ossimDtedTileSource.cpp
Go to the documentation of this file.
1 //---
2 //
3 // License: MIT
4 //
5 // Author: David Burken
6 //
7 // Description:
8 //
9 // Contains class declaration for ossimDtedTileSource.
10 //
11 //---
12 // $Id$
13
16 #include <ossim/base/ossimCommon.h>
18 #include <ossim/base/ossimTrace.h>
22 #include <ossim/base/ossimDatum.h>
30 #include <cstdlib>
31 #include <iostream>
32 using namespace std;
33
34 RTTI_DEF1(ossimDtedTileSource, "ossimDtedTileSource", ossimImageHandler)
35
36 // Static trace for debugging
37 static ossimTrace traceDebug("ossimDtedTileSource:debug");
38
39
41  :
43  theTile(0),
44  m_fileStr(0),
45  m_dtedInfo(0),
46  theTileWidth(0),
47  theTileHeight(0),
48  theNumberOfLines(0),
49  theNumberOfSamps(0),
50  theOffsetToFirstDataRecord(0),
51  theDataRecordSize(0),
52  theMinHeight(0),
53  theMaxHeight(0),
54  thePostSpacing(0.0, 0.0),
55  theSwapBytesFlag(false)
56 {
58  {
59  theSwapBytesFlag = true;
60  }
61
62  // Set the tile size to the default.
65  theTileWidth = static_cast<ossim_uint32>(defaultTileSize.x);
66  theTileHeight = static_cast<ossim_uint32>(defaultTileSize.y);
67
68  // Construction not complete. Users should call "open" method.
69 }
70
72 {
73  close();
74 }
75
77 {
78  return ossimString("dted");
79 }
80
82 {
83  return ossimString("dted reader");
84 }
85
87  const ossimIrect& tile_rect, ossim_uint32 resLevel)
88 {
89  if (!theTile.valid())
90  {
91  allocate(); // First getTile call or after changeTileSize.
92  if (!theTile.valid())
93  {
94  return ossimRefPtr<ossimImageData>(); // Throw exception???
95  }
96  }
97
98  // Image rectangle must be set prior to calling getTile.
99  theTile->setImageRectangle(tile_rect);
100
101  if ( getTile( theTile.get(), resLevel ) == false )
102  {
104  {
105  theTile->makeBlank();
106  }
107  }
108
109  return theTile;
110 }
111
113  ossim_uint32 resLevel)
114 {
115  bool status = false;
116
117  //---
118  // Not open, this tile source bypassed, or invalid res level,
119  // return a blank tile.
120  //---
121  if( isOpen() && isSourceEnabled() && isValidRLevel(resLevel) &&
122  result && (result->getNumberOfBands() == getNumberOfOutputBands()) )
123  {
124  result->ref(); // Increment ref count.
125
126  //---
127  // Check for overview tile. Some overviews can contain r0 so always
128  // call even if resLevel is 0. Method returns true on success, false
129  // on error.
130  //---
131  status = getOverviewTile(resLevel, result);
132
133  if ( !status ) // Did not get an overview tile.
134  {
135  ossimIrect image_rect = getImageRectangle(resLevel);
136
137  ossimIrect tile_rect = result->getImageRectangle();
138
139  //---
140  // See if any point of the requested tile is in the image.
141  //---
142  if ( tile_rect.intersects(image_rect) )
143  {
144  ossimIrect clip_rect = tile_rect.clipToRect(image_rect);
145
146  if ( !tile_rect.completely_within(clip_rect) )
147  {
148  // Start with a blank tile.
149  result->makeBlank();
150  }
151
152  // Load the tile buffer with data from the dted cell.
153  status = fillBuffer(tile_rect, clip_rect, result);
154
155  } // End of if ( tile_rect.intersects(image_rect) )
156  }
157
158  result->unref(); // Decrement ref count.
159  }
160
161  return status;
162 }
163
164 //*******************************************************************
165 // Private Method:
166 //*******************************************************************
168  const ossimIrect& clip_rect,
169  ossimImageData* tile)
170 {
171  //***
172  // NOTE:
173  // Elevation posts are organized positive line up.
174  // The "tile_rect" and "clip_rect" is organized positive line down.
175  //***
176
177  const ossim_int32 TILE_WIDTH = tile->getWidth();
178
179  //***
180  // Position the file pointer to the first record needed.
181  // Posts are organized positive line up so we're going to start at
182  // the lower left side of the cell so all reads are going forward in
183  // the file.
184  //***
185  ossim_int32 seek_position = theOffsetToFirstDataRecord +
186  (clip_rect.ul().x * theDataRecordSize);
187  seek_position += DATA_RECORD_OFFSET_TO_POST +
188  (theNumberOfLines - 1 - clip_rect.lr().y) * 2;
189
190  //***
191  // Get a pointer positioned at the first valid pixel in
192  // the tile. Tiles are organized positive line down.
193  //***
194  ossim_sint16* d = static_cast<ossim_sint16*>(tile->getBuf());
195
196  // Loop in the longitude or sample direction.
197  for (ossim_int32 samp = clip_rect.ul().x; samp <= clip_rect.lr().x; samp++)
198  {
199  ossim_int32 d_offset = (clip_rect.lr().y - tile_rect.ul().y) *
200  TILE_WIDTH +
201  (samp - tile_rect.ul().x);
202
203  m_fileStr->seekg(seek_position, ios::beg); // Seek to the first post.
204
205  for (ossim_int32 line = clip_rect.lr().y; line >= clip_rect.ul().y; line--)
206  {
207  // Grab all the post needed from the column.
208  ossim_uint16 temp;
209  ossim_sint16 s;
210  m_fileStr->read((char*)&temp, POST_SIZE);
211  s = convertSignedMagnitude(temp);
212  d[d_offset] = s;
213  d_offset -= TILE_WIDTH;
214  }
215  seek_position += theDataRecordSize;
216  }
217
218  tile->validate();
219
220  return true;
221 }
222
224 {
225  return getNumberOfInputBands();
226 }
227
230 {
231  return ossimIrect(0,
232  0,
233  getNumberOfSamples(reduced_res_level) - 1,
234  getNumberOfLines(reduced_res_level) - 1);
235 }
236
238 {
239  return (m_fileStr!=0);
240 }
241
243 {
244  m_fileStr.reset();
245 }
246
248 {
249  static const char MODULE[] = "ossimDtedTileSource::open";
250
251  if (traceDebug())
252  {
253  CLOG << "DEBUG:"
254  << "\nAttempting to parse file: " << theImageFile.c_str()
255  << endl;
256  }
257  std::shared_ptr<ossim::istream> str = ossim::StreamFactoryRegistry::instance()->
258  createIstream( theImageFile.c_str(), std::ios_base::in|std::ios_base::binary);
259
260  // Open up the file for reading.
261  if (!str)
262  {
264
265  if(traceDebug())
266  {
267  ossimNotify(ossimNotifyLevel_WARN) << MODULE << " ERROR!"
268  << "\nCould not open file: " << theImageFile.c_str()
269  << "\nReturning..." << endl;
270  CLOG << "returning with error..." << endl;
271  }
272  return false;
273  }
274
275  if(!str)
276  {
277  if (traceDebug())
278  {
279  CLOG << "DEBUG:"
280  << "\nCannot open: " << theImageFile.c_str()
281  << endl;
282  }
283  str.reset();
284  return false;
285  }
286  std::string connectionString = theImageFile.c_str();
287  m_dtedInfo = std::make_shared<ossimDtedInfo>();
288  if(!m_dtedInfo->open(str, connectionString))
289  {
290  close();
291  return false;
292  }
293  m_fileStr = str;
294  m_fileStr->clear();
295  m_fileStr->seekg(0);
296
297  m_vol.parse(*str);
298  m_hdr.parse(*str);
299  m_uhl.parse(*str);
300  m_dsi.parse(*str);
301  m_acc.parse(*str);
302
303  //***
304  // Check for errors. Must have uhl, dsi and acc records. vol and hdr
305  // are for magnetic tape only; hence, may or may not be there.
306  //***
310  {
311  if (traceDebug())
312  {
313  CLOG << "DEBUG:"
314  << "\nError parsing file: " << theImageFile.c_str()
315  << "\nPossibly not a dted file.\n";
316  }
317
318  str.reset();
319  return false;
320  }
321  m_fileStr = str;
322
323  // Get the cell specific info needed for later.
330  (theNumberOfLines * sizeof(ossim_sint16)) +
332
333  //---
334  // Note:
335  // Complete open calls loadMetaData which we have overriden to check for
336  // dot omd or dot statistics file. If not there it will call
337  // gatherStatistics which will scan the file for min/max values.
338  //---
339  completeOpen();
340
341  if (traceDebug())
342  {
343  CLOG << "DEBUG:"
344  << "\nNull pix: " << getNullPixelValue(0)
345  << "\nMin pix: " << getMinPixelValue(0)
346  << "\nMax pix: " << getMaxPixelValue(0)
347  << "\ntheNumberOfLines: " << theNumberOfLines
348  << "\ntheNumberOfSamps: " << theNumberOfSamps
349  << "\ntheOffsetToFirstDataRecord: " << theOffsetToFirstDataRecord
350  << "\ntheDataRecordSize: " << theDataRecordSize << "\n";
351  }
352
353  return true;
354 }
355
357 {
358  //---
359  // Set up the tiles. Note the blank tile will not get initialized to save
360  // memory. This includes setting the min and max pixel value gathered
361  // from the statistics.
362  //---
364  if(theTile.valid())
365  {
366  theTile->initialize();
367  }
368
369  if (traceDebug())
370  {
372  << "DEBUG:"
373  << "\ntheTile:\n" << *theTile << "\n";
374  }
375 }
376
378  const char* prefix) const
379 {
380  // Currently nothing to do here.
381  return ossimImageHandler::saveState(kwl, prefix);
382 }
383
385  const char* prefix)
386 {
387  if (ossimImageHandler::loadState(kwl, prefix))
388  {
390  {
391  return true;
392  }
393  }
394
395  return false;
396 }
397
398 //**************************************************************************************************
399 // Returns the image geometry object associated with this tile source or NULL if not defined.
400 // The geometry contains full-to-local image transform as well as projection (image-to-world)
401 //**************************************************************************************************
403 {
404  if ( theGeometry.valid() )
405  return theGeometry;
406
407  // Compute the projection tie point (UL corner of dted cell). The UHL supplies the SW (LL) corner
408  // coordinates, so need to compute the UL lat from the cell spacing:
409  const ossimDatum* datum = ossimDatumFactory::instance()->wgs84();
410  ossim_float64 ul_lat = m_uhl.latOrigin() + (m_uhl.latInterval() * (m_uhl.numLatPoints()-1.0));
411  ossim_float64 ul_lon = m_uhl.lonOrigin();
412  ossimGpt tie(ul_lat, ul_lon, 0.0, datum);
413
414  //---
415  // This code is backed out as it affects the corner.
416  // E.g.: image0.ur_lon: -88.999999999995
417  // Should be -89.0
418  // Used ossimImageGeometry::::getMetersPerPixel for a center of the image gsd. (drb)
419  //
420  // We also need to define an origin for the projection as the center of the cell for proper GSD
421  // calculation (OLK 01/11: Used to set origin at 0,0 causing incorrect meters GSD to be
422  // computed)
423  // ossim_float64 mid_lat = m_uhl.latOrigin() + (m_uhl.latInterval()*m_uhl.numLatPoints()/2.0);
424  // ossim_float64 mid_lon = m_uhl.lonOrigin() + (m_uhl.lonInterval()*m_uhl.numLonLines()/2.0);
425  // ossimGpt origin (mid_lat, mid_lon, 0.0, datum);
426  //---
427  ossimGpt origin (0.0, 0.0, 0.0, datum);
428
429  // Make an Equidistant Cylindrical projection.
431  new ossimEquDistCylProjection(*(datum->ellipsoid()));
432
433  // Set the scale:
434  eq->setOrigin(origin);
435  eq->setUlTiePoints(tie);
437  eq->setDecimalDegreesPerPixel(gsd);
438
439  // Give it to the geometry object.
440  ossimRefPtr<ossimProjection> proj = eq.get();
441
442  // Make the geometry:
444
445  // Set the projection.
446  theGeometry->setProjection( proj.get() );
447
448  // Set image things the geometry object should know about.
450
451  return theGeometry;
452 }
453
455 {
456  return OSSIM_SSHORT16; // Always signed 16 bit.
457 }
458
460 {
461  return theTileWidth;
462 }
463
465 {
466  return theTileHeight;
467 }
468
470 {
471  if (reduced_res_level == 0)
472  {
473  return theNumberOfLines;
474  }
475  else if (theOverview.valid())
476  {
477  return theOverview->getNumberOfLines(reduced_res_level);
478  }
479
480  return 0;
481 }
482
484 {
485  if (reduced_res_level == 0)
486  {
487  return theNumberOfSamps;
488  }
489  else if (theOverview.valid())
490  {
491  return theOverview->getNumberOfSamples(reduced_res_level);
492  }
493
494  return 0;
495 }
496
498 {
499  ossimKeywordlist kwl;
500  const char* min_str = 0;
501  const char* max_str = 0;
502
504
505  // Check for omd file.
506  f.setExtension("omd");
507  if ( f.exists() )
508  {
509  kwl.addFile(f);
510  min_str = kwl.find("band1.min_value");
511  max_str = kwl.find("band1.max_value");
512  }
513
514  if ( !min_str || !max_str )
515  {
516  f.setExtension("statistics");
517  if ( f.exists() )
518  {
519  kwl.addFile(f);
520  min_str = kwl.find(ossimKeywordNames::MIN_VALUE_KW);
521  max_str = kwl.find(ossimKeywordNames::MAX_VALUE_KW);
522  }
523  }
524
525  if ( min_str || max_str )
526  {
527  theMinHeight = atoi(min_str);
528  theMaxHeight = atoi(max_str);
529  }
530  else
531  {
532  gatherStatistics(false);
533  }
534 }
535
536 void ossimDtedTileSource::gatherStatistics(bool writeStatsFile)
537 {
538  // Scan the cell and gather the statistics...
539  if ( traceDebug() )
540  {
542  << "ossimDtedTileSource::gatherStatistics() scanning for min/max"
543  << "\nThis may take a while...\n";
544  }
545
546  // Start off with the min and max pegged.
547  theMinHeight = 32767;
548  theMaxHeight = -32767;
549
550  // Put the file pointer at the start of the first elevation post.
551  m_fileStr->seekg(theOffsetToFirstDataRecord, ios::beg);
552
553  //---
554  // Loop through all records and scan for lowest min and highest max.
555  // Each record contains a row of latitude points for a given longitude.
556  // There are eight bytes in front of the post and four checksum bytes at
557  // the end so ignore them.
558  //---
559  for (ossim_uint32 i=0; i<theNumberOfSamps; i++) // longitude direction
560  {
561  m_fileStr->seekg(DATA_RECORD_OFFSET_TO_POST, ios::cur);
562
563  for (ossim_uint32 j=0; j<theNumberOfLines; j++) // latitude direction
564  {
565  ossim_uint16 temp;
566  ossim_sint16 s;
567  m_fileStr->read((char*)&temp, POST_SIZE);
568  s = convertSignedMagnitude(temp);
569  if (s < theMinHeight && s != NULL_PIXEL) theMinHeight = s;
570  if (s > theMaxHeight) theMaxHeight = s;
571  }
572
573  m_fileStr->seekg(DATA_RECORD_CHECKSUM_SIZE, ios::cur);
574  }
575
576  if ( writeStatsFile )
577  {
578  // Add the stats to the keyword list.
579  ossimKeywordlist kwl;
582
583  // Write out the statistics file.
585  f.setExtension("statistics");
586  kwl.write( f.c_str() );
587  }
588
589  if (traceDebug())
590  {
592  << "ossimDtedTileSource::gatherStatistics DEBUG:"
593  << "\ntheMinHeight: " << theMinHeight
594  << "\ntheMaxHeight: " << theMaxHeight
595  << "\n";
596  }
597 }
598
600 {
601  return 0;
602 }
603
605 {
606  return 0;
607 }
608
610 {
611  return 1;
612 }
613
615 {
617  {
618  return theMetaData.getNullPix(0);
619  }
620  return -32767.0;
621 }
623 {
625  {
626  return theMetaData.getMinPix(band);
627  }
628  return theMinHeight;
629 }
630
632 {
634  {
635  return theMetaData.getMaxPix(band);
636  }
637  return theMaxHeight;
638 }
639
641 {
642  postSpacing.x = thePostSpacing.x;
643  postSpacing.y = thePostSpacing.y;
644 }
645
647  const ossimString& name)const
648 {
649  // look in base class.
651
652  if (result.valid() == false)
653  {
654 // ossimDtedInfo info;
655 // std::string connectionString = theImageFile.c_str();
656  if (m_dtedInfo)
657  {
658  result = m_dtedInfo->getProperty(name);
659  }
660  }
661
662  return result;
663 }
664
666  std::vector<ossimString>& propertyNames) const
667 {
669
670  if (m_dtedInfo)
671  {
672  m_dtedInfo->getPropertyNames(propertyNames);
673  }
674 // ossimDtedInfo info;
675 // if (info.open(theImageFile))
676 // {
677 // info.getPropertyNames(propertyNames);
678 // }
679 }
680
682 {
683  return rhs;
684 }
685
687 {
688 }
double latOrigin() const
virtual bool open()=0
Pure virtual open.
ossim_int32 stopOffset() const
static const char * MIN_VALUE_KW
ossimRefPtr< ossimImageGeometry > theGeometry
virtual ossim_uint32 getTileWidth() const
Returns the width of the output tile.
double latInterval() const
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level=0) const
Returns the number of samples in the image.
#define CLOG
Definition: ossimTrace.h:23
ossimFilename theImageFile
double getMinPix(ossim_uint32 band) const
bool addFile(const char *file)
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
virtual ossimString getShortName() const
static const char * MAX_VALUE_KW
double y
Definition: ossimDpt.h:165
Gets a property for name.
bool theSwapBytesFlag
DTED data is always stored as BIG_ENDIAN.
OSSIM_DLL void defaultTileSize(ossimIpt &tileSize)
double getMaxPix(ossim_uint32 band) const
const ossimIpt & ul() const
Definition: ossimIrect.h:274
Adds this class&#39;s properties to list.
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
static const ossimErrorCode OSSIM_ERROR
virtual void setDecimalDegreesPerPixel(const ossimDpt &gsd)
static StreamFactoryRegistry * instance()
void parse(std::istream &in)
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
unsigned short ossim_uint16
ossim_uint32 theDataRecordSize
virtual bool write(const char *file, const char *comment=0) const
Methods to dump the ossimKeywordlist to a file on disk.
double getNullPix(ossim_uint32 band) const
virtual void initialize()
Initialize the data buffer.
void ref() const
increment the reference count by one, indicating that this object has another pointer which is refere...
ossim_uint32 getNumberOfBands() const
ossim_int32 numLatPoints() const
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
bool completely_within(const ossimIrect &rect) const
Definition: ossimIrect.cpp:425
virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level=0) const
Returns the number of lines in the image.
double ossim_float64
bool fillBuffer(const ossimIrect &tile_rect, const ossimIrect &clip_rect, ossimImageData *tile)
virtual ossim_uint32 getImageTileWidth() const
void getPostSpacing(ossimDpt &postSpacing) const
Initializes spacing to the post spacing of the cell.
virtual bool getOverviewTile(ossim_uint32 resLevel, ossimImageData *result)
Method to get an overview tile.
void gatherStatistics(bool writeStatsFile)
Scans for min and max.
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tile_rect, ossim_uint32 resLevel=0)
virtual ossimString getLongName() const
virtual void loadMetaData()
Sets the min/max.
bool exists() const
signed short ossim_sint16
unsigned int ossim_uint32
virtual const ossimEllipsoid * ellipsoid() const
Definition: ossimDatum.h:60
static ossimDatumFactory * instance()
virtual ossimIrect getImageRectangle() const
virtual void close()
const ossimIpt & lr() const
Definition: ossimIrect.h:276
virtual void setOrigin(const ossimGpt &origin)
Retuns the min pixel value.
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
virtual bool open()
Returns true if "theImageFile" can be opened and is a valid adrg file.
ossimScalarType
void unref() const
decrement the reference count by one, indicating that a pointer to this object is referencing it...
return status
virtual void makeBlank()
virtual void completeOpen()
Will complete the opening process.
ossimImageMetaData theMetaData
ossimRefPtr< ossimImageHandler > theOverview
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual ossimErrorCode getErrorStatus() const
virtual bool isOpen() const
ossim_int32 y
Definition: ossimIpt.h:142
void allocate()
Allocated the tiles.
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
ossimFilename fileNoExtension() const
double x
Definition: ossimDpt.h:164
virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level=0) const
Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in...
const char * c_str() const
Definition: ossimString.h:396
ossim_uint32 theOffsetToFirstDataRecord
double lonOrigin() const
std::shared_ptr< ossimDtedInfo > m_dtedInfo
virtual void setUlTiePoints(const ossimGpt &gpt)
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
ossim_int32 x
Definition: ossimIpt.h:141
ossim_int32 numLonLines() const
const ossimDatum * wgs84() const
#define RTTI_DEF1(cls, name, b1)
Definition: ossimRtti.h:485
const ossimDtedTileSource & operator=(const ossimDtedTileSource &rhs)
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
virtual ossim_uint32 getNumberOfInputBands() const
Returns the number of bands in the image.
virtual ossim_uint32 getImageTileHeight() const
std::shared_ptr< ossim::istream > m_fileStr
16 bit signed integer
ossim_sint16 convertSignedMagnitude(ossim_uint16 &s) const
virtual ossim_uint32 getTileHeight() const
Returns the height of the output tile.
double lonInterval() const
int ossim_int32
