Public Member Functions | Protected Member Functions | Private Member Functions | Private Attributes | List of all members
ossimEnviHeaderFileWriter Class Reference
Class for writing a "ENVI" style header. More...
#include <ossimEnviHeaderFileWriter.h>
Inheritance diagram for ossimEnviHeaderFileWriter:
ossimMetadataFileWriter ossimConnectableObject ossimProcessInterface ossimConnectableObjectListener ossimObject ossimListenerManager ossimPropertyInterface ossimListener ossimReferenced
 ossimEnviHeaderFileWriter ()
 default constructor More...
 Initializes the state of the writer. More...
virtual void getMetadatatypeList (std::vector< ossimString > &metadatatypeList) const
 Satisfies pure virtual from ossimMetadataWriter base. More...
virtual bool hasMetadataType (const ossimString &metadataType) const
- Public Member Functions inherited from ossimMetadataFileWriter
 ossimMetadataFileWriter ()
virtual void initialize ()
virtual bool execute ()
virtual void setFilename (const ossimFilename &file)
const ossimFilenamegetFilename () const
virtual void setPixelType (ossimPixelType pixelType)
 Ossim uses a concept of "pixel is point" internally. More...
virtual ossimPixelType getPixelType () const
virtual void setAreaOfInterest (const ossimIrect &areaOfInterest)
 Sets the area of interest to write the meta data for. More...
virtual ossimIrect getAreaOfInterest () const
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
- Public Member Functions inherited from ossimProcessInterface
 ossimProcessInterface ()
virtual void abort ()
bool needsAborting () const
bool isAborted () const
bool isExecuting () const
void enableEvents ()
void disableEvents ()
 ProcessEvent. More...
virtual void refreshEvent (ossimRefreshEvent &)
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
virtual ~ossimEnviHeaderFileWriter ()
 virtual destructor More...
- Protected Member Functions inherited from ossimMetadataFileWriter
virtual ~ossimMetadataFileWriter ()
virtual ~ossimReferenced ()
virtual bool writeFile ()
 Write out the file. More...
Private Attributes
ossimEnviHeader theHdr
Additional Inherited Members
- Public Types inherited from ossimProcessInterface
enum  ossimProcessStatus {
- Protected Attributes inherited from ossimMetadataFileWriter
ossimFilename theFilename
ossimPixelType thePixelType
ossimIrect theAreaOfInterest
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
- Protected Attributes inherited from ossimProcessInterface
double thePercentComplete
ossimString theMessage
bool theEventFlag
bool theListenerEnableFlag
Detailed Description
Definition at line 29 of file ossimEnviHeaderFileWriter.h.
◆ ossimEnviHeaderFileWriter()
ossimEnviHeaderFileWriter::ossimEnviHeaderFileWriter ( )
default constructor
◆ ~ossimEnviHeaderFileWriter()
ossimEnviHeaderFileWriter::~ossimEnviHeaderFileWriter ( )
protectedvirtual
virtual destructor
Definition at line 39 of file ossimEnviHeaderFileWriter.cpp.
40 {
41 }
Member Function Documentation
◆ getMetadatatypeList()
void ossimEnviHeaderFileWriter::getMetadatatypeList ( std::vector< ossimString > &  metadatatypeList) const
virtual
Appends the writers image types to the "metadatatypeList".
Parameters
metadatatypeListstl::vector<ossimString> list to append to.
Note
Appends to the list, does not clear it first.
Implements ossimMetadataFileWriter.
Definition at line 91 of file ossimEnviHeaderFileWriter.cpp.
93 {
94  metadatatypeList.push_back(ossimString("envi_header"));
95 }
◆ hasMetadataType()
bool ossimEnviHeaderFileWriter::hasMetadataType ( const ossimString metadataType) const
virtual
Parameters
imageTypestring representing image type.
Returns
true if "metadataType" is supported by writer.
Definition at line 97 of file ossimEnviHeaderFileWriter.cpp.
99 {
100  return (metadataType == "envi_header");
101 }
◆ loadState()
bool ossimEnviHeaderFileWriter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Users should use this to set the envi header fields that are not taken from theInputConnection prior to calling execute.
Returns
true on success, false on failure.
Reimplemented from ossimMetadataFileWriter.
Definition at line 43 of file ossimEnviHeaderFileWriter.cpp.
References ossimMetadataFileWriter::loadState(), ossimEnviHeader::loadState(), and theHdr.
45 {
46  bool result = false;
47
48  if (ossimMetadataFileWriter::loadState(kwl, prefix))
49  {
50  result = theHdr.loadState(kwl, prefix);
51  }
52
53  return result;
54 }
Load state method:
bool loadState(const ossimKeywordlist &kwl, const char *prefix=0)
Method to the load (recreate) the state of the object from a keyword list.
◆ writeFile()
bool ossimEnviHeaderFileWriter::writeFile ( )
privatevirtual
Write out the file.
Returns
Definition at line 63 of file ossimEnviHeaderFileWriter.cpp.
References ossimMapProjectionInfo::getGeom(), ossimImageSource::getImageGeometry(), ossimImageSource::getNumberOfOutputBands(), ossimImageGeometry::getProjection(), ossimIrect::height(), PTR_CAST, ossimEnviHeader::setBands(), ossimEnviHeader::setLines(), ossimEnviHeader::setMapInfo(), ossimEnviHeader::setSamples(), ossimMetadataFileWriter::theAreaOfInterest, ossimMetadataFileWriter::theFilename, theHdr, ossimMetadataFileWriter::theInputConnection, ossimRefPtr< T >::valid(), ossimIrect::width(), and ossimEnviHeader::writeFile().
64 {
68
69  // Get the geometry from the input.
70  // Get the geometry from the input.
71  ossimMapProjection* mapProj = 0;
73  if ( inputGeom.valid() ) mapProj = PTR_CAST(ossimMapProjection, inputGeom->getProjection());
74  if (mapProj)
75  {
76  // Create the projection info.
79
80  // Set the tie points in the keyword list.
81  ossimKeywordlist kwl;
82  projectionInfo->getGeom(kwl);
83
84  // Pass it on to envi header to set the map info string from geometry.
85  theHdr.setMapInfo(kwl);
86  }
87
89 }
void setMapInfo(const ossimString &mapInfo)
Sets the envi map info string.
void setBands(ossim_uint32 bands)
Sets the number of bands.
bool valid() const
Definition: ossimRefPtr.h:75
ossim_uint32 height() const
Definition: ossimIrect.h:487
void setSamples(ossim_uint32 samples)
Sets the number of samples.
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
ossim_uint32 width() const
Definition: ossimIrect.h:500
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
void getGeom(ossimKeywordlist &kwl, const char *prefix=0) const
Adds tie point to keyword list.
bool writeFile(const ossimFilename &file)
Writes header to file in a standard envi format.
void setLines(ossim_uint32 lines)
Sets the number of lines.
Member Data Documentation
◆ theHdr
ossimEnviHeader ossimEnviHeaderFileWriter::theHdr
private
Definition at line 74 of file ossimEnviHeaderFileWriter.h.
Referenced by loadState(), and writeFile().
