Functions | Variables
ossimKakaduPluginInit.cpp File Reference
#include <ossim/plugin/ossimPluginConstants.h>
#include "ossimKakaduOverviewBuilderFactory.h"
#include "ossimKakaduReaderFactory.h"
#include "ossimKakaduWriterFactory.h"
#include "ossimKakaduCodecFactory.h"
#include <ossim/plugin/ossimSharedObjectBridge.h>
#include <ossim/imaging/ossimImageHandlerRegistry.h>
#include <ossim/imaging/ossimCodecFactoryRegistry.h>
#include <ossim/imaging/ossimImageWriterFactoryRegistry.h>
#include <ossim/imaging/ossimOverviewBuilderFactoryRegistry.h>
#include "ossimKakaduJpipHandlerFactory.h"
#include "ossimKakaduJpipInfoFactory.h"
#include "ossimJpipProjectionFactory.h"
#include "ossimKakaduJpipImageGeometryFactory.h"
#include <ossim/support_data/ossimInfoFactoryRegistry.h>
#include <ossim/projection/ossimProjectionFactoryRegistry.h>
#include <ossim/imaging/ossimImageGeometryRegistry.h>
Go to the source code of this file.
Functions
const char * getKakaduDescription ()
int getKakaduNumberOfClassNames ()
const char * getKakaduClassName (int idx)
OSSIM_PLUGINS_DLL void ossimSharedLibraryInitialize (ossimSharedObjectInfo **info, const char *options)
OSSIM_PLUGINS_DLL void ossimSharedLibraryFinalize ()
Variables
ossimSharedObjectInfo myKakaduInfo
ossimString theKakaduDescription
std::vector< ossimStringtheKakaduObjList
Function Documentation
◆ getKakaduClassName()
const char* getKakaduClassName ( int  idx)
Definition at line 56 of file ossimKakaduPluginInit.cpp.
References theKakaduObjList.
Referenced by ossimSharedLibraryInitialize().
57  {
58  if(idx < (int)theKakaduObjList.size())
59  {
60  return theKakaduObjList[idx].c_str();
61  }
62  return (const char*)0;
63  }
std::vector< ossimString > theKakaduObjList
◆ getKakaduDescription()
const char* getKakaduDescription ( )
Definition at line 46 of file ossimKakaduPluginInit.cpp.
References ossimString::c_str(), and theKakaduDescription.
47  {
48  return theKakaduDescription.c_str();
49  }
const char * c_str() const
Definition: ossimString.h:396
◆ getKakaduNumberOfClassNames()
int getKakaduNumberOfClassNames ( )
Definition at line 51 of file ossimKakaduPluginInit.cpp.
52  {
53  return (int)theKakaduObjList.size();
54  }
◆ ossimSharedLibraryFinalize()
OSSIM_PLUGINS_DLL void ossimSharedLibraryFinalize ( )
Definition at line 164 of file ossimKakaduPluginInit.cpp.
References ossimKakaduJpipImageGeometryFactory::instance(), ossimImageGeometryRegistry::instance(), ossimImageWriterFactoryRegistry::instance(), ossimKakaduReaderFactory::instance(), ossimKakaduOverviewBuilderFactory::instance(), ossimKakaduWriterFactory::instance(), ossimOverviewBuilderFactoryRegistry::instance(), ossimImageHandlerRegistry::instance(), and ossimFactoryListInterface< T, NativeType >::unregisterFactory().
165  {
167  unregisterFactory(ossimKakaduReaderFactory::instance());
168
170  unregisterFactory(ossimKakaduOverviewBuilderFactory::instance());
171
173  unregisterFactory(ossimKakaduWriterFactory::instance());
174
176
177  }
static ossimImageGeometryRegistry * instance()
static ossimKakaduWriterFactory * instance()
static method to return instance (the only one) of this class.
static ossimImageWriterFactoryRegistry * instance()
static ossimKakaduJpipImageGeometryFactory * instance()
void unregisterFactory(T *factory)
Will remove the factory from the registry.
static ossimOverviewBuilderFactoryRegistry * instance()
instance method for access to theInstance pointer.
static ossimImageHandlerRegistry * instance()
static ossimKakaduOverviewBuilderFactory * instance()
static instance method.
static ossimKakaduReaderFactory * instance()
◆ ossimSharedLibraryInitialize()
OSSIM_PLUGINS_DLL void ossimSharedLibraryInitialize ( ossimSharedObjectInfo **  info,
const char *  options
Definition at line 66 of file ossimKakaduPluginInit.cpp.
References ossimKeywordlist::find(), ossimSharedObjectInfo::getClassName, ossimSharedObjectInfo::getDescription, getKakaduClassName(), getKakaduDescription(), getKakaduNumberOfClassNames(), ossimSharedObjectInfo::getNumberOfClassNames, ossimKakaduJpipImageGeometryFactory::instance(), ossimCodecFactoryRegistry::instance(), ossimJpipProjectionFactory::instance(), ossimKakaduJpipInfoFactory::instance(), ossimImageGeometryRegistry::instance(), ossimProjectionFactoryRegistry::instance(), ossimImageWriterFactoryRegistry::instance(), ossimKakaduReaderFactory::instance(), ossimKakaduJpipHandlerFactory::instance(), ossimKakaduOverviewBuilderFactory::instance(), ossimKakaduWriterFactory::instance(), ossimKakaduCodecFactory::instance(), ossimInfoFactoryRegistry::instance(), ossimOverviewBuilderFactoryRegistry::instance(), ossimImageHandlerRegistry::instance(), myKakaduInfo, ossimKeywordlist::parseString(), ossimInfoFactoryRegistry::registerFactory(), ossimFactoryListInterface< T, NativeType >::registerFactory(), ossimInfoFactoryRegistry::registerFactoryToFront(), and ossimFactoryListInterface< T, NativeType >::registerFactoryToFront().
69  {
73
74  *info = &myKakaduInfo;
75  ossimKeywordlist kwl;
76  kwl.parseString(ossimString(options));
77  if(ossimString(kwl.find("reader_factory.location")).downcase() == "front")
78  {
79  /* Register the readers... */
81  registerFactoryToFront(ossimKakaduReaderFactory::instance());
82
84  registerFactoryToFront(ossimKakaduJpipHandlerFactory::instance());
85  }
86  else
87  {
88  /* Register the readers... */
90  registerFactory(ossimKakaduReaderFactory::instance());
92  registerFactory(ossimKakaduJpipHandlerFactory::instance());
93  }
94
95
96  if(ossimString(kwl.find("overview_builder_factory.location")).downcase() == "front")
97  {
98  /* Register the overview buildeds. */
100  registerFactoryToFront(ossimKakaduOverviewBuilderFactory::instance());
101  }
102  else
103  {
104  /* Register the overview buildeds. */
107  false);
108  }
109
110  if(ossimString(kwl.find("writer_factory.location")).downcase() == "front")
111  {
112  /* Register the writers... */
114  registerFactoryToFront(ossimKakaduWriterFactory::instance());
115
116  }
117  else
118  {
119
120  /* Register the writers... */
122  registerFactory(ossimKakaduWriterFactory::instance());
123
124  }
125  if(ossimString(kwl.find("projection_factory.location")).downcase() == "front")
126  {
128
129  }
130  else
131  {
133  }
134  if(ossimString(kwl.find("info_factory.location")).downcase() == "front")
135  {
137
138  }
139  else
140  {
142  }
143  if(ossimString(kwl.find("image_geometry_factory.location")).downcase() == "front")
144  {
146  }
147  else
148  {
150  }
152
153  setKakaduDescription(theKakaduDescription);
160  theKakaduObjList.push_back("ossimKakaduJpipInfo");
161  }
static ossimCodecFactoryRegistry * instance()
static ossimKakaduJpipInfoFactory * instance()
ossimSharedLibraryGetNumberOfClassNamesPtr getNumberOfClassNames
virtual void getTypeNameList(std::vector< ossimString > &typeList) const
Adds "ossimKakaduWriter" to list.
Method to populate a list of supported types for the factory.
static ossimKakaduJpipHandlerFactory * instance()
void registerFactoryToFront(ossimInfoFactoryInterface *factory)
Adds factory to the front of the registry.
void registerFactoryToFront(T *factory)
Inserts the factory to the front of the list.
const char * getKakaduDescription()
Adds ossimKakaduWriter to the typeList.
ossimSharedLibraryGetDescriptionPtr getDescription
const char * getKakaduClassName(int idx)
void registerFactory(T *factory, bool pushToFrontFlag=false)
Will register a factory to the factory list.
virtual bool parseString(const std::string &inString)
ossimSharedLibraryGetClassNamesPtr getClassName
static ossimProjectionFactoryRegistry * instance()
static ossimInfoFactoryRegistry * instance()
instance method
int getKakaduNumberOfClassNames()
static ossimKakaduCodecFactory * instance()
static ossimJpipProjectionFactory * instance()
void registerFactory(ossimInfoFactoryInterface *factory)
Method to add factory to registry.
Variable Documentation
◆ myKakaduInfo
Definition at line 42 of file ossimKakaduPluginInit.cpp.
◆ theKakaduDescription
Definition at line 43 of file ossimKakaduPluginInit.cpp.
Referenced by getKakaduDescription().
◆ theKakaduObjList
std::vector<ossimString> theKakaduObjList
Definition at line 44 of file ossimKakaduPluginInit.cpp.
Referenced by getKakaduClassName(), and getKakaduNumberOfClassNames().
