Public Member Functions | Protected Member Functions | List of all members
ossimGeomFileWriter Class Reference
ossimGeomFileWriter More...
#include <ossimGeomFileWriter.h>
Inheritance diagram for ossimGeomFileWriter:
ossimMetadataFileWriter ossimConnectableObject ossimProcessInterface ossimConnectableObjectListener ossimObject ossimListenerManager ossimPropertyInterface ossimListener ossimReferenced
 ossimGeomFileWriter ()
 default constructor More...
virtual void getMetadatatypeList (std::vector< ossimString > &metadatatypeList) const
 Satisfies pure virtual from ossimMetadataWriter base. More...
virtual bool hasMetadataType (const ossimString &metadataType) const
- Public Member Functions inherited from ossimMetadataFileWriter
 ossimMetadataFileWriter ()
virtual void initialize ()
virtual bool execute ()
virtual void setFilename (const ossimFilename &file)
const ossimFilenamegetFilename () const
 Load state method: More...
virtual void setPixelType (ossimPixelType pixelType)
 Ossim uses a concept of "pixel is point" internally. More...
virtual ossimPixelType getPixelType () const
virtual void setAreaOfInterest (const ossimIrect &areaOfInterest)
 Sets the area of interest to write the meta data for. More...
virtual ossimIrect getAreaOfInterest () const
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
- Public Member Functions inherited from ossimProcessInterface
 ossimProcessInterface ()
virtual void abort ()
bool needsAborting () const
bool isAborted () const
bool isExecuting () const
void enableEvents ()
void disableEvents ()
 ProcessEvent. More...
virtual void refreshEvent (ossimRefreshEvent &)
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
virtual ~ossimGeomFileWriter ()
 virtual destructor More...
virtual bool writeFile ()
 Write a geometry file to "theFilename". More...
- Protected Member Functions inherited from ossimMetadataFileWriter
virtual ~ossimMetadataFileWriter ()
virtual ~ossimReferenced ()
Additional Inherited Members
- Public Types inherited from ossimProcessInterface
enum  ossimProcessStatus {
- Protected Attributes inherited from ossimMetadataFileWriter
ossimFilename theFilename
ossimPixelType thePixelType
ossimIrect theAreaOfInterest
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
- Protected Attributes inherited from ossimProcessInterface
double thePercentComplete
ossimString theMessage
bool theEventFlag
bool theListenerEnableFlag
Detailed Description
ossimGeomFileWriter
Definition at line 19 of file ossimGeomFileWriter.h.
◆ ossimGeomFileWriter()
ossimGeomFileWriter::ossimGeomFileWriter ( )
default constructor
Definition at line 32 of file ossimGeomFileWriter.cpp.
◆ ~ossimGeomFileWriter()
ossimGeomFileWriter::~ossimGeomFileWriter ( )
protectedvirtual
virtual destructor
Definition at line 37 of file ossimGeomFileWriter.cpp.
38 {}
Member Function Documentation
◆ getMetadatatypeList()
void ossimGeomFileWriter::getMetadatatypeList ( std::vector< ossimString > &  metadatatypeList) const
virtual
Appends the writers image types to the "metadatatypeList".
Parameters
metadatatypeListstl::vector<ossimString> list to append to.
Note
Appends to the list, does not clear it first.
Implements ossimMetadataFileWriter.
Definition at line 123 of file ossimGeomFileWriter.cpp.
124 {
125  metadatatypeList.push_back(ossimString("ossim_geometry"));
126 }
◆ hasMetadataType()
bool ossimGeomFileWriter::hasMetadataType ( const ossimString metadataType) const
virtual
Parameters
imageTypestring representing image type.
Returns
true if "metadataType" is supported by writer.
Definition at line 128 of file ossimGeomFileWriter.cpp.
130 {
131  return (metadataType == "ossim_geometry");
132 }
◆ writeFile()
bool ossimGeomFileWriter::writeFile ( )
protectedvirtual
Definition at line 40 of file ossimGeomFileWriter.cpp.
References ossimImageSource::getImageGeometry(), ossimImageGeometry::getImageSize(), ossimIpt::hasNans(), ossimIrect::size(), status, ossimMetadataFileWriter::theAreaOfInterest, ossimMetadataFileWriter::theInputConnection, and ossimRefPtr< T >::valid().
41 {
42  bool status = false;
44  {
46  if(geom.valid())
47  {
48  //---
49  // First check the ossimImageGeometry image size and adjust to area of interest if
50  // necessary. The ossimImageGeometry::applyScale method sometimes has rounding
51  // issues so fix it here...
52  //---
53  if ( geom->getImageSize().hasNans() ||
54  ( geom->getImageSize() != theAreaOfInterest.size() ) )
55  {
56  if ( traceDebug() )
57  {
59  << "ossimGeomFileWriter::writeFile DEBUG:"
60  << "\nAdjusting ossimImageGeometry size to reflect the area of interest."
61  << "\narea of interest size: " << theAreaOfInterest.size()
62  << "\nossimImageGeometry size: " << geom->getImageSize()
63  << std::endl;
64  }
66  }
67
68  // Save the state to keyword list.
69  ossimKeywordlist kwl;
70  geom->saveState(kwl);
71
72  const ossimMapProjection* mapProj =
74
75  if (mapProj)
76  {
77  const char* prefix = "projection.";
78
79  ossimDpt tiePoint;
80  if (mapProj->isGeographic())
81  {
82  // Get the ground tie point.
83  ossimGpt gpt;
84  mapProj->lineSampleToWorld(theAreaOfInterest.ul(), gpt);
85  tiePoint = gpt;
86
87  // Set the units to degrees.
88  kwl.add(prefix,
90  ossimUnitTypeLut::instance()->getEntryString(OSSIM_DEGREES),
91  true);
92  }
93  else
94  {
95  // Get the easting northing tie point.
96  mapProj->lineSampleToEastingNorthing(theAreaOfInterest.ul(), tiePoint);
97
98
99  // Set the units to meters.
100  kwl.add(prefix,
102  ossimUnitTypeLut::instance()->getEntryString(OSSIM_METERS),
103  true);
104  }
105
106  // Write the tie to keyword list.
107  kwl.add(prefix,
109  ossimDpt(tiePoint).toString().c_str(),
110  true);
111
112  } // matches: if (mapProj)
113
114  status = kwl.write(theFilename.c_str());
115
116  } // matches: if(geom.valid())
117
118  } // matches: if(theInputConnection)
119
120  return status;
121 }
const ossimIpt & getImageSize() const
bool valid() const
Definition: ossimRefPtr.h:75
virtual bool isGeographic() const
const ossimIpt & ul() const
Definition: ossimIrect.h:274
void setImageSize(const ossimIpt &size)
virtual bool write(const char *file, const char *comment=0) const
Methods to dump the ossimKeywordlist to a file on disk.
ossimIpt size() const
Definition: ossimIrect.h:510
virtual ossimGpt lineSampleToWorld(const ossimDpt &projectedPoint) const
static const char * TIE_POINT_XY_KW
virtual void lineSampleToEastingNorthing(const ossimDpt &liineSample, ossimDpt &eastingNorthing) const
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
return status
const char * c_str() const
Definition: ossimString.h:396
Saves the transform (if any) and projection (if any) states to the KWL.
bool hasNans() const
Definition: ossimIpt.h:58
static ossimUnitTypeLut * instance()
Returns the static instance of an ossimUnitTypeLut object.
static const char * TIE_POINT_UNITS_KW
