23 "ossimSrtmTileSource",
26 static ossimTrace traceDebug(
"ossimSrtmTileSource:debug");
41 static const char MODULE[] =
"ossimSrtmTileSource::open";
44 CLOG <<
" Entered..." << std::endl
75 if (traceDebug())
CLOG <<
" Unable to set filename"<< std::endl;
82 CLOG <<
" Exited with " << (result?
"true":
"false") <<
" ..." 109 const char* prefix)
const 123 std::string pfx =
130 std::string value = kwl.
findKey( pfx, key );
131 if ( value ==
"ossimSrtmTileSource" )
134 value = kwl.
155 if(name ==
"file_type")
164 std::vector<ossimString>& propertyNames)
const 167 propertyNames.push_back(
"file_type");
Method to save the state of the object to a keyword list.
ossimRefPtr< ossimImageGeometry > theGeometry
virtual bool open()
Pure virtual open.
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
ossimFilename theImageFile
ossimSrtmSupportData m_SrtmSupportData
const std::string & findKey(const std::string &key) const
Find methods that take std::string(s).
virtual ossimString getShortName() const
virtual bool isOpen() const
ossimRefPtr< ossimProjection > getProjection() const
Gets the projection for srtm cell.
static const char * TYPE_KW
virtual ossimString getLongName() const
virtual ~ossimSrtmTileSource()
Gets a property.
Adds property names to array.
virtual bool open()
Pure virtual open.
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
virtual void close()
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
ossimImageMetaData theMetaData
const ossimImageMetaData & getImageMetaData() const
#define RTTI_DEF1(cls, name, b1)
static const char * FILENAME_KW
bool setFilename(const ossimFilename &srtmFile, bool scanForMinMax=false)
Initializes object from file.
