#include <ossimScaleFilter.h>
Public Types | |
enum | ossimScaleFilterType { ossimScaleFilter_NEAREST_NEIGHBOR = 0, ossimScaleFilter_BOX = 1, ossimScaleFilter_GAUSSIAN = 2, ossimScaleFilter_CUBIC = 3, ossimScaleFilter_HANNING = 4, ossimScaleFilter_HAMMING = 5, ossimScaleFilter_LANCZOS = 6, ossimScaleFilter_MITCHELL = 7, ossimScaleFilter_CATROM = 8, ossimScaleFilter_BLACKMAN = 9, ossimScaleFilter_BLACKMAN_SINC = 10, ossimScaleFilter_BLACKMAN_BESSEL = 11, ossimScaleFilter_QUADRATIC = 12, ossimScaleFilter_TRIANGLE = 13, ossimScaleFilter_HERMITE = 14 } |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
ossimScaleFilter () | |
ossimScaleFilter (ossimImageSource *inputSource, const ossimDpt &scaleFactor) | |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
virtual ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
This will return the bounding rect of the source. More... | |
virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
Returns the image geometry object associated with this tile source or NULL if not defined. More... | |
virtual void | initialize () |
virtual void | getDecimationFactor (ossim_uint32 resLevel, ossimDpt &result) const |
Will return the decimation factor for the given resolution level. More... | |
virtual void | getDecimationFactors (vector< ossimDpt > &decimations) const |
virtual ossim_uint32 | getNumberOfDecimationLevels () const |
Will return the number of resolution levels. More... | |
void | setFilterType (ossimScaleFilterType filterType) |
void | setFilterType (ossimScaleFilterType minifyFilterType, ossimScaleFilterType magnifyFilterType) |
void | setFilterType (const ossimString &minifyType, const ossimString &magnifyType) |
void | setMinifyFilterType (const ossimString &minifyType) |
void | setMagnifyFilterType (const ossimString &magnifyType) |
void | setMinifyFilterType (ossimScaleFilterType filterType) |
void | setMagnifyFilterType (ossimScaleFilterType filterType) |
ossimString | getMinifyFilterTypeAsString () const |
ossimString | getMagnifyFilterTypeAsString () const |
void | setScaleFactor (const ossimDpt &scale) |
void | setBlurFactor (ossim_float64 blur) |
ossim_float64 | getBlurFactor () const |
const ossimDpt & | getScaleFactor () const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
ossimImageSourceFilter (ossimObject *owner=NULL) | |
ossimImageSourceFilter (ossimImageSource *inputSource) | |
ossimImageSourceFilter (ossimObject *owner, ossimImageSource *inputSource) | |
virtual void | getOutputBandList (std::vector< ossim_uint32 > &bandList) const |
virtual ossim_uint32 | getNumberOfInputBands () const |
bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
required to be overriden by derived classes More... | |
virtual void | connectInputEvent (ossimConnectionEvent &event) |
virtual void | disconnectInputEvent (ossimConnectionEvent &event) |
virtual void | propertyEvent (ossimPropertyEvent &event) |
virtual void | refreshEvent (ossimRefreshEvent &event) |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
ossimImageSource (ossimObject *owner=0) | |
ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimImageSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIpt &origin, ossim_uint32 resLevel=0) |
virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel=0) |
Method to get a tile. More... | |
virtual ossimObject * | getObject () |
For RTTI support. More... | |
virtual const ossimObject * | getObject () const |
virtual void | getDecimationFactors (std::vector< ossimDpt > &decimations) const |
Will return an array of all decimations for each resolution level. More... | |
virtual ossim_uint32 | getNumberOfOutputBands () const |
Returns the number of bands in a tile returned from this TileSource. More... | |
virtual ossimScalarType | getOutputScalarType () const |
This will be used to query the output pixel type of the tile source. More... | |
virtual ossim_uint32 | getTileWidth () const |
Returns the default processing tile width. More... | |
virtual ossim_uint32 | getTileHeight () const |
Returns the default processing tile height. More... | |
virtual double | getNullPixelValue (ossim_uint32 band=0) const |
Each band has a null pixel associated with it. More... | |
virtual double | getMinPixelValue (ossim_uint32 band=0) const |
Returns the min pixel of the band. More... | |
virtual double | getMaxPixelValue (ossim_uint32 band=0) const |
Returns the max pixel of the band. More... | |
virtual void | getBoundingRect (ossimIrect &rect, ossim_uint32 resLevel=0) const |
Gets the bounding rectangle of the source. More... | |
virtual void | getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
ordering specifies how the vertices should be arranged. More... | |
virtual void | setImageGeometry (const ossimImageGeometry *geom) |
Default implementation sets geometry of the first input to the geometry specified. More... | |
virtual void | saveImageGeometry () const |
Default method to call input's saveImageGeometry. More... | |
virtual void | saveImageGeometry (const ossimFilename &geometry_file) const |
virtual bool | isIndexedData () const |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
ossimConnectableObjectListener () | |
virtual | ~ossimConnectableObjectListener () |
virtual void | processEvent (ossimEvent &event) |
ProcessEvent. More... | |
virtual void | objectDestructingEvent (ossimObjectDestructingEvent &) |
virtual void | connectionEvent (ossimConnectionEvent &) |
virtual void | disconnectOutputEvent (ossimConnectionEvent &) |
virtual void | connectOutputEvent (ossimConnectionEvent &) |
virtual void | addObjectEvent (ossimContainerEvent &) |
virtual void | removeObjectEvent (ossimContainerEvent &) |
virtual void | containerEvent (ossimContainerEvent &) |
ossimListener () | |
virtual | ~ossimListener () |
void | enableListener () |
void | disableListener () |
void | setListenerEnableFlag (bool flag) |
bool | isListenerEnabled () const |
bool | getListenerEnableFlag () const |
virtual | ~ossimScaleFilter () |
void | allocate () |
void | updateGeometry () |
If this object is maintaining an ossimImageGeometry, this method needs to be called after a scale change so that the geometry's projection is modified accordingly. More... | |
template<class T > | |
void | runFilterTemplate (T dummy, const ossimIrect &imageRect, const ossimIrect &viewRect) |
void | runHorizontalFilterTemplate (T dummy, const ossimRefPtr< ossimImageData > &input, ossimRefPtr< ossimImageData > &output) |
void | runVerticalFilterTemplate (T dummy, const ossimRefPtr< ossimImageData > &input, ossimRefPtr< ossimImageData > &output) |
void | runFilter (const ossimIrect &imageRect, const ossimIrect &viewRect) |
void | getSupport (double &x, double &y) |
const ossimFilter * | getHorizontalFilter () const |
const ossimFilter * | getVerticalFilter () const |
ossimString | getFilterTypeAsString (ossimScaleFilterType type) const |
ossimScaleFilterType | getFilterType (const ossimString &type) const |
ossimIrect | scaleRect (const ossimIrect input, const ossimDpt &scaleFactor) const |
ossimFilter * | createNewFilter (ossimScaleFilterType filterType, ossimScaleFilterType &result) |
virtual | ~ossimImageSourceFilter () |
ossimImageSource (const ossimImageSource &rhs) | |
const ossimImageSource & | operator= (const ossimImageSource &) |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
Definition at line 22 of file ossimScaleFilter.h.
Definition at line 25 of file ossimScaleFilter.h.
ossimScaleFilter::ossimScaleFilter | ( | ) |
Definition at line 24 of file ossimScaleFilter.cpp.
References m_InputRect, m_MagnifyFilter, m_MinifyFilter, and ossimIrect::makeNan().
ossimScaleFilter::ossimScaleFilter | ( | ossimImageSource * | inputSource, |
const ossimDpt & | scaleFactor | ||
Definition at line 43 of file ossimScaleFilter.cpp.
protectedvirtual |
protected |
Definition at line 639 of file ossimScaleFilter.cpp.
References ossimImageDataFactory::create(), ossimImageSource::getBoundingRect(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimSource::isSourceEnabled(), m_BlankTile, m_InputRect, m_Tile, ossimIrect::makeNan(), and ossimImageSourceFilter::theInputConnection.
Referenced by getTile().
protected |
Definition at line 290 of file ossimScaleFilter.cpp.
References ossimScaleFilter_BLACKMAN, ossimScaleFilter_BLACKMAN_BESSEL, ossimScaleFilter_BLACKMAN_SINC, ossimScaleFilter_BOX, ossimScaleFilter_CATROM, ossimScaleFilter_CUBIC, ossimScaleFilter_GAUSSIAN, ossimScaleFilter_HAMMING, ossimScaleFilter_HANNING, ossimScaleFilter_HERMITE, ossimScaleFilter_LANCZOS, ossimScaleFilter_MITCHELL, ossimScaleFilter_NEAREST_NEIGHBOR, ossimScaleFilter_QUADRATIC, and ossimScaleFilter_TRIANGLE.
Referenced by setFilterType().
inline |
Definition at line 116 of file ossimScaleFilter.h.
We can have several sources which are in a chain to modify the bounding image rect. lets say you are next to an image handler then it will return the bounding rect for that image. If you are at the right side of a resampler then you will get a bounding rect along the image view plane. This is going to be a very import method for both image writers, mosaics or anything that needs to operate only within the bounds of an image.
Definition at line 248 of file ossimScaleFilter.cpp.
References ossimImageSource::getBoundingRect(), ossimIrect::hasNans(), and m_ScaleFactor.
inlinevirtual |
the decimation is the scale from Resolution 0 or full res. Usually this is a power of 2 decimation where the decimation result is 1.0/2^resoltion.
Definition at line 55 of file ossimScaleFilter.h.
References ossimDpt::makeNan(), ossimDpt::x, and ossimDpt::y.
inlinevirtual |
Definition at line 66 of file ossimScaleFilter.h.
protected |
Definition at line 779 of file ossimScaleFilter.cpp.
References ossimString::contains(), ossimScaleFilter_BLACKMAN, ossimScaleFilter_BLACKMAN_BESSEL, ossimScaleFilter_BLACKMAN_SINC, ossimScaleFilter_BOX, ossimScaleFilter_CATROM, ossimScaleFilter_CUBIC, ossimScaleFilter_GAUSSIAN, ossimScaleFilter_HAMMING, ossimScaleFilter_HANNING, ossimScaleFilter_HERMITE, ossimScaleFilter_LANCZOS, ossimScaleFilter_MITCHELL, ossimScaleFilter_NEAREST_NEIGHBOR, ossimScaleFilter_QUADRATIC, ossimScaleFilter_TRIANGLE, and ossimString::upcase().
Referenced by loadState().
protected |
Definition at line 709 of file ossimScaleFilter.cpp.
Referenced by saveState().
protected |
Definition at line 861 of file ossimScaleFilter.cpp.
References m_MagnifyFilter, m_MinifyFilter, m_ScaleFactor, and ossimDpt::x.
Referenced by getSupport(), and runHorizontalFilterTemplate().
The geometry contains full-to-local image transform as well as projection (image-to-world). Default implementation returns the image geometry object associated with the next
(left) input source (if any) connected to this source in the chain, or NULL.
Definition at line 660 of file ossimScaleFilter.cpp.
References ossimImageSource::getImageGeometry(), m_ScaledGeometry, m_ScaleFactor, ossimImageSourceFilter::theInputConnection, updateGeometry(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
inline |
Definition at line 107 of file ossimScaleFilter.h.
inline |
Definition at line 103 of file ossimScaleFilter.h.
inlinevirtual |
Note: resolution level 0 is included in the return count.
Definition at line 70 of file ossimScaleFilter.h.
inline |
Definition at line 120 of file ossimScaleFilter.h.
protected |
Definition at line 849 of file ossimScaleFilter.cpp.
References getHorizontalFilter(), ossimFilter::getSupport(), getVerticalFilter(), m_BlurFactor, m_ScaleFactor, ossim::max(), ossimDpt::x, x, ossimDpt::y, and y.
Definition at line 78 of file ossimScaleFilter.cpp.
References allocate(), getSupport(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), ossimIrect::lr(), m_BlankTile, m_BlurFactor, m_InverseScaleFactor, m_ScaleFactor, m_Tile, ossimImageData::makeBlank(), runFilter(), ossimImageData::setImageRectangle(), ossimImageSourceFilter::theInputConnection, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
protected |
Definition at line 872 of file ossimScaleFilter.cpp.
References m_MagnifyFilter, m_MinifyFilter, m_ScaleFactor, and ossimDpt::y.
Referenced by getSupport(), and runVerticalFilterTemplate().
Definition at line 628 of file ossimScaleFilter.cpp.
References ossimImageSourceFilter::initialize(), m_BlankTile, m_InputRect, m_Tile, and ossimIrect::makeNan().
Loads the state of this object.
Definition at line 908 of file ossimScaleFilter.cpp.
References ossimKeywordlist::find(), FLT_EPSILON, getFilterType(), ossimImageSourceFilter::loadState(), m_InverseScaleFactor, m_ScaleFactor, ossimKeywordNames::SCALE_X_KW, ossimKeywordNames::SCALE_Y_KW, setFilterType(), ossimString::toDouble(), updateGeometry(), ossimDpt::x, and ossimDpt::y.
protected |
Definition at line 132 of file ossimScaleFilter.cpp.
References ossimRectilinearDataObject::getScalarType(), m_Tile, OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SINT16, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, and runFilterTemplate().
protected |
Definition at line 193 of file ossimScaleFilter.cpp.
References ossimImageDataFactory::create(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getNumberOfBands(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimIrect::height(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimImageData::loadTile(), m_BlurFactor, m_ScaleFactor, m_Tile, OSSIM_EMPTY, runHorizontalFilterTemplate(), runVerticalFilterTemplate(), ossimImageData::setOrigin(), ossimImageSourceFilter::theInputConnection, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIrect::width(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Referenced by runFilter().
protected |
Definition at line 385 of file ossimScaleFilter.cpp.
References ossimFilter::filter(), FLT_EPSILON, ossimImageData::getBuf(), getHorizontalFilter(), ossimImageData::getImageRectangle(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimFilter::getSupport(), ossimIrect::height(), ossimIrect::lr(), m_BlurFactor, m_InputRect, m_ScaleFactor, m_Tile, ossim::max(), ossim::min(), ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, ossimDpt::x, x, and y.
Referenced by runFilterTemplate().
protected |
Definition at line 508 of file ossimScaleFilter.cpp.
References ossimFilter::filter(), FLT_EPSILON, ossimImageData::getBuf(), ossimImageData::getImageRectangle(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimFilter::getSupport(), getVerticalFilter(), ossimIrect::height(), ossimIrect::lr(), m_BlurFactor, m_InputRect, m_ScaleFactor, m_Tile, ossim::max(), ossim::min(), ossimIrect::ul(), ossimIrect::width(), x, ossimIpt::y, ossimDpt::y, and y.
Saves the state of this object.
Definition at line 885 of file ossimScaleFilter.cpp.
References ossimKeywordlist::add(), getFilterTypeAsString(), m_MagnifyFilterType, m_MinifyFilterType, m_ScaleFactor, ossimImageSourceFilter::saveState(), ossimKeywordNames::SCALE_X_KW, ossimKeywordNames::SCALE_Y_KW, ossimDpt::x, and ossimDpt::y.
protected |
Definition at line 691 of file ossimScaleFilter.cpp.
References ossimIrect::height(), ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
inline |
Definition at line 112 of file ossimScaleFilter.h.
void ossimScaleFilter::setFilterType | ( | ossimScaleFilterType | filterType | ) |
Definition at line 261 of file ossimScaleFilter.cpp.
void ossimScaleFilter::setFilterType | ( | ossimScaleFilterType | minifyFilterType, |
ossimScaleFilterType | magnifyFilterType | ||
Definition at line 268 of file ossimScaleFilter.cpp.
References createNewFilter(), m_MagnifyFilter, m_MagnifyFilterType, m_MinifyFilter, and m_MinifyFilterType.
inline |
Definition at line 80 of file ossimScaleFilter.h.
inline |
Definition at line 90 of file ossimScaleFilter.h.
inline |
Definition at line 99 of file ossimScaleFilter.h.
inline |
Definition at line 86 of file ossimScaleFilter.h.
inline |
Definition at line 94 of file ossimScaleFilter.h.
void ossimScaleFilter::setScaleFactor | ( | const ossimDpt & | scale | ) |
Definition at line 363 of file ossimScaleFilter.cpp.
References FLT_EPSILON, m_InverseScaleFactor, m_ScaleFactor, updateGeometry(), ossimDpt::x, and ossimDpt::y.
protected |
Definition at line 949 of file ossimScaleFilter.cpp.
References ossimMapProjection::applyScale(), ossimImageGeometry::getProjection(), m_InverseScaleFactor, m_ScaledGeometry, PTR_CAST, and ossimRefPtr< T >::valid().
Referenced by getImageGeometry(), loadState(), and setScaleFactor().
protected |
Definition at line 142 of file ossimScaleFilter.h.
Referenced by allocate(), getTile(), and initialize().
protected |
Definition at line 152 of file ossimScaleFilter.h.
Referenced by getSupport(), getTile(), runFilterTemplate(), runHorizontalFilterTemplate(), and runVerticalFilterTemplate().
protected |
Definition at line 151 of file ossimScaleFilter.h.
Referenced by allocate(), initialize(), ossimScaleFilter(), runHorizontalFilterTemplate(), and runVerticalFilterTemplate().
protected |
Definition at line 149 of file ossimScaleFilter.h.
Referenced by getTile(), loadState(), setScaleFactor(), and updateGeometry().
protected |
Definition at line 145 of file ossimScaleFilter.h.
Referenced by getHorizontalFilter(), getVerticalFilter(), ossimScaleFilter(), setFilterType(), and ~ossimScaleFilter().
protected |
Definition at line 147 of file ossimScaleFilter.h.
Referenced by saveState(), and setFilterType().
protected |
Definition at line 144 of file ossimScaleFilter.h.
protected |
Definition at line 146 of file ossimScaleFilter.h.
protected |
The input image geometry, altered by the scale.
Definition at line 153 of file ossimScaleFilter.h.
Referenced by getImageGeometry(), and updateGeometry().
protected |
Definition at line 148 of file ossimScaleFilter.h.
Referenced by getBoundingRect(), getHorizontalFilter(), getImageGeometry(), getSupport(), getTile(), getVerticalFilter(), loadState(), runFilterTemplate(), runHorizontalFilterTemplate(), runVerticalFilterTemplate(), saveState(), and setScaleFactor().
protected |
Definition at line 143 of file ossimScaleFilter.h.
Referenced by allocate(), getTile(), initialize(), runFilter(), runFilterTemplate(), runHorizontalFilterTemplate(), and runVerticalFilterTemplate().
protected |
Definition at line 150 of file ossimScaleFilter.h.
