ossimKakaduNitfReader class for reading NITF images with JPEG2000 (J2K) compressed blocks using kakadu library for decompression. More...
#include <ossimKakaduNitfReader.h>
Public Types | |
enum | { SIGNATURE_BOX_SIZE = 12 } |
Anonymous enumerations: More... | |
enum | ReadMode { READ_MODE_UNKNOWN = 0, READ_BIB_BLOCK = 1, READ_BIP_BLOCK = 2, READ_BIR_BLOCK = 3, READ_BSQ_BLOCK = 4, READ_BIB = 5, READ_BIP = 6, READ_BIR = 7, READ_JPEG_BLOCK = 8 } |
enum | ossimImageHandlerOverviewCompressionType { OSSIM_OVERVIEW_COMPRESSION_NONE = 0, OSSIM_OVERVIEW_COMPRESSION_JPEG, OSSIM_OVERVIEW_COMPRESSION_LZW, OSSIM_OVERVIEW_COMPRESSION_DEFLATE, OSSIM_OVERVIEW_COMPRESSION_PACKBITS } |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
ossimKakaduNitfReader () | |
default construtor More... | |
virtual | ~ossimKakaduNitfReader () |
virtural destructor More... | |
virtual ossimString | getShortName () const |
Returns short name. More... | |
virtual ossimString | getLongName () const |
Returns long name. More... | |
virtual ossim_uint32 | getNumberOfDecimationLevels () const |
Returns the number of decimation levels. More... | |
virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
Gets number of lines for res level. More... | |
virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
Gets the number of samples for res level. More... | |
virtual void | setMinPixelValue (ossim_uint32 band, const ossim_float64 &pix) |
convenience method to set min pixel value. More... | |
virtual void | setMaxPixelValue (ossim_uint32 band, const ossim_float64 &pix) |
convenience method to set max pixel value. More... | |
virtual void | setNullPixelValue (ossim_uint32 band, const ossim_float64 &pix) |
convenience method to set null pixel value. More... | |
virtual ossim_float64 | getMinPixelValue (ossim_uint32 band=0) const |
virtual ossim_float64 | getMaxPixelValue (ossim_uint32 band=0) const |
virtual ossim_float64 | getNullPixelValue (ossim_uint32 band=0) const |
ossimNitfTileSource () | |
virtual bool | open () |
Returns true if the image_file can be opened and is a valid nitf file. More... | |
bool | open (std::shared_ptr< ossim::istream > &str, const std::string &connectionString) |
This open takes a stream and stores/captures the shared pointer on success. More... | |
virtual void | close () |
Closes file and destroys all memory allocated. More... | |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
virtual ossim_uint32 | getNumberOfInputBands () const |
virtual ossim_uint32 | getNumberOfOutputBands () const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
Method to save the state of an object to a keyword list. More... | |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
Method to the load (recreate) the state of an object from a keyword list. More... | |
virtual ossimScalarType | getOutputScalarType () const |
Returns the output pixel type of the tile source. More... | |
virtual ossim_uint32 | getTileWidth () const |
Returns the width of the output tile. More... | |
virtual ossim_uint32 | getTileHeight () const |
Returns the height of the output tile. More... | |
virtual ossim_uint32 | getImageTileWidth () const |
Returns the tile width of the image or 0 if the image is not tiled. More... | |
virtual ossim_uint32 | getImageTileHeight () const |
virtual bool | isOpen () const |
Derived classes must implement this method to be concrete. More... | |
virtual ossim_uint32 | getCurrentEntry () const |
virtual void | getEntryList (std::vector< ossim_uint32 > &entryList) const |
ossim_uint32 | getNumberOfEntries () const |
virtual bool | setCurrentEntry (ossim_uint32 entryIdx) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
ossimString | getSecurityClassification () const |
bool | getCacheEnabledFlag () const |
void | setCacheEnabledFlag (bool flag) |
const ossimNitfFileHeader * | getFileHeader () const |
ossimNitfFileHeader * | getFileHeader () |
const ossimNitfImageHeader * | getCurrentImageHeader () const |
ossimNitfImageHeader * | getCurrentImageHeader () |
virtual bool | getRgbBandList (std::vector< ossim_uint32 > &bandList) const |
Convenience method to get the zero based rgb output band list. More... | |
ossimImageHandler () | |
Constructor (default): More... | |
virtual | ~ossimImageHandler () |
Destructor: Derived classes should implement. More... | |
virtual void | initialize () |
initialize Does nothing in this class. More... | |
virtual bool | openOverview () |
Searches for an overview. More... | |
virtual bool | openOverview (const ossimFilename &overview_file) |
Calls closeOverview(), then attempts to open the overview_file. More... | |
virtual void | closeOverview () |
If theOverview is initialized it will be deleted and set to NULL. More... | |
virtual const ossimImageHandler * | getOverview () const |
virtual bool | hasOverviews () const |
virtual ossimFilename | createDefaultOverviewFilename () const |
virtual ossimFilename | createDefaultGeometryFilename () const |
virtual ossimFilename | createDefaultMetadataFilename () const |
virtual ossimFilename | createDefaultHistogramFilename () const |
virtual ossimFilename | createDefaultValidVerticesFilename () const |
virtual bool | writeValidImageVertices (const std::vector< ossimIpt > &vertices, const ossimFilename &file=ossimFilename("")) |
Outputs vertices to file and updates the internal vertex array variable "theValidImageVertices". More... | |
virtual bool | openValidVertices (const ossimFilename &vertices_file) |
Opens the valid image vertices file and sets theValidImageVerticesFile variable. More... | |
virtual bool | openValidVertices () |
Creates vertices file name based on image, then tries to open. More... | |
virtual bool | open (const ossimFilename &imageFile, ossim_uint32 entryIndex) |
Opens the image file. More... | |
virtual bool | open (const ossimFilename &imageFile) |
virtual bool | open (std::shared_ptr< ossim::ImageHandlerState > state) |
virtual bool | buildHistogram (int numberOfRLevels=0, ossimHistogramMode mode=OSSIM_HISTO_MODE_NORMAL) |
Build a histogram for image file. More... | |
virtual bool | buildAllHistograms (int numberOfRLevels=0, ossimHistogramMode mode=OSSIM_HISTO_MODE_NORMAL) |
Build a histograms for all image entries. More... | |
virtual bool | buildOverview (ossimImageHandlerOverviewCompressionType compressionType=OSSIM_OVERVIEW_COMPRESSION_NONE, ossim_uint32 quality=75, ossimFilterResampler::ossimFilterResamplerType resampleType=ossimFilterResampler::ossimFilterResampler_BOX, bool includeFullResFlag=false) |
Will build over file for theImageFile. More... | |
virtual bool | buildAllOverviews (ossimImageHandlerOverviewCompressionType compressionType=OSSIM_OVERVIEW_COMPRESSION_NONE, ossim_uint32 quality=75, ossimFilterResampler::ossimFilterResamplerType resampleType=ossimFilterResampler::ossimFilterResampler_BOX, bool includeFullResFlag=false) |
Will build over file for all image entries. More... | |
virtual bool | buildOverview (const ossimFilename &filename, ossimImageHandlerOverviewCompressionType compressionType=OSSIM_OVERVIEW_COMPRESSION_NONE, ossim_uint32 quality=75, ossimFilterResampler::ossimFilterResamplerType resampleType=ossimFilterResampler::ossimFilterResampler_BOX, bool includeFullResFlag=false) |
Will build an over file for filename. More... | |
ossimRefPtr< ossimMultiResLevelHistogram > | getImageHistogram () const |
Fetches the current entry image's histogram. More... | |
virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
Returns the image geometry object associated with this tile source or NULL if non defined. More... | |
virtual void | setImageGeometry (ossimImageGeometry *geom) |
Sets the image geometry object. More... | |
virtual void | saveImageGeometry () const |
Saves the image geometry to a file that will be made based on the image file name. More... | |
virtual void | saveImageGeometry (const ossimFilename &geometry_file) const |
virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
Returns zero-based bounding rectangle of the image. More... | |
virtual ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
virtual void | getDecimationFactor (ossim_uint32 resLevel, ossimDpt &result) const |
virtual void | getDecimationFactors (vector< ossimDpt > &decimations) const |
This returns all decimation for all levels. More... | |
virtual ossim_uint32 | getNumberOfReducedResSets () const |
This method is obsolete. More... | |
virtual void | setFilename (const ossimFilename &filename) |
Sets the filename. More... | |
virtual const ossimFilename & | getFilename () const |
Returns the filename. More... | |
virtual bool | isValidRLevel (ossim_uint32 resLevel) const |
Determines if the passed in reslution level is valid. More... | |
bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
Connection rule. More... | |
virtual void | getValidImageVertices (vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
ordering specifies how the vertices should be arranged. More... | |
virtual bool | isBandSelector () const |
Indicates whether or not the image handler can control output band selection via the setOutputBandList method. More... | |
virtual bool | setOutputBandList (const std::vector< ossim_uint32 > &band_list) |
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled. More... | |
virtual bool | setOutputToInputBandList () |
If the image handler "isBandSeletor()" then the band selection of the output are set to input or identity. More... | |
virtual bool | isIdentityBandList (const std::vector< ossim_uint32 > &bandList) const |
Convenience method to see if band list is identity. More... | |
virtual bool | isImageTiled () const |
Indicates whether or not the image is tiled internally. More... | |
virtual bool | hasMetaData () const |
virtual ossimRefPtr< ossimNBandLutDataObject > | getLut () const |
virtual bool | hasLut () const |
virtual void | loadMetaData () |
There is an external file with an omd extension. More... | |
virtual void | getEntryName (ossim_uint32 entryIdx, std::string &name) const |
Get the name of entry as a string. More... | |
virtual void | getEntryNames (std::vector< ossimString > &entryNames) const |
bool | useEntryIndex () const |
Convenience method to determine if entry index should be used for support files, e.g. More... | |
ossimFilename | getOverviewFile () const |
ossimFilename | getFilenameWithThisExtension (const ossimString &ext, bool set_e0_prefix=false) const |
Returns the image file with extension set using supplentary directory for dirname if set. More... | |
void | getFilenameWithThisExt (const ossimString &ext, ossimFilename &f) const |
ossim_uint32 | getStartingResLevel () const |
void | setStartingResLevel (ossim_uint32 level) |
bool | getOpenOverviewFlag () const |
void | setOpenOverviewFlag (bool flag) |
Sets theOpenOverviewFlag. More... | |
virtual void | setSupplementaryDirectory (const ossimFilename &dir) |
Sets the supplementary directory. More... | |
virtual const ossimFilename & | getSupplementaryDirectory () const |
Returns the supplementary directory. More... | |
const ossimString & | getImageID () const |
Fetches the image ID. More... | |
void | setImageID (const ossimString &id) |
Sets the image ID in case it is externally generated. More... | |
ossimPixelType | getPixelType () const |
Returns the raster pixel alignment type. More... | |
template<class T > | |
std::shared_ptr< T > | getStateAs () |
std::shared_ptr< const T > | getStateAs () const |
std::shared_ptr< ossim::ImageHandlerState > | getState () |
std::shared_ptr< const ossim::ImageHandlerState > | getState () const |
void | setState (std::shared_ptr< ossim::ImageHandlerState > state) |
ossimImageSource (ossimObject *owner=0) | |
ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimImageSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIpt &origin, ossim_uint32 resLevel=0) |
virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel=0) |
Method to get a tile. More... | |
virtual ossimObject * | getObject () |
For RTTI support. More... | |
virtual const ossimObject * | getObject () const |
virtual void | getDecimationFactors (std::vector< ossimDpt > &decimations) const |
Will return an array of all decimations for each resolution level. More... | |
virtual void | getOutputBandList (std::vector< ossim_uint32 > &bandList) const |
Initializes bandList. More... | |
virtual void | getBoundingRect (ossimIrect &rect, ossim_uint32 resLevel=0) const |
Gets the bounding rectangle of the source. More... | |
virtual void | getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
virtual void | setImageGeometry (const ossimImageGeometry *geom) |
Default implementation sets geometry of the first input to the geometry specified. More... | |
virtual bool | isIndexedData () const |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
virtual bool | getOverviewTile (ossim_uint32 resLevel, ossimImageData *result) |
Gets an overview tile. More... | |
virtual bool | loadBlock (ossim_uint32 x, ossim_uint32 y) |
Loads a block of data to theCacheTile. More... | |
virtual bool | parseFile () |
Parses "theImageFile" and initializes all nitf headers. More... | |
virtual bool | allocate () |
Allocates everything for current entry. More... | |
virtual bool | allocateBuffers () |
Allocates buffers for current entry. More... | |
virtual bool | canUncompress (const ossimNitfImageHeader *hdr) const |
Checks header to see is we can decompress entry. More... | |
virtual void | initializeReadMode () |
Initializes the data member "theReadMode" from the current entry. More... | |
virtual bool | scanForJpegBlockOffsets () |
This method simply checks for Start of Codestream (SOC) marker as the Kakadu library handles finding tiles for us. More... | |
virtual void | initializeSwapBytesFlag () |
Sets the "theSwapBytesFlag" from the current entry. More... | |
virtual void | initializeCacheTileInterLeaveType () |
Initializes the data member "theCacheTileInterLeaveType". More... | |
virtual ossim_int32 | get_capabilities () |
Gets kdu source capability. More... | |
virtual ossim_int32 | read (kdu_core::kdu_byte *buf, ossim_int32 num_bytes) |
Read method. More... | |
virtual bool | seek (kdu_core::kdu_long offset) |
Seek method. More... | |
virtual kdu_core::kdu_long | get_pos () |
Get file position relative to the start of code stream offset. More... | |
virtual | ~ossimNitfTileSource () |
void | setBoundingRectangle (const ossimIrect &imageRect) |
ossimNitfTileSource (const ossimNitfTileSource &obj) | |
Copy constructor, disallow... More... | |
ossimNitfTileSource & | operator= (const ossimNitfTileSource &rhs) |
Operator=, disallow... More... | |
bool | loadTile (const ossimIrect &clipRect) |
Returns true on success, false on error. More... | |
ossim_uint32 | getBlockNumber (const ossimIpt &block_origin) const |
void | destroy () |
Deletes all memory allocated by this object. More... | |
virtual void | initializeScalarType () |
Initializes the data member "theScalarType" from the current entry. More... | |
void | initializeBandCount () |
Initializes the data member "theNumberOfBands" from the current entry. More... | |
bool | initializeBlockSize () |
Initializes the data member "theBlockSize" from the current entry. More... | |
virtual bool | initializeImageRect () |
Initializes the data members "theImageRect" and "theBlockRect" from the current entry. More... | |
void | initializeCacheSize () |
Initializes the data member "theCacheSize". More... | |
void | initializeCacheTile () |
Initializes the cache tile size(width and height). More... | |
virtual void | initializeCompressedBuf () |
Initializes the data member theCompressedBuf. More... | |
virtual void | initializeOutputTile () |
Initializes the output tile size(width and height). More... | |
void | initializeLut () |
Initializes "theLut" if applicable. More... | |
bool | loadBlockFromCache (ossim_uint32 x, ossim_uint32 y, const ossimIrect &clipRect) |
bool | getPosition (std::streamoff &position, ossim_uint32 x, ossim_uint32 y, ossim_uint32 band) const |
ossim_uint32 | getNumberOfBlocks () const |
std::streampos | getBandOffset () const |
std::streampos | getBlockOffset () const |
void | explodePackedBits (ossimRefPtr< ossimImageData > packedBuffer) const |
void | convertTransparentToNull (ossimRefPtr< ossimImageData > tile) const |
ossim_uint32 | getPartialReadSize (const ossimIpt &blockOrigin) const |
bool | isVqCompressed (const ossimString &compressionCode) const |
void | vqUncompressC4 (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source) |
Uncompresses Vector Quantization unmasked image data. More... | |
void | vqUncompressM4 (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source) |
Uncompresses Vector Quantization masked image data. More... | |
void | lutUncompress (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source) |
virtual bool | uncompressJpegBlock (ossim_uint32 x, ossim_uint32 y) |
Uncompresses a jpeg block using the jpeg-6b library. More... | |
bool | loadJpegQuantizationTables (jpeg_decompress_struct &cinfo) const |
Loads one of the default tables based on COMRAT value. More... | |
bool | loadJpegHuffmanTables (jpeg_decompress_struct &cinfo) const |
Loads default huffman tables. More... | |
virtual void | establishDecimationFactors () |
Virtual method determines the decimation factors at each resolution level. More... | |
virtual ossimRefPtr< ossimImageGeometry > | getExternalImageGeometry () const |
virtual ossimRefPtr< ossimImageGeometry > | getInternalImageGeometry () const |
bool | initVertices (const char *file) |
Opens file and attempts to initialize the valid image vertices. More... | |
virtual void | completeOpen () |
Will complete the opening process. More... | |
void | initImageParameters (ossimImageGeometry *geom) const |
Convenience method to set things needed in the image geometry from the image handler. More... | |
virtual bool | setOutputBandList (const std::vector< ossim_uint32 > &inBandList, std::vector< ossim_uint32 > &outBandList) |
Convenience method to set output band list. More... | |
void | getFilenameWithNoExtension (ossimFilename &f) const |
Get filename with no extension, using supplentary directory for dirname if set. More... | |
ossimImageSource (const ossimImageSource &rhs) | |
const ossimImageSource & | operator= (const ossimImageSource &) |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
Private Member Functions | |
bool | isEntryJ2k () const |
Checks current entry image header to see if it is j2k. More... | |
bool | checkJp2Signature () |
Checks for jp2 signature block. More... | |
void | configureChannelMapping () |
Initializes m_channels to be used with copyRegionToTile if it makes sense. More... | |
std::ostream & | dumpTiles (std::ostream &out) |
Method to print out tile info. More... | |
Private Attributes | |
std::streamoff | m_startOfCodestreamOffset |
kdu_supp::jp2_family_src * | m_jp2FamilySrc |
kdu_supp::jp2_source * | m_jp2Source |
kdu_supp::kdu_channel_mapping * | m_channels |
kdu_core::kdu_codestream | m_codestream |
kdu_core::kdu_thread_env * | m_threadEnv |
kdu_core::kdu_thread_queue * | m_openTileThreadQueue |
ossim_uint32 | m_sourcePrecisionBits |
ossim_uint32 | m_minDwtLevels |
std::vector< ossimIrect > | m_imageDims |
Image dimensions for each level. More... | |
ossim_float64 | m_minSampleValue |
min/max/null These are class attributes so that when behaving as an overview the owner or base image handler can pass its min/max/null to us. More... | |
ossim_float64 | m_maxSampleValue |
ossim_float64 | m_nullSampleValue |
Definition at line 44 of file ossimKakaduNitfReader.h.
anonymous enum |
Enumerator | |
SIGNATURE_BOX_SIZE |
Definition at line 50 of file ossimKakaduNitfReader.h.
ossimKakaduNitfReader::ossimKakaduNitfReader | ( | ) |
default construtor
virtural destructor
Definition at line 76 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::close(), m_channels, m_codestream, m_jp2FamilySrc, m_jp2Source, m_openTileThreadQueue, m_threadEnv, ossimNotify(), and ossimNotifyLevel_WARN.
protectedvirtual |
This is called on an open() or a entry change to an already open nitf file.
This does not allocate buffers and tiles to keep open and setCurrentEntry times to a minimum. Buffers are allocated on first grab of pixel data by allocatBuffers method.
Overrides ossimNitfTileSource::allocate
Reimplemented from ossimNitfTileSource.
Definition at line 528 of file ossimKakaduNitfReader.cpp.
protectedvirtual |
This is called on first getTile().
Overrides ossimNitfTileSource::allocateBuffers
Definition at line 763 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::allocateBuffers(), ossimNitfTileSource::getNumberOfOutputBands(), ossim::isnan(), m_maxSampleValue, m_minSampleValue, m_nullSampleValue, ossimImageData::setMaxPix(), ossimImageData::setMinPix(), ossimImageData::setNullPix(), ossimNitfTileSource::theCacheTile, ossimNitfTileSource::theTile, and ossimRefPtr< T >::valid().
protectedvirtual |
If compression code is not "C8" calls base canUncompress as you could have a J2k entry and a jpeg entry.
Overrides ossimNitfTileSource::canUncompress
hdr | Pointer to image header. |
Definition at line 815 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::canUncompress(), and ossimNitfImageHeader::getCompressionCode().
private |
Note the stream is repositioned to start of data after the check so that the jp2 open code does not have to reposition.
Definition at line 973 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::getCurrentImageHeader(), ossimNitfImageHeader::getDataLocation(), SIGNATURE_BOX_SIZE, and ossimNitfTileSource::theFileStr.
Referenced by scanForJpegBlockOffsets().
private |
Definition at line 1010 of file ossimKakaduNitfReader.cpp.
References m_channels, m_codestream, m_jp2Source, and ossimNitfTileSource::theNumberOfOutputBands.
private |
For debug only.
Definition at line 1050 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::getCurrentImageHeader(), ossimNitfImageHeader::getNumberOfBlocksPerCol(), ossimNitfImageHeader::getNumberOfBlocksPerRow(), m_startOfCodestreamOffset, ossimJ2kSizRecord::parseStream(), ossimJ2kSotRecord::parseStream(), ossimJ2kTlmRecord::parseStream(), ossimJ2kCodRecord::parseStream(), ossimJ2kCodRecord::print(), ossimJ2kSotRecord::print(), ossimJ2kSizRecord::print(), ossimJ2kTlmRecord::print(), ossimNitfTileSource::theFileStr, and ossimJ2kSotRecord::thePsot.
inlineprotectedvirtual |
Overrides kdu_compressed_source::get_capabilities
Definition at line 369 of file ossimKakaduNitfReader.h.
Overrides kdu_compressed_source::get_pos
Definition at line 395 of file ossimKakaduNitfReader.h.
References m_startOfCodestreamOffset, and ossimNitfTileSource::theFileStr.
Returns long name.
Definition at line 157 of file ossimKakaduNitfReader.cpp.
Definition at line 351 of file ossimKakaduNitfReader.cpp.
References ossimImageHandler::getMaxPixelValue(), ossim::isnan(), and m_maxSampleValue.
Definition at line 342 of file ossimKakaduNitfReader.cpp.
References ossimImageHandler::getMinPixelValue(), ossim::isnan(), and m_minSampleValue.
Definition at line 360 of file ossimKakaduNitfReader.cpp.
References ossimImageHandler::getNullPixelValue(), ossim::isnan(), and m_nullSampleValue.
This returns the total number of decimation levels. It is important to note that res level 0 or full resolution is included in the list and has decimation values 1.0, 1.0
Definition at line 162 of file ossimKakaduNitfReader.cpp.
References ossimImageHandler::getNumberOfDecimationLevels(), isEntryJ2k(), m_minDwtLevels, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Overrides ossimNitfTileSource::getNumberOfLines
resLevel | Reduced resolution level to return lines of. Default = 0 |
Definition at line 187 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::getNumberOfLines(), ossimImageHandler::getNumberOfLines(), isEntryJ2k(), ossimImageHandler::isValidRLevel(), m_imageDims, m_minDwtLevels, ossimImageHandler::theOverview, ossimImageHandler::theStartingResLevel, and ossimRefPtr< T >::valid().
Overrides ossimNitfTileSource::getNumberOfSamples
resLevel | Reduced resolution level to return samples of. Default = 0 |
Definition at line 224 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::getNumberOfSamples(), ossimImageHandler::getNumberOfSamples(), isEntryJ2k(), ossimImageHandler::isValidRLevel(), m_imageDims, m_minDwtLevels, ossimImageHandler::theOverview, ossimImageHandler::theStartingResLevel, and ossimRefPtr< T >::valid().
protectedvirtual |
Overrides ossimImageHandler::getOverviewTile
resLevel | The resolution level to pull from with resLevel 0 being full res. |
result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. This method will subtract the subImageOffset if needed for external overview call since they do not know about the sub image offset. |
Definition at line 369 of file ossimKakaduNitfReader.cpp.
References ossim::copyRegionToTile(), ossimImageData::getImageRectangle(), ossimImageData::getNumberOfBands(), ossimNitfTileSource::getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossimImageSource::getTile(), isEntryJ2k(), ossimImageHandler::isValidRLevel(), m_channels, m_codestream, m_minDwtLevels, m_openTileThreadQueue, m_threadEnv, ossimNotify(), ossimNotifyLevel_WARN, status, ossimImageHandler::theOverview, ossimImageHandler::theStartingResLevel, ossimRefPtr< T >::valid(), and ossimException::what().
Referenced by loadBlock().
Returns short name.
Definition at line 152 of file ossimKakaduNitfReader.cpp.
protectedvirtual |
Overrides ossimNitfTileSource::initializeCacheTileInterLeaveType
Definition at line 946 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::initializeCacheTileInterLeaveType(), isEntryJ2k(), OSSIM_BSQ, and ossimNitfTileSource::theCacheTileInterLeaveType.
protectedvirtual |
Overrides ossimNitfTileSource::initializeReadMode
Definition at line 832 of file ossimKakaduNitfReader.cpp.
References ossimNitfImageHeader::getCompressionCode(), ossimNitfTileSource::getCurrentImageHeader(), ossimNitfImageHeader::getIMode(), ossimNitfTileSource::initializeReadMode(), ossimNitfTileSource::READ_JPEG_BLOCK, ossimNitfTileSource::READ_MODE_UNKNOWN, and ossimNitfTileSource::theReadMode.
protectedvirtual |
Overrides ossimNitfTileSource::initializeSwapBytesFlag
Definition at line 933 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::initializeSwapBytesFlag(), isEntryJ2k(), and ossimNitfTileSource::theSwapBytesFlag.
private |
Definition at line 959 of file ossimKakaduNitfReader.cpp.
References ossimNitfImageHeader::getCompressionCode(), and ossimNitfTileSource::getCurrentImageHeader().
Referenced by getNumberOfDecimationLevels(), getNumberOfLines(), getNumberOfSamples(), getOverviewTile(), initializeCacheTileInterLeaveType(), initializeSwapBytesFlag(), and loadBlock().
protectedvirtual |
x | Starting x position of block to load. |
y | Starting y position of block to load. |
Definition at line 450 of file ossimKakaduNitfReader.cpp.
References ossimAppFixedTileCache::addTile(), ossimRefPtr< T >::get(), getOverviewTile(), ossimAppFixedTileCache::instance(), isEntryJ2k(), ossimNitfTileSource::loadBlock(), ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), ossimNitfTileSource::theCacheId, ossimNitfTileSource::theCacheSize, ossimNitfTileSource::theCacheTile, ossimIpt::x, x, ossimIpt::y, and y.
protectedvirtual |
Overrides ossimNitfTileSource::parseFile
Definition at line 488 of file ossimKakaduNitfReader.cpp.
Read method.
Implements pure virtual kdu_compressed_source::read
buf | Buffer to fill. |
num_bytes | Bytes to read. |
Definition at line 374 of file ossimKakaduNitfReader.h.
References ossimNitfTileSource::theFileStr.
protectedvirtual |
Overrides ossimNitfTileSource::scanForJpegBlockOffsets
Definition at line 852 of file ossimKakaduNitfReader.cpp.
References checkJp2Signature(), ossimNitfTileSource::getCurrentImageHeader(), ossimNitfImageHeader::getDataLocation(), m_startOfCodestreamOffset, and ossimNitfTileSource::theFileStr.
Seek method.
Overrides kdu_compressed_source::seek
offset | Seek position relative to the start of code stream offset. |
Definition at line 380 of file ossimKakaduNitfReader.h.
Added for overview readers so that the image handler that owns the overview reader can pass on it's max value.
band | Zero based band to set. |
pix | Max pixel value. |
Definition at line 280 of file ossimKakaduNitfReader.cpp.
References m_maxSampleValue, ossimImageData::setMaxPix(), ossimImageHandler::setMaxPixelValue(), ossimNitfTileSource::theCacheTile, ossimNitfTileSource::theTile, and ossimRefPtr< T >::valid().
Added for overview readers so that the image handler that owns the overview reader can pass on it's min value.
pix | Min pixel value. |
Definition at line 261 of file ossimKakaduNitfReader.cpp.
References m_minSampleValue, ossimImageData::setMinPix(), ossimImageHandler::setMinPixelValue(), ossimNitfTileSource::theCacheTile, ossimNitfTileSource::theTile, and ossimRefPtr< T >::valid().
pix | Null pixel value. |
Definition at line 299 of file ossimKakaduNitfReader.cpp.
References ossimImageData::getNullPix(), m_nullSampleValue, ossimImageData::makeBlank(), OSSIM_STATUS_UNKNOWN, ossimDataObject::setDataObjectStatus(), ossimImageData::setNullPix(), ossimImageHandler::setNullPixelValue(), ossimNitfTileSource::theCacheTile, ossimNitfTileSource::theTile, and ossimRefPtr< T >::valid().
private |
Definition at line 345 of file ossimKakaduNitfReader.h.
Referenced by configureChannelMapping(), getOverviewTile(), and ~ossimKakaduNitfReader().
private |
Definition at line 346 of file ossimKakaduNitfReader.h.
private |
Definition at line 354 of file ossimKakaduNitfReader.h.
Referenced by getNumberOfLines(), and getNumberOfSamples().
private |
Definition at line 343 of file ossimKakaduNitfReader.h.
Referenced by ~ossimKakaduNitfReader().
private |
Definition at line 344 of file ossimKakaduNitfReader.h.
Referenced by configureChannelMapping(), and ~ossimKakaduNitfReader().
private |
Definition at line 363 of file ossimKakaduNitfReader.h.
Referenced by allocateBuffers(), getMaxPixelValue(), and setMaxPixelValue().
private |
Definition at line 351 of file ossimKakaduNitfReader.h.
Referenced by getNumberOfDecimationLevels(), getNumberOfLines(), getNumberOfSamples(), and getOverviewTile().
private |
For non eight bit data this is critical so that the data gets stretched exactly as the base handler. Did NOT make these a vector the size of bands as it was not needed at time of coding.
Definition at line 362 of file ossimKakaduNitfReader.h.
Referenced by allocateBuffers(), getMinPixelValue(), and setMinPixelValue().
private |
Definition at line 364 of file ossimKakaduNitfReader.h.
Referenced by allocateBuffers(), getNullPixelValue(), and setNullPixelValue().
private |
Definition at line 348 of file ossimKakaduNitfReader.h.
Referenced by getOverviewTile(), and ~ossimKakaduNitfReader().
private |
Definition at line 350 of file ossimKakaduNitfReader.h.
private |
Definition at line 341 of file ossimKakaduNitfReader.h.
Referenced by dumpTiles(), get_pos(), scanForJpegBlockOffsets(), and seek().
private |
Definition at line 347 of file ossimKakaduNitfReader.h.
