ossimERSTileSource.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 // Copyright (C) 2000 ImageLinks Inc.
3 //
4 // License: LGPL
5 //
6 // See LICENSE.txt file in the top level directory for more details.
7 //
8 // Author: Chong-Ket Chuah
9 //
10 // Description:
11 //
12 // Implementation for the class "ossimERSTileSource". ossimERSTileSource
13 // is used for reading ER Mapper raster file format. The format consists
14 // of a raster file with no extension and a header file with the same name
15 // as the raster file but with an .ers extension.
16 //
17 //*******************************************************************
18 // $Id: ossimERSTileSource.cpp 21512 2012-08-22 11:53:57Z dburken $
19
22
24 #include <ossim/base/ossimTrace.h>
27
29
30 //*******************************************************************
31 // Public Constructor:
32 //*******************************************************************
35  theHdr(NULL)
36 {
37 }
38
39 //*******************************************************************
40 // Public Constructor:
41 //*******************************************************************
43  const char* prefix)
45  theHdr(NULL)
46 {
47  if (loadState(kwl, prefix) == false)
48  {
50  }
51 }
52
53 //*******************************************************************
54 // Destructor:
55 //*******************************************************************
57 {
58  if (theHdr)
59  {
60  delete theHdr;
61  theHdr = NULL;
62  }
63 }
64
66 {
67  // Open and parse the header file
68  theHdr = new ossimERS(fileName);
69
70 // theHdr->dump(cout);
71
73  {
74  delete theHdr;
75  theHdr = NULL;
76  return false;
77  }
78  else
79  {
80  vector<ossimFilename> f;
81  ossimFilename fne;
82  ossimFilename fpath = fileName.path();
83  if (fpath.empty())
84  fne = fileName.fileNoExtension();
85  else
86  fne = fpath+"/"+fileName.fileNoExtension();
87  f.push_back(fne);
88  ossimGeneralRasterInfo genRasterInfo(f,
90  OSSIM_BIL,
92  theHdr->theLine,
94  0,
96  0);
98  {
99  ossim_uint32 i = 0;
100  ossim_uint32 bands = static_cast<ossim_uint32>(theHdr->theBands);
101  for(i = 0; i < bands; ++i)
102  {
103  genRasterInfo.getImageMetaData().setNullPix(i, theHdr->theNullCell);
104  }
105  }
106  ossimFilename metadataFile = fne;
107  metadataFile = metadataFile + ".omd";
108
109  if(metadataFile.exists())
110  {
111  ossimKeywordlist kwl;
112
113  kwl.addFile(metadataFile.c_str());
114
115  theMetaData.loadState(kwl);
116  ossim_uint32 i = 0;
117  ossim_uint32 bands = static_cast<ossim_uint32>(theHdr->theBands);
118  for(i = 0; i < bands; ++i)
119  {
121  {
122  genRasterInfo.getImageMetaData().setMinPix(i, theMetaData.getMinPix(i));
123  }
125  {
126  genRasterInfo.getImageMetaData().setMaxPix(i, theMetaData.getMaxPix(i));
127  }
129  {
130  genRasterInfo.getImageMetaData().setNullPix(i, theMetaData.getNullPix(i));
131  }
132  }
133  }
135  << "general raster info is\n";
136  genRasterInfo.print(ossimNotify(ossimNotifyLevel_INFO));
137  ossimGeneralRasterTileSource::open(genRasterInfo);
138  }
139
140  return true;
141 }
142
143
145 {
146  if ( !theGeometry )
147  {
148  // Check for external geom:
150
151  if ( !theGeometry )
152  {
153
155
156  if(theHdr)
157  {
158  ossimKeywordlist kwl;
159  if ( theHdr->toOssimProjectionGeom(kwl) )
160  {
161  theGeometry->loadState(kwl);
162  }
163  }
164
165  // At this point it is assured theGeometry is set.
166
167  //---
168  // WARNING:
169  // Must create/set the geometry at this point or the next call to
170  // ossimImageGeometryRegistry::extendGeometry will put us in an infinite loop
171  // as it does a recursive call back to ossimImageHandler::getImageGeometry().
172  //---
173
174  // Check for set projection.
175  if ( !theGeometry->getProjection() )
176  {
177  // Try factories for projection.
179  }
180  }
181
182  // Set image things the geometry object should know about.
184  }
185  return theGeometry;
186 }
187
189  const char* prefix)
190 {
191  const char* lookup = kwl.find(prefix, ossimKeywordNames::FILENAME_KW);
192
193  if (lookup)
194  {
195  ossimFilename fileName = lookup;
196
197  bool result = open(fileName);
198  ossimImageSource::loadState(kwl, prefix);
199  return result;
200  }
201
202  return ossimGeneralRasterTileSource::loadState(kwl, prefix);
203 }
204
206 {
207  return ossimString("ERS");
208 }
209
211 {
212  return ossimString("ER Mapper Raster");
213 }
214
216 {
217  return ossimString("ossimERSTileSource");
218 }
219
bool loadState(const ossimKeywordlist &kwl, const char *prefix=0)
static ossimImageGeometryRegistry * instance()
ossimRefPtr< ossimImageGeometry > theGeometry
virtual bool open()
Pure virtual open.
double getMinPix(ossim_uint32 band) const
bool getMinValuesValidFlag() const
bool addFile(const char *file)
Attempts to initialize a transform and a projection given the KWL.
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
double getMaxPix(ossim_uint32 band) const
static const ossimErrorCode OSSIM_ERROR
bool toOssimProjectionGeom(ossimKeywordlist &kwl, const char *prefix=NULL) const
Definition: ossimERS.cpp:531
bool getNullValuesValidFlag() const
double getNullPix(ossim_uint32 band) const
virtual bool extendGeometry(ossimImageHandler *handler) const
virtual ossimString getLongName() const
ossimScalarType theCelltype
Definition: ossimERS.h:58
Generic print method.
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
void setMinPix(ossim_uint32 band, double pix)
bool theHasNullCells
Definition: ossimERS.h:60
double theNullCell
Definition: ossimERS.h:61
ossim_int32 theBands
Definition: ossimERS.h:68
bool exists() const
RTTI_DEF1(ossimERSTileSource, "ossimERSTileSource", ossimGeneralRasterTileSource)
unsigned int ossim_uint32
virtual ossimString getShortName() const
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
Returns the image geometry object associated with this tile source or NULL if non defined...
ossimImageMetaData theMetaData
ossim_int32 errorStatus() const
Definition: ossimERS.h:79
bool getMaxValuesValidFlag() const
ossimFilename fileNoExtension() const
const char * c_str() const
Definition: ossimString.h:396
bool empty() const
Definition: ossimString.h:411
const ossimImageMetaData & getImageMetaData() const
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
ossim_int32 theSample
Definition: ossimERS.h:65
ossim_int32 theLine
Definition: ossimERS.h:64
virtual ossimString className() const
static const char * FILENAME_KW
ossimFilename path() const
void setMaxPix(ossim_uint32 band, double pix)
void setNullPix(ossim_uint32 band, double pix)
