This class imlements the fusion algorithm from the paper: More...
#include <ossimSFIMFusion.h>
ossimSFIMFusion () | |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &rect, ossim_uint32 resLevel=0) |
virtual void | initialize () |
virtual ossimObject * | getBaseObject () |
virtual const ossimObject * | getBaseObject () const |
virtual void | initAdjustableParameters () |
virtual void | adjustableParametersChanged () |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
Method to save the state of an object to a keyword list. More... | |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
Method to the load (recreate) the state of an object from a keyword list. More... | |
ossimFusionCombiner () | |
ossimFusionCombiner (ossimObject *owner) | |
virtual ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
This will return the bounding rect of the source. More... | |
bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
required to be overriden by derived classes More... | |
ossimScalarType | getOutputScalarType () const |
This will be used to query the output pixel type of the tile source. More... | |
ossimImageCombiner () | |
ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
virtual void | updateRects () |
This will go through and precompute the bounding rects of each input image. More... | |
virtual ossim_uint32 | getNumberOfInputBands () const |
Returns the number of bands available from the input. More... | |
virtual ossim_uint32 | getTileWidth () const |
Returns the default processing tile width. More... | |
virtual ossim_uint32 | getTileHeight () const |
Returns the default processing tile height. More... | |
virtual double | getNullPixelValue (ossim_uint32 band=0) const |
Each band has a null pixel associated with it. More... | |
virtual double | getMinPixelValue (ossim_uint32 band=0) const |
Returns the min pixel of the band. More... | |
virtual double | getMaxPixelValue (ossim_uint32 band=0) const |
Returns the max pixel of the band. More... | |
virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
Used to retrieve the number of overlapping images withint the given rect. More... | |
virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
Used to populate the result with the index of the overlapping images. More... | |
virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
virtual void | connectInputEvent (ossimConnectionEvent &event) |
virtual void | disconnectInputEvent (ossimConnectionEvent &event) |
virtual void | propertyEvent (ossimPropertyEvent &event) |
virtual void | refreshEvent (ossimRefreshEvent &event) |
virtual bool | hasDifferentInputs () const |
ossimImageSource (ossimObject *owner=0) | |
ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimImageSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIpt &origin, ossim_uint32 resLevel=0) |
virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel=0) |
Method to get a tile. More... | |
virtual ossimObject * | getObject () |
For RTTI support. More... | |
virtual const ossimObject * | getObject () const |
virtual void | getDecimationFactor (ossim_uint32 resLevel, ossimDpt &result) const |
Will return the decimation factor for the given resolution level. More... | |
virtual void | getDecimationFactors (std::vector< ossimDpt > &decimations) const |
Will return an array of all decimations for each resolution level. More... | |
virtual ossim_uint32 | getNumberOfDecimationLevels () const |
Will return the number of resolution levels. More... | |
virtual ossim_uint32 | getNumberOfOutputBands () const |
Returns the number of bands in a tile returned from this TileSource. More... | |
virtual void | getOutputBandList (std::vector< ossim_uint32 > &bandList) const |
Initializes bandList. More... | |
virtual void | getBoundingRect (ossimIrect &rect, ossim_uint32 resLevel=0) const |
Gets the bounding rectangle of the source. More... | |
virtual void | getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
ordering specifies how the vertices should be arranged. More... | |
virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
Returns the image geometry object associated with this tile source or NULL if not defined. More... | |
virtual void | setImageGeometry (const ossimImageGeometry *geom) |
Default implementation sets geometry of the first input to the geometry specified. More... | |
virtual void | saveImageGeometry () const |
Default method to call input's saveImageGeometry. More... | |
virtual void | saveImageGeometry (const ossimFilename &geometry_file) const |
virtual bool | isIndexedData () const |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
ossimConnectableObjectListener () | |
virtual | ~ossimConnectableObjectListener () |
virtual void | processEvent (ossimEvent &event) |
ProcessEvent. More... | |
virtual void | objectDestructingEvent (ossimObjectDestructingEvent &) |
virtual void | connectionEvent (ossimConnectionEvent &) |
virtual void | disconnectOutputEvent (ossimConnectionEvent &) |
virtual void | connectOutputEvent (ossimConnectionEvent &) |
virtual void | addObjectEvent (ossimContainerEvent &) |
virtual void | removeObjectEvent (ossimContainerEvent &) |
virtual void | containerEvent (ossimContainerEvent &) |
ossimListener () | |
virtual | ~ossimListener () |
void | enableListener () |
void | disableListener () |
void | setListenerEnableFlag (bool flag) |
bool | isListenerEnabled () const |
bool | getListenerEnableFlag () const |
ossimAdjustableParameterInterface () | |
ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
virtual | ~ossimAdjustableParameterInterface () |
void | newAdjustment (ossim_uint32 numberOfParameters=0) |
void | setAdjustmentDescription (const ossimString &description) |
ossimString | getAdjustmentDescription () const |
ossimString | getAdjustmentDescription (ossim_uint32 adjustmentIdx) const |
Returns adjustmentDescription of specific adjustmentInfo. More... | |
void | setCurrentAdjustment (ossim_uint32 adjustmentIndex, bool notify=false) |
bool | setCurrentAdjustment (const ossimString &description, bool notify=false) |
Sets the current adjustment to the adjustment with a matching description. More... | |
void | eraseAdjustment (bool notify) |
void | eraseAdjustment (ossim_uint32 idx, bool notify) |
void | resetAdjustableParameters (bool notify=false) |
void | copyAdjustment (ossim_uint32 idx, bool notify) |
void | copyAdjustment (bool notify=false) |
void | keepAdjustment (ossim_uint32 idx, bool createCopy) |
virtual void | keepAdjustment (bool createCopy=true) |
const ossimAdjustableParameterInterface & | operator= (const ossimAdjustableParameterInterface &rhs) |
void | removeAllAdjustments () |
ossim_uint32 | getNumberOfAdjustableParameters () const |
double | getAdjustableParameter (ossim_uint32 idx) const |
virtual void | setAdjustableParameter (ossim_uint32 idx, double value, bool notify=false) |
virtual void | setAdjustableParameter (ossim_uint32 idx, double value, double sigma, bool notify=false) |
double | getParameterSigma (ossim_uint32 idx) const |
void | setParameterSigma (ossim_uint32 idx, double value, bool notify=false) |
ossimUnitType | getParameterUnit (ossim_uint32 idx) const |
void | setParameterUnit (ossim_uint32 idx, ossimUnitType unit) |
void | setParameterUnit (ossim_uint32 idx, const ossimString &unit) |
void | setParameterCenter (ossim_uint32 idx, double center, bool notify=false) |
double | getParameterCenter (ossim_uint32 idx) const |
double | computeParameterOffset (ossim_uint32 idx) const |
void | setParameterOffset (ossim_uint32 idx, ossim_float64 value, bool notify=false) |
ossimString | getParameterDescription (ossim_uint32 idx) const |
void | setParameterDescription (ossim_uint32 idx, const ossimString &descrption) |
ossim_int32 | findParameterIdxGivenDescription (ossim_uint32 adjustmentIdx, const ossimString &name) const |
ossim_int32 | findParameterIdxContainingDescription (ossim_uint32 adjustmentIdx, const ossimString &name) const |
bool | isParameterLocked (ossim_uint32 idx) const |
void | setParameterLockFlag (ossim_uint32 idxParam, bool flag) |
bool | getParameterLockFlag (ossim_uint32 idx) const |
void | lockAllParametersCurrentAdjustment () |
void | unlockAllParametersCurrentAdjustment () |
void | lockAllParameters (ossim_uint32 idxAdjustment) |
void | unlockAllParameters (ossim_uint32 idxAdjustment) |
void | resizeAdjustableParameterArray (ossim_uint32 numberOfParameters) |
void | setAdjustment (const ossimAdjustmentInfo &adj, bool notify=false) |
void | setAdjustment (ossim_uint32 idx, const ossimAdjustmentInfo &adj, bool notify=false) |
void | addAdjustment (const ossimAdjustmentInfo &adj, bool notify) |
void | getAdjustment (ossimAdjustmentInfo &adj) const |
void | getAdjustment (ossim_uint32 idx, ossimAdjustmentInfo &adj) const |
ossim_uint32 | getNumberOfAdjustments () const |
ossim_uint32 | getCurrentAdjustmentIdx () const |
void | setDirtyFlag (bool flag=true) |
void | setAllDirtyFlag (bool flag=true) |
bool | hasDirtyAdjustments () const |
virtual void | saveCurrentAdjustmentOnly (ossimKeywordlist &kwl, const ossimString &prefix=ossimString("")) |
Saves the current active adjustment to the KWL file. More... | |
bool | saveAdjustments (ossimKeywordlist &kwl, const ossimString &prefix=ossimString("")) const |
Save all adjustments to the KWL file. More... | |
bool | loadAdjustments (const ossimKeywordlist &kwl, const ossimString &prefix=ossimString("")) |
virtual void | updateModel () |
Provides the derived adjustable class an opportunity to update its state after a param change. More... | |
Dumps the currently active adjustment to ostream. More... | |
virtual | ~ossimSFIMFusion () |
void | setFilters () |
bool | computeRegression (ossim_float64 &slopeResult, const ossimIpt &origin, ossimRefPtr< ossimImageData > panData, ossimRefPtr< ossimImageData > colorData, ossim_uint32 colorBandIdx) |
virtual | ~ossimFusionCombiner () |
ossimRefPtr< ossimImageData > | getNormIntensity (const ossimIrect &rect, ossim_uint32 resLevel) |
ossimRefPtr< ossimImageData > | getNormTile (const ossimIrect &rect, ossim_uint32 resLevel) |
virtual | ~ossimImageCombiner () |
void | precomputeBounds () const |
ossimImageSource (const ossimImageSource &rhs) | |
const ossimImageSource & | operator= (const ossimImageSource &) |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
bool | paramChanged (ossim_uint32 param_idx) const |
Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
void | setAllChangeFlags (bool areChanged) |
Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
void | initChangeFlags () |
Initializes the change flags to TRUE. More... | |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
"Smoothing Filter-based Intesity Modulation: a spectral preserve image fusion technique for improving spatial details"
Pulished in INT. J. Remote Sensing, 2000, Vol. 21 NO. 18, 3461-3472
By J. G. LIU
Auther: Garrett Potts LICENSE: MIT
Definition at line 31 of file ossimSFIMFusion.h.
ossimSFIMFusion::ossimSFIMFusion | ( | ) |
Definition at line 29 of file ossimSFIMFusion.cpp.
References initAdjustableParameters(), setFilters(), theAutoAdjustScales, theHighPassFilter, and theLowPassFilter.
protectedvirtual |
Definition at line 42 of file ossimSFIMFusion.cpp.
Reimplemented from ossimAdjustableParameterInterface.
Definition at line 314 of file ossimSFIMFusion.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), and theLowPassKernelWidth.
Referenced by initialize(), and loadState().
protected |
inlinevirtual |
Implements ossimAdjustableParameterInterface.
Definition at line 40 of file ossimSFIMFusion.h.
inlinevirtual |
Definition at line 44 of file ossimSFIMFusion.h.
Definition at line 345 of file ossimSFIMFusion.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), and ossimString::toString().
Definition at line 375 of file ossimSFIMFusion.cpp.
References ossimImageSource::getPropertyNames().
Definition at line 46 of file ossimSFIMFusion.cpp.
References ossimImageData::copyNormalizedBufferToTile(), ossimImageData::copyTileBandToNormalizedBuffer(), ossimImageData::dup(), FLT_EPSILON, ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimConnectableObject::getInput(), ossimImageData::getMinPix(), ossimFusionCombiner::getNormTile(), ossimImageData::getNumberOfBands(), ossimImageSource::getTile(), ossimImageGaussianFilter::getTile(), ossimConvolutionSource::getTile(), ossimImageData::getWidth(), ossimIrect::height(), initialize(), ossimImageData::initialize(), ossimImageData::loadTile(), ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_NORMALIZED_FLOAT, ossimImageData::setImageRectangle(), theHighPassFilter, ossimFusionCombiner::theInputConnection, ossimFusionCombiner::theIntensityConnection, theLowPassFilter, theNormHighPassTile, theNormLowPassTile, ossimFusionCombiner::theTile, ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIrect::width(), x, and y.
Definition at line 287 of file ossimSFIMFusion.cpp.
References ossimAdjustableParameterInterface::resizeAdjustableParameterArray().
Referenced by ossimSFIMFusion().
Reimplemented from ossimFusionCombiner.
Definition at line 196 of file ossimSFIMFusion.cpp.
References ossimConnectableObject::accept(), adjustableParametersChanged(), ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnectAllInputs(), ossimImageSource::getImageGeometry(), ossimConnectableObject::getInput(), ossimImageGeometry::getMetersPerPixel(), ossimImageSource::getObject(), ossimCollectionVisitor::getObjectAs(), ossimDpt::hasNans(), ossimFusionCombiner::initialize(), ossimImageGaussianFilter::initialize(), ossimConvolutionSource::initialize(), ossimDpt::length(), PTR_CAST, ossimCollectionVisitor::reset(), setFilters(), ossimAdjustableParameterInterface::setParameterOffset(), theAutoAdjustScales, theHighPassFilter, ossimFusionCombiner::theInputConnection, ossimFusionCombiner::theIntensityConnection, theLowPassFilter, and ossimRefPtr< T >::valid().
Referenced by getTile().
Reimplemented from ossimImageCombiner.
Definition at line 396 of file ossimSFIMFusion.cpp.
References adjustableParametersChanged(), ossimString::empty(), ossimKeywordlist::find(), ossimAdjustableParameterInterface::loadAdjustments(), ossimImageCombiner::loadState(), theAutoAdjustScales, and ossimString::toBool().
Definition at line 383 of file ossimSFIMFusion.cpp.
References ossimKeywordlist::add(), ossimAdjustableParameterInterface::saveAdjustments(), ossimImageCombiner::saveState(), and theAutoAdjustScales.
protected |
Definition at line 255 of file ossimSFIMFusion.cpp.
References ossimAdjustableParameterInterface::computeParameterOffset(), ossimImageGaussianFilter::setGaussStd(), theHighPassKernelWidth, theHighPassMatrix, theLowPassFilter, and theLowPassKernelWidth.
Referenced by initialize(), and ossimSFIMFusion().
Definition at line 320 of file ossimSFIMFusion.cpp.
References ossimAdjustableParameterInterface::setParameterOffset().
protected |
Definition at line 81 of file ossimSFIMFusion.h.
Referenced by initialize(), loadState(), ossimSFIMFusion(), and saveState().
protected |
Definition at line 75 of file ossimSFIMFusion.h.
Referenced by getTile(), initialize(), and ossimSFIMFusion().
protected |
Definition at line 71 of file ossimSFIMFusion.h.
Referenced by setFilters().
protected |
Definition at line 80 of file ossimSFIMFusion.h.
protected |
Definition at line 74 of file ossimSFIMFusion.h.
Referenced by getTile(), initialize(), ossimSFIMFusion(), and setFilters().
protected |
Definition at line 70 of file ossimSFIMFusion.h.
Referenced by adjustableParametersChanged(), and setFilters().
protected |
Definition at line 78 of file ossimSFIMFusion.h.
protected |
Definition at line 77 of file ossimSFIMFusion.h.
protected |
Definition at line 76 of file ossimSFIMFusion.h.
