ossimOrthoImageMosaic Class Reference
#include <ossimOrthoImageMosaic.h>
Inheritance diagram for ossimOrthoImageMosaic:
ossimImageMosaic ossimImageCombiner ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimOrthoImageMosaic ()
 ossimOrthoImageMosaic (ossimConnectableObject::ConnectableObjectList &inputSources)
virtual void initialize ()
 Returns the geometry associated with the full mosaic. More...
virtual ossim_uint32 getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const
 Used to retrieve the number of overlapping images withint the given rect. More...
virtual void getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const
 Used to populate the result with the index of the overlapping images. More...
virtual ossimRefPtr< ossimImageDatagetNextTile (ossim_uint32 &returnedIdx, const ossimIrect &origin, ossim_uint32 resLevel=0)
ossimIrect getRelativeRect (ossim_uint32 index, ossim_uint32 resLevel=0) const
- Public Member Functions inherited from ossimImageMosaic
 ossimImageMosaic ()
 ossimImageMosaic (ossimConnectableObject::ConnectableObjectList &inputSources)
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &origin, ossim_uint32 resLevel=0)
- Public Member Functions inherited from ossimImageCombiner
 ossimImageCombiner ()
 ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag)
 ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources)
virtual void updateRects ()
 This will go through and precompute the bounding rects of each input image. More...
 Returns the number of bands available from the input. More...
virtual ossimRefPtr< ossimImageDatagetNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual bool getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0)
virtual ossimRefPtr< ossimImageDatagetNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual ossimRefPtr< ossimImageDatagetNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual bool canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const
virtual bool hasDifferentInputs () const
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
virtual ~ossimOrthoImageMosaic ()
void computeBoundingRect (ossim_uint32 resLevel=0)
void updateGeometry ()
 If this object is maintaining an ossimImageGeometry, this method needs to be called after each time the contents of the mosaic changes. More...
- Protected Member Functions inherited from ossimImageMosaic
virtual ~ossimImageMosaic ()
void allocate ()
 Called on first getTile, will initialize all data needed. More...
template<class T >
ossimRefPtr< ossimImageDatacombine (T, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
template<class T >
ossimRefPtr< ossimImageDatacombineNorm (T, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
- Protected Member Functions inherited from ossimImageCombiner
virtual ~ossimImageCombiner ()
void precomputeBounds () const
virtual ~ossimReferenced ()
Protected Attributes
std::vector< ossimDptm_InputTiePoints
ossimDpt m_Delta
 Holds R0 delta and will be scaled for different r-level requests. More...
ossimDpt m_UpperLeftTie
 Will hold the upper left tie of the mosaic. More...
ossimIrect m_BoundingRect
ossimString m_Units
ossimRefPtr< ossimImageGeometrym_Geometry
 The input image geometry, altered by the map tiepoint. More...
- Protected Attributes inherited from ossimImageMosaic
- Protected Attributes inherited from ossimImageCombiner
ossim_uint32 theLargestNumberOfInputBands
ossim_uint32 theInputToPassThrough
bool theHasDifferentInputs
ossimRefPtr< ossimImageDatatheNormTile
std::vector< ossimIrecttheFullResBounds
bool theComputeFullResBoundsFlag
ossim_uint32 theCurrentIndex
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Additional Inherited Members
Detailed Description
Definition at line 17 of file ossimOrthoImageMosaic.h.
◆ ossimOrthoImageMosaic() [1/2]
ossimOrthoImageMosaic::ossimOrthoImageMosaic ( )
Definition at line 24 of file ossimOrthoImageMosaic.cpp.
References m_Delta, m_UpperLeftTie, and ossimDpt::makeNan().
26 {
27  m_Delta.makeNan();
29 }
ossimDpt m_Delta
void makeNan()
Definition: ossimDpt.h:65
◆ ossimOrthoImageMosaic() [2/2]
ossimOrthoImageMosaic::ossimOrthoImageMosaic ( ossimConnectableObject::ConnectableObjectList inputSources)
Definition at line 34 of file ossimOrthoImageMosaic.cpp.
35  :ossimImageMosaic(inputSources)
36 {
37  m_Delta.makeNan();
39 }
ossimDpt m_Delta
void makeNan()
◆ ~ossimOrthoImageMosaic()
ossimOrthoImageMosaic::~ossimOrthoImageMosaic ( )
protectedvirtual
Definition at line 44 of file ossimOrthoImageMosaic.cpp.
45 {
46 }
Member Function Documentation
◆ computeBoundingRect()
void ossimOrthoImageMosaic::computeBoundingRect ( ossim_uint32  resLevel = 0)
protected
Definition at line 367 of file ossimOrthoImageMosaic.cpp.
References getRelativeRect(), m_BoundingRect, m_InputTiePoints, and ossimIrect::makeNan().
368 {
369  const char* MODULE = "ossimOrthoImageMosaic::computeBoundingRect";
370
372
373  for(ossim_uint32 i = 0; i < m_InputTiePoints.size(); ++ i)
374  {
375  ossimIrect shiftedRect = getRelativeRect(i, resLevel);
376
377  if(traceDebug())
378  {
379  CLOG << "bounding rect for input " << (i+1)
380  << ":" << shiftedRect << endl;
381  }
382  if(!shiftedRect.hasNans())
383  {
384  if(m_BoundingRect.hasNans())
385  {
386  m_BoundingRect = shiftedRect;
387  }
388  else
389  {
390  m_BoundingRect = m_BoundingRect.combine(shiftedRect);
391  }
392  }
393  }
394 }
std::vector< ossimDpt > m_InputTiePoints
#define CLOG
Definition: ossimTrace.h:23
ossimIrect getRelativeRect(ossim_uint32 index, ossim_uint32 resLevel=0) const
unsigned int ossim_uint32
void makeNan()
Definition: ossimIrect.h:329
bool hasNans() const
Definition: ossimIrect.h:337
ossimIrect combine(const ossimIrect &rect) const
Definition: ossimIrect.cpp:543
◆ getBoundingRect()
ossimIrect ossimOrthoImageMosaic::getBoundingRect ( ossim_uint32  resLevel = 0) const
virtual
This will return the bounding rect of the source.
We can have several sources which are in a chain to modify the bounding image rect. lets say you are next to an image handler then it will return the bounding rect for that image. If you are at the right side of a resampler then you will get a bounding rect along the image view plane. This is going to be a very import method for both image writers, mosaics or anything that needs to operate only within the bounds of an image.
Reimplemented from ossimImageCombiner.
Definition at line 158 of file ossimOrthoImageMosaic.cpp.
References ossimConnectableObject::getInput(), ossimDpt::hasNans(), m_BoundingRect, ossimDpt::makeNan(), and PTR_CAST.
159 {
160  ossimDpt decimation;
161
162  decimation.makeNan();
163
165  getInput(0));
166  if(interface)
167  {
168  interface->getDecimationFactor(resLevel,
169  decimation);
170  }
171  if(decimation.hasNans())
172  {
173  return m_BoundingRect;
174  }
175  return m_BoundingRect*decimation;
176 }
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
Definition: ossimDpt.h:67
void makeNan()
◆ getImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimOrthoImageMosaic::getImageGeometry ( )
virtual
This object maintains it's own geometry instance.
Definition at line 108 of file ossimOrthoImageMosaic.cpp.
References ossimConnectableObject::getInput(), m_Geometry, PTR_CAST, updateGeometry(), and ossimRefPtr< T >::valid().
Referenced by ossimTiledElevationDatabase::mapRegion().
109 {
110  if ( !m_Geometry.valid() )
111  {
112  // The geometry (projection) associated with this mosaic is necessarily the same for all
113  // single-image objects feeding into this combiner, So we will copy the first image source's
114  // geometry, and modify our copy to reflect the mosaic-specific items.
116  if(interface)
117  {
118  ossimRefPtr<ossimImageGeometry> inputGeom = interface->getImageGeometry();
119  if ( inputGeom.valid() )
120  {
121  m_Geometry = new ossimImageGeometry(*inputGeom);
122  updateGeometry();
123  }
124  }
125  }
126  return m_Geometry;
127 }
bool valid() const
Definition: ossimRefPtr.h:75
void updateGeometry()
If this object is maintaining an ossimImageGeometry, this method needs to be called after each time t...
ossimRefPtr< ossimImageGeometry > m_Geometry
◆ getNextTile()
ossimRefPtr< ossimImageData > ossimOrthoImageMosaic::getNextTile ( ossim_uint32 returnedIdx,
const ossimIrect origin,
virtual
Definition at line 290 of file ossimOrthoImageMosaic.cpp.
References ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), getRelativeRect(), OSSIM_NULL, PTR_CAST, size, status, and ossimImageCombiner::theCurrentIndex.
293 {
294  const char *MODULE="ossimOrthoImageMosaic::getNextTile";
295
297
298  if(theCurrentIndex >= size)
299  {
301  }
302
303  ossimImageSource* temp = NULL;
306
307  do
308  {
310  if(temp)
311  {
312  ossimIrect relRect = getRelativeRect(theCurrentIndex, resLevel);
313
314  if(traceDebug())
315  {
316  CLOG << "Rel rect for input " << theCurrentIndex
317  << " = " << relRect
318  << "\nRes level: " << resLevel
319  << endl;
320  }
321
322  if(origin.intersects(relRect))
323  {
324  // get the rect relative to the input rect
325  //
326  ossimIrect shiftedRect = origin + (ossimIpt(-relRect.ul().x,
327  -relRect.ul().y));
328
329  // request that tile from the input space.
330  result = temp->getTile(shiftedRect, resLevel);
331
332  // now change the origin to the output origin.
333  if (result.valid())
334  {
335  result->setOrigin(origin.ul());
336
337  status = result->getDataObjectStatus();
338
339  if((status == OSSIM_NULL)||(status == OSSIM_EMPTY))
340  {
341  result = NULL;
342  }
343  }
344  }
345  else
346  {
347  result = NULL;
348  }
349  }
350
351  // Go to next source.
352  ++theCurrentIndex;
353
354  } while(!result.valid() && (theCurrentIndex<size));
355
356  returnedIdx = theCurrentIndex;
357  if(result.valid())
358  {
359  --returnedIdx;
360  }
361  return result;
362 }
#define CLOG
bool valid() const
const ossimIpt & ul() const
Definition: ossimIrect.h:274
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
yy_size_t size
virtual void setOrigin(const ossimIpt &origin)
return status
ossim_int32 y
Definition: ossimIpt.h:142
virtual ossim_uint32 getNumberOfInputs() const
Returns the number of input objects.
ossim_int32 x
Definition: ossimIpt.h:141
ossimDataObjectStatus
Definitions for data object status.
◆ getNumberOfOverlappingImages()
ossim_uint32 ossimOrthoImageMosaic::getNumberOfOverlappingImages ( const ossimIrect rect,
) const
virtual
Definition at line 51 of file ossimOrthoImageMosaic.cpp.
References ossimConnectableObject::getInput(), getRelativeRect(), ossimIrect::hasNans(), ossimIrect::intersects(), m_InputTiePoints, and PTR_CAST.
53 {
54  ossim_uint32 result = 0;
55  for(ossim_uint32 i = 0; i < m_InputTiePoints.size(); ++i)
56  {
58  getInput(i));
59  if(interface&&
60  !m_InputTiePoints[i].hasNans())
61  {
62  ossimIrect tempRect = getRelativeRect(i, resLevel);
63
64  if(!tempRect.hasNans())
65  {
66  if(tempRect.intersects(rect))
67  {
68  ++result;
69  }
70  }
71  }
72  }
73
74  return 0;
75 }
◆ getOverlappingImages()
void ossimOrthoImageMosaic::getOverlappingImages ( std::vector< ossim_uint32 > &  result,
) const
virtual
Definition at line 80 of file ossimOrthoImageMosaic.cpp.
83 {
84  result.clear();
85  for(ossim_uint32 i = 0; i < m_InputTiePoints.size(); ++i)
86  {
88  getInput(i));
89  if(interface&&
90  !m_InputTiePoints[i].hasNans())
91  {
92  ossimIrect tempRect = getRelativeRect(i, resLevel);
93
94  if(!tempRect.hasNans())
95  {
96  if(tempRect.intersects(rect))
97  {
98  result.push_back(i);
99  }
100  }
101  }
102  }
103 }
◆ getRelativeRect()
ossimIrect ossimOrthoImageMosaic::getRelativeRect ( ossim_uint32  index,
) const
Definition at line 399 of file ossimOrthoImageMosaic.cpp.
References ossimConnectableObject::getInput(), ossimDpt::hasNans(), ossimIrect::hasNans(), m_Delta, m_InputTiePoints, m_UpperLeftTie, ossimIrect::makeNan(), PTR_CAST, ossimDpt::x, and ossimDpt::y.
Referenced by computeBoundingRect(), getNextTile(), getNumberOfOverlappingImages(), and getOverlappingImages().
401 {
402  ossimIrect result;
404  getInput(index));
405  result.makeNan();
406  if(interface&&
407  !m_InputTiePoints[index].hasNans())
408  {
409  ossimIrect inputRect = interface->getBoundingRect();
410  result = inputRect;
411
412  if(!inputRect.hasNans())
413  {
414  ossimDpt shift = (m_InputTiePoints[index] - m_UpperLeftTie);
415
416  shift.x/= m_Delta.x;
417  shift.y/=-m_Delta.y;
418
419  result = result + shift;
420  if(!resLevel)
421  {
422  return result;
423  }
424  ossimDpt decimation;
425  interface->getDecimationFactor(resLevel, decimation);
426  if(!decimation.hasNans())
427  {
428  result = result * decimation;
429  }
430  }
431  }
432
433  return result;
434 }
double y
Definition: ossimDpt.h:165
ossimDpt m_Delta
void makeNan()
double x
Definition: ossimDpt.h:164
◆ initialize()
void ossimOrthoImageMosaic::initialize ( )
virtual
Reimplemented from ossimImageMosaic.
Definition at line 181 of file ossimOrthoImageMosaic.cpp.
References m_Delta, m_InputTiePoints, m_UpperLeftTie, and ossimDpt::makeNan().
182 {
183  m_InputTiePoints.clear();
184  m_Delta.makeNan();
186
187  if(traceDebug())
188  {
190  << "ossimOrthoImageMosaic::initialize() DEBUG: Entered..."
191  << "Number of inputs = " << getNumberOfInputs()
192  << std::endl;
193  }
194  if(getNumberOfInputs())
195  {
197  for(ossim_uint32 i = 0; i < getNumberOfInputs(); ++i)
198  {
200  m_InputTiePoints[i].makeNan();
201  if(interface)
202  {
203  ossimRefPtr<ossimImageGeometry> geom = interface->getImageGeometry();
204  if( geom.valid() )
205  {
207  if(mapPrj)
208  {
209  if(!mapPrj->isGeographic())
210  {
211  m_Units = "meters";
212  m_Delta = mapPrj->getMetersPerPixel();
213  }
214  else
215  {
216  m_Units = "degrees";
218  }
219  if(m_Units == "degrees")
220  {
221  m_InputTiePoints[i].x = mapPrj->getUlGpt().lond();
222  m_InputTiePoints[i].y = mapPrj->getUlGpt().latd();
223  }
224  else if(m_Units == "meters")
225  {
226  m_InputTiePoints[i].x = mapPrj->getUlEastingNorthing().x;;
227  m_InputTiePoints[i].y = mapPrj->getUlEastingNorthing().y;
228  }
229
230  if(traceDebug())
231  {
233  << "tie points for input " << i << " = "
234  << m_InputTiePoints[i] << std::endl;
235  }
236
237  }
238  }
239  if(!m_InputTiePoints[i].hasNans())
240  {
241  if(m_UpperLeftTie.hasNans())
242  {
244  }
245  else if(!m_InputTiePoints[i].hasNans())
246  {
247  if(m_Units == "meters")
248  {
251  }
252  else
253  {
256  }
257  }
258  }
259  }
260  else
261  {
262  m_InputTiePoints[i].makeNan();
263 // CLOG << "Input " << i << " will not be used since no ortho information exists" << endl;
264  }
265  }
266  }
267
269  if(traceDebug())
270  {
272  << "m_UpperLeftTie = " << m_UpperLeftTie << std::endl
273  << "delta per pixel = " << m_Delta << std::endl
274  << "bounding rect = " << m_BoundingRect << std::endl;
275  }
277
278  // Finally, update the geometry (if there was one already defined), to reflect the change in input
279  updateGeometry();
280
281  if(traceDebug())
282  {
283  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimOrthoImageMosaic::initialize() DEBUG: Leaving..." << std::endl;
284  }
285 }
virtual const ossimDpt & getDecimalDegreesPerPixel() const
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing...
double lond() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:97
bool valid() const
void computeBoundingRect(ossim_uint32 resLevel=0)
double y
ossimDpt m_Delta
virtual bool isGeographic() const
double latd() const
Definition: ossimGpt.h:87
virtual void initialize()
double lat
double lon
virtual const ossimGpt & getUlGpt() const
#define max(a, b)
Definition: auxiliary.h:76
double x
virtual const ossimDpt & getUlEastingNorthing() const
virtual ossimDpt getMetersPerPixel() const
void makeNan()
#define min(a, b)
Definition: auxiliary.h:75
◆ updateGeometry()
void ossimOrthoImageMosaic::updateGeometry ( )
protected
Definition at line 133 of file ossimOrthoImageMosaic.cpp.
References ossimGpt::datum(), ossimImageGeometry::getProjection(), m_Delta, m_Geometry, m_Units, m_UpperLeftTie, ossimMapProjection::origin(), PTR_CAST, ossimMapProjection::setDecimalDegreesPerPixel(), ossimMapProjection::setMetersPerPixel(), ossimMapProjection::setUlEastingNorthing(), ossimMapProjection::setUlGpt(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Referenced by getImageGeometry().
134 {
135  if (!m_Geometry.valid())
136  return;
137
139  if (mapProj)
140  {
141  if(m_Units == "degrees")
142  {
145  mapProj->origin().datum()));
146  }
147  else if(m_Units == "meters")
148  {
149  mapProj->setMetersPerPixel(m_Delta);
151  }
152  }
153 }
bool valid() const
double y
ossimDpt m_Delta
virtual void setDecimalDegreesPerPixel(const ossimDpt &gsd)
virtual void setUlGpt(const ossimGpt &ulGpt)
virtual void setMetersPerPixel(const ossimDpt &gsd)
const ossimDatum * datum() const
datum().
Definition: ossimGpt.h:196
virtual void setUlEastingNorthing(const ossimDpt &ulEastingNorthing)
virtual ossimGpt origin() const
double x
Member Data Documentation
◆ m_BoundingRect
ossimIrect ossimOrthoImageMosaic::m_BoundingRect
protected
Definition at line 54 of file ossimOrthoImageMosaic.h.
Referenced by computeBoundingRect(), and getBoundingRect().
◆ m_Delta
ossimDpt ossimOrthoImageMosaic::m_Delta
protected
Definition at line 52 of file ossimOrthoImageMosaic.h.
Referenced by getRelativeRect(), initialize(), ossimOrthoImageMosaic(), and updateGeometry().
◆ m_Geometry
ossimRefPtr<ossimImageGeometry> ossimOrthoImageMosaic::m_Geometry
protected
Definition at line 56 of file ossimOrthoImageMosaic.h.
Referenced by getImageGeometry(), and updateGeometry().
◆ m_InputTiePoints
std::vector<ossimDpt> ossimOrthoImageMosaic::m_InputTiePoints
protected
◆ m_Units
ossimString ossimOrthoImageMosaic::m_Units
protected
Definition at line 55 of file ossimOrthoImageMosaic.h.
Referenced by updateGeometry().
◆ m_UpperLeftTie
ossimDpt ossimOrthoImageMosaic::m_UpperLeftTie
protected
Definition at line 53 of file ossimOrthoImageMosaic.h.
