ossimMG4LidarReader.cpp
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // License: LGPL
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Description: Class definition for MRSID MG4 reader.
8 //
9 // Author: Mingjie Su
10 //
11 //----------------------------------------------------------------------------
12 // $Id: ossimMG4LidarReader.cpp 2645 2011-05-26 15:21:34Z oscar.kramer $
13
14 #include <fstream>
15 #include <iostream>
16 #include <string>
17
18 //ossim includes
19 #include <ossim/base/ossimCommon.h>
20 #include <ossim/base/ossimDpt.h>
21 #include <ossim/base/ossimEndian.h>
25 #include <ossim/base/ossimNotify.h>
27 #include <ossim/base/ossimTrace.h>
29
32
37
39 #include <ogr_spatialref.h>
40
41 #include "ossimMG4LidarReader.h"
42
43 #ifdef OSSIM_ID_ENABLED
44 static const char OSSIM_ID[] = "$Id";
45 #endif
46
47 // Resolution Ratio between adjacent levels.
48
49 static double maxRasterSize = 2048.0;
50 static double maxBlockSideSize = 1024.0;
51
52 static ossimTrace traceDebug("ossimMG4LidarReader:debug");
53 static ossimTrace traceDump("ossimMG4LidarReader:dump");
54 //static ossimOgcWktTranslator wktTranslator;
55
57  "ossimMG4LidarReader",
59
62  m_reader(NULL),
63  m_imageRect(),
64  m_numberOfSamples(0),
65  m_numberOfLines(0),
66  m_scalarType(OSSIM_SCALAR_UNKNOWN),
67  m_tile(0)
68 {
69 }
70
72 {
73  closeEntry();
74 }
75
77 {
78  return ossimString("ossim_mg4_lidar_reader");
79 }
80
82 {
83  return ossimString("ossim mg4 lidar reader");
84 }
85
87 {
88  return ossimString("ossimMG4LidarReader");
89 }
90
92 {
93  ossim_uint32 result = 1; // Add r0
94
95  if (theOverview.valid())
96  {
97  //---
98  // Add external overviews.
99  //---
101  }
102
103  return result;
104 }
105
107  ossim_uint32 resLevel) const
108 {
109  if (theOverview.valid())
110  {
111  return theOverview->getNumberOfSamples(resLevel);
112  }
113  return m_numberOfLines;
114 }
115
117  ossim_uint32 resLevel) const
118 {
119  if (theOverview.valid())
120  {
121  return theOverview->getNumberOfSamples(resLevel);
122  }
123  return m_numberOfSamples;
124 }
125
127 {
128  static const char MODULE[] = "ossimMG4LidarReader::open";
129
130  if (traceDebug())
131  {
133  << MODULE << " entered...\n"
134  << "image: " << theImageFile << "\n";
135  }
136
137  bool result = false;
138
139  if(isOpen())
140  {
141  closeEntry();
142  }
143
144  int gen = 0;
145  bool raster = false;
146  result = Version::getMrSIDFileVersion(theImageFile.c_str(), gen, raster);
147  if (result == false)
148  {
149  return result;
150  }
151
152  m_reader = MG4PointReader::create();
153  m_reader->init(theImageFile.c_str());
154  m_bounds = m_reader->getBounds();
155
156  int numPoints = m_reader->getNumPoints();
157  m_numberOfSamples = m_bounds.x.length();
158  m_numberOfLines = m_bounds.y.length();
159
160  double pts_per_area = ((double)m_reader->getNumPoints())/(m_bounds.x.length()*m_bounds.y.length());
161  double average_pt_spacing = sqrt(1.0 / pts_per_area) ;
162  double cell_side = average_pt_spacing;
163  maxRasterSize = std::max(m_bounds.x.length()/cell_side, m_bounds.y.length()/cell_side);
164  //openZoomLevel(0);
165
166  //get data type from X channel as default
167  getDataType(0);
168
170  {
172
173  m_tile->initialize();
174
175  // Call the base complete open to pick up overviews.
176  completeOpen();
177
178  result = true;
179  }
180
181  if (result == false)
182  {
183  closeEntry();
184  }
185
186  if (traceDebug())
187  {
189  << MODULE << " exit status = " << (result?"true":"false\n")
190  << std::endl;
191  }
192
193  return result;
194 }
195
197 {
198  // geo dimensions
199  const double gWidth = m_reader->getBounds().x.length() ;
200  const double gHeight = m_reader->getBounds().y.length() ;
201
202  // geo res
203  double xRes = pow(2.0, zoom) * gWidth / maxRasterSize ;
204  double yRes = pow(2.0, zoom) * gHeight / maxRasterSize ;
205  xRes = yRes = std::max(xRes, yRes);
206
207  // pixel dimensions
208  m_numberOfSamples = static_cast<int>(gWidth / xRes + 0.5);
209  m_numberOfLines = static_cast<int>(gHeight / yRes + 0.5);
210 }
211
213 {
214  return m_tile.get();
215 }
216
218 {
219  m_tile = 0;
220
221  if (m_reader)
222  {
223  RELEASE(m_reader);
224  m_reader = 0;
225  }
227 }
228
230  const ossimIrect& rect, ossim_uint32 resLevel)
231 {
232  // This tile source bypassed, or invalid res level, return null tile.
233  if(!isSourceEnabled() || !isOpen() || !isValidRLevel(resLevel))
234  {
236  }
237
238  ossimIrect imageBound = getBoundingRect(resLevel);
239  if(!rect.intersects(imageBound))
240  {
242  }
243
244  // Check for overview.
245  if( resLevel > 0 )
246  {
247  if(theOverview.valid())
248  {
249  ossimRefPtr<ossimImageData> tileData = theOverview->getTile(rect, resLevel);
250  tileData->setScalarType(getOutputScalarType());
251  return tileData;
252  }
253  }
254
255  m_tile->setImageRectangle(rect);
256
257  // Compute clip rectangle with respect to the image bounds.
258  ossimIrect clipRect = rect.clipToRect(imageBound);
259
260  if (rect.completely_within(clipRect) == false)
261  {
262  // Not filling whole tile so blank it out first.
263  m_tile->makeBlank();
264  }
265
266  // access the point cloud with PointSource::read()
267  const ossimDpt UL_PT(m_bounds.x.min + clipRect.ul().x, m_bounds.y.min + clipRect.ul().y);
268  const ossimDpt LR_PT(m_bounds.x.min + clipRect.ul().x + clipRect.width(), m_bounds.y.min + clipRect.ul().y + clipRect.height());
269
270  Bounds bounds(UL_PT.lon, LR_PT.lon,
271  UL_PT.lat, LR_PT.lat,
272  -HUGE_VAL, +HUGE_VAL);
273
274  ossim_float32 fraction = 1.0/pow(2.0, (double)resLevel);
275
276  PointIterator* iter = m_reader->createIterator(bounds, fraction, m_reader->getPointInfo(), NULL);
277
278  // create a buffer to store the point data
279  PointData points;
280  points.init(m_reader->getPointInfo(), clipRect.width()*clipRect.height());
281
282  size_t count = 0;
283  ossimDpt lasPt;
284  double* dataValues = new double[clipRect.width()*clipRect.height()];
285  while((count = iter->getNextPoints(points)) != 0)
286  {
287  //loop through each point
288  for(size_t i = 0; i < count; i += 1)
289  {
290  const ChannelData* channelX = points.getChannel(CHANNEL_NAME_X);
291  const ChannelData* channelY = points.getChannel(CHANNEL_NAME_Y);
292  const ChannelData* channelZ = points.getChannel(CHANNEL_NAME_Z);
293
294  const void *dataX = channelX->getData();
295  const void *dataY = channelY->getData();
296  const void *dataZ = channelZ->getData();
297
298  lasPt.x = static_cast<const double*>(dataX)[i];
299  lasPt.y = static_cast<const double*>(dataY)[i];
300
301  ossim_int32 line = static_cast<ossim_int32>(lasPt.y - UL_PT.y);
302  ossim_int32 samp = static_cast<ossim_int32>(lasPt.x - UL_PT.x);
303  ossim_int32 bufIndex = line * clipRect.width() + samp;
304
305  if (bufIndex < clipRect.width()*clipRect.height())
306  {
307  dataValues[bufIndex] = static_cast<const double*>(dataZ)[i];
308  }
309  }
310  }
311  RELEASE(iter);
312
313  m_tile->loadBand((void*)dataValues, clipRect, 0);
314  m_tile->validate();
315
316  delete[] dataValues;
317
318  return m_tile;
319 }
320
322 {
323  return 1;
324 }
325
327 {
328  return 1;
329 }
330
332 {
333  return 0;
334 }
335
337 {
338  return 0;
339 }
340
342 {
343  return m_scalarType;
344 }
345
347 {
348  if ( !theGeometry )
349  {
350  //---
351  // Check for external geom:
352  //---
354
355  if ( !theGeometry )
356  {
357  //---
358  // Check the internal geometry first to avoid a factory call.
359  //---
361
362  // At this point it is assured theGeometry is set.
363
364  // Check for set projection.
365  if ( !theGeometry->getProjection() )
366  {
367  // Try factories for projection.
369  }
370  }
371
372  // Set image things the geometry object should know about.
374  }
375
376  return theGeometry;
377 }
378
380 {
381  static const char MODULE[] = "ossimMG4LidarReader::getInternalImageGeometry";
382  if (traceDebug())
383  {
384  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
385  }
386
388
389  // Must cast away constness.
390  ossimMG4LidarReader* th = const_cast<ossimMG4LidarReader*>(this);
392
393  geom->setProjection(proj.get());
394
395  return geom;
396 }
397
399  const char* prefix)
400 {
401  bool result = false;
402
403  if ( ossimImageHandler::loadState(kwl, prefix) )
404  {
405  result = open();
406  }
407
408  return result;
409 }
410
412 {
413  if (m_reader)
414  {
415  DataType pixelType = m_reader->getChannel(channelId).getDataType();
416  switch (pixelType)
417  {
418  case DATATYPE_UINT8:
419  {
421  break;
422  }
423  case DATATYPE_SINT8:
424  {
426  break;
427  }
428  case DATATYPE_UINT16:
429  {
431  break;
432  }
433  case DATATYPE_SINT16:
434  {
436  break;
437  }
438  case DATATYPE_UINT32:
439  {
441  break;
442  }
443  case DATATYPE_SINT32:
444  {
446  break;
447  }
448  case DATATYPE_FLOAT32:
449  {
451  break;
452  }
453  case DATATYPE_FLOAT64:
454  {
456  break;
457  }
458  default:
459  {
461  break;
462  }
463  }
464  }
465 }
466
468 {
469  ossimProjection* proj = NULL;
470  if (m_reader)
471  {
472  const char* wkt = m_reader->getWKT();
473  if (wkt)
474  {
475  OGRSpatialReferenceH hSRS = NULL;
476
477  //Translate the WKT into an OGRSpatialReference.
478  hSRS = OSRNewSpatialReference(NULL);
479  if(OSRImportFromWkt( hSRS, (char**)&wkt) != OGRERR_NONE)
480  {
481  OSRDestroySpatialReference( hSRS );
482  return NULL;
483  }
484
485  //Determine if State Plane Coordinate System
486  const char* epsg_code = OSRGetAttrValue(hSRS, "AUTHORITY", 1);
488
489  //get unit type
490  ossimUnitType unitType = OSSIM_METERS;
491  const char* units = OSRGetAttrValue(hSRS, "UNIT", 0);
492  bool bGeog = OSRIsGeographic(hSRS);
493  if (bGeog == false)
494  {
495  if ( units != NULL )
496  {
497  // Down case to avoid case mismatch.
498  ossimString s = units;
499  s.downcase();
500
501  if( ( s == ossimString("us survey foot") ) ||
502  ( s == ossimString("u.s. foot") ) ||
503  ( s == ossimString("foot_us") ) )
504  {
505  unitType = OSSIM_US_SURVEY_FEET;
506  }
507  else if( s == ossimString("degree") )
508  {
509  unitType = OSSIM_DEGREES;
510  }
511  else if( s == ossimString("feet") )
512  {
513  unitType = OSSIM_FEET;
514  }
515  }
516  }
517  else
518  {
519  unitType = OSSIM_DEGREES;
520  }
521
522  //set ul tie point and gsd
523  ossimMapProjection* mapProj = dynamic_cast<ossimMapProjection*>(proj);
524  if (mapProj)
525  {
526  double xMin = m_reader->getBounds().x.min;
527  double yMax = m_reader->getBounds().y.max;
528  double xRes = m_reader->getBounds().x.length()/m_numberOfSamples;
529  double yRes = m_reader->getBounds().y.length()/m_numberOfLines;
530  ossimDpt gsd(xRes, yRes);
531  if (mapProj->isGeographic())
532  {
533  ossimGpt tie(yMax, xMin);
534  mapProj->setUlTiePoints(tie);
535  mapProj->setDecimalDegreesPerPixel(gsd);
536  }
537  else
538  {
539  ossimDpt tie(xMin, yMax);
540  if ( unitType == OSSIM_US_SURVEY_FEET)
541  {
542  gsd = gsd * US_METERS_PER_FT;
543  tie = tie * US_METERS_PER_FT;
544  }
545  else if ( unitType == OSSIM_FEET )
546  {
547  gsd = gsd * MTRS_PER_FT;
548  tie = tie * MTRS_PER_FT;
549  }
550  mapProj->setUlTiePoints(tie);
551  mapProj->setMetersPerPixel(gsd);
552  }
553  }
554  return proj;
555  }
556  }
557  return proj;
558 }
559
560 template<typename DTYPE>
561 const DTYPE ossimMG4LidarReader::getChannelElement(const ChannelData* channel, size_t idx)
562 {
563  DTYPE retval = static_cast<DTYPE>(0);
564  switch (channel->getDataType())
565  {
566  case (DATATYPE_FLOAT64):
567  retval = static_cast<DTYPE>(static_cast<const double*>(channel->getData())[idx]);
568  break;
569  case (DATATYPE_FLOAT32):
570  retval = static_cast<DTYPE>(static_cast<const float *>(channel->getData())[idx]);
571  break;
572  case (DATATYPE_SINT32):
573  retval = static_cast<DTYPE>(static_cast<const long *>(channel->getData())[idx]);
574  break;
575  case (DATATYPE_UINT32):
576  retval = static_cast<DTYPE>(static_cast<const unsigned long *>(channel->getData())[idx]);
577  break;
578  case (DATATYPE_SINT16):
579  retval = static_cast<DTYPE>(static_cast<const short *>(channel->getData())[idx]);
580  break;
581  case (DATATYPE_UINT16):
582  retval = static_cast<DTYPE>(static_cast<const unsigned short *>(channel->getData())[idx]);
583  break;
584  case (DATATYPE_SINT8):
585  retval = static_cast<DTYPE>(static_cast<const char *>(channel->getData())[idx]);
586  break;
587  case (DATATYPE_UINT8):
588  retval = static_cast<DTYPE>(static_cast<const unsigned char *>(channel->getData())[idx]);
589  break;
590  case (DATATYPE_SINT64):
591  retval = static_cast<DTYPE>(static_cast<const GIntBig *>(channel->getData())[idx]);
592  break;
593  case (DATATYPE_UINT64):
594  retval = static_cast<DTYPE>(static_cast<const GUIntBig *>(channel->getData())[idx]);
595  break;
596  default:
597  break;
598  }
599  return retval;
600 }
601
virtual ossim_uint32 getNumberOfDecimationLevels() const
Returns the number of decimation levels.
virtual void loadBand(const void *src, const ossimIrect &src_rect, ossim_uint32 band)
8 bit signed integer
virtual ossim_uint32 getImageTileWidth() const
static ossimImageGeometryRegistry * instance()
ossimRefPtr< ossimImageGeometry > theGeometry
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
64 bit floating point
ossimFilename theImageFile
virtual bool open()
Open method.
16 bit unsigned integer
ossimUnitType
virtual ossimString getClassName() const
Returns class name.
bool valid() const
Definition: ossimRefPtr.h:75
RTTI_DEF1_INST(ossimMG4LidarReader, "ossimMG4LidarReader", ossimImageHandler) ossimMG4LidarReader
float ossim_float32
double y
Definition: ossimDpt.h:165
ossim_uint32 height() const
Definition: ossimIrect.h:487
virtual void closeEntry()
Method to close current entry.
virtual bool isOpen() const
Method to test for open file stream.
virtual bool isGeographic() const
16 bit signed integer
const ossimIpt & ul() const
Definition: ossimIrect.h:274
virtual void setDecimalDegreesPerPixel(const ossimDpt &gsd)
32 bit floating point
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
32 bit unsigned integer
ossimScalarType m_scalarType
virtual bool extendGeometry(ossimImageHandler *handler) const
virtual void initialize()
Initialize the data buffer.
virtual void setMetersPerPixel(const ossimDpt &gsd)
This returns the total number of decimation levels.
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
bool completely_within(const ossimIrect &rect) const
Definition: ossimIrect.cpp:425
virtual ossimRefPtr< ossimImageGeometry > getInternalImageGeometry() const
#define US_METERS_PER_FT
ossim_uint32 m_numberOfSamples
Has sub image offset.
ossimProjection * getGeoProjection()
ossimProjection * createProjection(const ossimFilename &filename, ossim_uint32 entryIdx) const
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const
Gets the number of samples for res level.
void getDataType(ossim_int32 channelId)
32 bit signed integer
unsigned int ossim_uint32
virtual ossimString getShortName() const
Returns short name.
virtual void close()
ossim_uint32 width() const
Definition: ossimIrect.h:500
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
virtual ~ossimMG4LidarReader()
virtural destructor
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
ossimScalarType
virtual ossim_uint32 getNumberOfInputBands() const
Returns the number of bands in the image.
static ossimProjectionFactoryRegistry * instance()
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
#define MTRS_PER_FT
virtual void makeBlank()
virtual void completeOpen()
Will complete the opening process.
ossimRefPtr< ossimImageHandler > theOverview
void openZoomLevel(ossim_int32 zoom)
ossimRefPtr< ossimImageData > m_tile
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual ossim_uint32 getImageTileHeight() const
#define max(a, b)
Definition: auxiliary.h:76
ossim_int32 y
Definition: ossimIpt.h:142
double x
Definition: ossimDpt.h:164
virtual ossimString getLongName() const
Returns long name.
const char * c_str() const
Definition: ossimString.h:396
virtual void setUlTiePoints(const ossimGpt &gpt)
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
Returns zero-based bounding rectangle of the image.
ossim_int32 x
Definition: ossimIpt.h:141
8 bit unsigned integer
virtual void setScalarType(ossimScalarType type)
See ossimScalarType in ossimConstants for a full list.
default construtor
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &rect, ossim_uint32 resLevel=0)
Method to grab a tile(rectangle) from image.
MG4PointReader * m_reader
int ossim_int32
const DTYPE getChannelElement(const ChannelData *channel, size_t idx)
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const
Gets number of lines for res level.
