Public Member Functions | Protected Member Functions | List of all members
ossimOpjNitfReader Class Reference
#include <ossimOpjNitfReader.h>
Inheritance diagram for ossimOpjNitfReader:
ossimNitfTileSource ossimImageHandler ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
 ossimOpjNitfReader ()
 default construtor More...
virtual ~ossimOpjNitfReader ()
 virtural destructor More...
- Public Member Functions inherited from ossimNitfTileSource
 ossimNitfTileSource ()
virtual bool open ()
 Returns true if the image_file can be opened and is a valid nitf file. More...
bool open (std::shared_ptr< ossim::istream > &str, const std::string &connectionString)
 This open takes a stream and stores/captures the shared pointer on success. More...
virtual void close ()
 Closes file and destroys all memory allocated. More...
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual ossim_uint32 getNumberOfLines (ossim_uint32 resLevel=0) const
 Returns the number of lines in the image. More...
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 resLevel=0) const
 Returns the number of samples in the image. More...
 Returns the output pixel type of the tile source. More...
 Returns the width of the output tile. More...
 Returns the height of the output tile. More...
virtual bool isOpen () const
ossim_uint32 getNumberOfEntries () const
ossimString getSecurityClassification () const
bool getCacheEnabledFlag () const
void setCacheEnabledFlag (bool flag)
const ossimNitfFileHeadergetFileHeader () const
const ossimNitfImageHeadergetCurrentImageHeader () const
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual void initialize ()
virtual bool openOverview ()
virtual void closeOverview ()
 Opens the image file. More...
 Sets the filename. More...
 Returns the filename. More...
virtual bool isValidRLevel (ossim_uint32 resLevel) const
 Connection rule. More...
virtual bool hasLut () const
virtual void loadMetaData ()
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
virtual bool canUncompress (const ossimNitfImageHeader *hdr) const
virtual void initializeReadMode ()
 Initializes the data member "theReadMode" from the current entry. More...
virtual void initializeCompressedBuf ()
 Initializes the data member theCompressedBuf. More...
virtual bool scanForJpegBlockOffsets ()
 scans the file storing in offsets in "theNitfBlockOffset" and block sizes in "theNitfBlockSize". More...
virtual bool uncompressJpegBlock (ossim_uint32 x, ossim_uint32 y)
 Uncompresses a jpeg block using the jpeg-6b library. More...
- Protected Member Functions inherited from ossimNitfTileSource
virtual ~ossimNitfTileSource ()
void setBoundingRectangle (const ossimIrect &imageRect)
 ossimNitfTileSource (const ossimNitfTileSource &obj)
 Copy constructor, disallow... More...
ossimNitfTileSourceoperator= (const ossimNitfTileSource &rhs)
 Operator=, disallow... More...
bool loadTile (const ossimIrect &clipRect)
 Returns true on success, false on error. More...
ossim_uint32 getBlockNumber (const ossimIpt &block_origin) const
void destroy ()
 Deletes all memory allocated by this object. More...
virtual bool parseFile ()
 Parses "theImageFile" and initializes all nitf headers. More...
virtual bool allocate ()
 Allocates everything for current entry. More...
virtual bool allocateBuffers ()
 Allocates buffers for current entry. More...
virtual void initializeScalarType ()
 Initializes the data member "theScalarType" from the current entry. More...
virtual void initializeSwapBytesFlag ()
 Initializes the data member "theSwapBytesFlag" from the current entry. More...
void initializeBandCount ()
 Initializes the data member "theNumberOfBands" from the current entry. More...
bool initializeBlockSize ()
 Initializes the data member "theBlockSize" from the current entry. More...
virtual bool initializeImageRect ()
 Initializes the data members "theImageRect" and "theBlockRect" from the current entry. More...
void initializeCacheSize ()
 Initializes the data member "theCacheSize". More...
virtual void initializeCacheTileInterLeaveType ()
 Initializes the data member "theCacheTileInterLeaveType". More...
void initializeCacheTile ()
 Initializes the cache tile size(width and height). More...
virtual void initializeOutputTile ()
 Initializes the output tile size(width and height). More...
void initializeLut ()
 Initializes "theLut" if applicable. More...
bool loadBlockFromCache (ossim_uint32 x, ossim_uint32 y, const ossimIrect &clipRect)
 Loads a block of data to theCacheTile. More...
virtual bool loadBlock (ossim_uint32 x, ossim_uint32 y)
bool getPosition (std::streamoff &position, ossim_uint32 x, ossim_uint32 y, ossim_uint32 band) const
ossim_uint32 getNumberOfBlocks () const
std::streampos getBandOffset () const
std::streampos getBlockOffset () const
void explodePackedBits (ossimRefPtr< ossimImageData > packedBuffer) const
void convertTransparentToNull (ossimRefPtr< ossimImageData > tile) const
ossim_uint32 getPartialReadSize (const ossimIpt &blockOrigin) const
bool isVqCompressed (const ossimString &compressionCode) const
void vqUncompressC4 (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source)
 Uncompresses Vector Quantization unmasked image data. More...
void vqUncompressM4 (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source)
 Uncompresses Vector Quantization masked image data. More...
void lutUncompress (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source)
bool loadJpegQuantizationTables (jpeg_decompress_struct &cinfo) const
 Loads one of the default tables based on COMRAT value. More...
bool loadJpegHuffmanTables (jpeg_decompress_struct &cinfo) const
 Loads default huffman tables. More...
virtual void completeOpen ()
virtual ~ossimReferenced ()
Additional Inherited Members
- Public Types inherited from ossimNitfTileSource
enum  ReadMode {
  READ_MODE_UNKNOWN = 0, READ_BIB_BLOCK = 1, READ_BIP_BLOCK = 2, READ_BIR_BLOCK = 3,
  READ_BSQ_BLOCK = 4, READ_BIB = 5, READ_BIP = 6, READ_BIR = 7,
  READ_JPEG_BLOCK = 8
- Protected Attributes inherited from ossimNitfTileSource
ossimRefPtr< ossimImageDatatheCacheTile
ossimRefPtr< ossimNitfFiletheNitfFile
std::vector< ossimRefPtr< ossimNitfImageHeader > > theNitfImageHeader
ReadMode theReadMode
ossimScalarType theScalarType
bool theSwapBytesFlag
ossim_uint32 theNumberOfInputBands
ossim_uint32 theNumberOfOutputBands
ossim_uint32 theBlockSizeInBytes
ossim_uint32 theReadBlockSizeInBytes
ossim_uint32 theNumberOfImages
ossim_uint32 theCurrentEntry
ossimIrect theImageRect
std::shared_ptr< ossim::istreamtheFileStr
std::vector< ossim_uint32theSelectorBandList
std::vector< ossim_uint32theOutputBandList
ossimIpt theCacheSize
ossimInterleaveType theCacheTileInterLeaveType
bool theCacheEnabledFlag
std::vector< ossim_uint32theEntryList
ossimAppFixedTileCache::ossimAppFixedCacheId theCacheId
bool thePackedBitsFlag
ossimIrect theBlockImageRect
std::vector< ossim_uint8theCompressedBuf
std::vector< std::streamoff > theNitfBlockOffset
std::vector< ossim_uint32theNitfBlockSize
bool m_jpegOffsetsDirty
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 20 of file ossimOpjNitfReader.h.
◆ ossimOpjNitfReader()
ossimOpjNitfReader::ossimOpjNitfReader ( )
default construtor
◆ ~ossimOpjNitfReader()
ossimOpjNitfReader::~ossimOpjNitfReader ( )
virtual
virtural destructor
Definition at line 46 of file ossimOpjNitfReader.cpp.
References ossimNitfTileSource::close().
47 {
48  close();
49 }
virtual void close()
Member Function Documentation
◆ canUncompress()
bool ossimOpjNitfReader::canUncompress ( const ossimNitfImageHeader hdr) const
protectedvirtual
Parameters
hdrPointer to image header.
Returns
true if reader can uncompress nitf.
Reimplemented from ossimNitfTileSource.
Definition at line 51 of file ossimOpjNitfReader.cpp.
References ossimNitfImageHeader::getCompressionCode().
53 {
54  if (!hdr)
55  {
56  return false;
57  }
58  if (hdr->getCompressionCode() == "C8") // jpeg
59  {
60  return true;
61  }
62  return false;
63 }
virtual ossimString getCompressionCode() const =0
◆ initializeCompressedBuf()
void ossimOpjNitfReader::initializeCompressedBuf ( )
protectedvirtual
Definition at line 82 of file ossimOpjNitfReader.cpp.
References size, ossimNitfTileSource::theCompressedBuf, and ossimNitfTileSource::theNitfBlockSize.
83 {
84  //---
85  // If all block sizes are the same initialize theCompressedBuf; else,
86  // we will allocate on each loadBlock.
87  //---
88  if (theNitfBlockSize.size() == 0)
89  {
90  theCompressedBuf.clear();
91  return;
92  }
93  std::vector<ossim_uint32>::const_iterator i = theNitfBlockSize.begin();
94  ossim_uint32 size = (*i);
95  ++i;
96  while (i != theNitfBlockSize.end())
97  {
98  if ((*i) != size)
99  {
100  theCompressedBuf.clear();
101  return; // block sizes different
102  }
103  ++i;
104  }
105  theCompressedBuf.resize(size); // block sizes all the same.
106 }
std::vector< ossim_uint32 > theNitfBlockSize
std::vector< ossim_uint8 > theCompressedBuf
yy_size_t size
unsigned int ossim_uint32
◆ initializeReadMode()
void ossimOpjNitfReader::initializeReadMode ( )
protectedvirtual
Definition at line 65 of file ossimOpjNitfReader.cpp.
References ossimNitfImageHeader::getCompressionCode(), ossimNitfTileSource::getCurrentImageHeader(), ossimNitfImageHeader::getIMode(), ossimNitfTileSource::READ_JPEG_BLOCK, ossimNitfTileSource::READ_MODE_UNKNOWN, and ossimNitfTileSource::theReadMode.
66 {
67  // Initialize the read mode.
69
71  if (!hdr)
72  {
73  return;
74  }
75
76  if ( (hdr->getIMode() == "B") && (hdr->getCompressionCode()== "C8") )
77  {
79  }
80 }
virtual ossimString getIMode() const =0
IMODE = B, IC = C3 "JPEG compressed blocks".
const ossimNitfImageHeader * getCurrentImageHeader() const
◆ scanForJpegBlockOffsets()
bool ossimOpjNitfReader::scanForJpegBlockOffsets ( )
protectedvirtual
Returns
true on success, false on error. This checks for arrays being the same size as number of blocks.
Definition at line 108 of file ossimOpjNitfReader.cpp.
References ossimNitfTileSource::getCurrentImageHeader(), ossimNitfImageHeader::getDataLocation(), ossimNitfImageHeader::getNumberOfBlocksPerCol(), ossimNitfImageHeader::getNumberOfBlocksPerRow(), ossimNitfTileSource::READ_JPEG_BLOCK, ossimNitfTileSource::theFileStr, ossimNitfTileSource::theNitfBlockOffset, ossimNitfTileSource::theNitfBlockSize, and ossimNitfTileSource::theReadMode.
109 {
111
112  if ( !hdr || (theReadMode != READ_JPEG_BLOCK) || !theFileStr )
113  {
114  return false;
115  }
116
117  theNitfBlockOffset.clear();
118  theNitfBlockSize.clear();
119
120  //---
121  // NOTE:
122  // SOC = 0xff4f Start of Codestream
123  // SOT = 0xff90 Start of tile
124  // SOD = 0xff93 Last marker in each tile
125  // EOC = 0xffd9 End of Codestream
126  //---
127  char c;
128
129  // Seek to the first block.
130  theFileStr->seekg(hdr->getDataLocation(), ios::beg);
131  if (theFileStr->fail())
132  {
133  return false;
134  }
135
136  // Read the first two bytes and verify it is SOC; if not, get out.
137  theFileStr->get( c );
138  if (static_cast<ossim_uint8>(c) != 0xff)
139  {
140  return false;
141  }
142  theFileStr->get(c);
143  if (static_cast<ossim_uint8>(c) != 0x4f)
144  {
145  return false;
146  }
147
148  ossim_uint32 blockSize = 2; // Read two bytes...
149
150  // Add the first offset.
151  // theNitfBlockOffset.push_back(hdr->getDataLocation());
152
153  // Find all the SOC markers.
154  while ( theFileStr->get(c) )
155  {
156  ++blockSize;
157  if (static_cast<ossim_uint8>(c) == 0xff)
158  {
159  if ( theFileStr->get(c) )
160  {
161  ++blockSize;
162
163  if (static_cast<ossim_uint8>(c) == 0x90) // At SOC marker...
164  {
165  std::streamoff pos = theFileStr->tellg();
166  theNitfBlockOffset.push_back(pos-2);
167  }
168  else if (static_cast<ossim_uint8>(c) == 0x93) // At EOC marker...
169  {
170  // Capture the size of this block.
171  theNitfBlockSize.push_back(blockSize);
172  blockSize = 0;
173  }
174  }
175  }
176  }
177
178  theFileStr->seekg(0, ios::beg);
179  theFileStr->clear();
180
181  // We should have the same amount of offsets as we do blocks...
182  ossim_uint32 total_blocks =
184
185  if (theNitfBlockOffset.size() != total_blocks)
186  {
187  if (traceDebug())
188  {
190  << "DEBUG:"
191  << "\nBlock offset count wrong!"
192  << "\nblocks: " << total_blocks
193  << "\noffsets: " << theNitfBlockOffset.size()
194  << std::endl;
195  }
196
197  return false;
198  }
199  if (theNitfBlockSize.size() != total_blocks)
200  {
201  if (traceDebug())
202  {
204  << "DEBUG:"
205  << "\nBlock size count wrong!"
206  << "\nblocks: " << total_blocks
207  << "\nblock size array: " << theNitfBlockSize.size()
208  << std::endl;
209  }
210
211  return false;
212  }
213
214  return true;
215 }
virtual ossim_int32 getNumberOfBlocksPerRow() const =0
std::shared_ptr< ossim::istream > theFileStr
virtual ossim_uint64 getDataLocation() const =0
virtual ossim_int32 getNumberOfBlocksPerCol() const =0
◆ uncompressJpegBlock()
bool ossimOpjNitfReader::uncompressJpegBlock ( ossim_uint32  x,
ossim_uint32  y
protectedvirtual
Parameters
xsample location in image space.
yline location in image space.
Returns
Definition at line 217 of file ossimOpjNitfReader.cpp.
References ossimNitfTileSource::getBlockNumber(), x, and y.
219 {
220  ossim_uint32 blockNumber = getBlockNumber(ossimIpt(x,y));
221
222  if (traceDebug())
223  {
225  << "ossimNitfTileSource::uncompressJpegBlock DEBUG:"
226  << "\nblockNumber: " << blockNumber
227  << "\noffset to block: " << theNitfBlockOffset[blockNumber]
228  << "\nblock size: " << theNitfBlockSize[blockNumber]
229  << std::endl;
230  }
231
232  // Seek to the block.
233  theFileStr->seekg(theNitfBlockOffset[blockNumber], ios::beg);
234
235  //---
236  // Get a buffer to read the compressed block into. If all the blocks are
237  // the same size this will be theCompressedBuf; else we will make our own.
238  //---
239  ossim_uint8* compressedBuf = &theCompressedBuf.front();
240  if (!compressedBuf)
241  {
242  compressedBuf = new ossim_uint8[theNitfBlockSize[blockNumber]];
243  }
244
245
246  // Read the block into memory. We could store this
247  if (!theFileStr->read((char*)compressedBuf, theNitfBlockSize[blockNumber]))
248  {
249  theFileStr->clear();
251  << "ossimNitfTileSource::loadBlock Read Error!"
252  << "\nReturning error..." << endl;
254  delete [] compressedBuf;
255  compressedBuf = 0;
256  return false;
257  }
258
259  try
260  {
261  //theCacheTile = decoder.decodeBuffer(compressedBuf,
262  // theNitfBlockSize[blockNumber]);
263  }
264  catch (const ossimException& e)
265  {
267  << e.what() << std::endl;
269  }
270
271  // If theCompressedBuf is null that means we allocated the compressedBuf.
272  if (theCompressedBuf.size() == 0)
273  {
274  delete [] compressedBuf;
275  compressedBuf = 0;
276  }
277
279  {
280  return false;
281  }
282  return true;
283 }
ossim_uint32 x
ossim_uint32 y
static const ossimErrorCode OSSIM_ERROR
virtual const char * what() const
Returns the error message.
ossim_uint32 getBlockNumber(const ossimIpt &block_origin) const
unsigned char ossim_uint8
