class ossimHistogramMatchFilter More...
#include <ossimHistogramMatchFilter.h>
ossimHistogramMatchFilter () | |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
Calls the owned equalizers to create a match composite image. More... | |
virtual void | initialize () |
Initializes the input and target equalizer filters. More... | |
void | setInputHistogram (const ossimFilename &inputHistogram) |
void | setTargetHistogram (const ossimFilename &targetHistogram) |
virtual void | connectInputEvent (ossimConnectionEvent &event) |
virtual void | disconnectInputEvent (ossimConnectionEvent &event) |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
Returns a property given the name. More... | |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
Returns a list of proeprties. More... | |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
ossimImageSourceFilter (ossimObject *owner=NULL) | |
ossimImageSourceFilter (ossimImageSource *inputSource) | |
ossimImageSourceFilter (ossimObject *owner, ossimImageSource *inputSource) | |
virtual void | getOutputBandList (std::vector< ossim_uint32 > &bandList) const |
virtual ossim_uint32 | getNumberOfInputBands () const |
bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
required to be overriden by derived classes More... | |
virtual void | propertyEvent (ossimPropertyEvent &event) |
virtual void | refreshEvent (ossimRefreshEvent &event) |
ossimImageSource (ossimObject *owner=0) | |
ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimImageSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIpt &origin, ossim_uint32 resLevel=0) |
virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel=0) |
Method to get a tile. More... | |
virtual ossimObject * | getObject () |
For RTTI support. More... | |
virtual const ossimObject * | getObject () const |
virtual void | getDecimationFactor (ossim_uint32 resLevel, ossimDpt &result) const |
Will return the decimation factor for the given resolution level. More... | |
virtual void | getDecimationFactors (std::vector< ossimDpt > &decimations) const |
Will return an array of all decimations for each resolution level. More... | |
virtual ossim_uint32 | getNumberOfDecimationLevels () const |
Will return the number of resolution levels. More... | |
virtual ossim_uint32 | getNumberOfOutputBands () const |
Returns the number of bands in a tile returned from this TileSource. More... | |
virtual ossimScalarType | getOutputScalarType () const |
This will be used to query the output pixel type of the tile source. More... | |
virtual ossim_uint32 | getTileWidth () const |
Returns the default processing tile width. More... | |
virtual ossim_uint32 | getTileHeight () const |
Returns the default processing tile height. More... | |
virtual double | getNullPixelValue (ossim_uint32 band=0) const |
Each band has a null pixel associated with it. More... | |
virtual double | getMinPixelValue (ossim_uint32 band=0) const |
Returns the min pixel of the band. More... | |
virtual double | getMaxPixelValue (ossim_uint32 band=0) const |
Returns the max pixel of the band. More... | |
virtual ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
This will return the bounding rect of the source. More... | |
virtual void | getBoundingRect (ossimIrect &rect, ossim_uint32 resLevel=0) const |
Gets the bounding rectangle of the source. More... | |
virtual void | getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
ordering specifies how the vertices should be arranged. More... | |
virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
Returns the image geometry object associated with this tile source or NULL if not defined. More... | |
virtual void | setImageGeometry (const ossimImageGeometry *geom) |
Default implementation sets geometry of the first input to the geometry specified. More... | |
virtual void | saveImageGeometry () const |
Default method to call input's saveImageGeometry. More... | |
virtual void | saveImageGeometry (const ossimFilename &geometry_file) const |
virtual bool | isIndexedData () const |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
ossimConnectableObjectListener () | |
virtual | ~ossimConnectableObjectListener () |
virtual void | processEvent (ossimEvent &event) |
ProcessEvent. More... | |
virtual void | objectDestructingEvent (ossimObjectDestructingEvent &) |
virtual void | connectionEvent (ossimConnectionEvent &) |
virtual void | disconnectOutputEvent (ossimConnectionEvent &) |
virtual void | connectOutputEvent (ossimConnectionEvent &) |
virtual void | addObjectEvent (ossimContainerEvent &) |
virtual void | removeObjectEvent (ossimContainerEvent &) |
virtual void | containerEvent (ossimContainerEvent &) |
ossimListener () | |
virtual | ~ossimListener () |
void | enableListener () |
void | disableListener () |
void | setListenerEnableFlag (bool flag) |
bool | isListenerEnabled () const |
bool | getListenerEnableFlag () const |
void | autoLoadInputHistogram () |
Will search the input chain and get the histogram_filename property of the image handler. More... | |
virtual | ~ossimImageSourceFilter () |
ossimImageSource (const ossimImageSource &rhs) | |
const ossimImageSource & | operator= (const ossimImageSource &) |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
This class owns two ossimHistogramEqualization filters and will chain them together. It will make the left most filter the forward transform by transforming the input input to an equalized space defined by the input histogram. The right filter is the target histogram to match. It will take the equalized space and invert it to a target histogram.
There is an auto load input histogram flag that if set true will always try to search for an input handler and get the input handlers histogram file. and set it. If this is enabled then the only other field that is required is to specify the target histogram. If a target histogram is not specified then the output
will be an equalized image without the target applied.
Definition at line 24 of file ossimHistogramMatchFilter.h.
ossimHistogramMatchFilter::ossimHistogramMatchFilter | ( | ) |
Definition at line 9 of file ossimHistogramMatchFilter.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimRefPtr< T >::get(), ossimHistogramEqualization::setInverseFlag(), theInputHistogramEqualizer, and theTargetHistogramEqualizer.
protected |
Once retrieved it calls the setInputHistogram with the found histogram filename. It does nothing if the histogram filename does not exist
Definition at line 235 of file ossimHistogramMatchFilter.cpp.
References ossimConnectableObject::accept(), ossimFilename::exists(), ossimCollectionVisitor::getObjectAs(), ossimCollectionVisitor::getObjects(), ossimImageHandler::getProperty(), setInputHistogram(), ossimRefPtr< T >::valid(), ossimProperty::valueToString(), ossimVisitor::VISIT_CHILDREN, and ossimVisitor::VISIT_INPUTS.
Referenced by getTile(), and initialize().
event | Connection event |
Definition at line 56 of file ossimHistogramMatchFilter.cpp.
References ossimImageSourceFilter::connectInputEvent(), ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnectMyInput(), ossimConnectableObject::getInput(), ossimHistogramEqualization::initialize(), theInputHistogramEqualizer, and theTargetHistogramEqualizer.
Definition at line 73 of file ossimHistogramMatchFilter.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimImageSourceFilter::disconnectInputEvent(), ossimConnectableObject::disconnectMyInput(), ossimConnectableObject::getInput(), ossimHistogramEqualization::initialize(), theInputHistogramEqualizer, and theTargetHistogramEqualizer.
Valid names are: auto_load_input_histogram_flag input_histogram_filename output_histogram_filename
Example:
ossimRefPtr<ossimProperty> prop = obj->getProperty("auto_load_input_histogram_flag");
Definition at line 132 of file ossimHistogramMatchFilter.cpp.
References ossimImageSourceFilter::getProperty(), ossimFilenameProperty::ossimFilenamePropertyIoType_INPUT, ossimProperty::setCacheRefreshBit(), ossimFilenameProperty::setIoType(), theAutoLoadInputHistogramFlag, theInputHistogramFilename, and theTargetHistogramFilename.
Valid properties are:
auto_load_input_histogram_flag Is a boolean property and specifes whether or not the input histogram will be auto searched from the conected input source chain.
input_histogram_filename Holds the input histogram filename
output_histogram_filename holds the output histogram filename
Definition at line 163 of file ossimHistogramMatchFilter.cpp.
References ossimImageSourceFilter::getPropertyNames().
Definition at line 21 of file ossimHistogramMatchFilter.cpp.
References autoLoadInputHistogram(), ossimHistogramEqualization::getTile(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), theAutoLoadInputHistogramFlag, ossimImageSourceFilter::theInputConnection, theInputHistogramFilename, and theTargetHistogramEqualizer.
Definition at line 90 of file ossimHistogramMatchFilter.cpp.
References autoLoadInputHistogram(), ossimHistogramEqualization::initialize(), ossimImageSourceFilter::initialize(), theAutoLoadInputHistogramFlag, theInputHistogramEqualizer, theInputHistogramFilename, and theTargetHistogramEqualizer.
Referenced by setProperty().
Keywords to search and load:
kwl | Holds the keywords for this object to load prefixed by the passed in prefix parameter |
prefix | Is the prefix value prepended to all keywords |
Definition at line 172 of file ossimHistogramMatchFilter.cpp.
References ossimKeywordlist::find(), ossimImageSourceFilter::loadState(), setInputHistogram(), setTargetHistogram(), theAutoLoadInputHistogramFlag, and ossimString::toBool().
Keywords:
kwl | This object will store the keywords in kwl and prefix by the parameter prefix |
Definition at line 205 of file ossimHistogramMatchFilter.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimImageSourceFilter::saveState(), theAutoLoadInputHistogramFlag, theInputHistogramFilename, and theTargetHistogramFilename.
void ossimHistogramMatchFilter::setInputHistogram | ( | const ossimFilename & | inputHistogram | ) |
inputHistogram | Input histogram to load |
Definition at line 42 of file ossimHistogramMatchFilter.cpp.
References ossimHistogramEqualization::initialize(), ossimHistogramEqualization::setHistogram(), theInputHistogramEqualizer, and theInputHistogramFilename.
Referenced by autoLoadInputHistogram(), loadState(), and setProperty().
property | Is the property to set. |
Definition at line 105 of file ossimHistogramMatchFilter.cpp.
References initialize(), setInputHistogram(), ossimImageSourceFilter::setProperty(), setTargetHistogram(), theAutoLoadInputHistogramFlag, ossimRefPtr< T >::valid(), and ossimProperty::valueToString().
void ossimHistogramMatchFilter::setTargetHistogram | ( | const ossimFilename & | targetHistogram | ) |
targetHistogram | Target histogram to match |
Definition at line 49 of file ossimHistogramMatchFilter.cpp.
References ossimHistogramEqualization::initialize(), ossimHistogramEqualization::setHistogram(), theTargetHistogramEqualizer, and theTargetHistogramFilename.
Referenced by loadState(), and setProperty().
protected |
Definition at line 170 of file ossimHistogramMatchFilter.h.
Referenced by getProperty(), getTile(), initialize(), loadState(), saveState(), and setProperty().
protected |
Definition at line 166 of file ossimHistogramMatchFilter.h.
Referenced by connectInputEvent(), disconnectInputEvent(), initialize(), ossimHistogramMatchFilter(), and setInputHistogram().
protected |
Definition at line 168 of file ossimHistogramMatchFilter.h.
Referenced by getProperty(), getTile(), initialize(), saveState(), and setInputHistogram().
protected |
Definition at line 167 of file ossimHistogramMatchFilter.h.
Referenced by connectInputEvent(), disconnectInputEvent(), getTile(), initialize(), ossimHistogramMatchFilter(), and setTargetHistogram().
protected |
Definition at line 169 of file ossimHistogramMatchFilter.h.
Referenced by getProperty(), saveState(), and setTargetHistogram().
