Public Member Functions | Protected Member Functions | Private Member Functions | Private Attributes | List of all members
ossimKakaduJ2kReader Class Reference
ossimKakaduJ2kReader class for reading images with JPEG2000 (J2K) compressed blocks using kakadu library for decompression. More...
#include <ossimKakaduJ2kReader.h>
Inheritance diagram for ossimKakaduJ2kReader:
ossimImageHandler ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
 ossimKakaduJ2kReader ()
 default construtor More...
virtual ~ossimKakaduJ2kReader ()
 virtural destructor More...
 Returns short name. More...
 Returns long name. More...
 Method to grab a tile(rectangle) from image. More...
 Returns the number of bands in the image. More...
 Returns the output pixel type of the tile source. More...
 Gets the decimation factor for a resLevel. More...
 Get array of decimations for all levels. More...
 Returns the number of decimation levels. More...
virtual ossim_uint32 getNumberOfLines (ossim_uint32 resLevel=0) const
 Gets number of lines for res level. More...
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 resLevel=0) const
 Gets the number of samples for res level. More...
virtual bool open ()
 Open method. More...
virtual bool isOpen () const
 Method to test for open file stream. More...
virtual void closeEntry ()
 Method to close current entry. More...
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual void initialize ()
virtual bool openOverview ()
virtual void closeOverview ()
 Opens the image file. More...
virtual void close ()
 Deletes the overview and clears the valid image vertices. More...
 Sets the filename. More...
 Returns the filename. More...
virtual bool isValidRLevel (ossim_uint32 resLevel) const
 Connection rule. More...
virtual bool hasLut () const
virtual void loadMetaData ()
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 Gets an overview tile. More...
virtual ossim_int32 get_capabilities ()
 Gets kdu source capability. More...
virtual ossim_int32 read (kdu_core::kdu_byte *buf, ossim_int32 num_bytes)
 Read method. More...
virtual bool seek (kdu_core::kdu_long offset)
 Seek method. More...
virtual kdu_core::kdu_long get_pos ()
 Get file position relative to the start of code stream offset. More...
virtual void completeOpen ()
virtual ~ossimReferenced ()
void initializeTile ()
 Initializes data member "theTile". More...
bool loadTileFromCache (ossim_uint32 x, ossim_uint32 y, const ossimIrect &clipRect)
 Loads a block of data to theCacheTile from the cache. More...
bool loadTile (ossim_uint32 x, ossim_uint32 y)
 Loads a block of data to theCacheTile. More...
Private Attributes
kdu_core::kdu_codestream theCodestream
kdu_core::kdu_thread_env * theThreadEnv
kdu_core::kdu_thread_queue * theOpenTileThreadQueue
ossim_uint32 theSourcePrecisionBits
ossim_uint32 theMinDwtLevels
std::ifstream theFileStr
ossimJ2kSizRecord theSizRecord
ossimScalarType theScalarType
ossimIrect theImageRect
ossimRefPtr< ossimImageDatatheCacheTile
ossim_uint32 theTileSizeX
ossim_uint32 theTileSizeY
ossimAppFixedTileCache::ossimAppFixedCacheId theCacheId
Additional Inherited Members
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 44 of file ossimKakaduJ2kReader.h.
◆ ossimKakaduJ2kReader()
ossimKakaduJ2kReader::ossimKakaduJ2kReader ( )
default construtor
◆ ~ossimKakaduJ2kReader()
ossimKakaduJ2kReader::~ossimKakaduJ2kReader ( )
virtual
virtural destructor
Definition at line 73 of file ossimKakaduJ2kReader.cpp.
References closeEntry().
74 {
75  closeEntry();
76 }
virtual void closeEntry()
Member Function Documentation
◆ closeEntry()
void ossimKakaduJ2kReader::closeEntry ( )
virtual
Note
There is a bool kdu_compressed_source::close() and a void ossimImageHandler::close(); hence, a new close to avoid conflicting return types.
Definition at line 462 of file ossimKakaduJ2kReader.cpp.
References ossimImageHandler::close(), ossimAppFixedTileCache::deleteCache(), ossimAppFixedTileCache::instance(), theCacheId, theCacheTile, theCodestream, theFileStr, theOpenTileThreadQueue, theThreadEnv, theTile, theTileSizeX, and theTileSizeY.
Referenced by ~ossimKakaduJ2kReader().
463 {
464  theFileStr.close();
465
466  // Cleanup processing environment
467  if ( theThreadEnv )
468  {
469  theThreadEnv->join(NULL,true); // Wait until all internal processing is complete.
470  theThreadEnv->terminate(theOpenTileThreadQueue, true);
471  theThreadEnv->cs_terminate(theCodestream); // Terminates background codestream processing.
472  theThreadEnv->destroy();
473  delete theThreadEnv;
474  theThreadEnv = 0;
475  }
476
477  if(theCodestream.exists())
478  {
479  theCodestream.destroy();
480  }
481
483  {
485  }
486
487  if (theCacheId != -1)
488  {
490  theCacheId = -1;
491  }
492
493  theTile = 0;
494  theCacheTile = 0;
495  theTileSizeX = 0;
496  theTileSizeY = 0;
497
499 }
virtual void deleteCache(ossimAppFixedCacheId cacheId)
ossimRefPtr< ossimImageData > theCacheTile
static ossimAppFixedTileCache * instance(ossim_uint32 maxSize=0)
virtual void close()
◆ get_capabilities()
ossim_int32 ossimKakaduJ2kReader::get_capabilities ( )
inlineprotectedvirtual
Overrides kdu_compressed_source::get_capabilities
Returns
KDU_SOURCE_CAP_SEEKABLE
Definition at line 316 of file ossimKakaduJ2kReader.h.
317 {
318  return ( KDU_SOURCE_CAP_SEEKABLE );
319 }
◆ get_pos()
kdu_core::kdu_long ossimKakaduJ2kReader::get_pos ( )
Overrides kdu_compressed_source::get_pos
Returns
Position in codestream.
Definition at line 344 of file ossimKakaduJ2kReader.h.
References theFileStr.
345 {
346  //---
347  // Must subtract the SOC(start of code stream) from the real file position
348  // since positions are relative to SOC.
349  //---
350  return static_cast<kdu_core::kdu_long>(theFileStr.tellg());
351 }
◆ getClassName()
ossimString ossimKakaduJ2kReader::getClassName ( ) const
virtual
Returns short name.
Returns
"ossim_kakadu_j2k_reader"
Definition at line 88 of file ossimKakaduJ2kReader.cpp.
89 {
90  return ossimString("ossimKakaduJ2kReader");
91 }
◆ getDecimationFactor()
void ossimKakaduJ2kReader::getDecimationFactor ( ossim_uint32  resLevel,
ossimDpt result
) const
virtual
Parameters
resLevelReduced resolution set for requested decimation.
resultossimDpt to initialize with requested decimation.
Definition at line 93 of file ossimKakaduJ2kReader.cpp.
References getNumberOfDecimationLevels(), getNumberOfLines(), ossimImageHandler::getNumberOfLines(), getNumberOfSamples(), ossimImageHandler::getNumberOfSamples(), ossim::nan(), theMinDwtLevels, ossimImageHandler::theOverview, ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Referenced by getDecimationFactors(), getNumberOfLines(), and getNumberOfSamples().
95 {
96  if (resLevel == 0)
97  {
98  //---
99  // Assumption r0 or first layer is full res. Might need to change to
100  // use nitf IMAG field.
101  //---
102  result.x = 1.0;
103  result.y = 1.0;
104  }
105  else if ( theOverview.valid() && (resLevel > theMinDwtLevels) &&
106  (resLevel < getNumberOfDecimationLevels()) )
107  {
108  //---
109  // External overview file.
110  //
111  // Use the real lines and samples in case an resLevel is skipped.
112  //
113  // Note we must subtract the internal overviews as the external
114  // overview reader does not know about them.
115  //---
117  ossim_float64 rL =
119
120  if (r0) // Divide by zero check
121  {
122  result.x = rL/r0;
123  }
124  else
125  {
126  result.x = ossim::nan();
127  }
128  r0 = getNumberOfLines(0);
130
131  if (r0) // Divide by zero check.
132  {
133  result.y = rL/r0;
134  }
135  else
136  {
137  result.y = ossim::nan();
138  }
139  }
140  else
141  {
142  // Internal overviews are on power of two decimation.
143  result.x = 1.0 / pow((double)2, (double)resLevel);
144  result.y = result.x;
145  }
146 }
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
double nan()
Definition: ossimCommon.h:135
double y
Definition: ossimDpt.h:165
double ossim_float64
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const
virtual ossim_uint32 getNumberOfDecimationLevels() const
ossimRefPtr< ossimImageHandler > theOverview
double x
Definition: ossimDpt.h:164
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
◆ getDecimationFactors()
void ossimKakaduJ2kReader::getDecimationFactors ( vector< ossimDpt > &  decimations) const
virtual
Parameters
decimationsVector to initialize with decimations.
Definition at line 148 of file ossimKakaduJ2kReader.cpp.
References getDecimationFactor(), and getNumberOfDecimationLevels().
150 {
151  const ossim_uint32 LEVELS = getNumberOfDecimationLevels();
152  decimations.resize(LEVELS);
153  for (ossim_uint32 level = 0; level < LEVELS; ++level)
154  {
155  getDecimationFactor(level, decimations[level]);
156  }
157 }
unsigned int ossim_uint32
virtual void getDecimationFactor(ossim_uint32 resLevel, ossimDpt &result) const
◆ getImageTileHeight()
ossim_uint32 ossimKakaduJ2kReader::getImageTileHeight ( ) const
virtual
Implements ossimImageHandler.
Definition at line 669 of file ossimKakaduJ2kReader.cpp.
References ossimJ2kSizRecord::m_XTsiz, ossimJ2kSizRecord::m_YTsiz, and theSizRecord.
Referenced by initializeTile().
670 {
671  ossim_uint32 result = 0;
672  if ( (theSizRecord.m_XTsiz <= 1024) && (theSizRecord.m_YTsiz <= 1024) )
673  {
674  result = theSizRecord.m_YTsiz;
675  }
676  return result;
677 }
ossim_uint32 m_YTsiz
height of one reference tile
ossim_uint32 m_XTsiz
width of one reference tile
◆ getImageTileWidth()
ossim_uint32 ossimKakaduJ2kReader::getImageTileWidth ( ) const
virtual
Definition at line 659 of file ossimKakaduJ2kReader.cpp.
660 {
661  ossim_uint32 result = 0;
662  if ( (theSizRecord.m_XTsiz <= 1024) && (theSizRecord.m_YTsiz <= 1024) )
663  {
664  result = theSizRecord.m_XTsiz;
665  }
666  return result;
667 }
◆ getLongName()
ossimString ossimKakaduJ2kReader::getLongName ( ) const
virtual
Returns long name.
Returns
"ossim kakadu j2k reader"
Definition at line 83 of file ossimKakaduJ2kReader.cpp.
84 {
85  return ossimString("ossim kakadu j2k reader");
86 }
◆ getNumberOfDecimationLevels()
ossim_uint32 ossimKakaduJ2kReader::getNumberOfDecimationLevels ( ) const
virtual
This returns the total number of decimation levels. It is important to note that res level 0 or full resolution is included in the list and has decimation values 1.0, 1.0
Returns
The number of decimation levels.
Definition at line 159 of file ossimKakaduJ2kReader.cpp.
References ossimImageHandler::getNumberOfDecimationLevels(), theMinDwtLevels, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getDecimationFactor(), getDecimationFactors(), getNumberOfLines(), getNumberOfSamples(), and getOverviewTile().
160 {
161  ossim_uint32 result = 1; // Add r0
162
163  if (theMinDwtLevels)
164  {
165  //---
166  // Add internal overviews.
167  //---
168  result += theMinDwtLevels;
169  }
170
171  if (theOverview.valid())
172  {
173  //---
174  // Add external overviews.
175  //
176  // NOTE: The ossimTiffTileSource will count r0 if present or it will
177  // add 1 to the decimation count if r0 is NOT present. Since
178  // since r0 has already be added subtract one.
179  //---
181  }
182
183  return result;
184 }
bool valid() const
◆ getNumberOfInputBands()
ossim_uint32 ossimKakaduJ2kReader::getNumberOfInputBands ( ) const
virtual
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 649 of file ossimKakaduJ2kReader.cpp.
References ossimJ2kSizRecord::m_Csiz, and theSizRecord.
650 {
651  return theSizRecord.m_Csiz;
652 }
ossim_uint16 m_Csiz
number of component in the image
◆ getNumberOfLines()
ossim_uint32 ossimKakaduJ2kReader::getNumberOfLines ( ossim_uint32  resLevel = 0) const
virtual
Overrides ossimJ2kTileSource::getNumberOfLines
Parameters
resLevelReduced resolution level to return lines of. Default = 0
Returns
The number of lines for specified reduced resolution level.
Definition at line 186 of file ossimKakaduJ2kReader.cpp.
References getDecimationFactor(), getNumberOfDecimationLevels(), ossimDpt::hasNans(), ossimJ2kSizRecord::m_Ysiz, theSizRecord, and ossimDpt::y.
Referenced by getDecimationFactor().
188 {
189  ossim_uint32 result = 0;
190  if (resLevel < getNumberOfDecimationLevels())
191  {
192  result = theSizRecord.m_Ysiz;
193  if ( resLevel > 0 )
194  {
195  ossimDpt dpt;
196  getDecimationFactor(resLevel, dpt);
197  if ( !dpt.hasNans() )
198  {
199  result = static_cast<ossim_uint32>(result * dpt.y);
200  }
201  }
202  }
203  return result;
204 }
double y
bool hasNans() const
Definition: ossimDpt.h:67
ossim_uint32 m_Ysiz
height of reference grid
◆ getNumberOfOutputBands()
ossim_uint32 ossimKakaduJ2kReader::getNumberOfOutputBands ( ) const
virtual
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 654 of file ossimKakaduJ2kReader.cpp.
Referenced by getOverviewTile(), and initializeTile().
655 {
656  return theSizRecord.m_Csiz;
657 }
ossim_uint16 m_Csiz
◆ getNumberOfSamples()
ossim_uint32 ossimKakaduJ2kReader::getNumberOfSamples ( ossim_uint32  resLevel = 0) const
virtual
Overrides ossimJ2kTileSource::getNumberOfSamples
Parameters
resLevelReduced resolution level to return samples of. Default = 0
Returns
The number of samples for specified reduced resolution level.
Definition at line 206 of file ossimKakaduJ2kReader.cpp.
References getDecimationFactor(), getNumberOfDecimationLevels(), ossimJ2kSizRecord::m_Xsiz, theSizRecord, and ossimDpt::x.
208 {
209  ossim_uint32 result = 0;
210  if (resLevel < getNumberOfDecimationLevels())
211  {
212  result = theSizRecord.m_Xsiz;
213  if ( resLevel > 0 )
214  {
215  ossimDpt dpt;
216  getDecimationFactor(resLevel, dpt);
217  result = static_cast<ossim_uint32>(result * dpt.x);
218  }
219  }
220  return result;
221 }
ossim_uint32 m_Xsiz
width of reference grid
double x
◆ getOutputScalarType()
ossimScalarType ossimKakaduJ2kReader::getOutputScalarType ( ) const
virtual
Definition at line 679 of file ossimKakaduJ2kReader.cpp.
References ossimJ2kSizRecord::getScalarType(), and theSizRecord.
680 {
681  return theSizRecord.getScalarType();
682 }
ossimScalarType getScalarType() const
Gets the scalar type.
◆ getOverviewTile()
bool ossimKakaduJ2kReader::getOverviewTile ( ossim_uint32  resLevel,
ossimImageData result
protectedvirtual
Overrides ossimImageHandler::getOverviewTile
Parameters
resLevelThe resolution level to pull from with resLevel 0 being full res.
resultThe tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. This method will subtract the subImageOffset if needed for external overview call since they do not know about the sub image offset.
Returns
true on success false on error. Typically this will return false if resLevel==0 unless the overview has r0. If return is false, result is undefined so caller should handle appropriately with makeBlank or whatever.
Definition at line 611 of file ossimKakaduJ2kReader.cpp.
References ossim::copyRegionToTile(), ossimImageData::getNumberOfBands(), getNumberOfDecimationLevels(), getNumberOfOutputBands(), ossimImageSource::getTile(), ossimNotify(), ossimNotifyLevel_WARN, status, theCodestream, theMinDwtLevels, theOpenTileThreadQueue, ossimImageHandler::theOverview, theThreadEnv, and ossimException::what().
Referenced by getTile(), and loadTile().
613 {
614  bool status = false;
615
616  if ( (resLevel < getNumberOfDecimationLevels()) && result &&
617  (result->getNumberOfBands() == getNumberOfOutputBands()) )
618  {
619  if (resLevel <= theMinDwtLevels)
620  {
621  // Internal overviews...
622  try
623  {
625  static_cast<int>(resLevel),
626  theThreadEnv,
628  result);
629  }
630  catch(const ossimException& e)
631  {
633  << __FILE__ << " " << __LINE__ << " caught exception\n"
634  << e.what();
635  status = false;
636  }
637
638  } // matches: if (resLevel <= theMinDwtLevels)
639  else
640  {
641  // External overviews...
642  status = theOverview->getTile(result, resLevel - theMinDwtLevels);
643  }
644  }
645
646  return status;
647 }
virtual const char * what() const
Returns the error message.
return status
bool copyRegionToTile(kdu_supp::kdu_channel_mapping *channelMapping, kdu_core::kdu_codestream &codestream, int discard_levels, kdu_core::kdu_thread_env *threadEnv, kdu_core::kdu_thread_queue *threadQueue, ossimImageData *destTile)
Copies region from codestream to tile at a given rlevel.
◆ getShortName()
ossimString ossimKakaduJ2kReader::getShortName ( ) const
virtual
Returns short name.
Returns
Definition at line 78 of file ossimKakaduJ2kReader.cpp.
79 {
80  return ossimString("ossim_kakadu_j2k_reader");
81 }
◆ getTile()
ossimRefPtr< ossimImageData > ossimKakaduJ2kReader::getTile ( const ossimIrect rect,
virtual
Parameters
rectThe zero based rectangle to grab.
resLevelThe reduced resolution level to grab from.
Returns
The ref pointer with the image data pointer.
Definition at line 515 of file ossimKakaduJ2kReader.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimImageData::getImageRectangle(), getOverviewTile(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), loadTile(), ossimImageData::loadTile(), loadTileFromCache(), ossimIrect::lr(), ossimImageData::makeBlank(), OSSIM_BSQ, ossimImageData::setImageRectangle(), ossimIrect::stretchToTileBoundary(), theCacheTile, theImageRect, theTile, theTileSizeX, theTileSizeY, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, x, ossimIpt::y, and y.
517 {
518  // This tile source bypassed, or invalid res level, return a blank tile.
519  if(!isSourceEnabled() || !isOpen() || !isValidRLevel(resLevel))
520  {
522  }
523
524  if (theTile.valid())
525  {
526  // Rectangle must be set prior to getOverviewTile call.
527  theTile->setImageRectangle(rect);
528
529  if (resLevel)
530  {
531  if ( getOverviewTile(resLevel, theTile.get() ) == false )
532  {
533  theTile->makeBlank();
534  }
535  }
536  else
537  {
538  //---
539  // See if the whole tile is going to be filled, if not, start out with
540  // a blank tile so data from a previous load gets wiped out.
541  //---
542  if ( !rect.completely_within(theImageRect) )
543  {
544  // Start with a blank tile.
545  theTile->makeBlank();
546  }
547
548  //---
549  // See if any point of the requested tile is in the image.
550  //---
551  if ( rect.intersects(theImageRect) )
552  {
553  ossimIrect clipRect = rect.clipToRect(theImageRect);
554
555  ossimIrect exandedRect = clipRect;
556
557  //---
558  // Shift the upper left corner of the "clip_rect" to the an even
559  // j2k tile boundry.
560  //---
562  theTileSizeY));
563
564  // Vertical tile loop.
565  ossim_int32 y = exandedRect.ul().y;
566  while (y < exandedRect.lr().y)
567  {
568  // Horizontal tile loop.
569  ossim_int32 x = exandedRect.ul().x;
570  while (x < exandedRect.lr().x)
571  {
572  if ( loadTileFromCache(x, y, clipRect) == false )
573  {
574  if ( loadTile(x, y) )
575  {
576  //---
577  // Note: Clip the cache tile to the image clipRect
578  // since there are j2k tiles that go beyond the image
579  // dimensions, i.e., edge tiles.
580  //---
581  ossimIrect cr =
583  clipToRect(clipRect);
584
587  cr,
588  OSSIM_BSQ);
589  }
590
591  }
592
593  x += theTileSizeX; // Go to next tile.
594  }
595
596  y += theTileSizeY; // Go to next row of tiles.
597  }
598
599  // Set the tile status.
600  theTile->validate();
601
602  } // matches: if ( rect.intersects(theImageRect) )
603
604  } // r0 block
605
606  } // matches: if (theTile.valid())
607
608  return theTile;
609 }
ossim_uint32 x
ossim_uint32 y
bool valid() const
const ossimIpt & ul() const
Definition: ossimIrect.h:274
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
bool loadTile(ossim_uint32 x, ossim_uint32 y)
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
bool completely_within(const ossimIrect &rect) const
Definition: ossimIrect.cpp:425
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
virtual bool isOpen() const
virtual bool getOverviewTile(ossim_uint32 resLevel, ossimImageData *result)
virtual ossimIrect getImageRectangle() const
const ossimIpt & lr() const
Definition: ossimIrect.h:276
virtual void makeBlank()
ossim_int32 y
Definition: ossimIpt.h:142
bool loadTileFromCache(ossim_uint32 x, ossim_uint32 y, const ossimIrect &clipRect)
void stretchToTileBoundary(const ossimIpt &tileWidthHeight)
Definition: ossimIrect.cpp:212
ossim_int32 x
Definition: ossimIpt.h:141
int ossim_int32
◆ initializeTile()
void ossimKakaduJ2kReader::initializeTile ( )
private
Definition at line 684 of file ossimKakaduJ2kReader.cpp.
References ossim::defaultTileSize(), getImageTileHeight(), getImageTileWidth(), getNumberOfOutputBands(), getOutputScalarType(), ossimImageData::initialize(), ossimImageDataFactory::instance(), theCacheTile, theTile, theTileSizeX, theTileSizeY, ossimIpt::x, and ossimIpt::y.
685 {
688
689  // Check for zero width, height and limit output tile sizes to 1024.
690  if ( !theTileSizeX || !theTileSizeY ||
691  ( theTileSizeX > 1024) || (theTileSizeY > 1024) )
692  {
693  ossimIpt tileSize;
694  ossim::defaultTileSize(tileSize);
695
696  theTileSizeX = tileSize.x;
697  theTileSizeY = tileSize.y;
698  }
699
701  create( this,
702  this->getOutputScalarType(),
703  this->getNumberOfOutputBands(),
704  theTileSizeX,
705  theTileSizeY);
706
707  theTile->initialize();
708
710  create( this,
711  this->getOutputScalarType(),
712  this->getNumberOfOutputBands(),
713  theTileSizeX,
714  theTileSizeY);
715
717 }
OSSIM_DLL void defaultTileSize(ossimIpt &tileSize)
virtual void initialize()
Initialize the data buffer.
virtual ossim_uint32 getImageTileWidth() const
ossim_int32 y
virtual ossim_uint32 getImageTileHeight() const
ossim_int32 x
◆ isOpen()
bool ossimKakaduJ2kReader::isOpen ( ) const
virtual
Returns
true if open, false if not.
Definition at line 454 of file ossimKakaduJ2kReader.cpp.
References theTile, and ossimRefPtr< T >::valid().
Referenced by getTile().
455 {
456  // return theFileStr.is_open();
457
458  // Temp fix for gcc's that don't have a const "ifstream::is_open() const"
459  return theTile.valid();
460 }
bool valid() const
◆ loadState()
bool ossimKakaduJ2kReader::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 501 of file ossimKakaduJ2kReader.cpp.
References ossimImageHandler::loadState(), and open().
503 {
504  bool result = false;
505
506  if ( ossimImageHandler::loadState(kwl, prefix) )
507  {
508  result = open();
509  }
510
511  return result;
512 }
virtual bool open()
Open method.
◆ loadTile()
bool ossimKakaduJ2kReader::loadTile ( ossim_uint32  x,
ossim_uint32  y
private
Parameters
xStarting x position of block to load.
yStarting y position of block to load.
Returns
Note
x and y are zero based relative to the upper left corner so any sub image offset should be subtracted off.
Definition at line 748 of file ossimKakaduJ2kReader.cpp.
References ossimAppFixedTileCache::addTile(), ossimRefPtr< T >::get(), getOverviewTile(), ossimAppFixedTileCache::instance(), ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), theCacheId, theCacheTile, theTileSizeX, theTileSizeY, ossimIpt::x, x, ossimIpt::y, and y.
749 {
750  bool result = true;
751
752  ossimIpt ul(x, y);
753  ossimIpt lr(ul.x + theTileSizeX - 1,
754  ul.y + theTileSizeY - 1);
755
756  // Set the cache rectangle to be an even j2k tile.
758
759  //---
760  // Let the getOverviewTile do the rest of the work.
761  if ( getOverviewTile(0, theCacheTile.get()) )
762  {
763  // Add it to the cache for the next time.
765  }
766  else
767  {
769  << __FILE__ << __LINE__
770  << " ossimKakaduJ2kReader::loadBlock failed!"
771  << std::endl;
772  result = false;
773  }
774
775  return result;
776 }
ossim_uint32 x
ossim_uint32 y
ossimRefPtr< ossimImageData > addTile(ossimAppFixedCacheId cacheId, ossimRefPtr< ossimImageData > data, bool duplicateData=true)
◆ loadTileFromCache()
bool ossimKakaduJ2kReader::loadTileFromCache ( ossim_uint32  x,
ossim_uint32  y,
const ossimIrect clipRect
private
Parameters
clipRectThe rectangle to fill.
Returns
Note
Definition at line 719 of file ossimKakaduJ2kReader.cpp.
References ossimIrect::clipToRect(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimImageData::getImageRectangle(), ossimAppFixedTileCache::getTile(), ossimAppFixedTileCache::instance(), ossimImageData::loadTile(), OSSIM_BSQ, theCacheId, theTile, ossimRefPtr< T >::valid(), x, and y.
721 {
722  bool result = false;
723
724  ossimIpt origin(x, y);
725
726  ossimRefPtr<ossimImageData> tempTile =
728
729  if (tempTile.valid())
730  {
731  //---
732  // Note: Clip the cache j2k tile to the image clipRect since
733  // there are j2k tiles that go beyond the image dimensions, i.e.,
734  // edge tiles.
735  //---
736  ossimIrect cr =
737  tempTile->getImageRectangle().clipToRect(clipRect);
738
739  theTile->loadTile(tempTile.get()->getBuf(),
740  tempTile->getImageRectangle(),
741  cr,
742  OSSIM_BSQ);
743  result = true;
744  }
745  return result;
746 }
ossim_uint32 x
ossim_uint32 y
bool valid() const
ossimRefPtr< ossimImageData > getTile(ossimAppFixedCacheId cacheId, const ossimIpt &origin)
◆ open()
bool ossimKakaduJ2kReader::open ( )
virtual
Open method.
Returns
Definition at line 223 of file ossimKakaduJ2kReader.cpp.
Referenced by loadState().
224 {
225  static const char MODULE[] = "ossimKakaduJ2kReader::open";
226
227  if (traceDebug())
228  {
230  << MODULE << " entered...\n";
231  }
232
233  bool result = false;
234
235  if(isOpen())
236  {
237  closeEntry();
238  }
239
240  // Open up a stream to the file.
241  theFileStr.open(theImageFile.c_str(), ios::in | ios::binary);
242  if ( theFileStr.good() )
243  {
244  //---
245  // Check for the Start Of Codestream (SOC) and Size (SIZ) markers which
246  // are required as first and second fields in the main header.
247  //---
248  ossim_uint16 soc;
249  ossim_uint16 siz;
250  theFileStr.read((char*)&soc, 2);
251  theFileStr.read((char*)&siz, 2);
252
253  if (ossim::byteOrder() == OSSIM_LITTLE_ENDIAN) // Alway big endian.
254  {
255  ossimEndian().swap(soc);
256  ossimEndian().swap(siz);
257  }
258
259  const ossim_uint16 SOC_MARKER = 0xff4f; // start of codestream marker
260  const ossim_uint16 SIZ_MARKER = 0xff51; // size maker
261
262  if ( (soc == SOC_MARKER) && (siz == SIZ_MARKER) )
263  {
264  // Read in and store the size record.
266
267  // Position to start of code stream prior to create call.
268  theFileStr.seekg(0);
269
270  //---
271  // Initialize the codestream. The class ossimKakaduNitfReader is a
272  // kdu_compressed source so we feed ourself to the codestream.
273  //
274  // TODO: Currently no kdu_thread_env. This should be implemented for
275  // speed...
276  //---
277
278  //---
279  // Construct multi-threaded processing environment if required.
280  // Temp hard coded to a single thread.
281  //---
282
283  if (theThreadEnv)
284  {
285  theThreadEnv->terminate(NULL, true);
286  theThreadEnv->destroy();
287  }
288  else
289  {
290  theThreadEnv = new kdu_core::kdu_thread_env();
291  }
292
293  theThreadEnv->create(); // Creates the single "owner" thread
294
295  // Check for threads in prefs file.
296  ossim_uint32 threads = 1;
297  const char* lookup = ossimPreferences::instance()->findPreference("kakadu_threads");
298  if ( lookup )
299  {
300  threads = ossimString::toUInt32(lookup);
301  if ( threads > 1 )
302  {
303  for (ossim_uint32 nt=1; nt < threads; ++nt)
304  {
305  if ( !theThreadEnv->add_thread() )
306  {
307  if (traceDebug())
308  {
310  << "Unable to create thread!\n";
311  }
312  }
313  }
314  }
315  }
316
317  theOpenTileThreadQueue = theThreadEnv->add_queue(NULL,NULL,"open_tile_q");
318
319  theCodestream.create(this, theThreadEnv);
320
321  if ( theCodestream.exists() )
322  {
323  //---
324  // We have to store things here in this non-const method because
325  // NONE of the kakadu methods are const.
326  //---
327  theMinDwtLevels = theCodestream.get_min_dwt_levels();
328
329  theCodestream.set_persistent(); // ????
330  theCodestream.enable_restart(); // ????
331
332  kdu_core::kdu_dims region_of_interest;
333  region_of_interest.pos.x = 0;
334  region_of_interest.pos.y = 0;
335  region_of_interest.size.x = getNumberOfSamples(0);
336  region_of_interest.size.y = getNumberOfLines(0);
337
338  theCodestream.apply_input_restrictions(
339  0, // first_component
340  0, // max_components (0 = all remaining will appear)
341  0, // highest resolution level
342  0, // max_layers (0 = all layers retained)
343  &region_of_interest, // expanded out to block boundary.
344  //KDU_WANT_CODESTREAM_COMPONENTS);
345  kdu_core::KDU_WANT_OUTPUT_COMPONENTS);
346
347  // Set the scalar:
350  {
351  //---
352  // NOTE: Please leave commented out code for now.
353  //---
354  // Capture the sub image offset.
355  // theSubImageOffset.x = theSizRecord.theXOsiz;
356  // theSubImageOffset.y = theSizRecord.theYOsiz;
357
358  // Initialize the image rect.
360  0,
362  theSizRecord.m_Ysiz-1);
363
364  // Initialize the cache.
365  if (theCacheId != -1)
366  {
368  theCacheId = -1;
369  }
371
372  // Stretch to tile boundary for the cache.
373  ossimIrect fullImgRect = theImageRect;
374  fullImgRect.stretchToTileBoundary(tileSize);
375
376  // Set up the tile cache.
378  newTileCache(fullImgRect, tileSize);
379
380  // Add the sub image rect after the
381
382  // Initialize the tile we will return.
383  initializeTile();
384
385  // Call the base complete open to pick up overviews.
386  completeOpen();
387
388  // We should be good now so set the return result to true.
389  result = true;
390
391  if (traceDebug())
392  {
394  << "\nSIZ marker segment"
395  << theSizRecord
396  << "theCodestream.get_num_components(false): "
397  << theCodestream.get_num_components(false)
398  << "\ntheCodestream.get_num_components(true): "
399  << theCodestream.get_num_components(true)
400  << "\ntheCodestream.get_bit_depth(0, true): "
401  << theCodestream.get_bit_depth(0, true)
402  << "\ntheCodestream.get_signed(0, true): "
403  << theCodestream.get_signed(0, true)
404  << "\ntheCodestream.get_min_dwt_levels(): "
405  << theCodestream.get_min_dwt_levels()
406  << "\ntheImageRect: " << theImageRect
407  << "\nFull image rect: " << fullImgRect
408  << "\nthreads: " << threads
409  << "\n";
410
411  vector<ossimDpt> decimations;
412  getDecimationFactors(decimations);
413  for (ossim_uint32 i = 0; i < decimations.size(); ++i)
414  {
416  << theCodestream.get_min_dwt_levels()
417  << "Decimation factor[" << i << "]: "
418  << decimations[i]
419  << "\nsamples[" << i << "]: "
420  << getNumberOfSamples(i)
421  << "\nlines[" << i << "]: "
422  << getNumberOfLines(i)
423  << std::endl;
424
425  }
426  }
427  }
428
429  } // matches: if ( theCodestream.exists() )
430
431  } // matches: if ( (soc == SOC_MARKER) && (siz == SIZ_MARKER) )
432
433  } // matches: if ( theFileStr.good() )
434  else
435  {
436  if(traceDebug())
437  {
439  << MODULE << " ERROR:"
440  << "\nCannot open: " << theImageFile.c_str() << endl;
441  }
442  }
443
444  if (traceDebug())
445  {
447  << MODULE << " exit status = " << (result?"true":"false\n")
448  << std::endl;
449  }
450
451  return result;
452 }
ossim_uint32 m_Xsiz
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
ossim_uint32 toUInt32() const
unsigned short ossim_uint16
void initializeTile()
const char * findPreference(const char *key) const
static ossimPreferences * instance()
virtual void completeOpen()
Will complete the opening process.
virtual void getDecimationFactors(vector< ossimDpt > &decimations) const
const char * c_str() const
Definition: ossimString.h:396
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
ossim_uint32 m_Ysiz
void parseStream(ossim::istream &in)
Parse method.
◆ read()
ossim_int32 ossimKakaduJ2kReader::read ( kdu_core::kdu_byte *  buf,
Read method.
Implements pure virtual kdu_compressed_source::read
Parameters
bufBuffer to fill.
num_bytesBytes to read.
Returns
Actual bytes read.
Definition at line 321 of file ossimKakaduJ2kReader.h.
323 {
324  theFileStr.read((char*)buf, num_bytes);
325  return theFileStr.gcount();
326 }
◆ seek()
bool ossimKakaduJ2kReader::seek ( kdu_core::kdu_long  offset)
Seek method.
Overrides kdu_compressed_source::seek
Parameters
offsetSeek position relative to the start of code stream offset.
Returns
Definition at line 328 of file ossimKakaduJ2kReader.h.
329 {
330  // If the last byte is read, the eofbit must be reset.
331  if ( theFileStr.eof() )
332  {
333  theFileStr.clear();
334  }
335
336  //---
337  // All seeks are relative to the start of code stream.
338  //---
339  theFileStr.seekg(offset, ios_base::beg);
340
341  return theFileStr.good();
342 }
Member Data Documentation
◆ theCacheId
ossimAppFixedTileCache::ossimAppFixedCacheId ossimKakaduJ2kReader::theCacheId
private
Definition at line 311 of file ossimKakaduJ2kReader.h.
Referenced by closeEntry(), loadTile(), and loadTileFromCache().
◆ theCacheTile
ossimRefPtr<ossimImageData> ossimKakaduJ2kReader::theCacheTile
private
Definition at line 306 of file ossimKakaduJ2kReader.h.
Referenced by closeEntry(), getTile(), initializeTile(), and loadTile().
◆ theCodestream
kdu_core::kdu_codestream ossimKakaduJ2kReader::theCodestream
private
Definition at line 296 of file ossimKakaduJ2kReader.h.
Referenced by closeEntry(), and getOverviewTile().
◆ theFileStr
std::ifstream ossimKakaduJ2kReader::theFileStr
private
Definition at line 301 of file ossimKakaduJ2kReader.h.
Referenced by closeEntry(), get_pos(), read(), and seek().
◆ theImageRect
ossimIrect ossimKakaduJ2kReader::theImageRect
private
Definition at line 304 of file ossimKakaduJ2kReader.h.
◆ theMinDwtLevels
ossim_uint32 ossimKakaduJ2kReader::theMinDwtLevels
private
◆ theOpenTileThreadQueue
kdu_core::kdu_thread_queue* ossimKakaduJ2kReader::theOpenTileThreadQueue
private
Definition at line 298 of file ossimKakaduJ2kReader.h.
◆ theScalarType
ossimScalarType ossimKakaduJ2kReader::theScalarType
private
Definition at line 303 of file ossimKakaduJ2kReader.h.
◆ theSizRecord
ossimJ2kSizRecord ossimKakaduJ2kReader::theSizRecord
private
◆ theSourcePrecisionBits
ossim_uint32 ossimKakaduJ2kReader::theSourcePrecisionBits
private
Definition at line 299 of file ossimKakaduJ2kReader.h.
◆ theThreadEnv
kdu_core::kdu_thread_env* ossimKakaduJ2kReader::theThreadEnv
private
Definition at line 297 of file ossimKakaduJ2kReader.h.
◆ theTile
ossimRefPtr<ossimImageData> ossimKakaduJ2kReader::theTile
private
◆ theTileSizeX
ossim_uint32 ossimKakaduJ2kReader::theTileSizeX
private
Definition at line 307 of file ossimKakaduJ2kReader.h.
◆ theTileSizeY
ossim_uint32 ossimKakaduJ2kReader::theTileSizeY
private
Definition at line 308 of file ossimKakaduJ2kReader.h.
