ossimLandsatTileSource.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: Garrett Potts
6 //
7 // Description:
8 //
9 // Contains class implementaiton for the class "ossim LandsatTileSource".
10 //
11 //*******************************************************************
12 // $Id: ossimLandsatTileSource.cpp 21512 2012-08-22 11:53:57Z dburken $
13
16 #include <ossim/base/ossimTrace.h>
25
27  "ossimLandsatTileSource",
29
30 static ossimTrace traceDebug("ossimLandsatTileSource:debug");
31
32
33 //*******************************************************************
34 // Public Constructor:
35 //*******************************************************************
37  :
39  theFfHdr(NULL)
40 {
41 }
42
43 //*******************************************************************
44 // Public Constructor:
45 //*******************************************************************
47  const char* prefix)
48  :
50  theFfHdr(NULL)
51 {
52  if (loadState(kwl, prefix) == false)
53  {
55  }
56 }
57
58 //*******************************************************************
59 // Destructor:
60 //*******************************************************************
62 {
63  theFfHdr = NULL;
64 }
65
67 {
68  static const char MODULE[] = "ossimLandsatTileSource::open";
69
70  if (traceDebug())
71  {
72  CLOG << " Entered..." << std::endl
73  << " trying to open file " << theImageFile << std::endl;
74  }
75
76  ossimFilename tempFilename = theImageFile;
77  // See if the file passed in is a header file.
78
80
81  if (!theFfHdr) return false;
82
83  // Start building the keyword list for the general raster base class.
84  ossimKeywordlist kwl;
85
86  //***
87  // There can be up to seven (six for L7) files that belong to the header.
88  // Note that it seems the file names in the header are always upper case.
89  // So test the file given to us to see if they should be downcased. This
90  // is assuming that all files in the directory have the same case.
91  //***
92  vector<ossimFilename> fileList;
93
94  for (ossim_uint32 i=0; i<theFfHdr->getBandCount(); ++i)
95  {
96  bool addFile = false;
98  if (f1.trim() != "")
99  {
100  // Make the file name.
102  f2 = f2.dirCat(f1);
103
104  if (f2.exists())
105  {
106  addFile = true;
107  }
108  else
109  {
110  // Try it downcased...
111  f2 = theImageFile.path();
112  f1.downcase();
113  f2 = f2.dirCat(f1);
114  if (f2.exists())
115  {
116  addFile = true;
117  }
118  else
119  {
120  // Try is upcased...
121  f2 = theImageFile.path();
122  f1.upcase();
123  f2 = f2.dirCat(f1);
124  if (f2.exists())
125  {
126  addFile = true;
127  }
128  }
129  }
130
131  if (addFile)
132  {
133  if (traceDebug())
134  {
135  CLOG << "\nAdding file: " << f2 << std::endl;
136  }
137  fileList.push_back(f2);
138  }
139  else
140  {
141  if (traceDebug())
142  {
143  f2 = theImageFile.path();
144  f1 = theFfHdr->getBandFilename(i);
145  f1.trim();
146  f2 = f2.dirCat(f1);
147  CLOG << "\nCould not find: " << f2 << std::endl;
148  }
149  }
150  }
151  }
152
153  if(fileList.size() == 0)
154  {
155  close();
156  return false;
157  }
158
159  ossimGeneralRasterInfo generalRasterInfo(fileList,
160  OSSIM_UINT8,
162  (ossim_uint32)fileList.size(),
165  0,
167  0);
168  if(fileList.size() == 1)
169  {
170  generalRasterInfo = ossimGeneralRasterInfo(fileList,
171  OSSIM_UINT8,
172  OSSIM_BSQ,
173  (ossim_uint32)fileList.size(),
176  0,
178  0);
179  }
180  theMetaData.clear();
182  theMetaData.setNumberOfBands((ossim_uint32)fileList.size());
183  m_rasterInfo = generalRasterInfo;
184  if(initializeHandler())
185  {
186  theImageFile = tempFilename;
187
188  completeOpen();
189  }
190  else
191  {
192  if (traceDebug()) CLOG << " Exited..." << std::endl;
193  return false;
194  }
195
196  if (traceDebug()) CLOG << " Exited..." << std::endl;
197
198  return true;
199 }
200
202 {
203  //***
204  // Landsat file name example: l71024031_03119990929_hpn.fst
205  // Three header header file type substrings:
206  // HPN = Pan
207  // HRF = VNIR/SWIR (visible near infrared/shortwave infrared)
208  // HTM = Thermal
209  //***
210  ossimFilename hdr = file.file();
211  hdr.downcase();
212  theFfHdr = 0;
213  if ( hdr.contains("hpn") || hdr.contains("hrf") || hdr.contains("htm") )
214  {
215  theFfHdr = new ossimFfL7(file.c_str());
216  }
217  else if (hdr.contains("header.dat"))
218  {
219  theFfHdr = new ossimFfL5(file.c_str());
220  }
221  else
222  {
223  theFfHdr = 0;
224  return;
225  }
227  {
228  theFfHdr = 0;
229  }
230  return;
231
232  // I had to force the open to go with a header since there are duplicate entries when scanning
233  // landsat directories.
234  // For now I am commenting this code out.
235  //
236 #if 0
237  //***
238  // User may have passed in an image file name in which case the header file
239  // must be derived from it.
240  //***
241  if (hdr.size() < 25)
242  {
243  // file name not long enough...
244  if (traceDebug())
245  {
247  << "ossimLandsatTileSource::openHeader DEBUG:"
248  << "\nNot a standard landsat 7 file name: " << hdr << std::endl;
249  return;
250  }
251  }
252
253  char substr[4];
254  const char* f = hdr.c_str();
255  strncpy(substr, (f+22), 3);
256  substr[3] = '\0';
257  ossimString s1 = substr;
258  ossimString s2;
259  s1.downcase();
260  if (s1 == "b80")
261  {
262  s2 = "hpn";
263  }
264  else if (s1 == "b61" || s1 == "b62")
265  {
266  s2 = "htm";
267  }
268  else if (s1 == "b10" || s1 == "b20" || s1 == "b30" ||
269  s1 == "b40" || s1 == "b50" || s1 == "b70")
270  {
271  s2 = "hrf";
272  }
273  else
274  {
275  // Not of any format we know of...
276  if (traceDebug())
277  {
279  << "ossimLandsatTileSource::openHeader DEBUG:"
280  << "\nCould not derive header name from: " << file
281  << std::endl;
282  }
283
284  return;
285  }
286
287  // Set the case to be the same as the file passed in.
288  if (substr[0] == 0x42) // ascii "B"
289  {
290  s1.upcase();
291  s2.upcase();
292  hdr.upcase();
293
294  // Header files alway start with "L71"
295  hdr = hdr.substitute(ossimString("L72"), ossimString("L71"));
296  }
297  else
298  {
299  // Header files alway start with "l71"
300  hdr = hdr.substitute(ossimString("l72"), ossimString("l71"));
301  }
302
303  // Make the hdr file name.
304  hdr = hdr.substitute(s1, s2);
305
306  ossimFilename f1 = file.drive();
307  f1 += file.path();
308  hdr = f1.dirCat(hdr);
309  theFfHdr = new ossimFfL7(hdr.c_str());
310
312  {
313  delete theFfHdr;
314  theFfHdr = NULL;
315  }
316 #endif
317 }
318
320 {
321  if ( !theGeometry )
322  {
323  // Check for external geom:
325
326  if ( !theGeometry )
327  {
329
330  if ( theFfHdr.valid() )
331  {
332  // Make a model
335  {
336  //initialize the image geometry object with the model
337  theGeometry->setProjection(model);
338  }
339  }
340
341  //---
342  // WARNING:
343  // Must create/set the geometry at this point or the next call to
344  // ossimImageGeometryRegistry::extendGeometry will put us in an infinite loop
345  // as it does a recursive call back to ossimImageHandler::getImageGeometry().
346  //---
347
348  // Check for set projection.
349  if ( !theGeometry->getProjection() )
350  {
351  // Try factories for projection.
353  }
354  }
355
356  // Set image things the geometry object should know about.
358  }
359
360  return theGeometry;
361 }
362
364  const char* prefix)
365 {
366  const char* lookup = kwl.find(prefix, ossimKeywordNames::FILENAME_KW);
367  if (lookup)
368  {
369  ossimFilename fileName = lookup;
370
371  ossimString ext = fileName.ext();
372
373  if((ext.upcase() == "FST") || (ext.upcase() == "DAT"))
374  {
375  //---
376  // This will call:
377  // ossimImageHandler::loadState() the open()
378  //---
380  {
381  return true;
382  }
383  }
384  }
385  return false;
386 }
387
389  const ossimString& name)const
390 {
391  ossimRefPtr<ossimProperty> result = 0;
392
393  if(name == "file_type")
394  {
395  if(ossimString(getFilename()).downcase().contains("header"))
396  {
397  return (new ossimStringProperty(name, "landsat5"));
398  }
399  else
400  {
401  return (new ossimStringProperty(name, "landsat7"));
402  }
403  }
404  else if (theFfHdr.valid())
405  {
406  result = theFfHdr->getProperty(name);
407  }
408
409  if ( result.valid() == false )
410  {
412  }
413
414  return result;
415 }
416
418  std::vector<ossimString>& propertyNames)const
419 {
420  propertyNames.push_back("file_type");
421  if (theFfHdr.valid())
422  {
423  theFfHdr->getPropertyNames(propertyNames);
424  }
426 }
427
429 {
430  return ossimString("Landsat");
431 }
432
434 {
435  return ossimString("Landsat reader");
436 }
437
439 {
440  return 0.0;
441 }
442
444 {
445  return 1.0;
446 }
447
449 {
450  return 255.0;
451 }
452
454 {
455  return OSSIM_UINT8;
456 }
457
459 {
460  if(!theFfHdr) return false;
461
463
464  return true;
465 }
466
468 {
469  if(!theFfHdr) return "";
470
471  return theFfHdr->getSatelliteName();
472 }
473
475 {
477
478  if(!theFfHdr||(idx > maxIdx))
479  {
480  return "";
481  }
482
483  ossimFilename path = getFilename().path();
484  ossimString filename = theFfHdr->getBandFilename(idx);
485  filename = filename.trim();
486  ossimFilename file = path.dirCat(filename);
487
488  if (file.exists())
489  {
490  return file;
491  }
492
493  // Try downcased name.
494  file = path.dirCat(filename.downcase());
495  if (file.exists())
496  {
497  return file;
498  }
499
500  // Try upcase name.
501  file = path.dirCat(filename.upcase());
502  if (file.exists())
503  {
504  return file;
505  }
506
507  return ossimFilename();
508 }
509
511 {
512  return (getNumberOfInputBands() == 1);
513 }
514
516 {
517  return (getNumberOfInputBands() == 6);
518 }
519
521 {
522  return (getNumberOfInputBands() == 2);
523 }
524
void setScalarType(ossimScalarType aType)
static ossimImageGeometryRegistry * instance()
ossimRefPtr< ossimImageGeometry > theGeometry
ossimString substitute(const ossimString &searchKey, const ossimString &replacementValue, bool replaceAll=false) const
Substitutes searchKey string with replacementValue and returns a string.
int getLinesPerBand() const
Definition: ossimFfL7.cpp:616
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
#define CLOG
Definition: ossimTrace.h:23
ossimFilename theImageFile
virtual bool open()
Pure virtual open.
static const ossimErrorCode OSSIM_OK
bool valid() const
Definition: ossimRefPtr.h:75
virtual unsigned int getBandCount() const
Definition: ossimFfL7.cpp:690
Gets a property for matching name.
Definition: ossimFfL7.cpp:636
int getPixelsPerLine() const
Definition: ossimFfL7.cpp:621
bool contains(char aChar) const
Definition: ossimString.h:58
ossimString getSatelliteName() const
Definition: ossimFfL7.cpp:601
static const ossimErrorCode OSSIM_ERROR
virtual ossimString getShortName() const
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
Override base getXXXXPixValue methods since the null/min/max can be set to something different...
virtual bool extendGeometry(ossimImageHandler *handler) const
ossimFilename getBandFilename(ossim_uint32 idx) const
Definition: ossimFfL7.cpp:606
Gets a list of property names available.
Definition: ossimFfL7.cpp:680
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
void setNumberOfBands(ossim_uint32 numberOfBands)
#define RTTI_DEF1_INST(cls, name, b1)
Definition: ossimRtti.h:481
bool exists() const
virtual const ossimFilename & getFilename() const
Returns the filename.
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
std::string::size_type size() const
Definition: ossimString.h:405
unsigned int ossim_uint32
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
ossimRefPtr< ossimFfL7 > theFfHdr
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
virtual void close()
ossimScalarType
bool getAcquisitionDate(ossimDate &date) const
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
virtual void completeOpen()
Will complete the opening process.
ossimImageMetaData theMetaData
virtual ossimErrorCode getErrorStatus() const
virtual ossimString getLongName() const
ossimFilename dirCat(const ossimFilename &file) const
const char * c_str() const
Definition: ossimString.h:396
ossimFilename file() const
ossimString getAcquisitionDate() const
Definition: ossimFfL7.cpp:582
ossimString ext() const
8 bit unsigned integer
Retuns the min pixel value.
static const char * FILENAME_KW
virtual ~ossimLandsatTileSource()
ossimFilename path() const
ossimFilename drive() const
void openHeader(const ossimFilename &file)
virtual ossim_uint32 getNumberOfInputBands() const
Returns the number of bands in the image.
