ossimNitfWriterBase.cpp
Go to the documentation of this file.
1 //---
2 //
3 // License: MIT
4 //
5 // Author: David Burken
6 //
7 // Description: OSSIM nitf writer base class to hold methods common to
8 // all nitf writers.
9 //
10 //---
11 // $Id$
12
16 #include <ossim/base/ossimIrect.h>
19 #include <ossim/base/ossimRefPtr.h>
20 #include <ossim/base/ossimString.h>
21 #include <ossim/base/ossimTrace.h>
37
38 static const char ENABLE_BLOCKA_KW[] = "enable_blocka_tag";
39 static const char ENABLE_RPCB_KW[] = "enable_rpcb_tag";
40 static const char ENABLE_GEOLOB_KW[] = "enable_geolob_tag";
41
42 RTTI_DEF1(ossimNitfWriterBase, "ossimNitfWriterBase", ossimImageFileWriter)
43
44 static ossimTrace traceDebug(ossimString("ossimNitfWriterBase:debug"));
45
48  theEnableRpcbTagFlag(false),
49  theEnableBlockaTagFlag(true),
50  theEnableGeolobTagFlag(true)
51 {
52 }
53
55  ossimImageSource* inputSource)
56  : ossimImageFileWriter(filename, inputSource, 0),
57  theEnableRpcbTagFlag(false),
58  theEnableBlockaTagFlag(true),
59  theEnableGeolobTagFlag(true)
60 {
61 }
62
64 {
65 }
66
68 {
69  if(property.valid())
70  {
71  ossimString name = property->getName();
72
73  if (name == ENABLE_RPCB_KW)
74  {
75  theEnableRpcbTagFlag = property->valueToString().toBool();
76  }
77  else if (name == ENABLE_BLOCKA_KW)
78  {
79  theEnableBlockaTagFlag = property->valueToString().toBool();
80  }
81  else if (name == ENABLE_GEOLOB_KW)
82  {
83  theEnableGeolobTagFlag = property->valueToString().toBool();
84  }
85  else
86  {
88  }
89  }
90 }
91
93  const ossimString& name)const
94 {
95  ossimRefPtr<ossimProperty> result = 0;
96
97  if(name == ENABLE_BLOCKA_KW)
98  {
99  result = new ossimBooleanProperty(name, theEnableBlockaTagFlag);
100  }
101  else if (name == ENABLE_GEOLOB_KW)
102  {
103  result = new ossimBooleanProperty(name, theEnableGeolobTagFlag);
104  }
105  else if(name == ENABLE_RPCB_KW)
106  {
107  result = new ossimBooleanProperty(name, theEnableRpcbTagFlag);
108  }
109  else
110  {
111  result = ossimImageFileWriter::getProperty(name);
112  }
113
114  return result;
115 }
116
118  std::vector<ossimString>& propertyNames)const
119 {
121
122  propertyNames.push_back(ENABLE_BLOCKA_KW);
123  propertyNames.push_back(ENABLE_GEOLOB_KW);
124  propertyNames.push_back(ENABLE_RPCB_KW);
125 }
126
127
129  const char* prefix) const
130 {
131  kwl.add(prefix, ENABLE_BLOCKA_KW, theEnableBlockaTagFlag, true);
132  kwl.add(prefix, ENABLE_GEOLOB_KW, theEnableGeolobTagFlag, true);
133  kwl.add(prefix, ENABLE_RPCB_KW, theEnableRpcbTagFlag, true);
134
135  return ossimImageFileWriter::saveState(kwl, prefix);
136 }
137
139  const char* prefix)
140 {
141  // Look for the rpcb enable flag keyword.
142
143
144  // Look for the blocka enable flag keyword.
145  const char* lookup = kwl.find(prefix, ENABLE_BLOCKA_KW);
146  if(lookup)
147  {
148  ossimString os = lookup;
150  }
151
152  // Look for the geolob enable flag keyword.
153  lookup = kwl.find(prefix, ENABLE_GEOLOB_KW);
154  if(lookup)
155  {
156  ossimString os = lookup;
158  }
159
160  lookup = kwl.find(prefix, ENABLE_RPCB_KW);
161  if(lookup)
162  {
163  ossimString os = lookup;
165  }
166
167  return ossimImageFileWriter::loadState(kwl, prefix);
168 }
169
172 {
173  if (hdr && seq)
174  {
176  ossimKeywordlist kwl;
177
178  if (geom.valid()&&geom->hasProjection())
179  {
180  // Get the requested bounding rectangles.
181  ossimIrect rect = seq->getBoundingRect();
182
183  // See if it's a map projection; else, a sensor model.
184  ossimMapProjection* mapProj =
186  if (mapProj)
187  {
188  // Use map info to get the corners.
189  ossimMapProjectionInfo mapInfo(mapProj, rect);
191
192  // See if it's utm.
194  mapProj);
195  if(utmProj)
196  {
197  ossimDpt ul = mapInfo.ulEastingNorthingPt();
198  ossimDpt ur = mapInfo.urEastingNorthingPt();
199  ossimDpt lr = mapInfo.lrEastingNorthingPt();
200  ossimDpt ll = mapInfo.llEastingNorthingPt();
201
202  if(utmProj->getHemisphere() == 'N')
203  {
204  hdr->setUtmNorth(utmProj->getZone(), ul, ur, lr, ll);
205  }
206  else
207  {
208  hdr->setUtmSouth(utmProj->getZone(), ul, ur, lr, ll);
209  }
210  }
211  else
212  {
213  ossimGpt ul = mapInfo.ulGroundPt();
214  ossimGpt ur = mapInfo.urGroundPt();
215  ossimGpt lr = mapInfo.lrGroundPt();
216  ossimGpt ll = mapInfo.llGroundPt();
217  hdr->setGeographicLocationDms(ul, ur, lr, ll);
218  }
219
221  {
222  addBlockaTag(mapInfo, hdr);
223  }
224
226  {
227  addGeolobTag( mapProj, hdr );
228  }
229  }
230  else
231  {
232  ossimGpt ul, ur, lr, ll;
233  bool status = geom->getCornerGpts(ul, ur, lr, ll);
234  if (status)
235  {
236  hdr->setGeographicLocationDms(ul, ur, lr, ll);
237  }
238  }
239
241  {
242  addRpcbTag(rect, geom->getProjection(), hdr);
243  }
244
245  } // matches: if (proj.valid())
246
247  } // matches: if (hdr && seq)
248 }
249
252 {
253  if (hdr)
254  {
255  // Capture the current pixel type.
256  ossimPixelType originalPixelType = mapInfo.getPixelType();
257
258  // This tag wants corners as area:
260
261  // Stuff the blocka tag which has six digit precision.
263
264  // Set the block number.
265  blockaTag->setBlockInstance(1);
266
267  // Set the number of lines.
268  blockaTag->setLLines(mapInfo.linesPerImage());
269
270  // Set first row, first column.
271  blockaTag->setFrfcLoc(ossimDpt(mapInfo.ulGroundPt()));
272
273  // Set first row, last column.
274  blockaTag->setFrlcLoc(ossimDpt(mapInfo.urGroundPt()));
275
276  // Set last row, last column.
277  blockaTag->setLrlcLoc(ossimDpt(mapInfo.lrGroundPt()));
278
279  // Set last row, first column.
280  blockaTag->setLrfcLoc(ossimDpt(mapInfo.llGroundPt()));
281
282  if (traceDebug())
283  {
285  << "ossimNitfWriterBase::addBlockaTag DEBUG:"
286  << "\nBLOCKA Tag:" << *((ossimObject*)(blockaTag.get()))
287  << std::endl;
288  }
289
290  // Add the tag to the header.
291  ossimRefPtr<ossimNitfRegisteredTag> blockaTagRp = blockaTag.get();
292  ossimNitfTagInformation blockaTagInfo(blockaTagRp);
293  hdr->addTag(blockaTagInfo);
294
295  // Reset the pixel type to original value
296  mapInfo.setPixelType(originalPixelType);
297
298  } // matches: if (hdr)
299 }
300
303 {
304  if (hdr && mapProj)
305  {
306  if ( mapProj->isGeographic() == true )
307  {
309
310  // Get the scale:
311  ossimDpt gsd = mapProj->getDecimalDegreesPerPixel();
312  if ( (gsd.hasNans() == false) && (gsd.x > 0.0) && (gsd.y > 0.0) )
313  {
314  ossimGpt tie = mapProj->getUlGpt();
315  if ( tie.hasNans() == false )
316  {
317  // Shift the tie to edge of pixel:
318  tie.lat = tie.lat + gsd.y*0.5;
319  tie.lon = tie.lon - gsd.x*0.5;
320  if ( (tie.lat <= 90.0) && (tie.lon >= -180.0) )
321  {
323  geolobTag->setDegreesPerPixelLon( gsd.x );
324  geolobTag->setDegreesPerPixelLat( gsd.y );
325  geolobTag->setLso( tie.lon ); // Origin Longitude
326  geolobTag->setPso( tie.lat ); // Origin Latitude
327
328  // Add the tag to the header.
329  ossimRefPtr<ossimNitfRegisteredTag> geolobTagRp = geolobTag.get();
330  ossimNitfTagInformation geolobTagInfo(geolobTagRp);
331  hdr->addTag(geolobTagInfo);
332
333  if (traceDebug())
334  {
336  << "ossimNitfWriterBase::addGeolobTag DEBUG:"
337  << "\nAdded GEOLOB Tag:\n" << *(geolobTag.get())
338  << "\n";
339  }
340  }
341  }
342  }
343  }
344  }
345 }
346
348  ossimProjection* proj,
350 {
351  if (proj && hdr)
352  {
353  bool useElevation = false;
354
355  if (PTR_CAST(ossimMapProjection, proj))
356  {
357  // If we're already map projected turn the elevation off.
358  useElevation = false;
359  }
360
361  // Make an rpc solver.
362  ossimRefPtr<ossimRpcSolver> rs = new ossimRpcSolver(useElevation);
363
364  // Compute the coefficients.
365  rs->solveCoefficients(ossimDrect(rect), proj, 64, 64);
366
367  // Add the tag.
369  ossimNitfTagInformation tagInfo(tag);
370  hdr->addTag(tagInfo);
371
372  if (traceDebug())
373  {
375  << "ossimNitfWriterBase::addRpcbTag DEBUG:"
376  << "\nRPCB Tag:" << *((ossimObject*)(tag.get()))
377  << "\nProjection:\n";
378
380
382  << "\nRect: " << rect << std::endl;
383  }
384
385  } // matches: if (proj && hdr)
386 }
387
388 void ossimNitfWriterBase::setComplexityLevel(std::streamoff endPosition,
390 {
391  if (hdr)
392  {
393  //---
394  // See MIL-STD-2500C, Table A-10:
395  //
396  // Lots of rules here, but for now we will key off of file size.
397  //---
398  const std::streamoff MB = 1024 * 1024;
399  const std::streamoff MB50 = 50 * MB;
400  const std::streamoff GIG = 1000 * MB;
401  const std::streamoff GIG2 = 2 * GIG;
402
403  ossimString complexity = "03"; // Less than 50 mb.
404
405  if ( (endPosition >= MB50) && (endPosition < GIG) )
406  {
407  complexity = "05";
408  }
409  else if ( (endPosition >= GIG) && (endPosition < GIG2) )
410  {
411  complexity = "06";
412  }
413  else if (endPosition >= GIG2)
414  {
415  complexity = "07";
416  }
417
418  hdr->setComplexityLevel(complexity);
419  }
420 }
421
422 // Alternate calculation option for complexity. This seems to match more test data.
424 {
425  if (hdr)
426  {
427  ossim_uint64 max = (width > height) ? width : height;
428  ossimString complexity = "03";
429  if (max > 65536) complexity = "07";
430  else if (max > 8192) complexity = "06";
431  else if (max > 2048) complexity = "05";
432
433  hdr->setComplexityLevel(complexity);
434  }
435 }
436
438 {
439  return ossimString("ntf");
440 }
441
443 {
444 }
445
447 {
448 }
449
450 void ossimNitfWriterBase::addRegisteredTag(ossimRefPtr<ossimNitfRegisteredTag> /* registeredTag */, bool /* unique */, const ossim_uint32& /* ownerIndex */, const ossimString& /* tagType */)
451 {
452 }
453
455 {
456 }
457
459 {
460 }
461
463  ossimNitfImageHeaderV2_X* imgHdr )
464 {
465  // Look in prefs for site configuration file:
466  const char* lookup = ossimPreferences::instance()->
467  findPreference("nitf_writer.site_configuration_file");
468  if ( lookup && fileHdr && imgHdr )
469  {
470  ossimKeywordlist kwl;
471  if ( kwl.addFile( lookup ) )
472  {
473  fileHdr->loadState( kwl, "nitf.file." );
474  imgHdr->loadState( kwl, "nitf.image." );
475  }
476  }
477 }
478
Set the properties.
bool theEnableGeolobTagFlag
If true user wants to set GEOLOG tag.
virtual const ossimDpt & getDecimalDegreesPerPixel() const
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing...
void setFrlcLoc(const ossimDpt &pt)
Convert latitude and logitude to theFrlcLoc string.
ossimGpt urGroundPt() const
Returns the upper right ground point.
virtual void setFileHeaderV2_1(ossimRefPtr< ossimNitfFileHeaderV2_1 >, bool preferSource=false)
ossim_int32 linesPerImage() const
void setLrfcLoc(const ossimDpt &pt)
Convert latitude and logitude to theLrfcLoc string.
ossimRefPtr< ossimNitfRegisteredTag > getNitfRpcBTag() const
bool addFile(const char *file)
ossimNitfWriterBase()
default constructor
bool valid() const
Definition: ossimRefPtr.h:75
Method to set fields from a keyword list.
bool theEnableBlockaTagFlag
If true user wants to set BLOCKA tag.
virtual void setUtmNorth(ossim_uint32 zone, const ossimDpt &ul, const ossimDpt &ur, const ossimDpt &lr, const ossimDpt &ll)
void setLrlcLoc(const ossimDpt &pt)
Convert latitude and logitude to theLrlcLoc string.
void setBlockInstance(ossim_uint32 block)
double y
Definition: ossimDpt.h:165
virtual void addTag(const ossimNitfTagInformation &tag, bool unique=true)
virtual bool isGeographic() const
void setPixelType(ossimPixelType type)
Sets the data member "thePixelType".
bool getCornerGpts(ossimGpt &ul, ossimGpt &ur, ossimGpt &lr, ossimGpt &ll) const
Assigns the ossimGpts with the ground coordinates of the four corresponding image corner points...
Pure virtual base class for image file writers.
ossimDpt lrEastingNorthingPt() const
Returns the lower right easting and northing as a ossimDpt.
void solveCoefficients(const ossimDrect &imageBounds, ossimProjection *imageProj, ossim_uint32 xSamples=8, ossim_uint32 ySamples=8)
This will convert any projector to an RPC model.
ossimPixelType getPixelType() const
Returns data member "thePixelType".
void addBlockaTag(ossimMapProjectionInfo &mapInfo, ossimNitfImageHeaderV2_X *hdr)
Adds the BLOCKA tag.
void setFrfcLoc(const ossimDpt &pt)
Convert latitude and logitude to theFrfcLoc string.
void setDegreesPerPixelLon(const ossim_float64 &deltaLon)
Sets the ARV field from decimal degrees per pixel longitude.
ossim_float64 lon
Definition: ossimGpt.h:266
ossimRefPtr< ossimImageSourceSequencer > theInputConnection
void addRpcbTag(const ossimIrect &rect, ossimProjection *proj, ossimNitfImageHeaderV2_X *hdr)
Adds the RPC00B tag.
ossimGpt lrGroundPt() const
Returns the lower right ground point.
bool toBool() const
String to numeric methods.
This will return the bounding rect of the source.
unsigned long long ossim_uint64
unsigned int ossim_uint32
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
OSSIM nitf writer base class to hold methods common to all nitf writers.
ossimGpt ulGroundPt() const
Returns the upper left ground point.
ossimDpt urEastingNorthingPt() const
Returns the upper right easting and northing as a ossimDpt.
void setLso(const ossim_float64 &lso)
Sets the LSO field(Longitude Origin).
bool hasNans() const
Definition: ossimDpt.h:67
virtual const ossimGpt & getUlGpt() const
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
static ossimPreferences * instance()
ossimDpt llEastingNorthingPt() const
Returns the lower left easting and northing as a ossimDpt.
void setLLines(ossim_uint32 lines)
virtual void setImageHeaderV2_1(ossimRefPtr< ossimNitfImageHeaderV2_1 >, bool preferSource=false)
void addGeolobTag(const ossimMapProjection *mapProj, ossimNitfImageHeaderV2_X *hdr)
Adds the GEOLOB tag.
return status
ossimDpt ulEastingNorthingPt() const
Returns the upper left easting and northing as a ossimDpt.
ossimPixelType
virtual void initializeDefaultsFromConfigFile(ossimNitfFileHeaderV2_X *fileHdr, ossimNitfImageHeaderV2_X *imgHdr)
Sets file header and image header defaults from config file if found in preferences.
virtual void setUtmSouth(ossim_uint32 zone, const ossimDpt &ul, const ossimDpt &ur, const ossimDpt &lr, const ossimDpt &ll)
void setComplexityLevel(const ossimString &level)
void writeGeometry(ossimNitfImageHeaderV2_X *hdr, ossimImageSourceSequencer *seq)
Populates tags with geometry info from projection.
Definition: ossimGpt.h:135
#define max(a, b)
Definition: auxiliary.h:76
void setPso(const ossim_float64 &pso)
Sets the PSO field(Latitude Origin).
Initializes the state of the writer from kwl with prefix then calls base class ossimImageFileWriter::...
void setComplexityLevel(std::streamoff, ossimNitfFileHeaderV2_X *hdr)
Sets the complexity level of theFileHeader.
double x
Definition: ossimDpt.h:164
virtual void addRegisteredTag(ossimRefPtr< ossimNitfRegisteredTag > registeredTag)
This currently only support Rational poilynomial B format.
virtual ossimString getExtension() const
Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for...
ossim_int32 getZone() const
bool hasProjection() const
Returns TRUE if valid projection defined.
void setDegreesPerPixelLat(const ossim_float64 &deltaLat)
Sets the BRV field from decimal degrees per pixel latitude.
ossim_float64 lat
Definition: ossimGpt.h:265
Gets a property.
virtual void setGeographicLocationDms(const ossimDpt &ul, const ossimDpt &ur, const ossimDpt &lr, const ossimDpt &ll)
#define RTTI_DEF1(cls, name, b1)
Definition: ossimRtti.h:485
bool theEnableRpcbTagFlag
If true user wants to set RPC00B tag.
Saves the state of the writer to kwl with prefix then calls base class ossimImageFileWriter::saveStat...
ossimGpt llGroundPt() const
Returns the lower left ground point.
