21 static const char* SMOOTHNESS_FACTOR_KW=
"smoothness_factor";
29 theTrackScaleFlag(
true),
32 theSmoothnessFactor(1.0)
40 theTrackScaleFlag(
true),
43 theSmoothnessFactor(1.0)
76 if(!input||(input->getDataObjectStatus()==
OSSIM_EMPTY)||!input->getBuf())
210 T* inbuf = (T*) inputTile->
getBuf();
212 double* normX = (
double*)outputTile->
getBuf(0);
213 double* normY = (
getBuf(1);
214 double* normZ = (
getBuf(2);
219 bool valid_component =
true;
235 if (inbuf[i+1] != inputNull)
237 if (inbuf[i-1] != inputNull)
239 else if (inbuf[i] != inputNull)
242 else if ((inbuf[i] != inputNull) && (inbuf[i-1] != inputNull))
248 valid_component =
false;
254 if (inbuf[i+inbuf_width] != inputNull)
256 if (inbuf[i-inbuf_width] != inputNull)
258 else if (inbuf[i] != inputNull)
261 else if ((inbuf[i] != inputNull) && (inbuf[i-inbuf_width] != inputNull))
267 valid_component =
false;
274 normal = normal.
unit();
275 normX[
n] = normal[0];
276 normY[
n] = normal[1];
277 normZ[
n] = normal[2];
281 normX[
n] = outputNull;
282 normY[
n] = outputNull;
283 normZ[
n] = outputNull;
288 valid_component =
true;
322 const char* prefix)
const 340 SMOOTHNESS_FACTOR_KW,
427 if((name ==
"smoothnessFactor")||
433 else if(name ==
"xscale")
435 theXScale =
property->valueToString().toDouble();
438 else if(name ==
"yscale")
440 theYScale =
443 else if(name ==
"autoTrackScaleFlag")
456 if((name ==
463 else if(name ==
"xscale")
469 else if(name ==
"yscale")
475 else if(name ==
488 propertyNames.push_back(
"gain");
489 propertyNames.push_back(
"xscale");
490 propertyNames.push_back(
"yscale");
491 propertyNames.push_back(
"autoTrackScaleFlag");
This will return the bounding rect of the source.
Numeric to string methods.
ossimColumnVector3d unit() const
const ossimIpt & ul() const
double getSmoothnessFactor() const
double theSmoothnessFactor
unsigned short ossim_uint16
virtual void initialize()
Initialize the data buffer.
bool getTrackScaleFlag() const
virtual ossimObject * dup() const
bool completely_within(const ossimIrect &rect) const
static const char * SCALE_PER_PIXEL_X_KW
ossimImageToPlaneNormalFilter()
signed short ossim_sint16
bool loadState(const ossimKeywordlist &kwl, const char *prefix)
os2<< "> n<< " > nendobj n
bool toBool() const
String to numeric methods.
virtual ossim_uint32 getSizePerBand() const
Returns the number of pixels in a single band in a tile.
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
ossimDpt getMetersPerPixel() const
Returns the GSD associated with this image in the active projection.
void setTrackScaleFlag(bool flag)
RTTI_DEF1(ossimImageToPlaneNormalFilter, "ossimImageToPlaneNormalFilter", ossimImageSourceFilter)
const ossimIpt & lr() const
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
void setXScale(const double &scale)
ossimIrect theInputBounds
void setYScale(const double &scale)
void setSmoothnessFactor(double value)
void computeNormalsTemplate(T inputScalarTypeDummy, ossimRefPtr< ossimImageData > &inputTile, ossimRefPtr< ossimImageData > &outputTile)
virtual void initialize()=0
virtual void computeNormals(ossimRefPtr< ossimImageData > &inputTile, ossimRefPtr< ossimImageData > &outputTile)
static const char * SCALE_PER_PIXEL_Y_KW
bool saveState(ossimKeywordlist &kwl, const char *prefix) const
virtual void getDecimationFactor(ossim_uint32 resLevel, ossimDpt &result) const
Will return the decimation factor for the given resolution level.
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
unsigned char ossim_uint8
ossimRefPtr< ossimImageData > theBlankTile
void setCacheRefreshBit()
