ossimReadmeFileWriter.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 // Copyright (C) 2003 Storage Area Networks, Inc.
3 //
4 // License: LGPL
5 //
6 // See LICENSE.txt file in the top level directory for more details.
7 //
8 // Author: Kenneth Melero (kmelero@sanz.com)
9 //
10 //*******************************************************************
11 // $Id: ossimReadmeFileWriter.cpp 21631 2012-09-06 18:10:55Z dburken $
12
15 #include <ossim/base/ossimTrace.h>
24 #include <iostream>
25 using namespace std;
26
28  "ossimReadmeFileWriter",
30
31 static const char DEFAULT_FILE_NAME[] = "output_readme.txt";
32 static ossimTrace traceDebug("ossimReadmeFileWriter:debug");
33
34 //**************************************************************************************************
35 //
36 //**************************************************************************************************
38 :
40 {
41 }
42
43 //**************************************************************************************************
44 //
45 //**************************************************************************************************
47 {
48 }
49
50 //**************************************************************************************************
51 //
52 //**************************************************************************************************
54 {
55  static const char MODULE[] = "ossimReadmeFileWriter::writeFile";
56
58  {
59  if (traceDebug())
60  {
61  CLOG << "DEBUG:"
62  << "\nNo input connection! Returning..."
63  << endl;
64  }
65
66  return false;
67  }
68
69  std::ofstream out(theFilename.c_str(), ios_base::out);
70  if (!out)
71  return false;
72
73  // Fetch the map projection of the input image if it exists:
74  const ossimMapProjection* mapProj = 0;
76  if ( imgGeom.valid() )
77  {
78  const ossimProjection* proj = imgGeom->getProjection();
79  mapProj = PTR_CAST(ossimMapProjection, proj);
80  }
81  if (!mapProj)
82  {
83  out.close();
84  return false;
85  }
86
87  ossimMapProjectionInfo* projectionInfo = new ossimMapProjectionInfo(mapProj, theAreaOfInterest);
88  if(projectionInfo)
89  {
90  out << setiosflags(ios::fixed)
91  << setiosflags(ios::left)
92  << setw(16) << "Image: "
93  << projectionInfo->getImageInfoString();
94
95  out << setw(17) << "\nLines:"
96  << projectionInfo->linesPerImage()
97  << setw(17) << "\nSamples:"
98  << projectionInfo->pixelsPerLine()
99  << setw(17) << "\nPixel Size x:"
100  << setprecision(8)
101  << projectionInfo->getMetersPerPixel().x
102  << " meters";
103
104  out << ", "
105  << setprecision(8)
106  << projectionInfo->getUsSurveyFeetPerPixel().x
107  << " U.S. feet";
108
109  out << setw(17) << "\nPixel Size y:"
110  << setprecision(8)
111  << projectionInfo->getMetersPerPixel().y
112  << " meters";
113
114  out << ", "
115  << setprecision(8)
116  << projectionInfo->getUsSurveyFeetPerPixel().y
117  << " U.S. feet";
118
119  const ossimString type = TYPE_NAME(mapProj);
120  const ossimString datum = mapProj->getDatum()->code();
121  const ossimString ellipsoid = mapProj->getEllipsoid().code();
122
123  if(type)
124  out << setw(17) << "\nProjection:" << type;
125
126  const ossimUtmProjection* utmProj = PTR_CAST(ossimUtmProjection, mapProj);
127  if (utmProj)
128  out << setw(17) << "\nUTM map zone:" << utmProj->getZone();
129
130  if(datum && ellipsoid)
131  out << setw(17) << "\nDatum:" << datum
132  << setw(17) << "\nEllipsoid:"
133  << ellipsoid;
134
135  out << resetiosflags(ios::left) << endl;
136
137  const ossimString NORTH = "N";
138  const ossimString SOUTH = "S";
139  const ossimString EAST = "E";
140  const ossimString WEST = "W";
141
142  ossimString tmpString;
143  double tmpDouble;
144
145  // HACK: Easiest way to get projection info for optional params is via the old keywordlist:
146  ossimKeywordlist kwl;
147  mapProj->saveState(kwl);
148  const char* parallel1 = kwl.find(ossimKeywordNames::STD_PARALLEL_1_KW);
149  const char* parallel2 = kwl.find(ossimKeywordNames::STD_PARALLEL_2_KW);
150  const char* scaleFactor = kwl.find(ossimKeywordNames::SCALE_FACTOR_KW);
151
152
153  ossimString proj_name = mapProj->getClassName();
154  if ( ( proj_name.contains("Lambert") ) ||
155  ( proj_name.contains("Albers") ) ||
156  ( proj_name.contains("TransverseMercator" ) ) )
157  {
158  double falseEasting = mapProj->getFalseEasting();
159  double falseNorthing = mapProj->getFalseNorthing();
160
161  double origin_lat = mapProj->origin().latd();
162  tmpDouble = fabs(origin_lat);
163  tmpString = (origin_lat < 0.0) ? SOUTH : NORTH;
164  out << setiosflags(ios::left)
165  << "\n"
166  << setw(18) << "Origin Latitude:"
167  << resetiosflags(ios::left)
168  << setw(21) << setprecision(12) << tmpDouble
169  << tmpString << endl;
170
171  double origin_lon = mapProj->origin().lond();
172  tmpDouble = fabs(origin_lon);
173  tmpString = (origin_lon < 0.0) ? WEST : EAST;
174  out << setiosflags(ios::left)
175  << setw(18) << "Origin Longitude:"
176  << resetiosflags(ios::left)
177  << setw(21) << tmpDouble << tmpString
178  << setiosflags(ios::left)
179  << "\n"
180  << setw(23) << "False Easting:"
181  << resetiosflags(ios::left)
182  << setw(17) << setprecision(4)
183  << falseEasting;
184
185  out << " meters, " << setprecision(4)
186  << ossim::mtrs2usft(falseEasting)
187  << " U.S. feet";
188
189  out << endl;
190
191  out << setiosflags(ios::left)
192  << setw(23) << "False Northing:"
193  << resetiosflags(ios::left)
194  << setw(17) << setprecision(4)
195  << falseNorthing;
196
197  out << " meters, " << setprecision(4)
198  << ossim::mtrs2usft(falseNorthing)
199  << " U.S. feet";
200
201  out << endl;
202
203  } // End of if "Alber Lambert or TM.
204
205  if (proj_name.contains("TransverseMercator"))
206  {
207
208  out << setiosflags(ios::left)
209  << "\n"
210  << setw(18) << "Scale Factor:"
211  << resetiosflags(ios::left)
212  << setw(21) << setprecision(10)
213  << ossimString(scaleFactor).toDouble()
214  << "\n" << endl;
215  }
216
217  if ( (proj_name.contains("Lambert") ) ||
218  (proj_name.contains("Albers") ) )
219  {
220  double stdpar1 = ossimString(parallel1).toDouble();
221  tmpDouble = fabs(stdpar1);
222  tmpString = (stdpar1 < 0.0) ? SOUTH : NORTH;
223  out << setiosflags(ios::left)
224  << setw(23) << "Standard Parallel #1:"
225  << resetiosflags(ios::left)
226  << setw(16) << setprecision(12) << tmpDouble
227  << tmpString << endl;
228
229  double stdpar2 = ossimString(parallel2).toDouble();
230  tmpDouble = fabs(stdpar2);
231  tmpString = (stdpar2 < 0.0) ? SOUTH : NORTH;
232  out << setiosflags(ios::left)
233  << setw(23) << "Standard Parallel #2:"
234  << resetiosflags(ios::left)
235  << setw(16) << setprecision(12)
236  << tmpDouble << tmpString
237  << "\n" << endl;
238  }
239
240  ossimString cornerString[4] = { "Upper Left",
241  "Upper Right",
242  "Lower Right",
243  "Lower Left" };
244
245  //---
246  // Add a note to the readme file stating what the corner coordinates
247  // are relative to.
248  //---
249  if (projectionInfo->getPixelType() == OSSIM_PIXEL_IS_AREA)
250  {
251  out
252  << "\nCorner coordinates relative to outer edge of pixel.\n\n";
253  }
254  else
255  {
256  out
257  << "\nCorner coordinates relative to center of pixel.\n\n";
258  }
259
260  out << "Corner Coordinates:\n\n";
261
262  //---
263  // Upper Left Corner Points
264  //---
265  tmpDouble = fabs(projectionInfo->ulGroundPt().latd());
266  tmpString = (projectionInfo->ulGroundPt().latd() < 0.0) ? SOUTH : NORTH;
267  out << cornerString[0] << endl;
268  out << setw(14) << "Latitude: "
269  << setw(16) << setprecision(12) << tmpDouble
270  << tmpString << endl;
271  tmpDouble = fabs(projectionInfo->ulGroundPt().lond());
272  tmpString = (projectionInfo->ulGroundPt().lond() < 0.0) ? WEST : EAST;
273  out << setw(14) << "Longitude: "
274  << setw(16) << tmpDouble << tmpString << endl;
275
276  out << setw(14) << "Easting: "
277  << setw(17) << setprecision(4)
278  << projectionInfo->ulEastingNorthingPt().x;
279
280  out << " meters, " << setprecision(4)
281  << ossim::mtrs2usft(projectionInfo->ulEastingNorthingPt().x)
282  << " U.S. feet";
283
284  out << endl
285  << setw(14) << "Northing: "
286  << setw(17) << projectionInfo->ulEastingNorthingPt().y;
287
288  out << " meters, " << setprecision(4)
289  << ossim::mtrs2usft(projectionInfo->ulEastingNorthingPt().y)
290  << " U.S. feet";
291
292  out << endl << endl;
293
294  //---
295  // Upper Right Corner Points
296  //---
297  tmpDouble = fabs(projectionInfo->urGroundPt().latd());
298  tmpString = (projectionInfo->urGroundPt().latd() < 0.0) ? SOUTH : NORTH;
299  out << cornerString[1] << endl;
300  out << setw(14) << "Latitude: "
301  << setw(16) << setprecision(12) << tmpDouble
302  << tmpString << endl;
303  tmpDouble = fabs(projectionInfo->urGroundPt().lond());
304  tmpString = (projectionInfo->urGroundPt().lond() < 0.0) ? WEST : EAST;
305  out << setw(14) << "Longitude: "
306  << setw(16) << tmpDouble << tmpString << endl;
307
308  out << setw(14) << "Easting: "
309  << setw(17) << setprecision(4)
310  << projectionInfo->urEastingNorthingPt().x;
311
312  out << " meters, " << setprecision(4)
313  << ossim::mtrs2usft(projectionInfo->urEastingNorthingPt().x)
314  << " U.S. feet";
315
316  out << endl
317  << setw(14) << "Northing: "
318  << setw(17) << projectionInfo->urEastingNorthingPt().y;
319
320  out << " meters, " << setprecision(4)
321  << ossim::mtrs2usft(projectionInfo->urEastingNorthingPt().y)
322  << " U.S. feet";
323
324  out << endl << endl;
325
326  //---
327  // Lower Right Corner Points
328  //---
329  tmpDouble = fabs(projectionInfo->lrGroundPt().latd());
330  tmpString = (projectionInfo->lrGroundPt().latd() < 0.0) ? SOUTH : NORTH;
331  out << cornerString[2] << endl;
332  out << setw(14) << "Latitude: "
333  << setw(16) << setprecision(12) << tmpDouble
334  << tmpString << endl;
335  tmpDouble = fabs(projectionInfo->lrGroundPt().lond());
336  tmpString = (projectionInfo->lrGroundPt().lond() < 0.0) ? WEST : EAST;
337  out << setw(14) << "Longitude: "
338  << setw(16) << tmpDouble << tmpString << endl;
339
340  out << setw(14) << "Easting: "
341  << setw(17) << setprecision(4)
342  << projectionInfo->lrEastingNorthingPt().x;
343
344  out << " meters, " << setprecision(4)
345  << ossim::mtrs2usft(projectionInfo->lrEastingNorthingPt().x)
346  << " U.S. feet";
347
348  out << endl
349  << setw(14) << "Northing: "
350  << setw(17) << projectionInfo->lrEastingNorthingPt().y;
351
352  out << " meters, " << setprecision(4)
353  << ossim::mtrs2usft(projectionInfo->lrEastingNorthingPt().y)
354  << " U.S. feet";
355
356  out << endl << endl;
357
358  //---
359  // Lower Left Corner Points
360  //---
361  tmpDouble = fabs(projectionInfo->llGroundPt().latd());
362  tmpString = (projectionInfo->llGroundPt().latd() < 0.0) ? SOUTH : NORTH;
363  out << cornerString[3] << endl;
364  out << setw(14) << "Latitude: "
365  << setw(16) << setprecision(12) << tmpDouble
366  << tmpString << endl;
367  tmpDouble = fabs(projectionInfo->llGroundPt().lond());
368  tmpString = (projectionInfo->llGroundPt().lond() < 0.0) ? WEST : EAST;
369  out << setw(14) << "Longitude: "
370  << setw(16) << tmpDouble << tmpString << endl;
371
372  out << setw(14) << "Easting: "
373  << setw(17) << setprecision(4)
374  << projectionInfo->llEastingNorthingPt().x;
375
376  out << " meters, " << setprecision(4)
377  << ossim::mtrs2usft(projectionInfo->llEastingNorthingPt().x)
378  << " U.S. feet";
379
380  out << endl
381  << setw(14) << "Northing: "
382  << setw(17) << projectionInfo->llEastingNorthingPt().y;
383
384  out << " meters, " << setprecision(4)
385  << ossim::mtrs2usft(projectionInfo->llEastingNorthingPt().y)
386  << " U.S. feet";
387
388  out << endl << endl;
389
390  out << "Center Coordinates:\n\n";
391
392  tmpDouble = fabs(projectionInfo->centerGroundPt().latd());
393
394  tmpString = (projectionInfo->centerGroundPt().latd() < 0.0) ? SOUTH : NORTH;
395
396  out << setw(14) << "Latitude: "
397  << setw(16) << setprecision(12) << tmpDouble
398  << tmpString << endl;
399
400  tmpDouble = fabs(projectionInfo->centerGroundPt().lond());
401
402  tmpString = (projectionInfo->centerGroundPt().lond() < 0.0) ? WEST : EAST;
403
404  out << setw(14) << "Longitude: "
405  << setw(16) << tmpDouble << tmpString << endl;
406
407  out << setw(14) << "Easting: "
408  << setw(17) << setprecision(4)
409  << projectionInfo->centerEastingNorthingPt().x;
410
411  out << " meters, " << setprecision(4)
412  << ossim::mtrs2usft(projectionInfo->centerEastingNorthingPt().x)
413  << " U.S. feet";
414
415  out << endl
416  << setw(14) << "Northing: "
417  << setw(17) << projectionInfo->centerEastingNorthingPt().y;
418
419  out << " meters, " << setprecision(4)
420  << ossim::mtrs2usft(projectionInfo->centerEastingNorthingPt().y)
421  << " U.S. feet";
422
423  out << endl << endl;
424
425  out
426  << "\nNOTE: Lat/Lon values are in decimal degrees.";
427
428  out
429  << "\n Eastings/Northings are in meters.";
430
431  out << endl;
432
433  delete projectionInfo;
434  }
435
436  out.close();
437  return true;
438 }
439
440 //**************************************************************************************************
441 //
442 //**************************************************************************************************
443 void ossimReadmeFileWriter::getMetadatatypeList(std::vector<ossimString>& metadatatypeList) const
444 {
445  metadatatypeList.push_back(ossimString("ossim_readme"));
446 }
447
448 //**************************************************************************************************
449 //
450 //**************************************************************************************************
452 {
453  return (metadataType == "ossim_readme");
454 }
ossimGpt urGroundPt() const
Returns the upper right ground point.
#define TYPE_NAME(p)
Definition: ossimRtti.h:326
virtual double getFalseNorthing() const
#define CLOG
Definition: ossimTrace.h:23
ossim_int32 linesPerImage() const
double lond() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:97
bool valid() const
Definition: ossimRefPtr.h:75
ossimDpt getUsSurveyFeetPerPixel() const
Returns the pixel size in U.S.
double y
Definition: ossimDpt.h:165
bool contains(char aChar) const
Definition: ossimString.h:58
virtual const ossimString & code() const
Definition: ossimDatum.h:57
virtual void getMetadatatypeList(std::vector< ossimString > &metadatatypeList) const
Satisfies pure virtual from ossimMetadataWriter base.
virtual ossimString getClassName() const
Definition: ossimObject.cpp:64
ossimDpt lrEastingNorthingPt() const
Returns the lower right easting and northing as a ossimDpt.
double latd() const
Definition: ossimGpt.h:87
virtual bool writeFile()
Write out the file.
ossimPixelType getPixelType() const
Returns data member "thePixelType".
virtual const ossimDatum * getDatum() const
RTTI_DEF1(ossimReadmeFileWriter, "ossimReadmeFileWriter", ossimMetadataFileWriter) static const char DEFAULT_FILE_NAME[]
ossimGpt lrGroundPt() const
Returns the lower right ground point.
ossimDpt centerEastingNorthingPt() const
ossimString getImageInfoString() const
Returns theImageInfoString.
virtual ossimGpt origin() const
virtual ~ossimReadmeFileWriter()
virtual destructor
double toDouble() const
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
ossimGpt ulGroundPt() const
Returns the upper left ground point.
ossimDpt urEastingNorthingPt() const
Returns the upper right easting and northing as a ossimDpt.
static const char * STD_PARALLEL_1_KW
ossim_int32 pixelsPerLine() const
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
ossimDpt llEastingNorthingPt() const
Returns the lower left easting and northing as a ossimDpt.
ossimDpt getMetersPerPixel() const
Returns the pixel size in meters.
virtual double getFalseEasting() const
const ossimEllipsoid & getEllipsoid() const
ossimDpt ulEastingNorthingPt() const
Returns the upper left easting and northing as a ossimDpt.
ossimGpt centerGroundPt() const
Returns the center ground point.
default constructor
double x
Definition: ossimDpt.h:164
const char * c_str() const
Definition: ossimString.h:396
ossim_int32 getZone() const
std::basic_ofstream< char > ofstream
Class for char output file streams.
Definition: ossimIosFwd.h:47
double mtrs2usft(double meters)
Definition: ossimCommon.h:375
static const char * SCALE_FACTOR_KW
static const char * STD_PARALLEL_2_KW
ossimGpt llGroundPt() const
Returns the lower left ground point.
virtual bool hasMetadataType(const ossimString &metadataType) const
