ossimTerraSarTiffReader.cpp
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // License: See top level LICENSE.txt file
4 //
5 // Author: David Burken
6 //
7 // Description: Image handelr for TerraSar-X data that is TIFF based.
8 //
9 //----------------------------------------------------------------------------
10 // $Id$
11
14 #include <ossimTerraSarModel.h>
19 #include <ossim/base/ossimTrace.h>
20 #include <ossim/base/ossimNotify.h>
26
27 // Keyword constants:
28 static const char PRODUCT_XML_FILE_KW[] = "product_xml_filename";
29
30 namespace ossimplugins
31 {
32 RTTI_DEF1(ossimTerraSarTiffReader,
33  "ossimTerraSarTiffReader",
35 }
36
37 #ifdef OSSIM_ID_ENABLED
38  static const char OSSIM_ID[] = "$Id$";
39 #endif
40
41 static ossimTrace traceDebug("ossimTerraSarTiffReader:degug");
42
44  :
46 {
47  if (traceDebug())
48  {
50  << "ossimplugins::ossimTerraSarTiffReader::ossimTerraSarTiffReader entered...\n";
51 #ifdef OSSIM_ID_ENABLED
53  << "OSSIM_ID: " << OSSIM_ID << std::endl;
54 #endif
55  }
56 }
57
59 {
60 }
61
63  ossimKeywordlist& kwl, const char* prefix) const
64 {
65  static const char MODULE[] = "ossimplugins::ossimTerraSarTiffReader::saveState";
66
67  if (traceDebug())
68  {
70  << MODULE << " entered...\n";
71  }
72
73  // Save our state:
74  kwl.add(prefix, PRODUCT_XML_FILE_KW, theProductXmlFile.c_str());
75
76  // Save the base:
77  return ossimTiffTileSource::saveState(kwl, prefix);
78 }
79
81  const ossimKeywordlist& kwl, const char* prefix)
82 {
83  static const char MODULE[] = "ossimplugins::ossimTerraSarTiffReader::loadState";
84
85  if (traceDebug())
86  {
88  << MODULE << " entered...\n";
89  }
90
91  bool result = false;
92
93  // Get the product.xml file name.
94  const char* lookup = kwl.find(prefix, PRODUCT_XML_FILE_KW);
95  if (lookup)
96  {
97  theProductXmlFile = lookup;
98  if ( isTerraSarProductFile(theProductXmlFile) )
99  {
100  //---
101  // Although we can open any tiff here we only do if we have matching
102  // TerraSAR-X product.xml.
103  //---
104  result = ossimTiffTileSource::loadState(kwl, prefix);
105  }
106  }
107
108  if (!result)
109  {
110  theProductXmlFile.clear();
111  }
112
113  if (traceDebug())
114  {
116  << MODULE << " exit status = " << (result?"true":"false\n")
117  << std::endl;
118  }
119
120  return result;
121 }
122
124 {
125  return ossimString("ossim_terrasar_tiff_reader");
126 }
127
129 {
130  return ossimString("ossim TerraSAR-X tiff reader");
131 }
132
134 {
135  return ossimString("ossimTerraSarTiffReader");
136 }
137
139 {
140  static const char MODULE[] = "ossimplugins::ossimTerraSarTiffReader::open";
141
142  if (traceDebug())
143  {
145  << MODULE << " entered...\n"
146  << "file: " << file << "\n";
147  }
148
149  bool result = false;
150
151  if ( isOpen() )
152  {
153  close();
154  }
155
156  // Check extension to see if it's xml.
157  if ( file.ext().downcase() == "xml" )
158  {
160  if ( xdoc->openFile(file) )
161  {
162  // See if it's a TerraSAR-X product xml file.
163  if ( isTerraSarProductFile( xdoc.get() ) )
164  {
165  ossimString s;
167
168  if ( helper.getImageFile(xdoc.get(), s) )
169  {
170  ossimFilename imageFile = file.expand().path();
171  imageFile = imageFile.dirCat(s);
172
173  setFilename(imageFile);
174
175  result = ossimTiffTileSource::open();
176  if (result)
177  {
178  theProductXmlFile = file;
179
180  completeOpen();
181  }
182  }
183  }
184  }
185
186  } // matches: if ( file.ext().downcase() == "xml" )
187
188  if (traceDebug())
189  {
191  << MODULE << " exit status = " << (result?"true":"false\n")
192  << std::endl;
193  }
194
195  return result;
196 }
197
199 {
200  theProductXmlFile.clear();
202 }
203
205 {
206  if ( !theGeometry )
207  {
208  // Check for external geom:
209  theGeometry = getExternalImageGeometry();
210
211  if ( !theGeometry )
212  {
213  // Check the internal geometry first to avoid a factory call.
214  theGeometry = getInternalImageGeometry();
215
216  // At this point it is assured theGeometry is set.
217
218  //---
219  // WARNING:
220  // Must create/set theGeometry at this point or the next call to
221  // ossimImageGeometryRegistry::extendGeometry will put us in an infinite loop
222  // as it does a recursive call back to ossimImageHandler::getImageGeometry().
223  //---
224
225  // Check for set projection.
226  if ( !theGeometry->getProjection() )
227  {
228  // Try factories for projection.
230  }
231  }
232
233  // Set image things the geometry object should know about.
234  initImageParameters( theGeometry.get() );
235  }
236
237  return theGeometry;
238 }
239
242 {
243  static const char MODULE[] = "ossimplugins::ossimTerraSarTiffReader::getInternalImageGeometry";
244  if (traceDebug())
245  {
246  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
247  }
248
250
252  if ( xdoc->openFile(theProductXmlFile) )
253  {
255  ossimString s;
256  if ( helper.getProjection(xdoc.get(), s) )
257  {
258  s.upcase();
259  if ( s == "GROUNDRANGE" )
260  {
262  new ossimTerraSarModel();
263  if ( model->open(theProductXmlFile) )
264  {
265  // Assign the model to our ossimImageGeometry object.
266  geom->setProjection( model.get() );
267  }
268  }
269  else if ( (s == "MAP") && theTiffPtr )
270  {
271  ossimGeoTiff geotiff;
272
273  //---
274  // Note: must pass false to readTags so it doesn't close our
275  // tiff pointer.
276  //---
277  geotiff.readTags(theTiffPtr, getCurrentEntry(), false);
278  ossimKeywordlist kwl;
279  if(geotiff.addImageGeometry(kwl))
280  {
283  createProjection(kwl);
284
285  if ( proj.valid() )
286  {
287  // Assign projection to our ossimImageGeometry object.
288  geom->setProjection( proj.get() );
289  }
290  }
291  }
292  else
293  {
294  if (traceDebug())
295  {
297  << "WARNING: Unhandled projection: " << s << std::endl;
298
299  }
300  }
301  }
302
303  } // matches: if ( xdoc->openFile(theProductXmlFile) )
304
305  if (traceDebug())
306  {
307  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited..." << std::endl;
308  }
309
310  return geom;
311 }
312
314  const ossimFilename& file) const
315 {
316  bool result = false;
317
318  // Check extension to see if it's xml.
319  if ( file.ext().downcase() == "xml" )
320  {
322  if ( xdoc->openFile(file) )
323  {
324  result = isTerraSarProductFile( xdoc.get() );
325  }
326  }
327
328  return result;
329 }
330
332  const ossimXmlDocument* xdoc) const
333 {
334  bool result = false;
335
336  if (xdoc)
337  {
339
340  // See if it's a TerraSAR-X product xml file.
341  result = helper.isTerraSarX(xdoc);
342  }
343
344  return result;
345 }
Class to encapsulate parsing TerraSAR product xml file.
static ossimImageGeometryRegistry * instance()
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
bool open()
Returns true if no errors initializing object.
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
bool getProjection(const ossimXmlDocument *xdoc, ossimString &s) const
bool isTerraSarProductFile(const ossimFilename &file) const
Method to check file to see if it&#39;s a TerraSAR-X product xml file.
bool isTerraSarX(const ossimXmlDocument *xdoc) const
Checks for node /level1Product/generalHeader/mission containing "TSX-1".
bool addImageGeometry(ossimKeywordlist &kwl, const char *prefix=0) const
Add geometry info from tags to keword list.
RTTI_DEF1(ossimAlosPalsarModel, "ossimAlosPalsarModel", ossimGeometricSarSensorModel)
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossimRefPtr< ossimImageGeometry > getInternalImageGeometry() const
ossimFilename expand() const
Method to do file name expansion.
This class allows for direct localisation and indirect localisation using the TerraSar sensor model...
virtual bool extendGeometry(ossimImageHandler *handler) const
bool openFile(const ossimFilename &filename)
virtual void close()
bool open(const ossimFilename &file)
Method to intantial model from a file.
static ossimProjectionFactoryRegistry * instance()
bool getImageFile(const ossimXmlDocument *xdoc, ossimString &s) const
ossimFilename dirCat(const ossimFilename &file) const
ossimString ext() const
bool readTags(const ossimFilename &file, ossim_uint32 entryIdx=0)
Reads tags.
virtual ~ossimTerraSarTiffReader()
virtual destructor
ossimFilename path() const
