatchSize
unsigned int ATP::ossimCorrelationSource::m_nominalCmpPatchSize
protected
Definition at line 47 of file ossimCorrelationSource.h.
Referenced by correlate(), and initialize().
