Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ossimGdalFactory Class Reference
#include <ossimGdalFactory.h>
Inheritance diagram for ossimGdalFactory:
ossimImageHandlerFactoryBase ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimGdalFactory ()
virtual ossimImageHandleropen (const ossimFilename &fileName, bool openOverview=true) const
 open that takes a filename. More...
virtual ossimImageHandleropen (const ossimKeywordlist &kwl, const char *prefix=0) const
virtual ossimRefPtr< ossimImageHandleropenOverview (const ossimFilename &file) const
 Open overview that takes a file name. More...
virtual ossimObjectcreateObject (const ossimString &typeName) const
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
virtual void getSupportedExtensions (ossimImageHandlerFactoryBase::UniqueStringList &extensionList) const
virtual void getImageHandlersBySuffix (ossimImageHandlerFactoryBase::ImageHandlerList &result, const ossimString &ext) const
virtual void getImageHandlersByMimeType (ossimImageHandlerFactoryBase::ImageHandlerList &result, const ossimString &mimeType) const
- Public Member Functions inherited from ossimImageHandlerFactoryBase
virtual ossimRefPtr< ossimImageHandleropen (std::shared_ptr< ossim::istream > &str, const std::string &connectionString, bool openOverview=true) const
 Open method that takes a stream. More...
virtual ossimRefPtr< ossimImageHandleropen (std::shared_ptr< ossim::ImageHandlerState > state) const
virtual ossimRefPtr< ossimImageHandleropenOverview (std::shared_ptr< ossim::istream > &str, const ossimString &connectionString) const
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimGdalFactoryinstance ()
 ossimGdalFactory ()
 ossimGdalFactory (const ossimGdalFactory &)
void operator= (const ossimGdalFactory &)
virtual ~ossimReferenced ()
static ossimGdalFactorytheInstance = 0
Additional Inherited Members
- Public Types inherited from ossimImageHandlerFactoryBase
typedef UniqueList< ossimStringUniqueStringList
typedef std::vector< ossimRefPtr< ossimImageHandler > > ImageHandlerList
Detailed Description
Definition at line 25 of file ossimGdalFactory.h.
◆ ~ossimGdalFactory()
ossimGdalFactory::~ossimGdalFactory ( )
virtual
Definition at line 32 of file ossimGdalFactory.cpp.
References theInstance.
33 {
35 }
static ossimGdalFactory * theInstance
◆ ossimGdalFactory() [1/2]
ossimGdalFactory::ossimGdalFactory ( )
inlineprotected
Definition at line 74 of file ossimGdalFactory.h.
Referenced by instance().
74 {}
◆ ossimGdalFactory() [2/2]
ossimGdalFactory::ossimGdalFactory ( const ossimGdalFactory )
inlineprotected
Definition at line 75 of file ossimGdalFactory.h.
75 {}
Member Function Documentation
◆ createObject() [1/2]
ossimObject * ossimGdalFactory::createObject ( const ossimString typeName) const
virtual
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 218 of file ossimGdalFactory.cpp.
References STATIC_TYPE_NAME.
Referenced by createObject().
219 {
220  if(STATIC_TYPE_NAME(ossimHdfReader) == typeName)
221  {
222  return new ossimHdfReader();
223  }
224  if(STATIC_TYPE_NAME(ossimGdalTileSource) == typeName)
225  {
226  return new ossimGdalTileSource();
227  }
229  {
230  return new ossimOgrGdalTileSource();
231  }
232
233  return (ossimObject*)0;
234 }
#define STATIC_TYPE_NAME(T)
Definition: ossimRtti.h:325
◆ createObject() [2/2]
ossimObject * ossimGdalFactory::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Creates and object given a keyword list.
Definition at line 236 of file ossimGdalFactory.cpp.
References createObject(), ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimObject::loadState(), open(), ossimRefPtr< T >::release(), STATIC_TYPE_NAME, ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
238 {
240  const char* type = kwl.find(prefix, ossimKeywordNames::TYPE_KW);
241
242  if(type)
243  {
244  if (ossimString(type).trim() == STATIC_TYPE_NAME(ossimImageHandler))
245  {
246  const char* lookup = kwl.find(prefix, ossimKeywordNames::FILENAME_KW);
247  if (lookup)
248  {
249  // Call the open that takes a filename...
250  result = this->open(kwl, prefix);//ossimFilename(lookup));
251  }
252  }
253  else
254  {
255  result = createObject(ossimString(type));
256  if(result.valid())
257  {
258  result->loadState(kwl, prefix);
259  }
260  }
261  }
262
263  return result.release();
264 }
virtual ossimObject * createObject(const ossimString &typeName) const
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossimImageHandler * open(const ossimFilename &fileName, bool openOverview=true) const
static const char * TYPE_KW
T * release()
Definition: ossimRefPtr.h:93
This class defines an abstract Handler which all image handlers(loaders) should derive from...
static const char * FILENAME_KW
◆ getImageHandlersByMimeType()
void ossimGdalFactory::getImageHandlersByMimeType ( ossimImageHandlerFactoryBase::ImageHandlerList result,
const ossimString mimeType
) const
virtual
Reimplemented from ossimImageHandlerFactoryBase.
Definition at line 332 of file ossimGdalFactory.cpp.
333 {
334  int driverCount = GDALGetDriverCount();
335  int idx = 0;
336
337  for(idx = 0; idx < driverCount; ++idx)
338  {
339  GDALDriverH driver = GDALGetDriver(idx);
340
341  if(driver)
342  {
343  const char* metaData = GDALGetMetadataItem(driver, GDAL_DMD_MIMETYPE, 0);
344  int nMetaData = metaData ? strlen(metaData) : 0;
345  if(metaData && nMetaData>0 )
346  {
347  if(ossimString(metaData) == mimeType)
348  {
349  result.push_back(new ossimGdalTileSource());
350  return;
351  }
352  }
353  }
354  }
355 }
◆ getImageHandlersBySuffix()
void ossimGdalFactory::getImageHandlersBySuffix ( ossimImageHandlerFactoryBase::ImageHandlerList result,
const ossimString ext
) const
virtual
Definition at line 310 of file ossimGdalFactory.cpp.
References ossimString::downcase(), ossimImageHandlerFactoryBase::UniqueList< T >::getList(), getSupportedExtensions(), and ossimString::push_back().
312 {
313  if ( ext == "shp" )
314  {
315  result.push_back(new ossimOgrGdalTileSource);
316  }
317  else
318  {
320  getSupportedExtensions(extList);
321
322  ossimString testExt = ext.downcase();
323
324  if(std::find(extList.getList().begin(),
325  extList.getList().end(), testExt) != extList.getList().end())
326  {
327  result.push_back(new ossimGdalTileSource);
328  }
329  }
330 }
virtual void getSupportedExtensions(ossimImageHandlerFactoryBase::UniqueStringList &extensionList) const
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
◆ getSupportedExtensions()
void ossimGdalFactory::getSupportedExtensions ( ossimImageHandlerFactoryBase::UniqueStringList extensionList) const
virtual
Implements ossimImageHandlerFactoryBase.
Definition at line 273 of file ossimGdalFactory.cpp.
References ossimImageHandlerFactoryBase::UniqueList< T >::push_back(), and ossimString::split().
Referenced by getImageHandlersBySuffix().
274 {
275  // ossimOgrGdalTileSource - shape file reader:
276  extensionList.push_back( ossimString("shp") );
277
278  int driverCount = GDALGetDriverCount();
279  int idx = 0;
280
281  for(idx = 0; idx < driverCount; ++idx)
282  {
283  GDALDriverH driver = GDALGetDriver(idx);
284
285  if(driver)
286  {
287  const char* metaData = GDALGetMetadataItem(driver, GDAL_DMD_EXTENSION, 0);
288  int nMetaData = metaData ? strlen(metaData) : 0;
289  if(metaData && nMetaData>0 )
290  {
291  std::vector<ossimString> splitArray;
292  ossimString(metaData).split(splitArray, " /");
293
294  ossim_uint32 idxExtension = 0;
295
296  for(idxExtension = 0; idxExtension < splitArray.size(); ++idxExtension)
297  {
298  extensionList.push_back(splitArray[idxExtension].downcase());
299  }
300  }
301  }
302  }
303
304  if(GDALGetDriverByName("AAIGrid"))
305  {
306  extensionList.push_back("adf");
307  }
308 }
unsigned int ossim_uint32
◆ getTypeNameList()
void ossimGdalFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 266 of file ossimGdalFactory.cpp.
267 {
268  typeList.push_back(STATIC_TYPE_NAME(ossimHdfReader));
269  typeList.push_back(STATIC_TYPE_NAME(ossimGdalTileSource));
270  typeList.push_back(STATIC_TYPE_NAME(ossimOgrGdalTileSource));
271 }
◆ instance()
ossimGdalFactory * ossimGdalFactory::instance ( )
static
Definition at line 38 of file ossimGdalFactory.cpp.
References ossimGdalFactory(), and theInstance.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
39 {
40  if(!theInstance)
41  {
43  CPLSetErrorHandler((CPLErrorHandler)CPLQuietErrorHandler);
44  GDALAllRegister();
45  OGRRegisterAll();
46  }
47
48  // lets turn off gdal error reporting
49  //
50 // GDALSetCacheMax(1024*1024*20);
51 // GDALSetCacheMax(0);
52
53  return theInstance;
54 }
◆ open() [1/2]
ossimImageHandler * ossimGdalFactory::open ( const ossimFilename fileName,
bool  openOverview = true
) const
virtual
Parameters
fileNameFile to open.
trySuffixFirstIf true calls code to try to open by suffix first, then goes through the list of available handlers. default=true.
openOverviewIf true image handler will attempt to open overview. default = true
Returns
Pointer to image handler or null if cannot open.
Definition at line 56 of file ossimGdalFactory.cpp.
References ossimString::downcase(), and ossimFilename::ext().
58 {
59  // For GDAL we can't check for file exists since they support encoded opens for
60  // subdatasets
61  //
62
63  if(fileName.ext().downcase() == "nui") return 0;
64  if(traceDebug())
65  {
67  << "ossimGdalFactory::open(filename) DEBUG: entered..." << std::endl;
68  }
69
71
72  //try hdf reader first
73  if (traceDebug())
74  {
76  << "ossimGdalFactory::open(filename) DEBUG:"
77  << "\ntrying ossimHdfReader"
78  << std::endl;
79  }
80  result = new ossimHdfReader;
82  if(result->open(fileName))
83  {
84  return result.release();
85  }
86
87  if (traceDebug())
88  {
90  << "ossimGdalFactory::open(filename) DEBUG:"
91  << "\ntrying ossimGdalTileSource"
92  << std::endl;
93  }
94
95  result = new ossimGdalTileSource;
97  if(result->open(fileName))
98  {
99  return result.release();
100  }
101
102  if (traceDebug())
103  {
105  << "ossimGdalFactory::open(filename) DEBUG:"
106  << "\ntrying ossimOgrVectorTileSource\n";
107  }
108
109  // No need to set overview flag.
110  result = new ossimOgrVectorTileSource;
111  if(result->open(fileName))
112  {
113  return result.release();
114  }
115
116  // we will have vector datasets only open if file exists.
117  if(!fileName.exists() ||
118  fileName.before(":", 3).upcase() == "SDE" ||
119  fileName.before(":", 4).upcase() == "GLTP" ||
120  fileName.ext().downcase() == "mdb")
121  {
122  result = 0;
123  return result.release();
124  }
125
126  // No need to set overview flag.
127  if (traceDebug())
128  {
130  << "ossimGdalFactory::open(filename) DEBUG:"
131  << "\ntrying ossimOgrGdalTileSource\n";
132  }
133
134  result = new ossimOgrGdalTileSource;
135  if(result->open(fileName))
136  {
137  return result.release();
138  }
139  result = 0;
140  return result.release();
141  if(traceDebug())
142  {
144  << "ossimGdalFactory::open(filename) DEBUG: leaving..."
145  << std::endl;
146  }
147
148  return (ossimImageHandler*)NULL;
149 }
virtual bool open()=0
Pure virtual open.
void setOpenOverviewFlag(bool flag)
Sets theOpenOverviewFlag.
ossimString before(const ossimString &str, std::string::size_type pos=0) const
METHOD: before(str, pos) Returns string beginning at pos and ending one before the token str If strin...
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
bool exists() const
T * release()
ossimString ext() const
virtual ossimRefPtr< ossimImageHandler > openOverview(const ossimFilename &file) const
◆ open() [2/2]
ossimImageHandler * ossimGdalFactory::open ( const ossimKeywordlist kwl,
) const
virtual
Definition at line 151 of file ossimGdalFactory.cpp.
153 {
155
156  if(traceDebug())
157  {
158  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimGdalFactory::open(kwl, prefix) DEBUG: entered..." << std::endl;
159  }
160  if(traceDebug())
161  {
162  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimGdalFactory::open(kwl, prefix) DEBUG: trying ossimHdfReader" << std::endl;
163  }
164  result = new ossimHdfReader;
165  if(result->loadState(kwl, prefix))
166  {
167  return result.release();
168  }
169  result = 0;
170
171  if(traceDebug())
172  {
173  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimGdalFactory::open(kwl, prefix) DEBUG: trying ossimGdalTileSource" << std::endl;
174  }
175  result = new ossimGdalTileSource;
176  if(result->loadState(kwl, prefix))
177  {
178  return result.release();
179  }
180  result = 0;
181  if(traceDebug())
182  {
183  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimGdalFactory::open(kwl, prefix) DEBUG: trying ossimOgrGdalTileSource" << std::endl;
184  }
185
186  result = new ossimOgrGdalTileSource;
187  if(result->loadState(kwl, prefix))
188  {
189  return result.release();
190  }
191  result = 0;
192  if(traceDebug())
193  {
194  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimGdalFactory::open(kwl, prefix) DEBUG: leaving..." << std::endl;
195  }
196
197  return result.release();
198 }
T * release()
◆ openOverview()
ossimRefPtr< ossimImageHandler > ossimGdalFactory::openOverview ( const ossimFilename file) const
virtual
Parameters
fileFile to open.
Returns
ossimRefPtr to image handler on success or null on failure.
Definition at line 200 of file ossimGdalFactory.cpp.
References ossimImageHandler::open(), ossimImageHandler::setOpenOverviewFlag(), and ossimString::size().
202 {
204  if ( file.size() )
205  {
206  result = new ossimGdalTileSource;
207
208  result->setOpenOverviewFlag( false ); // Always false.
209
210  if ( result->open( file ) == false )
211  {
212  result = 0;
213  }
214  }
215  return result;
216 }
Pure virtual open.
std::string::size_type size() const
Definition: ossimString.h:405
◆ operator=()
void ossimGdalFactory::operator= ( const ossimGdalFactory )
inlineprotected
Definition at line 76 of file ossimGdalFactory.h.
76 {}
Member Data Documentation
◆ theInstance
ossimGdalFactory * ossimGdalFactory::theInstance = 0
staticprotected
Definition at line 78 of file ossimGdalFactory.h.
Referenced by instance(), and ~ossimGdalFactory().
