Classes | Public Types | Public Member Functions | Static Public Attributes | Protected Member Functions | Protected Attributes | Friends | List of all members
ossimCibCadrgTileSource Class Reference
CIB/CADRG formats are encoded the same except that the CIB is a grey scale image and the CADRG is a color image. More...
#include <ossimCibCadrgTileSource.h>
Inheritance diagram for ossimCibCadrgTileSource:
ossimImageHandler ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Classes
struct  ossimFrameEntryData
 Protected structure that is only used internally by this class. More...
Public Types
enum  ossimCibCadrgProductType { OSSIM_PRODUCT_TYPE_UNKNOWN = 0, OSSIM_PRODUCT_TYPE_CIB = 1, OSSIM_PRODUCT_TYPE_CADRG = 2 }
 Basic enumeration. More...
 ossimCibCadrgTileSource ()
 Default constructor. More...
 This method is defined in the base class ossimObject. More...
virtual void close ()
 Closes this image handler and deletes any allocated data. More...
virtual bool open ()
 Pure virtual open. More...
void setSkipEmptyCheck (bool bSkipEmptyCheck=false)
 Changes the way the open() routine functions slightly. More...
 Returns a pointer to an ossimImageDataObject given a rectangluar region of interest. More...
 Method to get a tile. More...
virtual ossim_uint32 getNumberOfLines (ossim_uint32 reduced_res_level=0) const
 Satisfies pure virtual requirement from ImageHandler class. More...
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 reduced_res_level=0) const
virtual ossimIrect getImageRectangle (ossim_uint32 reduced_res_level=0) const
 Method to load the state of an object from a keyword list. More...
Populates the geometry object with image geometry information. More...
 This method allows you to query the scalar type of the output data. More...
 This method allows you to query the number of input bands. More...
 This method allows one to query the number of output bands. More...
 Returns the width of the output tile. More...
 Returns the height of the output tile. More...
virtual ossim_int32 getCurrentEntryIndex () const
 Returns -1 if invalid. More...
virtual const ossimRpfTocEntrygetCurrentTocEntry () const
virtual const ossimRpfTocgetToc () const
bool isValidRLevel (ossim_uint32 reduced_res_level) const
bool isOpen () const
 Determines if its open if there eists a table of contents object. More...
bool isCib () const
bool isCadrg () const
ossimString getProductScale () const
vector< ossimStringgetProductScaleList () const
 This retrieves all product scales that are within the Table of contents. More...
vector< ossim_int32getProductEntryList (const ossimString &productScale) const
 Using the product scales from getProductScaleList() you can pass each string in so you can get all associated indices for a given product. More...
ossimString getSecurityClassification () const
 Gets a property for matching name. More...
 Gets a list of property names available. More...
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual void initialize ()
virtual bool openOverview ()
virtual void closeOverview ()
 Opens the image file. More...
 Sets the filename. More...
 Returns the filename. More...
 Connection rule. More...
virtual bool hasLut () const
virtual void loadMetaData ()
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
static const ossim_uint32 CIBCADRG_FRAME_WIDTH = 1536
 CONSTANT representing the width of a Frame. More...
static const ossim_uint32 CIBCADRG_FRAME_HEIGHT = 1536
 CONSTANT representing the height of a Frame. More...
virtual ~ossimCibCadrgTileSource ()
 Destructor. More...
void updatePropertiesToFirstValidFrame ()
virtual void setTocEntryToRender (const ossimRpfTocEntry *entry)
 Sets the entry to be renderer. More...
virtual bool setEntryToRender (ossim_uint32 index)
 Sets the entry to render. More...
vector< ossimFrameEntryDatagetIntersectingEntries (const ossimIrect &rect)
 It is important to note that each frame is organized into an easting northing type orientation. More...
void fillTile (const ossimIrect &tileRect, const vector< ossimFrameEntryData > &framesInvolved, ossimImageData *tile)
 This is a wrapper for the fill cib and fill cadrg. More...
void fillSubTileCib (const ossimRpfFrame &aFrame, const ossimIrect &tileRect, const ossimFrameEntryData &frameEntryData, ossimImageData *tile)
 Will uncompress the CIB file using a VQ decompression algorithm. More...
void fillSubTileCadrg (const ossimRpfFrame &aFrame, const ossimIrect &tileRect, const ossimFrameEntryData &frameEntryData, ossimImageData *tile)
 Will uncompress the CADRG file using a VQ decompression algorithm. More...
void allocateForProduct ()
 Will allocate an internal buffer for the given product. More...
const ossimRpfTocEntryfindFirstFrame ()
 This will search each entry in the table and look for a certain entry. More...
void deleteAll ()
void populateLut ()
virtual void completeOpen ()
virtual ~ossimReferenced ()
unsigned char * theCompressedBuffer
 This is for storage of a single compressed buffer. More...
unsigned char * theUncompressedBuffer
 This is used as a buffer to uncompress the data to. More...
ossim_uint32 theNumberOfLines
 This will be computed based on the frames organized within the directory. More...
ossim_uint32 theNumberOfSamples
 This is the actual data returned from a getTile request. More...
ossimRpfToctheTableOfContents
 Will own a table of contents. More...
const ossimRpfTocEntrytheEntryToRender
 This is the actual frame file to render. More...
ossim_int32 theEntryNumberToRender
 This will be the entry number that we are currently rendering. More...
ossimCibCadrgProductType theProductType
 Holds the enumeration specifying the product type. More...
ossimRpfFrametheWorkFrame
bool theSkipEmptyCheck
 If true during the call to open(), the RPF file is opened even if all the frame files are missing. More...
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Friends
class ossimMultiEntryCibCadrg
Detailed Description
Both are VQ compressed. The images are encoded into an NITF format with embedded RPF headers. It reads the embedded RPF tags from the NITF file and parses the data. It allows for you to select which CIB/CADRG entry to render. The handler is opened by giving it the associated a.toc file. This is a table of contents file that describes all the entries found in the CIB/CADRG product. You must set which entry you wish to render. By default it will render the first product it comes to.
Note: This handler will eventually merge into the nitf handler.
Definition at line 35 of file ossimCibCadrgTileSource.h.
◆ ossimCibCadrgProductType
Basic enumeration.
This should be either a CIB or a CADRG product type.
Enumerator
Definition at line 45 of file ossimCibCadrgTileSource.h.
◆ ossimCibCadrgTileSource()
ossimCibCadrgTileSource::ossimCibCadrgTileSource ( )
Initializes all internal attributes to a default state.
Definition at line 51 of file ossimCibCadrgTileSource.cpp.
57  theTile(0),
62  theWorkFrame(0),
63  theSkipEmptyCheck(false)
64 {
65  if (traceDebug())
66  {
68  << "ossimCibCadrgTileSource::ossimCibCadrgTileSource entered...\n";
69 #ifdef OSSIM_ID_ENABLED
71  << "OSSIM_ID: " << OSSIM_ID << "\n";
72 #endif
73  }
74
75  // Moved memory allocation to happen in first get tile. drb
76
77  // theWorkFrame = new ossimRpfFrame;
78
79  // a CADRG and CIBis a 64*64*12 bit buffer and must divide by 8 to
80  // convert to bytes
81  // theCompressedBuffer = new ossim_uint8[(64*64*12)/8];
82
83  // whether CIB or CADRG we will alocate the buffer
84  // to the larger of the 2 (CADRG is 3 bands)
85  // theUncompressedBuffer = new ossim_uint8[256*256*3];
86
87 }
ossimRpfToc * theTableOfContents
If true during the call to open(), the RPF file is opened even if all the frame files are missing...
const ossimRpfTocEntry * theEntryToRender
ossimImageHandler()
Constructor (default):
◆ ~ossimCibCadrgTileSource()
ossimCibCadrgTileSource::~ossimCibCadrgTileSource ( )
protectedvirtual
Destructor.
Will return allocated memory back to the heap.
Definition at line 89 of file ossimCibCadrgTileSource.cpp.
References close(), theCompressedBuffer, theUncompressedBuffer, and theWorkFrame.
90 {
92  {
93  delete [] theCompressedBuffer;
95  }
97  {
98  delete [] theUncompressedBuffer;
100  }
101  if(theWorkFrame)
102  {
103  delete theWorkFrame;
104  theWorkFrame = 0;
105  }
106  close();
107 }
virtual void close()
Member Function Documentation
◆ allocateForProduct()
void ossimCibCadrgTileSource::allocateForProduct ( )
protected
If the product is a CIB then it is a single band OSSIM_UCHAR buffer and if its a CADRG it is a 3 band OSSIM_UCHAR buffer.
Definition at line 1036 of file ossimCibCadrgTileSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), OSSIM_PRODUCT_TYPE_CIB, OSSIM_PRODUCT_TYPE_UNKNOWN, theCompressedBuffer, theProductType, theTile, theUncompressedBuffer, and theWorkFrame.
Referenced by getTile().
1037 {
1039  {
1040  return;
1041  }
1042
1043  if ( theWorkFrame )
1044  {
1045  delete theWorkFrame;
1046  }
1048
1050  {
1051  delete [] theCompressedBuffer;
1052  }
1053
1054  //---
1055  // A CADRG and CIBis a 64*64*12 bit buffer and must divide by 8 to convert
1056  // to bytes.
1057  //---
1058  theCompressedBuffer = new ossim_uint8[(64*64*12)/8];
1059
1061  {
1062  delete [] theUncompressedBuffer;
1063  }
1065  {
1066  theUncompressedBuffer = new ossim_uint8[256*256];
1067  }
1068  else
1069  {
1070  theUncompressedBuffer = new ossim_uint8[256*256*3];
1071  }
1072
1074  theTile->initialize();
1075 }
virtual void initialize()
Initialize the data buffer.
unsigned char ossim_uint8
◆ close()
void ossimCibCadrgTileSource::close ( )
virtual
Definition at line 120 of file ossimCibCadrgTileSource.cpp.
References ossimImageHandler::close(), and deleteAll().
Referenced by ~ossimCibCadrgTileSource().
121 {
122  deleteAll();
124 }
◆ deleteAll()
void ossimCibCadrgTileSource::deleteAll ( )
protected
Definition at line 1098 of file ossimCibCadrgTileSource.cpp.
References ossimImageHandler::theOverview, and theTableOfContents.
Referenced by close().
1099 {
1100  theOverview = 0;
1101  if(theTableOfContents)
1102  {
1103  delete theTableOfContents;
1104  theTableOfContents = 0;
1105  }
1106 }
ossimRefPtr< ossimImageHandler > theOverview
◆ fillSubTileCadrg()
void ossimCibCadrgTileSource::fillSubTileCadrg ( const ossimRpfFrame aFrame,
const ossimIrect tileRect,
const ossimFrameEntryData frameEntryData,
ossimImageData tile
protected
Parameters
aFrameFrame that overlaps the requested tile rect.
tileRectThe region requested to render.
frameEntryDataThe frame entry data.
Definition at line 757 of file ossimCibCadrgTileSource.cpp.
References CIBCADRG_FRAME_HEIGHT, CIBCADRG_FRAME_WIDTH, ossimIrect::clipToRect(), ossimRpfFrame::fillSubFrameBuffer(), ossimRpfFrame::getColorGrayscaleTable(), ossimRpfFrame::getCompressionSection(), ossimRpfCompressionSection::getTable(), ossimIrect::height(), ossimImageData::loadTile(), OSSIM_BSQ, theCompressedBuffer, ossimCibCadrgTileSource::ossimFrameEntryData::thePixelCol, ossimCibCadrgTileSource::ossimFrameEntryData::thePixelRow, theUncompressedBuffer, ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Referenced by fillTile().
762 {
763  // first let's grab the absolute position of the frame rectangle in pixel space
764  ossimIrect frameRect(frameEntryData.thePixelCol,
765  frameEntryData.thePixelRow,
766  frameEntryData.thePixelCol + CIBCADRG_FRAME_WIDTH - 1,
767  frameEntryData.thePixelRow + CIBCADRG_FRAME_HEIGHT - 1);
768
769
770  // now clip it to the tile
771  ossimIrect clipRect = tileRect.clipToRect(frameRect);
772
773  const ossimRpfCompressionSection* compressionSection = aFrame.getCompressionSection();
774
775  if(!compressionSection)
776  {
777  return;
778  }
779
780  const vector<ossimRpfColorGrayscaleTable>& colorTable =
781  aFrame.getColorGrayscaleTable();
782
783  // ESH 03/2009 -- Partial fix for ticket #646.
784  // Crash fix on reading RPFs: Make sure the colorTable vector
785  // has entries before trying to make use of them.
786  int numTables = (int)colorTable.size();
787  if ( numTables <= 0 )
788  {
789  return;
790  }
791
792  ossim_uint8 *tempRows[3];
793
794  tempRows[0] = theUncompressedBuffer;
795  tempRows[1] = (theUncompressedBuffer + 256*256);
796  tempRows[2] = (tempRows[1] + 256*256);
797
798  // find the shift to 0,0
799  ossimIpt tempDelta(clipRect.ul().x - frameEntryData.thePixelCol,
800  clipRect.ul().y - frameEntryData.thePixelRow);
801
802
803  // In order to compute the subframe we will need the corner offsets of
804  // the upper left of the frame and the upper left of the clip rect. The
805  // clip rect should be completely within the frame. This just translates the value
806  // to make the upper left of the frame be 0,0.
807  //
808  ossimIrect offsetRect(tempDelta.x,
809  tempDelta.y,
810  tempDelta.x + clipRect.width()-1,
811  tempDelta.y + clipRect.height()-1);
812
813  // each subframe is 64x64. We will actually use 256x256 since
814  // we will be uncompressing them. Note CADRG is a 256x256 tile
815  // compressed to 64x64x12 bit data
816  //
817  ossimIrect subFrameRect(offsetRect.ul().x/256,
818  offsetRect.ul().y/256,
819  (offsetRect.lr().x)/256,
820  (offsetRect.lr().y)/256);
821
822  ossim_uint32 readPtr = 0;
823
824  ossim_int32 row = 0;
825  ossim_int32 col = 0;
826  ossim_uint32 i = 0;
827  ossim_uint32 j = 0;
828  ossim_int32 upperY = subFrameRect.lr().y;
829  ossim_int32 upperX = subFrameRect.lr().x;
830  ossim_int32 lowerY = subFrameRect.ul().y;
831  ossim_int32 lowerX = subFrameRect.ul().x;
832  for(row = lowerY; row <= upperY; ++row)
833  {
834  for(col = lowerX; col <= upperX; ++col)
835  {
836  readPtr = 0;
837  if(aFrame.fillSubFrameBuffer(theCompressedBuffer, 0, row, col))
838  {
839  for (i = 0; i < 256; i += 4)
840  {
841  for (j = 0; j < 256; j += 8)
842  {
843  ossim_uint16 firstByte = theCompressedBuffer[readPtr++] & 0xff;
844  ossim_uint16 secondByte = theCompressedBuffer[readPtr++] & 0xff;
845  ossim_uint16 thirdByte = theCompressedBuffer[readPtr++] & 0xff;
846
847  //because dealing with half-bytes is hard, we
848  //uncompress two 4x4 tiles at the same time. (a
849  //4x4 tile compressed is 12 bits )
850  // this little code was grabbed from openmap software.
851
852  /* Get first 12-bit value as index into VQ table */
853  // I think we need to swap
854  ossim_uint16 val1 = (firstByte << 4) | (secondByte >> 4);
855
856  /* Get second 12-bit value as index into VQ table*/
857  ossim_uint16 val2 = ((secondByte & 0x000F) << 8) | thirdByte;
858
859  for (ossim_uint32 t = 0; t < 4; ++t)
860  {
861  for (ossim_uint32 e = 0; e < 4; ++e)
862  {
863  ossim_uint16 tableVal1 = compressionSection->getTable()[t].theData[val1*4 + e] & 0xff;
864  ossim_uint16 tableVal2 = compressionSection->getTable()[t].theData[val2*4 + e] & 0xff;
865
866  ossim_uint32 pixindex = ((i+t)*256) +
867  (j + e);
868  const ossim_uint8* color1 = colorTable[0].getStartOfData(tableVal1);
869  const ossim_uint8* color2 = colorTable[0].getStartOfData(tableVal2);
870
871
872  tempRows[0][pixindex] = color1[0];
873  tempRows[1][pixindex] = color1[1];
874  tempRows[2][pixindex] = color1[2];
875
876  tempRows[0][pixindex+4] = color2[0];
877  tempRows[1][pixindex+4] = color2[1];
878  tempRows[2][pixindex+4] = color2[2];
879  } //for e
880  } //for t
881  } /* for j */
882  } //for i
883  }
884  else
885  {
886  memset(theUncompressedBuffer, 0, 256*256*3);
887  }
888  ossim_int32 tempCol = col*256;
889  ossim_int32 tempRow = row*256;
890  ossimIrect subRectToFill(frameRect.ul().x + tempCol,
891  frameRect.ul().y + tempRow,
892  frameRect.ul().x + tempCol + 255,
893  frameRect.ul().y + tempRow + 255);
895  subRectToFill,
896  OSSIM_BSQ);
897  }
898  }
899 }
const std::vector< ossimRpfCompressionOffsetTableData > & getTable() const
ossim_uint32 height() const
Definition: ossimIrect.h:487
const ossimIpt & ul() const
Definition: ossimIrect.h:274
unsigned short ossim_uint16
const vector< ossimRpfColorGrayscaleTable > & getColorGrayscaleTable() const
Definition: ossimRpfFrame.h:80
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
bool fillSubFrameBuffer(ossim_uint8 *buffer, ossim_uint32 spectralGroup, ossim_uint32 row, ossim_uint32 col) const
unsigned int ossim_uint32
ossim_uint32 width() const
Definition: ossimIrect.h:500
ossim_int32 y
Definition: ossimIpt.h:142
ossim_int32 x
Definition: ossimIpt.h:141
const ossimRpfCompressionSection * getCompressionSection() const
Definition: ossimRpfFrame.h:76
int ossim_int32
◆ fillSubTileCib()
void ossimCibCadrgTileSource::fillSubTileCib ( const ossimRpfFrame aFrame,
ossimImageData tile
protected
Parameters
Definition at line 901 of file ossimCibCadrgTileSource.cpp.
906 {
907  // first let's grab the absolute position of the frame rectangle in pixel
908  // space
909  ossimIrect frameRect(frameEntryData.thePixelCol,
910  frameEntryData.thePixelRow,
911  frameEntryData.thePixelCol + CIBCADRG_FRAME_WIDTH - 1,
912  frameEntryData.thePixelRow + CIBCADRG_FRAME_HEIGHT - 1);
913
914
915  // now clip it to the tile
916  ossimIrect clipRect = tileRect.clipToRect(frameRect);
917
918  const ossimRpfCompressionSection* compressionSection = aFrame.getCompressionSection();
919
920  if(!compressionSection)
921  {
922  return;
923  }
924
925  const vector<ossimRpfColorGrayscaleTable>& colorTable =
926  aFrame.getColorGrayscaleTable();
927
928  // ESH 03/2009 -- Partial fix for ticket #646.
929  // Crash fix on reading RPFs: Make sure the colorTable vector
930  // has entries before trying to make use of them.
931  int numTables = (int)colorTable.size();
932  if ( numTables <= 0 )
933  {
934  return;
935  }
936
937  // check to see if it does overlap. If it doesn't then the width and height
938  // will be a single point
939  {
940  ossim_uint8 *tempRow;
941
942  tempRow = theUncompressedBuffer;
943
944  // find the shift to 0,0
945  ossimIpt tempDelta(clipRect.ul().x - frameEntryData.thePixelCol,
946  clipRect.ul().y - frameEntryData.thePixelRow);
947
948  // In order to compute the subframe we will need the corner offsets of
949  // the upper left of the frame and the upper left of the clip rect. The
950  // clip rect should be completely within the frame. This just translates the value
951  // to make the upper left of the frame be 0,0.
952  //
953  ossimIrect offsetRect(tempDelta.x,
954  tempDelta.y,
955  tempDelta.x + clipRect.width()-1,
956  tempDelta.y + clipRect.height()-1);
957
958  // each subframe is 64x64. We will actually use 256x256 since
959  // we will be uncompressing them. Note CADRG is a 256x256 tile
960  // compressed to 64x64x12 bit data
961  //
962  ossimIrect subFrameRect(offsetRect.ul().x/256,
963  offsetRect.ul().y/256,
964  (offsetRect.lr().x)/256,
965  (offsetRect.lr().y)/256);
966
967  ossim_int32 row = 0;
968  ossim_int32 col = 0;
969  ossim_uint32 i = 0;
970  ossim_uint32 j = 0;
971  ossim_uint32 readPtr = 0;
972  for(row = subFrameRect.ul().y; row <= subFrameRect.lr().y; ++row)
973  {
974  for(col = subFrameRect.ul().x; col <= subFrameRect.lr().x; ++col)
975  {
976  readPtr = 0;
977  if(aFrame.fillSubFrameBuffer(theCompressedBuffer, 0, row, col))
978  {
979  for (i = 0; i < 256; i += 4)
980  {
981  for (j = 0; j < 256; j += 8)
982  {
983  ossim_uint16 firstByte = theCompressedBuffer[readPtr++] & 0xff;
984  ossim_uint16 secondByte = theCompressedBuffer[readPtr++] & 0xff;
985  ossim_uint16 thirdByte = theCompressedBuffer[readPtr++] & 0xff;
986
987  //because dealing with half-bytes is hard, we
988  //uncompress two 4x4 tiles at the same time. (a
989  //4x4 tile compressed is 12 bits )
990  // this little code was grabbed from openmap software.
991
992  /* Get first 12-bit value as index into VQ table */
993  // I think we need to swap
994  ossim_uint16 val1 = (firstByte << 4) | (secondByte >> 4);
995
996  /* Get second 12-bit value as index into VQ table*/
997  ossim_uint16 val2 = ((secondByte & 0x000F) << 8) | thirdByte;
998
999  for (ossim_uint32 t = 0; t < 4; ++t)
1000  {
1001  for (ossim_uint32 e = 0; e < 4; ++e)
1002  {
1003  ossim_uint16 tableVal1 = compressionSection->getTable()[t].theData[val1*4 + e] & 0xff;
1004  ossim_uint16 tableVal2 = compressionSection->getTable()[t].theData[val2*4 + e] & 0xff;
1005
1006  ossim_uint32 pixindex = ((i+t)*256) + (j + e);
1007  const ossim_uint8* color1 = colorTable[0].getStartOfData(tableVal1);
1008  const ossim_uint8* color2 = colorTable[0].getStartOfData(tableVal2);
1009
1010
1011  tempRow[pixindex] = color1[0];
1012  tempRow[pixindex + 4] = color2[0];
1013  } //for e
1014  } //for t
1015  } /* for j */
1016  } //for i
1017  }
1018  else
1019  {
1020  memset(theUncompressedBuffer, 0, 256*256);
1021  }
1022  ossim_int32 tCol = col*256;
1023  ossim_int32 tRow = row*256;
1024  ossimIrect subRectToFill(frameRect.ul().x + tCol,
1025  frameRect.ul().y + tRow,
1026  frameRect.ul().x + tCol + 255,
1027  frameRect.ul().y + tRow + 255);
1029  subRectToFill,
1030  OSSIM_BSQ);
1031  }
1032  }
1033  }
1034 }
ossim_int32 y
ossim_int32 x
int ossim_int32
◆ fillTile()
void ossimCibCadrgTileSource::fillTile ( const ossimIrect tileRect,
const vector< ossimFrameEntryData > &  framesInvolved,
ossimImageData tile
protected
It takes the frames involved that were found in the getIntersectingEntries and call the appropriate fill cib or fill cadrg on each frame entry data. It will loop through making sure that the frame file exists before calling the associated fill routines.
Parameters
tileRectRegion to fill.
framesInvolvedAll intersecting frames used to render the region.
Definition at line 723 of file ossimCibCadrgTileSource.cpp.
References fillSubTileCadrg(), fillSubTileCib(), ossimErrorCodes::OSSIM_OK, OSSIM_PRODUCT_TYPE_CIB, ossimRpfFrame::parseFile(), theProductType, and theWorkFrame.
727 {
728  ossim_uint32 idx = 0;
729  for(idx = 0;
730  idx < framesInvolved.size();
731  ++idx)
732  {
733
734  if(theWorkFrame->parseFile(framesInvolved[idx].theFrameEntry.getFullPath())
736  {
737  // we will fill a subtile. We pass in which frame it is and the position of the frame.
738  // the actual pixel will be 1536*row and 1536 *col.
740  {
742  tileRect,
743  framesInvolved[idx],
744  tile);
745  }
746  else
747  {
749  tileRect,
750  framesInvolved[idx],
751  tile);
752  }
753  }
754  }
755 }
static const ossimErrorCode OSSIM_OK
void fillSubTileCib(const ossimRpfFrame &aFrame, const ossimIrect &tileRect, const ossimFrameEntryData &frameEntryData, ossimImageData *tile)
ossimErrorCode parseFile(const ossimFilename &filename, bool minimalParse=false)
void fillSubTileCadrg(const ossimRpfFrame &aFrame, const ossimIrect &tileRect, const ossimFrameEntryData &frameEntryData, ossimImageData *tile)
◆ findFirstFrame()
const ossimRpfTocEntry * ossimCibCadrgTileSource::findFirstFrame ( )
protected
The first entry it comes to that has Geographic coverage will be the frame to render. This method is best here instead of in the ossimRpfToc. I am not sure, but I feel these types of searches are specific to the product (CADRG, CIB ...). This is called immediately after a succesful open of the ossimRpfToc
Definition at line 1077 of file ossimCibCadrgTileSource.cpp.
References getProductEntryList(), getProductScaleList(), ossimRpfToc::getTocEntry(), theEntryNumberToRender, and theTableOfContents.
1078 {
1079  vector<ossimString> products = getProductScaleList();
1080  vector<ossim_int32> indexProducts;
1081
1082  if(products.size() > 0)
1083  {
1084  indexProducts = getProductEntryList(products[0]);
1085
1086  if(indexProducts.size()>0)
1087  {
1088  theEntryNumberToRender = indexProducts[0];
1089
1090  return theTableOfContents->getTocEntry(indexProducts[0]);
1091  }
1092  }
1093
1094  return 0;
1095 }
vector< ossimString > getProductScaleList() const
const ossimRpfTocEntry * getTocEntry(ossim_uint32 index) const
vector< ossim_int32 > getProductEntryList(const ossimString &productScale) const
Using the product scales from getProductScaleList() you can pass each string in so you can get all as...
◆ getCurrentEntry()
ossim_uint32 ossimCibCadrgTileSource::getCurrentEntry ( ) const
virtual
Returns
The current entry number.
Note
This implementation returns 0. Derived classes should override if of multiple entry image type.
Definition at line 447 of file ossimCibCadrgTileSource.cpp.
References theEntryNumberToRender.
448 {
450 }
◆ getCurrentEntryIndex()
ossim_int32 ossimCibCadrgTileSource::getCurrentEntryIndex ( ) const
virtual
Definition at line 539 of file ossimCibCadrgTileSource.cpp.
540 {
541  return theEntryNumberToRender;
542 }
◆ getCurrentTocEntry()
const ossimRpfTocEntry * ossimCibCadrgTileSource::getCurrentTocEntry ( ) const
virtual
Returns
The current entry being rendered
Definition at line 544 of file ossimCibCadrgTileSource.cpp.
References theEntryToRender.
545 {
546  return theEntryToRender;
547 }
◆ getEntryList()
void ossimCibCadrgTileSource::getEntryList ( std::vector< ossim_uint32 > &  entryList) const
virtual
Parameters
entryListThis is the list to initialize with entry indexes.
Note
This implementation returns puts one entry "0" in the list.
Definition at line 473 of file ossimCibCadrgTileSource.cpp.
References getProductEntryList(), and getProductScaleList().
474 {
475  std::vector<ossimString> scaleList = getProductScaleList();
476  ossim_uint32 scaleIdx = 0;
477  ossim_uint32 entryIdx = 0;
478  for(scaleIdx = 0; scaleIdx < scaleList.size(); ++scaleIdx)
479  {
480  std::vector<ossim_int32> eList = getProductEntryList(scaleList[scaleIdx]);
481
482  for(entryIdx = 0; entryIdx < eList.size(); ++entryIdx)
483  {
484  entryList.push_back(eList[entryIdx]);
485  }
486  }
487
488 }
◆ getImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimCibCadrgTileSource::getImageGeometry ( )
virtual
This method is used to relay projection/model information to users. Returns true if geometry info is present, false if not. Keywords supported by this class are:
*  datum:    // datum code>   // Datum code
*  ul_lat:   // upper left latitude
*  ul_lon:   // upper left longitude
*  ll_lat:   // lower left latitude
*  ll_lon:   // lower left longitude
*  lr_lat:   // lower right latitude
*  lr_lon:   // lower right longitude
*  ur_lat:   // upper right latitude
*  ur_lon:   // upper right longitude
*  number_input_bands:
*  number_output_bands:
*  number_lines:
*  number_samples:
*  decimal_degrees_per_pixel_lat:  // specifies the spacing per pixel along Y direction
*  decimal_degrees_per_pixel_lon:  // specifies the spacing per pixel along X direction
*  origin_latitude:                // specifies the origin or center of the projector for the latitude
*  central_meridian:               // specifies the origin or center of the projector for the longitude
*  tie_point_lat:     // tie point lat.  Represents the latitude of the upper left center of pixel
*  tie_point_lon:     // tie point lon.  Represents the longitude of the upper left center of pixel
*  zone:              // zone read from the CIB/CADRG boundary info
*  type:              // class name of the object for factory driven reconstruction
*  map_scale:         // Map scale of the image
See also
ossimImageSource for further code example on using the geometry.
Definition at line 413 of file ossimCibCadrgTileSource.cpp.
References ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), ossimRpfTocEntry::getImageGeometry(), ossimImageHandler::initImageParameters(), theEntryToRender, and ossimImageHandler::theGeometry.
414 {
415  if ( !theGeometry )
416  {
417  // Check for external geom:
419
420  if ( !theGeometry && theEntryToRender )
421  {
423  }
424
425  // Set image things the geometry object should know about.
427  }
428
429  return theGeometry;
430 }
ossimRefPtr< ossimImageGeometry > theGeometry
ossimRefPtr< ossimImageGeometry > getImageGeometry() const
Returns the image geometry object associated with this tile source or NULL if non defined...
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
◆ getImageRectangle()
ossimIrect ossimCibCadrgTileSource::getImageRectangle ( ossim_uint32  reduced_res_level = 0) const
virtual
Parameters
reduced_res_levelWhich res level to get the bounds for. 0 represents the default and is the full resolution.
Returns
A rectangle representing the bounds for the passed in resolution level.
Definition at line 405 of file ossimCibCadrgTileSource.cpp.
References getNumberOfLines(), and getNumberOfSamples().
Referenced by getIntersectingEntries(), and getTile().
406 {
407  return ossimIrect(0, // upper left x
408  0, // upper left y
409  getNumberOfSamples(reduced_res_level) - 1, // lower right x
410  getNumberOfLines(reduced_res_level) - 1); // lower right y
411 }
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level=0) const
virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level=0) const
◆ getImageTileHeight()
ossim_uint32 ossimCibCadrgTileSource::getImageTileHeight ( ) const
virtual
Implements ossimImageHandler.
Definition at line 1167 of file ossimCibCadrgTileSource.cpp.
Referenced by getTileHeight().
1168 {
1169  return 256; // ??? drb
1170 }
◆ getImageTileWidth()
ossim_uint32 ossimCibCadrgTileSource::getImageTileWidth ( ) const
virtual
Definition at line 1162 of file ossimCibCadrgTileSource.cpp.
Referenced by getTileWidth().
1163 {
1164  return 256; // ??? drb
1165 }
◆ getIntersectingEntries()
vector< ossimCibCadrgTileSource::ossimFrameEntryData > ossimCibCadrgTileSource::getIntersectingEntries ( const ossimIrect rect)
protected
This means that a frame at 0,0 is at the lower left corner. Each frame's pixel data is has 0,0 at the upper left.
It will take the curent region to render and then find all entries that intersect that region.
Parameters
rectthe current region to render.
Returns
The list of entry data objects found for this rect.
Definition at line 680 of file ossimCibCadrgTileSource.cpp.
References CIBCADRG_FRAME_HEIGHT, CIBCADRG_FRAME_WIDTH, ossimIrect::clipToRect(), ossimRpfTocEntry::getEntry(), getImageRectangle(), ossimRpfTocEntry::getNumberOfFramesVertical(), ossimIrect::intersects(), isOpen(), ossimIrect::lr(), theEntryToRender, ossimIrect::ul(), ossimIpt::x, and ossimIpt::y.
681 {
682  vector<ossimFrameEntryData> result;
683
684  // make sure we have the Toc entry to render
685  if(!isOpen()) return result;
686
687  ossimIrect imageRect = getImageRectangle();
688  if(rect.intersects(imageRect))
689  {
690  ossimIrect clipRect = rect.clipToRect(imageRect);
691  ossimIrect frameRect(clipRect.ul().x/CIBCADRG_FRAME_WIDTH,
692  clipRect.ul().y/CIBCADRG_FRAME_HEIGHT,
693  clipRect.lr().x/CIBCADRG_FRAME_WIDTH,
694  clipRect.lr().y/CIBCADRG_FRAME_HEIGHT);
695
696  ossimRpfFrameEntry tempEntry;
697
698
699  for(ossim_int32 row = frameRect.ul().y; row <= frameRect.lr().y; ++row)
700  {
701  for(ossim_int32 col = frameRect.ul().x; col <= frameRect.lr().x; ++col)
702  {
704  col,
705  tempEntry))
706  {
707  if(tempEntry.exists())
708  {
709  result.push_back(ossimFrameEntryData(row,
710  col,
713  tempEntry));
714  }
715  }
716  }
717  }
718  }
719
720  return result;
721 }
ossim_uint32 getNumberOfFramesVertical() const
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
bool isOpen() const
virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level=0) const
const ossimIpt & lr() const
Definition: ossimIrect.h:276
ossim_int32 y
ossim_int32 x
bool getEntry(long row, long col, ossimRpfFrameEntry &result) const
int ossim_int32
◆ getLongName()
ossimString ossimCibCadrgTileSource::getLongName ( ) const
virtual
This class overrides the default implementation to return its own long name.
Returns
The long name for this class as an ossimString.
Definition at line 114 of file ossimCibCadrgTileSource.cpp.
115 {
116  return ossimString("CIB/CADRG reader");
117 }
◆ getNumberOfInputBands()
ossim_uint32 ossimCibCadrgTileSource::getNumberOfInputBands ( ) const
virtual
If an image is band selectable this will allow one to select the bands you wish to read in. This indicates that the number of input bands might not match the number of output bands.
Returns
Implements ossimImageSource.
Definition at line 335 of file ossimCibCadrgTileSource.cpp.
References OSSIM_PRODUCT_TYPE_CADRG, OSSIM_PRODUCT_TYPE_CIB, OSSIM_PRODUCT_TYPE_UNKNOWN, and theProductType.
336 {
337  switch(theProductType)
338  {
340  {
341  return 0;
342  }
344  {
345  return 1;
346  }
348  {
349  return 3;
350  }
351  }
352
353  return 0;
354 }
◆ getNumberOfLines()
ossim_uint32 ossimCibCadrgTileSource::getNumberOfLines ( ossim_uint32  reduced_res_level = 0) const
virtual
Parameters
reduced_res_levelThe reduced res level to query number of lines from.
Returns
The number of lines in the image.
Definition at line 377 of file ossimCibCadrgTileSource.cpp.
References ossimImageHandler::getNumberOfLines(), theNumberOfLines, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getImageRectangle().
378 {
379  if (reduced_res_level == 0)
380  {
381  return theNumberOfLines;
382  }
383  else if (theOverview.valid())
384  {
385  return theOverview->getNumberOfLines(reduced_res_level);
386  }
387
388  return 0;
389 }
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
◆ getNumberOfOutputBands()
ossim_uint32 ossimCibCadrgTileSource::getNumberOfOutputBands ( ) const
virtual
This might not be the same as the n umber of input bands.
See also
getNumberOfInputBands().
Returns
Definition at line 356 of file ossimCibCadrgTileSource.cpp.
357 {
358  switch(theProductType)
359  {
361  {
362  return 0;
363  }
365  {
366  return 1;
367  }
369  {
370  return 3;
371  }
372  }
373
374  return 0;
375 }
◆ getNumberOfSamples()
ossim_uint32 ossimCibCadrgTileSource::getNumberOfSamples ( ossim_uint32  reduced_res_level = 0) const
virtual
Parameters
reduced_res_levelThe reduced res level to query number of samples from.
Returns
The number of samples in the image.
Definition at line 391 of file ossimCibCadrgTileSource.cpp.
References ossimImageHandler::getNumberOfSamples(), theNumberOfSamples, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
392 {
393  if (reduced_res_level == 0)
394  {
395  return theNumberOfSamples;
396  }
397  else if (theOverview.valid())
398  {
399  return theOverview->getNumberOfSamples(reduced_res_level);
400  }
401
402  return 0;
403 }
bool valid() const
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
◆ getOutputScalarType()
ossimScalarType ossimCibCadrgTileSource::getOutputScalarType ( ) const
virtual
This is simply the data type, i.e. whether its OSSIM_FLOAT, OSSIM_DOUBLE, OSSIM_UCHAR, ... etc. This means that if there are bands of different scalar types from a single image then they must be casted to the highest precision type.
See also
ossimConstants.h for all ossimScalarType.
Returns
The output scalar type.
Definition at line 432 of file ossimCibCadrgTileSource.cpp.
References OSSIM_UCHAR.
433 {
434  return OSSIM_UCHAR;
435 }
8 bit unsigned iteger
◆ getProductEntryList()
vector< ossim_int32 > ossimCibCadrgTileSource::getProductEntryList ( const ossimString productScale) const
Returns
Entry indices for a passed in product scale.
Definition at line 626 of file ossimCibCadrgTileSource.cpp.
References ossimRpfTocEntry::getBoundaryInformation(), ossimRpfToc::getNumberOfEntries(), ossimRpfBoundaryRectRecord::getScale(), ossimRpfToc::getTocEntry(), ossimRpfTocEntry::isEmpty(), isOpen(), ossimString::push_back(), theSkipEmptyCheck, theTableOfContents, ossimString::trim(), and ossimString::upcase().
Referenced by findFirstFrame(), and getEntryList().
627 {
628  vector<ossim_int32> result;
629
630  if(isOpen())
631  {
633
634  for(ossim_int32 index = 0; index < upperBound; ++index)
635  {
636  const ossimRpfTocEntry* entry = theTableOfContents->getTocEntry(index);
637
638  if(entry)
639  {
640  // If the "skip empty check" is true, we don't check to see if the
641  // actual frame images exist. Otherwise the check is carried out,
642  // which is the default situation.
643  bool bIsEmpty = (theSkipEmptyCheck==false) ? entry->isEmpty() : false;
644
645  // if the entry is not empty then add it to the list.
646  if( bIsEmpty == false )
647  {
648  ossimString scale = entry->getBoundaryInformation().getScale();
649  scale = scale.trim().upcase();
650  if(scale==productScale)
651  {
652  result.push_back(index);
653  }
654  }
655  }
656  }
657  }
658
659  if (traceDebug())
660  {
662  << "ossimCibCadrgTileSource::getProductEntryList DEBUG:"
663  << endl;
664
665  std::vector<ossim_int32>::const_iterator i = result.begin();
666  ossim_uint32 index = 0;
667  while (i != result.end())
668  {
670  << "scale[" << index << "]: " << (*i) << endl;
671  ++index;
672  ++i;
673  }
674  }
675
676  return result;
677
678 }
ossim_uint32 getNumberOfEntries() const
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
const ossimRpfBoundaryRectRecord & getBoundaryInformation() const
bool isOpen() const
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
int ossim_int32
◆ getProductScale()
ossimString ossimCibCadrgTileSource::getProductScale ( ) const
Returns
Scale string ( like 1:24000 ) for current entry.
Definition at line 1182 of file ossimCibCadrgTileSource.cpp.
References ossimRpfTocEntry::getBoundaryInformation(), ossimRpfBoundaryRectRecord::getScale(), ossimRpfToc::getTocEntry(), theEntryNumberToRender, and theTableOfContents.
1183 {
1184  ossimString result;
1185
1186  const ossimRpfTocEntry* entry =
1188
1189  if (entry)
1190  {
1191  result = entry->getBoundaryInformation().getScale();
1192  }
1193
1194  return result;
1195 }
◆ getProductScaleList()
vector< ossimString > ossimCibCadrgTileSource::getProductScaleList ( ) const
I make no assumptions that a CIB/CADRG has only one product. A product here is 1meter, 5 meter, 10 meter ... etc for CIB and 1:24000, 1:50000, ... etc for CADRG.
Returns
The prduct list as a vector of strings.
Definition at line 570 of file ossimCibCadrgTileSource.cpp.
References ossimString::begin(), ossimString::end(), ossimRpfTocEntry::getBoundaryInformation(), ossimRpfToc::getNumberOfEntries(), ossimRpfBoundaryRectRecord::getScale(), ossimRpfToc::getTocEntry(), isOpen(), ossimString::push_back(), ossimString::size(), theTableOfContents, ossimString::trim(), and ossimString::upcase().
571 {
572  vector<ossimString> result;
573
574  if(isOpen())
575  {
577
578  for(ossim_int32 index = 0; index < upperBound; ++index)
579  {
580  const ossimRpfTocEntry* entry = theTableOfContents->getTocEntry(index);
581  ossimString scale = entry->getBoundaryInformation().getScale();
582
583  scale = scale.trim().upcase();
584  if(scale!="")
585  {
586  // CIB will have product scales like 5M or 10M
587  // and CADRG's will have product scales like
588  // 1:50K and 1:250K ...
589  // So if these patterns exist then add it to
590  // the product list.
591  if( ( std::find(scale.begin(), scale.end(), ':') != scale.end() )
592  ||
593  (scale[scale.size()-1]=='M'))
594  {
595  // only add it if it doesn't already exist
596  // on the list.
597  if(find(result.begin(), result.end(), scale) == result.end())
598  {
599  result.push_back(scale);
600  }
601  }
602  }
603  }
604  }
605
606  if (traceDebug())
607  {
609  << "ossimCibCadrgTileSource::getProductScaleList DEBUG:"
610  << endl;
611
612  std::vector<ossimString>::const_iterator i = result.begin();
613  ossim_uint32 index = 0;
614  while (i != result.end())
615  {
617  << "scale[" << index << "]: " << (*i) << endl;
618  ++index;
619  ++i;
620  }
621  }
622
623  return result;
624 }
std::string::iterator end()
Definition: ossimString.h:423
bool isOpen() const
std::string::size_type size() const
Definition: ossimString.h:405
std::string::iterator begin()
Definition: ossimString.h:420
int ossim_int32
◆ getProperty()
ossimRefPtr< ossimProperty > ossimCibCadrgTileSource::getProperty ( const ossimString name) const
virtual
Parameters
nameThe name of the property to get.
Returns
Returns property matching "name".
Definition at line 1212 of file ossimCibCadrgTileSource.cpp.
References ossimImageHandler::getProperty(), OSSIM_PRODUCT_TYPE_CADRG, OSSIM_PRODUCT_TYPE_CIB, and theProductType.
1213 {
1214  if(name == "file_type")
1215  {
1217  {
1218  return new ossimStringProperty("file_type", "CIB");
1219  }
1221  {
1222  return new ossimStringProperty("file_type", "CADRG");
1223  }
1224  return 0;
1225  }
1226  return ossimImageHandler::getProperty(name);
1227 }
◆ getPropertyNames()
void ossimCibCadrgTileSource::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Parameters
propertyNamesThe list to push back names to.
This code is crashing and not sure why in here. Looks like a bad GeoEye baseline merge.
Definition at line 1229 of file ossimCibCadrgTileSource.cpp.
References ossimString::c_str(), ossimImageHandler::getPropertyNames(), ossimRpfToc::getRpfHeader(), ossimImageHandler::theImageFile, and theTableOfContents.
1230 {
1231  ossimImageHandler::getPropertyNames(propertyNames);
1232  propertyNames.push_back("file_type");
1233
1238 #if 0
1239  const ossimRpfHeader* header =
1241  if(header)
1242  {
1243  std::ifstream in(theImageFile.c_str(), std::ios::in|std::ios::binary);
1244  }
1245 #endif
1246 }
std::basic_ifstream< char > ifstream
Class for char input file streams.
Definition: ossimIosFwd.h:44
const ossimRpfHeader * getRpfHeader() const
const char * c_str() const
Definition: ossimString.h:396
◆ getSecurityClassification()
ossimString ossimCibCadrgTileSource::getSecurityClassification ( ) const
Definition at line 1197 of file ossimCibCadrgTileSource.cpp.
References ossimRpfToc::getRpfHeader(), ossimRpfHeader::getSecurityClassification(), and theTableOfContents.
1198 {
1199  ossimString result;
1200
1201  const ossimRpfHeader* header =
1203
1204  if (header)
1205  {
1206  result = header->getSecurityClassification();
1207  }
1208
1209  return result;
1210 }
ossimString getSecurityClassification() const
◆ getShortName()
ossimString ossimCibCadrgTileSource::getShortName ( ) const
virtual
This class overrides the default implementation to return its own short name.
Returns
The short name for this class as an ossimString.
Definition at line 109 of file ossimCibCadrgTileSource.cpp.
110 {
111  return ossimString("CIB/CADRG");
112 }
◆ getTile() [1/2]
ossimRefPtr< ossimImageData > ossimCibCadrgTileSource::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
Parameters
rectThe region of interest to return.
resLevelFrom which resolution set are we querying (default is 0 full res).
Returns
The ossimImageData object to the caller.
Definition at line 237 of file ossimCibCadrgTileSource.cpp.
References allocateForProduct(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), theTile, and ossimRefPtr< T >::valid().
239 {
240  if ( theTile.valid() == false )
241  {
242  // First time through.
244  }
245
246  if (theTile.valid())
247  {
248  // Image rectangle must be set prior to calling getTile.
249  theTile->setImageRectangle(rect);
250
251  if ( getTile( theTile.get(), resLevel ) == false )
252  {
254  {
255  theTile->makeBlank();
256  }
257  }
258  }
259
260  return theTile;
261 }
void allocateForProduct()
bool valid() const
virtual void makeBlank()
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &rect, ossim_uint32 resLevel=0)
◆ getTile() [2/2]
bool ossimCibCadrgTileSource::getTile ( ossimImageData result,
virtual
Parameters
resultThe tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands()
Returns
true on success false on error. If return is false, result is undefined so caller should handle appropriately with makeBlank or whatever.
Definition at line 263 of file ossimCibCadrgTileSource.cpp.
References allocateForProduct(), fillTile(), getImageRectangle(), ossimImageData::getImageRectangle(), getIntersectingEntries(), ossimImageData::getNumberOfBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), isValidRLevel(), ossimImageData::makeBlank(), OSSIM_PRODUCT_TYPE_UNKNOWN, status, theCompressedBuffer, theProductType, and ossimImageData::validate().
265 {
266  bool status = false;
267
268  //---
269  // Not open, this tile source bypassed, or invalid res level,
270  // return a blank tile.
271  //---
272  if( isOpen() && isSourceEnabled() && isValidRLevel(resLevel) &&
273  result && (result->getNumberOfBands() == getNumberOfOutputBands()) &&
275  {
276  if ( resLevel > 0 )
277  {
278  //---
279  // Check for overview tile. Some overviews can contain r0 so always
280  // call even if resLevel is 0 (if overview is not virtual). Method
281  // returns true on success, false on error.
282  //---
283  status = getOverviewTile(resLevel, result);
284  }
285
286  if (!status) // Did not get an overview tile.
287  {
288  if ( !theCompressedBuffer )
289  {
290  // First time through.
292  }
293
294  if ( theCompressedBuffer )
295  {
296  status = true;
297
298  ossimIrect rect = result->getImageRectangle();
299
300  ossimIrect imageRect = getImageRectangle();
301
302  if ( rect.intersects(imageRect) )
303  {
304  //---
305  // Start with a blank tile in case there is not total coverage
306  // for rect.
307  //---
308  result->makeBlank();
309
310  vector<ossimFrameEntryData> frames = getIntersectingEntries(rect);
311  if(frames.size() > 0)
312  {
313  //---
314  // Now lets render each frame. Note we will have to find
315  // subframes
316  // that intersect the rectangle of interest for each frame.
317  //---
318  fillTile(rect, frames, result);
319
320  // Revalidate tile status.
321  result->validate();
322  }
323  }
324  else
325  {
326  result->makeBlank();
327  }
328  }
329  }
330  }
331
332  return status;
333 }
void fillTile(const ossimIrect &tileRect, const vector< ossimFrameEntryData > &framesInvolved, ossimImageData *tile)
bool isOpen() const
virtual bool getOverviewTile(ossim_uint32 resLevel, ossimImageData *result)
Method to get an overview tile.
vector< ossimFrameEntryData > getIntersectingEntries(const ossimIrect &rect)
It is important to note that each frame is organized into an easting northing type orientation...
virtual ossimIrect getImageRectangle() const
return status
bool isValidRLevel(ossim_uint32 reduced_res_level) const
◆ getTileHeight()
ossim_uint32 ossimCibCadrgTileSource::getTileHeight ( ) const
virtual
Definition at line 442 of file ossimCibCadrgTileSource.cpp.
References getImageTileHeight().
443 {
444  return getImageTileHeight();
445 }
virtual ossim_uint32 getImageTileHeight() const
◆ getTileWidth()
ossim_uint32 ossimCibCadrgTileSource::getTileWidth ( ) const
virtual
Definition at line 437 of file ossimCibCadrgTileSource.cpp.
References getImageTileWidth().
438 {
439  return getImageTileWidth();
440 }
virtual ossim_uint32 getImageTileWidth() const
◆ getToc()
const ossimRpfToc * ossimCibCadrgTileSource::getToc ( ) const
virtual
Returns
The table of contents object.
Definition at line 549 of file ossimCibCadrgTileSource.cpp.
References theTableOfContents.
550 {
551  return theTableOfContents;
552 }
◆ isCadrg()
bool ossimCibCadrgTileSource::isCadrg ( ) const
Returns
true if CADRG
Definition at line 1177 of file ossimCibCadrgTileSource.cpp.
References OSSIM_PRODUCT_TYPE_CADRG, and theProductType.
1178 {
1180 }
◆ isCib()
bool ossimCibCadrgTileSource::isCib ( ) const
Returns
true if CIB
Definition at line 1172 of file ossimCibCadrgTileSource.cpp.
References OSSIM_PRODUCT_TYPE_CIB, and theProductType.
1173 {
1175 }
◆ isOpen()
bool ossimCibCadrgTileSource::isOpen ( ) const
virtual
Returns
True if the handler is open and flase otherwise.
Definition at line 126 of file ossimCibCadrgTileSource.cpp.
Referenced by getIntersectingEntries(), getProductEntryList(), getProductScaleList(), getTile(), setEntryToRender(), and setTocEntryToRender().
127 {
128  return (theTableOfContents!=0);
129 }
◆ isValidRLevel()
bool ossimCibCadrgTileSource::isValidRLevel ( ossim_uint32  reduced_res_level) const
virtual
Parameters
reduced_res_levelpassed in resolution level.
Returns
True if the reduced_res_level is within an acceptable range and false otherwise.
Definition at line 554 of file ossimCibCadrgTileSource.cpp.
References ossimImageHandler::isValidRLevel(), ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
555 {
556  if (reduced_res_level == 0)
557  {
558  return true;
559  }
560  else if (theOverview.valid())
561  {
562  return theOverview->isValidRLevel(reduced_res_level);
563  }
564  else
565  {
566  return false;
567  }
568 }
bool valid() const
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
◆ loadState()
bool ossimCibCadrgTileSource::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Loading with a prefix.
cibCadrgHandler->laodState(kwl, "handler1.");
Loading without a prefix.
cibCadrgHandler->laodState(kwl);
Since all objects are factory created you can go through the registry and pass the keyword list in.
Parameters
kwlKeywordlist that holds the state information for this object.
prefixprefix value prepended to all keywords to uniquely locate the state attributes for this object.
Definition at line 1121 of file ossimCibCadrgTileSource.cpp.
1123 {
1124  const char* MODULE = "ossimCibCadrgTileSource::loadState";
1125
1126  if(traceDebug())
1127  {
1128  CLOG << "Entering..." << endl;
1129  }
1130  bool result = ossimImageHandler::loadState(kwl, prefix);
1131
1132  if(!result)
1133  {
1134  if(traceDebug())
1135  {
1136  CLOG << "Leaving..." << endl;
1137  }
1138  return false;
1139  }
1140  const char* lookup = 0;
1141  lookup = kwl.find(ossimString(prefix), "entry");
1142  ossim_int32 entry = ossimString(lookup).toInt32();
1143
1144  // if an entry is specified then
1145  // call the open with an entry number
1146  if(lookup)
1147  {
1148  if(traceDebug())
1149  {
1150  CLOG << "Leaving..." << endl;
1151  }
1153  setCurrentEntry(entry);
1154  return result;
1155  }
1156
1158
1159  return result;
1160 }
virtual bool open()=0
Pure virtual open.
#define CLOG
Definition: ossimTrace.h:23
ossim_int32 toInt32() const
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
int ossim_int32
◆ open()
bool ossimCibCadrgTileSource::open ( )
virtual
Pure virtual open.
Derived classes must implement.
Returns
Note
This method relies on the data member ossimImageData::theImageFile being set. Callers should do a "setFilename" prior to calling this method or use the ossimImageHandler::open that takes a file name and an entry index.
Definition at line 131 of file ossimCibCadrgTileSource.cpp.
132 {
133  if(traceDebug())
134  {
136  << "ossimCibCadrgTileSource::open(): Entered....."
137  << "\ntheImageFile: " << theImageFile << std::endl;
138  }
139
140  bool result = false;
141
142  if(isOpen())
143  {
144  close();
145  }
146
148
150  {
152  {
154  {
155  vector<ossimString> scaleList = getProductScaleList();
156  if(scaleList.size() > 0)
157  {
158  std::vector<ossim_uint32> entryList;
159  getEntryList(entryList);
160  if(entryList.size() > 0)
161  {
162  setCurrentEntry(entryList[0]);
163
164  if(theEntryToRender)
165  {
166  // a CADRG is 1536x1536 per frame.
169  }
170
171  if(theEntryToRender->getProductType().trim().upcase() == "CADRG")
172  {
174  result = true;
175  }
176  else if(theEntryToRender->getProductType().trim().upcase() == "CIB")
177  {
179  result = true;
180  }
181
182  // Moved this code to be called on first get tile. drb
183  // if ( result )
184  // {
185  // This initializes tiles and buffers.
186  // allocateForProduct();
187  // }
188  }
189  }
190  }
191  }
192  }
193
194  if(!result)
195  {
197  close();
198  }
199
200 #if 0 /* 20100414 - drb */
201  else
202  {
203  //---
204  // Adjust image rect so not to go over the -180 to 180 and -90 to 90
205  // bounds.
206  //---
207  // Note this did not do any boundary checking and was in conflict with setTocEntryToRender
208  // method calculation of lines and samps.
209  // setActualImageRect();
210
211  std::ifstream in(theImageFile.c_str(), std::ios::in|std::ios::binary);
212  if(in.good()&&theTableOfContents->getRpfHeader())
213  {
214  }
215  completeOpen();
216
218  theTile->initialize();
219  }
220 #endif
221
222  if(traceDebug())
223  {
225  << "ossimCibCadrgTileSource::open(): Leaving at line " << __LINE__
226  << " result=" << (result?"true":"false") << std::endl;
227  }
228
229  return result;
230 }
void clear()
Erases the entire container.
Definition: ossimString.h:432
ossimString getProductType() const
ossim_uint32 getNumberOfSamples() const
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
bool isOpen() const
ossimErrorCode parseFile(const ossimFilename &fileName, bool keepFileHeader=false)
Parses a.toc file.
Definition: ossimRpfToc.cpp:55
virtual void completeOpen()
Will complete the opening process.
ossim_uint32 getNumberOfLines() const
◆ populateLut()
void ossimCibCadrgTileSource::populateLut ( )
protected
Definition at line 1248 of file ossimCibCadrgTileSource.cpp.
References ossimFilename::exists(), ossimRpfFrame::getColorGrayscaleTable(), ossimRpfTocEntry::getEntry(), ossimRpfFrameEntry::getFullPath(), ossimRpfTocEntry::getNumberOfFramesHorizontal(), ossimRpfTocEntry::getNumberOfFramesVertical(), ossimErrorCodes::OSSIM_OK, OSSIM_PRODUCT_TYPE_CADRG, OSSIM_PRODUCT_TYPE_CIB, OSSIM_UINT8, ossimRpfFrame::parseFile(), theEntryToRender, ossimImageHandler::theLut, and theProductType.
Referenced by setEntryToRender().
1249 {
1250  theLut = 0;
1251  if(theEntryToRender)
1252  {
1255  ossim_uint32 wi, hi;
1256  bool found = false;
1257  ossimRpfFrameEntry tempEntry;
1258  ossimRpfFrame aFrame;
1259  for(wi = 0; ((wi < w)&&(!found)); ++wi)
1260  {
1261  for(hi = 0; ((hi < h)&&(!found)); ++hi)
1262  {
1264  wi,
1265  tempEntry);
1266  if(tempEntry.getFullPath().exists())
1267  {
1268  found = true;
1269  }
1270  }
1271  }
1272  if(aFrame.parseFile(tempEntry.getFullPath())
1274  {
1275  const vector<ossimRpfColorGrayscaleTable>& colorTable =
1276  aFrame.getColorGrayscaleTable();
1277
1278  // ESH 03/2009 -- Partial fix for ticket #646.
1279  // Crash fix on reading RPFs: Make sure the colorTable vector
1280  // has entries before trying to make use of them.
1281  int numTables = (int)colorTable.size();
1282
1283  ossim_uint32 numElements = (numTables > 0) ? colorTable[0].getNumberOfElements() : 0;
1284  if(numElements > 0)
1285  {
1288  {
1289  theLut = new ossimNBandLutDataObject(numElements,
1290  3,
1291  OSSIM_UINT8);
1292  }
1293  else
1294  {
1295  theLut = 0;
1296  return;
1297  }
1298  ossim_uint32 idx = 0;
1299
1300  for(idx = 0; idx < numElements;++idx)
1301  {
1302  const ossim_uint8* startOfData = colorTable[0].getStartOfData(idx);
1303  switch(theProductType)
1304  {
1306  {
1307  (*theLut)[idx][0] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[0]);
1308  (*theLut)[idx][1] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[0]);
1309  (*theLut)[idx][2] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[0]);
1310  break;
1311  }
1313  {
1314  (*theLut)[idx][0] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[0]);
1315  (*theLut)[idx][1] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[1]);
1316  (*theLut)[idx][2] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[2]);
1317  break;
1318  }
1319  default:
1320  {
1321  break;
1322  }
1323  }
1324  }
1325  }
1326  }
1327  }
1328 }
bool exists() const
ossim_uint32 getNumberOfFramesHorizontal() const
class ossimNBandLutDataObject
ossimRefPtr< ossimNBandLutDataObject > theLut
8 bit unsigned integer
const ossimFilename & getFullPath() const
◆ saveState()
bool ossimCibCadrgTileSource::saveState ( ossimKeywordlist kwl,
) const
virtual
Saving data without a prefix.
cibCadrgHandler->open(filename);
cibCadrgHandler->saveState(kwl);
and saving data with a prefix.
cibCadrgHandler->saveState(kwl, "handler1.");
Saving with a prefix will help uniquely identify objects in the kwl. To see what is in the keywordlist after a save state then do:
cout << kwl << endl;
There is only 1 keyword for this object:
entry: <entry number>="">
where <entry number>=""> is the index value for the current entry.
See also
ossimImageHandler for additional keywords.
Parameters
kwlKeywordlist to save the state of the object to.
prefixprefix to prepend to the keywords. This will help uniquely identify each keyword if multiple objects are saved to the same list.
Returns
True if successfully saved the state of the object and false otherwise.
Definition at line 1108 of file ossimCibCadrgTileSource.cpp.
References ossimKeywordlist::add(), ossimImageHandler::saveState(), and theEntryNumberToRender.
1110 {
1111  bool result = ossimImageHandler::saveState(kwl, prefix);
1112
1113  kwl.add(prefix,
1114  "entry",
1116  true);
1117
1118  return result;
1119 }
◆ setCurrentEntry()
bool ossimCibCadrgTileSource::setCurrentEntry ( ossim_uint32  entryIdx)
virtual
Parameters
entryIdxEntry number to select.
Note
The implementation does nothing. Derived classes that handle multiple images should override.
Returns
true if it was able to set the current entry and false otherwise.
Definition at line 452 of file ossimCibCadrgTileSource.cpp.
References ossimString::clear(), ossimImageHandler::completeOpen(), setEntryToRender(), ossimImageHandler::theDecimationFactors, ossimImageHandler::theGeometry, and ossimImageHandler::theOverviewFile.
453 {
454  bool result = false;
455
456  theDecimationFactors.clear();
457
458  // Clear the geometry.
459  theGeometry = 0;
460
461  // Must clear or openOverview will use last entries.
463
464  if(setEntryToRender(entryIdx))
465  {
466  completeOpen();
467  result = true;
468  }
469
470  return result;
471 }
void clear()
std::vector< ossimDpt > theDecimationFactors
virtual bool setEntryToRender(ossim_uint32 index)
◆ setEntryToRender()
bool ossimCibCadrgTileSource::setEntryToRender ( ossim_uint32  index)
protectedvirtual
Definition at line 490 of file ossimCibCadrgTileSource.cpp.
References ossimRpfTocEntry::getBoundaryInformation(), ossimRpfBoundaryRectRecord::getCoverage(), ossimRpfTocEntry::getProductType(), ossimRpfToc::getTocEntry(), ossimRpfCoverageSection::isGeographicRectNull(), isOpen(), OSSIM_PRODUCT_TYPE_CADRG, OSSIM_PRODUCT_TYPE_CIB, OSSIM_PRODUCT_TYPE_UNKNOWN, populateLut(), setTocEntryToRender(), theEntryNumberToRender, theEntryToRender, theProductType, theTableOfContents, ossimString::trim(), and ossimString::upcase().
Referenced by setCurrentEntry().
491 {
492  if(isOpen())
493  {
494  const ossimRpfTocEntry *temp = theTableOfContents->getTocEntry(index);
495
496  if(temp)
497  {
499  {
500  setTocEntryToRender(temp);
501  theEntryNumberToRender = index;
502  if(theEntryToRender)
503  {
504  if(theEntryToRender->getProductType().trim().upcase() == "CADRG")
505  {
507  }
508  else if(theEntryToRender->getProductType().trim().upcase() == "CIB")
509  {
511  }
512  else
513  {
515  }
516  }
517
518  populateLut();
519
520  return true;
521  }
522  }
523  }
524
525  return false;
526 }
virtual void setTocEntryToRender(const ossimRpfTocEntry *entry)
const ossimRpfCoverageSection & getCoverage() const
bool isOpen() const
◆ setSkipEmptyCheck()
void ossimCibCadrgTileSource::setSkipEmptyCheck ( bool  bSkipEmptyCheck = false)
Parameters
bSkipEmptyCheckIf true, the RPF file is opened even if all the frame files are missing. By default this is set to false.
Definition at line 232 of file ossimCibCadrgTileSource.cpp.
References theSkipEmptyCheck.
233 {
234  theSkipEmptyCheck = bSkipEmptyCheck;
235 }
◆ setTocEntryToRender()
void ossimCibCadrgTileSource::setTocEntryToRender ( const ossimRpfTocEntry entry)
protectedvirtual
The entry within the table of contents are stored in an Toc entry object.
Parameters
entrythe Rpf toc entry object to set to.
Definition at line 528 of file ossimCibCadrgTileSource.cpp.
References ossimRpfTocEntry::getNumberOfLines(), ossimRpfTocEntry::getNumberOfSamples(), ossimRpfToc::getTocEntryIndex(), isOpen(), theEntryNumberToRender, theEntryToRender, theNumberOfLines, theNumberOfSamples, and theTableOfContents.
529 {
530  if(isOpen()&&entry)
531  {
532  theEntryToRender = entry;
536  }
537 }
bool isOpen() const
ossim_int32 getTocEntryIndex(const ossimRpfTocEntry *entry)
Returns -1 if not found.
◆ updatePropertiesToFirstValidFrame()
void ossimCibCadrgTileSource::updatePropertiesToFirstValidFrame ( )
protected
Definition at line 1330 of file ossimCibCadrgTileSource.cpp.
References ossimFilename::exists(), ossimRpfTocEntry::getEntry(), ossimRpfFrameEntry::getFullPath(), ossimRpfTocEntry::getNumberOfFramesHorizontal(), ossimRpfTocEntry::getNumberOfFramesVertical(), ossimErrorCodes::OSSIM_OK, ossimRpfFrame::parseFile(), and theEntryToRender.
1331 {
1332  if(theEntryToRender)
1333  {
1336  ossim_uint32 wi, hi;
1337  bool found = false;
1338  ossimRpfFrameEntry tempEntry;
1339  ossimRpfFrame aFrame;
1340  for(wi = 0; ((wi < w)&&(!found)); ++wi)
1341  {
1342  for(hi = 0; ((hi < h)&&(!found)); ++hi)
1343  {
1345  wi,
1346  tempEntry);
1347  if(tempEntry.getFullPath().exists())
1348  {
1349  found = true;
1350  }
1351  }
1352  }
1353  if(found)
1354  {
1355  if(aFrame.parseFile(tempEntry.getFullPath()) == ossimErrorCodes::OSSIM_OK)
1356  {
1357
1358  }
1359  }
1360  }
1361 }
bool exists() const
◆ ossimMultiEntryCibCadrg
friend class ossimMultiEntryCibCadrg
friend
Definition at line 38 of file ossimCibCadrgTileSource.h.
Member Data Documentation
◆ CIBCADRG_FRAME_HEIGHT
const ossim_uint32 ossimCibCadrgTileSource::CIBCADRG_FRAME_HEIGHT = 1536
static
This should be 1536.
Definition at line 393 of file ossimCibCadrgTileSource.h.
Referenced by fillSubTileCadrg(), fillSubTileCib(), and getIntersectingEntries().
◆ CIBCADRG_FRAME_WIDTH
const ossim_uint32 ossimCibCadrgTileSource::CIBCADRG_FRAME_WIDTH = 1536
static
Definition at line 388 of file ossimCibCadrgTileSource.h.
◆ theCompressedBuffer
unsigned char* ossimCibCadrgTileSource::theCompressedBuffer
protected
Definition at line 536 of file ossimCibCadrgTileSource.h.
Referenced by allocateForProduct(), fillSubTileCadrg(), fillSubTileCib(), getTile(), and ~ossimCibCadrgTileSource().
◆ theEntryNumberToRender
ossim_int32 ossimCibCadrgTileSource::theEntryNumberToRender
protected
This will mainly be used when using overviews.
Definition at line 580 of file ossimCibCadrgTileSource.h.
Referenced by findFirstFrame(), getCurrentEntry(), getCurrentEntryIndex(), getProductScale(), saveState(), setEntryToRender(), and setTocEntryToRender().
◆ theEntryToRender
const ossimRpfTocEntry* ossimCibCadrgTileSource::theEntryToRender
protected
This should be divided into frames where each frame is 1536x1536 in size.
Definition at line 573 of file ossimCibCadrgTileSource.h.
Referenced by getCurrentTocEntry(), getImageGeometry(), getIntersectingEntries(), populateLut(), setEntryToRender(), setTocEntryToRender(), and updatePropertiesToFirstValidFrame().
◆ theNumberOfLines
ossim_uint32 ossimCibCadrgTileSource::theNumberOfLines
protected
The CibCadrg have fixed size frames of 1536x1536 and we must count how many there are.
Definition at line 548 of file ossimCibCadrgTileSource.h.
Referenced by getNumberOfLines(), and setTocEntryToRender().
◆ theNumberOfSamples
ossim_uint32 ossimCibCadrgTileSource::theNumberOfSamples
protected
Definition at line 555 of file ossimCibCadrgTileSource.h.
Referenced by getNumberOfSamples(), and setTocEntryToRender().
◆ theProductType
ossimCibCadrgProductType ossimCibCadrgTileSource::theProductType
protected
The product type can be a CIB or a CADRG product.
Definition at line 586 of file ossimCibCadrgTileSource.h.
Referenced by allocateForProduct(), fillTile(), getNumberOfInputBands(), getNumberOfOutputBands(), getProperty(), getTile(), isCadrg(), isCib(), populateLut(), and setEntryToRender().
◆ theSkipEmptyCheck
bool ossimCibCadrgTileSource::theSkipEmptyCheck
protected
Definition at line 594 of file ossimCibCadrgTileSource.h.
Referenced by getProductEntryList(), and setSkipEmptyCheck().
◆ theTableOfContents
ossimRpfToc* ossimCibCadrgTileSource::theTableOfContents
protected
This describes all entries within the CIB/CADRG.
Definition at line 566 of file ossimCibCadrgTileSource.h.
Referenced by deleteAll(), findFirstFrame(), getProductEntryList(), getProductScale(), getProductScaleList(), getPropertyNames(), getSecurityClassification(), getToc(), isOpen(), setEntryToRender(), and setTocEntryToRender().
◆ theTile
ossimRefPtr<ossimImageData> ossimCibCadrgTileSource::theTile
protected
Definition at line 560 of file ossimCibCadrgTileSource.h.
Referenced by allocateForProduct(), and getTile().
◆ theUncompressedBuffer
unsigned char* ossimCibCadrgTileSource::theUncompressedBuffer
protected
Definition at line 541 of file ossimCibCadrgTileSource.h.
Referenced by allocateForProduct(), fillSubTileCadrg(), fillSubTileCib(), and ~ossimCibCadrgTileSource().
◆ theWorkFrame
ossimRpfFrame* ossimCibCadrgTileSource::theWorkFrame
mutableprotected
