40 static ossimTrace traceDebug(
"ossimAdrgTileSource:debug");
186 ulTilePt.
x = tileOrigin.
x;
211 int seek_position = (tileOffset - 1) * 49152 + 2048;
215 m_FileStr.seekg(seek_position, ios::beg);
216 for (band=0; band<3; band++)
288 static const char MODULE[] =
"ossimAdrgTileSource::open";
293 << MODULE <<
"Entered..."<<std::endl;
313 << MODULE <<
" Error in ossimAdrg header detected." << std::endl;
321 ios::in | ios::binary);
372 const char* prefix)
const 447 degPerPixelY ) - ( degPerPixelY * 0.5 ) );
450 degPerPixelX ) + ( degPerPixelX * 0.5 ) );
454 const char* prefix = 0;
457 "ossimEquDistCylProjection",
481 ossimDpt(ul_lon, ul_lat).toString().c_str(),
502 ossimDpt(degPerPixelX, degPerPixelY).toString().c_str(),
549 <<
"\nfull image lines: " << lines
550 <<
"\nfull image samples: " << samples
639 if(name ==
"file_type")
650 propertyNames.push_back(
"file_type");
virtual void loadBand(const void *src, const ossimIrect &src_rect, ossim_uint32 band)
ossimRefPtr< ossimImageGeometry > theGeometry
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
ossimRefPtr< ossimImageData > m_Tile
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &rect, ossim_uint32 resLevel=0)
Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab fr...
static const char * DATUM_KW
ossimFilename theImageFile
static const char * CENTRAL_MERIDIAN_KW
virtual ossimString getShortName() const
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
static const char * NUMBER_LINES_KW
static const char * TIE_POINT_LON_KW
virtual ossim_uint32 getImageTileWidth() const
static const char * NUMBER_INPUT_BANDS_KW
const ossimIpt & ul() const
static const ossimErrorCode OSSIM_ERROR
ossim_uint8 * m_TileBuffer
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level=0) const
Returns the number of samples in the image.
bool intersects(const ossimIrect &rect) const
static const char * TYPE_KW
virtual void initialize()
Initialize the data buffer.
void ref() const
increment the reference count by one, indicating that this object has another pointer which is refere...
virtual ossim_uint32 getNumberOfDecimationLevels() const
This returns the total number of decimation levels.
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
virtual ossim_uint32 getImageTileHeight() const
static const char * PIXEL_SCALE_XY_KW
virtual bool getOverviewTile(ossim_uint32 resLevel, ossimImageData *result)
Method to get an overview tile.
virtual ossim_uint32 getTileHeight() const
Returns the height of the output tile.
ossimProjection * createProjection(const ossimFilename &filename, ossim_uint32 entryIdx) const
Gets a property for matching name.
static const char * TIE_POINT_XY_KW
bool fillBuffer(const ossimIrect &tile_rect, const ossimIrect &clip_rect, ossimImageData *tile)
unsigned int ossim_uint32
static const char * NUMBER_OUTPUT_BANDS_KW
void adjustToStartOfTile(ossimIpt &pt) const
Adjust point to even 128 boundary.
virtual ossimIrect getImageRectangle() const
const ossimIpt & lr() const
ossimErrorCode theErrorStatus
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
void unref() const
decrement the reference count by one, indicating that a pointer to this object is referencing it...
static ossimProjectionFactoryRegistry * instance()
static const char * ORIGIN_LATITUDE_KW
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
virtual ossimString getLongName() const
virtual ossim_uint32 getNumberOfInputBands() const
Returns the number of bands in the image.
virtual void makeBlank()
virtual void completeOpen()
Will complete the opening process.
virtual void close()
ossimRefPtr< ossimImageHandler > theOverview
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual bool isOpen() const
const char * c_str() const
Returns a pointer to a null-terminated array of characters representing the string's contents...
virtual ~ossimAdrgTileSource()
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
Gets a list of property names available.
static const char * TIE_POINT_LAT_KW
#define RTTI_DEF1(cls, name, b1)
static const char * NUMBER_REDUCED_RES_SETS_KW
virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level=0) const
Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in...
ossimAdrgHeader * m_AdrgHeader
static ossimUnitTypeLut * instance()
Returns the static instance of an ossimUnitTypeLut object.
virtual ossim_uint32 getTileWidth() const
Returns the width of the output tile.
static const char * NUMBER_SAMPLES_KW
unsigned char ossim_uint8
static const char * PIXEL_SCALE_UNITS_KW
static const char * TIE_POINT_UNITS_KW
virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level=0) const
Returns the number of lines in the image.
