Public Member Functions | Protected Member Functions | Private Member Functions | Private Attributes | List of all members
ossimGeneralRasterWriter Class Reference
#include <ossimGeneralRasterWriter.h>
Inheritance diagram for ossimGeneralRasterWriter:
ossimImageFileWriter ossimImageWriter ossimProcessInterface ossimConnectableObjectListener ossimOutputSource ossimListener ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
 ossimGeneralRasterWriter ()
 default constructor More...
virtual void getImageTypeList (std::vector< ossimString > &imageTypeList) const
 void getImageTypeList(std::vector<ossimString>& imageTypeList)const More...
virtual ossimString getExtension () const
 Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for image file extensions. More...
virtual void set_rr_level (ossim_uint32 rr)
virtual bool isOpen () const
virtual bool open ()
virtual void close ()
 saves the state of the object. More...
virtual bool writeStream ()
 Method to write the image to a stream. More...
virtual bool setOutputStream (std::ostream &stream)
 Sets the output stream to write to. More...
- Public Member Functions inherited from ossimImageFileWriter
 ossimImageFileWriter (const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0)
 The writer will own the sequencer. More...
virtual ~ossimImageFileWriter ()
virtual bool getOutputHasInternalOverviews (void) const
 Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nitf_j2k. More...
virtual bool hasImageType (const ossimString &imageType) const
 bool hasImageType(const ossimString& imageType) const More...
virtual void setTileSize (const ossimIpt &tileSize)
 Sets the output image tiling size if supported by the writer. More...
virtual bool writeEnviHeaderFile ()
 Will write an envi header file. More...
virtual bool writeErsHeaderFile ()
 Will write an ER Mapper header file. More...
virtual bool writeExternalGeometryFile ()
 Will write an external geometry file. More...
virtual bool writeFgdcFile ()
 Will write an fgdc file. More...
virtual bool writeHistogramFile ()
 Returns true on success, false on error. More...
virtual bool writeJpegWorldFile ()
 Will write a jpeg world file. More...
virtual bool writeOverviewFile (ossim_uint16 tiff_compress_type=1, ossim_int32 jpeg_compress_quality=75, bool includeR0=false)
 Write out an ossim overview file from the source_file. More...
virtual bool writeReadmeFile ()
 Will write a readme file. More...
virtual bool writeTiffWorldFile ()
 Will write a world file. More...
virtual bool writeWorldFile ()
virtual bool writeMetaDataFiles ()
 Convenience method that calls meta data write methods that are flagged to be called. More...
virtual void setAreaOfInterest (const ossimIrect &inputRect)
virtual void changeSequencer (ossimImageSourceSequencer *sequencer)
 Sets the sequencer and connects it to the input of this. More...
virtual ossimImageSourceSequencergetSequencer ()
virtual void initialize ()
 Initialize method. More...
virtual bool execute ()
 Calls: writeFile() writeMetaDataFiles() More...
virtual bool setOutputStream (ossimRefPtr< ossimOStream > stream)
virtual ossimRefPtr< ossimOStreamgetOutputStream () const
 Method to return the stream attached to output. More...
virtual void setOutputImageType (ossim_int32 type)
virtual void setOutputImageType (const ossimString &type)
virtual ossim_int32 getOutputImageType () const
virtual ossimString getOutputImageTypeString () const
virtual void setOutputName (const ossimString &outputName)
virtual void setFilename (const ossimFilename &file)
virtual bool canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const
virtual bool getWriteImageFlag () const
 Control flags... More...
virtual bool getWriteHistogramFlag () const
virtual bool getWriteOverviewFlag () const
virtual bool getScaleToEightBitFlag () const
virtual bool getWriteEnviHeaderFlag () const
virtual bool getWriteErsHeaderFlag () const
virtual bool getWriteExternalGeometryFlag () const
virtual bool getWriteFgdcFlag () const
virtual bool getWriteJpegWorldFileFlag () const
virtual bool getWriteReadmeFlag () const
virtual bool getWriteTiffWorldFileFlag () const
virtual bool getWriteWorldFileFlag () const
virtual void setWriteImageFlag (bool flag)
virtual void setWriteOverviewFlag (bool flag)
virtual void setWriteHistogramFlag (bool flag)
virtual void setScaleToEightBitFlag (bool flag)
virtual void setWriteEnviHeaderFlag (bool flag)
virtual void setWriteErsHeaderFlag (bool flag)
virtual void setWriteExternalGeometryFlag (bool flag)
virtual void setWriteFgdcFlag (bool flag)
virtual void setWriteJpegWorldFile (bool flag)
virtual void setWriteReadme (bool flag)
virtual void setWriteTiffWorldFile (bool flag)
virtual void setWriteWorldFile (bool flag)
virtual ossim_uint16 getOverviewCompressType () const
virtual ossim_int32 getOverviewJpegCompressQuality () const
virtual void setOverviewCompressType (ossim_uint16 type)
virtual void setOverviewJpegCompressQuality (ossim_int32 quality)
 Overrides base "addListener" this will capture the pointer and then call the base class "addListener". More...
 Overrides base "removeListener". More...
virtual void setPixelType (ossimPixelType type)
 If "point" the coordinate tie points are relative to the center of the pixel. More...
virtual void setPixelType (const ossimString &type)
virtual ossimPixelType getPixelType () const
virtual void getPixelTypeString (ossimString &type) const
- Public Member Functions inherited from ossimImageWriter
 ossimImageWriter (ossimObject *owner=NULL)
 ossimImageWriter (ossimObject *owner, ossim_uint32 numberOfInputs, ossim_uint32 numberOfOutputs, bool inputListIsFixed, bool outputListIsFixed)
virtual ~ossimImageWriter ()
virtual bool setViewingRect (const ossimIrect &aRect)
virtual ossimIrect getAreaOfInterest () const
- Public Member Functions inherited from ossimOutputSource
 ossimOutputSource (ossimObject *owner=NULL)
 ossimOutputSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true)
virtual ~ossimOutputSource ()
virtual bool open (const ossimString &outputName)
virtual const ossimStringgetOutputName ()
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
- Public Member Functions inherited from ossimProcessInterface
 ossimProcessInterface ()
virtual void abort ()
bool needsAborting () const
bool isAborted () const
bool isExecuting () const
void enableEvents ()
void disableEvents ()
 ProcessEvent. More...
virtual void refreshEvent (ossimRefreshEvent &)
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
virtual bool writeFile ()
 Write out the file. More...
virtual ~ossimGeneralRasterWriter ()
 Protected ( this is a ossimRefPtr) destructor. More...
- Protected Member Functions inherited from ossimImageFileWriter
bool writeWorldFile (const ossimFilename &file)
 Common world file writer method. More...
virtual ~ossimReferenced ()
bool writeToBip ()
 Writes image data to output file in BIP(Band Interleaved by Pixel) format. More...
bool writeToBil ()
 Writes image data to output file in BIL(Band Interleaved by Line) format. More...
bool writeToBsq ()
 Writes image data to output file in BSQ(Band Sequential) format. More...
void writeHeader () const
 Writes an ossim header file which can be used to load file in ossim. More...
void writeEnviHeader () const
 Writes an envi header file which can be used to load file in envi. More...
ossimString getInterleaveString () const
Private Attributes
std::ostream * theOutputStream
bool theOwnsStreamFlag
ossim_uint32 theRlevel
ossimByteOrder theOutputByteOrder
std::vector< double > theMinPerBand
 Populated while writting the data. More...
std::vector< double > theMaxPerBand
Additional Inherited Members
- Public Types inherited from ossimProcessInterface
enum  ossimProcessStatus {
- Protected Attributes inherited from ossimImageFileWriter
ossimRefPtr< ossimImageSourceSequencertheInputConnection
ossimRefPtr< ossimViewControllertheViewController
ossimListenertheProgressListener
ossimFilename theFilename
ossimString theOutputImageType
bool theWriteImageFlag
bool theWriteOverviewFlag
bool theWriteHistogramFlag
bool theScaleToEightBitFlag
ossim_uint16 theOverviewCompressType
ossim_int32 theOverviewJpegCompressQuality
bool theWriteEnviHeaderFlag
 External meta data writer flags. More...
bool theWriteErsHeaderFlag
bool theWriteExternalGeometryFlag
bool theWriteFgdcFlag
bool theWriteJpegWorldFileFlag
bool theWriteReadmeFlag
bool theWriteTiffWorldFileFlag
bool theWriteWorldFileFlag
bool theAutoCreateDirectoryFlag
ossimUnitType theLinearUnits
 If not a geographic projection this allows the user to set the linear units of the output tag to be: More...
ossimPixelType thePixelType
 OSSIM_PIXEL_IS_POINT = 0, OSSIM_PIXEL_IS_AREA = 1. More...
- Protected Attributes inherited from ossimImageWriter
ossimIrect theAreaOfInterest
- Protected Attributes inherited from ossimOutputSource
ossimString theOutputName
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
- Protected Attributes inherited from ossimProcessInterface
double thePercentComplete
ossimString theMessage
bool theEventFlag
bool theListenerEnableFlag
Detailed Description
Definition at line 25 of file ossimGeneralRasterWriter.h.
◆ ossimGeneralRasterWriter()
ossimGeneralRasterWriter::ossimGeneralRasterWriter ( )
default constructor
Definition at line 35 of file ossimGeneralRasterWriter.cpp.
References ossimEndian::getSystemEndianType(), OSSIM_GENERAL_RASTER_BSQ, ossimImageFileWriter::setOutputImageType(), ossimImageFileWriter::setWriteExternalGeometryFlag(), and theOutputByteOrder.
36  :
38  theOutputStream(0),
39  theOwnsStreamFlag(false),
40  theRlevel(0),
42  theMinPerBand(0),
43  theMaxPerBand(0)
44 {
46
47  // Since there is no internal geometry set the flag to write out one.
50 }
virtual void setOutputImageType(ossim_int32 type)
ossimImageFileWriter(const ossimFilename &filename=ossimFilename(), ossimImageSource *inputSource=0, ossimObject *owner=0)
ossimByteOrder getSystemEndianType() const
Definition: ossimEndian.h:78
virtual void setWriteExternalGeometryFlag(bool flag)
◆ ~ossimGeneralRasterWriter()
ossimGeneralRasterWriter::~ossimGeneralRasterWriter ( )
protectedvirtual
Definition at line 52 of file ossimGeneralRasterWriter.cpp.
References close(), and isOpen().
53 {
54  if(isOpen())
55  {
56  close();
57  }
58 }
Member Function Documentation
◆ close()
void ossimGeneralRasterWriter::close ( )
virtual
Generic interface to allow one to close a consumer. For displays this might minimize the window and free up internal pointers for file writers it will make sure the file stream is closed and flushed.
Implements ossimOutputSource.
Definition at line 93 of file ossimGeneralRasterWriter.cpp.
References theOutputStream, and theOwnsStreamFlag.
Referenced by open(), writeFile(), and ~ossimGeneralRasterWriter().
94 {
95  if (theOutputStream)
96  {
97  theOutputStream->flush();
99  {
100  delete theOutputStream;
101  theOwnsStreamFlag = false;
102  }
103  theOutputStream = 0;
104  }
105 }
◆ getExtension()
ossimString ossimGeneralRasterWriter::getExtension ( ) const
virtual
Parameters
imageTypestring representing image type.
Returns
the 3-letter string extension.
Reimplemented from ossimImageFileWriter.
Definition at line 819 of file ossimGeneralRasterWriter.cpp.
820 {
821  return "ras";
822  //return getInterleaveString();
823 }
◆ getImageTypeList()
void ossimGeneralRasterWriter::getImageTypeList ( std::vector< ossimString > &  imageTypeList) const
virtual
Appends this writer image types to list "imageTypeList".
This writer has the following types: general_raster_bip general_raster_bil general_raster_bsq
Parameters
imageTypeListstl::vector<ossimString> list to append to.
Implements ossimImageFileWriter.
Definition at line 825 of file ossimGeneralRasterWriter.cpp.
826 {
827  imageTypeList.push_back(ossimString("general_raster_bip"));
828  imageTypeList.push_back(ossimString("general_raster_bil"));
829  imageTypeList.push_back(ossimString("general_raster_bsq"));
830  imageTypeList.push_back(ossimString("general_raster_bip_envi"));
831  imageTypeList.push_back(ossimString("general_raster_bil_envi"));
832  imageTypeList.push_back(ossimString("general_raster_bsq_envi"));
833 }
◆ getInterleaveString()
ossimString ossimGeneralRasterWriter::getInterleaveString ( ) const
private
Returns
The interleave as a string of either: bil, bip, or bsq
Definition at line 835 of file ossimGeneralRasterWriter.cpp.
References ossimImageFileWriter::theOutputImageType.
836 {
837  ossimString interleaveType = "unknown";
838  if ( (theOutputImageType == "general_raster_bip") ||
839  (theOutputImageType == "general_raster_bip_envi") )
840  {
841  interleaveType = "bip";
842  }
843  else if ( (theOutputImageType == "general_raster_bil") ||
844  (theOutputImageType == "general_raster_bil_envi") )
845  {
846  interleaveType = "bil";
847  }
848  else if ( (theOutputImageType == "general_raster_bsq") ||
849  (theOutputImageType == "general_raster_bsq_envi") )
850  {
851  interleaveType = "bsq";
852  }
853  return interleaveType;
854 }
◆ isOpen()
bool ossimGeneralRasterWriter::isOpen ( ) const
virtual
Definition at line 60 of file ossimGeneralRasterWriter.cpp.
References theOutputStream.
Referenced by writeFile(), and ~ossimGeneralRasterWriter().
61 {
62  return ( theOutputStream ? true : false );
63 }
◆ loadState()
bool ossimGeneralRasterWriter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 651 of file ossimGeneralRasterWriter.cpp.
References ossimKeywordNames::BYTE_ORDER_KW, ossim::byteOrder(), ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimEndian::getSystemEndianType(), ossimKeywordNames::INPUT_RR_LEVEL_KW, ossimImageFileWriter::loadState(), OSSIM_BIG_ENDIAN, OSSIM_LITTLE_ENDIAN, ossimImageFileWriter::setFilename(), theOutputByteOrder, ossimImageFileWriter::theOutputImageType, and theRlevel.
653 {
654  const char* value;
655
656  value = kwl.find(prefix, ossimKeywordNames::FILENAME_KW);
657  if(value)
658  {
659  setFilename(ossimFilename(value));
660  }
661
662  value = kwl.find(prefix, ossimKeywordNames::INPUT_RR_LEVEL_KW);
663  if(value)
664  {
665  theRlevel = atoi(value);
666  }
667
668  if(ossimImageFileWriter::loadState(kwl, prefix))
669  {
670  if( (theOutputImageType!="general_raster_bip") &&
671  (theOutputImageType!="general_raster_bil") &&
672  (theOutputImageType!="general_raster_bsq") &&
673  (theOutputImageType!="general_raster_bip_envi") &&
674  (theOutputImageType!="general_raster_bil_envi") &&
675  (theOutputImageType!="general_raster_bsq_envi")
676  )
677  {
678  theOutputImageType = "general_raster_bsq";
679  }
680  }
681  else
682  {
683  return false;
684  }
685  const char* outputByteOrder = kwl.find(prefix, ossimKeywordNames::BYTE_ORDER_KW);
687  if(outputByteOrder)
688  {
689  ossimString byteOrder = outputByteOrder;
690  byteOrder = byteOrder.downcase();
691  if(byteOrder.contains("little"))
692  {
694  }
695  else if(byteOrder.contains("big"))
696  {
698  }
699  }
700
701  return true;
702 }
static const char * BYTE_ORDER_KW
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
static const char * INPUT_RR_LEVEL_KW
virtual void setFilename(const ossimFilename &file)
static const char * FILENAME_KW
◆ open()
bool ossimGeneralRasterWriter::open ( )
virtual
Allows a generic interface to open a consumer for writing. If you are a display writer then you would probably show the window or init the device context for writing.
Definition at line 65 of file ossimGeneralRasterWriter.cpp.
References ossimString::c_str(), close(), ossimString::size(), ossimImageFileWriter::theFilename, theOutputStream, and theOwnsStreamFlag.
Referenced by writeFile().
66 {
67  bool result = false;
68
69  close();
70
71  // Check for empty filenames.
72  if ( theFilename.size() )
73  {
74  std::ofstream* os = new std::ofstream();
75  os->open(theFilename.c_str(), ios::out | ios::binary);
76
77  if(os->is_open())
78  {
79  theOutputStream = os;
80  theOwnsStreamFlag = true;
81  result = true;
82  }
83  else
84  {
85  delete os;
86  os = 0;
87  }
88  }
89
90  return result;
91 }
std::string::size_type size() const
Definition: ossimString.h:405
const char * c_str() const
Definition: ossimString.h:396
std::basic_ofstream< char > ofstream
Class for char output file streams.
Definition: ossimIosFwd.h:47
◆ saveState()
bool ossimGeneralRasterWriter::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 640 of file ossimGeneralRasterWriter.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::BYTE_ORDER_KW, OSSIM_LITTLE_ENDIAN, ossimImageFileWriter::saveState(), and theOutputByteOrder.
642 {
643  kwl.add(prefix,
645  ((theOutputByteOrder==OSSIM_LITTLE_ENDIAN)?"little_endian":"big_endian"),
646  true);
648  prefix);
649 }
◆ set_rr_level()
virtual void ossimGeneralRasterWriter::set_rr_level ( ossim_uint32  rr)
inlinevirtual
Definition at line 56 of file ossimGeneralRasterWriter.h.
56 { theRlevel = rr; }
◆ setOutputStream()
bool ossimGeneralRasterWriter::setOutputStream ( std::ostream &  stream)
virtual
The stream will not be closed/deleted by this object.
Parameters
outputThe stream to write to.
Definition at line 856 of file ossimGeneralRasterWriter.cpp.
857 {
859  {
860  delete theOutputStream;
861  }
862  theOutputStream = &stream;
863  theOwnsStreamFlag = false;
864  return true;
865 }
◆ writeEnviHeader()
void ossimGeneralRasterWriter::writeEnviHeader ( ) const
private
If the output image file is "foo.ras" then the ossim header file will be "foo.hdr".
Definition at line 789 of file ossimGeneralRasterWriter.cpp.
790 {
791  static const char MODULE[] = "ossimGeneralRasterWriter::writeEnviHeader";
792
793  if (traceDebug()) CLOG << " Entered..." << endl;
794
795  if (!theInputConnection)
796  {
797  return;
798  }
799
800  // Make a header file name from the image file.
801  ossimFilename headerFile = theFilename;
802  headerFile.setExtension(".hdr"); // ossim meta data
803
804  ossimString interleaveType = getInterleaveString();
805  ossimKeywordlist kwl;
806  kwl.add(ossimKeywordNames::INTERLEAVE_TYPE_KW, interleaveType.c_str());
807
810  hdr->initialize();
811  hdr->setFilename(headerFile);
812  hdr->loadState(kwl);
814  hdr->execute();
815
816  if (traceDebug()) CLOG << " Exited..." << endl;
817 }
virtual void setAreaOfInterest(const ossimIrect &areaOfInterest)
Sets the area of interest to write the meta data for.
#define CLOG
Definition: ossimTrace.h:23
Initializes the state of the writer.
ossimRefPtr< ossimImageSourceSequencer > theInputConnection
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
static const char * INTERLEAVE_TYPE_KW
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
Class for writing a "ENVI" style header.
◆ writeFile()
bool ossimGeneralRasterWriter::writeFile ( )
protectedvirtual
Write out the file.
Returns
Definition at line 107 of file ossimGeneralRasterWriter.cpp.
References close(), ossimString::contains(), ossimErrorStatusInterface::getErrorStatus(), ossimImageFileWriter::getSequencer(), ossimImageSourceSequencer::isMaster(), isOpen(), open(), ossimErrorCodes::OSSIM_OK, ossimImageFileWriter::theInputConnection, ossimImageFileWriter::theOutputImageType, ossimRefPtr< T >::valid(), writeEnviHeader(), writeHeader(), and writeStream().
108 {
109  bool result = false;
110
112  {
113  //---
114  // Make sure we can open the file. Note only the master process is used for
115  // writing...
116  //---
118  {
119  if (!isOpen())
120  {
121  open();
122  }
123  }
124
125  result = writeStream();
126
127  if ( result )
128  {
129  // Do this only on the master process. Note left to right precedence!
130  if (getSequencer() && getSequencer()->isMaster())
131  {
132  //---
133  // Write the header out. We do this last since we must
134  // compute min max pixel while we are writting the image.
135  // since the header is an external text file this is Ok
136  // to do.
137  //---
138  writeHeader();
139
140  if (theOutputImageType.contains("envi"))
141  {
142  writeEnviHeader();
143  }
144  }
145  }
146
147  close();
148  }
149
150  return result;
151
152 } // End: ossimGeneralRasterWriter::writeFile()
virtual bool writeStream()
static const ossimErrorCode OSSIM_OK
bool valid() const
Definition: ossimRefPtr.h:75
bool contains(char aChar) const
Definition: ossimString.h:58
void writeEnviHeader() const
virtual ossimImageSourceSequencer * getSequencer()
virtual ossimErrorCode getErrorStatus() const
void writeHeader() const
◆ writeHeader()
void ossimGeneralRasterWriter::writeHeader ( ) const
private
Definition at line 704 of file ossimGeneralRasterWriter.cpp.
705 {
706  static const char MODULE[] = "ossimGeneralRasterWriter::writeHeader";
707
708  if (traceDebug()) CLOG << " Entered..." << std::endl;
709
710  // Make a header file name from the image file.
711  ossimFilename headerFile = theFilename;
712  headerFile.setExtension(".omd"); // ossim meta data
713
714  std::ofstream os;
715  os.open(headerFile.c_str(), ios::out);
716  if (!os)
717  {
718  ossimNotify(ossimNotifyLevel_FATAL) << MODULE << " Error:\n"
719  << "Could not open: " << headerFile << std::endl;
720  return;
721  }
722
723  ossimString interleaveType = getInterleaveString();
724
725  ossimString scalar =
727  getOutputScalarType());
728
729  os << "// *** ossim meta data general raster header file ***\n"
731  << theFilename.file().c_str() << "\n"
733  << getOutputImageTypeString() << "\n"
735  << interleaveType.c_str() << "\n"
739  << (theAreaOfInterest.lr().y - theAreaOfInterest.ul().y + 1) << "\n"
741  << (theAreaOfInterest.lr().x - theAreaOfInterest.ul().x + 1) << "\n"
743  << scalar.c_str() << "\n"
745  << ((theOutputByteOrder==OSSIM_BIG_ENDIAN)?"big_endian":"little_endian")
746  << "\n"
747  << std::endl;
748
749  // Output the null/min/max for each band.
750  os << "\n// NOTE: Bands are one based, band1 is the first band."
751  << std::endl;
752
754  {
756  ossimString::toString(i+1) + ".";
757
759  getNullPixelValue(i));
760  ossimString min_pix;
761  ossimString max_pix;
762
763  if(!theMinPerBand.size()||!theMaxPerBand.size())
764  {
766  getMinPixelValue(i));
768  getMaxPixelValue(i));
769  }
770  else
771  {
772  min_pix = ossimString::toString(theMinPerBand[i]);
773  max_pix = ossimString::toString(theMaxPerBand[i]);
774  }
775
776  os << prefix.c_str() << ossimKeywordNames::NULL_VALUE_KW << ": "
777  << null_pix.c_str() << "\n"
778  << prefix << ossimKeywordNames::MIN_VALUE_KW << ": "
779  << min_pix.c_str() << "\n"
780  << prefix << ossimKeywordNames::MAX_VALUE_KW << ": "
781  << max_pix.c_str() << std::endl;
782  }
783
784  os.close();
785
786  if (traceDebug()) CLOG << " Exited..." << endl;
787 }
static const char * MIN_VALUE_KW
#define CLOG
virtual ossimString getEntryString(ossim_int32 entry_number) const
static const char * MAX_VALUE_KW
static const char * NULL_VALUE_KW
Numeric to string methods.
static const char * NUMBER_LINES_KW
const ossimIpt & ul() const
Definition: ossimIrect.h:274
static ossimScalarTypeLut * instance()
Returns the static instance of an ossimScalarTypeLut object.
unsigned int ossim_uint32
const ossimIpt & lr() const
Definition: ossimIrect.h:276
static const char * NUMBER_BANDS_KW
static const char * BAND_KW
virtual ossimString getOutputImageTypeString() const
ossim_int32 y
Definition: ossimIpt.h:142
static const char * SCALAR_TYPE_KW
ossimFilename file() const
ossim_int32 x
Definition: ossimIpt.h:141
static const char * IMAGE_TYPE_KW
static const char * NUMBER_SAMPLES_KW
◆ writeStream()
bool ossimGeneralRasterWriter::writeStream ( )
virtual
Callers must call setOutputStream(...) method prior to this.
Returns
Definition at line 154 of file ossimGeneralRasterWriter.cpp.
References ossimErrorStatusInterface::getErrorStatus(), ossimImageSourceSequencer::isMaster(), ossimErrorCodes::OSSIM_OK, ossimNotify(), ossimNotifyLevel_FATAL, ossimImageSourceSequencer::slaveProcessTiles(), ossimImageFileWriter::theInputConnection, ossimImageFileWriter::theOutputImageType, theOutputStream, ossimRefPtr< T >::valid(), writeToBil(), writeToBip(), and writeToBsq().
155 {
156  static const char MODULE[] = "ossimGeneralRasterWriter::writeStream";
157
158  bool result = false;
159
162  {
163  if ( theInputConnection->isMaster() )
164  {
165  // Write the file with the image data.
166  if ( (theOutputImageType == "general_raster_bip") ||
167  (theOutputImageType == "general_raster_bip_envi") )
168  {
169  result = writeToBip();
170  }
171  else if ( (theOutputImageType == "general_raster_bil") ||
172  (theOutputImageType == "general_raster_bil_envi") )
173  {
174  result = writeToBil();
175  }
176  else if ( (theOutputImageType == "general_raster_bsq") ||
177  (theOutputImageType == "general_raster_bsq_envi") )
178  {
179  result = writeToBsq();
180  }
181  else
182  {
184  << MODULE << " ERROR:"
185  << "\nUnsupported output type: " << theOutputImageType << std::endl;
186  result = false;
187  }
188
189  if ( result )
190  {
191  // Flush the stream to disk...
192  theOutputStream->flush();
193  }
194  }
195  else // Matching else: if ( theInputConnection->isMaster() )
196  {
197  // Slave process:
199  result = true;
200  }
201  }
202
203  return result;
204
205 } // End: ossimGeneralRasterWriter::writeStream()
bool valid() const
bool writeToBil()
bool writeToBsq()
bool writeToBip()
◆ writeToBil()
bool ossimGeneralRasterWriter::writeToBil ( )
private
Returns
Definition at line 354 of file ossimGeneralRasterWriter.cpp.
Referenced by writeStream().
355 {
356  ossimEndian endian;
357  static const char* const MODULE = "ossimGeneralRasterWriter::writeToBil";
358
359  if (traceDebug()) CLOG << " Entered." << std::endl;
360
361  //***
362  // Get an arbitrary tile just to get the size in bytes!
363  // This should be changed later... An ossimImageSource should know
364  // this.
365  //***
368
375  ossim_uint64 bufferSizeInBytes = 0;
376  ossim_uint64 bytesInLine = 0;
377  unsigned char* buffer = NULL;
378
379  // Start with a clean min/max.
380  theMinPerBand.clear();
381  theMaxPerBand.clear();
382
384  bool wroteSomethingOut = false;
386  for(ossim_uint64 i = 0; ((i < tilesHigh)&&(!needsAborting())); ++i)
387  {
388  // Clear the buffer.
389  // Clear the buffer.
390  if(buffer)
391  {
392  memset(buffer, 0, bufferSizeInBytes);
393  }
394
395  ossimIrect bufferRect(theAreaOfInterest.ul().x,
396  theAreaOfInterest.ul().y + i*tileHeight,
397  theAreaOfInterest.ul().x + (width - 1),
398  theAreaOfInterest.ul().y + i *
399  tileHeight + (tileHeight - 1));
400
401  // Tile loop in the sample (width) direction.
402  for(ossim_uint64 j = 0; ((j < tilesWide)&&(!needsAborting())); ++j)
403  {
404  // Get the tile and copy it to the buffer.
406  if(id.valid())
407  {
409
410  if(!buffer)
411  {
412  bytesInLine = id->getScalarSizeInBytes() * width;
413
414  // Buffer to hold one line x tileHeight
415  bufferSizeInBytes = bytesInLine * tileHeight * bands;
416  buffer = new unsigned char[bufferSizeInBytes];
417  memset(buffer, 0, bufferSizeInBytes);
418  }
419  id->unloadTile(buffer,
420  bufferRect,
421  OSSIM_BIL);
422  }
423  ++tileNumber;
424  }
425
426  // Get the number of lines to write from the buffer.
427  ossim_uint64 linesToWrite =
428  min(tileHeight,
429  static_cast<ossim_uint64>(theAreaOfInterest.lr().y -
430  bufferRect.ul().y + 1));
431
432  // Write the buffer out to disk.
433  ossim_uint8* buf = buffer;
434  for (ossim_uint64 ii=0; ((ii<linesToWrite)&(!needsAborting())); ++ii)
435  {
436  for (ossim_uint64 band = 0;
437  ((band < bands)&&(!needsAborting()));
438  ++band)
439  {
440  wroteSomethingOut = true;
442  {
443  endian.swap(scalarType,
444  buf,
445  bytesInLine/ossim::scalarSizeInBytes(scalarType));
446  }
447  theOutputStream->write((char*)buf, bytesInLine);
448  if (theOutputStream->fail())
449  {
451  << MODULE << " ERROR:"
452  << "Error returned writing line!" << std::endl;
453  setErrorStatus();
454  if(buffer)
455  {
456  // Free the memory.
457  delete [] buffer;
458  }
459  return false;
460  }
461
462  buf += bytesInLine;
463  }
464
465  } // End of loop to write lines from buffer to tiff file.
466
467  double tile = tileNumber;
468  double numTiles = numberOfTiles;
469  setPercentComplete(tile / numTiles * 100);
470
471  if(needsAborting())
472  {
473  setPercentComplete(100.0);
474  }
475
476  } // End of loop in the line (height) direction.
477
478  if(buffer)
479  {
480  // Free the memory.
481  delete [] buffer;
482  }
483
484  if (traceDebug()) CLOG << " Exited." << std::endl;
485
486  return wroteSomethingOut;
487 }
#define CLOG
ossim_uint32 tileNumber
virtual void computeMinMaxPix(std::vector< ossim_float64 > &minBands, std::vector< ossim_float64 > &maxBands) const
If the minBands and maxBands are empty or not equal to the imageData&#39;s current number of bands it wil...
virtual ossimRefPtr< ossimImageData > getNextTile(ossim_uint32 resLevel=0)
unsigned long long ossim_uint64
OSSIM_DLL ossim_uint32 scalarSizeInBytes(ossimScalarType scalarType)
ossim_uint32 width() const
Definition: ossimIrect.h:500
ossimScalarType
ossim_int64 getNumberOfTilesHorizontal() const
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
ossim_int32 y
ossim_int32 x
virtual void setPercentComplete(double percentComplete)
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
unsigned char ossim_uint8
ossim_int64 getNumberOfTilesVertical() const
#define min(a, b)
Definition: auxiliary.h:75
◆ writeToBip()
bool ossimGeneralRasterWriter::writeToBip ( )
private
Returns
Definition at line 207 of file ossimGeneralRasterWriter.cpp.
208 {
209  ossimEndian endian;
210  static const char* const MODULE = "ossimGeneralRasterWriter::writeToBip";
211
212  if (traceDebug()) CLOG << " Entered." << std::endl;
213
214
215  //---
216  // Get an arbitrary tile just to get the size in bytes!
217  // This should be changed later... An ossimImageSource should know
218  // this.
219  //---
221
222  // Start the sequence at the first tile.
224
231
232  if (traceDebug())
233  {
235  << "\nossimGeneralRasterWriter::writeToBip DEBUG:"
236  << "\nbands: " << bands
237  << "\ntilesWide: " << tilesWide
238  << "\ntilesHigh: " << tilesHigh
239  << "\ntileHeight: " << tileHeight
240  << "\nnumberOfTiles: " << numberOfTiles
241  << "\nwidth: " << width
242  << std::endl;
243  }
244
245  //---
246  // Buffer to hold one line x tileHeight
247  //---
248  ossim_uint64 bufferSizeInBytes = 0;
249  ossim_uint64 bytesInLine = 0;
250  unsigned char* buffer = NULL;
251
252  theMinPerBand.clear();
253  theMaxPerBand.clear();
255  bool wroteSomethingOut = false;
257  for(ossim_uint64 i = 0; ((i < tilesHigh)&&(!needsAborting())); ++i)
258  {
259  // Clear the buffer.
260  if(buffer)
261  {
262  memset(buffer, 0, bufferSizeInBytes);
263  }
264
265  ossimIrect bufferRect(theAreaOfInterest.ul().x,
266  theAreaOfInterest.ul().y + i*tileHeight,
267  theAreaOfInterest.ul().x + (width - 1),
268  theAreaOfInterest.ul().y + i*tileHeight + (tileHeight - 1));
269  // Tile loop in the sample (width) direction.
270  for(ossim_uint64 j = 0; ((j < tilesWide)&&(!needsAborting())); ++j)
271  {
272  // Get the tile and copy it to the buffer.
274  if(id.valid())
275  {
277  if(!buffer)
278  {
279  bytesInLine = id->getScalarSizeInBytes() * width * bands;
280
281  //---
282  // Buffer to hold one line x tileHeight
283  //---
284  bufferSizeInBytes = bytesInLine * tileHeight;
285  buffer = new unsigned char[bufferSizeInBytes];
286  memset(buffer, 0, bufferSizeInBytes);
287  }
288  id->unloadTile(buffer,
289  bufferRect,
290  OSSIM_BIP);
291  }
292  ++tileNumber;
293  }
294
295  // Get the number of lines to write from the buffer.
296  ossim_uint64 linesToWrite =
297  min(tileHeight,
298  static_cast<ossim_uint64>(theAreaOfInterest.lr().y -
299  bufferRect.ul().y + 1));
300  // Write the buffer out to disk.
301  ossim_uint8* buf = buffer;
302  if(buf)
303  {
304  for (ossim_uint64 ii=0; ((ii<linesToWrite)&&(!needsAborting())); ++ii)
305  {
306  std::streamsize lineBytes = bytesInLine;
307  wroteSomethingOut = true;
308
310  {
311  endian.swap(scalarType,
312  buf,
313  lineBytes/ossim::scalarSizeInBytes(scalarType));
314  }
315  theOutputStream->write((char*)buf, lineBytes);
316  if (theOutputStream->fail())
317  {
319  << MODULE << " ERROR:"
320  << "Error returned writing line!" << std::endl;
321  setErrorStatus();
322  if(buffer)
323  {
324  // Free the memory.
325  delete [] buffer;
326  }
327  return false;
328  }
329
330  buf += bytesInLine;
331
332  } // End of loop to write lines from buffer to tiff file.
333  }
334  double tile = tileNumber;
335  double numTiles = numberOfTiles;
336  setPercentComplete(tile / numTiles * 100);
337  if(needsAborting())
338  {
339  setPercentComplete(100.0);
340  }
341
342  } // End of loop in the line (height) direction.
343  if(buffer)
344  {
345  // Free the memory.
346  delete [] buffer;
347  }
348
349  if (traceDebug()) CLOG << " Exited." << std::endl;
350
351  return wroteSomethingOut;
352 }
#define CLOG
ossimScalarType
ossim_int32 y
ossim_int32 x
#define min(a, b)
◆ writeToBsq()
bool ossimGeneralRasterWriter::writeToBsq ( )
private
Returns
Definition at line 489 of file ossimGeneralRasterWriter.cpp.
490 {
491  ossimEndian endian;
492  static const char* const MODULE = "ossimGeneralRasterWriter::writeToBsq";
493
494  if (traceDebug()) CLOG << " Entered." << std::endl;
495
496  //***
497  // Get an arbitrary tile just to get the size in bytes!
498  // This should be changed later... An ossimImageSource should know
499  // this.
500  //***
502
503  // Start the sequence at the first tile.
505
513
514  ossim_uint64 bytesInLine = 0;
515  ossim_uint64 buf_band_offset = 0;
516
517  // Use the system "streampos" typedef for future 64 bit seeks (long long).
518  streampos file_band_offset = 0;
519
520  //***
521  // Buffer to hold one line x tileHeight
522  //***
523  ossim_uint64 bufferSizeInBytes = 0;
524  unsigned char* buffer = NULL;
525
526  theMinPerBand.clear();
527  theMaxPerBand.clear();
528
530  bool wroteSomethingOut = false;
532  for(ossim_uint64 i = 0; ((i < tilesHigh)&&(!needsAborting())); ++i)
533  {
534  if(buffer)
535  {
536  // Clear the buffer.
537  memset(buffer, 0, bufferSizeInBytes);
538  }
539
540  ossimIrect bufferRect(theAreaOfInterest.ul().x,
541  theAreaOfInterest.ul().y + i*tileHeight,
542  theAreaOfInterest.ul().x + (width - 1),
543  theAreaOfInterest.ul().y + i *
544  tileHeight + (tileHeight - 1));
545
546  // Tile loop in the sample (width) direction.
547  for(ossim_uint64 j = 0; ((j < tilesWide)&&(!needsAborting())); ++j)
548  {
549  // Get the tile and copy it to the buffer.
551  if(id.valid())
552  {
554  if(!buffer)
555  {
556  bytesInLine = id->getScalarSizeInBytes() * width;
557  buf_band_offset = bytesInLine * tileHeight;
558  file_band_offset = height * bytesInLine;
559  bufferSizeInBytes = bytesInLine * tileHeight * bands;
560  buffer = new unsigned char[bufferSizeInBytes];
561  memset(buffer, 0, bufferSizeInBytes);
562  }
563  id->unloadTile(buffer,
564  bufferRect,
565  OSSIM_BSQ);
566  }
567  ++tileNumber;
568  }
569
570  // Get the number of lines to write from the buffer.
571  ossim_uint64 linesToWrite =
572  min(tileHeight,
573  static_cast<ossim_uint64>(theAreaOfInterest.lr().y -
574  bufferRect.ul().y + 1));
575
576  // Write the buffer out to disk.
577  ossim_uint64 start_line =
578  static_cast<ossim_uint64>(bufferRect.ul().y -
580  for (ossim_uint64 band = 0; ((band < bands)&&(!needsAborting())); ++band)
581  {
582  ossim_uint8* buf = buffer;
583  buf += buf_band_offset * band;
584
585  // Put the file pointer in the right spot.
586  streampos pos = file_band_offset * band + start_line * bytesInLine;
587  theOutputStream->seekp(pos, ios::beg);
588  if (theOutputStream->fail())
589  {
590  ossimNotify(ossimNotifyLevel_FATAL) << MODULE << " ERROR:"
591  << "Error returned seeking to image data position!" << std::endl;
592  setErrorStatus();
593  return false;
594  }
595
596  for (ossim_uint64 ii=0; ((ii<linesToWrite)&&(!needsAborting())); ++ii)
597  {
598  wroteSomethingOut = true;
600  {
601  endian.swap(scalarType,
602  buf,
603  bytesInLine/ossim::scalarSizeInBytes(scalarType));
604  }
605
606  theOutputStream->write((char*)buf, bytesInLine);
607
608  if (theOutputStream->fail())
609  {
610  ossimNotify(ossimNotifyLevel_FATAL) << MODULE << " ERROR:"
611  << "Error returned writing line!" << std::endl;
612  setErrorStatus();
613  return false;
614  }
615
616  buf += bytesInLine;
617  }
618
619  } // End of loop to write lines from buffer to tiff file.
620
621  double tile = tileNumber;
622  double numTiles = numberOfTiles;
623  setPercentComplete(tile / numTiles * 100);
624
625  if(needsAborting())
626  {
627  setPercentComplete(100.0);
628  }
629
630  } // End of loop in the line (height) direction.
631
632  // Free the memory.
633  delete [] buffer;
634
635  if (traceDebug()) CLOG << " Exited." << std::endl;
636
637  return wroteSomethingOut;
638 }
#define CLOG
ossim_uint32 height() const
Definition: ossimIrect.h:487
ossimScalarType
ossim_int32 y
ossim_int32 x
#define min(a, b)
Member Data Documentation
◆ theMaxPerBand
std::vector<double> ossimGeneralRasterWriter::theMaxPerBand
private
Definition at line 152 of file ossimGeneralRasterWriter.h.
◆ theMinPerBand
std::vector<double> ossimGeneralRasterWriter::theMinPerBand
private
Definition at line 151 of file ossimGeneralRasterWriter.h.
◆ theOutputByteOrder
ossimByteOrder ossimGeneralRasterWriter::theOutputByteOrder
private
Definition at line 146 of file ossimGeneralRasterWriter.h.
Referenced by loadState(), ossimGeneralRasterWriter(), and saveState().
◆ theOutputStream
std::ostream* ossimGeneralRasterWriter::theOutputStream
private
Definition at line 143 of file ossimGeneralRasterWriter.h.
Referenced by close(), isOpen(), open(), setOutputStream(), and writeStream().
◆ theOwnsStreamFlag
bool ossimGeneralRasterWriter::theOwnsStreamFlag
private
Definition at line 144 of file ossimGeneralRasterWriter.h.
Referenced by close(), open(), and setOutputStream().
◆ theRlevel
ossim_uint32 ossimGeneralRasterWriter::theRlevel
private
Definition at line 145 of file ossimGeneralRasterWriter.h.
Referenced by loadState().
