28 static const char* PARAMETER_KEYWORDS[] = {
"map_offset_x",
33 static const char* MAP_PROJ_FILE_KW =
"map_proj_filename";
44 theAdjParams(NUM_ADJ_PARAMS),
62 theAdjParams(NUM_ADJ_PARAMS),
63 theMapProjection(map_proj),
79 theAdjParams(NUM_ADJ_PARAMS),
80 theMapProjection(copy_this.theMapProjection),
94 theAdjParams(NUM_ADJ_PARAMS),
111 theAdjParams(NUM_ADJ_PARAMS),
199 const double& heightEllipsoid,
220 worldPoint.
height(heightEllipsoid);
271 if (map_prefix.
size() && (map_prefix[map_prefix.
size()-1] !=
273 map_prefix +=
"map_proj.";
294 static const ossimString MODULE (
"ossimAdjMapModel::loadState() -- ");
296 const char* value_str;
298 ossimString error_msg (MODULE+
"Error encountered reading keyword: ");
304 if ((!value_str) || (strcmp(value_str,
TYPE_NAME(
this))))
310 if (map_prefix.
size()-1] !=
312 map_prefix +=
"map_proj.";
323 value_str = kwl.
find(prefix, MAP_PROJ_FILE_KW);
326 throw (error_msg + MAP_PROJ_FILE_KW);
332 throw "Error encountered instantiating map ";
343 value_str = kwl.
find(prefix, PARAMETER_KEYWORDS[i]);
346 throw (error_msg + PARAMETER_KEYWORDS[i]).chars();
348 value = atof(value_str);
380 "//*****************************************************************\n" 381 "// Template for Adjustable Map Model keywordlist\n" 382 "//*****************************************************************\n" 388 <<
"// Derived-class AdjMapModel Keywords:\n" 390 << PARAMETER_KEYWORDS[
OFFSET_X] <<
": <east offset meters>\n" 391 << PARAMETER_KEYWORDS[
OFFSET_Y] <<
": <north offset meters>\n" 392 << PARAMETER_KEYWORDS[
ROTATION] <<
": <degrees CW>\n" 393 << PARAMETER_KEYWORDS[
SCALE_X] <<
": <ratio>\n" 394 << PARAMETER_KEYWORDS[
SCALE_Y] <<
": <ratio>\n" 407 out << PARAMETER_KEYWORDS[i] <<
theAdjParams[i] << endl;
virtual ossimProjection * createProjection(const ossimFilename &filename, ossim_uint32 entryIdx) const
takes a filename.
void setParameterDescription(ossim_uint32 idx, const ossimString &descrption)
double computeParameterOffset(ossim_uint32 idx) const
virtual void initAdjustableParameters()
Initializes adjustable parameters to their default values.
virtual ossimDpt getMetersPerPixel() const
Fetches the GSD from the internal map projection.
double nan()
virtual ossimDpt worldToLineSample(const ossimGpt &worldPoint) const
static ossimMapProjectionFactory * instance()
ColumnVector theAdjParams
This is the vector of UNNORMALIZED, BIASED parameters as used in the model.
Extends base-class implementation. Dumps contents of object to ostream.
void setAdjustmentDescription(const ossimString &description)
static const char * TYPE_KW
virtual void updateModel()
Following a change to the adjustable parameter set, this virtual is.
std::string::size_type size() const
virtual ossimGpt origin() const
virtual ossimObject * dup() const
Returns pointer to a new instance, copy of this.
void newAdjustment(ossim_uint32 numberOfParameters=0)
const char * chars() const
For backward compatibility.
bool initializeFromMap()
Initializes base class data members after map model established.
ossimErrorCode theErrorStatus
static void writeGeomTemplate(ostream &os)
virtual void lineSampleToWorld(const ossimDpt &image_point, ossimGpt &worldPoint) const
Overrides base class virtual.
virtual void setAdjustableParameter(ossim_uint32 idx, double value, bool notify=false)
virtual void worldToLineSample(const ossimGpt &world_point, ossimDpt &image_point) const
Rigorous inverse transform implented, overrides base-class' iterative.
Fulfills ossimObject base-class pure virtuals.
void removeAllAdjustments()
ossimRefPtr< ossimMapProjection > theMapProjection
Writes a template of geom keywords processed by loadState and saveState.
virtual void lineSampleHeightToWorld(const ossimDpt &image_point, const double &heightEllipsoid, ossimGpt &worldPoint) const
Overrides base class pure virtual.
Special "sensor model" that provides a conventional map projection but with.
ossimAdjMapModel()
Constructs to uninitialized state (needed by factory).
void setParameterCenter(ossim_uint32 idx, double center, bool notify=false)
virtual void lineSampleHeightToWorld(const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const
This is the pure virtual that projects the image point to the given elevation above ellipsoid...
virtual ~ossimAdjMapModel()
ground to image faster (you don't need DEM)
RTTI_DEF1(ossimAdjMapModel, "ossimAdjMapModel", ossimSensorModel)
std::basic_ostream< char > ostream
Base class for char output streams.
