Public Types | Public Member Functions | Protected Member Functions | Private Member Functions | Private Attributes | List of all members
ossimKakaduJp2Reader Class Reference
ossimKakaduJp2Reader class for reading images with JPEG2000 (J2K) compressed blocks using kakadu library for decompression. More...
#include <ossimKakaduJp2Reader.h>
Inheritance diagram for ossimKakaduJp2Reader:
ossimImageHandler ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Types
enum  { SIGNATURE_BOX_SIZE = 12, GEOTIFF_UUID_SIZE = 16 }
 Anonymous enumerations: More...
 ossimKakaduJp2Reader ()
 default construtor More...
virtual ~ossimKakaduJp2Reader ()
 virtural destructor More...
 Returns short name. More...
 Returns long name. More...
 Returns class name. More...
 Method to grab a tile(rectangle) from image. More...
 Returns the number of bands in the image. More...
 Returns the output pixel type of the tile source. More...
 Returns the number of decimation levels. More...
virtual ossim_uint32 getNumberOfLines (ossim_uint32 resLevel=0) const
 Gets number of lines for res level. More...
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 resLevel=0) const
 Gets the number of samples for res level. More...
virtual bool open ()
 Open method. More...
virtual bool isOpen () const
 Method to test for open file stream. More...
virtual void closeEntry ()
 Method to close current entry. More...
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual void initialize ()
virtual bool openOverview ()
virtual void closeOverview ()
 Opens the image file. More...
virtual void close ()
 Deletes the overview and clears the valid image vertices. More...
 Sets the filename. More...
 Returns the filename. More...
virtual bool isValidRLevel (ossim_uint32 resLevel) const
 Connection rule. More...
virtual bool hasLut () const
virtual void loadMetaData ()
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 Gets an overview tile. More...
virtual void completeOpen ()
virtual ~ossimReferenced ()
virtual ossimRefPtr< ossimImageGeometrygetInternalImageGeometry ()
virtual ossimRefPtr< ossimImageGeometrygetImageGeometryFromGeotiffBox ()
virtual ossimRefPtr< ossimImageGeometrygetImageGeometryFromGmlBox ()
ossimRefPtr< ossimImageGeometrygetMetadataImageGeometry () const
bool isJp2 ()
 Test first 12 bytes of file for the jp2 signature block. More...
bool openJp2File ()
 Opens the jp2 and initializes this object. More...
void initializeTile ()
 Initializes data member "theTile". More...
bool loadTileFromCache (const ossimIpt &origin, const ossimIrect &clipRect)
 Loads a block of data to theCacheTile from the cache. More...
bool loadTile (const ossimIpt &origin)
 Loads a block of data to theCacheTile. More...
bool configureChannelMapping ()
 Initializes m_channels to be used with copyRegionToTile if it makes sense. More...
Private Attributes
kdu_supp::jp2_family_src * theJp2FamilySrc
kdu_core::kdu_compressed_source * theJp2Source
kdu_supp::kdu_channel_mapping * theChannels
kdu_core::kdu_codestream theCodestream
kdu_core::kdu_thread_env * theThreadEnv
kdu_core::kdu_thread_queue * theOpenTileThreadQueue
ossim_uint32 theMinDwtLevels
ossim_uint32 theNumberOfBands
ossimIpt theCacheSize
ossimScalarType theScalarType
ossimIrect theImageRect
std::vector< ossimIrecttheJp2Dims
 Has sub image offset. More...
std::vector< ossimIrecttheJp2TileDims
 Tile dimensions for each level. More...
ossimRefPtr< ossimImageDatatheCacheTile
ossimAppFixedTileCache::ossimAppFixedCacheId theCacheId
 Cache initialized to image rect with sub image offset. More...
Additional Inherited Members
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 54 of file ossimKakaduJp2Reader.h.
◆ anonymous enum
anonymous enum
Enumerator
SIGNATURE_BOX_SIZE
GEOTIFF_UUID_SIZE
Definition at line 186 of file ossimKakaduJp2Reader.h.
◆ ossimKakaduJp2Reader()
ossimKakaduJp2Reader::ossimKakaduJp2Reader ( )
default construtor
◆ ~ossimKakaduJp2Reader()
ossimKakaduJp2Reader::~ossimKakaduJp2Reader ( )
virtual
virtural destructor
Definition at line 90 of file ossimKakaduJp2Reader.cpp.
References closeEntry().
91 {
92  closeEntry();
93 }
virtual void closeEntry()
Member Function Documentation
◆ closeEntry()
void ossimKakaduJp2Reader::closeEntry ( )
virtual
Note
There is a bool kdu_compressed_source::close() and a void ossimImageHandler::close(); hence, a new close to avoid conflicting return types.
Definition at line 518 of file ossimKakaduJp2Reader.cpp.
References ossimImageHandler::close(), ossimAppFixedTileCache::deleteCache(), ossimAppFixedTileCache::instance(), theCacheId, theCacheTile, theChannels, theCodestream, theJp2FamilySrc, theJp2Source, theOpenTileThreadQueue, theThreadEnv, and theTile.
Referenced by ~ossimKakaduJp2Reader().
519 {
520  // Cleanup processing environment
521  if ( theThreadEnv )
522  {
523  theThreadEnv->join(NULL,true); // Wait until all internal processing is complete.
524  theThreadEnv->terminate(theOpenTileThreadQueue, true);
525  theThreadEnv->cs_terminate(theCodestream); // Terminates background codestream processing.
526  theThreadEnv->destroy();
527  delete theThreadEnv;
528  theThreadEnv = 0;
529  }
530
531  theTile = 0;
532  theCacheTile = 0;
533
534  if (theChannels)
535  {
536  theChannels->clear();
537  delete theChannels;
538  theChannels = 0;
539  }
540  if(theCodestream.exists())
541  {
542  theCodestream.destroy();
543  }
544
545  if (theJp2Source)
546  {
547  delete theJp2Source;
548  theJp2Source = 0;
549  }
550
551  if (theJp2FamilySrc)
552  {
553  delete theJp2FamilySrc;
554  theJp2FamilySrc = 0;
555  }
556
558  {
560  }
561
562  if (theCacheId != -1)
563  {
565  theCacheId = -1;
566  }
567
569 }
virtual void deleteCache(ossimAppFixedCacheId cacheId)
static ossimAppFixedTileCache * instance(ossim_uint32 maxSize=0)
ossimRefPtr< ossimImageData > theCacheTile
virtual void close()
◆ configureChannelMapping()
bool ossimKakaduJp2Reader::configureChannelMapping ( )
private
Also set number of bands if channel mapping was successful.
Returns
Definition at line 1276 of file ossimKakaduJp2Reader.cpp.
References theChannels, theCodestream, theJp2Source, and theNumberOfBands.
1277 {
1278  bool result = false;
1279
1280  if ( theChannels )
1281  {
1282  theChannels->clear();
1283  }
1284  else
1285  {
1286  theChannels = new kdu_supp::kdu_channel_mapping;
1287  }
1288
1289  if ( theJp2Source )
1290  {
1291  // bool flag "ignore_alpha", turns on off alpha channel.
1292  result = theChannels->configure(static_cast<kdu_supp::jp2_source*>(theJp2Source), true);
1293  }
1294  else
1295  {
1296  result = theChannels->configure(theCodestream);
1297  }
1298
1299  if ( result )
1300  {
1301  theNumberOfBands = (ossim_uint32)theChannels->get_num_colour_channels();
1302
1303  if (traceDebug())
1304  {
1306  << "ossimKakaduJp2Reader::configureChannelMapping() DEBUG:"
1307  << "\nkdu_channel_mapping::get_num_channels(): "
1308  << theChannels->get_num_channels()
1309  << "\nkdu_channel_mapping::get_num_colour_channels(): "
1310  << theChannels->get_num_colour_channels()
1311  << "\ntheNumberOfBands: " << theNumberOfBands << endl;
1312  }
1313  }
1314
1315  // Force a per component kdu region decompress.
1316  if ( !result || ( theNumberOfBands != (ossim_uint32)theChannels->get_num_channels() ) )
1317  {
1318  // Remove the channel mapping.
1319  theChannels->clear();
1320  delete theChannels;
1321  theChannels = 0;
1322  }
1323
1324  return result;
1325 }
unsigned int ossim_uint32
◆ getClassName()
ossimString ossimKakaduJp2Reader::getClassName ( ) const
virtual
Returns class name.
Returns
"ossimKakaduJp2Reader"
Definition at line 105 of file ossimKakaduJp2Reader.cpp.
106 {
107  return ossimString("ossimKakaduJp2Reader");
108 }
◆ getImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimKakaduJp2Reader::getImageGeometry ( )
virtual
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 875 of file ossimKakaduJp2Reader.cpp.
References ossimImageGeometryRegistry::extendGeometry(), ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), getInternalImageGeometry(), getMetadataImageGeometry(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), and ossimImageHandler::theGeometry.
876 {
877  if ( !theGeometry )
878  {
879  //---
880  // Check for external geom - this is a file.geom not to be confused with
881  // geometries picked up from dot.xml, dot.prj, dot.j2w and so on. We
882  // will check for that later if the getInternalImageGeometry fails.
883  //---
885
886  if ( !theGeometry )
887  {
888  //---
889  // Check for external files other than .geom, i.e. file.xml & j2w:
890  //---
892
893  if ( !theGeometry )
894  {
895  // Check the internal geometry first to avoid a factory call.
897
898  //---
899  // WARNING:
900  // Must create/set the geometry at this point or the next call to
901  // ossimImageGeometryRegistry::extendGeometry will put us in an infinite loop
902  // as it does a recursive call back to ossimImageHandler::getImageGeometry().
903  //---
904  if ( !theGeometry )
905  {
907  }
908
909  // Check for set projection.
910  if ( !theGeometry->getProjection() )
911  {
912  // Last try factories for projection.
914  }
915  }
916  }
917
918  // Set image things the geometry object should know about.
920  }
921  return theGeometry;
922 }
static ossimImageGeometryRegistry * instance()
ossimRefPtr< ossimImageGeometry > theGeometry
ossimRefPtr< ossimImageGeometry > getMetadataImageGeometry() const
virtual bool extendGeometry(ossimImageHandler *handler) const
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
Returns the image geometry object associated with this tile source or NULL if non defined...
virtual ossimRefPtr< ossimImageGeometry > getInternalImageGeometry()
◆ getImageGeometryFromGeotiffBox()
ossimRefPtr< ossimImageGeometry > ossimKakaduJp2Reader::getImageGeometryFromGeotiffBox ( )
privatevirtual
Parameters
Methodto get geometry from the embedded JP2 GeoTIFF Box.
Definition at line 956 of file ossimKakaduJp2Reader.cpp.
957 {
958  static const char MODULE[] = "ossimKakaduJp2Reader::getImageGeometryFromGeotiffBox";
959
960  if (traceDebug())
961  {
962  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
963  }
964
966
967  if ( isOpen() )
968  {
969  std::ifstream str;
970  str.open( theImageFile.c_str(), std::ios_base::in | std::ios_base::binary);
971
972  if ( str.is_open() )
973  {
974  std::vector<ossim_uint8> box;
975  ossimJp2Info jp2Info;
976
977  std::streamoff boxPos = jp2Info.getGeotiffBox( str, box );
978
979  if ( box.size() )
980  {
981  if (traceDebug())
982  {
984  << "Found geotiff uuid at: " << boxPos+8 << "\n";
985  }
986
987  //---
988  // Create a string stream and set the vector buffer as its source.
989  // Note: The box has the 16 GEOTIFF_UUID bytes in there so offset
990  // address and size.
991  //---
992 #if 0
993  // This doesn't work with VS2010...
994  // Create a string stream and set the vector buffer as its source.
995  std::istringstream boxStream;
996  boxStream.rdbuf()->pubsetbuf( (char*)&box.front()+GEOTIFF_UUID_SIZE,
997  box.size()-GEOTIFF_UUID_SIZE );
998 #else
999  // convert the vector into a string
1000  std::string boxString( box.begin()+GEOTIFF_UUID_SIZE, box.end() );
1001  std::istringstream boxStream;
1002  boxStream.str( boxString );
1003 #endif
1004
1005  // Give the stream to tiff info to create a geometry.
1006  ossimTiffInfo info;
1007  ossim_uint32 entry = 0;
1008  ossimKeywordlist kwl; // Used to capture geometry data.
1009
1010  if ( info.getImageGeometry(boxStream, kwl, entry) )
1011  {
1012  //---
1013  // The tiff embedded in the geojp2 only has one line
1014  // and one sample by design so overwrite the lines and
1015  // samples with the real value.
1016  //---
1017  ossimString pfx = "image";
1018  pfx += ossimString::toString(entry);
1019  pfx += ".";
1020
1021  // Add the lines.
1023  getNumberOfLines(0), true);
1024
1025  // Add the samples.
1027  getNumberOfSamples(0), true);
1028
1029  // Create the projection.
1032  if ( proj.valid() )
1033  {
1034  // Create and assign projection to our ossimImageGeometry object.
1035  geom = new ossimImageGeometry();
1036  geom->setProjection( proj.get() );
1037  if (traceDebug())
1038  {
1039  ossimNotify(ossimNotifyLevel_DEBUG) << "Found GeoTIFF box." << std::endl;
1040  }
1041
1042  // Get the internal raster pixel alignment type and set the base class.
1043  const char* lookup = kwl.find(pfx.chars(), ossimKeywordNames::PIXEL_TYPE_KW);
1044  if ( lookup )
1045  {
1046  ossimString type = lookup;
1047  type.downcase();
1048  if ( type == "pixel_is_area" )
1049  {
1051  }
1052  else if ( type == "pixel_is_point" )
1053  {
1055  }
1056  }
1057  }
1058  }
1059  }
1060  }
1061  }
1062
1063  if (traceDebug())
1064  {
1065  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited...\n";
1066  }
1067
1068  return geom;
1069
1070 } // End: ossimKakaduJp2Reader::getImageGeometryFromGeotiffBox
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const
std::basic_ifstream< char > ifstream
Class for char input file streams.
Definition: ossimIosFwd.h:44
bool valid() const
Definition: ossimRefPtr.h:75
bool getImageGeometry(ossimKeywordlist &geomKwl, ossim_uint32 entryIndex) const
Extracts geometry info to keyword list.
Numeric to string methods.
static const char * NUMBER_LINES_KW
TIFF info class.
Definition: ossimTiffInfo.h:36
ossimProjection * createProjection(const ossimFilename &filename, ossim_uint32 entryIdx) const
JP2 info class.
Definition: ossimJp2Info.h:21
const char * chars() const
For backward compatibility.
Definition: ossimString.h:77
static ossimProjectionFactoryRegistry * instance()
static const char * PIXEL_TYPE_KW
const char * c_str() const
Definition: ossimString.h:396
std::basic_istringstream< char > istringstream
Class for char input memory streams.
Definition: ossimIosFwd.h:32
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const
virtual bool isOpen() const
std::streamoff getGeotiffBox(std::ifstream &str, std::vector< ossim_uint8 > &box) const
Method to get the embedded JP2 GeoTIFF box.
static const char * NUMBER_SAMPLES_KW
◆ getImageGeometryFromGmlBox()
ossimRefPtr< ossimImageGeometry > ossimKakaduJp2Reader::getImageGeometryFromGmlBox ( )
privatevirtual
Parameters
Methodto get geometry from the embedded JP2 GML Box.
Definition at line 1073 of file ossimKakaduJp2Reader.cpp.
1074 {
1075  static const char M[] = "ossimKakaduJp2Reader::getImageGeometryFromGmlBox";
1076
1077  if (traceDebug())
1078  {
1079  ossimNotify(ossimNotifyLevel_DEBUG) << M << " entered...\n";
1080  }
1081
1083
1084  if ( isOpen() )
1085  {
1086  std::ifstream str;
1087  str.open( theImageFile.c_str(), std::ios_base::in | std::ios_base::binary);
1088
1089  if ( str.is_open() )
1090  {
1091  std::vector<ossim_uint8> box;
1092  ossimJp2Info jp2Info;
1093
1094  std::streamoff boxPos = jp2Info.getGmlBox( str, box );
1095
1096  if ( boxPos && box.size() )
1097  {
1098  if (traceDebug())
1099  {
1101  << "Found gml box at: " << boxPos+8
1102  << "\nbox size: " << box.size() << "\n";
1103  }
1104
1105 #if 0
1106  // This doesn't work with VS2010...
1107  // Create a string stream and set the vector buffer as its source.
1108  std::istringstream boxStream;
1109  boxStream.rdbuf()->pubsetbuf( (char*)&box.front(), box.size() );
1110 #else
1111  // convert the vector into a string
1112  std::string boxString( box.begin(), box.end() );
1113  std::istringstream boxStream;
1114  boxStream.str( boxString );
1115 #endif
1116
1118
1119  if ( gml->initialize( boxStream ) )
1120  {
1121  ossimKeywordlist geomKwl;
1122  if ( gml->getImageGeometry( geomKwl ) )
1123  {
1124  // Make projection:
1125  // Create the projection.
1128  if ( proj.valid() )
1129  {
1130  // Create and assign projection to our ossimImageGeometry object.
1131  geom = new ossimImageGeometry();
1132  geom->setProjection( proj.get() );
1133  }
1134  }
1135  }
1136
1137  // Cleanup:
1138  delete gml;
1139  gml = 0;
1140  }
1141  }
1142  }
1143
1144  if (traceDebug())
1145  {
1147  << M << " exit status = " << (geom.valid()?"true":"false\n")
1148  << std::endl;
1149  }
1150
1151  return geom;
1152
1153 } // End: ossimKakaduJp2Reader::getImageGeometryFromGmlBox
bool valid() const
GML support data class.
bool getImageGeometry(ossimKeywordlist &geomKwl) const
JP2 info class.
bool initialize(const ossimImageGeometry *geom, const ossimIrect &rect)
Initializes gml block from geometry file.
std::streamoff getGmlBox(std::ifstream &str, std::vector< ossim_uint8 > &box) const
Method to get the embedded JP2 GML Box.
◆ getImageTileHeight()
ossim_uint32 ossimKakaduJp2Reader::getImageTileHeight ( ) const
virtual
Implements ossimImageHandler.
Definition at line 768 of file ossimKakaduJp2Reader.cpp.
References ossimIrect::height(), theImageRect, and theJp2TileDims.
Referenced by initializeTile().
769 {
770  ossim_uint32 result = 0;
771  if ( theJp2TileDims.size() )
772  {
773  if ( theJp2TileDims[0].height() != theImageRect.height() )
774  {
775  // Not a single tile.
776  result = static_cast<ossim_uint32>(theJp2TileDims[0].height());
777  }
778  }
779  return result;
780 }
ossim_uint32 height() const
Definition: ossimIrect.h:487
std::vector< ossimIrect > theJp2TileDims
◆ getImageTileWidth()
ossim_uint32 ossimKakaduJp2Reader::getImageTileWidth ( ) const
virtual
Definition at line 754 of file ossimKakaduJp2Reader.cpp.
References theImageRect, theJp2TileDims, and ossimIrect::width().
755 {
756  ossim_uint32 result = 0;
757  if ( theJp2TileDims.size() )
758  {
759  if ( theJp2TileDims[0].width() != theImageRect.width() )
760  {
761  // Not a single tile.
762  result = theJp2TileDims[0].width();
763  }
764  }
765  return result;
766 }
ossim_uint32 width() const
Definition: ossimIrect.h:500
◆ getInternalImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimKakaduJp2Reader::getInternalImageGeometry ( )
privatevirtual
Parameters
Methodto get geometry from the embedded JP2 Boxes.
Definition at line 924 of file ossimKakaduJp2Reader.cpp.
Referenced by getImageGeometry().
925 {
926  static const char MODULE[] = "ossimKakaduJp2Reader::getInternalImageGeometry";
927
928  if (traceDebug())
929  {
930  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
931  }
932
934
935  if ( isOpen() )
936  {
937  // Try to get geom from GML box:
939
940  if ( geom.valid() == false )
941  {
942  // Try to get geom from geotiff box:
944  }
945  }
946
947  if (traceDebug())
948  {
949  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited...\n";
950  }
951
952  return geom;
953
954 } // End: ossimKakaduJp2Reader::getInternalImageGeometry()
bool valid() const
virtual ossimRefPtr< ossimImageGeometry > getImageGeometryFromGmlBox()
virtual ossimRefPtr< ossimImageGeometry > getImageGeometryFromGeotiffBox()
◆ getLongName()
ossimString ossimKakaduJp2Reader::getLongName ( ) const
virtual
Returns long name.
Returns
"ossim kakadu jp2 reader"
Definition at line 100 of file ossimKakaduJp2Reader.cpp.
101 {
102  return ossimString("ossim kakadu jp2 reader");
103 }
◆ getMetadataImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimKakaduJp2Reader::getMetadataImageGeometry ( ) const
private
Parameters
Methodto get geometry from the various external files like .prj, .j2w .xml and so on.
Definition at line 1156 of file ossimKakaduJp2Reader.cpp.
1157 {
1158  static const char M[] = "ossimKakaduJp2Reader::getMetadataImageGeometry";
1159  if ( traceDebug() )
1160  {
1161  ossimNotify(ossimNotifyLevel_DEBUG) << M << " entered...\n";
1162  }
1163
1166
1167  // See if we can pick up the projection from the FGDC file:
1168  ossimFilename fdgcFile = theImageFile;
1169
1170  fdgcFile += ".xml"; // file.jp2.xml
1171  if ( fdgcFile.exists() == false )
1172  {
1173  fdgcFile = theImageFile;
1174  fdgcFile.setExtension(ossimString("xml")); // file.xml
1175  }
1176
1177  if ( fdgcFile.exists() )
1178  {
1179  ossimFgdcXmlDoc fgdcDoc;
1180  if ( fgdcDoc.open(fdgcFile) )
1181  {
1182  try
1183  {
1184  proj = fgdcDoc.getGridCoordSysProjection();
1185  }
1186  catch (const ossimException& e)
1187  {
1188  ossimNotify(ossimNotifyLevel_WARN) << e.what() << std::endl;
1189  }
1190
1191  if ( proj.valid() )
1192  {
1193  geom = new ossimImageGeometry();
1194
1195  ossimMapProjection* mapProj = dynamic_cast<ossimMapProjection*>(proj.get());
1196  if ( mapProj )
1197  {
1198  // See if we have a world file. Seems they have a more accurate tie point.
1199  ossimFilename worldFile = theImageFile;
1200  worldFile.setExtension(ossimString("j2w")); // file.j2w
1201  if ( worldFile.exists() )
1202  {
1203  //---
1204  // Note need a way to determine pixel type from fgdc doc.
1205  // This can result in a half pixel shift.
1206  //---
1208  ossimUnitType unitType = fgdcDoc.getUnitType();
1209
1210  ossimTiffWorld tfw;
1211  if ( tfw.open(worldFile, pixelType, unitType) )
1212  {
1213  ossimDpt gsd = tfw.getScale();
1214  gsd.y = std::fabs(gsd.y); // y positive up so negate.
1215  ossimDpt tie = tfw.getTranslation();
1216
1217  if ( unitType != OSSIM_METERS )
1218  {
1220
1221  // GSD (scale):
1222  uct.setValue(gsd.x, unitType);
1223  gsd.x = uct.getValue(OSSIM_METERS);
1224  uct.setValue(gsd.y, unitType);
1225  gsd.y = uct.getValue(OSSIM_METERS);
1226
1227  // Tie point:
1228  uct.setValue(tie.x, unitType);
1229  tie.x = uct.getValue(OSSIM_METERS);
1230  uct.setValue(tie.y, unitType);
1231  tie.y = uct.getValue(OSSIM_METERS);
1232  }
1233
1234  mapProj->setMetersPerPixel(gsd);
1235  mapProj->setUlTiePoints(tie);
1236  }
1237
1238  if ( tfw.getRotation() != 0.0 )
1239  {
1241  << M << " Unhandled rotation in tfw file." << std::endl;
1242  }
1243  }
1244
1245  } // if ( worldFile.exists() )
1246
1247  geom->setProjection( proj.get() );
1248
1249  } // if ( proj.valid() )
1250
1251  } // if ( fgdcDoc.open(fdgcFile) )
1252
1253  } // if ( fdgcFile.exists() )
1254
1255  if (traceDebug())
1256  {
1258  << M << " exit status = " << (geom.valid()?"true":"false\n")
1259  << std::endl;
1260  }
1261
1262  return geom;
1263 }
bool open(const ossimFilename &file, ossimPixelType ptype, ossimUnitType unit)
double getValue(ossimUnitType unitType=OSSIM_METERS) const
ossimUnitType
bool valid() const
void setValue(double value, ossimUnitType unitType=OSSIM_METERS)
double y
Definition: ossimDpt.h:165
ossimRefPtr< ossimProjection > getGridCoordSysProjection()
Gets projection from Grid Coordinate system node.
virtual void setMetersPerPixel(const ossimDpt &gsd)
bool exists() const
virtual const char * what() const
Returns the error message.
Class for FGDC XML doc parsing.
ossimPixelType
const ossimDpt & getScale() const
Converts world file parameters into x, y scale (for use in affine transform)
double x
Definition: ossimDpt.h:164
const ossimDpt & getTranslation() const
Provides access to the translation (for use in affine transform)
virtual void setUlTiePoints(const ossimGpt &gpt)
bool open(const ossimFilename &xmlFileName)
Open method.
double getRotation() const
Converts world file parameters into RH rotation in radians (for use in affine transform) ...
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
ossimUnitType getUnitType() const
◆ getNumberOfDecimationLevels()
ossim_uint32 ossimKakaduJp2Reader::getNumberOfDecimationLevels ( ) const
virtual
This returns the total number of decimation levels. It is important to note that res level 0 or full resolution is included in the list and has decimation values 1.0, 1.0
Returns
The number of decimation levels.
Definition at line 110 of file ossimKakaduJp2Reader.cpp.
References ossimImageHandler::getNumberOfDecimationLevels(), theMinDwtLevels, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getOverviewTile().
111 {
112  ossim_uint32 result = 1; // Add r0
113
114  if (theMinDwtLevels)
115  {
116  //---
117  // Add internal overviews.
118  //---
119  result += theMinDwtLevels;
120  }
121
122  if (theOverview.valid())
123  {
124  //---
125  // Add external overviews.
126  //---
128  }
129
130  return result;
131 }
bool valid() const
virtual ossim_uint32 getNumberOfDecimationLevels() const
ossimRefPtr< ossimImageHandler > theOverview
◆ getNumberOfInputBands()
ossim_uint32 ossimKakaduJp2Reader::getNumberOfInputBands ( ) const
virtual
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 744 of file ossimKakaduJp2Reader.cpp.
References theNumberOfBands.
745 {
746  return theNumberOfBands;
747 }
◆ getNumberOfLines()
ossim_uint32 ossimKakaduJp2Reader::getNumberOfLines ( ossim_uint32  resLevel = 0) const
virtual
Overrides ossimJ2kTileSource::getNumberOfLines
Parameters
resLevelReduced resolution level to return lines of. Default = 0
Returns
The number of lines for specified reduced resolution level.
Definition at line 133 of file ossimKakaduJp2Reader.cpp.
References ossimImageHandler::getNumberOfLines(), ossimImageHandler::isValidRLevel(), theJp2Dims, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
135 {
136  ossim_uint32 result = 0;
137  if ( isValidRLevel(resLevel) )
138  {
139  if (resLevel < theJp2Dims.size() )
140  {
141  result = theJp2Dims[resLevel].height();
142  }
143  else if (theOverview.valid())
144  {
145  result = theOverview->getNumberOfLines(resLevel);
146  }
147  }
148  return result;
149 }
bool valid() const
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
std::vector< ossimIrect > theJp2Dims
◆ getNumberOfOutputBands()
ossim_uint32 ossimKakaduJp2Reader::getNumberOfOutputBands ( ) const
virtual
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 749 of file ossimKakaduJp2Reader.cpp.
Referenced by getOverviewTile(), and initializeTile().
750 {
751  return theNumberOfBands;
752 }
◆ getNumberOfSamples()
ossim_uint32 ossimKakaduJp2Reader::getNumberOfSamples ( ossim_uint32  resLevel = 0) const
virtual
Overrides ossimJ2kTileSource::getNumberOfSamples
Parameters
resLevelReduced resolution level to return samples of. Default = 0
Returns
The number of samples for specified reduced resolution level.
Definition at line 151 of file ossimKakaduJp2Reader.cpp.
References ossimImageHandler::getNumberOfSamples(), ossimImageHandler::isValidRLevel(), theJp2Dims, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
153 {
154  ossim_uint32 result = 0;
155  if ( isValidRLevel(resLevel) )
156  {
157  if (resLevel < theJp2Dims.size() )
158  {
159  result = theJp2Dims[resLevel].width();
160  }
161  else if (theOverview.valid())
162  {
163  result = theOverview->getNumberOfSamples(resLevel);
164  }
165  }
166  return result;
167 }
bool valid() const
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
◆ getOutputScalarType()
ossimScalarType ossimKakaduJp2Reader::getOutputScalarType ( ) const
virtual
Definition at line 782 of file ossimKakaduJp2Reader.cpp.
References theScalarType.
783 {
784  return theScalarType;
785 }
◆ getOverviewTile()
bool ossimKakaduJp2Reader::getOverviewTile ( ossim_uint32  resLevel,
ossimImageData result
protectedvirtual
Overrides ossimImageHandler::getOverviewTile
Parameters
resLevelThe resolution level to pull from with resLevel 0 being full res.
resultThe tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. This method will subtract the subImageOffset if needed for external overview call since they do not know about the sub image offset.
Returns
true on success false on error. Typically this will return false if resLevel==0 unless the overview has r0. If return is false, result is undefined so caller should handle appropriately with makeBlank or whatever.
Definition at line 671 of file ossimKakaduJp2Reader.cpp.
References ossim::copyRegionToTile(), ossimImageData::getImageRectangle(), ossimImageData::getNumberOfBands(), getNumberOfDecimationLevels(), getNumberOfOutputBands(), ossimImageSource::getTile(), ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), status, theChannels, theCodestream, theJp2Dims, theMinDwtLevels, theOpenTileThreadQueue, ossimImageHandler::theOverview, theThreadEnv, and ossimException::what().
Referenced by getTile(), and loadTile().
673 {
674  bool status = false;
675
676  if ( (resLevel < getNumberOfDecimationLevels()) && result &&
677  (result->getNumberOfBands() == getNumberOfOutputBands()) )
678  {
679  if (resLevel <= theMinDwtLevels)
680  {
681  // Using internal overviews.
682
683  //---
684  // NOTE:
685  //
686  // The geojp2 doqq's that I have all have an offset in them. In
687  // other words the "pos" from "get_dims" is not always 0,0. I
688  // think this was intended for mosaicing without any projection. I
689  // do NOT think it was intended to be used as a sub image offset
690  // into the projection picked up by the geotiff_box. If this were
691  // so the current code here would not mosaic correctly.
692  //
693  // This may not be the case though with all data sets... In which
694  // case some kind of logic would have to be added to this code.
695  //---
696  ossimIrect originalTileRect = result->getImageRectangle();
697
698  ossimIrect shiftedRect = originalTileRect + theJp2Dims[resLevel].ul();
699
700  result->setImageRectangle(shiftedRect);
701
702  try
703  {
704  if ( theChannels )
705  {
708  static_cast<int>(resLevel),
709  theThreadEnv,
711  result);
712  }
713  else
714  {
716  static_cast<int>(resLevel),
717  theThreadEnv,
719  result);
720  }
721  }
722  catch(const ossimException& e)
723  {
725  << __FILE__ << " " << __LINE__ << " caught exception\n"
726  << e.what();
727  status = false;
728  }
729
730  // Set the rect back.
731  result->setImageRectangle(originalTileRect);
732
733  } // matches: if (resLevel <= theMinDwtLevels)
734  else
735  {
736  // Using external overview.
737  status = theOverview->getTile(result, resLevel);
738  }
739  }
740
741  return status;
742 }
virtual ossimIrect getImageRectangle() const
return status
bool copyRegionToTile(kdu_supp::kdu_channel_mapping *channelMapping, kdu_core::kdu_codestream &codestream, int discard_levels, kdu_core::kdu_thread_env *threadEnv, kdu_core::kdu_thread_queue *threadQueue, ossimImageData *destTile)
Copies region from codestream to tile at a given rlevel.
◆ getShortName()
ossimString ossimKakaduJp2Reader::getShortName ( ) const
virtual
Returns short name.
Returns
"ossim_kakadu_jp2_reader"
Definition at line 95 of file ossimKakaduJp2Reader.cpp.
96 {
97  return ossimString("ossim_kakadu_jp2_reader");
98 }
◆ getTile()
ossimRefPtr< ossimImageData > ossimKakaduJp2Reader::getTile ( const ossimIrect rect,
virtual
Parameters
rectThe zero based rectangle to grab.
resLevelThe reduced resolution level to grab from.
Returns
The ref pointer with the image data pointer.
Definition at line 571 of file ossimKakaduJp2Reader.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimImageData::getImageRectangle(), getOverviewTile(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), loadTile(), ossimImageData::loadTile(), loadTileFromCache(), ossimIrect::lr(), ossimImageData::makeBlank(), OSSIM_BSQ, ossimImageData::setImageRectangle(), ossimIrect::stretchToTileBoundary(), theCacheSize, theCacheTile, theImageRect, theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, and ossimIpt::y.
573 {
574  // This tile source bypassed, or invalid res level, return null tile.
575  if(!isSourceEnabled() || !isOpen() || !isValidRLevel(resLevel))
576  {
578  }
579
580  if (theTile.valid())
581  {
582  // Rectangle must be set prior to getOverviewTile call.
583  theTile->setImageRectangle(rect);
584
585  if (resLevel)
586  {
587  if ( getOverviewTile(resLevel, theTile.get()) == false )
588  {
589  theTile->makeBlank();
590  }
591  }
592  else // r0
593  {
594  // NOTE: Using cache for r0 tiles.
595
596  //---
597  // See if the whole tile is going to be filled, if not, start out with
598  // a blank tile so data from a previous load gets wiped out.
599  //---
600  if ( !rect.completely_within(theImageRect) )
601  {
602  // Start with a blank tile.
603  theTile->makeBlank();
604  }
605
606  //---
607  // See if any point of the requested tile is in the image.
608  //---
609  if ( rect.intersects(theImageRect) )
610  {
611  ossimIrect clipRect = rect.clipToRect(theImageRect);
612
613  ossimIrect expandedRect = clipRect;
614  expandedRect.stretchToTileBoundary(theCacheSize);
615
616  //---
617  // Shift the upper left corner of the "clip_rect" to the an even
618  // j2k tile boundry.
619  //---
620  ossimIpt tileOrigin = expandedRect.ul();
621
622  // Vertical tile loop.
623  while (tileOrigin.y < expandedRect.lr().y)
624  {
625  // Horizontal tile loop.
626  while (tileOrigin.x < expandedRect.lr().x)
627  {
628  if ( loadTileFromCache(tileOrigin, clipRect) == false )
629  {
630  if ( loadTile(tileOrigin) )
631  {
632  //---
633  // Note: Clip the cache tile to the image clipRect
634  // since there are j2k tiles that go beyond the image
635  // dimensions, i.e., edge tiles.
636  //---
637  ossimIrect cr =
639  clipToRect(clipRect);
640
643  cr,
644  OSSIM_BSQ);
645  }
646
647  }
648
649  tileOrigin.x += theCacheSize.x; // Go to next tile.
650
651  } // End loop in x direction.
652
653  // Go to next row of tiles.
654  tileOrigin.x = expandedRect.ul().x;
655  tileOrigin.y += theCacheSize.y;
656
657  } // End loop in y direction.
658
659  // Set the tile status.
660  theTile->validate();
661
662  } // matches: if ( rect.intersects(theImageRect) )
663
664  } // r0 block
665
666  } // matches: if (theTile.valid())
667
668  return theTile;
669 }
virtual bool getOverviewTile(ossim_uint32 resLevel, ossimImageData *result)
bool loadTile(const ossimIpt &origin)
bool valid() const
const ossimIpt & ul() const
Definition: ossimIrect.h:274
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
bool completely_within(const ossimIrect &rect) const
Definition: ossimIrect.cpp:425
bool loadTileFromCache(const ossimIpt &origin, const ossimIrect &clipRect)
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
const ossimIpt & lr() const
Definition: ossimIrect.h:276
virtual void makeBlank()
ossim_int32 y
Definition: ossimIpt.h:142
void stretchToTileBoundary(const ossimIpt &tileWidthHeight)
Definition: ossimIrect.cpp:212
ossim_int32 x
Definition: ossimIpt.h:141
◆ initializeTile()
void ossimKakaduJp2Reader::initializeTile ( )
private
Definition at line 787 of file ossimKakaduJp2Reader.cpp.
References ossim::defaultTileSize(), getImageTileHeight(), getImageTileWidth(), getNumberOfOutputBands(), getOutputScalarType(), ossimImageData::initialize(), ossimImageDataFactory::instance(), theCacheSize, theCacheTile, theTile, ossimIpt::x, and ossimIpt::y.
788 {
789  ossim_uint32 width = this->getImageTileWidth();
790  ossim_uint32 height = this->getImageTileHeight();
791
792  // Check for zero width, height and limit output tile sizes to 1024.
793  if ( !width || !height || ( width > 1024) || (height > 1024) )
794  {
795  ossimIpt tileSize;
796  ossim::defaultTileSize(tileSize);
797
798  width = tileSize.x;
799  height = tileSize.y;
800  }
801
803  create( this,
804  this->getOutputScalarType(),
805  this->getNumberOfOutputBands(),
806  width,
807  height);
808
809  theTile->initialize();
810
812  create( this,
813  this->getOutputScalarType(),
814  this->getNumberOfOutputBands(),
815  theCacheSize.x,
816  theCacheSize.y );
817
819 }
virtual ossim_uint32 getImageTileHeight() const
OSSIM_DLL void defaultTileSize(ossimIpt &tileSize)
virtual void initialize()
Initialize the data buffer.
ossim_int32 y
virtual ossim_uint32 getImageTileWidth() const
ossim_int32 x
◆ isJp2()
bool ossimKakaduJp2Reader::isJp2 ( )
private
Returns
true is theImageFile is a jp2, false if not.
Definition at line 207 of file ossimKakaduJp2Reader.cpp.
References ossimString::chars(), SIGNATURE_BOX_SIZE, and ossimImageHandler::theImageFile.
208 {
209  bool result = true;
210
211  std::ifstream str;
212  str.open(theImageFile.chars(), ios::in | ios::binary);
213
214  if ( str.is_open() )
215  {
216  const ossim_uint8 J2K_SIGNATURE_BOX[SIGNATURE_BOX_SIZE] =
217  {0x00,0x00,0x00,0x0c,0x6a,0x50,0x20,0x20,0x0d,0x0a,0x87,0x0a};
218
220
221  // Read in the box.
222  str.read((char*)box, SIGNATURE_BOX_SIZE);
223
224  for (ossim_uint32 i = 0; i < SIGNATURE_BOX_SIZE; ++i)
225  {
226  if (box[i] != J2K_SIGNATURE_BOX[i])
227  {
228  result = false;
229  break;
230  }
231  }
232
233  str.close();
234  }
235  else
236  {
237  result = false;
238
239  if(traceDebug())
240  {
242  << "isJp2 ERROR:"
243  << "\nCannot open: " << theImageFile.chars() << endl;
244  }
245  }
246
247  return result;
248 }
unsigned char ossim_uint8
◆ isOpen()
bool ossimKakaduJp2Reader::isOpen ( ) const
virtual
Returns
true if open, false if not.
Definition at line 510 of file ossimKakaduJp2Reader.cpp.
References theTile, and ossimRefPtr< T >::valid().
Referenced by getTile().
511 {
512  return theTile.valid();
513
514  // return theCodestream.exists()
515  // return theFileStr.is_open();
516 }
bool valid() const
◆ loadState()
bool ossimKakaduJp2Reader::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 1265 of file ossimKakaduJp2Reader.cpp.
References ossimImageHandler::loadState(), and open().
1267 {
1268  bool result = false;
1269  if ( ossimImageHandler::loadState(kwl, prefix) )
1270  {
1271  result = open();
1272  }
1273  return result;
1274 }
virtual bool open()
Open method.
◆ loadTile()
bool ossimKakaduJp2Reader::loadTile ( const ossimIpt origin)
private
Parameters
originStarting position of block to load.
Returns
Definition at line 847 of file ossimKakaduJp2Reader.cpp.
References ossimAppFixedTileCache::addTile(), ossimRefPtr< T >::get(), getOverviewTile(), ossimAppFixedTileCache::instance(), ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), theCacheId, theCacheSize, theCacheTile, ossimIpt::x, and ossimIpt::y.
848 {
849  bool result = true;
850
851  ossimIpt lr(origin.x + theCacheSize.x - 1,
852  origin.y + theCacheSize.y - 1);
853
854  // Set the cache rectangle to be an even j2k tile.
856
857  // Let the getOverviewTile do the rest of the work.
858  if ( getOverviewTile(0, theCacheTile.get()) )
859  {
860  // Add it to the cache for the next time.
862  }
863  else
864  {
866  << __FILE__ << __LINE__
867  << " ossimKakaduJp2Reader::loadBlock failed!"
868  << std::endl;
869  result = false;
870  }
871
872  return result;
873 }
ossim_int32 y
ossim_int32 x
ossimRefPtr< ossimImageData > addTile(ossimAppFixedCacheId cacheId, ossimRefPtr< ossimImageData > data, bool duplicateData=true)
◆ loadTileFromCache()
bool ossimKakaduJp2Reader::loadTileFromCache ( const ossimIpt origin,
const ossimIrect clipRect
private
Parameters
originThis is the point used for the cache query.
clipRectThe rectangle to fill.
Returns
Definition at line 821 of file ossimKakaduJp2Reader.cpp.
References ossimIrect::clipToRect(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimImageData::getImageRectangle(), ossimAppFixedTileCache::getTile(), ossimAppFixedTileCache::instance(), ossimImageData::loadTile(), OSSIM_BSQ, theCacheId, theTile, and ossimRefPtr< T >::valid().
823 {
824  bool result = false;
825
826  ossimRefPtr<ossimImageData> tempTile =
828  if (tempTile.valid())
829  {
830  //---
831  // Note: Clip the cache j2k tile to the image clipRect since
832  // there are j2k tiles that go beyond the image dimensions, i.e.,
833  // edge tiles.
834  //---
835  ossimIrect cr = tempTile->getImageRectangle().clipToRect(clipRect);
836
837  theTile->loadTile(tempTile.get()->getBuf(),
838  tempTile->getImageRectangle(),
839  cr,
840  OSSIM_BSQ);
841  result = true;
842  }
843
844  return result;
845 }
bool valid() const
ossimRefPtr< ossimImageData > getTile(ossimAppFixedCacheId cacheId, const ossimIpt &origin)
◆ open()
bool ossimKakaduJp2Reader::open ( )
virtual
Open method.
Returns
Definition at line 169 of file ossimKakaduJp2Reader.cpp.
Referenced by loadState().
170 {
171  static const char MODULE[] = "ossimKakaduJp2Reader::open";
172
173  if (traceDebug())
174  {
176  << MODULE << " entered...\n"
177  << "image: " << theImageFile << "\n";
178  }
179
180  bool result = false;
181
182  if(isOpen())
183  {
184  closeEntry();
185  }
186
187  if ( isJp2() )
188  {
189  result = openJp2File();
190
191  if ( !result )
192  {
193  closeEntry();
194  }
195  }
196
197  if (traceDebug())
198  {
200  << MODULE << " exit status = " << (result?"true":"false\n")
201  << std::endl;
202  }
203
204  return result;
205 }
bool isJp2()
bool openJp2File()
◆ openJp2File()
bool ossimKakaduJp2Reader::openJp2File ( )
private
Returns
Definition at line 250 of file ossimKakaduJp2Reader.cpp.
251 {
252  static const char MODULE[] = "ossimKakaduJp2Reader::openJp2File";
253
254  if (traceDebug())
255  {
257  << MODULE << " entered...\n";
258  }
259
260  bool result = false;
261
262  theJp2FamilySrc = new kdu_supp::jp2_family_src();
263  theJp2FamilySrc->open(theImageFile.c_str(), true);
264
265  if (theJp2FamilySrc->exists())
266  {
267  kdu_supp::jp2_source* src = new kdu_supp::jp2_source();
268  theJp2Source = src;
269
270  src->open(theJp2FamilySrc);
271
272  src->read_header();
273
274  if (traceDebug())
275  {
276  kdu_supp::jp2_colour colour = src->access_colour();
277  if ( colour.exists() )
278  {
280  << "jp2 color space: " << colour.get_space() << std::endl;
281  }
282  }
283
284  theThreadEnv = new kdu_core::kdu_thread_env();
285
286  theThreadEnv->create(); // Creates the single "owner" thread
287
288  ossim_uint32 threads = 1;
289
290  const char* lookup = ossimPreferences::instance()->findPreference("kakadu_threads");
291  if ( lookup )
292  {
293  threads = ossimString::toUInt32(lookup);
294  if ( threads > 1 )
295  {
296  for (ossim_uint32 nt=1; nt < threads; ++nt)
297  {
298  if ( !theThreadEnv->add_thread() )
299  {
300  if (traceDebug())
301  {
303  << "Unable to create thread!\n";
304  }
305  }
306  }
307  }
308  }
309
311  theThreadEnv->add_queue(NULL,NULL,"open_tile_q");
312
314
315  if ( theCodestream.exists() )
316  {
317  // This must be done before anything else...
318  theCodestream.set_persistent();
319
320  theCodestream.enable_restart(); // ????
321
322  // Get the image and tile dimensions.
324  theJp2Dims,
325  theJp2TileDims) )
326  {
327  //---
328  // Set the image size.
329  //
330  // NOTE:
331  //
332  // The geojp2 doqq's that I have all have an offset in them. In
333  // other words the "pos" from "get_dims" is not always 0,0. I
334  // think this was intended for mosaicing without any projection. I
335  // do NOT think it was intended to be used as a sub image offset
336  // into the projection picked up by the geotiff_box. If this were
337  // so the current code here would not mosaic correctly.
338  //
339  // This may not be the case though with all data sets... In which
340  // case some kind of logic would have to be added to this code.
341  //---
343  0,
344  theJp2Dims[0].width() -1,
345  theJp2Dims[0].height()-1);
346
347  // Number of internal dwl layers
348  theMinDwtLevels = theCodestream.get_min_dwt_levels();
349
350  //---
351  // Set up channel mapping for copyRegionToTile if it makes sense.
352  // This will set the number of bands if successful, ignoring the
353  // alpha channel.
354  //---
355  if ( configureChannelMapping() == false )
356  {
358  static_cast<ossim_uint32>(theCodestream.get_num_components(true));
359  }
360
361  if (traceDebug())
362  {
364  << "codestream::get_num_components(true): "
365  << theCodestream.get_num_components(true)
366  << "\ntheNumberOfBands: " << theNumberOfBands << "\n";
367  }
368
369  //---
370  // Set the cache tile size. Use the internal j2k tile size if it's
371  // reasonable else clamp to some max. Some j2k writer make one
372  // BIG tile so this must be done.
373  //---
374  const ossim_uint32 MAX_CACHE_TILE_DIMENSION = 1024;
375  theCacheSize.x =
376  static_cast<ossim_int32>(
377  (theJp2TileDims[0].width() <= MAX_CACHE_TILE_DIMENSION) ?
378  theJp2TileDims[0].width() : MAX_CACHE_TILE_DIMENSION );
379  theCacheSize.y =
380  static_cast<ossim_int32>(
381  (theJp2TileDims[0].height() <= MAX_CACHE_TILE_DIMENSION) ?
382  theJp2TileDims[0].height() : MAX_CACHE_TILE_DIMENSION );
383
384  // Set the scalar:
385  int bitDepth = theCodestream.get_bit_depth(0, true);
386  bool isSigned = theCodestream.get_signed(0, true);
387
388  switch (bitDepth)
389  {
390  case 8:
391  {
393  break;
394  }
395  case 11:
396  {
398  break;
399  }
400  case 12:
401  {
403  break;
404  }
405  case 13:
406  {
408  break;
409  }
410  case 14:
411  {
413  break;
414  }
415  case 15:
416  {
418  break;
419  }
420  case 16:
421  {
423  break;
424  }
425  default:
426  {
428  break;
429  }
430  }
431
433  {
434  // Initialize the cache.
435  if (theCacheId != -1)
436  {
438  theCacheId = -1;
439  }
440
441  ossimIrect fullImgRect = theImageRect;
442  fullImgRect.stretchToTileBoundary(theCacheSize);
443
445  newTileCache(fullImgRect, theCacheSize);
446
447  // Initialize the tile we will return.
448  initializeTile();
449
450  // Call the base complete open to pick up overviews.
451  completeOpen();
452
453
454  // We should be good now so set the return result to true.
455  result = true;
456
457  if (traceDebug())
458  {
460  theCodestream);
462  << "\ntheImageRect: " << theImageRect
463  << "\nFull image rect: " << fullImgRect
464  << "\ntheCacheSize: " << theCacheSize
465  << "\nscalar type: "
467  getEntryString(theScalarType)
468  << "\n";
469
470  for (ossim_uint32 level=0;
471  level < theJp2Dims.size(); ++level)
472  {
474  << "theJp2Dims[" << level << "]: "
475  << theJp2Dims[level]
476  << "\ntheJp2TileDims[" << level << "]: "
477  << theJp2TileDims[level] << "\n";
478  }
480  << "threads: " << threads << endl;
481  }
482
483  } // if (theScalarType != OSSIM_SCALAR_UNKNOWN)
484
485  } // matches: if ( ossim::getCodestreamDimensions
486
487  } // matches: if ( theCodestream.exists() )
488
489  } // if (theJp2FamilySrc->exists())
490
491  if (traceDebug())
492  {
494  << MODULE << " exit status = " << (result?"true":"false\n")
495  << std::endl;
496  }
497
498  return result;
499
500  if (traceDebug())
501  {
503  << MODULE << " exit status = " << (result?"true":"false\n")
504  << std::endl;
505  }
506
507  return result;
508 }
16 bit unsigned integer
void initializeTile()
16 bit signed integer
ossim_uint32 toUInt32() const
static ossimScalarTypeLut * instance()
Returns the static instance of an ossimScalarTypeLut object.
OSSIM_DLL bool isSigned(ossimScalarType scalarType)
const char * findPreference(const char *key) const
std::ostream & print(std::ostream &out, kdu_core::kdu_codestream &cs)
Convenience print method for kdu_codestream.
bool configureChannelMapping()
static ossimPreferences * instance()
virtual void completeOpen()
Will complete the opening process.
ossim_int32 y
ossim_int32 x
8 bit unsigned integer
bool getCodestreamDimensions(kdu_core::kdu_codestream &codestream, std::vector< ossimIrect > &imageDims, std::vector< ossimIrect > &tileDims)
Gets image and tile dimensions from codestream for each resolution level (rlevel).
int ossim_int32
Member Data Documentation
◆ theCacheId
ossimAppFixedTileCache::ossimAppFixedCacheId ossimKakaduJp2Reader::theCacheId
private
Definition at line 317 of file ossimKakaduJp2Reader.h.
Referenced by closeEntry(), loadTile(), and loadTileFromCache().
◆ theCacheSize
ossimIpt ossimKakaduJp2Reader::theCacheSize
private
Definition at line 303 of file ossimKakaduJp2Reader.h.
Referenced by getTile(), initializeTile(), and loadTile().
◆ theCacheTile
ossimRefPtr<ossimImageData> ossimKakaduJp2Reader::theCacheTile
private
Definition at line 314 of file ossimKakaduJp2Reader.h.
Referenced by closeEntry(), getTile(), initializeTile(), and loadTile().
◆ theChannels
kdu_supp::kdu_channel_mapping* ossimKakaduJp2Reader::theChannels
private
Definition at line 296 of file ossimKakaduJp2Reader.h.
Referenced by closeEntry(), configureChannelMapping(), and getOverviewTile().
◆ theCodestream
kdu_core::kdu_codestream ossimKakaduJp2Reader::theCodestream
private
Definition at line 297 of file ossimKakaduJp2Reader.h.
◆ theImageRect
ossimIrect ossimKakaduJp2Reader::theImageRect
private
Definition at line 305 of file ossimKakaduJp2Reader.h.
Referenced by getImageTileHeight(), getImageTileWidth(), and getTile().
◆ theJp2Dims
std::vector<ossimIrect> ossimKakaduJp2Reader::theJp2Dims
private
Image dimensions for each level.
Definition at line 308 of file ossimKakaduJp2Reader.h.
Referenced by getNumberOfLines(), getNumberOfSamples(), and getOverviewTile().
◆ theJp2FamilySrc
kdu_supp::jp2_family_src* ossimKakaduJp2Reader::theJp2FamilySrc
private
Definition at line 294 of file ossimKakaduJp2Reader.h.
Referenced by closeEntry().
◆ theJp2Source
kdu_core::kdu_compressed_source* ossimKakaduJp2Reader::theJp2Source
private
Definition at line 295 of file ossimKakaduJp2Reader.h.
Referenced by closeEntry(), and configureChannelMapping().
◆ theJp2TileDims
std::vector<ossimIrect> ossimKakaduJp2Reader::theJp2TileDims
private
Definition at line 311 of file ossimKakaduJp2Reader.h.
Referenced by getImageTileHeight(), and getImageTileWidth().
◆ theMinDwtLevels
ossim_uint32 ossimKakaduJp2Reader::theMinDwtLevels
private
Definition at line 301 of file ossimKakaduJp2Reader.h.
Referenced by getNumberOfDecimationLevels(), and getOverviewTile().
◆ theNumberOfBands
ossim_uint32 ossimKakaduJp2Reader::theNumberOfBands
private
◆ theOpenTileThreadQueue
kdu_core::kdu_thread_queue* ossimKakaduJp2Reader::theOpenTileThreadQueue
private
Definition at line 299 of file ossimKakaduJp2Reader.h.
Referenced by closeEntry(), and getOverviewTile().
◆ theScalarType
ossimScalarType ossimKakaduJp2Reader::theScalarType
private
Definition at line 304 of file ossimKakaduJp2Reader.h.
Referenced by getOutputScalarType().
◆ theThreadEnv
kdu_core::kdu_thread_env* ossimKakaduJp2Reader::theThreadEnv
private
Definition at line 298 of file ossimKakaduJp2Reader.h.
◆ theTile
ossimRefPtr<ossimImageData> ossimKakaduJp2Reader::theTile
private
