26 static const char COLOR_RED_KW[] =
"color_red";
27 static const char COLOR_GREEN_KW[] =
"color_green";
28 static const char COLOR_BLUE_KW[] =
"color_blue";
31 "ossimBumpShadeTileSource",
38 m_lightSourceElevationAngle(45.0),
39 m_lightSourceAzimuthAngle(45.0),
77 if (!
getInput(0) || !tile)
return false;
94 colorSource->
getTile(colorData.
get(), resLevel);
106 normalSource->
getTile(normalData.
get(), resLevel);
125 if ( colorData.
get() &&
145 colorBuf[1] = colorBuf[0];
153 colorBuf[2] = colorBuf[0];
158 for(
long y = 0;
y < h; ++
y)
160 for(
long x = 0;
x < w; ++
x)
162 if((*normalBuf[0] != normalNp) &&
163 (*normalBuf[1] != normalNp) &&
164 (*normalBuf[2] != normalNp) )
166 if((*colorBuf[0])||(*colorBuf[1])||(*colorBuf[2]))
193 *resultBuf[0] = *colorBuf[0];
194 *resultBuf[1] = *colorBuf[1];
195 *resultBuf[2] = *colorBuf[2];
213 <<
"ossimBumpShadeTileSource::getTile NOTICE:\n" 214 <<
"only 8-bit unsigned char is supported." << endl;
226 for(
long y = 0;
y < h; ++
y)
228 for(
long x = 0;
x < w; ++
x)
230 if((*normalBuf[0] != normalNp) &&
231 (*normalBuf[1] != normalNp) &&
232 (*normalBuf[2] != normalNp) )
315 NEWMAT::ColumnVector v(3);
346 const char* lookup = kwl.
find(prefix, COLOR_RED_KW);
352 lookup = kwl.
find(prefix, COLOR_GREEN_KW);
358 lookup = kwl.
find(prefix, COLOR_BLUE_KW);
377 const char* prefix)
const 389 kwl.
add(prefix, COLOR_RED_KW,
m_r,
true);
390 kwl.
add(prefix, COLOR_GREEN_KW,
m_g,
true);
391 kwl.
add(prefix, COLOR_BLUE_KW,
m_b,
true);
455 ( (inputIndex>=0) && inputIndex < 2)&&
483 if(name ==
"lightSourceElevationAngle")
487 else if(name ==
"lightSourceAzimuthAngle")
499 if(name ==
505 else if(name ==
518 propertyNames.push_back(
"lightSourceElevationAngle");
519 propertyNames.push_back(
"lightSourceAzimuthAngle");
virtual void setNumberOfInputs(ossim_int32 numberOfInputs)
Will set the number of inputs.
virtual double getAzimuthAngle() const
ossim_uint8 m_r
rgb values used when no color source (2nd layer) is present.
This uses a derivative of Blinn's bump function to compute a 3-D looking image.
virtual void refreshEvent(ossimRefreshEvent &event)
This will be a base for all combiners.
static long clamp(long colorValue, unsigned char min=0, unsigned char max=255)
ossim_uint8 toUInt8() const
void computeLightDirection()
Will re-compute the light direction given the elevation angle and azimuth angle.
virtual void propertyEvent(ossimPropertyEvent &event)
Numeric to string methods.
ossimColumnVector3d unit() const
This should always return 3.
bool canConnectMyInputTo(ossim_int32 inputIndex, const ossimConnectableObject *object) const
required to be overriden by derived classes
virtual void initialize()
Initialize the data buffer.
virtual void setElevationAngle(double angle)
double m_lightSourceAzimuthAngle
Used for the light vector computation.
virtual ~ossimBumpShadeTileSource()
NEWMAT::ColumnVector m_lightDirection
This is computed from the elevation and azimuth angles of the light source.
The output scalar type should always be 8-bit.
void computeColor(ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b, ossim_float64 normalX, ossim_float64 normalY, ossim_float64 normalZ, ossim_uint8 dr, ossim_uint8 dg, ossim_uint8 db) const
RTTI_DEF1(ossimBumpShadeTileSource, "ossimBumpShadeTileSource", ossimImageCombiner)
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
void getRgbColorSource(ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const
Gets the red, green and blue color source values.
void setRgbColorSource(ossim_uint8 r, ossim_uint8 g, ossim_uint8 b)
Set the red, green and blue color source values.
virtual void setAzimuthAngle(double angle)
ossimString getShortName() const
virtual ossimIrect getImageRectangle() const
static const char * AZIMUTH_ANGLE_KW
virtual void makeBlank()
virtual void disconnectInputEvent(ossimConnectionEvent &event)
the max pixel is 255.
virtual ossim_uint32 getNumberOfInputs() const
Returns the number of input objects.
virtual double getNullPixelValue() const
the null pixel is 0.0.
the min pixel is 1.0.
bool theInputListIsFixedFlag
Indicates whether the theInputObjectList is fixed.
ossimRefPtr< ossimImageData > m_tile
The result of the illumination equation is stored in here.
virtual void initialize()=0
static const char * ELEVATION_ANGLE_KW
ossimDataObjectStatus
Definitions for data object status.
bool theOutputListIsFixedFlag
Indicates whether the theOutputObjectList is fixed.
ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual void connectInputEvent(ossimConnectionEvent &event)
unsigned char ossim_uint8
ossimString getLongName() const
double m_lightSourceElevationAngle
virtual double getElevationAngle() const
void setCacheRefreshBit()
static NEWMAT::Matrix createRotationMatrix(double angleX, double angleY, double angleZ, ossimCoordSysOrientMode orientationMode=OSSIM_RIGHT_HANDED)
