ossimImageToPlaneNormalFilter Class Reference
#include <ossimImageToPlaneNormalFilter.h>
Inheritance diagram for ossimImageToPlaneNormalFilter:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimImageToPlaneNormalFilter ()
 ossimImageToPlaneNormalFilter (ossimImageSource *inputSource)
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0)
void setXScale (const double &scale)
void setYScale (const double &scale)
double getXScale () const
double getYScale () const
void setTrackScaleFlag (bool flag)
bool getTrackScaleFlag () const
void setSmoothnessFactor (double value)
double getSmoothnessFactor () const
bool loadState (const ossimKeywordlist &kwl, const char *prefix)
bool saveState (ossimKeywordlist &kwl, const char *prefix) const
virtual void initialize ()
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
void initializeTile ()
virtual void computeNormals (ossimRefPtr< ossimImageData > &inputTile, ossimRefPtr< ossimImageData > &outputTile)
template<class T >
void computeNormalsTemplate (T inputScalarTypeDummy, ossimRefPtr< ossimImageData > &inputTile, ossimRefPtr< ossimImageData > &outputTile)
virtual ~ossimReferenced ()
Protected Attributes
ossimRefPtr< ossimImageDatatheBlankTile
ossimIrect theInputBounds
bool theTrackScaleFlag
double theXScale
double theYScale
double theSmoothnessFactor
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Additional Inherited Members
Detailed Description
Definition at line 16 of file ossimImageToPlaneNormalFilter.h.
◆ ossimImageToPlaneNormalFilter() [1/2]
ossimImageToPlaneNormalFilter::ossimImageToPlaneNormalFilter ( )
◆ ossimImageToPlaneNormalFilter() [2/2]
ossimImageToPlaneNormalFilter::ossimImageToPlaneNormalFilter ( ossimImageSource inputSource)
Member Function Documentation
◆ computeNormals()
void ossimImageToPlaneNormalFilter::computeNormals ( ossimRefPtr< ossimImageData > &  inputTile,
ossimRefPtr< ossimImageData > &  outputTile
protectedvirtual
Definition at line 151 of file ossimImageToPlaneNormalFilter.cpp.
References computeNormalsTemplate(), ossimRectilinearDataObject::getScalarType(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, and OSSIM_USHORT16.
Referenced by getTile().
154 {
155  switch(inputTile->getScalarType())
156  {
157  case OSSIM_SSHORT16:
158  {
160  inputTile,
161  outputTile);
162  break;
163  }
164  case OSSIM_UCHAR:
165  {
167  inputTile,
168  outputTile);
169  break;
170  }
171  case OSSIM_USHORT11:
172  case OSSIM_USHORT12:
173  case OSSIM_USHORT13:
174  case OSSIM_USHORT14:
175  case OSSIM_USHORT15:
176  case OSSIM_USHORT16:
177  {
179  inputTile,
180  outputTile);
181  break;
182  }
184  case OSSIM_DOUBLE:
185  {
187  inputTile,
188  outputTile);
189  break;
190  }
192  case OSSIM_FLOAT:
193  {
195  inputTile,
196  outputTile);
197  break;
198  }
199  default:
200  break;
201  }
202 }
float ossim_float32
unsigned short ossim_uint16
double ossim_float64
signed short ossim_sint16
void computeNormalsTemplate(T inputScalarTypeDummy, ossimRefPtr< ossimImageData > &inputTile, ossimRefPtr< ossimImageData > &outputTile)
32 bit floating point
16 bit unsigned iteger
64 bit floating point
16 bit signed integer
unsigned char ossim_uint8
8 bit unsigned iteger
◆ computeNormalsTemplate()
template<class T >
void ossimImageToPlaneNormalFilter::computeNormalsTemplate ( inputScalarTypeDummy,
protected
Definition at line 204 of file ossimImageToPlaneNormalFilter.cpp.
References ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageData::getNullPix(), ossimImageData::getWidth(), n, theSmoothnessFactor, theXScale, theYScale, ossimColumnVector3d::unit(), x, and y.
Referenced by computeNormals().
208 {
209  T inputNull = (T) inputTile->getNullPix(0);
210  T* inbuf = (T*) inputTile->getBuf();
211  T outputNull = (T) outputTile->getNullPix(0);
212  double* normX = (double*)outputTile->getBuf(0);
213  double* normY = (double*)outputTile->getBuf(1);
214  double* normZ = (double*)outputTile->getBuf(2);
215  ossim_int32 inbuf_width = inputTile->getWidth();
216  ossim_int32 normbuf_width = outputTile->getWidth();
217  ossim_int32 normbuf_height = outputTile->getHeight();
218  ossimColumnVector3d normal;
219  bool valid_component = true;
220  for (ossim_int32 y=0; y<normbuf_height; y++)
221  {
222  // Establish offsets into the image and output normals buffers given row:
223  ossim_uint32 n = y*normbuf_width;
224  ossim_uint32 i = (y+1)*inbuf_width + 1;
225
226  // Loop to compute the gradient (normal) vector [dh/dx, dh/dy, 1]:
227  for (ossim_int32 x=0; x<normbuf_width; x++)
228  {
229  // Default in case of null inputs is a flat earth:
230  normal[0] = 0;
231  normal[1] = 0;
232  normal[2] = 1.0;
233
234  // Compute the x-direction differential:
235  if (inbuf[i+1] != inputNull)
236  {
237  if (inbuf[i-1] != inputNull)
238  normal[0] = theXScale*theSmoothnessFactor*(inbuf[i+1] - inbuf[i-1]) / 2.0;
239  else if (inbuf[i] != inputNull)
240  normal[0] = theXScale*theSmoothnessFactor*(inbuf[i+1] - inbuf[i]);
241  }
242  else if ((inbuf[i] != inputNull) && (inbuf[i-1] != inputNull))
243  {
244  normal[0] = theXScale*theSmoothnessFactor*(inbuf[i] - inbuf[i-1]);
245  }
246  else
247  {
248  valid_component = false;
249  }
250
251  // Compute the y-direction differential:
252  if (valid_component)
253  {
254  if (inbuf[i+inbuf_width] != inputNull)
255  {
256  if (inbuf[i-inbuf_width] != inputNull)
257  normal[1] = theYScale*theSmoothnessFactor*(inbuf[i+inbuf_width] - inbuf[i-inbuf_width]) / 2.0;
258  else if (inbuf[i] != inputNull)
259  normal[1] = theYScale*theSmoothnessFactor*(inbuf[i+inbuf_width] - inbuf[i]);
260  }
261  else if ((inbuf[i] != inputNull) && (inbuf[i-inbuf_width] != inputNull))
262  {
263  normal[1] = theYScale*theSmoothnessFactor*(inbuf[i] - inbuf[i-inbuf_width]);
264  }
265  else
266  {
267  valid_component = false;
268  }
269  }
270
271  // Stuff the normalized gradient vector into the output buffers:
272  if (valid_component)
273  {
274  normal = normal.unit();
275  normX[n] = normal[0];
276  normY[n] = normal[1];
277  normZ[n] = normal[2];
278  }
279  else
280  {
281  normX[n] = outputNull;
282  normY[n] = outputNull;
283  normZ[n] = outputNull;
284  }
285
286  ++n;
287  ++i;
288  valid_component = true;
289  }
290  }
291 }
ossim_uint32 x
ossim_uint32 y
ossimColumnVector3d unit() const
os2<< "> n<< " > nendobj n
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
int ossim_int32
◆ getMaxPixelValue()
double ossimImageToPlaneNormalFilter::getMaxPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 356 of file ossimImageToPlaneNormalFilter.cpp.
References ossimImageSource::getMaxPixelValue(), and ossimSource::isSourceEnabled().
357 {
358  if(!isSourceEnabled())
359  {
361  }
362  return 1.0;
363 }
◆ getMinPixelValue()
double ossimImageToPlaneNormalFilter::getMinPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 347 of file ossimImageToPlaneNormalFilter.cpp.
References ossimImageSource::getMinPixelValue(), and ossimSource::isSourceEnabled().
348 {
349  if(!isSourceEnabled())
350  {
352  }
353  return -1;
354 }
◆ getNumberOfOutputBands()
ossim_uint32 ossimImageToPlaneNormalFilter::getNumberOfOutputBands ( ) const
virtual
Definition at line 375 of file ossimImageToPlaneNormalFilter.cpp.
References ossimImageSource::getNumberOfOutputBands(), and ossimSource::isSourceEnabled().
376 {
377  if(isSourceEnabled())
378  {
379  return 3;
380  }
382 }
◆ getOutputScalarType()
ossimScalarType ossimImageToPlaneNormalFilter::getOutputScalarType ( ) const
virtual
Definition at line 365 of file ossimImageToPlaneNormalFilter.cpp.
References ossimImageSource::getOutputScalarType(), ossimSource::isSourceEnabled(), and OSSIM_DOUBLE.
366 {
367  if(isSourceEnabled())
368  {
369  return OSSIM_DOUBLE;
370  }
371
373 }
◆ getProperty()
ossimRefPtr< ossimProperty > ossimImageToPlaneNormalFilter::getProperty ( const ossimString name) const
virtual
Definition at line 454 of file ossimImageToPlaneNormalFilter.cpp.
References ossimImageSourceFilter::getProperty(), ossimProperty::setCacheRefreshBit(), theSmoothnessFactor, theTrackScaleFlag, theXScale, theYScale, and ossimString::toString().
455 {
456  if((name == "smoothnessFactor")||
457  (name == "gain"))
458  {
460  prop->setCacheRefreshBit();
461  return prop;
462  }
463  else if(name == "xscale")
464  {
466  prop->setCacheRefreshBit();
467  return prop;
468  }
469  else if(name == "yscale")
470  {
472  prop->setCacheRefreshBit();
473  return prop;
474  }
475  else if(name == "autoTrackScaleFlag")
476  {
478  prop->setCacheRefreshBit();
479  return prop;
480  }
481
483 }
Numeric to string methods.
void setCacheRefreshBit()
◆ getPropertyNames()
void ossimImageToPlaneNormalFilter::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Definition at line 485 of file ossimImageToPlaneNormalFilter.cpp.
References ossimImageSourceFilter::getPropertyNames().
486 {
488  propertyNames.push_back("gain");
489  propertyNames.push_back("xscale");
490  propertyNames.push_back("yscale");
491  propertyNames.push_back("autoTrackScaleFlag");
492 }
◆ getSmoothnessFactor()
double ossimImageToPlaneNormalFilter::getSmoothnessFactor ( ) const
Definition at line 419 of file ossimImageToPlaneNormalFilter.cpp.
References theSmoothnessFactor.
◆ getTile()
ossimRefPtr< ossimImageData > ossimImageToPlaneNormalFilter::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
Returns
Definition at line 47 of file ossimImageToPlaneNormalFilter.cpp.
References ossimIrect::completely_within(), computeNormals(), ossimRefPtr< T >::get(), ossimImageSource::getDecimationFactor(), ossimImageSource::getTile(), ossimDpt::hasNans(), initialize(), initializeTile(), ossimSource::isSourceEnabled(), ossimIrect::lr(), OSSIM_EMPTY, ossimImageData::setImageRectangle(), theBlankTile, theInputBounds, ossimImageSourceFilter::theInputConnection, theTile, theXScale, theYScale, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Referenced by ossimSlopeFilter::getTile().
50 {
52  {
53  return ossimImageSourceFilter::getTile(tileRect, resLevel);
54  }
55
56  if(!theTile.valid())
57  {
58  initialize();
59  }
60
61  if(!theTile.valid())
62  {
63  return ossimImageSourceFilter::getTile(tileRect, resLevel);
64  }
65
66  theTile->setImageRectangle(tileRect);
67
68  ossimIrect requestRect(tileRect.ul().x - 1,
69  tileRect.ul().y - 1,
70  tileRect.lr().x + 1,
71  tileRect.lr().y + 1);
72
74  theInputConnection->getTile(requestRect, resLevel);
75
76  if(!input||(input->getDataObjectStatus()==OSSIM_EMPTY)||!input->getBuf())
77  {
78  if(tileRect.completely_within(theInputBounds))
79  {
81  theTile->validate();
82  return theTile.get();
83  }
85  return theBlankTile;
86  }
87
88  double oldScaleX = theXScale;
89  double oldScaleY = theYScale;
90
91  if(resLevel > 0)
92  {
93  ossimDpt scaleFactor;
94  theInputConnection->getDecimationFactor(resLevel, scaleFactor);
95
96  if(!scaleFactor.hasNans())
97  {
98  theXScale *= scaleFactor.x;
99  theYScale *= scaleFactor.y;
100  }
101  }
102
103  computeNormals(input, theTile);
104
105  theXScale = oldScaleX;
106  theYScale = oldScaleY;
107
108  theTile->validate();
109
110  return theTile;
111 }
bool valid() const
Definition: ossimRefPtr.h:75
double y
Definition: ossimDpt.h:165
bool hasNans() const
Definition: ossimDpt.h:67
double x
Definition: ossimDpt.h:164
virtual void computeNormals(ossimRefPtr< ossimImageData > &inputTile, ossimRefPtr< ossimImageData > &outputTile)
virtual void getDecimationFactor(ossim_uint32 resLevel, ossimDpt &result) const
Will return the decimation factor for the given resolution level.
ossimRefPtr< ossimImageData > theBlankTile
◆ getTrackScaleFlag()
bool ossimImageToPlaneNormalFilter::getTrackScaleFlag ( ) const
Definition at line 409 of file ossimImageToPlaneNormalFilter.cpp.
References theTrackScaleFlag.
◆ getXScale()
double ossimImageToPlaneNormalFilter::getXScale ( ) const
Definition at line 389 of file ossimImageToPlaneNormalFilter.cpp.
References theXScale.
390 {
391  return theXScale;
392 }
◆ getYScale()
double ossimImageToPlaneNormalFilter::getYScale ( ) const
Definition at line 394 of file ossimImageToPlaneNormalFilter.cpp.
References theYScale.
395 {
396  return theYScale;
397 }
◆ initialize()
void ossimImageToPlaneNormalFilter::initialize ( )
virtual
Definition at line 124 of file ossimImageToPlaneNormalFilter.cpp.
References ossimImageDataFactory::create(), ossimImageData::dup(), ossimImageSource::getBoundingRect(), ossimImageSource::getImageGeometry(), ossimImageGeometry::getMetersPerPixel(), ossimDpt::hasNans(), ossimImageSource::initialize(), ossimImageData::initialize(), ossimImageDataFactory::instance(), theBlankTile, theInputBounds, ossimImageSourceFilter::theInputConnection, theTile, theTrackScaleFlag, theXScale, theYScale, ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Referenced by getTile(), ossimSlopeFilter::initialize(), and setProperty().
125 {
127  {
129
133  theTile->initialize();
134
136  {
138  if( geom.valid() )
139  {
140  ossimDpt pt = geom->getMetersPerPixel();
141  if(!pt.hasNans())
142  {
143  theXScale = 1.0/pt.x;
144  theYScale = 1.0/pt.y;
145  }
146  }
147  }
148  }
149 }
This will return the bounding rect of the source.
bool valid() const
double y
virtual void initialize()
Initialize the data buffer.
virtual ossimObject * dup() const
ossimDpt getMetersPerPixel() const
Returns the GSD associated with this image in the active projection.
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
double x
virtual void initialize()=0
◆ initializeTile()
void ossimImageToPlaneNormalFilter::initializeTile ( )
protected
Definition at line 113 of file ossimImageToPlaneNormalFilter.cpp.
References ossimImageData::getBuf(), ossimImageData::getSizePerBand(), theTile, x, and y.
114 {
115  double* x = static_cast<double*>(theTile->getBuf(0));
116  double* y = static_cast<double*>(theTile->getBuf(1));
117  double* z = static_cast<double*>(theTile->getBuf(2));
118
119  if(x) std::fill(x, x+theTile->getSizePerBand(), 0.0);
120  if(y) std::fill(y, y+theTile->getSizePerBand(), 0.0);
121  if(z) std::fill(z, z+theTile->getSizePerBand(), 1.0);
122 }
ossim_uint32 x
ossim_uint32 y
virtual ossim_uint32 getSizePerBand() const
Returns the number of pixels in a single band in a tile.
◆ loadState()
bool ossimImageToPlaneNormalFilter::loadState ( const ossimKeywordlist kwl,
const char *  prefix
virtual
Definition at line 293 of file ossimImageToPlaneNormalFilter.cpp.
References ossimKeywordlist::find(), ossimKeywordNames::SCALE_PER_PIXEL_X_KW, and ossimKeywordNames::SCALE_PER_PIXEL_Y_KW.
295 {
298  ossimString trackFlag = kwl.find(prefix, "track_scale_flag");
299  ossimString smoothness = kwl.find(prefix, SMOOTHNESS_FACTOR_KW);
300
301  if(scaleX != "")
302  {
303  theXScale = scaleX.toDouble();
304  }
305  if(scaleY != "")
306  {
307  theYScale = scaleY.toDouble();
308  }
309  if(trackFlag != "")
310  {
311  theTrackScaleFlag = trackFlag.toBool();
312  }
313  if(smoothness!="")
314  {
315  theSmoothnessFactor = smoothness.toDouble();
316  }
317
318  return ossimImageSourceFilter::loadState(kwl, prefix);
319 }
static const char * SCALE_PER_PIXEL_X_KW
bool toBool() const
String to numeric methods.
double toDouble() const
static const char * SCALE_PER_PIXEL_Y_KW
◆ saveState()
bool ossimImageToPlaneNormalFilter::saveState ( ossimKeywordlist kwl,
const char *  prefix
) const
virtual
Definition at line 321 of file ossimImageToPlaneNormalFilter.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::SCALE_PER_PIXEL_X_KW, ossimKeywordNames::SCALE_PER_PIXEL_Y_KW, theTrackScaleFlag, and theXScale.
323 {
324  kwl.add(prefix,
326  theXScale,
327  true);
328
329  kwl.add(prefix,
331  theXScale,
332  true);
333
334  kwl.add(prefix,
335  "track_scale_flag",
337  true);
338
339  kwl.add(prefix,
340  SMOOTHNESS_FACTOR_KW,
342  true);
343
344  return ossimImageSourceFilter::saveState(kwl, prefix);
345 }
◆ setProperty()
void ossimImageToPlaneNormalFilter::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Definition at line 424 of file ossimImageToPlaneNormalFilter.cpp.
References initialize(), ossimImageSourceFilter::setProperty(), theSmoothnessFactor, theTrackScaleFlag, theXScale, and theYScale.
425 {
426  ossimString name = property->getName();
427  if((name == "smoothnessFactor")||
428  (name == "gain"))
429  {
430  theSmoothnessFactor = property->valueToString().toDouble();
431  initialize();
432  }
433  else if(name == "xscale")
434  {
435  theXScale = property->valueToString().toDouble();
436  initialize();
437  }
438  else if(name == "yscale")
439  {
440  theYScale = property->valueToString().toDouble();
441  initialize();
442  }
443  else if(name == "autoTrackScaleFlag")
444  {
445  theTrackScaleFlag = property->valueToString().toDouble();
446  initialize();
447  }
448  else
449  {
451  }
452 }
◆ setSmoothnessFactor()
void ossimImageToPlaneNormalFilter::setSmoothnessFactor ( double  value)
◆ setTrackScaleFlag()
void ossimImageToPlaneNormalFilter::setTrackScaleFlag ( bool  flag)
◆ setXScale()
void ossimImageToPlaneNormalFilter::setXScale ( const double &  scale)
Definition at line 384 of file ossimImageToPlaneNormalFilter.cpp.
385 {
386  theXScale = scale;
387 }
◆ setYScale()
void ossimImageToPlaneNormalFilter::setYScale ( const double &  scale)
Definition at line 399 of file ossimImageToPlaneNormalFilter.cpp.
400 {
401  theYScale = scale;
402 }
Member Data Documentation
◆ theBlankTile
ossimRefPtr<ossimImageData> ossimImageToPlaneNormalFilter::theBlankTile
protected
Definition at line 56 of file ossimImageToPlaneNormalFilter.h.
Referenced by getTile(), and initialize().
◆ theInputBounds
ossimIrect ossimImageToPlaneNormalFilter::theInputBounds
protected
Definition at line 57 of file ossimImageToPlaneNormalFilter.h.
◆ theSmoothnessFactor
double ossimImageToPlaneNormalFilter::theSmoothnessFactor
protected
◆ theTile
ossimRefPtr<ossimImageData> ossimImageToPlaneNormalFilter::theTile
protected
Definition at line 55 of file ossimImageToPlaneNormalFilter.h.
Referenced by getTile(), initialize(), and initializeTile().
◆ theTrackScaleFlag
bool ossimImageToPlaneNormalFilter::theTrackScaleFlag
protected
◆ theXScale
double ossimImageToPlaneNormalFilter::theXScale
protected
◆ theYScale
double ossimImageToPlaneNormalFilter::theYScale
protected
