For engineering use in ATP. More...
#include <AtpAnnotatedImage.h>
AtpAnnotatedImage (ossimRefPtr< ossimImageChain > &sourceChain, ossimRefPtr< ossimImageViewProjectionTransform > &ivt, const ossimDrect &aoi) | |
~AtpAnnotatedImage () | |
void | setImageName (const std::string &name) |
void | setAOI (const ossimDrect &aoi) |
void | annotateFeatureSearchTiles (std::vector< ossimIrect > &tileRects) |
void | annotateFeatures (std::vector< ossimDpt > &atpList, int r, int g, int b) |
void | annotateCorrelations (AtpList &atpList, int r, int g, int b) |
void | annotateCorrelationSearchTile (const ossimIrect &tileRect) |
void | annotateOverlap (ossimPolygon &poly) |
void | annotateResiduals (AtpList &atps, int r, int g, int b) |
void | annotateTPIDs (AtpList &atps, int r, int g, int b) |
void | annotateCorrBoxes (AtpList &atpList, int r) |
bool | write () |
ossimImageChain () | |
virtual | ~ossimImageChain () |
ossimConnectableObject::ConnectableObjectList & | getChainList () |
const ossimConnectableObject::ConnectableObjectList & | getChainList () const |
ossimConnectableObject * | operator[] (ossim_uint32 index) |
virtual ossimConnectableObject * | getConnectableObject (ossim_uint32 index) |
Same as operator[](ossim_uint32 i) More... | |
virtual ossim_int32 | indexOf (ossimConnectableObject *obj) const |
virtual ossimImageSource * | getFirstSource () |
Return the first source which is the one that first receives the getTile request. More... | |
virtual const ossimImageSource * | getFirstSource () const |
virtual ossimObject * | getFirstObject () |
virtual ossimImageSource * | getLastSource () |
Return the last source which is the one that last receives the getTile request. More... | |
virtual const ossimImageSource * | getLastSource () const |
virtual ossimObject * | getLastObject () |
bool | addFirst (ossimConnectableObject *obj) |
Adds it to the start of the chain. More... | |
bool | addLast (ossimConnectableObject *obj) |
Adds it to the end. More... | |
bool | deleteFirst () |
Deletes the first object. More... | |
bool | deleteLast () |
Deletes the last object. More... | |
bool | insertRight (ossimConnectableObject *newObj, ossimConnectableObject *rightOfThisObj) |
bool | insertRight (ossimConnectableObject *newObj, const ossimId &id) |
bool | insertLeft (ossimConnectableObject *newObj, const ossimId &id) |
bool | insertLeft (ossimConnectableObject *newObj, ossimConnectableObject *leftOfThisObj) |
bool | replace (ossimConnectableObject *newObj, ossimConnectableObject *oldObj) |
virtual bool | add (ossimConnectableObject *source) |
Will return true or false if an image source was added to the chain. More... | |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
Within the image chain will pass the head of the list. More... | |
virtual ossim_uint32 | getNumberOfInputBands () const |
this call is passed to the head of the list. More... | |
virtual ossimScalarType | getOutputScalarType () const |
This call is passed to the head of the list. More... | |
virtual double | getNullPixelValue (ossim_uint32 band=0) const |
Each band has a null pixel associated with it. More... | |
virtual double | getMinPixelValue (ossim_uint32 band=0) const |
Returns the min pixel of the band. More... | |
virtual double | getMaxPixelValue (ossim_uint32 band=0) const |
Returns the max pixel of the band. More... | |
virtual void | getOutputBandList (std::vector< ossim_uint32 > &bandList) const |
Initializes bandList. More... | |
virtual ossim_uint32 | getTileWidth () const |
virtual ossim_uint32 | getTileHeight () const |
virtual ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
Will pass this call to the head of the list. More... | |
virtual void | getValidImageVertices (vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
Returns the image geometry object associated with this tile source or NULL if not defined. More... | |
virtual void | getDecimationFactor (ossim_uint32 resLevel, ossimDpt &result) const |
Will return the decimation factor for the given resolution level. More... | |
virtual void | getDecimationFactors (vector< ossimDpt > &decimations) const |
virtual ossim_uint32 | getNumberOfDecimationLevels () const |
Will return the number of resolution levels. More... | |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
Will save the state of the chain. More... | |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
Will load the state. More... | |
virtual void | initialize () |
virtual void | enableSource () |
virtual void | disableSource () |
bool | canConnectMyInputTo (ossim_int32 myInputIndex, const ossimConnectableObject *object) const |
required to be overriden by derived classes More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject::ConnectableObjectList findAllObjectsOfType(const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject::ConnectableObjectList findAllObjectsOfType(const ossimString &className, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findFirstObjectOfType(const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findFirstObjectOfType(const ossimString &className, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObject(const ossimId &id, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObject(const ossimConnectableObject *obj, bool recurse=true)) | |
virtual void | makeUniqueIds () |
Will cycle through all sources setting their ids. More... | |
virtual ossim_uint32 | getNumberOfObjects (bool recurse=true) const |
Returns the number of objects within this container and all child containers. More... | |
virtual ossim_uint32 | getNumberOfSources () const |
Deprecated! Please use getNumberOfObjects(false). More... | |
virtual bool | addChild (ossimConnectableObject *attachableObject) |
Will add an object to the container and then set the added objects owner to this. More... | |
virtual bool | removeChild (ossimConnectableObject *object) |
Will remove the child from the container. More... | |
virtual ossimConnectableObject * | removeChild (const ossimId &id) |
virtual void | getChildren (vector< ossimConnectableObject *> &children, bool immediateChildrenOnlyFlag) |
virtual void | disconnectInputEvent (ossimConnectionEvent &event) |
virtual void | disconnectOutputEvent (ossimConnectionEvent &event) |
virtual void | connectInputEvent (ossimConnectionEvent &event) |
virtual void | connectOutputEvent (ossimConnectionEvent &event) |
virtual void | objectDestructingEvent (ossimObjectDestructingEvent &event) |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | processEvent (ossimEvent &event) |
ProcessEvent. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
void | deleteList () |
virtual ossimConnectableObject::ConnectableObjectList & | imageChainList () |
These access methods greatly facilitate the implementation of an image chain adaptor class. More... | |
virtual const ossimConnectableObject::ConnectableObjectList & | imageChainList () const |
ossimImageSource (ossimObject *owner=0) | |
ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimImageSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIpt &origin, ossim_uint32 resLevel=0) |
virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel=0) |
Method to get a tile. More... | |
virtual ossimObject * | getObject () |
For RTTI support. More... | |
virtual const ossimObject * | getObject () const |
virtual void | getDecimationFactors (std::vector< ossimDpt > &decimations) const |
Will return an array of all decimations for each resolution level. More... | |
virtual ossim_uint32 | getNumberOfOutputBands () const |
Returns the number of bands in a tile returned from this TileSource. More... | |
virtual void | getBoundingRect (ossimIrect &rect, ossim_uint32 resLevel=0) const |
Gets the bounding rectangle of the source. More... | |
virtual void | getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
ordering specifies how the vertices should be arranged. More... | |
virtual void | setImageGeometry (const ossimImageGeometry *geom) |
Default implementation sets geometry of the first input to the geometry specified. More... | |
virtual void | saveImageGeometry () const |
Default method to call input's saveImageGeometry. More... | |
virtual void | saveImageGeometry (const ossimFilename &geometry_file) const |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
virtual bool | isIndexedData () const |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
ossimConnectableObjectListener () | |
virtual | ~ossimConnectableObjectListener () |
virtual void | connectionEvent (ossimConnectionEvent &) |
virtual void | propertyEvent (ossimPropertyEvent &) |
virtual void | addObjectEvent (ossimContainerEvent &) |
virtual void | removeObjectEvent (ossimContainerEvent &) |
virtual void | containerEvent (ossimContainerEvent &) |
virtual void | refreshEvent (ossimRefreshEvent &) |
ossimListener () | |
virtual | ~ossimListener () |
void | enableListener () |
void | disableListener () |
void | setListenerEnableFlag (bool flag) |
bool | isListenerEnabled () const |
bool | getListenerEnableFlag () const |
ossimConnectableContainerInterface (ossimObject *obj) | |
virtual | ~ossimConnectableContainerInterface () |
virtual ossimConnectableObject::ConnectableObjectList | findAllObjectsOfType (const RTTItypeid &typeInfo, bool recurse=true)=0 |
virtual ossimConnectableObject::ConnectableObjectList | findAllObjectsOfType (const ossimString &className, bool recurse=true)=0 |
virtual ossimConnectableObject * | findFirstObjectOfType (const RTTItypeid &typeInfo, bool recurse=true)=0 |
virtual ossimConnectableObject * | findFirstObjectOfType (const ossimString &className, bool recurse=true)=0 |
virtual ossimConnectableObject * | findObject (const ossimId &id, bool recurse=true)=0 |
virtual ossimConnectableObject * | findObject (const ossimConnectableObject *obj, bool recurse=true)=0 |
void | deleteAllChildren () |
virtual void | getChildren (std::vector< ossimConnectableObject *> &children, bool immediateChildrenOnlyFlag)=0 |
void | drawBox (const ossimIrect &rect, int r, int g, int b) |
void | prepareForRemoval (ossimConnectableObject *connectableObject) |
Inserts all of this object's children and inputs into the container provided. More... | |
bool | addAllSources (map< ossimId, vector< ossimId > > &idMapping, const ossimKeywordlist &kwl, const char *prefix=NULL) |
For dynamic loading to take place we must allocate all objects first and then assign id's later. More... | |
void | findInputConnectionIds (vector< ossimId > &result, const ossimKeywordlist &kwl, const char *prefix=NULL) |
bool | connectAllSources (const map< ossimId, vector< ossimId > > &idMapping) |
ossimImageSource (const ossimImageSource &rhs) | |
const ossimImageSource & | operator= (const ossimImageSource &) |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
Definition at line 27 of file AtpAnnotatedImage.h.
ATP::AtpAnnotatedImage::AtpAnnotatedImage | ( | ossimRefPtr< ossimImageChain > & | sourceChain, |
ossimRefPtr< ossimImageViewProjectionTransform > & | ivt, | ||
const ossimDrect & | aoi | ||
Definition at line 29 of file AtpAnnotatedImage.cpp.
References ossimImageChain::accept(), ossimImageChain::add(), ossim::JsonParam::asInt(), ossimRefPtr< T >::get(), ossim::JsonConfig::getParameter(), ossimDrect::height(), ossimImageChain::initialize(), ATP::AtpConfig::instance(), m_annScale, m_annScaleInverse, m_annSource, setAOI(), ossimBandSelector::setOutputBandList(), ossimDrect::width(), ossimDpt::x, and ossimDpt::y.
ATP::AtpAnnotatedImage::~AtpAnnotatedImage | ( | ) |
Definition at line 91 of file AtpAnnotatedImage.cpp.
void ATP::AtpAnnotatedImage::annotateCorrBoxes | ( | AtpList & | atpList, |
int | r | ||
void ATP::AtpAnnotatedImage::annotateCorrelations | ( | AtpList & | atpList, |
int | r, | ||
int | g, | ||
int | b | ||
Definition at line 175 of file AtpAnnotatedImage.cpp.
References ossimAnnotationSource::addObject(), ossim::JsonParam::asFloat(), ossim::JsonParam::asUint(), drawBox(), ossimRefPtr< T >::get(), ossim::JsonConfig::getParameter(), ATP::AtpConfig::instance(), m_annScaleInverse, m_annSource, ossimIrect::set_ll(), ossimIrect::set_lr(), ossimIrect::set_ul(), ossimIrect::set_ur(), ossimDpt::x, and ossimDpt::y.
void ATP::AtpAnnotatedImage::annotateCorrelationSearchTile | ( | const ossimIrect & | tileRect | ) |
Definition at line 273 of file AtpAnnotatedImage.cpp.
References drawBox(), m_annScaleInverse, m_annSource, and ossimDpt::x.
void ATP::AtpAnnotatedImage::annotateFeatures | ( | std::vector< ossimDpt > & | atpList, |
int | r, | ||
int | g, | ||
int | b | ||
Definition at line 150 of file AtpAnnotatedImage.cpp.
References ossimAnnotationSource::addObject(), ATP::AtpConfig::instance(), m_annScaleInverse, m_annSource, and ossimDpt::x.
void ATP::AtpAnnotatedImage::annotateFeatureSearchTiles | ( | std::vector< ossimIrect > & | tileRects | ) |
Definition at line 233 of file AtpAnnotatedImage.cpp.
References CINFO, drawBox(), m_annScaleInverse, m_annSource, ossimIrect::set_ll(), ossimIrect::set_lr(), ossimIrect::set_ul(), ossimIrect::set_ur(), ossimDpt::x, and ossimDpt::y.
void ATP::AtpAnnotatedImage::annotateOverlap | ( | ossimPolygon & | poly | ) |
Definition at line 212 of file AtpAnnotatedImage.cpp.
References ossimAnnotationSource::addObject(), ossimPolygon::getVertexList(), m_annScaleInverse, m_annSource, and ossimDpt::x.
void ATP::AtpAnnotatedImage::annotateResiduals | ( | AtpList & | atps, |
int | r, | ||
int | g, | ||
int | b | ||
Definition at line 101 of file AtpAnnotatedImage.cpp.
void ATP::AtpAnnotatedImage::annotateTPIDs | ( | AtpList & | atps, |
int | r, | ||
int | g, | ||
int | b | ||
Definition at line 135 of file AtpAnnotatedImage.cpp.
References ossimAnnotationSource::addObject(), ossimRefPtr< T >::get(), and m_annSource.
protected |
Definition at line 298 of file AtpAnnotatedImage.cpp.
References ossimAnnotationSource::addObject(), ossimIrect::ll(), ossimIrect::lr(), m_annSource, ossimIrect::ul(), and ossimIrect::ur().
Referenced by annotateCorrelations(), annotateCorrelationSearchTile(), annotateFeatureSearchTiles(), and annotateResiduals().
void ATP::AtpAnnotatedImage::setAOI | ( | const ossimDrect & | aoi | ) |
Definition at line 95 of file AtpAnnotatedImage.cpp.
References m_annScaledAoi, m_annScaleInverse, and ossimDpt::x.
Referenced by AtpAnnotatedImage().
inline |
bool ATP::AtpAnnotatedImage::write | ( | ) |
Definition at line 282 of file AtpAnnotatedImage.cpp.
References CINFO, ossimTiffWriter::close(), ossimConnectableObject::connectMyInputTo(), ossimImageFileWriter::execute(), ossimImageFileWriter::initialize(), m_annFilename, m_annScaledAoi, ossimImageFileWriter::setAreaOfInterest(), ossimImageFileWriter::setFilename(), and status.
protected |
Definition at line 56 of file AtpAnnotatedImage.h.
Referenced by setImageName(), and write().
protected |
Definition at line 53 of file AtpAnnotatedImage.h.
protected |
Definition at line 55 of file AtpAnnotatedImage.h.
protected |
Definition at line 54 of file AtpAnnotatedImage.h.
Referenced by annotateCorrelations(), annotateCorrelationSearchTile(), annotateFeatures(), annotateFeatureSearchTiles(), annotateOverlap(), annotateResiduals(), AtpAnnotatedImage(), and setAOI().
protected |
Definition at line 52 of file AtpAnnotatedImage.h.
Referenced by annotateCorrelations(), annotateCorrelationSearchTile(), annotateFeatures(), annotateFeatureSearchTiles(), annotateOverlap(), annotateResiduals(), annotateTPIDs(), AtpAnnotatedImage(), and drawBox().
