ossimRpfCacheTileSource.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: LGPL
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Author: Garrett Potts
8 //
9 //********************************************************************
10 // $Id: ossimRpfCacheTileSource.cpp 1361 2010-08-26 00:24:22Z david.burken $
11 #include <algorithm>
12 using namespace std;
13
15
21 #include <ossim/base/ossimCommon.h>
27 #include <ossim/base/ossimDatum.h>
28 #include <ossim/base/ossimNotify.h>
36 #include <ossim/base/ossimEndian.h>
37 #include <ossim/base/ossimTrace.h>
39
40 static ossimTrace traceDebug = ossimTrace("ossimRpfCacheTileSource:debug");
41
42 #ifdef OSSIM_ID_ENABLED
43 static const char OSSIM_ID[] = "$Id: ossimRpfCacheTileSource.cpp 1361 2010-08-26 00:24:22Z david.burken $";
44 #endif
45
46 RTTI_DEF1(ossimRpfCacheTileSource, "ossimRpfCacheTileSource", ossimImageHandler)
47
50
52  :
54
55  // a CADRG and CIBis a 64*64*12 bit buffer and must divide by 8 to
56  // convert to bytes
57  m_compressedBuffer(new ossim_uint8[(64*64*12)/8]),
58
59  // whether CIB or CADRG we will alocate the buffer
60  // to the larger of the 2 (CADRG is 3 bands)
61  m_uncompressedBuffer(new ossim_uint8[256*256*3]),
62
63  m_numberOfLines(0),
64  m_numberOfSamples(0),
65  m_tile(0),
66  m_fileNames(),
67  m_tileSize(128, 128),
68  m_productType(OSSIM_PRODUCT_TYPE_UNKNOWN),
69  m_workFrame(new ossimRpfFrame),
70  m_bBox_LL_Lon(0.0),
71  m_bBox_LL_Lat(0.0),
72  m_bBox_UR_Lon(0.0),
73  m_bBox_UR_Lat(0.0),
74  m_numOfFramesVertical(0),
75  m_numOfFramesHorizontal(0),
76  m_frameEntryArray()
77 {
78  if (traceDebug())
79  {
81  << "ossimRpfCacheTileSource::ossimRpfCacheTileSource entered...\n";
82 #ifdef OSSIM_ID_ENABLED
84  << "OSSIM_ID: " << OSSIM_ID << "\n";
85 #endif
86  }
87
89
90 }
91
93 {
95  {
96  delete [] m_compressedBuffer;
98  }
100  {
101  delete [] m_uncompressedBuffer;
103  }
104  if(m_workFrame)
105  {
106  delete m_workFrame;
107  m_workFrame = 0;
108  }
109  close();
110 }
111
113 {
114  return ossimString("RpfCache");
115 }
116
118 {
119  return ossimString("RpfCache reader");
120 }
121
122
124 {
125  deleteAll();
126 }
127
129 {
130  //return (theTableOfContents!=0);
132
133  if(ext == "rpf")
134  {
135  return true;
136  }
137  else
138  {
139  return false;
140  }
141 }
142
144 {
145  if(traceDebug())
146  {
147  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimRpfCacheTileSource::open(): Entered....." << std::endl;
148  }
149
150  ossimFilename imageFile = theImageFile;
151  bool result = true;
152
153  if(isOpen() == false)
154  {
155  close();
156  result = false;
157  }
158
159  if(result)
160  {
161  if (m_fileNames.size() == 0 && m_frameEntryArray.size() == 0)
162  {
163  if (buildFrameEntryArray(imageFile) == false)
164  {
165  return false;
166  }
167  }
168
169  setCurrentEntry(0);
170  //---
171  // Adjust image rect so not to go over the -180 to 180 and -90 to 90
172  // bounds.
173  //---
175
176  // Set the base class image file name.
177  theImageFile = imageFile;
179  m_tile->initialize();
180  }
181
182  if(traceDebug())
183  {
184  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimRpfCacheTileSource::open(): Leaving at line" << __LINE__ << std::endl;
185  }
186
187  return result;
188 }
189
191 {
192  static const char MODULE[] = "ossimRpfCacheTileSource::buildFrameEntryArray";
193  if ( traceDebug() )
194  {
195  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered..." << endl;
196  }
197
198  std::ifstream in((imageFile).c_str() );
199
200  std::string line;
201  ossim_uint32 index = 0; // used throughout
202  while( in.good() )
203  {
204  // Read in a line.
205  std::getline(in, line);
206
207  ossimString tmpStr = ossimString(line);
208  if (!tmpStr.empty())
209  {
210  if (index == 0)
211  {
212  std::vector<ossimString> box_lat_lon;
213  tmpStr.split(box_lat_lon, "|");
214
215  if (box_lat_lon.size() > 2)
216  {
217  std::vector<ossimString> ll;
218  std::vector<ossimString> ur;
219
220  box_lat_lon[0].split(ll, ",");
221  box_lat_lon[1].split(ur, ",");
222  ossimString bandStr = box_lat_lon[2];
223
224  m_bBox_LL_Lon = ll[0].toFloat64();
225  m_bBox_LL_Lat = ll[1].toFloat64();
226  m_bBox_UR_Lon = ur[0].toFloat64();
227  m_bBox_UR_Lat = ur[1].toFloat64();
228
230
231  ossim_int32 bands = ossimString(bandStr).toInt32();
232  if (bands == 1)
233  {
235  }
236  else if (bands == 3)
237  {
239  }
240  }
241  else
242  {
243  return false;
244  }
245  }
246  else if (index == 1)
247  {
248  m_fileNames.push_back(tmpStr);
249  std::vector<ossimString> frame_lat_lon = tmpStr.split("|");
250  if (frame_lat_lon.size() > 2)
251  {
252  ossimString ll_lon_lat = frame_lat_lon[1];
253  ossimString ur_lon_lat = frame_lat_lon[2];
254  ossim_float64 ll_lon = ossimString(ll_lon_lat.split(",")[0]).toDouble();
255  ossim_float64 ll_lat = ossimString(ll_lon_lat.split(",")[1]).toDouble();
256  ossim_float64 ur_lon = ossimString(ur_lon_lat.split(",")[0]).toDouble();
257  ossim_float64 ur_lat = ossimString(ur_lon_lat.split(",")[1]).toDouble();
258
259  checkLongitude(ll_lon, ur_lon);
260
261  ossim_float64 bBox_lat_diff = std::fabs(m_bBox_UR_Lat - m_bBox_LL_Lat);
262  ossim_float64 bBox_lon_diff = std::fabs(m_bBox_UR_Lon - m_bBox_LL_Lon);
263
264  ossim_float64 lat_diff = std::fabs(ur_lat - ll_lat);
265  ossim_float64 lon_diff = std::fabs(ur_lon - ll_lon);
266
267  m_numOfFramesVertical = static_cast<ossim_uint32>(bBox_lat_diff/lat_diff + 0.5);
268  m_numOfFramesHorizontal = static_cast<ossim_uint32>(bBox_lon_diff/lon_diff + 0.5);
269
272
273  if ( traceDebug() )
274  {
276  << "\nscene height in degrees: " << bBox_lat_diff
277  << "\nscene width in degrees: " << bBox_lon_diff
278  << "\nframe height in degrees: " << lat_diff
279  << "\nframe width in degrees: " << lon_diff
280  << "\nframes vertical: " << m_numOfFramesVertical
281  << "\nframes horizontal: " << m_numOfFramesHorizontal
282  << "\nlines: " << m_numberOfLines
283  << "\nsamples: " << m_numberOfSamples << "\n";
284  }
285  }
286  else
287  {
288  return false;
289  }
290  }
291  else
292  {
293  m_fileNames.push_back(tmpStr);
294  }
295
296  } // matches: if (!tmpStr.empty())
297
298  ++index;
299
300  } // matches: while( in.good() )
301  in.close();
302
304  for(index = 0; index < m_frameEntryArray.size(); ++index)
305  {
307  }
308
309  for(index = 0; index < m_fileNames.size(); ++index)
310  {
311  ossimString tmpStr = m_fileNames[index];
312  std::vector<ossimString> frameInfos = tmpStr.split("|");
313  if (frameInfos.size() > 1)
314  {
315  ossimString fileName = frameInfos[0];
316  ossimString ll_lon_lat = frameInfos[1];
317  ossimString ur_lon_lat = frameInfos[2];
318  double ll_lon = ossimString(ll_lon_lat.split(",")[0]).toDouble();
319  double ll_lat = ossimString(ll_lon_lat.split(",")[1]).toDouble();
320  double ur_lon = ossimString(ur_lon_lat.split(",")[0]).toDouble();
321  double ur_lat = ossimString(ur_lon_lat.split(",")[1]).toDouble();
322
323  checkLongitude(ll_lon, ur_lon);
324
325  ossim_float64 tmpColPostion = std::fabs(ll_lon - m_bBox_LL_Lon);
326  ossim_float64 tmpFrameLon = std::fabs(ur_lon - ll_lon);
327
328  ossim_float64 tmpRowPostion = std::fabs(m_bBox_UR_Lat - ur_lat);
329  ossim_float64 tmpFrameLat = std::fabs(ur_lat - ll_lat);
330
331  ossim_uint32 colNum = static_cast<ossim_uint32>(tmpColPostion/tmpFrameLon + 0.5);
332  ossim_uint32 rowNum = static_cast<ossim_uint32>(tmpRowPostion/tmpFrameLat + 0.5);
333
334  if (colNum >= m_numOfFramesHorizontal)
335  {
336  colNum = m_numOfFramesHorizontal-1; // Clamp to last column.
337  }
338
339  if (rowNum >= m_numOfFramesVertical)
340  {
341  rowNum = m_numOfFramesVertical-1; // Clamp to last row.
342  }
343
344  ossimRpfFrameEntry tempEntry;
345  tempEntry.setEntry(ossimFilename(""), fileName);
346  m_frameEntryArray[rowNum][colNum] = tempEntry;
347  }
348  else
349  {
350  return false;
351  }
352  }
353
354  return true;
355 }
356
358  const ossim_float64& rightLon) const
359 {
360  //---
361  // Test for scene coordinates being 180 to 180 and adjust leftLon to -180
362  // if so.
363  //
364  // NOTE:
365  // Setting tolerance to 1/7200 about 15 meters.
366  // Not sure if this is too loose or not. (drb)
367  //---
368  const ossim_float64 TOLERANCE = 0.000138889; // 1/7200 about 15 meters.
369
370  if ( ossim::almostEqual(leftLon, 180.0, TOLERANCE) )
371  {
372  if ( ossim::almostEqual(rightLon, 180.0, TOLERANCE) )
373  {
374  leftLon = -180.0;
375  }
376  }
377 }
378
380  const ossimIrect& rect, ossim_uint32 resLevel)
381 {
382  if (m_tile.valid())
383  {
384  // Image rectangle must be set prior to calling getTile.
385  m_tile->setImageRectangle(rect);
386
387  if ( getTile( m_tile.get(), resLevel ) == false )
388  {
390  {
391  m_tile->makeBlank();
392  }
393  }
394  }
395
396  return m_tile;
397 }
398
400  ossim_uint32 resLevel)
401 {
402  bool status = false;
403
404  //---
405  // Not open, this tile source bypassed, or invalid res level,
406  // return a blank tile.
407  //---
408  if( isOpen() && isSourceEnabled() && isValidRLevel(resLevel) &&
409  result && (result->getNumberOfBands() == getNumberOfOutputBands()) &&
411  {
412  if ( resLevel > 0 )
413  {
414  //---
415  // Check for overview tile. Some overviews can contain r0 so always
416  // call even if resLevel is 0 (if overview is not virtual). Method
417  // returns true on success, false on error.
418  //---
419  status = getOverviewTile(resLevel, result);
420  }
421
422  if (!status) // Did not get an overview tile.
423  {
424  status = true;
425
426  ossimIrect rect = result->getImageRectangle();
427
428  ossimIrect imageRect = getImageRectangle();
429
430  if ( rect.intersects(imageRect) )
431  {
432  //---
433  // Start with a blank tile in case there is not total coverage
434  // for rect.
435  //---
436  result->makeBlank();
437
438  vector<ossimFrameEntryData> frames = getIntersectingEntries(rect);
439  if(frames.size() > 0)
440  {
441  //---
442  // Now lets render each frame. Note we will have to find
443  // subframes
444  // that intersect the rectangle of interest for each frame.
445  //---
446  fillTile(rect, frames, result);
447
448  // Revalidate tile status.
449  result->validate();
450  }
451  }
452  else
453  {
454  result->makeBlank();
455  }
456  }
457  }
458
459  return status;
460 }
461
463 {
464  switch(m_productType)
465  {
467  {
468  return 0;
469  }
471  {
472  return 1;
473  }
475  {
476  return 3;
477  }
478  }
479
480  return 0;
481 }
482
484 {
485  switch(m_productType)
486  {
488  {
489  return 0;
490  }
492  {
493  return 1;
494  }
496  {
497  return 3;
498  }
499  }
500
501  return 0;
502 }
503
505 {
506  if (reduced_res_level == 0)
507  {
508  return m_numberOfLines;
509  }
510  else if (theOverview.valid())
511  {
512  return theOverview->getNumberOfLines(reduced_res_level);
513  }
514
515  return 0;
516 }
517
519 {
520  if (reduced_res_level == 0)
521  {
522  return m_numberOfSamples;
523  }
524  else if (theOverview.valid())
525  {
526  return theOverview->getNumberOfSamples(reduced_res_level);
527  }
528
529  return 0;
530 }
531
533 {
535 }
536
538 {
539  return ossimIrect(0, // upper left x
540  0, // upper left y
541  getNumberOfSamples(reduced_res_level) - 1, // lower right x
542  getNumberOfLines(reduced_res_level) - 1); // lower right y
543 }
544
546 {
547  if (theGeometry.valid()) return theGeometry;
548
549  // datum
550  // WGS 84
551  ossimKeywordlist kwl;
552  const char* prefix = 0; // legacy
553  kwl.add(prefix,
555  "WGE",
556  true);
557
562
563  double latInterval = fabs(ul.latd() - lr.latd())/ getNumberOfLines();
564  double lonInterval = fabs(ul.lond() - ur.lond())/ getNumberOfSamples();
565
566  kwl.add(prefix,
568  ul.latd(),//-(latInterval/2.0),
569  true);
570
571  kwl.add(prefix,
573  ul.lond(),//+(lonInterval/2.0),
574  true);
575
576  kwl.add(prefix,
578  ll.latd(),//+(latInterval/2.0),
579  true);
580
581  kwl.add(prefix,
583  ll.lond(),//+(lonInterval/2.0),
584  true);
585
586  kwl.add(prefix,
588  lr.latd(),//+(latInterval/2.0),
589  true);
590
591  kwl.add(prefix,
593  lr.lond(),//-(lonInterval/2.0),
594  true);
595
596  kwl.add(prefix,
598  ur.latd(),//-(latInterval/2.0),
599  true);
600
601  kwl.add(prefix,
603  ur.lond(),//-(latInterval/2.0),
604  true);
605
606  kwl.add(prefix,
609  true);
610
611  kwl.add(prefix,
614  true);
615
616  kwl.add(prefix,
619  true);
620
621  kwl.add(prefix,
624  true);
625
626
627  //---
628  // Make a projection to get the easting / northing of the tie point and
629  // the scale in meters. This will only be used by the CIB.
630  //---
631  kwl.add(prefix,
633  "WGE",
634  true);
635
636  ossimGpt origin((ul.latd()+lr.latd())*.5,
637  (ul.lond()+lr.lond())*.5,
638  0.0);
639
640  double deltaLatPerPixel = latInterval;
641  double deltaLonPerPixel = lonInterval;
642
643  ossimDpt tie;
644
645  tie.lat = ul.latd() - deltaLatPerPixel/2.0;
646  tie.lon = ul.lond() + deltaLonPerPixel/2.0;
647
648  kwl.add(prefix,
650  tie.toString(),
651  true);
652
653  kwl.add(prefix,
655  deltaLatPerPixel,
656  true);
657
658  kwl.add(prefix,
660  deltaLonPerPixel,
661  true);
662
663  kwl.add(prefix,
665  origin.latd(),
666  true);
667
668  kwl.add(prefix,
670  origin.lond(),
671  true);
672
673  kwl.add(prefix,
675  ul.latd()-(deltaLatPerPixel/2.0),
676  true);
677
678  kwl.add(prefix,
680  ul.lond()+(deltaLonPerPixel/2.0),
681  true);
682
683  kwl.add(prefix,
685  "ossimEquDistCylProjection",
686  true);
687
688  // Capture this for next time.
690  theGeometry->loadState(kwl, prefix);
691
692  // Set image things the geometry object should know about.
694
695  return theGeometry;
696 }
697
699 {
700  return OSSIM_UCHAR;
701 }
702
704 {
705  return m_tileSize.x;
706 }
707
709 {
710  return m_tileSize.y;
711 }
712
714 {
715  // Clear the geometry.
716  theGeometry = 0;
717
718  // Must clear or openOverview will use last entries.
720
721  if(!setEntryToRender(entryIdx))
722  {
723  return false;
724  }
725  completeOpen();
726
727  return true;
728 }
729
730 void ossimRpfCacheTileSource::getEntryList(std::vector<ossim_uint32>& entryList)const
731 {
732  entryList.push_back(0);
733 }
734
736 {
737  if(isOpen())
738  {
739  populateLut();
740  return true;
741  }
742
743  return false;
744 }
745
747 {
748  if (reduced_res_level == 0)
749  {
750  return true;
751  }
752  else if (theOverview.valid())
753  {
754  return theOverview->isValidRLevel(reduced_res_level);
755  }
756  else
757  {
758  return false;
759  }
760 }
761
762 vector<ossimRpfCacheTileSource::ossimFrameEntryData> ossimRpfCacheTileSource::getIntersectingEntries(const ossimIrect& rect)
763 {
764  vector<ossimFrameEntryData> result;
765
766  // make sure we have the Toc entry to render
767  if(!isOpen()) return result;
768
769  ossimIrect imageRect = getImageRectangle();
770  if(rect.intersects(imageRect))
771  {
772  ossimIrect clipRect = rect.clipToRect(imageRect);
773  ossimIrect frameRect(clipRect.ul().x/CIBCADRG_FRAME_WIDTH,
774  clipRect.ul().y/CIBCADRG_FRAME_HEIGHT,
775  clipRect.lr().x/CIBCADRG_FRAME_WIDTH,
776  clipRect.lr().y/CIBCADRG_FRAME_HEIGHT);
777
778  for(ossim_int32 row = frameRect.ul().y; row <= frameRect.lr().y; ++row)
779  {
780  for(ossim_int32 col = frameRect.ul().x; col <= frameRect.lr().x; ++col)
781  {
782  ossimRpfFrameEntry tempEntry = m_frameEntryArray[row][col];
783  if(tempEntry.exists())
784  {
785  result.push_back(ossimFrameEntryData(row,
786  col,
789  tempEntry));
790  }
791  }
792  }
793  }
794
795  return result;
796 }
797
799  const ossimIrect& tileRect,
800  const vector<ossimFrameEntryData>& framesInvolved,
801  ossimImageData* tile)
802 {
803  ossim_uint32 idx = 0;
804  for(idx = 0;
805  idx < framesInvolved.size();
806  ++idx)
807  {
808
809  if(m_workFrame->parseFile(framesInvolved[idx].theFrameEntry.getFullPath())
811  {
812  // we will fill a subtile. We pass in which frame it is and the position of the frame.
813  // the actual pixel will be 1536*row and 1536 *col.
815  {
817  tileRect,
818  framesInvolved[idx],
819  tile);
820  }
821  else
822  {
824  tileRect,
825  framesInvolved[idx],
826  tile);
827  }
828  }
829  }
830 }
831
833  const ossimRpfFrame& aFrame,
834  const ossimIrect& tileRect,
835  const ossimFrameEntryData& frameEntryData,
836  ossimImageData* tile)
837 {;
838 // first let's grab the absolute position of the frame rectangle in pixel space
839  ossimIrect frameRect(frameEntryData.thePixelCol,
840  frameEntryData.thePixelRow,
841  frameEntryData.thePixelCol + CIBCADRG_FRAME_WIDTH - 1,
842  frameEntryData.thePixelRow + CIBCADRG_FRAME_HEIGHT - 1);
843
844
845 // now clip it to the tile
846  ossimIrect clipRect = tileRect.clipToRect(frameRect);
847
848  const ossimRpfCompressionSection* compressionSection = aFrame.getCompressionSection();
849
850  if(!compressionSection)
851  {
852  return;
853  }
854
855  const vector<ossimRpfColorGrayscaleTable>& colorTable =
856  aFrame.getColorGrayscaleTable();
857
858 // ESH 03/2009 -- Partial fix for ticket #646.
859 // Crash fix on reading RPFs: Make sure the colorTable vector
860 // has entries before trying to make use of them.
861  int numTables = (int)colorTable.size();
862  if ( numTables <= 0 )
863  {
864  return;
865  }
866
867  ossim_uint8 *tempRows[3];
868
869  tempRows[0] = m_uncompressedBuffer;
870  tempRows[1] = (m_uncompressedBuffer + 256*256);
871  tempRows[2] = (tempRows[1] + 256*256);
872
873 // find the shift to 0,0
874  ossimIpt tempDelta(clipRect.ul().x - frameEntryData.thePixelCol,
875  clipRect.ul().y - frameEntryData.thePixelRow);
876
877
878 // In order to compute the subframe we will need the corner offsets of
879 // the upper left of the frame and the upper left of the clip rect. The
880 // clip rect should be completely within the frame. This just translates the value
881 // to make the upper left of the frame be 0,0.
882 //
883  ossimIrect offsetRect(tempDelta.x,
884  tempDelta.y,
885  tempDelta.x + clipRect.width()-1,
886  tempDelta.y + clipRect.height()-1);
887
888 // each subframe is 64x64. We will actually use 256x256 since
889 // we will be uncompressing them. Note CADRG is a 256x256 tile
890 // compressed to 64x64x12 bit data
891 //
892  ossimIrect subFrameRect(offsetRect.ul().x/256,
893  offsetRect.ul().y/256,
894  (offsetRect.lr().x)/256,
895  (offsetRect.lr().y)/256);
896
897  ossim_uint32 readPtr = 0;
898
899  ossim_int32 row = 0;
900  ossim_int32 col = 0;
901  ossim_uint32 i = 0;
902  ossim_uint32 j = 0;
903  ossim_int32 upperY = subFrameRect.lr().y;
904  ossim_int32 upperX = subFrameRect.lr().x;
905  ossim_int32 lowerY = subFrameRect.ul().y;
906  ossim_int32 lowerX = subFrameRect.ul().x;
907  for(row = lowerY; row <= upperY; ++row)
908  {
909  for(col = lowerX; col <= upperX; ++col)
910  {
911  readPtr = 0;
912  if(aFrame.fillSubFrameBuffer(m_compressedBuffer, 0, row, col))
913  {
914  for (i = 0; i < 256; i += 4)
915  {
916  for (j = 0; j < 256; j += 8)
917  {
918  ossim_uint16 firstByte = m_compressedBuffer[readPtr++] & 0xff;
919  ossim_uint16 secondByte = m_compressedBuffer[readPtr++] & 0xff;
920  ossim_uint16 thirdByte = m_compressedBuffer[readPtr++] & 0xff;
921
922  //because dealing with half-bytes is hard, we
923  //uncompress two 4x4 tiles at the same time. (a
924  //4x4 tile compressed is 12 bits )
925  // this little code was grabbed from openmap software.
926
927  /* Get first 12-bit value as index into VQ table */
928  // I think we need to swap
929  ossim_uint16 val1 = (firstByte << 4) | (secondByte >> 4);
930
931  /* Get second 12-bit value as index into VQ table*/
932  ossim_uint16 val2 = ((secondByte & 0x000F) << 8) | thirdByte;
933
934  for (ossim_uint32 t = 0; t < 4; ++t)
935  {
936  for (ossim_uint32 e = 0; e < 4; ++e)
937  {
938  ossim_uint16 tableVal1 = compressionSection->getTable()[t].theData[val1*4 + e] & 0xff;
939  ossim_uint16 tableVal2 = compressionSection->getTable()[t].theData[val2*4 + e] & 0xff;
940
941  ossim_uint32 pixindex = ((i+t)*256) +
942  (j + e);
943  const ossim_uint8* color1 = colorTable[0].getStartOfData(tableVal1);
944  const ossim_uint8* color2 = colorTable[0].getStartOfData(tableVal2);
945
946
947  tempRows[0][pixindex] = color1[0];
948  tempRows[1][pixindex] = color1[1];
949  tempRows[2][pixindex] = color1[2];
950
951  tempRows[0][pixindex+4] = color2[0];
952  tempRows[1][pixindex+4] = color2[1];
953  tempRows[2][pixindex+4] = color2[2];
954  } //for e
955  } //for t
956  } /* for j */
957  } //for i
958  }
959  else
960  {
961  memset(m_uncompressedBuffer, 0, 256*256*3);
962  }
963  ossim_int32 tempCol = col*256;
964  ossim_int32 tempRow = row*256;
965  ossimIrect subRectToFill(frameRect.ul().x + tempCol,
966  frameRect.ul().y + tempRow,
967  frameRect.ul().x + tempCol + 255,
968  frameRect.ul().y + tempRow + 255);
970  subRectToFill,
971  OSSIM_BSQ);
972  }
973  }
974 }
975
977  const ossimRpfFrame& aFrame,
978  const ossimIrect& tileRect,
979  const ossimFrameEntryData& frameEntryData,
980  ossimImageData* tile)
981 {
982  // first let's grab the absolute position of the frame rectangle in pixel
983  // space
984  ossimIrect frameRect(frameEntryData.thePixelCol,
985  frameEntryData.thePixelRow,
986  frameEntryData.thePixelCol + CIBCADRG_FRAME_WIDTH - 1,
987  frameEntryData.thePixelRow + CIBCADRG_FRAME_HEIGHT - 1);
988
989
990  // now clip it to the tile
991  ossimIrect clipRect = tileRect.clipToRect(frameRect);
992
993  const ossimRpfCompressionSection* compressionSection = aFrame.getCompressionSection();
994
995  if(!compressionSection)
996  {
997  return;
998  }
999
1000  const vector<ossimRpfColorGrayscaleTable>& colorTable =
1001  aFrame.getColorGrayscaleTable();
1002
1003  // ESH 03/2009 -- Partial fix for ticket #646.
1004  // Crash fix on reading RPFs: Make sure the colorTable vector
1005  // has entries before trying to make use of them.
1006  int numTables = (int)colorTable.size();
1007  if ( numTables <= 0 )
1008  {
1009  return;
1010  }
1011
1012  // check to see if it does overlap. If it doesn't then the width and height
1013  // will be a single point
1014  {
1015  ossim_uint8 *tempRow;
1016
1017  tempRow = m_uncompressedBuffer;
1018
1019  // find the shift to 0,0
1020  ossimIpt tempDelta(clipRect.ul().x - frameEntryData.thePixelCol,
1021  clipRect.ul().y - frameEntryData.thePixelRow);
1022
1023  // In order to compute the subframe we will need the corner offsets of
1024  // the upper left of the frame and the upper left of the clip rect. The
1025  // clip rect should be completely within the frame. This just translates the value
1026  // to make the upper left of the frame be 0,0.
1027  //
1028  ossimIrect offsetRect(tempDelta.x,
1029  tempDelta.y,
1030  tempDelta.x + clipRect.width()-1,
1031  tempDelta.y + clipRect.height()-1);
1032
1033  // each subframe is 64x64. We will actually use 256x256 since
1034  // we will be uncompressing them. Note CADRG is a 256x256 tile
1035  // compressed to 64x64x12 bit data
1036  //
1037  ossimIrect subFrameRect(offsetRect.ul().x/256,
1038  offsetRect.ul().y/256,
1039  (offsetRect.lr().x)/256,
1040  (offsetRect.lr().y)/256);
1041
1042  ossim_int32 row = 0;
1043  ossim_int32 col = 0;
1044  ossim_uint32 i = 0;
1045  ossim_uint32 j = 0;
1046  ossim_uint32 readPtr = 0;
1047  for(row = subFrameRect.ul().y; row <= subFrameRect.lr().y; ++row)
1048  {
1049  for(col = subFrameRect.ul().x; col <= subFrameRect.lr().x; ++col)
1050  {
1051  readPtr = 0;
1052  if(aFrame.fillSubFrameBuffer(m_compressedBuffer, 0, row, col))
1053  {
1054  for (i = 0; i < 256; i += 4)
1055  {
1056  for (j = 0; j < 256; j += 8)
1057  {
1058  ossim_uint16 firstByte = m_compressedBuffer[readPtr++] & 0xff;
1059  ossim_uint16 secondByte = m_compressedBuffer[readPtr++] & 0xff;
1060  ossim_uint16 thirdByte = m_compressedBuffer[readPtr++] & 0xff;
1061
1062  //because dealing with half-bytes is hard, we
1063  //uncompress two 4x4 tiles at the same time. (a
1064  //4x4 tile compressed is 12 bits )
1065  // this little code was grabbed from openmap software.
1066
1067  /* Get first 12-bit value as index into VQ table */
1068  // I think we need to swap
1069  ossim_uint16 val1 = (firstByte << 4) | (secondByte >> 4);
1070
1071  /* Get second 12-bit value as index into VQ table*/
1072  ossim_uint16 val2 = ((secondByte & 0x000F) << 8) | thirdByte;
1073
1074  for (ossim_uint32 t = 0; t < 4; ++t)
1075  {
1076  for (ossim_uint32 e = 0; e < 4; ++e)
1077  {
1078  ossim_uint16 tableVal1 = compressionSection->getTable()[t].theData[val1*4 + e] & 0xff;
1079  ossim_uint16 tableVal2 = compressionSection->getTable()[t].theData[val2*4 + e] & 0xff;
1080
1081  ossim_uint32 pixindex = ((i+t)*256) + (j + e);
1082  const ossim_uint8* color1 = colorTable[0].getStartOfData(tableVal1);
1083  const ossim_uint8* color2 = colorTable[0].getStartOfData(tableVal2);
1084
1085
1086  tempRow[pixindex] = color1[0];
1087  tempRow[pixindex + 4] = color2[0];
1088  } //for e
1089  } //for t
1090  } /* for j */
1091  } //for i
1092  }
1093  else
1094  {
1095  memset(m_uncompressedBuffer, 0, 256*256);
1096  }
1097  ossim_int32 tCol = col*256;
1098  ossim_int32 tRow = row*256;
1099  ossimIrect subRectToFill(frameRect.ul().x + tCol,
1100  frameRect.ul().y + tRow,
1101  frameRect.ul().x + tCol + 255,
1102  frameRect.ul().y + tRow + 255);
1104  subRectToFill,
1105  OSSIM_BSQ);
1106  }
1107  }
1108  }
1109 }
1110
1112 {
1114  {
1115  return;
1116  }
1118  {
1119  delete [] m_uncompressedBuffer;
1121  }
1122  if(m_compressedBuffer)
1123  {
1124  delete [] m_compressedBuffer;
1125  m_compressedBuffer = 0;
1126  }
1127
1128  // a CADRG and CIBis a 64*64*12 bit buffer and must divide by 8 to
1129  // convert to bytes
1130  m_compressedBuffer = new ossim_uint8[(64*64*12)/8];
1132  {
1133  m_uncompressedBuffer = new ossim_uint8[256*256];
1134  }
1135  else
1136  {
1137  m_uncompressedBuffer = new ossim_uint8[256*256*3];
1138  }
1139
1141  m_tile->initialize();
1142 }
1143
1145 {
1146  theOverview = 0;
1147 }
1148
1150  const char* prefix)const
1151 {
1152  bool result = ossimImageHandler::saveState(kwl, prefix);
1153
1154  return result;
1155 }
1156
1158  const char* prefix)
1159 {
1160  const char* MODULE = "ossimRpfCacheTileSource::loadState";
1161
1162  if(traceDebug())
1163  {
1164  CLOG << "Entering..." << endl;
1165  }
1166  bool result = ossimImageHandler::loadState(kwl, prefix);
1167
1168  if(!result)
1169  {
1170  if(traceDebug())
1171  {
1172  CLOG << "Leaving..." << endl;
1173  }
1174  return false;
1175  }
1176  const char* lookup = 0;
1177  lookup = kwl.find(ossimString(prefix), "entry");
1178  ossim_int32 entry = ossimString(lookup).toInt32();
1179
1180  // if an entry is specified then
1181  // call the open with an entry number
1182  if(lookup)
1183  {
1184  if(traceDebug())
1185  {
1186  CLOG << "Leaving..." << endl;
1187  }
1189  setCurrentEntry(entry);
1190  return result;
1191  }
1192
1194
1195  return result;
1196 }
1197
1199 {
1200  return 256;
1201 }
1202
1204 {
1205  return 256;
1206 }
1207
1209 {
1211 }
1212
1214 {
1216 }
1217
1219 {
1220  if(name == "file_type")
1221  {
1223  {
1224  return new ossimStringProperty("file_type", "CIB");
1225  }
1227  {
1228  return new ossimStringProperty("file_type", "CADRG");
1229  }
1230  return 0;
1231  }
1232  return ossimImageHandler::getProperty(name);
1233 }
1234
1236 {
1237  theLut = 0;
1238  if(m_fileNames.size() > 0)
1239  {
1240  // bool found = false;
1241  ossimRpfFrameEntry tempEntry;
1242  ossimRpfFrame aFrame;
1243  ossimFilename fileName = m_fileNames[0].split("|")[0];
1244  // if (fileName.exists())
1245  // {
1246  // found = true;
1247  // }
1248
1249  if(aFrame.parseFile(fileName)
1251  {
1252  const vector<ossimRpfColorGrayscaleTable>& colorTable =
1253  aFrame.getColorGrayscaleTable();
1254
1255  // ESH 03/2009 -- Partial fix for ticket #646.
1256  // Crash fix on reading RPFs: Make sure the colorTable vector
1257  // has entries before trying to make use of them.
1258  int numTables = (int)colorTable.size();
1259
1260  ossim_uint32 numElements = (numTables > 0) ? colorTable[0].getNumberOfElements() : 0;
1261  if(numElements > 0)
1262  {
1265  {
1266  theLut = new ossimNBandLutDataObject(numElements,
1267  3,
1268  OSSIM_UINT8);
1269  }
1270  else
1271  {
1272  theLut = 0;
1273  return;
1274  }
1275  ossim_uint32 idx = 0;
1276
1277  for(idx = 0; idx < numElements;++idx)
1278  {
1279  const ossim_uint8* startOfData = colorTable[0].getStartOfData(idx);
1280  switch(m_productType)
1281  {
1283  {
1284  (*theLut)[idx][0] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[0]);
1285  (*theLut)[idx][1] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[0]);
1286  (*theLut)[idx][2] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[0]);
1287  break;
1288  }
1290  {
1291  (*theLut)[idx][0] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[0]);
1292  (*theLut)[idx][1] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[1]);
1293  (*theLut)[idx][2] = (ossimNBandLutDataObject::LUT_ENTRY_TYPE)(startOfData[2]);
1294  break;
1295  }
1296  default:
1297  {
1298  break;
1299  }
1300  }
1301  }
1302  }
1303  }
1304  }
1305 }
1306
1308 {
1309  theDecimationFactors.clear();
1310
1311  // Just needed to set the first R level here, the base class can do the rest:
1313 }
1314
virtual bool open()=0
Pure virtual open.
void clear()
Erases the entire container.
Definition: ossimString.h:432
std::vector< ossimString > m_fileNames
The size of the input frames.
Protected structure that is only used internally by this class.
virtual ossim_uint32 getTileWidth() const
Returns the width of the output tile.
void fillSubTileCib(const ossimRpfFrame &aFrame, const ossimIrect &tileRect, const ossimFrameEntryData &frameEntryData, ossimImageData *tile)
Will uncompress the CIB file using a VQ decompression algorithm.
ossimRefPtr< ossimImageGeometry > theGeometry
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level=0) const
Satisfies pure virtual requirement from ImageHandler class.
This method allows you to query the scalar type of the output data.
ossimIrect m_actualImageRect
This holds the image bounds for the current entry.
static const char * DECIMAL_DEGREES_PER_PIXEL_LAT
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
static const char * DATUM_KW
Gets a property for matching name.
#define CLOG
Definition: ossimTrace.h:23
ossimFilename theImageFile
const std::vector< ossimRpfCompressionOffsetTableData > & getTable() const
double lond() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:97
static const char * CENTRAL_MERIDIAN_KW
void allocateForProduct()
Will allocate an internal buffer for the given product.
static const char * UL_LAT_KW
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
static const ossimErrorCode OSSIM_OK
std::basic_ifstream< char > ifstream
Class for char input file streams.
Definition: ossimIosFwd.h:44
bool valid() const
Definition: ossimRefPtr.h:75
Attempts to initialize a transform and a projection given the KWL.
std::vector< ossimDpt > theDecimationFactors
bool almostEqual(T x, T y, T tolerance=FLT_EPSILON)
Definition: ossimCommon.h:53
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &rect, ossim_uint32 resLevel=0)
Returns a pointer to an ossimImageDataObject given a rectangluar region of interest.
ossim_uint32 height() const
Definition: ossimIrect.h:487
virtual ossimString getShortName() const
This method is defined in the base class ossimObject.
static const char * NUMBER_LINES_KW
static const char * TIE_POINT_LON_KW
static const char * NUMBER_INPUT_BANDS_KW
const ossimIpt & ul() const
Definition: ossimIrect.h:274
static const char * LR_LON_KW
std::istream & getline(std::istream &is, ossimString &str, char delim)
Definition: ossimString.h:916
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
unsigned short ossim_uint16
double latd() const
Definition: ossimGpt.h:87
static const char * TYPE_KW
virtual void initialize()
Initialize the data buffer.
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
ossim_int32 toInt32() const
const vector< ossimRpfColorGrayscaleTable > & getColorGrayscaleTable() const
Definition: ossimRpfFrame.h:80
double ossim_float64
ossimRefPtr< ossimImageData > m_tile
This is the actual data returned from a getTile request.
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
This method allows one to query the number of output bands.
vector< ossimFrameEntryData > getIntersectingEntries(const ossimIrect &rect)
It is important to note that each frame is organized into an easting northing type orientation...
virtual bool getOverviewTile(ossim_uint32 resLevel, ossimImageData *result)
Method to get an overview tile.
static const char * LR_LAT_KW
double lat
Definition: ossimDpt.h:165
virtual bool setEntryToRender(ossim_uint32 index)
Sets the entry to render.
bool fillSubFrameBuffer(ossim_uint8 *buffer, ossim_uint32 spectralGroup, ossim_uint32 row, ossim_uint32 col) const
static const ossim_uint32 CIBCADRG_FRAME_HEIGHT
CONSTANT representing the height of a Frame.
virtual ~ossimRpfCacheTileSource()
Destructor.
static const char * TIE_POINT_XY_KW
virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level=0) const
virtual ossimString getLongName() const
bool buildFrameEntryArray(ossimFilename imageFile)
static const char * LL_LON_KW
virtual ossim_uint32 getImageTileHeight() const
ossimRpfCacheProductType m_productType
Holds the enumeration specifying the product type.
unsigned int ossim_uint32
bool isValidRLevel(ossim_uint32 reduced_res_level) const
static const char * NUMBER_OUTPUT_BANDS_KW
void setEntry(const ossimFilename &rootDirectory, const ossimFilename &pathToFrameFileFromRoot)
virtual ossimIrect getImageRectangle() const
static const char * DECIMAL_DEGREES_PER_PIXEL_LON
unsigned char * m_compressedBuffer
This is for storage of a single compressed buffer.
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Populates the geometry object with image geometry information.
static const char * LL_LAT_KW
virtual bool open()
Pure virtual open.
const ossimIpt & lr() const
Definition: ossimIrect.h:276
ossim_uint32 width() const
Definition: ossimIrect.h:500
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
double lon
Definition: ossimDpt.h:164
virtual void establishDecimationFactors()
Virtual method determines the decimation factors at each resolution level.
ossimScalarType
Method to load the state of an object from a keyword list.
virtual ossim_uint32 getImageTileWidth() const
static const char * ORIGIN_LATITUDE_KW
return status
ossimErrorCode parseFile(const ossimFilename &filename, bool minimalParse=false)
virtual void makeBlank()
Default constructor.
virtual void completeOpen()
Will complete the opening process.
ossimIpt m_tileSize
The size of the output tile.
std::vector< std::vector< ossimRpfFrameEntry > > m_frameEntryArray
ossimString toString(ossim_uint32 precision=15) const
Definition: ossimDpt.cpp:160
ossimRefPtr< ossimImageHandler > theOverview
void setActualImageRect()
Will shift the rect and clamp it so not to go outside the -180 to 180 degree range.
This class defines an abstract Handler which all image handlers(loaders) should derive from...
static const ossim_uint32 CIBCADRG_FRAME_WIDTH
CONSTANT representing the width of a Frame.
unsigned char * m_uncompressedBuffer
This is used as a buffer to uncompress the data to.
ossim_int32 y
Definition: ossimIpt.h:142
void fillSubTileCadrg(const ossimRpfFrame &aFrame, const ossimIrect &tileRect, const ossimFrameEntryData &frameEntryData, ossimImageData *tile)
Will uncompress the CADRG file using a VQ decompression algorithm.
void makeNan()
Definition: ossimIrect.h:329
void checkLongitude(ossim_float64 &leftLon, const ossim_float64 &rightLon) const
Method to test for 180.0 <–> 180.00 and set leftLon to -180 if both left and right are 180...
virtual ossim_uint32 getNumberOfInputBands() const
This method allows you to query the number of input bands.
static const char * UL_LON_KW
static const char * UR_LAT_KW
static const char * UR_LON_KW
bool empty() const
Definition: ossimString.h:411
class ossimNBandLutDataObject
ossimFilename theOverviewFile
void fillTile(const ossimIrect &tileRect, const vector< ossimFrameEntryData > &framesInvolved, ossimImageData *tile)
This is a wrapper for the fill cib and fill cadrg.
ossimString ext() const
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
ossim_int32 x
Definition: ossimIpt.h:141
virtual ossim_uint32 getTileHeight() const
Returns the height of the output tile.
static const char * TIE_POINT_LAT_KW
ossimRefPtr< ossimNBandLutDataObject > theLut
8 bit unsigned integer
#define RTTI_DEF1(cls, name, b1)
Definition: ossimRtti.h:485
const ossimRpfCompressionSection * getCompressionSection() const
Definition: ossimRpfFrame.h:76
virtual void close()
Closes this image handler and deletes any allocated data.
bool isOpen() const
Determines if its open if there eists a table of contents object.
static const char * NUMBER_SAMPLES_KW
unsigned char ossim_uint8
virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level=0) const
ossim_uint32 m_numberOfSamples
This will be computed based on the frames organized within the directory.
8 bit unsigned iteger
ossim_uint32 m_numberOfLines
int ossim_int32
