#include <ossimMapProjectionFactory.h>
virtual ossimProjection * | createProjection (const ossimFilename &filename, ossim_uint32 entryIdx) const |
takes a filename. More... | |
virtual ossimProjection * | createProjection (const ossimString &name) const |
virtual ossimProjection * | createProjection (const ossimKeywordlist &kwl, const char *prefix=0) const |
Take a keywordlist. More... | |
virtual ossimObject * | createObject (const ossimString &typeName) const |
virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
virtual ossimProjection * | createProjection (ossimImageHandler *handler) const |
virtual | ~ossimObjectFactory () |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
static ossimMapProjectionFactory * | instance () |
ossimMapProjectionFactory () | |
ossimProjection * | createProjectionFromGeometryFile (const ossimFilename &imageFile, ossim_uint32 entryIdx) const |
This method takes the filename and tries to find an external ".geom" file. More... | |
virtual | ~ossimReferenced () |
Static Protected Attributes | |
static ossimMapProjectionFactory * | theInstance = 0 |
Definition at line 26 of file ossimMapProjectionFactory.h.
inlineprotected |
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 249 of file ossimMapProjectionFactory.cpp.
References createProjection().
Creates and object given a keyword list.
Definition at line 254 of file ossimMapProjectionFactory.cpp.
takes a filename.
This filename can be an image file or it can also be a ossim .geom file. It could be other forms of geom files as well. The factories job will be to determine what parser to use and return a projection if successful.
Implements ossimProjectionFactoryBase.
Definition at line 83 of file ossimMapProjectionFactory.cpp.
References ossimKeywordlist::addFile(), ossimProjectionFactoryBase::createProjectionFromGeometryFile(), ossimFilename::exists(), and ossimFilename::setExtension().
Referenced by createObject(), createProjection(), ossimFgdcTxtDoc::getProjectionV1(), and ossimAdjMapModel::loadState().
METHOD: create() Attempts to create an instance of the projection specified by name. Returns successfully constructed projection or NULL.
Definition at line 181 of file ossimMapProjectionFactory.cpp.
References STATIC_TYPE_NAME.
Take a keywordlist.
Definition at line 118 of file ossimMapProjectionFactory.cpp.
References ossimKeywordlist::add(), ossimKeywordlist::addFile(), ossimProjectionFactoryRegistry::createProjection(), createProjection(), ossimSpaceImagingGeom::exportToOssim(), ossimKeywordlist::find(), ossimKeywordNames::GEOM_FILE_KW, ossimProjectionFactoryRegistry::instance(), ossimProjection::loadState(), ossimSpaceImagingGeom::setGeometry(), ossimSpaceImagingGeom::SIG_PRODUCER_KW, and ossimKeywordNames::TYPE_KW.
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 260 of file ossimMapProjectionFactory.cpp.
static |
METHOD: instance() Instantiates singleton instance of this class:
Definition at line 72 of file ossimMapProjectionFactory.cpp.
References ossimMapProjectionFactory(), and theInstance.
Referenced by ossimEpsgProjectionDatabase::createProjFromFormatBRecord(), ossimGeneralRasterTileSource::getImageGeometry(), ossimFgdcTxtDoc::getProjectionV1(), ossimProjectionFactoryRegistry::initializeDefaults(), and ossimAdjMapModel::loadState().
staticprotected |
Definition at line 62 of file ossimMapProjectionFactory.h.
Referenced by instance().
