Public Types | Public Member Functions | Private Member Functions | Private Attributes | List of all members
ossimChipperUtil Class Reference
ossimChipperUtil class. More...
#include <ossimChipperUtil.h>
Inheritance diagram for ossimChipperUtil:
ossimReferenced
Public Types
enum  ossimChipperOperation {
  OSSIM_CHIPPER_OP_UNKNOWN = 0, OSSIM_CHIPPER_OP_HILL_SHADE = 1, OSSIM_CHIPPER_OP_COLOR_RELIEF = 2, OSSIM_CHIPPER_OP_ORTHO = 3,
  OSSIM_CHIPPER_OP_2CMV = 4, OSSIM_CHIPPER_OP_CHIP = 5, OSSIM_CHIPPER_OP_PSM = 6
 emumerated operations More...
enum  ossimChipperOutputProjection {
  OSSIM_CHIPPER_PROJ_UNKNOWN = 0, OSSIM_CHIPPER_PROJ_GEO = 1, OSSIM_CHIPPER_PROJ_GEO_SCALED = 2, OSSIM_CHIPPER_PROJ_INPUT = 3,
  OSSIM_CHIPPER_PROJ_UTM = 4
 emumerated output projections More...
 ossimChipperUtil ()
 default constructor More...
virtual ~ossimChipperUtil ()
 virtual destructor More...
void clear ()
 Disconnects and clears the dem and image layers. More...
bool initialize (ossimArgumentParser &ap)
 Initial method to be ran prior to execute. More...
void initialize (const ossimKeywordlist &kwl)
 Initialize method to be ran prior to execute. More...
void execute ()
 execute method. More...
void abort ()
ossimRefPtr< ossimImageDatagetChip (const ossimKeywordlist &optionsKwl=ossimKeywordlist())
 Gets initialized area of interest(aoi) from chain. More...
void getOutputFilename (ossimFilename &f) const
 Gets the output file name. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
void initialize ()
ossimRefPtr< ossimImageSourceinitializeChain (ossimIrect &aoi)
 Builds image chains returns ref pointer to image source and initializes area of interest(aoi). More...
void setOptionsToChain (ossimIrect &aoi, const ossimKeywordlist &kwl)
ossimRefPtr< ossimImageSourceinitializeColorReliefChain ()
 Initializes a color relief chain. More...
ossimRefPtr< ossimImageSourceinitializeBumpShadeChain ()
 Initializes a bump shade chain. More...
ossimRefPtr< ossimImageSourceinitialize2CmvChain ()
 Combines two images into a two color multi view chain. More...
ossimRefPtr< ossimImageSourceinitializePsmChain ()
 Initializes a psm (pan sharpening multispectra) chain. More...
void initializeOutputProjection ()
 Initializes the output projection and propagates to image chains. More...
void addDemSources ()
 Create chains for all dems. More...
void addDemSource (const ossimFilename &file, ossim_uint32 entryIndex)
 Method to create a chain and add to dem layers from file. More...
void addDemSource (const ossimSrcRecord &rec)
 Method to create a chain and add to dem layers from a ossimSrcRecord. More...
void addImgSources ()
 Creates chains for all images. More...
void addImgSource (const ossimFilename &file, ossim_uint32 entryIndex)
 Method to create a chain and add to img layers from file. More...
void addImgSource (const ossimSrcRecord &rec)
 Method to create a chain and add to img layers from a ossimSrcRecord. More...
ossimRefPtr< ossimSingleImageChaincreateChain (const ossimFilename &file, ossim_uint32 entryIndex, bool isDemSource) const
 Creates a ossimSingleImageChain from file. More...
ossimRefPtr< ossimSingleImageChaincreateChain (const ossimSrcRecord &rec, bool isDemSource) const
 Creates a ossimSingleImageChain from ossimSrcRecord. More...
void createOutputProjection ()
 Creates the output or view projection. More...
void createIdentityProjection ()
 Sets the single image chain for identity operations view to a ossimImageViewAffineTransform. More...
ossimRefPtr< ossimMapProjectiongetFirstInputProjection ()
 Gets the first input projection. More...
ossimRefPtr< ossimMapProjectiongetNewGeoProjection ()
 Convenience method to get geographic projection. More...
ossimRefPtr< ossimMapProjectiongetNewGeoScaledProjection ()
ossimRefPtr< ossimMapProjectiongetNewProjectionFromSrsCode (const std::string &code)
 Convenience method to get a projection from an srs code. More...
ossimRefPtr< ossimMapProjectiongetNewUtmProjection ()
 Convenience method to get a utm projection. More...
ossimRefPtr< ossimMapProjectiongetMapProjection ()
 Convenience method to get a pointer to the output map projection. More...
void intiailizeProjectionTiePoint ()
 Sets the projection tie point to the scene bounding rect corner. More...
void initializeProjectionGsd ()
 Initializes the projection gsd. More...
void initializeIvtScale ()
 Initializes the image view transform(IVT) scale. More...
void getTiePoint (ossimGpt &tie)
 Loops through all layers to get the upper left tie point. More...
void getTiePoint (ossimSingleImageChain *chain, ossimGpt &tie)
 Gets the upper left tie point from a chain. More...
void getTiePoint (ossimDpt &tie)
void getTiePoint (ossimSingleImageChain *chain, ossimDpt &tie)
void getMetersPerPixel (ossimDpt &gsd)
 Loops through all layers to get the best gsd. More...
void getMetersPerPixel (ossimSingleImageChain *chain, ossimDpt &gsd)
 Gets the gsd from a chain. More...
ossim_float64 getCentralMeridian () const
 Gets value of key "central_meridan" if set, nan if not. More...
ossim_float64 getOriginLatitude () const
 Gets value of key "origin_latitude" if set, nan if not. More...
void getSceneCenter (ossimGpt &gpt)
 Loops through all layers to get the scene center ground point. More...
void getSceneCenter (ossimSingleImageChain *chain, ossimGpt &gpt)
 Gets the scene center from a chain. More...
ossimRefPtr< ossimImageFileWritercreateNewWriter () const
 Creates a new writer. More...
void propagateOutputProjectionToChains ()
 loops through all chains and sets the output projection. More...
ossimRefPtr< ossimImageSourcecombineLayers (std::vector< ossimRefPtr< ossimSingleImageChain > > &layers) const
 Combines all layers into an ossimImageMosaic. More...
ossimRefPtr< ossimImageSourcecombineLayers ()
 Combines dems(m_demLayer) and images(m_imgLayer). More...
ossimRefPtr< ossimImageSourceaddIndexToRgbLutFilter (ossimRefPtr< ossimImageSource > &source) const
 Creates ossimIndexToRgbLutFilter and connects to source. More...
ossimRefPtr< ossimImageSourceaddScalarRemapper (ossimRefPtr< ossimImageSource > &source, ossimScalarType scalar) const
 Creates ossimScalarRemapper and connects to source. More...
ossimRefPtr< ossimImageSourceaddAnnotations (ossimRefPtr< ossimImageSource > &source) const
 Add annotation source to chain. More...
void addCrossHairAnnotation (ossimRefPtr< ossimAnnotationSource > annotator, const std::string &prefix) const
 Adds cross hair graphic to annotation source. More...
bool setupChainHistogram (ossimRefPtr< ossimSingleImageChain > &chain, std::shared_ptr< ossimSrcRecord > srcRecordPtr=0) const
 Set up ossimHistogramRemapper for a chain. More...
bool setChainEntry (ossimRefPtr< ossimSingleImageChain > &chain, ossim_uint32 entryIndex) const
 Sets entry for a chain. More...
void getAreaOfInterest (ossimImageSource *source, ossimIrect &rect) const
 Initializes "rect" with the output area of interest. More...
bool getIrect (const std::string &s, ossimIrect &rect) const
 Gets rect from string in the form of <x>,<y>,<w>,<h>. More...
bool getIrect (ossimRefPtr< ossimSingleImageChain > &chain, const std::string &s, ossimIrect &rect) const
 Gets image rect from string in the form of <lat>,<lon>,<w>,<h>. More...
bool getIrect (ossimRefPtr< ossimSingleImageChain > &chain, ossimIrect &rect) const
 Gets 256 x 256 image rect from center of the image. More...
void initializeThumbnailProjection (const ossimIrect &originalRect, ossimIrect &adjustedRect)
 Method to calculate and initialize scale and area of interest for making a thumbnail. More...
bool hasBandSelection () const
void getBandList (std::vector< ossim_uint32 > &bandList) const
 Gets the band list if BANDS keyword is set. More...
bool hasAnnotations () const
bool hasLutFile () const
bool hasBrightnesContrastOperation () const
bool hasGeoPolyCutterOption () const
bool hasBumpShadeArg () const
bool hasThumbnailResolution () const
bool hasHistogramOperation () const
bool isDemFile (const ossimFilename &file) const
bool isSrcFile (const ossimFilename &file) const
void initializeSrcKwl ()
 Initializes m_srcKwl if option was set. More...
ossim_uint32 getNumberOfInputs () const
ossimChipperOutputProjection getOutputProjectionType () const
 Gets the emumerated output projection type. More...
ossimScalarType getOutputScalarType () const
 Returns the scalar type from OUTPUT_RADIOMETRY_KW keyword if present. More...
bool scaleToEightBit () const
bool snapTieToOrigin () const
void getImageSpaceScale (ossimDpt &imageSpaceScale) const
 Gets the image space scale. More...
void getImageSpacePivot (ossimDpt &imageSpacePivot) const
 Gets the image space pivot. More...
ossim_float64 getRotation () const
 Gets rotation. More...
bool hasRotation () const
bool upIsUp () const
bool northUp () const
bool isChipMode () const
bool keyIsTrue (const std::string &key) const
ossim_uint32 getEntryNumber () const
ossim_int32 getZone () const
std::string getHemisphere () const
bool hasSensorModelInput ()
bool hasCutBoxWidthHeight () const
bool hasWmsBboxCutWidthHeight () const
bool hasScaleOption () const
bool isThreeBandOut () const
bool padThumbnail () const
void setReaderProps (ossimImageHandler *ih) const
 Passes reader properties to single image handler if any. More...
void addArguments (ossimArgumentParser &ap)
 Adds application arguments to the argument parser. More...
void getClipPolygon (ossimGeoPolygon &polygon) const
ossim_float64 getBrightness () const
 Gets the brightness level. More...
ossim_float64 getContrast () const
 Gets the contrast level. More...
std::string getSharpenMode () const
 Gets the sharpen mode. More...
int getHistoMode () const
void usage (ossimArgumentParser &ap)
 Initializes arg parser and outputs usage. More...
 ossimChipperUtil (const ossimChipperUtil &obj)
 Hidden from use copy constructor. More...
const ossimChipperUtiloperator= (const ossimChipperUtil &rhs)
 Hidden from use assignment operator. More...
ossimRefPtr< ossimImageSourcecreateCombiner () const
Private Attributes
ossimChipperOperation m_operation
 Enumerated operation to perform. More...
ossimRefPtr< ossimKeywordlistm_kwl
 Hold all options passed into intialize. More...
ossimRefPtr< ossimKeywordlistm_srcKwl
 Hold contents of src file if –src is used. More...
ossimRefPtr< ossimImageGeometrym_geom
 The image geometry. More...
ossimRefPtr< ossimImageViewAffineTransformm_ivt
 Image view transform(IVT). More...
std::vector< ossimRefPtr< ossimSingleImageChain > > m_demLayer
 Array of dem chains. More...
std::vector< ossimRefPtr< ossimSingleImageChain > > m_imgLayer
 Array of image source chains. More...
ossimRefPtr< ossimImageFileWriterm_writer
 We need access to the writer so we can support aborting. More...
ossimRefPtr< ossimImageSourcem_source
 We need to support changing clips without doing a full initilization. More...
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
This is a utility class to orthorectify imagery with an added slant toward doing digital elevation model(DEM) operations.
See the ossim-dem application for a code usage example.
Note
Almost all methods use throw for stack unwinding. This is not in method declarations to alleviate build errors on windows. Sorry...
"bumpshade" and "hillshade" intermixed throughout. The class to do a hillshade is the ossimBumpShadeTileSource.
Definition at line 61 of file ossimChipperUtil.h.
◆ ossimChipperOperation
Enumerator
Definition at line 66 of file ossimChipperUtil.h.
◆ ossimChipperOutputProjection
Enumerator
Definition at line 78 of file ossimChipperUtil.h.
◆ ossimChipperUtil() [1/2]
ossimChipperUtil::ossimChipperUtil ( )
default constructor
Definition at line 142 of file ossimChipperUtil.cpp.
References m_kwl, and ossimKeywordlist::setExpandEnvVarsFlag().
143  : ossimReferenced(),
145  m_kwl(new ossimKeywordlist()),
146  m_srcKwl(0),
147  m_geom(0),
148  m_ivt(0),
149  m_demLayer(0),
150  m_imgLayer(0)
151 {
152  // traceDebug.setTraceFlag(true);
153
155 }
ossimRefPtr< ossimKeywordlist > m_srcKwl
ossimRefPtr< ossimKeywordlist > m_kwl
ossimRefPtr< ossimImageGeometry > m_geom
The image geometry.
ossimRefPtr< ossimImageViewAffineTransform > m_ivt
void setExpandEnvVarsFlag(bool flag)
◆ ~ossimChipperUtil()
ossimChipperUtil::~ossimChipperUtil ( )
virtual
virtual destructor
Definition at line 187 of file ossimChipperUtil.cpp.
References clear().
188 {
189  clear();
190 }
void clear()
◆ ossimChipperUtil() [2/2]
ossimChipperUtil::ossimChipperUtil ( const ossimChipperUtil obj)
private
Definition at line 158 of file ossimChipperUtil.cpp.
160 {
161 }
Member Function Documentation
◆ abort()
void ossimChipperUtil::abort ( )
Definition at line 1500 of file ossimChipperUtil.cpp.
References ossimProcessInterface::abort(), m_writer, and ossimRefPtr< T >::valid().
1501 {
1502  if(m_writer.valid())
1503  {
1504  m_writer->abort();
1505  }
1506 }
bool valid() const
Definition: ossimRefPtr.h:75
ossimRefPtr< ossimImageFileWriter > m_writer
◆ addAnnotations()
ossimRefPtr< ossimImageSource > ossimChipperUtil::addAnnotations ( ossimRefPtr< ossimImageSource > &  source) const
private
Parameters
Sourceto connect to.
Returns
End of chain with annotion source on it.
Definition at line 3999 of file ossimChipperUtil.cpp.
4001 {
4002  static const char MODULE[] = "ossimChipperUtil::addAnnotations(source)";
4003  if ( traceDebug() )
4004  {
4005  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
4006  }
4007
4008  ossimRefPtr<ossimImageSource> result = 0;
4009
4010  if ( source.valid() & m_geom.valid() )
4011  {
4012  ossimString regularExpression = "annotation[0-9]*\\.type";
4013  const ossim_uint32 COUNT = m_kwl->getNumberOfKeysThatMatch( regularExpression );
4014  if ( COUNT > 0 )
4015  {
4016  // Create annotator:
4018
4019  // Connect it up:
4020  annotator->connectMyInputTo( source.get() );
4021
4022  // Loop through keyword list and add all annotation objects.
4023  ossim_uint32 i = 0;
4024  ossim_uint32 found = 0;
4025  std::string prefixBase = "annotation";
4026  std::string prefix;
4027  std::string key;
4028  std::string value;
4029  while ( (found < COUNT) && ( i < (COUNT+100) ) )
4030  {
4031  prefix = prefixBase + ossimString::toString( i ).string() + ".";
4032  key = "type";
4033  value = m_kwl->findKey( prefix, key );
4034  if ( value.size() )
4035  {
4036  ++found;
4037
4038  if ( value == "cross_hair" )
4039  {
4040  addCrossHairAnnotation( annotator, prefix );
4041  }
4042  }
4043  ++i;
4044  }
4045
4046  annotator->initialize();
4047
4048  // Assign return result:
4049  result = annotator.get();
4050  }
4051  }
4052  else
4053  {
4054  std::string errMsg = MODULE;
4055  errMsg += " ERROR: Null source passed to method!";
4056  throw ossimException(errMsg);
4057  }
4058
4059  if ( traceDebug() )
4060  {
4061  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited...\n";
4062  }
4063
4064  return result;
4065 }
const std::string & findKey(const std::string &key) const
Find methods that take std::string(s).
bool valid() const
Numeric to string methods.
ossim_uint32 getNumberOfKeysThatMatch(const ossimString &regularExpression) const
Gets number keys that match regular expression.
unsigned int ossim_uint32
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
The image geometry.
void addCrossHairAnnotation(ossimRefPtr< ossimAnnotationSource > annotator, const std::string &prefix) const
const std::string & string() const
Definition: ossimString.h:414
◆ addArguments()
void ossimChipperUtil::addArguments ( ossimArgumentParser ap)
private
Parameters
apParser to add to.
Definition at line 192 of file ossimChipperUtil.cpp.
References ossimApplicationUsage::addCommandLineOption(), ossimArgumentParser::getApplicationName(), ossimArgumentParser::getApplicationUsage(), ossimApplicationUsage::setCommandLineUsage(), and ossimApplicationUsage::setDescription().
Referenced by usage().
193 {
194  ossimString usageString = ap.getApplicationName();
195  usageString += " [option]... [input-option]... <input-file(s)> <output-file>\nNote at least one input is required either from one of the input options, e.g. --input-dem <my-dem.hgt> or adding to command line in front of the output file in which case the code will try to ascertain what type of input it is.\n\nAvailable traces:\n-T \"ossimChipperUtil:debug\" - General debug trace to standard out.\n-T \"ossimChipperUtil:log\" - Writes a log file to output-file.log.\n-T \"ossimChipperUtil:options\" - Writes the options to output-file-options.kwl.";
196
198
199  au->setCommandLineUsage(usageString);
200
201  au->setDescription(ap.getApplicationName()+" Utility application for generating elevation products from dem data.");
202
203  au->addCommandLineOption("--azimuth", "<azimuth>\nhillshade option - Light source azimuth angle for bump shade.\nRange: 0 to 360, Default = 180.0");
204
205  au->addCommandLineOption( "-b or --bands <n,n...>", "Use the specified bands in given order: e.g. \"3,2,1\" will select bands 3, 2 and 1 of the input image.\nNote: it is 1 based" );
206
207  au->addCommandLineOption( "--brightness", "<brightness>\nApply brightness to input image(s). Valid range: -1.0 to 1.0" );
208
209  au->addCommandLineOption("--central-meridian","<central_meridian_in_decimal_degrees>\nNote if set this will be used for the central meridian of the projection. This can be used to lock the utm zone.");
210
211  au->addCommandLineOption("--color","<r> <g> <b>\nhillshade option - Set the red, green and blue color values to be used with hillshade.\nThis option can be used with or without an image source for color.\nRange 0 to 255, Defualt r=255, g=255, b=255");
212
213  au->addCommandLineOption("--color-table","<color-table.kwl>\nhillshade or color-relief option - Keyword list containing color table for color-relief option.");
214
215  au->addCommandLineOption( "--contrast", "<constrast>\nApply constrast to input image(s). Valid range: -1.0 to 1.0" );
216
217  au->addCommandLineOption("--cut-bbox-xywh", "<x>,<y>,<width>,<height>\nSpecify a comma separated bounding box.");
218
219  au->addCommandLineOption("--cut-wms-bbox", "<minx>,<miny>,<maxx>,<maxy>\nSpecify a comma separated list in the format of a WMS BBOX.\nThe units are in the units of the projector defined by the --srs key");
220
221  au->addCommandLineOption("--cut-wms-bbox-ll", "<minx>,<miny>,<maxx>,<maxy>\nSpecify a comma separated list in the format of a WMS BBOX.\nThe units are always decimal degrees");
222
223  au->addCommandLineOption("--cut-width", "<width>\nSpecify the cut width in pixel");
224
225  au->addCommandLineOption("--cut-height", "<height>\nSpecify the cut height in pixel");
226
227  au->addCommandLineOption("--clip-wms-bbox-ll", "<minx>,<miny>,<maxx>,<maxy>\nSpecify a comma separated list in the format of a WMS BBOX.\nThe units are always decimal degrees");
228
229  au->addCommandLineOption("--clip-poly-lat-lon", "Polygon in the form of a string: (lat,lon),(lat,lon),...(lat,lon)");
230
231  au->addCommandLineOption("--cut-bbox-ll", "<min_lat> <min_lon> <max_lat> <max_lon>\nSpecify a bounding box with the minimum latitude/longitude and max latitude/longitude in decimal degrees.\nNote coordinates are edge to edge.");
232
233  au->addCommandLineOption("--cut-bbox-llwh", "<min_lat> <min_lon> <max_lat> <max_lon> <width> <height>\nSpecify a bounding box with the minimum latitude/longitude, max latitude/longitude in decimal degrees and width/height in pixels.\nNote coordinates are edge to edge.");
234
235  au->addCommandLineOption("--cut-center-llwh","<latitude> <longitude> <width> <height>\nSpecify the center cut in latitude longitude space with width and height in pixels.");
236
237  au->addCommandLineOption("--cut-center-llr","<latitude> <longitude> <radius_in_meters>\nSpecify the center cut in latitude longitude space with radius in meters.");
238
239  au->addCommandLineOption("--degrees","<dpp_xy> | <dpp_x> <dpp_y>\nSpecifies an override for degrees per pixel. Takes either a single value applied equally to x and y directions, or two values applied correspondingly to x then y. This option takes precedence over the \"--meters\" option.");
240
241  au->addCommandLineOption("--enable-null-pixel-flip", "Will add to the start of the chain and will flip interior pixels that are null to valid.");
242  au->addCommandLineOption("--elevation", "<elevation>\nhillshade option - Light source elevation angle for bumb shade.\nRange: 0 to 90, Default = 45.0");
243
244  au->addCommandLineOption("-e or --entry", "<entry> For multi image handlers which entry do you wish to extract. For list of entries use: \"ossim-info -i <your_image>\" ");
245
246  au->addCommandLineOption("--exaggeration", "<factor>\nMultiplier for elevation values when computing surface normals. Has the effect of lengthening shadows for oblique lighting.\nRange: .0001 to 50000, Default = 1.0");
247
248  au->addCommandLineOption("--fullres-xys", "<full res center x>,<full res center y>,<scale>[,<scale>]\nSpecify a full resolution x,y point (Used as pivot and center cut) and scale, comma seperated with no spaces. If two scales are specified then first is x and second is y else x and y are set to equal scales");
249
250  au->addCommandLineOption("-h or --help", "Display this help and exit.");
251
252  au->addCommandLineOption("--hemisphere", "<hemisphere>\nSpecify a projection hemisphere if supported. E.g. UTM projection. This will lock the hemisphere even if input scene center is the other hemisphere. Valid values for UTM are \"N\" and \"S\"");
253
254  au->addCommandLineOption("--histogram-aoi", "<x>,<y>,<width>,<height>\nSets single image region of interest(roi) to compute histogram from. Coordinates are zero based image space. Single image operation only. Comma separated, no spaces.");
255
256  au->addCommandLineOption("--histogram-center-tile", "Will compute histogram from center tile of image.");
257
258  au->addCommandLineOption("--histogram-llwh", "<latitude>,<longitude>,<width>,<height>\nSpecify the region of interest(roi) to compute histogram from. Latitude and longitude will be roi center space with width and height in pixels. Comma separated, no spaces.");
259
260  au->addCommandLineOption("--histogram-op", "<operation>\nHistogram operation to perform. Valid operations are \"auto-minmax\", \"auto-percentile\", \"std-stretch-1\", \"std-stretch-2\" and \"std-stretch-3\".");
261
262  au->addCommandLineOption("--image-space-scale","<x> <y>\nSpecifies an image space scale for x and y direction. \"chip\" operation only.");
263
264  au->addCommandLineOption("--input-dem", "<dem> Input dem to process.");
265
266  au->addCommandLineOption("--input-img", "<image> Input image to process.");
267
268  au->addCommandLineOption("--input-src","<file.src> Input source file list keyword list with list of dems or images or both to process.");
269
270  au->addCommandLineOption("--meters", "<meters>\nSpecifies an override for the meters per pixel");
271
272  au->addCommandLineOption("-n or --north-up", "Rotates image North up. \"chip\" operation only.");
273
274  au->addCommandLineOption( "--op", "<operation>\nOperation to perform. Valid operations are \"chip\", \"color-relief\", \"hillshade\", \"psm\"(pan sharpened multispectral), \"2cmv\"(two color multi view) and \"ortho\".\nchip = input projection = output projection(image space), single image operation only." );
275
276  au->addCommandLineOption("--options","<options.kwl> This can be all or part of the application options. To get a template you can turn on trace to the ossimChipperUtil class by adding \"-T ossimChipperUtil\" to your command.");
277
278  au->addCommandLineOption("--origin-latitude","<latidude_in_decimal_degrees>\nNote if set this will be used for the origin latitude of the projection. Setting this to something other than 0.0 with a geographic projection creates a scaled geographic projection.");
279
280  au->addCommandLineOption("--output-radiometry", "<R>\nSpecifies the desired product's pixel radiometry type. Possible values for <R> are: U8, U11, U16, S16, F32. Note this overrides the deprecated option \"scale-to-8-bit\".");
281
282  au->addCommandLineOption("--pad-thumbnail", "<boolean>\nIf true, output thumbnail dimensions will be padded in width or height to make square; else, it will have the aspect ratio of input, Default=false");
283
284  au->addCommandLineOption("--projection", "<output_projection> Valid projections: geo, geo-scaled, input or utm\ngeo = Equidistant Cylindrical, origin latitude = 0.0\ngeo-scaled = Equidistant Cylindrical, origin latitude = image center\ninput Use first images projection. Must be a map projecion.\nutm = Universal Tranverse Mercator\nIf input and multiple sources the projection of the first image will be used.\nIf utm the zone will be set from the scene center of first image.\nNOTE: --srs takes precedence over this option.");
285
286  au->addCommandLineOption("--resample-filter","<type>\nSpecify what resampler filter to use, e.g. nearest neighbor, bilinear, cubic, sinc.\nSee ossim-info --resampler-filters");
287
288  au->addCommandLineOption("-r or --rotate", "<degrees>\nRotate image by degrees. \"chip\" operation only.");
289
290  au->addCommandLineOption("--reader-prop", "<string>Adds a property to send to the reader. format is name=value");
291
292  au->addCommandLineOption("--rrds", "<rrds> Reduced resolution data set where 0 is full resolution. \"chip\" operation only.");
293
294  au->addCommandLineOption("--scale-to-8-bit", "Scales the output to unsigned eight bits per band. This option has been deprecated by the newer \"--output-radiometry\" option.");
295
296  au->addCommandLineOption("--sharpen-mode", "<mode> Applies sharpness to image chain(s). Valid modes: \"light\", \"heavy\"");
297
298  au->addCommandLineOption("--snap-tie-to-origin",
299  "Snaps tie point to projection origin so that (tie-origin)/gsd come out on an even integer boundary.");
300
301  au->addCommandLineOption("--srs","<src_code>\nSpecify a spatial reference system(srs) code for the output projection. Example: --srs EPSG:4326");
302
303  au->addCommandLineOption("-t or --thumbnail", "<max_dimension>\nSpecify a thumbnail resolution.\nScale will be adjusted so the maximum dimension = argument given.");
304
305  au->addCommandLineOption("--three-band-out", "Force three band output even if input is not. Attempts to map bands to RGB if possible.");
306
307  au->addCommandLineOption("--tile-size", "<size_in_pixels>\nSets the output tile size if supported by writer. Notes: This sets both dimensions. Must be a multiple of 16, e.g. 1024.");
308
309  au->addCommandLineOption("-u or --up-is-up", "Rotates image to up is up. \"chip\" operation only.");
310
311  au->addCommandLineOption("-w or --writer","<writer>\nSpecifies the output writer. Default uses output file extension to determine writer. For valid output writer types use: \"ossim-info --writers\"\n");
312
313  au->addCommandLineOption("--writer-prop", "<writer-property>\nPasses a name=value pair to the writer for setting it's property. Any number of these can appear on the line.");
314
315  au->addCommandLineOption("--zone", "<zone>\nSpecify a projection zone if supported. E.g. UTM projection. This will lock the zone even if input scene center is in another zone. Valid values for UTM are \"1\" to \"60\"");
316
317  au->addCommandLineOption("--2cmv-old-input-band", "<band>\nBand to use for two color multi view old input.\n");
318  au->addCommandLineOption("--2cmv-new-input-band", "<band>\nBand to use for two color multi view new input.\n");
319
320  au->addCommandLineOption("--2cmv-red-output-source", "<source>\nTwo color multi view source input for red output. Either, old, new, or mp(min pix). Default=old.\n");
321
322  au->addCommandLineOption("--2cmv-green-output-source", "<source>\nTwo color multi view source input for green output. Either, old, new, or mp(min pix). Default=new.\n");
323
324  au->addCommandLineOption("--2cmv-blue-output-source", "<source>\nTwo color multi view source input for blue output. Either, old, new, or mp(min pix). Default=new.\n");
325  au->addCommandLineOption("--combiner-type", "<type>\nossimBlendMosaic, ossimFeatherMosaic, ossimImageMosaic. Default: ossimImageMosaic. Example --combiner-type ossimImageMosaic\n");
326
327 } // End: ossimChipperUtil::addArguments
std::string getApplicationName() const
return the application name, as specified by argv[0]
void addCommandLineOption(const ossimString &option, const ossimString &explanation)
void setCommandLineUsage(const ossimString &explanation)
ossimApplicationUsage * getApplicationUsage()
void setDescription(const ossimString &desc)
◆ addCrossHairAnnotation()
void ossimChipperUtil::addCrossHairAnnotation ( ossimRefPtr< ossimAnnotationSource annotator,
const std::string &  prefix
) const
private
Parameters
Annotatorto add objects to.
prefixe.g. annotation0.
Definition at line 4067 of file ossimChipperUtil.cpp.
References ossimAnnotationSource::addObject(), ossimKeywordlist::findKey(), ossimRefPtr< T >::get(), ossimAnnotationFontObject::getBoundingRect(), ossimAnnotationSource::getBoundingRect(), ossimDpt::hasNans(), ossimGpt::hasNans(), ossimImageViewAffineTransform::imageToView(), ossimAnnotationObject::loadState(), m_geom, m_ivt, m_kwl, ossimDpt::makeNan(), ossimIrect::midPoint(), ossimAnnotationLineObject::setLine(), ossimAnnotationFontObject::setPointSize(), ossimAnnotationFontObject::setScale(), ossimAnnotationFontObject::setString(), ossimAnnotationFontObject::setUpperLeftPosition(), ossimString::toInt32(), ossimIpt::toPoint(), ossimDpt::toPoint(), ossimGpt::toPoint(), ossimRefPtr< T >::valid(), ossimDrect::width(), ossimImageGeometry::worldToLocal(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
4069 {
4070  if ( annotator.valid() && prefix.size() )
4071  {
4072  std::string linePrefix = prefix + std::string("line.");
4073  std::string textPrefix = prefix + std::string("text.");
4074  ossimDpt centerPt;
4075  centerPt.makeNan();
4076  ossim_float64 lineSize = 8.0;
4077  ossimDpt start;
4078  ossimDpt end;
4079
4080  // Cross hair line location:
4081  std::string key = "location";
4082  std::string value = m_kwl->findKey( linePrefix, key );
4083  if ( value.size() )
4084  {
4085  if (value == "scene_center")
4086  {
4087  ossimIrect boundingRect = annotator->getBoundingRect( 0 );
4088  centerPt = boundingRect.midPoint();
4089  }
4090  }
4091  else
4092  {
4093  key = "location.gpt";
4094  value = m_kwl->findKey( linePrefix, key );
4095  if ( value.size() )
4096  {
4097  ossimGpt gpt;
4098  gpt.toPoint( value );
4099  if ( gpt.hasNans() == false )
4100  {
4101  // Convert to view coordinate.
4102  ossimDpt imgPt;
4103  m_geom->worldToLocal( gpt, imgPt );
4104  if ( m_ivt.valid() )
4105  {
4106  m_ivt->imageToView( imgPt, centerPt );
4107  }
4108  else
4109  {
4110  centerPt = imgPt;
4111  }
4112  }
4113  }
4114  }
4115
4116  if ( centerPt.hasNans() == false )
4117  {
4118  // Cross hair size:
4119  key = "size";
4120  value = m_kwl->findKey( linePrefix, key );
4121  if ( value.size() )
4122  {
4123  lineSize = ossimString::toInt32( ossimString(value) );
4124  }
4125  ossim_float64 halfLine = lineSize/2.0;
4126
4127  // Create lines.
4129
4130  // Pick up r,g,b,thickness.
4131  line1->loadState( *(m_kwl.get()), linePrefix.c_str() );
4132
4133  start.x = centerPt.x;
4134  start.y = centerPt.y-halfLine;
4135  end.x = centerPt.x;
4136  end.y = centerPt.y+halfLine;
4137
4138  // ossimAnnotationLineObject::setLine recomputes the bounding box.
4139  line1->setLine( start, end );
4140
4141  annotator->addObject( line1.get() );
4142
4144
4145  // This will pick up r,g,b,thickness.
4146  line2->loadState( *(m_kwl.get()), linePrefix.c_str() );
4147
4148  start.x = centerPt.x-halfLine;
4149  start.y = centerPt.y;
4150  end.x = centerPt.x+halfLine;
4151  end.y = centerPt.y;
4152
4153  // ossimAnnotationLineObject::setLine recomputes the bounding box.
4154  line2->setLine( start, end );
4155
4156  annotator->addObject( line2.get() );
4157
4158  // Set text if any:
4159  key = "string";
4160  value = m_kwl->findKey( textPrefix, key );
4161  if ( value.size() )
4162  {
4164  text->loadState( *(m_kwl.get()), textPrefix.c_str() );
4165
4166  text->setString( ossimString(value) );
4167
4168  // text scale:
4169  key = "scale";
4170  value = m_kwl->findKey( textPrefix, key );
4171  if ( value.size() )
4172  {
4173  ossimDpt scale;
4174  scale.toPoint( value );
4175  text->setScale( scale );
4176  }
4177
4178  // text point size:
4179  key = "point_size";
4180  value = m_kwl->findKey( textPrefix, key );
4181  if ( value.size() )
4182  {
4183  ossimIpt ptSize;
4184  ptSize.toPoint( value );
4185  text->setPointSize( ptSize );
4186  }
4187
4188  // text location:
4189  key = "location";
4190  value = m_kwl->findKey( textPrefix, key );
4191  if ( value.size() )
4192  {
4193  if ( value == "bottom" )
4194  {
4195  ossimIpt ipt;
4196  ipt.x = (ossim_int32)centerPt.x;
4197  ipt.y = (ossim_int32)(centerPt.y+halfLine+10);
4198  text->setUpperLeftPosition( ipt );
4199
4200  ossimDrect rect;
4201  text->getBoundingRect( rect );
4202  ipt.x = ipt.x - rect.width()/2;
4203  text->setUpperLeftPosition( ipt );
4204  }
4205  }
4206
4207  annotator->addObject( text.get() );
4208  }
4209  }
4210  }
4211
4212 } // End: ossimChipperUtil::addCrossHairAnnotations( ... )
ossim_float64 width() const
Definition: ossimDrect.h:522
bool valid() const
double y
Definition: ossimDpt.h:165
virtual void setPointSize(const ossimIpt &size)
virtual void imageToView(const ossimDpt &imagePoint, ossimDpt &viewPoint) const
virtual void setUpperLeftPosition(const ossimIpt &position)
virtual bool addObject(ossimAnnotationObject *anObject)
ossim_int32 toInt32() const
double ossim_float64
void toPoint(const std::string &s)
Initializes this point from string.
Definition: ossimGpt.cpp:116
virtual void setScale(const ossimDpt &scale)
void setLine(const ossimDpt &start, const ossimDpt &end)
ossimIpt midPoint() const
Definition: ossimIrect.h:750
virtual void setString(const ossimString &s)
Definition: ossimDpt.cpp:192
Class to draw fonts onto an image.
bool hasNans() const
Definition: ossimDpt.h:67
The image geometry.
Definition: ossimIpt.cpp:170
Definition: ossimGpt.h:135
ossim_int32 y
Definition: ossimIpt.h:142
double x
Definition: ossimDpt.h:164
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
ossim_int32 x
Definition: ossimIpt.h:141
virtual void getBoundingRect(ossimDrect &rect) const
void makeNan()
Definition: ossimDpt.h:65
int ossim_int32
◆ addDemSource() [1/2]
void ossimChipperUtil::addDemSource ( const ossimFilename file,
private
Parameters
fileImage to open. entryIndex Entry to open.
Definition at line 1613 of file ossimChipperUtil.cpp.
1614 {
1615  static const char MODULE[] = "ossimChipperUtil::addDemSource(const ossimFilename&)";
1616
1617  if ( traceDebug() )
1618  {
1619  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
1620  }
1621
1622  ossimRefPtr<ossimSingleImageChain> ic = createChain(file, entryIndex, true);
1623  if ( ic.valid() )
1624  {
1625  m_demLayer.push_back(ic);
1626  }
1627
1628  if ( traceDebug() )
1629  {
1630  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exiting...\n";
1631  }
1632 }
ossimRefPtr< ossimSingleImageChain > createChain(const ossimFilename &file, ossim_uint32 entryIndex, bool isDemSource) const
bool valid() const
◆ addDemSource() [2/2]
void ossimChipperUtil::addDemSource ( const ossimSrcRecord rec)
private
Definition at line 1634 of file ossimChipperUtil.cpp.
1635 {
1636  static const char MODULE[] = "ossimChipperUtil::addDemSource(const ossimSrcRecord&)";
1637
1638  if ( traceDebug() )
1639  {
1640  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
1641  }
1642
1644  if ( ic.valid() )
1645  {
1646  m_demLayer.push_back(ic);
1647  }
1648
1649  if ( traceDebug() )
1650  {
1651  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exiting...\n";
1652  }
1653 }
bool valid() const
◆ addDemSources()
void ossimChipperUtil::addDemSources ( )
private
Definition at line 1553 of file ossimChipperUtil.cpp.
1554 {
1555  static const char MODULE[] = "ossimChipperUtil::addDemSources";
1556
1557  if ( traceDebug() )
1558  {
1559  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
1560  }
1561
1562  std::vector<ossimString> sortedList;
1563  m_kwl->getSortedList(sortedList, DEM_KW);
1564  for(auto record:sortedList)
1565  {
1566  ossimString key = record + ".";
1567  ossimString file = key + FILE_KW;
1569  ossimFilename f = m_kwl->findKey( file.string() );
1570  if ( f.size() )
1571  {
1572  // Look for the entry key, e.g. dem0.entry: 10
1573  ossim_uint32 entryIndex = 0;
1574  std::string value = m_kwl->findKey( entry.string() );
1575  if ( value.size() )
1576  {
1577  entryIndex = ossimString(value).toUInt32();
1578  }
1579  else
1580  {
1581  // Get global entry. Set by "-e" on command line apps.
1582  entryIndex = getEntryNumber();
1583  }
1584  ossimSrcRecord srcRecord;
1585  srcRecord.setFilename(f);
1586  srcRecord.setEntryIndex(entryIndex);
1587  // addDemSource( f, entryIndex );
1588  addDemSource( srcRecord );
1589  }
1590  }
1591  sortedList.clear();
1592  if ( m_srcKwl.valid() )
1593  {
1594  // Add stuff from src keyword list.
1595  m_srcKwl->getSortedList(sortedList, DEM_KW);
1596  for(auto record:sortedList)
1597  {
1598  ossimString prefix = record+".";
1599  ossimSrcRecord src;
1600  if ( src.loadState( *(m_srcKwl.get()), prefix ) )
1601  {
1602  addDemSource(src);
1603  }
1604  }
1605  }
1606
1607  if ( traceDebug() )
1608  {
1609  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited...\n";
1610  }
1611 }
Class used for parsing the command line *.src files.
bool loadState(const ossimKeywordlist &kwl, const char *prefix=0)
Initializes record from an in-memory KWL and prefix.
bool valid() const
void addDemSource(const ossimFilename &file, ossim_uint32 entryIndex)
ossim_uint32 toUInt32() const
void setEntryIndex(ossim_int32 i)
void setFilename(const ossimFilename &f)
std::string::size_type size() const
Definition: ossimString.h:405
static const char * ENTRY_KW
void getSortedList(std::vector< ossimString > &prefixValues, const ossimString &prefixKey) const
This return the sorted keys if you have a list.
ossim_uint32 getEntryNumber() const
◆ addImgSource() [1/2]
void ossimChipperUtil::addImgSource ( const ossimFilename file,
private
Parameters
Definition at line 1700 of file ossimChipperUtil.cpp.
1701 {
1702  static const char MODULE[] = "ossimChipperUtil::addImgSource";
1703
1704  if ( traceDebug() )
1705  {
1707  << MODULE << " entered...\nFile: " << file << "\n";
1708  }
1709
1710  ossimRefPtr<ossimSingleImageChain> ic = createChain(file, entryIndex, false);
1711  if ( ic.valid() )
1712  {
1713  m_imgLayer.push_back(ic);
1714  }
1715
1716  if ( traceDebug() )
1717  {
1718  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exiting...\n";
1719  }
1720 }
bool valid() const
◆ addImgSource() [2/2]
void ossimChipperUtil::addImgSource ( const ossimSrcRecord rec)
private
Definition at line 1722 of file ossimChipperUtil.cpp.
1723 {
1724  static const char MODULE[] = "ossimChipperUtil::addImgSource(const ossimSrcRecord&)";
1725
1726  if ( traceDebug() )
1727  {
1728  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
1729  }
1730
1732  if ( ic.valid() )
1733  {
1734  m_imgLayer.push_back(ic);
1735  }
1736
1737  if ( traceDebug() )
1738  {
1739  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exiting...\n";
1740  }
1741 }
bool valid() const
◆ addImgSources()
void ossimChipperUtil::addImgSources ( )
private
Definition at line 1655 of file ossimChipperUtil.cpp.
1656 {
1657  static const char MODULE[] = "ossimChipperUtil::addImgSources";
1658
1659  if ( traceDebug() )
1660  {
1661  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
1662  }
1663  std::vector<ossimString> sortedList;
1664  m_kwl->getSortedList(sortedList, IMG_KW);
1665  for(auto record:sortedList)
1666  {
1667  ossimString fileKey = record + "." + FILE_KW;
1668  ossimFilename f = m_kwl->findKey( fileKey.string() );
1669  if ( !f.empty())
1670  {
1671  ossimString imagePrefix = record+".";
1672  std::shared_ptr<ossimSrcRecord> srcRecord = std::make_shared<ossimSrcRecord>();
1673  if(srcRecord->loadState(*m_kwl, imagePrefix.c_str()))
1674  {
1675  addImgSource(*srcRecord);
1676  }
1677  }
1678  }
1679  sortedList.clear();
1680  if ( m_srcKwl.valid() )
1681  {
1682  m_srcKwl->getSortedList(sortedList, IMG_KW);
1683  for(auto record:sortedList)
1684  {
1685  ossimString prefix = record+".";
1686  std::shared_ptr<ossimSrcRecord> src = std::make_shared<ossimSrcRecord>();
1687  if ( src->loadState( *(m_srcKwl.get()), prefix ) )
1688  {
1689  addImgSource(*src);
1690  }
1691  }
1692  }
1693
1694  if ( traceDebug() )
1695  {
1696  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited...\n";
1697  }
1698 }
bool valid() const
void addImgSource(const ossimFilename &file, ossim_uint32 entryIndex)
const char * c_str() const
Definition: ossimString.h:396
bool empty() const
Definition: ossimString.h:411
◆ addIndexToRgbLutFilter()
ossimRefPtr< ossimImageSource > ossimChipperUtil::addIndexToRgbLutFilter ( ossimRefPtr< ossimImageSource > &  source) const
private
Parameters
Returns
End of chain with lut filter on it.
Note
Throws ossimException on error.
Definition at line 3895 of file ossimChipperUtil.cpp.
Referenced by initializeColorReliefChain().
3897 {
3898  static const char MODULE[] = "ossimChipperUtil::addIndexToRgbLutFilter(source)";
3899  if ( traceDebug() )
3900  {
3901  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
3902  }
3903
3904  ossimRefPtr<ossimImageSource> result = 0;
3905
3906  if ( source.valid() )
3907  {
3909  ossimFilename lutFile;
3910  lutFile.string() = m_kwl->findKey( LUT_FILE_KW );
3911  if ( lutFile.exists() )
3912  {
3913  //---
3914  // Connect to dems:
3915  // Must do this first so that the min and max get set from the input
3916  // connection prior to initializing the lut.
3917  //---
3918  lut->connectMyInputTo( source.get() );
3919
3920  // Note sure about this. Make option maybe? (drb)
3922
3923  lut->setLut(lutFile);
3924
3925  // Set as color source for bump shade.
3926  result = lut.get();
3927  }
3928  else
3929  {
3930  std::string errMsg = MODULE;
3931  errMsg += " color table does not exists: ";
3932  errMsg += lutFile.string();
3933  throw ossimException(errMsg);
3934  }
3935  }
3936  else
3937  {
3938  std::string errMsg = MODULE;
3939  errMsg += " ERROR: Null source passed to method!";
3940  throw ossimException(errMsg);
3941  }
3942
3943  if ( traceDebug() )
3944  {
3945  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited...\n";
3946  }
3947
3948  return result;
3949 }
bool valid() const
bool exists() const
void setLut(const ossimFilename &file)
Set lookup table(lut) method.
◆ addScalarRemapper()
ossimRefPtr< ossimImageSource > ossimChipperUtil::addScalarRemapper ( ossimRefPtr< ossimImageSource > &  source,
) const
private
Parameters
scalarScalar type.
Returns
End of chain with remapper on it.
Note
Definition at line 3951 of file ossimChipperUtil.cpp.
3953 {
3954  static const char MODULE[] = "ossimChipperUtil::addScalarRemapper(source)";
3955  if ( traceDebug() )
3956  {
3957  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
3958  }
3959
3960  ossimRefPtr<ossimImageSource> result = 0;
3961
3962  if ( source.valid() )
3963  {
3964  if ( ( scalar != OSSIM_SCALAR_UNKNOWN ) && ( source->getOutputScalarType() != scalar ) )
3965  {
3967  remapper->setOutputScalarType(scalar);
3968  remapper->connectMyInputTo( source.get() );
3969  result = remapper.get();
3970
3971  if ( traceDebug() )
3972  {
3974  << "\nOutput remapped to: "
3975  << ossimScalarTypeLut::instance()->getEntryString(scalar) << "\n";
3976  }
3977  }
3978  else
3979  {
3980  result = source;
3981  }
3982  }
3983  else
3984  {
3985  std::string errMsg = MODULE;
3986  errMsg += " ERROR: Null source passed to method!";
3987  throw ossimException(errMsg);
3988  }
3989
3990  if ( traceDebug() )
3991  {
3993  << MODULE << " exited...\n";
3994  }
3995
3996  return result;
3997 }
bool valid() const
virtual ossimString getEntryString(ossim_int32 entry_number) const
static ossimScalarTypeLut * instance()
Returns the static instance of an ossimScalarTypeLut object.
virtual void setOutputScalarType(ossimScalarType scalarType)
Sets the output scalar type.
◆ clear()
void ossimChipperUtil::clear ( )
Definition at line 329 of file ossimChipperUtil.cpp.
References ossimConnectableObject::disconnect(), m_demLayer, m_imgLayer, m_writer, and ossimRefPtr< T >::valid().
Referenced by initialize(), and ~ossimChipperUtil().
330 {
331  // Must disonnect chains so that they destroy.
332  std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator i = m_imgLayer.begin();
333  while ( i != m_imgLayer.end() )
334  {
335  (*i)->disconnect();
336  (*i) = 0;
337  ++i;
338  }
339  m_imgLayer.clear();
340
341  i = m_demLayer.begin();
342  while ( i != m_demLayer.end() )
343  {
344  (*i)->disconnect();
345  (*i) = 0;
346  ++i;
347  }
348  m_demLayer.clear();
349
350  if(m_writer.valid())
351  {
352  m_writer->disconnect();
353  m_writer = 0;
354  }
355 }
virtual void disconnect(ossimConnectableObject *object=0)
Will disconnect the object passed in.
bool valid() const
◆ combineLayers() [1/2]
ossimRefPtr< ossimImageSource > ossimChipperUtil::combineLayers ( std::vector< ossimRefPtr< ossimSingleImageChain > > &  layers) const
private
Returns
ossimRefPtr with pointer to ossimImageSource. Can be null.
Definition at line 3645 of file ossimChipperUtil.cpp.
3647 {
3648  static const char MODULE[] = "ossimChipperUtil::combineLayers(layers)";
3649  if ( traceDebug() )
3650  {
3651  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
3652  }
3653
3654  ossimRefPtr<ossimImageSource> result = 0;
3655
3656  if ( layers.size() == 1 )
3657  {
3658  result = layers[0].get();
3659  }
3660  else if ( layers.size() > 1 )
3661  {
3662
3663  result = createCombiner();//new ossimImageMosaic;
3664
3665  std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator chainIdx = layers.begin();
3666  while ( chainIdx != layers.end() )
3667  {
3668  result->connectMyInputTo( (*chainIdx).get() );
3669  ++chainIdx;
3670  }
3671  }
3672
3673  if ( traceDebug() )
3674  {
3675  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited...\n";
3676  }
3677
3678  return result;
3679 }
ossimRefPtr< ossimImageSource > createCombiner() const
◆ combineLayers() [2/2]
ossimRefPtr< ossimImageSource > ossimChipperUtil::combineLayers ( )
private
Definition at line 3681 of file ossimChipperUtil.cpp.
3682 {
3683  static const char MODULE[] = "ossimChipperUtil::combineLayers()";
3684  if ( traceDebug() )
3685  {
3686  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
3687  }
3688
3689  ossimRefPtr<ossimImageSource> result = 0;
3690
3691  ossim_uint32 layerCount = (ossim_uint32) (m_demLayer.size() + m_imgLayer.size());
3692
3693  if ( layerCount )
3694  {
3695  if ( layerCount == 1 )
3696  {
3697  if ( m_imgLayer.size() )
3698  {
3699  result = m_imgLayer[0].get();
3700  }
3701  else
3702  {
3703  result = m_demLayer[0].get();
3704  }
3705  }
3706  else
3707  {
3708  result = createCombiner();//new ossimImageMosaic;
3709
3710  // Combine the images. Note we'll put the images on top of the dems.
3711  if ( m_imgLayer.size() )
3712  {
3713  std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator chainIdx =
3714  m_imgLayer.begin();
3715  while ( chainIdx != m_imgLayer.end() )
3716  {
3717  result->connectMyInputTo( (*chainIdx).get() );
3718  ++chainIdx;
3719  }
3720  }
3721  if ( m_demLayer.size() ) // Combine any dem layers.
3722  {
3723  std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator chainIdx =
3724  m_demLayer.begin();
3725  while ( chainIdx != m_demLayer.end() )
3726  {
3727  result->connectMyInputTo( (*chainIdx).get() );
3728  ++chainIdx;
3729  }
3730  }
3731  }
3732  }
3733
3734  if ( traceDebug() )
3735  {
3736  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited...\n";
3737  }
3738
3739  return result;
3740
3741 } // End: ossimChipperUtil::combineLayers
◆ createChain() [1/2]
ossimRefPtr< ossimSingleImageChain > ossimChipperUtil::createChain ( const ossimFilename file,
bool  isDemSource
) const
private
Parameters
fileFile to open.
entryIndexEntry to open.
isDemSourceTrue if dem source, false if not. This controls chain options like histogram stretches.
Returns
Ref pointer to ossimSingleImageChain.
Note
Definition at line 1743 of file ossimChipperUtil.cpp.
1746 {
1747  static const char MODULE[] = "ossimChipperUtil::createChain(const ossimFilename&";
1748
1749  if ( traceDebug() )
1750  {
1752  << MODULE << " entered..."
1753  << "\nfile: " << file
1754  << "\nentry: " << entryIndex
1755  << "\nisDemSource: " << (isDemSource?"true":"false")
1756  << "\n";
1757  }
1758
1760
1761  if ( !file.empty()&&file.exists() )
1762  {
1763  ic = new ossimSingleImageChain;
1764  if ( ic->open( file ) )
1765  {
1766  // Set any reader props:
1767  setReaderProps( ic->getImageHandler().get() );
1768
1769  // we can't guarantee the state of the image handler at this point so
1770  // let's make sure that the entry is always set to the requested location
1771  // On Cib/Cadrg we were having problems. Removed the compare for entry 0
1772  //
1773
1774  if ( setChainEntry( ic, entryIndex ) == false )
1775  {
1776  std::ostringstream errMsg;
1777  errMsg << MODULE << " ERROR:\nEntry " << entryIndex << " out of range!"
1778  << std::endl;
1779  throw ossimException( errMsg.str() );
1780  }
1781
1782  //---
1783  // If PSM (pan sharpening) operation and this input is one band, don't
1784  // mess with its bands.
1785  //---
1786  bool psmPanInput = false;
1787  if ( ( m_operation == OSSIM_CHIPPER_OP_PSM ) && ( ic->getNumberOfOutputBands() == 1 ) )
1788  {
1789  psmPanInput = true;
1790  }
1791
1792  // Bands selection. Note: Not performed on PSM pan band.
1793  if ( !psmPanInput )
1794  {
1795  if ( isThreeBandOut() )
1796  {
1797  //---
1798  // This will guarantee three bands out. Will put band
1799  // selector at the end of the chain if input is one band. If input image
1800  // handler has implemented a getRgbBandlist(...) it will also set the
1801  // rgb band order.
1802  //---
1803  ic->setThreeBandFlag( true );
1804  }
1805
1806  if ( hasBandSelection() )
1807  {
1808  // User entered band list.
1809  std::vector<ossim_uint32> bandList(0);
1810  getBandList( bandList );
1811  if ( bandList.size() )
1812  {
1813  ic->setBandSelection( bandList );
1814  }
1815  else
1816  {
1817  ic->setDefaultBandSelection();
1818  }
1819  }
1820  }
1821
1822  ossimString nullPixelFlip = m_kwl->find(NULL_PIXEL_FLIP_KW.c_str());
1823  if(nullPixelFlip.toBool())
1824  {
1825  ic->setAddNullPixelFlipFlag(true);
1826  }
1827  //---
1828  // If multiple inputs and scaleToEightBit do it at the end of the processing
1829  // chain to alleviate un-even stretches between inputs.
1830  //---
1831  const ossim_uint32 INPUT_COUNT = getNumberOfInputs();
1832  bool scaleFlag = ( scaleToEightBit() && (INPUT_COUNT == 1) );
1833  ic->setRemapToEightBitFlag( scaleFlag );
1834
1835  // Always have resampler cache.
1836  ic->setAddResamplerCacheFlag(true);
1837
1838  //---
1839  // Don't need a chain cache as we're doing a sequential write. So the same tile
1840  // should never be visited more than once.
1841  //---
1842  ic->setAddChainCacheFlag(false);
1843
1844  //---
1845  // Histogram:
1846  // Don't apply histogram stretch to dem sources for hill shade
1847  // operation.
1848  //---
1849  if ( ( isDemSource == false ) ||
1850  ( isDemSource && (m_operation != OSSIM_CHIPPER_OP_HILL_SHADE) ) )
1851  {
1853  }
1854
1855  // Brightness, contrast. Note in same filter.
1857  {
1858  ic->setBrightnessContrastFlag(true);
1859  }
1860
1861  std::string sharpnessMode = getSharpenMode();
1862  if ( sharpnessMode.size() )
1863  {
1864  ic->setSharpenFlag(true);
1865  }
1866
1867  // Create the chain.
1868  ic->createRenderedChain();
1869
1870  // Set the filter type if needed.
1871  ossimString lookup = m_kwl->findKey( RESAMPLER_FILTER_KW );
1872  if ( lookup.size() )
1873  {
1874  // Assumption image renderer is in chain:
1875  ic->getImageRenderer()->getResampler()->setFilterType( lookup );
1876  }
1877
1878  // Histogram setup.
1879  if ( hasHistogramOperation() )
1880  {
1881  setupChainHistogram( ic );
1882  }
1883
1884  // Brightness constrast setup:
1886  {
1887  // Assumption bright contrast filter in chain:
1888
1889  ossim_float64 value = getBrightness();
1890  ic->getBrightnessContrast()->setBrightness( value );
1891
1892  value = getContrast();
1893  ic->getBrightnessContrast()->setContrast( value );
1894  }
1895
1896  // Sharpness:
1897  if ( sharpnessMode.size() )
1898  {
1899  if ( sharpnessMode == "light" )
1900  {
1901  ic->getSharpenFilter()->setWidthAndSigma( 3, 0.5 );
1902  }
1903  else if ( sharpnessMode == "heavy" )
1904  {
1905  ic->getSharpenFilter()->setWidthAndSigma( 5, 1.0 );
1906  }
1907  }
1908
1910  {
1911  ossimGeoPolygon polygon;
1912  getClipPolygon(polygon);
1913  if(polygon.size()>0)
1914  {
1915  ic->addGeoPolyCutterPolygon(polygon);
1916  }
1917  }
1918  }
1919  else
1920  {
1921  ic = 0;
1922  }
1923  }
1924
1925  if ( !ic.valid())
1926  {
1927  std::string errMsg = "Could not open: ";
1928  errMsg += file.string();
1929  throw ossimException(errMsg);
1930  }
1931
1932  if ( traceDebug() )
1933  {
1934  ossimKeywordlist kwl;
1935  ic->saveState(kwl, 0);
1936
1938  << "chain:\n" << kwl << "\n"
1939  << MODULE << " exiting...\n";
1940  }
1941
1942  return ic;
1943 }
std::string getSharpenMode() const
bool hasGeoPolyCutterOption() const
void setAddResamplerCacheFlag(bool flag)
If flag is true a resampler cache will be added to the chain at create time.
void setAddNullPixelFlipFlag(bool flag)
If flag is true a null pixel flip will be added to the chain at create time.
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
ossimRefPtr< const ossimImageSharpenFilter > getSharpenFilter() const
bool setChainEntry(ossimRefPtr< ossimSingleImageChain > &chain, ossim_uint32 entryIndex) const
ossimRefPtr< const ossimImageHandler > getImageHandler() const
virtual bool saveState(ossimKeywordlist &kwl, const char *prefix=NULL) const
Will save the state of the chain.
bool valid() const
void setSharpenFlag(bool flag)
Sets the sharpenflag.
void createRenderedChain()
Create a rendered image chain.
void getBandList(std::vector< ossim_uint32 > &bandList) const
bool hasBrightnesContrastOperation() const
void setBrightnessContrastFlag(bool flag)
Sets the brightness contrast flag.
void setBandSelection(const std::vector< ossim_uint32 > &bandList)
method to set band selector.
ossim_uint32 getNumberOfInputs() const
Single image chain class.
ossim_float64 getBrightness() const
bool exists() const
bool toBool() const
String to numeric methods.
bool setupChainHistogram(ossimRefPtr< ossimSingleImageChain > &chain, std::shared_ptr< ossimSrcRecord > srcRecordPtr=0) const
ossim_float64 getContrast() const
ossim_uint32 size() const
void setAddHistogramFlag(bool flag)
If flag is true a histogram will be added to the chain at create time.
bool hasBandSelection() const
void setRemapToEightBitFlag(bool flag)
Sets remap to eigth bit flag.
bool open(const ossimFilename &file, bool openOverview=true)
open method that takes an image file.
bool empty() const
void setReaderProps(ossimImageHandler *ih) const
bool isThreeBandOut() const
ossimRefPtr< const ossimImageRenderer > getImageRenderer() const
void getClipPolygon(ossimGeoPolygon &polygon) const
bool hasHistogramOperation() const
bool scaleToEightBit() const
void setThreeBandFlag(bool flag)
Sets the three band flag.
void addGeoPolyCutterPolygon(const vector< ossimGpt > &polygon)
ossimRefPtr< const ossimBrightnessContrastSource > getBrightnessContrast() const
void setAddChainCacheFlag(bool flag)
If flag is true a chain cache will be added to the chain at create time.
◆ createChain() [2/2]
ossimRefPtr< ossimSingleImageChain > ossimChipperUtil::createChain ( const ossimSrcRecord rec,
bool  isDemSource
) const
private
Parameters
srcRecord.
Returns
Note
Definition at line 1945 of file ossimChipperUtil.cpp.
1947 {
1948  static const char MODULE[] = "ossimChipperUtil::createChain(const ossimSrcRecord&)";
1949  if ( traceDebug() )
1950  {
1951  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
1952  }
1953
1955  if ( ic->open(rec) )
1956  {
1957  // Set any reader props:
1958  setReaderProps( ic->getImageHandler().get() );
1959
1960  // Entry is set in ossimSingleImageChain::open(src)
1961
1962  //---
1963  // If PSM (pan sharpening) operation and this input is one band, don't
1964  // mess with its bands.
1965  //---
1966  bool psmPanInput = false;
1967  if ( ( m_operation == OSSIM_CHIPPER_OP_PSM ) && ( ic->getNumberOfOutputBands() == 1 ) )
1968  {
1969  psmPanInput = true;
1970  }
1971
1972  // Bands selection. Note: Not performed on PSM pan band.
1973  if ( !psmPanInput )
1974  {
1975  if ( isThreeBandOut() )
1976  {
1977  //---
1978  // This will guarantee three bands out. Will put band
1979  // selector at the end of the chain if input is one band. If input image
1980  // handler has implemented a getRgbBandlist(...) it will also set the
1981  // rgb band order.
1982  //---
1983  ic->setThreeBandFlag( true );
1984  }
1985
1986  if ( hasBandSelection() )
1987  {
1988  // User entered band list.
1989  std::vector<ossim_uint32> bandList(0);
1990  getBandList( bandList );
1991  if ( bandList.size() )
1992  {
1993  ic->setBandSelection( bandList );
1994  }
1995  else
1996  {
1997  ic->setDefaultBandSelection();
1998  }
1999  }
2000  }
2001  ossimString nullPixelFlip = m_kwl->find(NULL_PIXEL_FLIP_KW.c_str());
2002  if (nullPixelFlip.toBool())
2003  {
2004  ic->setAddNullPixelFlipFlag(true);
2005  }
2006
2007  //---
2008  // If multiple inputs and scaleToEightBit do it at the end of the processing
2009  // chain to alleviate un-even stretches between inputs.
2010  //---
2011  const ossim_uint32 INPUT_COUNT = getNumberOfInputs();
2012  bool scaleFlag = ( scaleToEightBit() && (INPUT_COUNT == 1) );
2013  ic->setRemapToEightBitFlag( scaleFlag );
2014
2015  // Always have resampler cache.
2016  ic->setAddResamplerCacheFlag(true);
2017
2018  //---
2019  // Don't need a chain cache as we're doing a sequential write. So the same tile
2020  // should never be visited more than once.
2021  //---
2022  ic->setAddChainCacheFlag(false);
2023
2024  //---
2025  // Histogram:
2026  // Don't apply histogram stretch to dem sources for hill shade
2027  // operation.
2028  //---
2029  if ( ( isDemSource == false ) ||
2030  ( isDemSource && (m_operation != OSSIM_CHIPPER_OP_HILL_SHADE) ) )
2031  {
2033  }
2034
2035  // Brightness, contrast. Note in same filter.
2037  {
2038  ic->setBrightnessContrastFlag(true);
2039  }
2040
2041  std::string sharpnessMode = getSharpenMode();
2042  if ( sharpnessMode.size() )
2043  {
2044  ic->setSharpenFlag(true);
2045  }
2046
2047  //---
2048  // Create the chain.
2049  //
2050  // NOTE: Histogram and band selector can be set in ic->createRenderedChain(rec)
2051  // if the right keywords are there.
2052  //---
2053  ic->createRenderedChain(rec);
2054
2055  // Set the filter type if needed.
2056  ossimString lookup = m_kwl->findKey( RESAMPLER_FILTER_KW );
2057  if ( lookup.size() )
2058  {
2059  // Assumption image renderer is in chain:
2060  ic->getImageRenderer()->getResampler()->setFilterType( lookup );
2061  }
2062
2063  // Histogram setup.
2064  if ( hasHistogramOperation() )
2065  {
2066  setupChainHistogram( ic , std::make_shared<ossimSrcRecord>(rec));
2067  }
2068
2069  // Brightness constrast setup:
2071  {
2072  // Assumption bright contrast filter in chain:
2073
2074  ossim_float64 value = getBrightness();
2075  ic->getBrightnessContrast()->setBrightness( value );
2076
2077  value = getContrast();
2078  ic->getBrightnessContrast()->setContrast( value );
2079  }
2080
2081  // Sharpness:
2082  if ( sharpnessMode.size() )
2083  {
2084  if ( sharpnessMode == "light" )
2085  {
2086  ic->getSharpenFilter()->setWidthAndSigma( 3, 0.5 );
2087  }
2088  else if ( sharpnessMode == "heavy" )
2089  {
2090  ic->getSharpenFilter()->setWidthAndSigma( 5, 1.0 );
2091  }
2092  }
2093
2095  {
2096  ossimGeoPolygon polygon;
2097  getClipPolygon(polygon);
2098  if(polygon.size()>0)
2099  {
2100  ic->addGeoPolyCutterPolygon(polygon);
2101  }
2102  }
2103  }
2104  else // Open failed.
2105  {
2106  std::string errMsg = "Could not open from src record!";
2107  throw ossimException(errMsg);
2108  }
2109
2110  if ( traceDebug() )
2111  {
2112  ossimKeywordlist kwl;
2113  ic->saveState(kwl, 0);
2114
2116  << "chain:\n" << kwl << "\n"
2117  << MODULE << " exiting...\n";
2118  }
2119
2120  return ic;
2121 }
bool toBool() const
◆ createCombiner()
ossimRefPtr< ossimImageSource > ossimChipperUtil::createCombiner ( ) const
private
Definition at line 169 of file ossimChipperUtil.cpp.
References ossimKeywordlist::find(), and m_kwl.
170 {
172  ossimString combinerType = m_kwl->find(COMBINER_TYPE_KW.c_str());
173  if(combinerType.empty())
174  {
175  combinerType = "ossimImageMosaic";
176  }
177
179  if(!result.valid())
180  {
181  result = new ossimImageMosaic();
182  }
183
184  return result;
185 }
bool valid() const
An image mosaic is a simple combiner that will just do a simple mosaic.
virtual ossimImageSource * createImageSource(const ossimString &name) const
bool empty() const
static ossimImageSourceFactoryRegistry * instance()
◆ createIdentityProjection()
void ossimChipperUtil::createIdentityProjection ( )
private
This will have a rotation if up is up is selected. Also set m_outputProjection to the input's for area of interest.
Definition at line 2274 of file ossimChipperUtil.cpp.
Referenced by initializeOutputProjection().
2275 {
2276  static const char MODULE[] = "ossimChipperUtil::createIdentityProjection";
2277
2278  if ( traceDebug() )
2279  {
2280  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
2281  }
2282
2283  // Get the singe image chain. Sould be only one.
2285  if ( m_demLayer.size() )
2286  {
2287  sic = m_demLayer[0];
2288  }
2289  else if ( m_imgLayer.size() )
2290  {
2291  sic = m_imgLayer[0];
2292  }
2293
2294  if ( sic.valid() )
2295  {
2296  // Get the image handler.
2298
2299  // Resampler:
2301
2302  if ( ih.valid() )
2303  {
2304  //---
2305  // Get the geometry from the image handler. Since we're in "identity"
2306  // mode use the inputs for the outputs.
2307  //---
2308  m_geom = ih->getImageGeometry();
2309
2310  if ( m_geom.valid() )
2311  {
2312  ossim_float64 rotation = 0.0;
2313
2314  if ( upIsUp() )
2315  {
2317  if ( proj.valid() )
2318  {
2319  rotation = m_geom->upIsUpAngle();
2320  }
2321  else
2322  {
2324  << "WARNING: No projection to compute the up is up angle!" << std::endl;
2325  }
2326  }
2327  else if ( northUp() )
2328  {
2330  if ( proj.valid() )
2331  {
2332  rotation = m_geom->northUpAngle();
2333  }
2334  else
2335  {
2337  << "WARNING: No projection to compute the North up angle!" << std::endl;
2338  }
2339  }
2340  else if ( hasRotation() )
2341  {
2342  rotation = getRotation();
2343  }
2344
2345  if ( ossim::isnan( rotation ) )
2346  {
2347  rotation = 0.0;
2348  }
2349
2350  ossimDpt imageSpaceScale;
2351  getImageSpaceScale( imageSpaceScale );
2352
2353
2354  //ossimDrect rect;
2355  //m_geom->getBoundingRect(rect);
2356  ossimDpt midPt;// = rect.midPoint();
2357
2358  getImageSpacePivot(midPt);
2359
2360  if ( traceDebug() )
2361  {
2363  << MODULE
2364  << "\nAffine transform parameters:"
2365  << "\nrotation: " << rotation
2366  << "\nmid point: " << midPt << std::endl;
2367  }
2368
2369  m_ivt = new ossimImageViewAffineTransform(-rotation,
2370  imageSpaceScale.x, // image space scale x
2371  imageSpaceScale.y, // image space scale y
2372  1.0,1.0, //scale x and y
2373  0.0, 0.0, // translate x,y
2374  midPt.x*imageSpaceScale.x,
2375  midPt.y*imageSpaceScale.y); // pivot point
2376
2377  if ( m_kwl->hasKey( METERS_KW ) ||
2378  m_kwl->hasKey( DEGREES_X_KW ) ||
2379  m_kwl->hasKey( RRDS_KW ) )
2380  {
2381  // Set the image view transform scale.
2383  }
2384
2385
2386  resampler->setImageViewTransform( m_ivt.get() );
2387
2388  } // Matches: if ( m_geom.valid() )
2389
2390  } // Matches: if ( ih.valid() )
2391
2392  } // Matches: if ( sic.valid()
2393
2394 } // End: createIdentityProjection()
void getImageSpaceScale(ossimDpt &imageSpaceScale) const
bool valid() const
double y
bool hasKey(const std::string &key) const
Checks for key in map.
ossim_float64 getRotation() const
Gets rotation.
bool hasRotation() const
void setImageViewTransform(ossimImageViewTransform *transform)
void getImageSpacePivot(ossimDpt &imageSpacePivot) const
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
void initializeIvtScale()
The image geometry.
double x
ossim_float64 upIsUpAngle(const ossimDpt &) const
ossim_float64 northUpAngle() const
bool isnan(const float &v)
Definition: ossimCommon.h:91
◆ createNewWriter()
ossimRefPtr< ossimImageFileWriter > ossimChipperUtil::createNewWriter ( ) const
private
This will use the writer option (-w or –writer), if present; else, it will be derived from the output file extension.
This will also set any writer properties passed in.
Returns
new ossimImageFileWriter.
Note
Definition at line 3470 of file ossimChipperUtil.cpp.
3471 {
3472  static const char MODULE[] = "ossimChipperUtil::createNewWriter()";
3473  if ( traceDebug() )
3474  {
3475  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
3476  }
3477
3478  ossimFilename outputFile;
3479  getOutputFilename(outputFile);
3480
3481  if ( outputFile == ossimFilename::NIL)
3482  {
3483  std::string errMsg = MODULE;
3484  errMsg += " ERROR no output file name!";
3485  throw ossimException(errMsg);
3486  }
3487
3489
3490  ossimString lookup = m_kwl->findKey( WRITER_KW );
3491  if ( lookup.size() )
3492  {
3494  if ( !writer.valid() )
3495  {
3496  std::string errMsg = MODULE;
3497  errMsg += " ERROR creating writer: ";
3498  errMsg += lookup.string();
3499  throw ossimException(errMsg);
3500  }
3501  }
3502  else // Create from output file extension.
3503  {
3505  createWriterFromExtension( outputFile.ext() );
3506
3507  if ( !writer.valid() )
3508  {
3509  std::string errMsg = MODULE;
3510  errMsg += " ERROR creating writer from extension: ";
3511  errMsg += outputFile.ext().string();
3512  throw ossimException(errMsg);
3513  }
3514  }
3515
3516  // Set the output name.
3517  writer->setFilename( outputFile );
3518
3519  // Add any writer props.
3520  ossim_uint32 count = m_kwl->numberOf( WRITER_PROPERTY_KW.c_str() );
3521  for (ossim_uint32 i = 0; i < count; ++i)
3522  {
3523  ossimString key = WRITER_PROPERTY_KW;
3524  key += ossimString::toString(i);
3525  lookup = m_kwl->findKey( key.string() );
3526  if ( lookup.size() )
3527  {
3528  std::vector<ossimString> splitArray;
3529  lookup.split(splitArray, "=");
3530  if(splitArray.size() == 2)
3531  {
3533  new ossimStringProperty(splitArray[0], splitArray[1]);
3534
3535  if ( traceDebug() )
3536  {
3538  << "Setting writer prop: " << splitArray[0] << "=" << splitArray[1] << "\n";
3539  }
3540
3541  writer->setProperty( prop );
3542  }
3543  }
3544  }
3545
3546  // Output tile size:
3547  lookup = m_kwl->findKey( TILE_SIZE_KW );
3548  if ( lookup.size() )
3549  {
3550  ossimIpt tileSize;
3551  tileSize.x = lookup.toInt32();
3552  if ( (tileSize.x % 16) == 0 )
3553  {
3554  tileSize.y = tileSize.x;
3555  writer->setTileSize( tileSize );
3556  }
3557  else if ( traceDebug() )
3558  {
3560  << MODULE << " NOTICE:"
3561  << "\nTile width must be a multiple of 16! Using default.."
3562  << std::endl;
3563  }
3564  }
3565
3566  if ( traceDebug() )
3567  {
3569  << "writer name: " << writer->getClassName() << "\n"
3570  << MODULE << " exited...\n";
3571  }
3572
3573  return writer;
3574 }
void getOutputFilename(ossimFilename &f) const
Gets the output file name.
ossim_uint32 numberOf(const char *str) const
static const ossimFilename NIL
This was taken from Wx widgets for performing touch and access date stamps.
Definition: ossimFilename.h:40
bool valid() const
static ossimImageWriterFactoryRegistry * instance()
virtual void setTileSize(const ossimIpt &tileSize)
Sets the output image tiling size if supported by the writer.
virtual ossimString getClassName() const
Definition: ossimObject.cpp:64
virtual void setFilename(const ossimFilename &file)
ossim_int32 y
ossimImageFileWriter * createWriter(const ossimFilename &filename) const
ossimString ext() const
ossim_int32 x
◆ createOutputProjection()
void ossimChipperUtil::createOutputProjection ( )
private
Creates the output or view projection.
Note
All chains should be constructed prior to calling this.
Definition at line 2123 of file ossimChipperUtil.cpp.
2124 {
2125  static const char MODULE[] = "ossimChipperUtil::createOutputProjection";
2126
2127  if ( traceDebug() )
2128  {
2129  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
2130  }
2131
2132  std::string op = m_kwl->findKey( std::string(ossimKeywordNames::PROJECTION_KW) );
2133  std::string srs = m_kwl->findKey( SRS_KW );
2134
2135  if ( op.size() && srs.size() )
2136  {
2138  << MODULE << " WARNING:"
2139  << "\nBoth " << SRS_KW << " and " << ossimKeywordNames::PROJECTION_KW
2140  << " keywords are set!"
2141  << "\nsrs: " << srs
2142  << "\noutput_projection: " << op
2143  << "\nTaking " << srs << " over " << op << "\n";
2144  }
2145
2146  bool usingInput = false;
2149
2150  // If an srs code use that first.
2151  if ( srs.size() )
2152  {
2153  proj = getNewProjectionFromSrsCode( srs );
2154  }
2155  else if ( op.size() )
2156  {
2157  switch ( projType )
2158  {
2160  {
2161  proj = getNewGeoProjection();
2162  break;
2163  }
2165  {
2166  proj = getNewGeoScaledProjection();
2167  break;
2168  }
2170  {
2171  proj = getFirstInputProjection();
2172  usingInput = true;
2173  break;
2174  }
2176  {
2177  proj = getNewUtmProjection();
2178  break;
2179  }
2180  default:
2181  {
2182  break; // Just for un-handled type warning.
2183  }
2184  }
2185  }
2186
2187  // Check for identity projection:
2189  if ( proj.valid() && inputProj.valid() )
2190  {
2191  if ( *(inputProj.get()) == *(proj.get()) )
2192  {
2193  if ( projType == OSSIM_CHIPPER_PROJ_GEO_SCALED )
2194  {
2195  // Get the origin used for scaling.
2196  ossimGpt origin = proj->getOrigin();
2197
2198  // Copy the input projection to our projection. Has the tie and scale we need.
2199  proj = inputProj;
2200
2201  // Set the origin for scaling.
2202  proj->setOrigin(origin);
2203  }
2204  else
2205  {
2206  proj = inputProj;
2207  }
2208  usingInput = true;
2209  }
2210  }
2211
2212  if ( !proj.valid() )
2213  {
2214  // Try first input. If map projected use that.
2215  if ( inputProj.valid() )
2216  {
2217  proj = inputProj;
2218  usingInput = true;
2219  if ( traceDebug() )
2220  {
2222  << "WARNING: No projection set!"
2223  << "\nDefaulting to first input's projection.\n";
2224  }
2225  }
2226  else
2227  {
2228  proj = getNewGeoScaledProjection();
2229  if ( traceDebug() )
2230  {
2232  << "WARNING: No projection set!"
2233  << "\nDefaulting to scaled geographic at scene center.\n";
2234  }
2235  }
2236  }
2237
2238  // Create our ossimImageGeometry with projection (no transform).
2239  m_geom = new ossimImageGeometry( 0, proj.get() );
2240
2241  //---
2242  // If the input is the same as output projection do not modify; else, set
2243  // the gsd to user selected "METERS_KW" or the best resolution of the inputs,
2244  // set the tie and then snap it to the projection origin.
2245  //---
2246  if ( !usingInput || hasScaleOption() )
2247  {
2248  // Set the scale.
2250  }
2251
2252  // Set the tie.
2254
2255  if ( snapTieToOrigin() )
2256  {
2257  // Adjust the projection tie to the origin.
2258  proj->snapTiePointToOrigin();
2259  }
2260
2261  if ( traceDebug() )
2262  {
2264  << "using input projection: " << (usingInput?"true":"false")
2265  << "\noutput image geometry:\n";
2266
2268
2269  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited...\n";
2270  }
2271
2272 } // End: ossimChipperUtil::createOutputProjection()
static const char * PROJECTION_KW
bool valid() const
std::ostream & print(std::ostream &out) const
Prints contents to output stream.
virtual void setOrigin(const ossimGpt &origin)
Sets theOrigin to origin.
void initializeProjectionGsd()
Initializes the projection gsd.
ossimRefPtr< ossimMapProjection > getFirstInputProjection()
Gets the first input projection.
ossimChipperOutputProjection
emumerated output projections
Hold all options passed into intialize.
ossimChipperOutputProjection getOutputProjectionType() const
Gets the emumerated output projection type.
ossimRefPtr< ossimMapProjection > getNewGeoProjection()
Convenience method to get geographic projection.
ossimRefPtr< ossimImageGeometry > m_geom
The image geometry.
void intiailizeProjectionTiePoint()
Sets the projection tie point to the scene bounding rect corner.
const ossimGpt & getOrigin() const
bool hasScaleOption() const
ossimRefPtr< ossimMapProjection > getNewGeoScaledProjection()
ossimRefPtr< ossimMapProjection > getNewProjectionFromSrsCode(const std::string &code)
Convenience method to get a projection from an srs code.
bool snapTieToOrigin() const
ossimRefPtr< ossimMapProjection > getNewUtmProjection()
Convenience method to get a utm projection.
◆ execute()
void ossimChipperUtil::execute ( )
execute method.
Performs the actual product write.
Note
Definition at line 1433 of file ossimChipperUtil.cpp.
1434 {
1435  static const char MODULE[] = "ossimChipperUtil::execute";
1436
1437  if ( traceDebug() )
1438  {
1439  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
1440  }
1441
1442  ossimIrect aoi;
1444
1445  if ( source.valid() && !aoi.hasNans() )
1446  {
1447  // Set up the writer.
1449
1450  // Connect the writer to the cutter.
1451  m_writer->connectMyInputTo(0, source.get());
1452
1453  //---
1454  // Set the area of interest.
1455  // NOTE: This must be called after the writer->connectMyInputTo as
1456  // ossimImageFileWriter::initialize incorrectly resets theAreaOfInterest
1457  // back to the bounding rect.
1458  //---
1460
1462  {
1463  // Add a listener to get percent complete.
1464  ossimStdOutProgress prog(0, true);
1465  m_writer->addListener(&prog);
1466
1467  if ( traceLog() )
1468  {
1469  ossimKeywordlist logKwl;
1470  m_writer->saveStateOfAllInputs(logKwl);
1471
1472  ossimFilename logFile;
1473  getOutputFilename(logFile);
1474  logFile.setExtension("log");
1475
1476  logKwl.write( logFile.c_str() );
1477  }
1478
1479  // Write the file:
1480  m_writer->execute();
1481
1482  m_writer->removeListener(&prog);
1483
1484  if(m_writer->isAborted())
1485  {
1486  throw ossimException( "Writer Process aborted!" );
1487  }
1488  }
1489  else
1490  {
1491  throw ossimException( "Unable to initialize writer for execution" );
1492  }
1493  }
1494
1495  if ( traceDebug() )
1496  {
1497  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited...\n";
1498  }
1499 }
ossimRefPtr< ossimImageSource > initializeChain(ossimIrect &aoi)
Builds image chains returns ref pointer to image source and initializes area of interest(aoi).
static const ossimErrorCode OSSIM_OK
bool valid() const
Definition: ossimRefPtr.h:75
virtual bool addListener(ossimListener *listener)
Overrides base "addListener" this will capture the pointer and then call the base class "addListener"...
ossimRefPtr< ossimImageFileWriter > m_writer
We need access to the writer so we can support aborting.
virtual ossim_uint32 saveStateOfAllInputs(ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const
Save the state of all inputs to a keyword list.
virtual bool write(const char *file, const char *comment=0) const
Methods to dump the ossimKeywordlist to a file on disk.
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
ossimRefPtr< ossimImageFileWriter > createNewWriter() const
Creates a new writer.
virtual ossimErrorCode getErrorStatus() const
virtual void setAreaOfInterest(const ossimIrect &inputRect)
Definition: ossimIrect.h:337
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
virtual bool removeListener(ossimListener *listener)
Overrides base "removeListener".
virtual bool execute()
Calls: writeFile() writeMetaDataFiles()
◆ getAreaOfInterest()
void ossimChipperUtil::getAreaOfInterest ( ossimImageSource source,
ossimIrect rect
) const
private
Initializes "rect" with the output area of interest.
Initialization will either come from user defined cut options or the source bounding rect with user options taking precidence.
Parameters
sourceShould be the end of the processing chain.
rectRectangle to initialize. This is in output (view) space.
Note
Definition at line 4377 of file ossimChipperUtil.cpp.
Referenced by getChip(), and setOptionsToChain().
4378 {
4379  static const char MODULE[] = "ossimChipperUtil::getAreaOfInterest()";
4380  if ( traceDebug() )
4381  {
4382  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
4383  }
4384
4385  // Nan rect for starters.
4386  rect.makeNan();
4387
4388  if ( source )
4389  {
4390  source->initialize(); // Ensure all bounding rectangles are set.
4391
4392  if ( m_kwl->hasKey( CUT_BBOX_XYWH_KW ) )
4393  {
4394  // <x>,<y>,<w>,<h>
4395  std::string cutBbox = m_kwl->findKey( CUT_BBOX_XYWH_KW );
4396  getIrect( cutBbox, rect );
4397  }
4398  if (rect.hasNans() &&
4399  m_kwl->hasKey(FULLRES_XYS_KW) &&
4400  m_kwl->hasKey(CUT_WIDTH_KW) &&
4401  m_kwl->hasKey(CUT_HEIGHT_KW))
4402  {
4403  ossimString tempFullXys = m_kwl->findKey(FULLRES_XYS_KW);
4404  ossimString tempWidth = m_kwl->findKey(CUT_WIDTH_KW);
4405  ossimString tempHeight = m_kwl->findKey(CUT_HEIGHT_KW);
4406  double w = tempWidth.toDouble();
4407  double h = tempHeight.toDouble();
4408  if (m_geom && m_ivt)
4409  {
4410  std::vector<ossimString> values;
4411  tempFullXys.split(values, ",");
4412  ossimDpt scale;
4413  ossimDpt location;
4414  scale.makeNan();
4415  location.makeNan();
4416  double w = tempWidth.toDouble();
4417  double h = tempHeight.toDouble();
4418  if (values.size() > 2)
4419  {
4420  location.x = values[0].toDouble();
4421  location.y = values[1].toDouble();
4422  // ossimDrect r;
4423  // m_geom->getBoundingRect(r);
4424  // r = m_ivt->getImageToViewBounds(r);
4425  ossimDpt mid;
4426  m_ivt->imageToView(location, mid);
4427  ossimIpt ul(ossim::round<int>(mid.x - (w / 2)),
4428  ossim::round<int>(mid.y - (h / 2)));
4429  ossimIpt lr((ul.x + w - 1), ul.y + h - 1);
4430  //rect = resampler->getBoundingRect();
4431  rect = ossimIrect(ul, lr);
4432  }
4433  }
4434  }
4435  if (rect.hasNans())
4436  {
4437  if ( m_geom.valid() )
4438  {
4439  if ( m_kwl->find( CUT_CENTER_LAT_KW.c_str() ) )
4440  {
4441  // "Cut Center" with: --cut-center-llwh or --cut-center-llr:
4442
4443  ossimString latStr = m_kwl->findKey( CUT_CENTER_LAT_KW );
4444  ossimString lonStr = m_kwl->findKey( CUT_CENTER_LON_KW );
4445  if ( latStr.size() && lonStr.size() )
4446  {
4447  ossimGpt centerGpt;
4448
4449  //---
4450  // Want the height nan going into worldToLocal call so it gets picked
4451  // up by the elevation manager.
4452  //---
4453  centerGpt.makeNan();
4454
4455  centerGpt.lat = latStr.toFloat64();
4456  centerGpt.lon = lonStr.toFloat64();
4457
4458  if ( !centerGpt.isLatNan() && !centerGpt.isLonNan() )
4459  {
4460  // Ground "cut center" to view:
4461  ossimDpt centerDpt(0.0, 0.0);
4462  m_geom->worldToLocal(centerGpt, centerDpt);
4463
4464  if ( !centerDpt.hasNans() )
4465  {
4466  if ( isChipMode() && m_ivt.valid() ) // Chipping in image space.
4467  {
4468  // Tranform image center point to view:
4469  ossimDpt ipt = centerDpt;
4470  m_ivt->imageToView( ipt, centerDpt );
4471  }
4472
4473  // --cut-center-llwh:
4474  ossimString widthStr = m_kwl->findKey( CUT_WIDTH_KW );
4475  ossimString heightStr = m_kwl->findKey( CUT_HEIGHT_KW );
4476  if ( widthStr.size() && heightStr.size() )
4477  {
4478  ossim_int32 width = widthStr.toInt32();
4479  ossim_int32 height = heightStr.toInt32();
4480  if ( width && height )
4481  {
4482  ossimIpt ul( ossim::round<int>(centerDpt.x - (width/2)),
4483  ossim::round<int>(centerDpt.y - (height/2)) );
4484  ossimIpt lr( (ul.x + width - 1), ul.y + height - 1);
4485  rect = ossimIrect(ul, lr);
4486  }
4487  }
4488  else // --cut-center-llr:
4489  {
4490  ossimString radiusStr = m_kwl->findKey( CUT_RADIUS_KW );
4491  if ( radiusStr.size() )
4492  {
4493  ossim_float64 radius = radiusStr.toFloat64();
4494  if ( radius )
4495  {
4496  ossimDpt mpp;
4497  m_geom->getMetersPerPixel( mpp );
4498
4499  if ( !mpp.hasNans() )
4500  {
4501  ossim_float64 rx = radius/mpp.x;
4502  ossim_float64 ry = radius/mpp.y;
4503
4504  ossimIpt ul( ossim::round<int>( centerDpt.x - rx ),
4505  ossim::round<int>( centerDpt.y - ry ) );
4506  ossimIpt lr( ossim::round<int>( centerDpt.x + rx ),
4507  ossim::round<int>( centerDpt.y + ry ) );
4508  rect = ossimIrect(ul, lr);
4509  }
4510  }
4511  }
4512  }
4513  }
4514
4515  } // Matches: if ( !centerGpt.hasNans() )
4516
4517  } // Matches: if ( latStr && lonStr )
4518
4519  } // Matches: if ( m_kwl->find( CUT_CENTER_LAT_KW ) )
4520
4521  else if ( (m_kwl->find( CUT_MAX_LAT_KW.c_str() ) ||
4522  (m_kwl->find( CUT_WMS_BBOX_LL_KW.c_str() ))))
4523  {
4524  ossimString maxLat;
4525  ossimString maxLon;
4526  ossimString minLat;
4527  ossimString minLon;
4528
4529  // --cut-bbox-ll or --cut-bbox-llwh
4530  if(m_kwl->find( CUT_MAX_LAT_KW.c_str() ))
4531  {
4532  maxLat = m_kwl->findKey( CUT_MAX_LAT_KW );
4533  maxLon = m_kwl->findKey( CUT_MAX_LON_KW );
4534  minLat = m_kwl->findKey( CUT_MIN_LAT_KW );
4535  minLon = m_kwl->findKey( CUT_MIN_LON_KW );
4536  }
4537  else
4538  {
4539  ossimString cutBbox = m_kwl->findKey( CUT_WMS_BBOX_LL_KW );
4540
4541  cutBbox = cutBbox.upcase().replaceAllThatMatch("BBOX:");
4542  std::vector<ossimString> cutBox = cutBbox.split(",");
4543  if(cutBox.size() >3)
4544  {
4545  minLon = cutBox[0];
4546  minLat = cutBox[1];
4547  maxLon = cutBox[2];
4548  maxLat = cutBox[3];
4549  }
4550  }
4551
4552  if ( maxLat.size() && maxLon.size() && minLat.size() && minLon.size() )
4553  {
4554  ossim_float64 minLatF = minLat.toFloat64();
4555  ossim_float64 maxLatF = maxLat.toFloat64();
4556  ossim_float64 minLonF = minLon.toFloat64();
4557  ossim_float64 maxLonF = maxLon.toFloat64();
4558
4559  //---
4560  // Check for swap so we don't get a negative height.
4561  // Note no swap check for longitude as box could cross date line.
4562  //---
4563  if ( minLatF > maxLatF )
4564  {
4565  ossim_float64 tmpF = minLatF;
4566  minLatF = maxLatF;
4567  maxLatF = tmpF;
4568  }
4569
4570  //---
4571  // Assume cut box is edge to edge or "Pixel Is Area". Our
4572  // AOI(area of interest) uses center of pixel or "Pixel Is Point"
4573  // so get the degrees per pixel and shift AOI to center.
4574  //---
4575  ossimDpt halfDpp;
4576  m_geom->getDegreesPerPixel( halfDpp );
4577  halfDpp = halfDpp/2.0;
4578
4579  ossimGpt gpt(0.0, 0.0, 0.0);
4580  ossimDpt ulPt;
4581  ossimDpt lrPt;
4582
4583  // Upper left:
4584  gpt.lat = maxLatF - halfDpp.y;
4585  gpt.lon = minLonF + halfDpp.x;
4586  m_geom->worldToLocal(gpt, ulPt);
4587
4588  // Lower right:
4589  gpt.lat = minLatF + halfDpp.y;
4590  gpt.lon = maxLonF - halfDpp.x;
4591  m_geom->worldToLocal(gpt, lrPt);
4592
4593  if ( isChipMode() && m_ivt.valid() )
4594  {
4595  // Chipping in image space:
4596
4597  // Tranform image ul point to view:
4598  ossimDpt ipt = ulPt;
4599  m_ivt->imageToView( ipt, ulPt );
4600
4601  // Tranform image lr point to view:
4602  ipt = lrPt;
4603  m_ivt->imageToView( ipt, lrPt );
4604  }
4605
4606  rect = ossimIrect( ossimIpt(ulPt), ossimIpt(lrPt) );
4607  }
4608  }
4609  else if ( m_kwl->find( CUT_WMS_BBOX_KW.c_str() ) )
4610  {
4611  ossimString cutBbox = m_kwl->findKey( CUT_WMS_BBOX_KW );
4612
4613  cutBbox = cutBbox.upcase().replaceAllThatMatch("BBOX:");
4614  std::vector<ossimString> cutBox = cutBbox.split(",");
4615  if(cutBox.size()==4)
4616  {
4617
4618  ossim_float64 minx=cutBox[0].toFloat64();
4619  ossim_float64 miny=cutBox[1].toFloat64();
4620  ossim_float64 maxx=cutBox[2].toFloat64();
4621  ossim_float64 maxy=cutBox[3].toFloat64();
4622
4623  const ossimMapProjection* mapProj = m_geom->getAsMapProjection();
4624  if(mapProj)
4625  {
4626  std::vector<ossimDpt> pts(4);
4627  ossimDpt* ptsArray = &pts.front();
4628  if(mapProj->isGeographic())
4629  {
4630  ossimDpt halfDpp;
4631  m_geom->getDegreesPerPixel( halfDpp );
4632  halfDpp = halfDpp/2.0;
4633
4634  ossimGpt gpt(0.0, 0.0, 0.0);
4635  ossimDpt ulPt;
4636  ossimDpt lrPt;
4637
4638  // Upper left:
4639  gpt.lat = maxy - halfDpp.y;
4640  gpt.lon = minx + halfDpp.x;
4641  m_geom->worldToLocal(gpt, ptsArray[0]);
4642  // Upper right:
4643  gpt.lat = maxy - halfDpp.y;
4644  gpt.lon = maxx - halfDpp.x;
4645  m_geom->worldToLocal(gpt, ptsArray[1]);
4646
4647  // Lower right:
4648  gpt.lat = miny + halfDpp.y;
4649  gpt.lon = maxx - halfDpp.x;
4650  m_geom->worldToLocal(gpt, ptsArray[2]);
4651
4652  //Lower left
4653  gpt.lat = miny + halfDpp.y;
4654  gpt.lon = minx + halfDpp.x;
4655  m_geom->worldToLocal(gpt, ptsArray[3]);
4656  //m_geom->worldToLocal(ossimGpt(miny,minx), ptsArray[0]);
4657  //m_geom->worldToLocal(ossimGpt(maxy,minx), ptsArray[1]);
4658  //m_geom->worldToLocal(ossimGpt(maxy,maxx), ptsArray[2]);
4659  //m_geom->worldToLocal(ossimGpt(miny,maxx), ptsArray[3]);
4660
4661  }
4662  else
4663  {
4664  ossimDpt halfMpp;
4665  ossimDpt eastingNorthing;
4666  m_geom->getMetersPerPixel( halfMpp );
4667  halfMpp = halfMpp/2.0;
4668
4669  eastingNorthing.x = minx+halfMpp.x;
4670  eastingNorthing.y = miny+halfMpp.y;
4671  mapProj->eastingNorthingToLineSample(eastingNorthing, ptsArray[0]);
4672  eastingNorthing.x = minx+halfMpp.x;
4673  eastingNorthing.y = maxy-halfMpp.y;
4674  mapProj->eastingNorthingToLineSample(eastingNorthing, ptsArray[1]);
4675  eastingNorthing.x = maxx-halfMpp.x;
4676  eastingNorthing.y = maxy-halfMpp.y;
4677  mapProj->eastingNorthingToLineSample(eastingNorthing, ptsArray[2]);
4678  eastingNorthing.x = maxx-halfMpp.x;
4679  eastingNorthing.y = miny+halfMpp.y;
4680  mapProj->eastingNorthingToLineSample(eastingNorthing, ptsArray[3]);
4681  }
4682  rect = ossimIrect(pts);
4683  }
4684  }
4685  }
4686
4687  } // if ( m_getOutputGeometry.valid() )
4688  else
4689  {
4690  // Should never happer...
4691  std::string errMsg = MODULE;
4692  if ( !source )
4693  {
4694  errMsg += " image source null!";
4695  }
4696  else
4697  {
4698  errMsg += " output projection null!";
4699  }
4700  throw( ossimException(errMsg) );
4701  }
4702
4703  // If no user defined rect set to scene bounding rect.
4704  if ( rect.hasNans() )
4705  {
4706  // Get the rectangle from the input chain:
4707  rect = source->getBoundingRect(0);
4708  }
4709
4710  } // if ( rect.hasNans() )
4711
4712  } // if ( source )
4713
4714  if ( traceDebug() )
4715  {
4717  << "aoi: " << rect << "\n"
4718  << MODULE << " exited...\n";
4719  }
4720
4721 } // End: ossimChipperUtil::getAreaOfInterest
This will return the bounding rect of the source.
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
bool getIrect(const std::string &s, ossimIrect &rect) const
Gets rect from string in the form of <x>,<y>,<w>,<h>.
const std::string & findKey(const std::string &key) const
Find methods that take std::string(s).
bool isLonNan() const
Definition: ossimGpt.h:140
bool valid() const
const ossimMapProjection * getAsMapProjection() const
double y
void makeNan()
Definition: ossimGpt.h:130
virtual bool isGeographic() const
ossimDpt getDegreesPerPixel() const
Returns the resolution of this image in degrees/pixel.
bool isLatNan() const
Definition: ossimGpt.h:139
ossimString replaceAllThatMatch(const char *regularExpressionPattern, const char *value="") const
double lat
ossim_float64 lon
Definition: ossimGpt.h:266
ossimDpt getMetersPerPixel() const
Returns the GSD associated with this image in the active projection.
double toDouble() const
ossim_float64 toFloat64() const
ossimRefPtr< ossimKeywordlist > m_kwl
The image geometry.
ossimRefPtr< ossimImageViewAffineTransform > m_ivt
Image view transform(IVT).
void makeNan()
Definition: ossimIrect.h:329
double x
virtual void eastingNorthingToLineSample(const ossimDpt &eastingNorthing, ossimDpt &lineSample) const
ossim_float64 lat
Definition: ossimGpt.h:265
virtual void initialize()=0
void makeNan()
int ossim_int32
◆ getBandList()
void ossimChipperUtil::getBandList ( std::vector< ossim_uint32 > &  bandList) const
private
Gets the band list if BANDS keyword is set.
NOTE: BANDS keyword values are ONE based. bandList values are ZERO based.
Parameters
bandListList initialized by this.
Definition at line 5052 of file ossimChipperUtil.cpp.
References ossimKeywordNames::BANDS_KW, ossimKeywordlist::findKey(), m_kwl, ossimString::size(), ossimString::split(), ossimString::string(), and ossimRefPtr< T >::valid().
5053 {
5054  bandList.clear();
5055  if ( m_kwl.valid() )
5056  {
5057  ossimString os;
5058  os.string() = m_kwl->findKey( std::string( ossimKeywordNames::BANDS_KW ) );
5059  if ( os.size() &&(os!="default"))
5060  {
5061  std::vector<ossimString> band_list(0);
5062  os.split( band_list, ossimString(","), false );
5063  if ( band_list.size() )
5064  {
5065  std::vector<ossimString>::const_iterator i = band_list.begin();
5066  while ( i != band_list.end() )
5067  {
5068  ossim_uint32 band = (*i).toUInt32();
5069  if ( band ) // One based so we need to subtract.
5070  {
5071  bandList.push_back( band - 1 );
5072  }
5073  ++i;
5074  }
5075  }
5076  }
5077  }
5078
5079 } // End: ossimChipperUtil::getBandList
bool valid() const
unsigned int ossim_uint32
static const char * BANDS_KW
const std::string & string() const
Definition: ossimString.h:414
◆ getBrightness()
ossim_float64 ossimChipperUtil::getBrightness ( ) const
private
Gets the brightness level.
This will return 0.0 if the keyword is not found or if the range check is not between -1.0 and 1.0.
Returns
brightness
Definition at line 5593 of file ossimChipperUtil.cpp.
References ossimKeywordlist::findKey(), and m_kwl.
5594 {
5595  ossim_float64 brightness = 0.0;
5596  std::string value = m_kwl->findKey( BRIGHTNESS_KW );
5597  if ( value.size() )
5598  {
5599  brightness = ossimString(value).toFloat64();
5600
5601  // Range check it:
5602  if ( ( brightness < -1.0 ) || ( brightness > 1.0 ) )
5603  {
5605  << "ossimChipperUtil::getBrightness range error!"
5606  << "\nbrightness: " << brightness
5607  << "\nvalid range: -1.0 to 1.0"
5608  << "\nReturned brightness has been reset to: 0.0"
5609  << std::endl;
5610
5611  brightness = 0.0;
5612  }
5613  }
5614  return brightness;
5615
5616 }
◆ getCentralMeridian()
ossim_float64 ossimChipperUtil::getCentralMeridian ( ) const
private
Gets value of key "central_meridan" if set, nan if not.
Returns
Value as a double or nan if keyord is not set.
Note
Throws ossimException on range error.
Definition at line 3094 of file ossimChipperUtil.cpp.
References ossimKeywordNames::CENTRAL_MERIDIAN_KW, ossimKeywordlist::findKey(), m_kwl, ossim::nan(), ossimString::size(), and ossimString::toFloat64().
Referenced by getNewGeoScaledProjection(), and getNewUtmProjection().
3095 {
3096  ossim_float64 result = ossim::nan();
3098  if ( lookup.size() )
3099  {
3100  result = lookup.toFloat64();
3101  if ( (result < -180.0) || (result > 180.0) )
3102  {
3103  std::string errMsg = "central meridian range error!";
3104  errMsg += " Valid range: -180 to 180";
3105  throw ossimException(errMsg);
3106  }
3107  }
3108  return result;
3109 }
static const char * CENTRAL_MERIDIAN_KW
double nan()
Definition: ossimCommon.h:135
◆ getChip()
ossimRefPtr< ossimImageData > ossimChipperUtil::getChip ( const ossimKeywordlist optionsKwl = ossimKeywordlist())
Gets initialized area of interest(aoi) from chain.
Returns
Pointer to ossimImageData holding chip. Pointer can be null if not initialized properly so caller should check. The options will only support a couple modifications while chipping.
this is mainly here to support a moving chip window so we do not need to do a full initialize for every chip. We can specify a new cut bounds and cut width height in pixels if desired.
cut_wms_bbox: .......... cut_width: cut_height:
Definition at line 1508 of file ossimChipperUtil.cpp.
References ossimKeywordlist::addList(), ossimRefPtr< T >::get(), getAreaOfInterest(), ossimKeywordlist::getSize(), ossimImageSource::getTile(), initializeChain(), initializeOutputProjection(), m_geom, m_kwl, m_source, ossimImageGeometry::setImageSize(), ossimIrect::size(), and ossimRefPtr< T >::valid().
1509 {
1510  ossimRefPtr<ossimImageData> result = 0;
1511
1512  ossimIrect aoi;
1513
1514  if( optionsKwl.getSize() > 0 )
1515  {
1516  m_kwl->addList(optionsKwl, true);
1517  }
1518
1519  // (GP)
1520  // Until we add more ellaborate code to check for scale changes
1521  // as well as moving windows we will just always initialize
1522  // the output projection
1523  //
1524
1526  if(!m_source.valid())
1527  {
1528  m_source = initializeChain( aoi );
1529  }
1530
1531  if ( optionsKwl.getSize() > 0 )
1532  {
1533  //---
1534  // Only do this if new options were passed in. This was causing an off by
1535  // one error when now options were passed in using thumbnail option.
1536  // The m_source->getBoundingRect(...) was returning 257 instead of 256.
1537  // Need to hunt that down but for right now this fixes problem.
1538  // (drb 20151222)
1539  //---
1540  getAreaOfInterest(m_source.get(), aoi);
1541
1542  m_geom->setImageSize( aoi.size() );
1543  }
1544
1545  if ( m_source.valid() )
1546  {
1547  result = m_source->getTile( aoi, 0 );
1548  }
1549
1550  return result;
1551 }
bool valid() const
void addList(const ossimKeywordlist &src, bool overwrite=true)
void setImageSize(const ossimIpt &size)
ossimIpt size() const
Definition: ossimIrect.h:510
void initializeOutputProjection()
Initializes the output projection and propagates to image chains.
void getAreaOfInterest(ossimImageSource *source, ossimIrect &rect) const
The image geometry.
ossimRefPtr< ossimImageSource > m_source
We need to support changing clips without doing a full initilization.
ossim_uint32 getSize() const
◆ getClipPolygon()
void ossimChipperUtil::getClipPolygon ( ossimGeoPolygon polygon) const
private
Definition at line 5568 of file ossimChipperUtil.cpp.
5569 {
5570  ossimString param = m_kwl->find(CLIP_WMS_BBOX_LL_KW.c_str());
5571  if(!param.empty())
5572  {
5573  if(!polygon.addWmsBbox(param))
5574  {
5575  polygon.clear();
5576  }
5577  }
5578  else
5579  {
5580  param = m_kwl->find(CLIP_POLY_LAT_LON_KW.c_str());
5581  if(!param.empty())
5582  {
5583  std::vector<ossimGpt> points;
5584  ossim::toVector(points, param);
5585  if(!points.empty())
5586  {
5587  polygon = points;
5588  }
5589  }
5590  }
5591 }
bool addWmsBbox(const ossimString &wmsBbox)
OSSIM_DLL void toVector(std::vector< ossimDpt > &result, const ossimString &stringOfPoints)
Will take a string list separated by spaces and convert to a vector of ossimDpts. ...
bool empty() const
◆ getContrast()
ossim_float64 ossimChipperUtil::getContrast ( ) const
private
Gets the contrast level.
This will return 1.0 if the keyword is not found or if the range check is not between 0.0 and 20.0.
Returns
brightness
Definition at line 5618 of file ossimChipperUtil.cpp.
5619 {
5620  ossim_float64 contrast = 1.0;
5621  std::string value = m_kwl->findKey( CONTRAST_KW );
5622  if ( value.size() )
5623  {
5624  contrast = ossimString(value).toFloat64();
5625
5626  // Range check it:
5627  if ( ( contrast < 0.0 ) || ( contrast > 20.0 ) )
5628  {
5630  << "ossimChipperUtil::getContrast range error!"
5631  << "\ncontrast: " << contrast
5632  << "\nvalid range: 0 to 20.0"
5633  << "\nReturned contrast has been reset to: 1.0"
5634  << std::endl;
5635
5636  contrast = 1.0;
5637  }
5638  }
5639  return contrast;
5640
5641 }
double ossim_float64
◆ getEntryNumber()
ossim_uint32 ossimChipperUtil::getEntryNumber ( ) const
private
Returns
The entry number if set. Zero if ossimKeywordNames::ENTRY_KW not found.
Definition at line 5369 of file ossimChipperUtil.cpp.
References ossimKeywordNames::ENTRY_KW, ossimKeywordlist::findKey(), m_kwl, ossimString::toUInt32(), and ossimRefPtr< T >::valid().
5370 {
5371  ossim_uint32 result = 0;
5372  if ( m_kwl.valid() )
5373  {
5374  std::string value = m_kwl->findKey( std::string( ossimKeywordNames::ENTRY_KW ) );
5375  if ( value.size() )
5376  {
5377  result = ossimString(value).toUInt32();
5378  }
5379  }
5380  return result;
5381 }
bool valid() const
◆ getFirstInputProjection()
ossimRefPtr< ossimMapProjection > ossimChipperUtil::getFirstInputProjection ( )
private
This gets the output projection of the first dem layer if present; if not, the first image layer.
Returns
ref ptr to projection, could be null.
Definition at line 3254 of file ossimChipperUtil.cpp.
3255 {
3256  static const char MODULE[] = "ossimChipperUtil::getFirstInputProjection";
3257  if ( traceDebug() )
3258  {
3259  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
3260  }
3261
3264
3265  // Get the first image handler.
3266  if ( m_demLayer.size() )
3267  {
3268  ih = m_demLayer[0]->getImageHandler();
3269  }
3270  else if ( m_imgLayer.size() )
3271  {
3272  ih = m_imgLayer[0]->getImageHandler();
3273  }
3274
3275  if ( ih.valid() )
3276  {
3277  // Get the geometry from the first image handler.
3279  if ( geom.valid() )
3280  {
3281  // Get the image projection.
3283  if ( proj.valid() )
3284  {
3285  // Cast and assign to result.
3286  ossimMapProjection* mapProj = PTR_CAST( ossimMapProjection, proj.get() );
3287  if (mapProj)
3288  {
3289  // Must duplicate in case the output projection gets modified.
3290  result = (ossimMapProjection*) mapProj->dup();
3291  }
3292  if ( !result.valid() && traceDebug() )
3293  {
3294  ossimNotify(ossimNotifyLevel_WARN) << "Could not cast to map projection.\n";
3295  }
3296  }
3297  else if ( traceDebug() )
3298  {
3299  ossimNotify(ossimNotifyLevel_WARN) << "No projection in first chain...\n";
3300  }
3301  }
3302  }
3303  else if ( traceDebug() )
3304  {
3305  ossimNotify(ossimNotifyLevel_WARN) << "No image handler in first chain...\n";
3306  }
3307
3308  if ( traceDebug() )
3309  {
3310  if ( result.valid() )
3311  {
3313  }
3314  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited...\n";
3315  }
3316
3317  return result;
3318 }
virtual ossimObject * dup() const =0
bool valid() const
std::vector< ossimRefPtr< ossimSingleImageChain > > m_imgLayer
Array of image source chains.
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
Prints data members to stream.
std::vector< ossimRefPtr< ossimSingleImageChain > > m_demLayer
Array of dem chains.
◆ getHemisphere()
std::string ossimChipperUtil::getHemisphere ( ) const
private
Returns
The hemisphere if set. Empty string if ossimKeywordNames::HEMISPHERE_KW not found.
Definition at line 5398 of file ossimChipperUtil.cpp.
References ossimKeywordlist::findKey(), ossimKeywordNames::HEMISPHERE_KW, m_kwl, and ossimRefPtr< T >::valid().
Referenced by getNewUtmProjection().
5399 {
5400  std::string result;
5401  if ( m_kwl.valid() )
5402  {
5403  result = m_kwl->findKey( std::string( ossimKeywordNames::HEMISPHERE_KW ) );
5404  }
5405  return result;
5406 }
bool valid() const
static const char * HEMISPHERE_KW
◆ getHistoMode()
int ossimChipperUtil::getHistoMode ( ) const
private
Definition at line 5663 of file ossimChipperUtil.cpp.
References ossimKeywordlist::findKey(), m_kwl, and ossimHistogramRemapper::STRETCH_UNKNOWN.
5664 {
5666
5667  ossimString op = m_kwl->findKey( HIST_OP_KW );
5668  op.downcase();
5669
5670  if ( ( op.string() == "auto-minmax" ) )
5671  {
5673  }
5674  else if ( ( op.string() == "auto-percentile" ) )
5675  {
5677  }
5678  else if ( (op == "std-stretch-1") || (op == "std-stretch 1") )
5679  {
5681  }
5682  else if ( (op == "std-stretch-2") || (op == "std-stretch 2") )
5683  {
5685  }
5686  else if ( (op == "std-stretch-3") || (op == "std-stretch 3") )
5687  {
5689  }
5690  else if( traceDebug() )
5691  {
5693  << "ossimChipperUtil::getHistoMode: Unhandled operation: " << op << "\n";
5694  }
5695
5696  return result;
5697 }
◆ getImageSpacePivot()
void ossimChipperUtil::getImageSpacePivot ( ossimDpt imageSpacePivot) const
private
Gets the image space pivot.
This is a "chip" operation only. Will extract the center from the FULLRES keyword
Keys: FULLRES_XYS
This will return NaN if not set
Definition at line 5274 of file ossimChipperUtil.cpp.
References ossimKeywordlist::hasKey(), m_kwl, and ossimDpt::makeNan().
5275 {
5276  ossimString lookup;
5277  imageSpacePivot.makeNan();
5278  if (m_kwl->hasKey(FULLRES_XYS_KW))
5279  {
5280  lookup = m_kwl->findKey(FULLRES_XYS_KW);
5281  std::vector<ossimString> values;
5282  lookup.trim().split(values, ",");
5283
5284  if(values.size() > 1)
5285  {
5286  imageSpacePivot.x = values[0].toDouble();
5287  imageSpacePivot.y = values[1].toDouble();
5288  }
5289  }
5290  else
5291  {
5292  if (m_geom)
5293  {
5294  ossimDrect rect;
5295  m_geom->getBoundingRect(rect);
5296  imageSpacePivot = rect.midPoint();
5297  }
5298  }
5299 }
void getBoundingRect(ossimIrect &bounding_rect) const
Get the bounding rect of (0, 0) to (imageSize.x-1, imageSize.y-1).
double y
Definition: ossimDpt.h:165
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
The image geometry.
ossimDpt midPoint() const
Definition: ossimDrect.h:817
double x
Definition: ossimDpt.h:164
void makeNan()
Definition: ossimDpt.h:65
◆ getImageSpaceScale()
void ossimChipperUtil::getImageSpaceScale ( ossimDpt imageSpaceScale) const
private
Gets the image space scale.
Keys: IMAGE_SPACE_SCALE_X_KW IMAGE_SPACE_SCALE_Y_KW FULLRES_XYS
Scale will be 1.0, 1.0 if keys not found.
Definition at line 5230 of file ossimChipperUtil.cpp.
References ossimKeywordlist::hasKey(), m_kwl, ossimDpt::x, and ossimDpt::y.
5231 {
5232  imageSpaceScale.x = 1.0;
5233  imageSpaceScale.y = 1.0;
5234  ossimString lookup;
5235
5236  if (m_kwl->hasKey(FULLRES_XYS_KW))
5237  {
5238  lookup = m_kwl->findKey(FULLRES_XYS_KW);
5239  std::vector<ossimString> values;
5240  lookup.trim().split(values, ",");
5241  if (values.size() > 2)
5242  {
5243  imageSpaceScale.x = values[2].toDouble();
5244  imageSpaceScale.y = imageSpaceScale.x;
5245  if (values.size() > 3)
5246  {
5247  imageSpaceScale.y = values[3].toDouble();
5248  }
5249  }
5250  }
5251  else
5252  {
5253  std::string value = m_kwl->findKey(IMAGE_SPACE_SCALE_X_KW);
5254  if (value.size())
5255  {
5256  imageSpaceScale.x = ossimString(value).toFloat64();
5257  }
5258  else
5259  {
5260  imageSpaceScale.x = 1.0;
5261  }
5262  value = m_kwl->findKey(IMAGE_SPACE_SCALE_Y_KW);
5263  if (value.size())
5264  {
5265  imageSpaceScale.y = ossimString(value).toFloat64();
5266  }
5267  else
5268  {
5269  imageSpaceScale.y = 1.0;
5270  }
5271  }
5272 }
double y
double x
◆ getIrect() [1/3]
bool ossimChipperUtil::getIrect ( const std::string &  s,
ossimIrect rect
) const
private
Parameters
sString to parse. Initialized by this.
Returns
true on success, false, on error.
Definition at line 4723 of file ossimChipperUtil.cpp.
References ossimString::split(), ossimIpt::x, and ossimIpt::y.
4724 {
4725  bool result = false;
4726  if ( s.size() )
4727  {
4728  // <x>,<y>,<w>,<h>
4729  ossimString cutBbox = s;
4730  std::vector<ossimString> keys;
4731  cutBbox.split(keys, ",");
4732  if( keys.size() > 3 )
4733  {
4734  ossimIpt ul;
4735  ossimIpt lr;
4736  ul.x = keys[0].toInt32();
4737  ul.y = keys[1].toInt32();
4738  lr.x = ul.x + keys[2].toInt32() - 1;
4739  lr.y = ul.y + keys[3].toInt32() - 1;
4740  rect = ossimIrect(ul, lr);
4741  result = true;
4742  }
4743  }
4744  return result;
4745 }
ossim_int32 y
Definition: ossimIpt.h:142
ossim_int32 x
Definition: ossimIpt.h:141
◆ getIrect() [2/3]
bool ossimChipperUtil::getIrect ( ossimRefPtr< ossimSingleImageChain > &  chain,
ossimIrect rect
) const
private
Gets image rect from string in the form of <lat>,<lon>,<w>,<h>.
Computes image rect from world point assumed to be center of aoi.
Parameters
chain
Returns
Definition at line 4747 of file ossimChipperUtil.cpp.
References ossimImageHandler::getImageGeometry(), ossimSingleImageChain::getImageHandler(), ossimGpt::lat, ossimGpt::lon, ossimString::split(), ossimRefPtr< T >::valid(), ossimImageGeometry::worldToLocal(), ossimIpt::x, and ossimIpt::y.
4750 {
4751  bool result = false;
4752
4753  if ( chain.valid() )
4754  {
4756  if ( ih.valid() )
4757  {
4758  // Get the geometry from the image handler.
4760  if ( geom.valid() )
4761  {
4762  // <lat>,<lon>,<w>,<h>
4763  ossimString cutBbox = s;
4764  std::vector<ossimString> keys;
4765  cutBbox.split(keys, ",");
4766  if( keys.size() > 3 )
4767  {
4768  ossimGpt gpt;
4769  gpt.lat = keys[0].toFloat64();
4770  gpt.lon = keys[1].toFloat64();
4771  ossim_int32 w = keys[2].toInt32();
4772  ossim_int32 h = keys[3].toInt32();
4773  ossimDpt dpt;
4774  geom->worldToLocal( gpt, dpt );
4775  ossimIpt ul = dpt;
4776  ul.x -= w/2;
4777  ul.y -= h/2;
4778  ossimIpt lr( ul.x + w - 1, ul.y + h - 1);
4779  rect = ossimIrect(ul, lr);
4780  result = true;
4781  }
4782  }
4783  }
4784  }
4785
4786  return result;
4787 }
bool valid() const
ossim_float64 lon
ossim_int32 y
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
ossim_int32 x
ossim_float64 lat
int ossim_int32
◆ getIrect() [3/3]
ossimIrect rect
) const
private
Gets 256 x 256 image rect from center of the image.
Parameters
chainInitialized by this.
Returns
Definition at line 4789 of file ossimChipperUtil.cpp.
References ossimSingleImageChain::getImageHandler(), ossimImageHandler::getImageRectangle(), MAX, ossimIrect::midPoint(), ossim::min(), ossimIrect::size(), size, ossimRefPtr< T >::valid(), ossimIpt::x, and ossimIpt::y.
4791 {
4792  bool result = false;
4793  if ( chain.valid() )
4794  {
4796  if ( ih.valid() )
4797  {
4798  const ossim_int32 MAX = 512;
4799  ossimIrect r = ih->getImageRectangle();
4800  ossimIpt size = r.size();
4801  ossim_int32 w = ossim::min( MAX, size.x );
4802  ossim_int32 h = ossim::min( MAX, size.y );
4803  ossimIpt ul = r.midPoint();
4804  ul.x -= w/2;
4805  ul.y -= h/2;
4806  ossimIpt lr( ul.x + w - 1, ul.y + h -1 );
4807  rect = ossimIrect(ul, lr);
4808  result = true;
4809  }
4810  }
4811  return result;
4812 }
bool valid() const
#define MAX(x, y)
yy_size_t size
ossimIpt midPoint() const
Definition: ossimIrect.h:750
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
T min(T a, T b)
Definition: ossimCommon.h:203
ossim_int32 y
ossim_int32 x
int ossim_int32
◆ getMapProjection()
ossimRefPtr< ossimMapProjection > ossimChipperUtil::getMapProjection ( )
private
Convenience method to get a pointer to the output map projection.
Callers should check for valid() as the pointer could be 0 if not initialized.
Returns
The ossimMapProjection* from the m_outputGeometry as a ref pointer.
Definition at line 3460 of file ossimChipperUtil.cpp.
References ossimImageGeometry::getProjection(), m_geom, and ossimRefPtr< T >::valid().
3461 {
3463  if ( m_geom.valid() )
3464  {
3465  mp = dynamic_cast<ossimMapProjection*>( m_geom->getProjection() );
3466  }
3467  return mp;
3468 }
bool valid() const
The image geometry.
◆ getMetersPerPixel() [1/2]
void ossimChipperUtil::getMetersPerPixel ( ossimDpt gsd)
private
Loops through all layers to get the best gsd.
Parameters
gsdPoint to initialize.
Definition at line 3004 of file ossimChipperUtil.cpp.
3005 {
3006  static const char MODULE[] = "ossimChipperUtil::getMetersPerPixel(ossimDpt&)";
3007  if ( traceDebug() )
3008  {
3009  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
3010  }
3011
3012  gsd.makeNan();
3013
3014  ossimDpt chainGsd;
3015  std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator chainIdx;
3016
3017  // Loop through dem layers.
3018  chainIdx = m_demLayer.begin();
3019  while ( chainIdx != m_demLayer.end() )
3020  {
3021  getMetersPerPixel( (*chainIdx).get(), chainGsd);
3022  if ( gsd.hasNans() || ( chainGsd.x < gsd.x ) )
3023  {
3024  gsd = chainGsd;
3025  }
3026  ++chainIdx;
3027  }
3028
3029  // Loop through image layers.
3030  chainIdx = m_imgLayer.begin();
3031  while ( chainIdx != m_imgLayer.end() )
3032  {
3033  getMetersPerPixel( (*chainIdx).get(), chainGsd);
3034  if ( gsd.hasNans() || ( chainGsd.x < gsd.x ) )
3035  {
3036  gsd = chainGsd;
3037  }
3038  ++chainIdx;
3039  }
3040
3041  if ( traceDebug() )
3042  {
3044  << "gsd: " << gsd << "\n" << MODULE << " exited...\n";
3045  }
3046 }
void getMetersPerPixel(ossimDpt &gsd)
bool hasNans() const
Definition: ossimDpt.h:67
double x
void makeNan()
◆ getMetersPerPixel() [2/2]
void ossimChipperUtil::getMetersPerPixel ( ossimSingleImageChain chain,
ossimDpt gsd
private
Gets the gsd from a chain.
Parameters
chainThe chain to get gsd from.
Note
Throws ossimException on error.
Definition at line 3048 of file ossimChipperUtil.cpp.
3049 {
3050  static const char MODULE[] = "ossimChipperUtil::getMetersPerPixel(ossimSingleImageChain*,ossimDpt&)";
3051  if ( traceDebug() )
3052  {
3053  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
3054  }
3055
3056  if (chain)
3057  {
3059  if ( geom.valid() )
3060  {
3061  geom->getMetersPerPixel( gsd );
3062  if ( gsd.hasNans() )
3063  {
3064  std::string errMsg = MODULE;
3065  errMsg += "\ngeom->getMetersPerPixel returned nan for chain.";
3066  errMsg += "\nChain: ";
3067  errMsg += chain->getFilename().string();
3068  throw ossimException(errMsg);
3069  }
3070  }
3071  else
3072  {
3073  std::string errMsg = MODULE;
3074  errMsg += "\nNo geometry for chain: ";
3075  errMsg += chain->getFilename().string();
3076  throw ossimException(errMsg);
3077  }
3078  }
3079  else
3080  {
3081  std::string errMsg = MODULE;
3082  errMsg += " ERROR: Null chain passed to method!";
3083  throw ossimException(errMsg);
3084  }
3085
3086  if ( traceDebug() )
3087  {
3089  << "chain name: " << chain->getFilename()
3090  << "\nmeters per pixel: " << gsd << "\n" << MODULE << " exited...\n";
3091  }
3092 }
Returns the image geometry object associated with this tile source or NULL if not defined...
bool valid() const
ossimFilename getFilename() const
◆ getNewGeoProjection()
ossimRefPtr< ossimMapProjection > ossimChipperUtil::getNewGeoProjection ( )
private
Returns
new ossimEquDistCylProjection.
Definition at line 3320 of file ossimChipperUtil.cpp.
Referenced by getNewGeoScaledProjection().
◆ getNewGeoScaledProjection()
ossimRefPtr< ossimMapProjection > ossimChipperUtil::getNewGeoScaledProjection ( )
private
This method sets the origin to the center of the scene bounding rect of all layers.
Returns
Definition at line 3325 of file ossimChipperUtil.cpp.
References getCentralMeridian(), getNewGeoProjection(), getOriginLatitude(), getSceneCenter(), ossimGpt::hasNans(), ossimGpt::hgt, ossimGpt::lat, ossimGpt::lon, and ossimMapProjection::setOrigin().
3326 {
3327  // Make projection:
3329
3330  // Set the origin for scaling:
3331
3332  // First check for user set "central_meridian" and "origin_latitude":
3333  ossimGpt origin;
3334  origin.lat = getOriginLatitude();
3335  origin.lon = getCentralMeridian();
3336  origin.hgt = 0.0;
3337
3338  if ( origin.hasNans() )
3339  {
3340  // Use the scene center from the input.
3341  getSceneCenter( origin );
3342
3343  //---
3344  // Note only latitude used for scaling, origin kept at 0.0.
3345  // This is a fix/hack for ossimEquDistCylProjection wrapping issues.
3346  //---
3347  origin.lon = 0.0;
3348  }
3349
3350  if ( !origin.hasNans() )
3351  {
3352  result->setOrigin(origin);
3353  }
3354  else
3355  {
3356  std::string errMsg = "ossimChipperUtil::getNewGeoScaledProjection ERROR";
3357  errMsg += "\nOrigin has nans!";
3358  throw ossimException(errMsg);
3359  }
3360
3361  return result;
3362 }
void getSceneCenter(ossimGpt &gpt)
Loops through all layers to get the scene center ground point.
ossim_float64 hgt
Height in meters above the ellipsiod.
Definition: ossimGpt.h:274
ossim_float64 lon
ossim_float64 getCentralMeridian() const
Definition: ossimGpt.h:135
ossim_float64 getOriginLatitude() const
Gets value of key "origin_latitude" if set, nan if not.
ossim_float64 lat
◆ getNewProjectionFromSrsCode()
ossimRefPtr< ossimMapProjection > ossimChipperUtil::getNewProjectionFromSrsCode ( const std::string &  code)
private
Returns
new ossimMapProjection.
Definition at line 3364 of file ossimChipperUtil.cpp.
References ossimString::downcase(), ossimRefPtr< T >::get(), ossimProjectionFactoryRegistry::instance(), PTR_CAST, and ossimRefPtr< T >::valid().
3366 {
3368
3369  ossimString os = code;
3370  os.downcase();
3371
3372  if ( ( os == "epsg:4326" ) || ( code == "4326" ) )
3373  {
3374  // Avoid factory call for this.
3375  result = new ossimEquDistCylProjection();
3376  }
3377  else
3378  {
3380  createProjection(code);
3381  if ( proj.valid() )
3382  {
3383  result = PTR_CAST( ossimMapProjection, proj.get() );
3384  }
3385  }
3386  return result;
3387 }
bool valid() const
static ossimProjectionFactoryRegistry * instance()
◆ getNewUtmProjection()
ossimRefPtr< ossimMapProjection > ossimChipperUtil::getNewUtmProjection ( )
private
Returns
new ossimUtmProjection.
Definition at line 3389 of file ossimChipperUtil.cpp.
References ossimRefPtr< T >::get(), getCentralMeridian(), getHemisphere(), getOriginLatitude(), getSceneCenter(), getZone(), ossimGpt::hasNans(), ossimGpt::hgt, ossimGpt::lat, ossimGpt::lon, ossimUtmProjection::setHemisphere(), ossimUtmProjection::setZone(), and ossimString::upcase().
3390 {
3391  // Make projection:
3393
3394  // Set the zone from keyword option:
3395  bool setZone = false;
3396  ossim_int32 zone = getZone();
3397  if ( (zone > 0 ) && ( zone < 61 ) )
3398  {
3399  utm->setZone( zone );
3400  setZone = true;
3401  }
3402
3403  // Set the hemisphere from keyword option:
3404  bool setHemisphere = false;
3405  std::string hemisphere = getHemisphere();
3406  if ( hemisphere.size() )
3407  {
3408  ossimString h(hemisphere);
3409  h.upcase();
3410  if ( ( h == "N" ) || ( h == "NORTH" ) )
3411  {
3412  char c = 'N';
3413  utm->setHemisphere( c );
3414  setHemisphere = true;
3415  }
3416  if ( ( h == "S" ) || ( h == "SOUTH" ) )
3417  {
3418  char c = 'S';
3419  utm->setHemisphere( c );
3420  setHemisphere = true;
3421  }
3422  }
3423
3424  if ( !setZone || !setHemisphere )
3425  {
3426  // First check for user set "central_meridian" and "origin_latitude":
3427  ossimGpt origin;
3428  origin.lat = getOriginLatitude();
3429  origin.lon = getCentralMeridian();
3430  origin.hgt = 0.0;
3431
3432  if ( origin.hasNans() )
3433  {
3434  // Use the scene center from the input.
3435  getSceneCenter( origin );
3436  }
3437
3438  if ( !origin.hasNans() )
3439  {
3440  if ( !setZone )
3441  {
3442  utm->setZone(origin);
3443  }
3444  if ( !setHemisphere )
3445  {
3446  utm->setHemisphere(origin);
3447  }
3448  }
3449  else
3450  {
3451  std::string errMsg = "ossimChipperUtil::getNewUtmProjection ERROR";
3452  errMsg += "\nOrigin has nans!";
3453  throw ossimException(errMsg);
3454  }
3455  }
3456
3457  return ossimRefPtr<ossimMapProjection>(utm.get());
3458 }
ossim_float64 hgt
ossim_int32 getZone() const
ossim_float64 lon
void setZone(const ossimGpt &ground)
std::string getHemisphere() const
ossim_float64 lat
void setHemisphere(const ossimGpt &ground)
int ossim_int32
◆ getNumberOfInputs()
ossim_uint32 ossimChipperUtil::getNumberOfInputs ( ) const
private
Returns
The number of DEM_KW and IMG_KW found in the m_kwl and m_srcKwl keyword list.
Definition at line 5512 of file ossimChipperUtil.cpp.
References ossimKeywordlist::getNumberOfKeysThatMatch(), m_kwl, m_srcKwl, and ossimRefPtr< T >::valid().
5513 {
5514  ossim_uint32 result = 0;
5515
5516  ossimString demRegExpr = "dem[0-9]*\\.file";
5517  ossimString imgRegExpr = "image[0-9]*\\.file";
5518
5519  if ( m_kwl.valid() )
5520  {
5521  // Look for dems, e.g. dem0.file: foo.tif
5522  result = m_kwl->getNumberOfKeysThatMatch( demRegExpr );
5523
5524  // Look for images, e.g. image0.file: foo.tif
5525  result += m_kwl->getNumberOfKeysThatMatch( imgRegExpr );
5526  }
5527
5528  if ( m_srcKwl.valid() )
5529  {
5530  // Look for dems, e.g. dem0.file: foo.tif
5531  result += m_srcKwl->getNumberOfKeysThatMatch( demRegExpr );
5532
5533  // Look for images, e.g. image0.file: foo.tif
5534  result += m_srcKwl->getNumberOfKeysThatMatch( imgRegExpr );
5535  }
5536
5537  return result;
5538 }
bool valid() const
ossimRefPtr< ossimKeywordlist > m_srcKwl
Hold contents of src file if –src is used.
ossim_uint32 getNumberOfKeysThatMatch(const ossimString &regularExpression) const
Gets number keys that match regular expression.
◆ getOriginLatitude()
ossim_float64 ossimChipperUtil::getOriginLatitude ( ) const
private
Returns
Note
Definition at line 3111 of file ossimChipperUtil.cpp.
References ossimKeywordlist::find(), m_kwl, ossim::nan(), ossimKeywordNames::ORIGIN_LATITUDE_KW, ossimString::size(), and ossimString::toFloat64().
3112 {
3113  ossim_float64 result = ossim::nan();
3115  if ( lookup.size() )
3116  {
3117  result = lookup.toFloat64();
3118  if ( (result < -90) || (result > 90.0) )
3119  {
3120  std::string errMsg = "origin latitude range error!";
3121  errMsg += " Valid range: -90 to 90";
3122  throw ossimException(errMsg);
3123  }
3124  }
3125  return result;
3126 }
double nan()
std::string::size_type size() const
Definition: ossimString.h:405
static const char * ORIGIN_LATITUDE_KW
◆ getOutputFilename()
void ossimChipperUtil::getOutputFilename ( ossimFilename f) const
Parameters
fInitialized by this with the filename.
Definition at line 4372 of file ossimChipperUtil.cpp.
References ossimKeywordlist::findKey(), m_kwl, ossimKeywordNames::OUTPUT_FILE_KW, and ossimString::string().
4373 {
4374  f.string() = m_kwl->findKey( std::string(ossimKeywordNames::OUTPUT_FILE_KW) );
4375 }
static const char * OUTPUT_FILE_KW
◆ getOutputProjectionType()
ossimChipperUtil::ossimChipperOutputProjection ossimChipperUtil::getOutputProjectionType ( ) const
private
This looks in m_kwl for ossimKeywordNames::PROJECTION_KW.
Returns
The enumerated output projection type.
Note
This does not cover SRS keyword which could be any type of projection.
Definition at line 5540 of file ossimChipperUtil.cpp.
References ossimString::downcase(), ossimKeywordlist::find(), m_kwl, OSSIM_CHIPPER_PROJ_GEO, OSSIM_CHIPPER_PROJ_GEO_SCALED, OSSIM_CHIPPER_PROJ_INPUT, OSSIM_CHIPPER_PROJ_UNKNOWN, OSSIM_CHIPPER_PROJ_UTM, and ossimKeywordNames::PROJECTION_KW.
5541 {
5543  const char* op = m_kwl->find(ossimKeywordNames::PROJECTION_KW);
5544  if ( op )
5545  {
5546  ossimString os = op;
5547  os.downcase();
5548  if (os == "geo")
5549  {
5551  }
5552  else if (os == "geo-scaled")
5553  {
5555  }
5556  else if ( os == "input" )
5557  {
5559  }
5560  else if ( (os == "utm") || (os == "ossimutmprojection") )
5561  {
5563  }
5564  }
5565  return result;
5566 }
◆ getOutputScalarType()
ossimScalarType ossimChipperUtil::getOutputScalarType ( ) const
private
Returns the scalar type from OUTPUT_RADIOMETRY_KW keyword if present.
Deprecated SCALE_2_8_BIT_KW is also checked.
Returns
ossimScalarType Note this can be OSSIM_SCALAR_UNKNOWN if the keywords are not present.
Definition at line 5196 of file ossimChipperUtil.cpp.
References ossimKeywordlist::findKey(), m_kwl, and OSSIM_SCALAR_UNKNOWN.
Referenced by scaleToEightBit().
5197 {
5199  ossimString lookup = m_kwl->findKey( OUTPUT_RADIOMETRY_KW );
5200  if ( lookup.size() )
5201  {
5203  }
5204  if ( scalar == OSSIM_SCALAR_UNKNOWN )
5205  {
5206  // deprecated keyword...
5207  if ( keyIsTrue( std::string(SCALE_2_8_BIT_KW) ) )
5208  {
5209  scalar = OSSIM_UINT8;
5210  }
5211  }
5212  return scalar;
5213 }
ossimScalarType getScalarTypeFromString(const ossimString &s) const
bool keyIsTrue(const std::string &key) const
static ossimScalarTypeLut * instance()
Returns the static instance of an ossimScalarTypeLut object.
ossimScalarType
8 bit unsigned integer
◆ getRotation()
ossim_float64 ossimChipperUtil::getRotation ( ) const
private
Gets rotation.
Returns
Rotation in decimal degrees if ROTATION_KW option is set; ossim::nan, if not.
Note
Definition at line 5301 of file ossimChipperUtil.cpp.
References ossimKeywordlist::findKey(), m_kwl, ossim::nan(), and ossimRefPtr< T >::valid().
5302 {
5303  ossim_float64 result = ossim::nan();
5304  if ( m_kwl.valid() )
5305  {
5306  std::string value = m_kwl->findKey( ROTATION_KW);
5307  if ( value.size() )
5308  {
5309  result = ossimString(value).toFloat64();
5310  if ( result < 0 )
5311  {
5312  result += 360.0;
5313  }
5314
5315  // Range check:
5316  if ( ( result < 0.0 ) || ( result > 360.0 ) )
5317  {
5318  std::ostringstream errMsg;
5319  errMsg << "ossimChipperUtil::getRotation range error!\n"
5320  << "rotation = " << result
5321  << "\nMust be between 0 and 360.";
5322  throw ossimException( errMsg.str() );
5323  }
5324  }
5325  }
5326  return result;
5327 }
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
bool valid() const
double nan()
◆ getSceneCenter() [1/2]
void ossimChipperUtil::getSceneCenter ( ossimGpt gpt)
private
Parameters
gptPoint to initialize.
Note
Definition at line 3128 of file ossimChipperUtil.cpp.
3129 {
3130  static const char MODULE[] = "ossimChipperUtil::getSceneCenter(ossimGpt&)";
3131  if ( traceDebug() )
3132  {
3133  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
3134  }
3135
3136  std::vector<ossimGpt> centerGptArray;
3137  ossimGpt centerGpt;
3138
3139  std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator chainIdx;
3140
3141  // Loop through dem layers.
3142  chainIdx = m_demLayer.begin();
3143  while ( chainIdx != m_demLayer.end() )
3144  {
3145  getSceneCenter( (*chainIdx).get(), centerGpt);
3146  if ( !centerGpt.hasNans() )
3147  {
3148  centerGptArray.push_back( centerGpt );
3149  }
3150  ++chainIdx;
3151  }
3152
3153  // Loop through image layers.
3154  chainIdx = m_imgLayer.begin();
3155  while ( chainIdx != m_imgLayer.end() )
3156  {
3157  getSceneCenter( (*chainIdx).get(), centerGpt);
3158  if ( !centerGpt.hasNans() )
3159  {
3160  centerGptArray.push_back( centerGpt );
3161  }
3162  ++chainIdx;
3163  }
3164
3165  ossim_float64 lat = 0.0;
3166  ossim_float64 lon = 0.0;
3167
3168  std::vector<ossimGpt>::const_iterator pointIdx = centerGptArray.begin();
3169  while ( pointIdx != centerGptArray.end() )
3170  {
3171  lat += (*pointIdx).lat;
3172  lon += (*pointIdx).lon;
3173  ++pointIdx;
3174  }
3175
3176  lat /= centerGptArray.size();
3177  lon /= centerGptArray.size();
3178
3179  if ( (lat >= -90.0) && (lat <= 90.0) && (lon >= -180.0) && (lon <= 180.0) )
3180  {
3181  gpt.lat = lat;
3182  gpt.lon = lon;
3183  }
3184  else
3185  {
3186  std::ostringstream errMsg;
3187  errMsg << MODULE << " range error!\nlatitude = "
3188  << ossimString::toString(lat).string()
3189  << "\nlongitude = "
3190  << ossimString::toString(lon).string();
3191  throw ossimException( errMsg.str() );
3192  }
3193
3194  if ( traceDebug() )
3195  {
3197  << "scene center: " << gpt << "\n" << MODULE << " exited...\n";
3198  }
3199 }
Numeric to string methods.
ossim_float64 lon
ossim_float64 lat
◆ getSceneCenter() [2/2]
void ossimChipperUtil::getSceneCenter ( ossimSingleImageChain chain,
ossimGpt gpt
private
Gets the scene center from a chain.
Parameters
chainThe chain to get scene center from.
Note
Definition at line 3201 of file ossimChipperUtil.cpp.
3202 {
3203  static const char MODULE[] =
3204  "ossimChipperUtil::getSceneCenter(const ossimSingleImageChain*,ossimGpt&)";
3205
3206  if ( traceDebug() )
3207  {
3208  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
3209  }
3210
3211  if (chain)
3212  {
3214  if ( geom.valid() )
3215  {
3216  ossimIrect boundingRect = chain->getBoundingRect();
3217  ossimDpt midPoint = boundingRect.midPoint();
3218  geom->localToWorld(midPoint, gpt);
3219  gpt.hgt = 0.0;
3220
3221  if ( gpt.hasNans() )
3222  {
3223  std::string errMsg = MODULE;
3224  errMsg += "\ngeom->localToWorld returned nan for chain.";
3225  errMsg += "\nChain: ";
3226  errMsg += chain->getFilename().string();
3227  throw ossimException(errMsg);
3228  }
3229  }
3230  else
3231  {
3232  std::string errMsg = MODULE;
3233  errMsg += "\nNo geometry for chain: ";
3234  errMsg += chain->getFilename().string();
3235  throw ossimException(errMsg);
3236  }
3237  }
3238  else
3239  {
3240  std::string errMsg = MODULE;
3241  errMsg += " ERROR: Null chain passed to method!";
3242  throw ossimException(errMsg);
3243  }
3244
3245  if ( traceDebug() )
3246  {
3248  << "chain name: " << chain->getFilename()
3249  << "\nscene center: " << gpt << "\n"
3250  << MODULE << " exited...\n";
3251  }
3252 }
bool valid() const
ossim_float64 hgt
bool localToWorld(const ossimDpt &local_pt, ossimGpt &world_pt) const
Exposes the 3D projection from image to world coordinates.
Will pass this call to the head of the list.
◆ getSharpenMode()
std::string ossimChipperUtil::getSharpenMode ( ) const
private
Gets the sharpen mode.
Valid modes: light, heavy
Returns
sharpness mode
Definition at line 5643 of file ossimChipperUtil.cpp.
5644 {
5645  ossimString mode = m_kwl->findKey( SHARPEN_MODE_KW );
5646  if ( mode.size() )
5647  {
5648  mode.downcase();
5649  if ( (mode != "light") && (mode != "heavy") && (mode != "none") )
5650  {
5652  << "ossimChipperUtil::getSharpnessMode WARNING!"
5653  << "\nInvalid sharpness mode: " << mode
5654  << "\nValid modes: \"light\" and \"heavy\""
5655  << std::endl;
5656  mode = "";
5657  }
5658  if(mode=="none") mode = "";
5659  }
5660  return mode.string();
5661 }
◆ getTiePoint() [1/4]
void ossimChipperUtil::getTiePoint ( ossimGpt tie)
private
Loops through all layers to get the upper left tie point.
Parameters
tiePoint to initialize.
Definition at line 2752 of file ossimChipperUtil.cpp.
2753 {
2754  static const char MODULE[] = "ossimChipperUtil::getTiePoint(ossimGpt&)";
2755  if ( traceDebug() )
2756  {
2757  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
2758  }
2759
2760  std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator chainIdx;
2761
2762  tie.lat = ossim::nan();
2763  tie.lon = ossim::nan();
2764  tie.hgt = 0.0;
2765
2766  // Loop through dem layers.
2767  ossimGpt chainTiePoint;
2768  chainIdx = m_demLayer.begin();
2769  while ( chainIdx != m_demLayer.end() )
2770  {
2771  getTiePoint( (*chainIdx).get(), chainTiePoint );
2772  if ( tie.hasNans() )
2773  {
2774  tie = chainTiePoint;
2775  }
2776  else
2777  {
2778  if ( chainTiePoint.lat > tie.lat )
2779  {
2780  tie.lat = chainTiePoint.lat;
2781  }
2782  if ( chainTiePoint.lon < tie.lon )
2783  {
2784  tie.lon = chainTiePoint.lon;
2785  }
2786  }
2787  ++chainIdx;
2788  }
2789
2790  // Loop through image layers.
2791  chainIdx = m_imgLayer.begin();
2792  while ( chainIdx != m_imgLayer.end() )
2793  {
2794  getTiePoint( (*chainIdx).get(), chainTiePoint );
2795  if ( tie.hasNans() )
2796  {
2797  tie = chainTiePoint;
2798  }
2799  else
2800  {
2801  if ( chainTiePoint.lat > tie.lat )
2802  {
2803  tie.lat = chainTiePoint.lat;
2804  }
2805  if ( chainTiePoint.lon < tie.lon )
2806  {
2807  tie.lon = chainTiePoint.lon;
2808  }
2809  }
2810  ++chainIdx;
2811  }
2812
2813  if ( traceDebug() )
2814  {
2816  << "tie point: " << tie << "\n" << MODULE << " exited...\n";
2817  }
2818 }
double nan()
ossim_float64 hgt
ossim_float64 lon
void getTiePoint(ossimGpt &tie)
ossim_float64 lat
◆ getTiePoint() [2/4]
void ossimChipperUtil::getTiePoint ( ossimSingleImageChain chain,
ossimGpt tie
private
Gets the upper left tie point from a chain.
Parameters
chainThe chain to get tie point from.
Note
Definition at line 2820 of file ossimChipperUtil.cpp.
2821 {
2822  static const char MODULE[] = "ossimChipperUtil::getTiePoint(ossimSingleImageChain*,ossimGpt&)";
2823  if ( traceDebug() )
2824  {
2825  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
2826  }
2827
2828  if (chain && m_geom.valid() )
2829  {
2830  //---
2831  // The view is not set yet in the chain so we get the tie point from the
2832  // image handler geometry not from the chain which will come from the
2833  // ossimImageRenderer.
2834  //---
2836  if ( ih.valid() )
2837  {
2839  if ( geom.valid() )
2840  {
2841  geom->getTiePoint( tie, true );
2842  }
2843
2844
2845  // Set height to 0.0 even though it's not used so hasNans test works.
2846  tie.hgt = 0.0;
2847
2848  if ( tie.hasNans() )
2849  {
2850  std::string errMsg = MODULE;
2851  errMsg += "\ngeom->localToWorld returned nan for chain.";
2852  errMsg += "\nChain: ";
2853  errMsg += chain->getFilename().string();
2854  throw ossimException(errMsg);
2855  }
2856  }
2857  else
2858  {
2859  std::string errMsg = MODULE;
2860  errMsg += "\nNo geometry for chain: ";
2861  errMsg += chain->getFilename().string();
2862  throw ossimException(errMsg);
2863  }
2864  }
2865  else
2866  {
2867  std::string errMsg = MODULE;
2868  errMsg += " ERROR: Null chain passed to method!";
2869  throw ossimException(errMsg);
2870  }
2871
2872  if ( traceDebug() )
2873  {
2875  << "chain name: " << chain->getFilename()
2876  << "\ntie point: " << tie << "\n"
2877  << MODULE << " exited...\n";
2878  }
2879 }
ossimRefPtr< const ossimImageHandler > getImageHandler() const
bool valid() const
ossim_float64 hgt
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
The image geometry.
void getTiePoint(ossimGpt &tie, bool edge) const
Get the latitude, longitude of the tie point.
◆ getTiePoint() [3/4]
void ossimChipperUtil::getTiePoint ( ossimDpt tie)
private
Parameters
Definition at line 2881 of file ossimChipperUtil.cpp.
2882 {
2883  static const char MODULE[] = "ossimChipperUtil::getTiePoint(ossimDpt&)";
2884  if ( traceDebug() )
2885  {
2886  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
2887  }
2888
2889  std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator chainIdx;
2890
2891  tie.makeNan();
2892
2893  // Loop through dem layers.
2894  ossimDpt chainTiePoint;
2895  chainIdx = m_demLayer.begin();
2896  while ( chainIdx != m_demLayer.end() )
2897  {
2898  getTiePoint( (*chainIdx).get(), chainTiePoint );
2899  if ( tie.hasNans() )
2900  {
2901  tie = chainTiePoint;
2902  }
2903  else
2904  {
2905  if ( chainTiePoint.y > tie.y )
2906  {
2907  tie.y = chainTiePoint.y;
2908  }
2909  if ( chainTiePoint.x < tie.x )
2910  {
2911  tie.x = chainTiePoint.x;
2912  }
2913  }
2914  ++chainIdx;
2915  }
2916
2917  // Loop through image layers.
2918  chainIdx = m_imgLayer.begin();
2919  while ( chainIdx != m_imgLayer.end() )
2920  {
2921  getTiePoint( (*chainIdx).get(), chainTiePoint );
2922  if ( tie.hasNans() )
2923  {
2924  tie = chainTiePoint;
2925  }
2926  else
2927  {
2928  if ( chainTiePoint.y > tie.y )
2929  {
2930  tie.y = chainTiePoint.y;
2931  }
2932  if ( chainTiePoint.x < tie.x )
2933  {
2934  tie.x = chainTiePoint.x;
2935  }
2936  }
2937  ++chainIdx;
2938  }
2939
2940  if ( traceDebug() )
2941  {
2943  << "tie point: " << tie << "\n" << MODULE << " exited...\n";
2944  }
2945 }
double y
double x
void makeNan()
◆ getTiePoint() [4/4]
ossimDpt tie
private
Parameters
Note
Definition at line 2947 of file ossimChipperUtil.cpp.
2948 {
2949  static const char MODULE[] = "ossimChipperUtil::getTiePoint(ossimSingleImageChain*,ossimDpt&)";
2950  if ( traceDebug() )
2951  {
2952  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
2953  }
2954
2955  if (chain && m_geom.valid() )
2956  {
2957  //---
2958  // The view is not set yet in the chain so we get the tie point from the
2959  // image handler geometry not from the chain which will come from the
2960  // ossimImageRenderer.
2961  //---
2963  if ( ih.valid() )
2964  {
2966  if ( geom.valid() )
2967  {
2968  geom->getTiePoint( tie, true );
2969  }
2970
2971  if ( tie.hasNans() )
2972  {
2973  std::string errMsg = MODULE;
2974  errMsg += "\ngeom->localToWorld returned nan for chain.";
2975  errMsg += "\nChain: ";
2976  errMsg += chain->getFilename().string();
2977  throw ossimException(errMsg);
2978  }
2979  }
2980  else
2981  {
2982  std::string errMsg = MODULE;
2983  errMsg += "\nNo geometry for chain: ";
2984  errMsg += chain->getFilename().string();
2985  throw ossimException(errMsg);
2986  }
2987  }
2988  else
2989  {
2990  std::string errMsg = MODULE;
2991  errMsg += " ERROR: Null chain passed to method!";
2992  throw ossimException(errMsg);
2993  }
2994
2995  if ( traceDebug() )
2996  {
2998  << "chain name: " << chain->getFilename()
2999  << "\ntie point: " << tie << "\n"
3000  << MODULE << " exited...\n";
3001  }
3002 }
bool valid() const
The image geometry.
◆ getZone()
ossim_int32 ossimChipperUtil::getZone ( ) const
private
Returns
The zone if set. Zero if ossimKeywordNames::ZONE_KW not found.
Definition at line 5383 of file ossimChipperUtil.cpp.
References ossimKeywordlist::findKey(), m_kwl, ossimString::toUInt32(), ossimRefPtr< T >::valid(), and ossimKeywordNames::ZONE_KW.
5384 {
5385  ossim_int32 result = 0;
5386  if ( m_kwl.valid() )
5387  {
5388  std::string value = m_kwl->findKey( std::string( ossimKeywordNames::ZONE_KW ) );
5389  if ( value.size() )
5390  {
5391  result = ossimString(value).toUInt32();
5392  }
5393  }
5394  return result;
5395 }
bool valid() const
ossim_uint32 toUInt32() const
static const char * ZONE_KW
int ossim_int32
◆ hasAnnotations()
bool ossimChipperUtil::hasAnnotations ( ) const
private
Returns
true if annotation options are set; false, if not.
Definition at line 5081 of file ossimChipperUtil.cpp.
References ossimKeywordlist::getNumberOfKeysThatMatch(), m_kwl, and ossimRefPtr< T >::valid().
5082 {
5083  bool result = false;
5084  if ( m_kwl.valid() )
5085  {
5086  ossimString regularExpression = "annotation[0-9]*\\.type";
5087  ossim_uint32 count = m_kwl->getNumberOfKeysThatMatch( regularExpression );
5088  if ( count > 0 )
5089  {
5090  result = true;
5091  }
5092  }
5093  return result;
5094 }
bool valid() const
Hold all options passed into intialize.
◆ hasBandSelection()
bool ossimChipperUtil::hasBandSelection ( ) const
private
Returns
true if BANDS keyword is set; false, if not.
Definition at line 4943 of file ossimChipperUtil.cpp.
References ossimKeywordNames::BANDS_KW, ossimKeywordlist::hasKey(), m_kwl, and ossimRefPtr< T >::valid().
4944 {
4945  bool result = false;
4946  if ( m_kwl.valid() )
4947  {
4948  result = m_kwl->hasKey( std::string(ossimKeywordNames::BANDS_KW) );
4949  }
4950  return result;
4951 }
bool valid() const
bool hasKey(const std::string &key) const
Checks for key in map.
◆ hasBrightnesContrastOperation()
bool ossimChipperUtil::hasBrightnesContrastOperation ( ) const
private
Returns
true if brightness or contrast option is set; false, if not.
Definition at line 5106 of file ossimChipperUtil.cpp.
5107 {
5108  bool result = false;
5109  std::string value = m_kwl->findKey( BRIGHTNESS_KW );
5110  if ( value.size() )
5111  {
5112  result = true;
5113  }
5114  else
5115  {
5116  value = m_kwl->findKey( CONTRAST_KW );
5117  if ( value.size() )
5118  {
5119  result = true;
5120  }
5121  }
5122  return result;
5123 }
◆ hasBumpShadeArg()
bool ossimChipperUtil::hasBumpShadeArg ( ) const
private
Returns
true if any bump share options have been set by user; false, if not.
Definition at line 5133 of file ossimChipperUtil.cpp.
References ossimKeywordNames::AZIMUTH_ANGLE_KW, ossimKeywordlist::find(), m_kwl, m_operation, OSSIM_CHIPPER_OP_HILL_SHADE, and ossimRefPtr< T >::valid().
5134 {
5135  bool result = ( m_operation == OSSIM_CHIPPER_OP_HILL_SHADE );
5136  if ( !result && m_kwl.valid() )
5137  {
5139  m_kwl->find( COLOR_RED_KW.c_str() ) ||
5140  m_kwl->find( COLOR_GREEN_KW.c_str() ) ||
5141  m_kwl->find( COLOR_BLUE_KW.c_str() ) ||
5143  m_kwl->find( GAIN_KW.c_str() ) );
5144  }
5145  return result;
5146 }
bool valid() const
static const char * AZIMUTH_ANGLE_KW
ossimChipperOperation m_operation
Enumerated operation to perform.
static const char * ELEVATION_ANGLE_KW
◆ hasCutBoxWidthHeight()
bool ossimChipperUtil::hasCutBoxWidthHeight ( ) const
private
Returns
true if all size cut box width height keywords are true.
Definition at line 4968 of file ossimChipperUtil.cpp.
References ossimKeywordlist::hasKey(), m_kwl, and ossimRefPtr< T >::valid().
4969 {
4970  bool result = false;
4971  if ( m_kwl.valid() )
4972  {
4973  if ( m_kwl->hasKey( CUT_HEIGHT_KW ) )
4974  {
4975  if ( m_kwl->hasKey( CUT_WIDTH_KW ) )
4976  {
4977  if ( m_kwl->hasKey( CUT_MIN_LAT_KW ) )
4978  {
4979  if ( m_kwl->hasKey( CUT_MIN_LON_KW ) )
4980  {
4981  if ( m_kwl->hasKey( CUT_MAX_LAT_KW ) )
4982  {
4983  if ( m_kwl->hasKey( CUT_MAX_LON_KW ) )
4984  {
4985  result = true;
4986  }
4987  }
4988  }
4989  } // if lat and lon WMS style bbox is specified then we will behave the same as above
4990  else if( m_kwl->hasKey(CUT_WMS_BBOX_LL_KW))
4991  {
4992  result = true;
4993  }
4994  }
4995  }
4996  }
4997  return result;
4998 }
bool valid() const
Definition: ossimRefPtr.h:75
◆ hasGeoPolyCutterOption()
bool ossimChipperUtil::hasGeoPolyCutterOption ( ) const
private
Returns
true if any Geo Poly cutter option is set
Definition at line 5125 of file ossimChipperUtil.cpp.
References ossimKeywordlist::find(), and m_kwl.
5126 {
5127  bool result = (m_kwl->find(CLIP_WMS_BBOX_LL_KW.c_str())||
5128  m_kwl->find(CLIP_POLY_LAT_LON_KW.c_str()));
5129
5130  return result;
5131 }
◆ hasHistogramOperation()
bool ossimChipperUtil::hasHistogramOperation ( ) const
private
Returns
true if histogram option is set; false, if not.
Definition at line 5158 of file ossimChipperUtil.cpp.
5159 {
5160  bool result = false;
5161  if ( m_kwl.valid() )
5162  {
5163  result = m_kwl->hasKey( HIST_OP_KW );
5164  }
5165  return result;
5166 }
bool valid() const
◆ hasLutFile()
bool ossimChipperUtil::hasLutFile ( ) const
private
Returns
true if color table (lut) is set; false, if not.
Definition at line 5096 of file ossimChipperUtil.cpp.
References ossimKeywordlist::find(), m_kwl, and ossimRefPtr< T >::valid().
Referenced by initializeColorReliefChain().
5097 {
5098  bool result = false;
5099  if ( m_kwl.valid() )
5100  {
5101  result = ( m_kwl->find( LUT_FILE_KW.c_str() ) != 0 );
5102  }
5103  return result;
5104 }
bool valid() const
◆ hasRotation()
bool ossimChipperUtil::hasRotation ( ) const
private
Returns
true if ROTATION_KW option is set; false, if not.
Definition at line 5334 of file ossimChipperUtil.cpp.
5335 {
5336  bool result = false;
5337  std::string value = m_kwl->findKey(std::string(ROTATION_KW));
5338  if ( value.size() )
5339  {
5340  result = true;
5341  }
5342  return result;
5343 }
◆ hasScaleOption()
bool ossimChipperUtil::hasScaleOption ( ) const
private
Returns
true if meters, degrees or cut box with width and height option.
Definition at line 5000 of file ossimChipperUtil.cpp.
5001 {
5002  bool result = false;
5003  if ( m_kwl.valid() )
5004  {
5005  if ( m_kwl->hasKey( METERS_KW.c_str() ) ||
5006  m_kwl->hasKey( DEGREES_X_KW.c_str() ) ||
5009  {
5010  result = true;
5011  }
5012  }
5013  return result;
5014 }
bool valid() const
bool hasWmsBboxCutWidthHeight() const
bool hasCutBoxWidthHeight() const
◆ hasSensorModelInput()
bool ossimChipperUtil::hasSensorModelInput ( )
private
Returns
True if any input has a sensor model input, false if all input projections are map projections.
Definition at line 5408 of file ossimChipperUtil.cpp.
References ossimRefPtr< T >::get(), ossimImageHandler::getImageGeometry(), ossimImageGeometry::getProjection(), m_demLayer, m_imgLayer, PTR_CAST, and ossimRefPtr< T >::valid().
5409 {
5410  bool result = false;
5411
5412  // Test image layers.
5413  std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator chainIdx = m_imgLayer.begin();
5414  while ( chainIdx != m_imgLayer.end() )
5415  {
5416  // Get the image handler:
5417  ossimRefPtr<ossimImageHandler> ih = (*chainIdx)->getImageHandler();
5418  if ( ih.valid() )
5419  {
5420  // Get the geometry from the first image handler.
5422  if ( geom.valid() )
5423  {
5424  // Get the image projection.
5426  if ( proj.valid() )
5427  {
5428  // Cast and assign to result.
5429  ossimMapProjection* mapProj = PTR_CAST( ossimMapProjection, proj.get() );
5430  if ( !mapProj )
5431  {
5432  result = true;
5433  break;
5434  }
5435  }
5436  }
5437  }
5438  ++chainIdx;
5439  }
5440
5441  if ( !result )
5442  {
5443  // Test dem layers.
5444  chainIdx = m_demLayer.begin();
5445  while ( chainIdx != m_demLayer.end() )
5446  {
5447  // Get the image handler:
5448  ossimRefPtr<ossimImageHandler> ih = (*chainIdx)->getImageHandler();
5449  if ( ih.valid() )
5450  {
5451  // Get the geometry from the first image handler.
5453  if ( geom.valid() )
5454  {
5455  // Get the image projection.
5457  if ( proj.valid() )
5458  {
5459  // Cast and assign to result.
5460  ossimMapProjection* mapProj = PTR_CAST( ossimMapProjection, proj.get() );
5461  if ( !mapProj )
5462  {
5463  result = true;
5464  break;
5465  }
5466  }
5467  }
5468  }
5469  ++chainIdx;
5470  }
5471  }
5472
5473  return result;
5474 }
bool valid() const
◆ hasThumbnailResolution()
bool ossimChipperUtil::hasThumbnailResolution ( ) const
private
Returns
true if thumbnail option is set; false, if not.
Definition at line 5148 of file ossimChipperUtil.cpp.
5149 {
5150  bool result = false;
5151  if ( m_kwl.valid() )
5152  {
5153  result = ( m_kwl->find( THUMBNAIL_RESOLUTION_KW.c_str() ) != 0 );
5154  }
5155  return result;
5156 }
bool valid() const
◆ hasWmsBboxCutWidthHeight()
bool ossimChipperUtil::hasWmsBboxCutWidthHeight ( ) const
private
Returns
true if the WMS style cut and the width and height keywords are set
Definition at line 4953 of file ossimChipperUtil.cpp.
4954 {
4955  bool result = false;
4956
4957  if(m_kwl.valid())
4958  {
4959  result = (m_kwl->hasKey( CUT_HEIGHT_KW )&&
4960  m_kwl->hasKey( CUT_WIDTH_KW ) &&
4961  (m_kwl->hasKey( CUT_WMS_BBOX_KW )||
4962  m_kwl->hasKey(CUT_WMS_BBOX_LL_KW)));
4963  }
4964
4965  return result;
4966 }
bool valid() const
◆ initialize() [1/3]
bool ossimChipperUtil::initialize ( ossimArgumentParser ap)
Initial method to be ran prior to execute.
Parameters
apArg parser to initialize from.
Note
A throw with an error message of "usage" is used to get out when a usage is printed.
Definition at line 357 of file ossimChipperUtil.cpp.
358 {
359  static const char MODULE[] = "ossimChipperUtil::initialize(ossimArgumentParser&)";
360
361  if ( traceDebug() )
362  {
363  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
364  }
365
366  clear();
367  if( ap.read("-h") || ap.read("--help") || (ap.argc() == 1) )
368  {
369  usage(ap);
370
371  return false; // Indicates process should be terminated to caller.
372  }
373
374  // Start with clean options keyword list.
375  m_kwl->clear();
376
377  std::string tempString1;
378  ossimArgumentParser::ossimParameter stringParam1(tempString1);
379  std::string tempString2;
380  ossimArgumentParser::ossimParameter stringParam2(tempString2);
381  std::string tempString3;
382  ossimArgumentParser::ossimParameter stringParam3(tempString3);
383  std::string tempString4;
384  ossimArgumentParser::ossimParameter stringParam4(tempString4);
385  std::string tempString5;
386  ossimArgumentParser::ossimParameter stringParam5(tempString5);
387  std::string tempString6;
388  ossimArgumentParser::ossimParameter stringParam6(tempString6);
389  double tempDouble1;
390  ossimArgumentParser::ossimParameter doubleParam1(tempDouble1);
391  double tempDouble2;
392  ossimArgumentParser::ossimParameter doubleParam2(tempDouble2);
393
394  ossim_uint32 demIdx = 0;
395  ossim_uint32 imgIdx = 0;
396  ossim_uint32 readerPropIdx = 0;
397  ossim_uint32 writerPropIdx = 0;
398  ossimString key = "";
399
400  // Extract optional arguments and stuff them in a keyword list.
401  if( ap.read("--azimuth", stringParam1) )
402  {
403  m_kwl->addPair( std::string(ossimKeywordNames::AZIMUTH_ANGLE_KW), tempString1 );
404  }
405
406  if (ap.read("-b", stringParam1) || ap.read("--bands", stringParam1))
407  {
408  m_kwl->addPair( std::string(ossimKeywordNames::BANDS_KW), tempString1 );
409  }
410
411  if( ap.read("--brightness", stringParam1) )
412  {
413  m_kwl->addPair( BRIGHTNESS_KW, tempString1 );
414  }
415
416  if( ap.read("--central-meridian", stringParam1) )
417  {
418  m_kwl->addPair( std::string(ossimKeywordNames::CENTRAL_MERIDIAN_KW), tempString1 );
419  }
420
421  if( ap.read("--color", stringParam1, stringParam2, stringParam3) )
422  {
423  m_kwl->addPair( COLOR_RED_KW, tempString1 );
424  m_kwl->addPair( COLOR_GREEN_KW, tempString2 );
425  m_kwl->addPair( COLOR_BLUE_KW, tempString3 );
426  }
427
428  if( ap.read("--color-table", stringParam1) )
429  {
430  m_kwl->addPair( LUT_FILE_KW, tempString1 );
431  }
432
433  if( ap.read("--contrast", stringParam1) )
434  {
435  m_kwl->addPair( CONTRAST_KW, tempString1 );
436  }
437
438  if( ap.read("--cut-width", stringParam1) )
439  {
440  m_kwl->addPair( CUT_WIDTH_KW, tempString1 );
441  }
442  if( ap.read("--cut-height", stringParam1) )
443  {
444  m_kwl->addPair( CUT_HEIGHT_KW, tempString1 );
445  }
446  if( ap.read("--cut-bbox-xywh", stringParam1) )
447  {
448  m_kwl->addPair(CUT_BBOX_XYWH_KW, tempString1);
449  }
450  if( ap.read("--cut-wms-bbox", stringParam1) )
451  {
452  m_kwl->addPair(CUT_WMS_BBOX_KW, tempString1);
453  }
454  if( ap.read("--cut-wms-bbox-ll", stringParam1) )
455  {
456  m_kwl->addPair(CUT_WMS_BBOX_LL_KW, tempString1);
457  }
458
459  if( ap.read("--clip-wms-bbox-ll", stringParam1) )
460  {
461  m_kwl->addPair(CLIP_WMS_BBOX_LL_KW, tempString1);
462  }
463
464  if( ap.read("--clip-poly-lat-lon", stringParam1) )
465  {
466  //std::vector<ossimGpt> result;
467  //ossim::toVector(result, ossimString(tempString1));
468  //std::cout << result[0] << std::endl;
469  //std::cout <<tempString1<<std::endl;
470  //exit(0);
471  m_kwl->addPair(CLIP_POLY_LAT_LON_KW, tempString1);
472  }
473
474  if( ap.read("--cut-bbox-ll", stringParam1, stringParam2, stringParam3, stringParam4) )
475  {
476  m_kwl->addPair( CUT_MIN_LAT_KW, tempString1 );
477  m_kwl->addPair( CUT_MIN_LON_KW, tempString2 );
478  m_kwl->addPair( CUT_MAX_LAT_KW, tempString3 );
479  m_kwl->addPair( CUT_MAX_LON_KW, tempString4 );
480  }
481
482  if( ap.read("--cut-bbox-llwh", stringParam1, stringParam2, stringParam3,
483  stringParam4, stringParam5, stringParam6) )
484  {
485  m_kwl->addPair( CUT_MIN_LAT_KW, tempString1 );
486  m_kwl->addPair( CUT_MIN_LON_KW, tempString2 );
487  m_kwl->addPair( CUT_MAX_LAT_KW, tempString3 );
488  m_kwl->addPair( CUT_MAX_LON_KW, tempString4 );
489  m_kwl->addPair( CUT_WIDTH_KW, tempString5 );
490  m_kwl->addPair( CUT_HEIGHT_KW, tempString6 );
491  }
492
493  if( ap.read("--cut-center-llwh", stringParam1, stringParam2, stringParam3, stringParam4) )
494  {
495  m_kwl->addPair( CUT_CENTER_LAT_KW, tempString1 );
496  m_kwl->addPair( CUT_CENTER_LON_KW, tempString2 );
497  m_kwl->addPair( CUT_WIDTH_KW, tempString3 );
498  m_kwl->addPair( CUT_HEIGHT_KW, tempString4 );
499  }
500
501  if( ap.read("--cut-center-llr", stringParam1, stringParam2, stringParam3) )
502  {
503  m_kwl->addPair( CUT_CENTER_LAT_KW, tempString1 );
504  m_kwl->addPair( CUT_CENTER_LON_KW, tempString2 );
505  m_kwl->addPair( CUT_RADIUS_KW, tempString3 );
506  }
507
508  int num_params = ap.numberOfParams("--degrees", doubleParam1);
509  if (num_params == 1)
510  {
511  ap.read("--degrees", doubleParam1);
512  m_kwl->add( DEGREES_X_KW.c_str(), tempDouble1 );
513  m_kwl->add( DEGREES_Y_KW.c_str(), tempDouble1 );
514  }
515  else if (num_params == 2)
516  {
517  ap.read("--degrees", doubleParam1, doubleParam2);
518  m_kwl->add( DEGREES_X_KW.c_str(), tempDouble1 );
519  m_kwl->add( DEGREES_Y_KW.c_str(), tempDouble2 );
520  }
521
522  if ( ap.read("--elevation", stringParam1) )
523  {
524  m_kwl->addPair( std::string(ossimKeywordNames::ELEVATION_ANGLE_KW), tempString1 );
525  }
526
527  if ( ap.read("-e", stringParam1) || ap.read("--entry", stringParam1) )
528  {
529  m_kwl->addPair( std::string(ossimKeywordNames::ENTRY_KW), tempString1 );
530  }
531
532  if (ap.read("--exaggeration", stringParam1))
533  {
534  m_kwl->addPair(GAIN_KW, tempString1);
535  }
536
537  if (ap.read("--fullres-xys", stringParam1))
538  {
539  m_kwl->addPair(FULLRES_XYS_KW, tempString1);
540
541  std::vector<ossimString> values;
542  ossimString(tempString1).split(values, ",");
543  double sx,sy;
544  if(values.size() > 2)
545  {
546  sx = values[2].toDouble();
547  sy = sx;
548  if(values.size() > 3)
549  {
550  sy = values[3].toDouble();
551  }
552  m_kwl->add(IMAGE_SPACE_SCALE_X_KW.c_str(), sx);
553  m_kwl->add(IMAGE_SPACE_SCALE_Y_KW.c_str(), sy);
554  }
555  }
556
557  if ( ap.read("--hemisphere", stringParam1) )
558  {
559  m_kwl->addPair( std::string(ossimKeywordNames::HEMISPHERE_KW), tempString1 );
560  }
561
562  if ( ap.read("--histogram-aoi", stringParam1) )
563  {
564  m_kwl->addPair( HIST_AOI_KW, tempString1 );
565  }
566
567  if(ap.read("--enable-null-pixel-flip"))
568  {
569  m_kwl->addPair(NULL_PIXEL_FLIP_KW, TRUE_KW);
570  }
571
572  if ( ap.read( "--histogram-center-tile" ) )
573  {
574  m_kwl->addPair( HIST_CENTER_KW, TRUE_KW );
575  }
576
577  if ( ap.read("--histogram-llwh", stringParam1) )
578  {
579  m_kwl->addPair( HIST_LLWH_KW, tempString1 );
580  }
581
582  if ( ap.read("--histogram-op", stringParam1) )
583  {
584  m_kwl->addPair( HIST_OP_KW, tempString1 );
585  }
586
587  if ( ap.read("--image-space-scale", doubleParam1, doubleParam2) )
588  {
589  m_kwl->add( IMAGE_SPACE_SCALE_X_KW.c_str(), tempDouble1 );
590  m_kwl->add( IMAGE_SPACE_SCALE_Y_KW.c_str(), tempDouble2 );
591  }
592
593  while( ap.read("--input-dem", stringParam1) )
594  {
595  key = DEM_KW;
596  key += ossimString::toString(demIdx);
597  key += ".";
598  key += FILE_KW;
599  m_kwl->addPair( key.string(), tempString1 );
600  ++demIdx;
601  }
602
603  while( ap.read("--input-img", stringParam1) )
604  {
605  key = IMG_KW;
606  key += ossimString::toString(imgIdx);
607  key += ".";
608  key += FILE_KW;
609  m_kwl->addPair(key.string(), tempString1 );
610  ++imgIdx;
611  }
612
613  if( ap.read("--input-src", stringParam1) )
614  {
615  m_kwl->addPair( SRC_FILE_KW, tempString1 );
616  }
617
618  if( ap.read("--meters", stringParam1) )
619  {
620  m_kwl->addPair( METERS_KW, tempString1 );
621  }
622
623  if ( ap.read("-n") || ap.read("--north-up") )
624  {
625  m_kwl->addPair( NORTH_UP_KW, TRUE_KW);
626  }
627
628  if( ap.read("--op", stringParam1) )
629  {
630  m_kwl->addPair( OP_KW, tempString1 );
631  }
632
633  //---
634  // Deprecated: "--options-keyword-list"
635  //---
636  if( ap.read("--options", stringParam1) )
637  {
638  ossimFilename optionsKwl = tempString1;
639  if ( optionsKwl.exists() )
640  {
641  if ( m_kwl->addFile(optionsKwl) == false )
642  {
643  std::string errMsg = "ERROR could not open options keyword list file: ";
644  errMsg += optionsKwl.string();
645  throw ossimException(errMsg);
646  }
647  }
648  else
649  {
650  std::string errMsg = "ERROR options keyword list file does not exists: ";
651  errMsg += optionsKwl.string();
652  throw ossimException(errMsg);
653  }
654  }
655
656  if( ap.read("--origin-latitude", stringParam1) )
657  {
658  m_kwl->addPair( std::string(ossimKeywordNames::ORIGIN_LATITUDE_KW), tempString1 );
659  }
660
661  if(ap.read("--output-radiometry", stringParam1))
662  {
663  m_kwl->addPair( OUTPUT_RADIOMETRY_KW, tempString1 );
664  }
665
666  if ( ap.read("--pad-thumbnail", stringParam1) )
667  {
668  m_kwl->addPair( PAD_THUMBNAIL_KW, tempString1 );
669  }
670
671  if( ap.read("--projection", stringParam1) )
672  {
673  m_kwl->addPair( std::string(ossimKeywordNames::PROJECTION_KW), tempString1 );
674  }
675
676  if( ap.read("--resample-filter", stringParam1) )
677  {
678  m_kwl->addPair( RESAMPLER_FILTER_KW, tempString1 );
679  }
680
681  if ( ap.read("-r", stringParam1) || ap.read("--rotate", stringParam1) )
682  {
683  m_kwl->addPair( ROTATION_KW, tempString1 );
684  }
685
686  while (ap.read("--reader-prop", stringParam1))
687  {
688  key = READER_PROPERTY_KW;
689  key += ossimString::toString(readerPropIdx);
690  m_kwl->addPair(key.string(), tempString1 );
691  ++readerPropIdx;
692  }
693
694  if ( ap.read("--rrds", stringParam1) )
695  {
696  m_kwl->addPair( RRDS_KW, tempString1);
697  }
698
699  if ( ap.read("--scale-to-8-bit") )
700  {
701  m_kwl->addPair( SCALE_2_8_BIT_KW, TRUE_KW);
702  }
703
704  if ( ap.read("--sharpen-mode", stringParam1) )
705  {
706  m_kwl->addPair( SHARPEN_MODE_KW, tempString1 );
707  }
708
709  if ( ap.read("--snap-tie-to-origin") )
710  {
711  m_kwl->addPair( SNAP_TIE_TO_ORIGIN_KW, TRUE_KW);
712  }
713
714  if( ap.read("--srs", stringParam1) )
715  {
716  ossimString os = tempString1;
717  if ( os.contains("EPSG:") )
718  {
719  os.gsub( ossimString("EPSG:"), ossimString("") );
720  }
721  m_kwl->addPair( SRS_KW, os.string() );
722  }
723
724  if( ap.read("-t", stringParam1) || ap.read("--thumbnail", stringParam1) )
725  {
726  m_kwl->addPair( THUMBNAIL_RESOLUTION_KW, tempString1 );
727  }
728
729  if ( ap.read("--three-band-out") )
730  {
731  m_kwl->addPair( THREE_BAND_OUT_KW, TRUE_KW);
732  }
733
734  if( ap.read("--tile-size", stringParam1) )
735  {
736  m_kwl->addPair( TILE_SIZE_KW, tempString1 );
737  }
738
739  if ( ap.read("-u") || ap.read("--up-is-up") )
740  {
741  m_kwl->addPair( UP_IS_UP_KW, TRUE_KW);
742  }
743
744  if( ap.read("-w", stringParam1) || ap.read("--writer", stringParam1) )
745  {
746  m_kwl->addPair( WRITER_KW, tempString1);
747  }
748
749  while (ap.read("--writer-prop", stringParam1))
750  {
751  key = WRITER_PROPERTY_KW;
752  key += ossimString::toString(writerPropIdx);
753  m_kwl->addPair(key.string(), tempString1 );
754  ++writerPropIdx;
755  }
756
757  if( ap.read("--zone", stringParam1) )
758  {
759  m_kwl->addPair( std::string(ossimKeywordNames::ZONE_KW), tempString1);
760  }
761
762  if( ap.read("--2cmv-old-input-band", stringParam1) )
763  {
764  m_kwl->addPair( TWOCMV_OLD_INPUT_BAND_KW, tempString1 );
765  }
766
767  if( ap.read("--2cmv-new-input-band", stringParam1) )
768  {
769  m_kwl->addPair( TWOCMV_NEW_INPUT_BAND_KW, tempString1 );
770  }
771  if( ap.read("--2cmv-red-output-source", stringParam1) )
772  {
773  m_kwl->addPair( TWOCMV_RED_OUTPUT_SOURCE_KW, tempString1 );
774  }
775
776  if( ap.read("--2cmv-green-output-source", stringParam1) )
777  {
778  m_kwl->addPair( TWOCMV_GREEN_OUTPUT_SOURCE_KW, tempString1 );
779  }
780
781  if( ap.read("--2cmv-blue-output-source", stringParam1) )
782  {
783  m_kwl->addPair( TWOCMV_BLUE_OUTPUT_SOURCE_KW, tempString1 );
784  }
785  if(ap.read("--combiner-type", stringParam1))
786  {
787  m_kwl->addPair(COMBINER_TYPE_KW, tempString1);
788  }
789  // End of arg parsing.
791  if ( ap.errors() )
792  {
794  std::string errMsg = "Unknown option...";
795  throw ossimException(errMsg);
796  }
797
798  if ( ap.argc() >= 2 )
799  {
800  // Output file is last arg:
802  }
803  else
804  {
806  {
808  std::string errMsg = "Must supply an output file.";
809  throw ossimException(errMsg);
810  }
811  }
812
813  if ( ap.argc() > 2 ) // User passed inputs in front of output file.
814  {
815  int pos = 1; // ap.argv[0] is application name.
816  while ( pos < (ap.argc()-1) )
817  {
818  ossimFilename file = ap[pos];
819  if ( traceDebug() )
820  {
822  << "argv[" << pos << "]: " << file << "\n";
823  }
824
825  if ( isDemFile(file) )
826  {
827  key = DEM_KW;
828  key += ossimString::toString(demIdx);
829  key += ".";
830  key += FILE_KW;
831  m_kwl->addPair( key, file.string() );
832  ++demIdx;
833  }
834  else if ( isSrcFile(file) )
835  {
836  if ( m_kwl->find( SRC_FILE_KW.c_str() ) ) // --input-src used also
837  {
838  std::string errMsg = MODULE;
839  errMsg += "ERROR Multiple src files passed in. Please combine into one.";
840  throw ossimException(errMsg);
841  }
842
843  m_kwl->addPair( SRC_FILE_KW, file.string() );
844  }
845  else // Add as an input image.
846  {
847  key = IMG_KW;
848  key += ossimString::toString(imgIdx);
849  key += ".";
850  key += FILE_KW;
851  m_kwl->addPair(key.string(), file.string() );
852  ++imgIdx;
853  }
854
855  ++pos; // Go to next arg...
856
857  } // End: while ( pos < (ap.argc()-1) )
858
859  } // End: if ( ap.argc() > 2 )
860
861  initialize();
862
863  if ( traceDebug() )
864  {
865  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited..." << std::endl;
866  }
867  return true;
868
869 } // End: void ossimChipperUtil::initialize(ossimArgumentParser& ap)
static const char * PROJECTION_KW
static const char * CENTRAL_MERIDIAN_KW
bool addFile(const char *file)
bool read(const std::string &str)
search for an occurance of a string in the argument list, on sucess remove that occurance from the li...
bool contains(char aChar) const
Definition: ossimString.h:58
void addPair(const std::string &key, const std::string &value, bool overwrite=true)
int numberOfParams(const std::string &str, const ossimParameter value) const
void clear()
Disconnects and clears the dem and image layers.
void reportRemainingOptionsAsUnrecognized(ossimErrorSeverity severity=OSSIM_BENIGN)
for each remaining option report it as an unrecongnized.
bool errors(ossimErrorSeverity severity=OSSIM_BENIGN) const
bool exists() const
unsigned int ossim_uint32
ossimRefPtr< ossimKeywordlist > m_kwl
static const char * BANDS_KW
bool isSrcFile(const ossimFilename &file) const
static const char * ENTRY_KW
void usage(ossimArgumentParser &ap)
Initializes arg parser and outputs usage.
void initialize()
ossimString & gsub(const ossimString &searchKey, const ossimString &replacementValue, bool replaceAll=false)
Substitutes searchKey string with replacementValue and returns a reference to *this.
int & argc()
return the argument count.
bool isDemFile(const ossimFilename &file) const
void writeErrorMessages(std::ostream &output, ossimErrorSeverity sevrity=OSSIM_BENIGN)
write out error messages at an above specified .
const std::string & string() const
Definition: ossimString.h:414
◆ initialize() [2/3]
void ossimChipperUtil::initialize ( const ossimKeywordlist kwl)
Initialize method to be ran prior to execute.
Note
Definition at line 871 of file ossimChipperUtil.cpp.
References ossimKeywordlist::addList(), clear(), ossimKeywordlist::clear(), initialize(), and m_kwl.
872 {
873  clear();
874
875  // Start with clean options keyword list.
876  m_kwl->clear();
877
878  m_kwl->addList( kwl, true );
879
880  initialize();
881 }
void addList(const ossimKeywordlist &src, bool overwrite=true)
void clear()
void initialize()
◆ initialize() [3/3]
void ossimChipperUtil::initialize ( )
private
Note
Definition at line 883 of file ossimChipperUtil.cpp.
Referenced by initialize().
884 {
885  static const char MODULE[] = "ossimChipperUtil::initialize()";
886
887  if ( traceDebug() )
888  {
889  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
890  }
891
892  if ( traceOptions() )
893  {
894  ossimFilename optionsFile;
895  getOutputFilename(optionsFile);
896  optionsFile = optionsFile.noExtension();
897  optionsFile += "-options.kwl";
898  ossimString comment = " Can be use for --options argument.";
899  m_kwl->write( optionsFile.c_str(), comment.c_str() );
900  }
901
902  // Determine the operation to do.
903  std::string op = m_kwl->findKey( OP_KW );
904  if ( op.size() )
905  {
906  ossimString s = op;
907  s.downcase();
908
909  if ( s == "chip" )
910  {
912  }
913  else if ( s == "hillshade" )
914  {
916  }
917
918  else if ( s == "color-relief" )
919  {
921  }
922  else if ( s == "ortho" )
923  {
925  }
926  else if ( s == "psm" )
927  {
929  }
930  else if ( s == "2cmv" )
931  {
933  }
934  else
935  {
936  std::string errMsg = "unknown operation: ";
937  errMsg += s.string();
938  throw ossimException(errMsg);
939  }
940  }
941  else
942  {
943  std::string errMsg = "keyword not found: ";
944  errMsg += OP_KW;
945  errMsg += "\nUse --op option to specify operation.\n";
946  throw ossimException(errMsg);
947  }
948
949  //---
950  // Populate the m_srcKwl if --src option was set.
951  // Note do this before creating chains.
952  //---
954
955  // Check for required inputs. Do this after initializeSrcKwl.
957  {
958  if ( getNumberOfInputs() != 1 )
959  {
960  std::ostringstream errMsg;
961  errMsg << op << " operation takes one input.";
962  throw ossimException( errMsg.str() );
963  }
964  }
965
967  {
968  if ( getNumberOfInputs() != 2 )
969  {
970  std::ostringstream errMsg;
971  errMsg << op << " operation requires two inputs.";
972  throw ossimException( errMsg.str() );
973  }
974  }
975
976  // Sanity check rotation options.
977  if ( upIsUp() || northUp() || hasRotation() )
978  {
979  std::string option;
980  ossim_uint32 rotationOptionCount = 0;
981  if ( upIsUp() )
982  {
983  option = UP_IS_UP_KW;
984  ++rotationOptionCount;
985  }
986  if ( northUp() )
987  {
988  option = NORTH_UP_KW;
989  ++rotationOptionCount;
990  }
991  if ( hasRotation() )
992  {
993  option = ROTATION_KW;
994  ++rotationOptionCount;
995  }
996
997  // Can only do ONE rotation option.
998  if ( rotationOptionCount > 1 )
999  {
1000  std::ostringstream errMsg;
1001  if ( upIsUp() )
1002  {
1003  errMsg << UP_IS_UP_KW << " is on.\n";
1004  }
1005  if ( northUp() )
1006  {
1007  errMsg << NORTH_UP_KW << " is on.\n";
1008  }
1009  if ( hasRotation() )
1010  {
1011  errMsg << ROTATION_KW << " is on.\n";
1012  }
1013  errMsg << "Multiple rotation options do not make sense!";
1014  throw ossimException( errMsg.str() );
1015  }
1016
1017  // One input, chip operation only.
1018  if ( getNumberOfInputs() != 1 )
1019  {
1020  std::ostringstream errMsg;
1021  errMsg << option << " option takes one input.";
1022  throw ossimException( errMsg.str() );
1023  }
1024
1026  {
1027  std::ostringstream errMsg;
1028  errMsg << option << " option only valid with \"chip\" operation.";
1029  throw ossimException( errMsg.str() );
1030  }
1031  }
1032
1033  // Create chains for any dem sources.
1034  addDemSources();
1035
1036  // Create chains for any image sources.
1037  addImgSources();
1038
1039  // Initialize projection and propagate to chains.
1041
1042  if ( traceDebug() )
1043  {
1045  << "options keyword list:\n"
1046  << *(m_kwl.get()) << "\n";
1047
1048  if ( m_srcKwl.valid() )
1049  {
1051  << "support record keyword list:\n"
1052  << *(m_srcKwl.get()) << "\n";
1053  }
1054
1055  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited...\n";
1056  }
1057
1058 } // End: void ossimChipperUtil::initialize()
void getOutputFilename(ossimFilename &f) const
Gets the output file name.
ossimFilename noExtension() const
const std::string & findKey(const std::string &key) const
Find methods that take std::string(s).
bool valid() const
virtual bool write(const char *file, const char *comment=0) const
Methods to dump the ossimKeywordlist to a file on disk.
void initializeSrcKwl()
Initializes m_srcKwl if option was set.
bool hasRotation() const
ossim_uint32 getNumberOfInputs() const
void initializeOutputProjection()
Initializes the output projection and propagates to image chains.
void addImgSources()
Creates chains for all images.
const char * c_str() const
Definition: ossimString.h:396
void addDemSources()
Create chains for all dems.
◆ initialize2CmvChain()
ossimRefPtr< ossimImageSource > ossimChipperUtil::initialize2CmvChain ( )
private
Combines two images into a two color multi view chain.
Returns
ossimRefPtr with pointer to ossimImageSource. Can be null.
Definition at line 3743 of file ossimChipperUtil.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimRefPtr< T >::get(), m_demLayer, m_imgLayer, ossimTwoColorView::NEW, ossimTwoColorView::OLD, and ossimRefPtr< T >::valid().
3744 {
3745  ossimRefPtr<ossimImageSource> result = 0;
3746
3747  ossim_uint32 layerCount = (ossim_uint32) (m_demLayer.size() + m_imgLayer.size());
3748
3749  // Must have two and only two inputs.
3750  if ( layerCount == 2 )
3751  {
3754
3755  //---
3756  // Expecting two image layers. We'll code it for flexabilty though...
3757  // - Take old and new from m_imgLayer if present.
3758  // - Use m_demLayer only if missing.
3759  // - Using first image found as old, second new.
3760  //---
3761
3762  // Most likely case, two image layers.
3763  if ( m_imgLayer.size() )
3764  {
3765  oldImg = m_imgLayer[0].get();
3766
3767  if ( m_imgLayer.size() == 2 )
3768  {
3769  newImg = m_imgLayer[1].get();
3770  }
3771  }
3772
3773  if ( m_demLayer.size() )
3774  {
3775  if ( !oldImg.valid() )
3776  {
3777  oldImg = m_demLayer[0].get();
3778  }
3779
3780  if ( !newImg.valid() )
3781  {
3782  if ( m_demLayer.size() == 1 )
3783  {
3784  newImg = m_demLayer[0].get();
3785  }
3786  else if ( m_demLayer.size() == 2 )
3787  {
3788  newImg = m_demLayer[1].get();
3789  }
3790  }
3791  }
3792
3793  if ( newImg.valid() && oldImg.valid() )
3794  {
3795  // Input 0 is old, 1 is new.
3797  tcmv->connectMyInputTo( 0, oldImg.get() );
3798  tcmv->connectMyInputTo( 1, newImg.get() );
3799
3800  // Look for 2cmv options.
3801  ossim_uint32 oldInputBandIndex = 0;
3802  ossim_uint32 newInputBandIndex = 0;
3809
3810  ossimString os;
3811  std::string key = TWOCMV_OLD_INPUT_BAND_KW;
3812  std::string val = m_kwl->findKey( key );
3813
3814  if ( val.size() )
3815  {
3816  os = val;
3817  oldInputBandIndex = os.toUInt32();
3818  }
3819
3820  key = TWOCMV_NEW_INPUT_BAND_KW;
3821  val = m_kwl->findKey( key );
3822  if ( val.size() )
3823  {
3824  os = val;
3825  newInputBandIndex = os.toUInt32();
3826  }
3827
3828  key = TWOCMV_RED_OUTPUT_SOURCE_KW;
3829  val = m_kwl->findKey( key );
3830  if ( val.size() )
3831  {
3832  os = val;
3833  os.downcase();
3834
3835  if ( os == "new" )
3836  {
3837  redOutputSource = ossimTwoColorView::NEW;
3838  }
3839  else if ( os == "MIN" )
3840  {
3841  redOutputSource = ossimTwoColorView::MIN;
3842  }
3843  }
3844
3845  key = TWOCMV_GREEN_OUTPUT_SOURCE_KW;
3846  val = m_kwl->findKey( key );
3847  if ( val.size() )
3848  {
3849  os = val;
3850  os.downcase();
3851
3852  if ( os == "old" )
3853  {
3854  grnOutputSource = ossimTwoColorView::OLD;
3855  }
3856  else if ( os == "MIN" )
3857  {
3858  grnOutputSource = ossimTwoColorView::MIN;
3859  }
3860  }
3861
3862  key = TWOCMV_BLUE_OUTPUT_SOURCE_KW;
3863  val = m_kwl->findKey( key );
3864  if ( val.size() )
3865  {
3866  os = val;
3867  os.downcase();
3868
3869  if ( os == "old" )
3870  {
3871  bluOutputSource = ossimTwoColorView::OLD;
3872  }
3873  else if ( os == "MIN" )
3874  {
3875  bluOutputSource = ossimTwoColorView::MIN;
3876  }
3877  }
3878
3879  // Set options.
3880  tcmv->setBandIndexMapping( oldInputBandIndex,
3881  newInputBandIndex,
3882  redOutputSource,
3883  grnOutputSource,
3884  bluOutputSource );
3885  tcmv->initialize();
3886
3887  result = tcmv.get();
3888  }
3889  }
3890
3891  return result;
3892
3893 } // ossimChipperUtil::initialize2CmvChain()
virtual void initialize()
This is a 2 color view of the input.
bool valid() const
void setBandIndexMapping(ossim_uint32 oldInputBandIndex, ossim_uint32 newInputBandIndex, ossimTwoColorMultiViewOutputSource redOutputSource, ossimTwoColorMultiViewOutputSource grnOutputSource, ossimTwoColorMultiViewOutputSource bluOutputSource)
Sets which bands to use from inputs, and which inputs to use for output red, green and blue channels...
std::vector< ossimRefPtr< ossimSingleImageChain > > m_imgLayer
Array of image source chains.
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
Enumerations for mapping inputs to red, green and blue output channels.
std::vector< ossimRefPtr< ossimSingleImageChain > > m_demLayer
Array of dem chains.
◆ initializeBumpShadeChain()
ossimRefPtr< ossimImageSource > ossimChipperUtil::initializeBumpShadeChain ( )
private
Initializes a bump shade chain.
Returns
Ref pointer to image chain.
Definition at line 1184 of file ossimChipperUtil.cpp.
1185 {
1186  static const char MODULE[] = "ossimChipperUtil::initializeBumpShadeChain";
1187  if ( traceDebug() )
1188  {
1189  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
1190  }
1191
1192  ossimString lookup;
1193  ossimRefPtr<ossimImageSource> source = 0;
1194
1195  // Combine the dems.
1197
1198  // Set up the normal source.
1200
1201  //---
1202  // Set the track scale flag to true. This enables scaling the surface
1203  // normals by the GSD in order to maintain terrain proportions.
1204  //---
1205  normSource->setTrackScaleFlag(true);
1206
1207  // Connect to dems.
1208  normSource->connectMyInputTo( demSource.get() );
1209
1210  // Set the smoothness factor.
1211  ossim_float64 gain = 1.0;
1212  lookup = m_kwl->findKey( GAIN_KW );
1213  if ( lookup.size() )
1214  {
1215  gain = lookup.toFloat64();
1216  }
1217  normSource->setSmoothnessFactor(gain);
1218
1219  ossimRefPtr<ossimImageSource> colorSource = 0;
1220  if ( hasLutFile() )
1221  {
1222  if ( m_imgLayer.size() )
1223  {
1225  << MODULE << " WARNING:"
1226  << "\nBoth a color table and image(s) have been provided for a color source.\n"
1227  << "Choosing color table of image(s).\n";
1228  }
1229
1230  colorSource = addIndexToRgbLutFilter( demSource );
1231  }
1232  else
1233  {
1234  // Combine the images and set as color source for bump shade.
1235  colorSource = combineLayers( m_imgLayer );
1236  }
1237
1238  // Create the bump shade.
1240
1241  // Set the azimuth angle.
1242  ossim_float64 azimuthAngle = 180;
1244  if ( lookup.size() )
1245  {
1246  ossim_float64 f = lookup.toFloat64();
1247  if ( (f >= 0) && (f <= 360) )
1248  {
1249  azimuthAngle = f;
1250  }
1251  }
1252  bumpShade->setAzimuthAngle(azimuthAngle);
1253
1254  // Set the elevation angle.
1255  ossim_float64 elevationAngle = 45.0;
1257  if ( lookup.size() )
1258  {
1259  ossim_float64 f = lookup.toFloat64();
1260  if ( (f >= 0.0) && (f <= 90) )
1261  {
1262  elevationAngle = f;
1263  }
1264  }
1265  bumpShade->setElevationAngle(elevationAngle);
1266
1267  if ( !hasLutFile() )
1268  {
1269  // Set the color.
1270  ossim_uint8 r = 0xff;
1271  ossim_uint8 g = 0xff;
1272  ossim_uint8 b = 0xff;
1273  lookup = m_kwl->findKey( COLOR_RED_KW );
1274  if ( lookup.size() )
1275  {
1276  r = lookup.toUInt8();
1277  }
1278  lookup = m_kwl->findKey( COLOR_GREEN_KW );
1279  if ( lookup.size() )
1280  {
1281  g = lookup.toUInt8();
1282  }
1283  lookup = m_kwl->findKey( COLOR_BLUE_KW );
1284  if ( lookup.size() )
1285  {
1286  b = lookup.toUInt8();
1287  }
1288  bumpShade->setRgbColorSource(r, g, b);
1289  }
1290
1291  // Connect the two sources.
1292  bumpShade->connectMyInputTo(0, normSource.get());
1293  bumpShade->connectMyInputTo(1, colorSource.get());
1294
1295  if ( traceDebug() )
1296  {
1297  ossim_uint8 r = 0xff;
1298  ossim_uint8 g = 0xff;
1299  ossim_uint8 b = 0xff;
1300  bumpShade->getRgbColorSource(r, g, b);
1302  << "\nazimuthAngle: " << azimuthAngle
1303  << "\nelevation angle: " << elevationAngle
1304  << "\ngain factor: " << gain
1305  << "\nr: " << int(r)
1306  << "\ng: " << int(g)
1307  << "\nb: " << int(b)
1308  << "\n";
1309  }
1310
1311  // Capture the pointer to give to the writer.
1312  source = bumpShade.get();
1313
1314  return source;
1315
1316 } // End: ossimChipperUtil::initializeBumpShadeChain()
ossimRefPtr< ossimImageSource > addIndexToRgbLutFilter(ossimRefPtr< ossimImageSource > &source) const
Creates ossimIndexToRgbLutFilter and connects to source.
This uses a derivative of Blinn&#39;s bump function to compute a 3-D looking image.
ossim_uint8 toUInt8() const
virtual void setElevationAngle(double angle)
double ossim_float64
ossimRefPtr< ossimImageSource > combineLayers()
Combines dems(m_demLayer) and images(m_imgLayer).
void getRgbColorSource(ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const
Gets the red, green and blue color source values.
void setRgbColorSource(ossim_uint8 r, ossim_uint8 g, ossim_uint8 b)
Set the red, green and blue color source values.
ossim_float64 toFloat64() const
virtual void setAzimuthAngle(double angle)
unsigned char ossim_uint8
◆ initializeChain()
ossimRefPtr< ossimImageSource > ossimChipperUtil::initializeChain ( ossimIrect aoi)
private
Builds image chains returns ref pointer to image source and initializes area of interest(aoi).
Returns
Definition at line 1060 of file ossimChipperUtil.cpp.
Referenced by getChip().
1061 {
1062  static const char MODULE[] = "ossimChipperUtil::initializeChain";
1063  if ( traceDebug() )
1064  {
1065  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
1066  }
1067
1068  ossimString lookup; // used throughout...
1069
1070  ossimRefPtr<ossimImageSource> source = 0;
1071
1072  if ( hasBumpShadeArg() )
1073  {
1074  // Create chain:
1075  source = initializeBumpShadeChain();
1076  }
1078  {
1079  source = initializeColorReliefChain();
1080  }
1081  else if ( ( m_operation == OSSIM_CHIPPER_OP_CHIP ) ||
1083  {
1084  source = combineLayers();
1085  }
1086  else if ( m_operation == OSSIM_CHIPPER_OP_2CMV )
1087  {
1088  source = initialize2CmvChain(); // Two Color Multiview.
1089  }
1090  else if ( m_operation == OSSIM_CHIPPER_OP_PSM )
1091  {
1092  source = initializePsmChain(); // Pan sharpened multispectral.
1093  }
1094
1095  if ( source.valid() )
1096  {
1097  //---
1098  // This is conditional. Output radiometry may of may not be set. This can also be set at
1099  // the ossimSingleImageChain level.
1100  //---
1102  ( source->getOutputScalarType() != getOutputScalarType() ) )
1103  {
1104  source = addScalarRemapper( source, getOutputScalarType() );
1105  }
1106
1107  //---
1108  // Get the area of interest. This will be the scene bounding rect if not
1109  // explicitly set by user with one of the --cut options.
1110  // Need to get this before the thumbnail code.
1111  //---
1112  getAreaOfInterest(source.get(), aoi);
1113
1114  //---
1115  // Set the image size here. Note must be set after combineLayers. This is needed for
1116  // the ossimImageGeometry::worldToLocal call for a geographic projection to handle wrapping
1117  // accross the date line.
1118  //---
1119  if(m_geom.valid())
1120  {
1121  m_geom->setImageSize( aoi.size() );
1122  }
1123
1124  if ( hasThumbnailResolution() )
1125  {
1126  //---
1127  // Adjust the projection scale and get the new rect.
1128  // Note this will resize the ossimImageGeometry::m_imageSize is scale changes.
1129  //---
1130  initializeThumbnailProjection( aoi, aoi );
1131
1132  // Reset the source bounding rect if it changed.
1133  source->initialize();
1134  }
1135
1136  if ( source.valid() && !aoi.hasNans() )
1137  {
1138  //---
1139  // Add a cut filter. This will:
1140  // 1) Null out/clip any data pulled in.
1141  // 2) Speed up by not propagating get tile request outside the cut or "aoi"
1142  // to the left hand side(input).
1143  //---
1145
1146  // Set the cut rectangle:
1147  cutter->setRectangle( aoi );
1148
1149  // Null outside.
1151
1152  // Connect cutter input to source chain.
1153  cutter->connectMyInputTo( 0, source.get() );
1154
1155  source = cutter.get();
1156
1157  // Dependent on correct aoi so place after the cutter.
1158  if ( hasAnnotations() )
1159  {
1160  // Put annotations after scalar remapper.
1161  ossimRefPtr<ossimImageSource> result = addAnnotations( source );
1162  if ( result.valid() )
1163  {
1164  source = result.get();
1165  }
1166  }
1167  }
1168  }
1169
1170  if ( traceDebug() )
1171  {
1172  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited...\n";
1173  }
1174
1175  return source;
1176 }
void setRectangle(const ossimIrect &rect)
bool hasAnnotations() const
ossimRefPtr< ossimImageSource > addScalarRemapper(ossimRefPtr< ossimImageSource > &source, ossimScalarType scalar) const
Creates ossimScalarRemapper and connects to source.
ossimRefPtr< ossimImageSource > initializeColorReliefChain()
Initializes a color relief chain.
bool valid() const
ossimRefPtr< ossimImageSource > initializeBumpShadeChain()
bool hasBumpShadeArg() const
ossimRefPtr< ossimImageSource > initializePsmChain()
Initializes a psm (pan sharpening multispectra) chain.
void setImageSize(const ossimIpt &size)
ossimRefPtr< ossimImageSource > addAnnotations(ossimRefPtr< ossimImageSource > &source) const
Add annotation source to chain.
ossimIpt size() const
Definition: ossimIrect.h:510
void setCutType(ossimRectangleCutType cutType)
bool hasThumbnailResolution() const
void getAreaOfInterest(ossimImageSource *source, ossimIrect &rect) const
Initializes "rect" with the output area of interest.
ossimRefPtr< ossimImageGeometry > m_geom
The image geometry.
ossimScalarType getOutputScalarType() const
void initializeThumbnailProjection(const ossimIrect &originalRect, ossimIrect &adjustedRect)
Method to calculate and initialize scale and area of interest for making a thumbnail.
ossimRefPtr< ossimImageSource > initialize2CmvChain()
bool hasNans() const
Definition: ossimIrect.h:337
virtual void initialize()=0
◆ initializeColorReliefChain()
ossimRefPtr< ossimImageSource > ossimChipperUtil::initializeColorReliefChain ( )
private
Returns
Definition at line 1318 of file ossimChipperUtil.cpp.
References addIndexToRgbLutFilter(), addScalarRemapper(), combineLayers(), ossimImageSource::getOutputScalarType(), hasLutFile(), and OSSIM_UINT8.
1319 {
1321  if ( hasLutFile() )
1322  {
1323  result = addIndexToRgbLutFilter( result );
1324  }
1325  else
1326  {
1327  // No LUT file provided, so doing the default 8-bit linear stretch:
1328  if ( result->getOutputScalarType() != OSSIM_UINT8 )
1329  {
1330  result = addScalarRemapper( result, OSSIM_UINT8 );
1331  }
1332  }
1333  return result;
1334 }
◆ initializeIvtScale()
void ossimChipperUtil::initializeIvtScale ( )
private
Initializes the image view transform(IVT) scale.
Chip mode only. Sets IVT scale to output / input.
Note
Throws ossimException on error.
Definition at line 2396 of file ossimChipperUtil.cpp.
References ossimKeywordlist::findKey(), isChipMode(), m_geom, m_ivt, m_kwl, ossimDpt::makeNan(), ossimString::string(), and ossimRefPtr< T >::valid().
2397 {
2398  if ( isChipMode() && m_ivt.valid() && m_geom.valid() )
2399  {
2400  ossimDpt scale;
2401  scale.makeNan();
2402
2403  // Check for GSD spec. Degrees/pixel takes priority over meters/pixel:
2404  ossimString lookup;
2405  lookup.string() = m_kwl->findKey( DEGREES_X_KW );
2406  if ( lookup.size() )
2407  {
2408  ossimDpt outputDpp;
2409  outputDpp.makeNan();
2410
2411  outputDpp.x = lookup.toFloat64();
2412
2413  lookup.string() = m_kwl->findKey( DEGREES_Y_KW );
2414  if ( lookup.size() )
2415  {
2416  outputDpp.y = lookup.toFloat64();
2417  }
2418
2419  if ( !outputDpp.hasNans() )
2420  {
2421  // Input degress per pixel. Consider this a scale of 1.0.
2422  ossimDpt inputDpp;
2423  m_geom->getDegreesPerPixel( inputDpp );
2424
2425  if ( !inputDpp.hasNans() )
2426  {
2427  scale.x = inputDpp.x/outputDpp.x;
2428  scale.y = inputDpp.y/outputDpp.y;
2429  }
2430  }
2431  }
2432
2433  if ( scale.hasNans() )
2434  {
2435  lookup = m_kwl->findKey( METERS_KW );
2436  if ( lookup.size() )
2437  {
2438  ossimDpt outputMpp;
2439  outputMpp.makeNan();
2440  outputMpp.x = lookup.toFloat64();
2441  outputMpp.y = outputMpp.x;
2442
2443  if ( !outputMpp.hasNans() )
2444  {
2445  // Input meters per pixel. Consider this a scale of 1.0.
2446  ossimDpt inputMpp;
2447  m_geom->getMetersPerPixel( inputMpp );
2448
2449  if ( !inputMpp.hasNans() )
2450  {
2451  scale.x = inputMpp.x/outputMpp.x;
2452  scale.y = inputMpp.y/outputMpp.y;
2453  }
2454  }
2455  }
2456  }
2457
2458  if ( scale.hasNans() )
2459  {
2460  lookup = m_kwl->findKey( RRDS_KW );
2461  if ( lookup.size() )
2462  {
2463  ossim_float64 d = lookup.toInt32();
2464  if ( d == 0.0 )
2465  {
2466  scale.x = 1.0;
2467  }
2468  else
2469  {
2470  scale.x = 1.0 / std::pow(2.0, d);
2471  }
2472  scale.y = scale.x;
2473  }
2474  }
2475
2476  if ( !scale.hasNans() )
2477  {
2478  m_ivt->scale( scale.x, scale.y );
2479  }
2480  else
2481  {
2482  std::string errMsg = "ossimChipperUtil::initializeIvtScale failed!";
2483  throw ossimException(errMsg);
2484  }
2485
2486  } // Matches: if ( isChipMode() && ... )
2487
2488 } // End: ossimChipperUtil::initializeIvtScale()
bool valid() const
double y
Definition: ossimDpt.h:165
ossimDpt getDegreesPerPixel() const
Returns the resolution of this image in degrees/pixel.
ossim_int32 toInt32() const
std::string::size_type size() const
Definition: ossimString.h:405
ossimDpt getMetersPerPixel() const
Returns the GSD associated with this image in the active projection.
Definition: ossimDpt.h:67
The image geometry.
ossimRefPtr< ossimImageViewAffineTransform > m_ivt
Image view transform(IVT).
double x
Definition: ossimDpt.h:164
virtual void scale(double x, double y)
void makeNan()
Definition: ossimDpt.h:65
◆ initializeOutputProjection()
void ossimChipperUtil::initializeOutputProjection ( )
private
Note
Definition at line 1417 of file ossimChipperUtil.cpp.
References createIdentityProjection(), createOutputProjection(), isChipMode(), and propagateOutputProjectionToChains().
1418 {
1419  if ( isChipMode() )
1420  {
1422  }
1423  else
1424  {
1425  // Create the output projection.
1427
1428  // Setup the view in all the chains.
1430  }
1431 }
void propagateOutputProjectionToChains()
loops through all chains and sets the output projection.
void createIdentityProjection()
Sets the single image chain for identity operations view to a ossimImageViewAffineTransform.
void createOutputProjection()
Creates the output or view projection.
◆ initializeProjectionGsd()
void ossimChipperUtil::initializeProjectionGsd ( )
private
Initializes the projection gsd.
This loops through all chains to find the best resolution gsd.
Note
Definition at line 2583 of file ossimChipperUtil.cpp.
2584 {
2585  static const char MODULE[] = "ossimChipperUtil::initializeProjectionGsd()";
2586  if ( traceDebug() )
2587  {
2588  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
2589  }
2590
2592  if ( !mapProj.valid() )
2593  {
2594  std::string errMsg = MODULE;
2595  errMsg += " projection is null!";
2596  throw( ossimException(errMsg) );
2597  }
2598
2599  ossimDpt gsd;
2600  gsd.makeNan();
2601
2602  ossimString degreesX;
2603  ossimString degreesY;
2604  ossimString meters;
2605  degreesX.string() = m_kwl->findKey( DEGREES_X_KW );
2606  degreesY.string() = m_kwl->findKey( DEGREES_Y_KW );
2607  meters.string() = m_kwl->findKey( METERS_KW );
2608
2609  if ( hasCutBoxWidthHeight() )
2610  {
2611  // --cut-bbox-llwh Implies a scale...
2612  if ( degreesX.size() || degreesY.size() || meters.size() )
2613  {
2614  std::ostringstream errMsg;
2615  errMsg << MODULE << " ERROR: Ambiguous scale keywords!\n"
2616  << "Do not combine meters or degrees with cut box with a width and height.\n";
2617  throw( ossimException( errMsg.str() ) );
2618  }
2619
2620  ossimString cutMinLat;
2621  ossimString cutMinLon;
2622  ossimString cutMaxLat;
2623  ossimString cutMaxLon;
2624  ossimString cutWidth;
2625  ossimString cutHeight;
2626  cutMinLat.string() = m_kwl->findKey( CUT_MIN_LAT_KW );
2627  cutMinLon.string() = m_kwl->findKey( CUT_MIN_LON_KW );
2628  cutMaxLat.string() = m_kwl->findKey( CUT_MAX_LAT_KW );
2629  cutMaxLon.string() = m_kwl->findKey( CUT_MAX_LON_KW );
2630  cutWidth.string() = m_kwl->findKey( CUT_WIDTH_KW );
2631  cutHeight.string() = m_kwl->findKey( CUT_HEIGHT_KW );
2632  if ( cutMinLat.size() && cutMinLon.size() && cutMaxLat.size() &&
2633  cutMaxLon.size() && cutWidth.size() && cutHeight.size() )
2634  {
2635  ossim_float64 minLat = cutMinLat.toFloat64();
2636  ossim_float64 minLon = cutMinLon.toFloat64();
2637  ossim_float64 maxLat = cutMaxLat.toFloat64();
2638  ossim_float64 maxLon = cutMaxLon.toFloat64();
2639  ossim_float64 width = cutWidth.toFloat64();
2640  ossim_float64 height = cutHeight.toFloat64();
2641  if ( !ossim::isnan(minLat) && !ossim::isnan(minLon) && !ossim::isnan(maxLat) &&
2642  !ossim::isnan(maxLon) && !ossim::isnan(width) && !ossim::isnan(height) )
2643  {
2644  gsd.x = std::fabs( maxLon - minLon ) / width;
2645  gsd.y = std::fabs( maxLat - minLat ) / height;
2646
2647  mapProj->setDecimalDegreesPerPixel(gsd);
2648  }
2649  }
2650  }
2651  else if(hasWmsBboxCutWidthHeight())
2652  {
2653  ossimString cutWidth;
2654  ossimString cutHeight;
2655  ossimString cutWmsBbox;
2656
2657  cutWidth.string() = m_kwl->findKey( CUT_WIDTH_KW );
2658  cutHeight.string() = m_kwl->findKey( CUT_HEIGHT_KW );
2659  cutWmsBbox.string() = m_kwl->findKey( CUT_WMS_BBOX_KW );
2660
2661  cutWmsBbox = cutWmsBbox.upcase().replaceAllThatMatch("BBOX:","");
2662  std::vector<ossimString> cutBox = cutWmsBbox.split(",");
2663  if(cutBox.size()==4)
2664  {
2665  ossim_float64 minx = cutBox[0].toFloat64();
2666  ossim_float64 miny = cutBox[1].toFloat64();
2667  ossim_float64 maxx = cutBox[2].toFloat64();
2668  ossim_float64 maxy = cutBox[3].toFloat64();
2669  ossim_float64 width = cutWidth.toFloat64();
2670  ossim_float64 height = cutHeight.toFloat64();
2671  gsd.x = std::fabs( maxx - minx ) / width;
2672  gsd.y = std::fabs( maxy - miny ) / height;
2673
2674  // bbox is in the units of the projector
2675  if(mapProj->isGeographic())
2676  {
2677
2678  mapProj->setDecimalDegreesPerPixel(gsd);
2679  }
2680  else
2681  {
2682  mapProj->setMetersPerPixel(gsd);
2683  }
2684  }
2685  else
2686  {
2687  std::ostringstream errMsg;
2688  errMsg << MODULE << " ERROR: cut box does not have 4 values!\n";
2689  throw( ossimException( errMsg.str() ) );
2690  }
2691  }
2692  else
2693  {
2694  if ( meters.size() && ( degreesX.size() || degreesY.size() ) )
2695  {
2696  std::ostringstream errMsg;
2697  errMsg << MODULE << " ERROR: Ambiguous scale keywords!\n"
2698  << "Do not combine meters with degrees.\n";
2699  throw( ossimException( errMsg.str() ) );
2700  }
2701
2702  if ( degreesX.size() )
2703  {
2704  // --degrees
2705  gsd.x = degreesX.toFloat64();
2706
2707  if ( degreesY.size() )
2708  {
2709  gsd.y = degreesY.toFloat64();
2710  }
2711  if ( !gsd.hasNans() )
2712  {
2713  mapProj->setDecimalDegreesPerPixel(gsd);
2714  }
2715  }
2716  else if ( meters.size() )
2717  {
2718  // --meters
2719  gsd.x = meters.toFloat64();
2720  gsd.y = gsd.x;
2721  if ( !gsd.hasNans() )
2722  {
2723  mapProj->setMetersPerPixel(gsd);
2724  }
2725  }
2726  }
2727
2728  if ( gsd.hasNans() )
2729  {
2730  // Get the best resolution from the inputs.
2731  getMetersPerPixel(gsd);
2732
2733  // See if the output projection is geo-scaled; if so, make the pixels square in meters.
2735  {
2736  // Pick the best resolution and make them both the same.
2737  gsd.x = ossim::min<ossim_float64>(gsd.x, gsd.y);
2738  gsd.y = gsd.x;
2739  }
2740
2741  // Set to input gsd.
2742  mapProj->setMetersPerPixel(gsd);
2743  }
2744
2745  if ( traceDebug() )
2746  {
2748  << "projection gsd: " << gsd << "\n" << MODULE << " exited...\n";
2749  }
2750 }
ossimRefPtr< ossimMapProjection > getMapProjection()
Convenience method to get a pointer to the output map projection.
void getMetersPerPixel(ossimDpt &gsd)
Loops through all layers to get the best gsd.
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
bool valid() const
double y
virtual bool isGeographic() const
virtual void setDecimalDegreesPerPixel(const ossimDpt &gsd)
virtual void setMetersPerPixel(const ossimDpt &gsd)
ossimString replaceAllThatMatch(const char *regularExpressionPattern, const char *value="") const
ossimChipperOutputProjection getOutputProjectionType() const
Gets the emumerated output projection type.
double x
void makeNan()
bool isnan(const float &v)
Definition: ossimCommon.h:91
ossim_float64 min< ossim_float64 >(ossim_float64 a, ossim_float64 b)
Definition: ossimCommon.h:223
◆ initializePsmChain()
ossimRefPtr< ossimImageSource > ossimChipperUtil::initializePsmChain ( )
private
Returns
Definition at line 1336 of file ossimChipperUtil.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimRefPtr< T >::get(), ossimImageSource::getNumberOfOutputBands(), ossimFusionCombiner::initialize(), m_demLayer, m_imgLayer, ossimSingleImageChain::setBandSelection(), and ossimRefPtr< T >::valid().
1337 {
1338  ossimRefPtr<ossimImageSource> result = 0;
1339
1340  ossim_uint32 layerCount = (ossim_uint32) (m_demLayer.size() + m_imgLayer.size());
1341
1342  // Must have two and only two inputs.
1343  if ( layerCount == 2 )
1344  {
1345  ossimRefPtr<ossimSingleImageChain> input1 = 0; // First input should be color.
1346  ossimRefPtr<ossimSingleImageChain> input2 = 0; // Second input should be pan.
1347
1348  // Most likely case, two image layers.
1349  if ( m_imgLayer.size() )
1350  {
1351  input1 = m_imgLayer[0].get();
1352
1353  if ( m_imgLayer.size() == 2 )
1354  {
1355  input2 = m_imgLayer[1].get();
1356  }
1357  }
1358
1359  if ( m_demLayer.size() )
1360  {
1361  if ( !input1.valid() )
1362  {
1363  input1 = m_demLayer[0].get();
1364  }
1365
1366  if ( !input2.valid() )
1367  {
1368  if ( m_demLayer.size() == 1 )
1369  {
1370  input2 = m_demLayer[0].get();
1371  }
1372  else if ( m_demLayer.size() == 2 )
1373  {
1374  input2 = m_demLayer[1].get();
1375  }
1376  }
1377  }
1378
1379  if ( input1.valid() && input2.valid() )
1380  {
1381  // Make the color input the first connection to the combiner.
1382  if ( input1->getNumberOfOutputBands() == 1 )
1383  {
1384  // Swap:
1385  ossimRefPtr<ossimSingleImageChain> tmpChain = input1;
1386  input1 = input2;
1387  input2 = tmpChain;
1388  }
1389
1390  //---
1391  // Check the pan source for one band:
1392  // This really shouldn't happen, i.e. caller should typically pass a
1393  // one band pan image that is higher resolution than the color source.
1394  //---
1395  if ( input2->getNumberOfOutputBands() > 1 )
1396  {
1397  // Note this will add a band selector if there isn't one in chain.
1398  std::vector<ossim_uint32> bandList(1);
1399  bandList[0] = 0;
1400  input2->setBandSelection( bandList );
1401  }
1402
1403  // TODO: Make dynamic by type.
1405  psm->connectMyInputTo(0, input1.get());
1406  psm->connectMyInputTo(1, input2.get());
1407  psm->initialize();
1408  result = dynamic_cast<ossimImageSource*>(psm.get());
1409  }
1410
1411  } // Matches: if ( layerCount == 2 )
1412
1413  return result;
1414
1415 } // End: ossimChipperUtil::initializePsmChain()
bool valid() const
This class imlements the fusion algorithm from the paper:
void setBandSelection(const std::vector< ossim_uint32 > &bandList)
method to set band selector.
◆ initializeSrcKwl()
void ossimChipperUtil::initializeSrcKwl ( )
private
Definition at line 5476 of file ossimChipperUtil.cpp.
5477 {
5478  static const char MODULE[] = "ossimChipperUtil::initializeSrcKwl";
5479  if ( traceDebug() )
5480  {
5482  << MODULE << " entered...\n";
5483  }
5484
5485  std::string value = m_kwl->findKey(std::string(SRC_FILE_KW));
5486  if ( value.size() )
5487  {
5488  m_srcKwl = new ossimKeywordlist();
5490  if ( m_srcKwl->addFile( value.c_str() ) == false )
5491  {
5492  m_srcKwl = 0;
5493  }
5494  }
5495  else
5496  {
5497  m_srcKwl = 0;
5498  }
5499
5500  if ( traceDebug() )
5501  {
5502  if ( m_srcKwl.valid() )
5503  {
5505  << "src keyword list:\n" << *(m_srcKwl.get()) << "\n";
5506  }
5508  << MODULE << " exited...\n";
5509  }
5510 }
bool valid() const
ossimRefPtr< ossimKeywordlist > m_srcKwl
Hold contents of src file if –src is used.
void setExpandEnvVarsFlag(bool flag)
◆ initializeThumbnailProjection()
void ossimChipperUtil::initializeThumbnailProjection ( const ossimIrect originalRect,
ossimIrect adjustedRect
private
Sets the scale of the output projection so that the adjusted rectangle meets the cut rect and demension requirements set in options.
Parameters
originalRectOriginal scene area of interest.
adjustedRectNew rect for thumbnail.
Note
Definition at line 4814 of file ossimChipperUtil.cpp.
4816 {
4817  static const char MODULE[] = "ossimChipperUtil::initializeThumbnailProjection";
4818  if ( traceDebug() )
4819  {
4821  << MODULE << " entered...\n"
4822  << "origial rect: " << originalRect << "\n";
4823
4824  if (m_geom.valid())
4825  {
4827  }
4828  }
4829
4830  if ( !originalRect.hasNans() && m_geom.valid() )
4831  {
4832  //---
4833  // Thumbnail setup:
4834  //---
4835  ossimString thumbRes = m_kwl->findKey( THUMBNAIL_RESOLUTION_KW );
4836  if ( thumbRes.size() )
4837  {
4838  ossim_float64 thumbSize = thumbRes.toFloat64();
4839  ossim_float64 maxRectDimension =
4840  ossim::max( originalRect.width(), originalRect.height() );
4841  ossim_uint32 tw = originalRect.width();
4842  ossim_uint32 th = originalRect.height();
4843  ossim_float64 scale = 1.0;
4844  if ( maxRectDimension > thumbSize )
4845  {
4846  // Need to adjust scale:
4847
4848  // Get the corners before the scale change:
4849  ossimGpt ulGpt;
4850  ossimGpt lrGpt;
4851
4852  m_geom->localToWorld(ossimDpt(originalRect.ul()), ulGpt);
4853  m_geom->localToWorld(ossimDpt(originalRect.lr()), lrGpt);
4854
4855  if ( isChipMode() && m_ivt.valid() ) // Chipping in image space.)
4856  {
4857  scale = thumbSize / maxRectDimension;
4858  if ( m_ivt->getScale().hasNans() )
4859  {
4860  m_ivt->scale( scale, scale );
4861  }
4862  else
4863  {
4864  m_ivt->scale( m_ivt->getScale().x*scale,m_ivt->getScale().y*scale );
4865  }
4866  }
4867  else
4868  {
4869  scale = maxRectDimension / thumbSize;
4870
4871  //---
4872  // Adjust the projection scale. Note the "true" is to recenter
4873  // the tie point so it falls relative to the projection origin.
4874  //
4875  // This call also scales: ossimImageGeometry::m_imageSize
4876  //---
4877  m_geom->applyScale(ossimDpt(scale, scale), true);
4878  }
4879  tw *= scale;
4880  th *= scale;
4881  if(tw < 1) tw = 1;
4882  if(th < 1) th = 1;
4883  // Must call to reset the ossimImageRenderer's bounding rect for each input.
4885
4886  // Get the new upper left in view space.
4887  ossimDpt dpt;
4888  m_geom->worldToLocal(ulGpt, dpt);
4889  ossimIpt ul(dpt);
4890
4891  // Get the new lower right in view space.
4892  m_geom->worldToLocal(lrGpt, dpt);
4893  ossimIpt lr(dpt);
4894
4895  //---
4896  // Clamp to thumbnail bounds with padding if turned on.
4897  // Padding is optional. If padding turned on alway make square.
4898  //---
4899  ossim_int32 ts = thumbSize;
4900  bool pad = padThumbnail();
4901  if(pad)
4902  {
4903  lr.x = ul.x + ts - 1;
4904  lr.y = ul.y + ts - 1;
4905  }
4906  else // let it vary
4907  {
4908  lr.x = ul.x + tw - 1;
4909  lr.y = ul.y + th - 1;
4910  }
4911
4912  adjustedRect = ossimIrect(ul, lr);
4913  }
4914  }
4915
4916  } // if ( !originalRect.hasNans() && m_geom.valid() )
4917  else
4918  {
4919  // Should never happer...
4920  std::string errMsg = MODULE;
4921  if ( originalRect.hasNans() )
4922  {
4923  errMsg += " passed in rect has nans!";
4924  }
4925  else
4926  {
4927  errMsg += " output projection null!";
4928  }
4929  throw( ossimException(errMsg) );
4930  }
4931
4932  if ( traceDebug() )
4933  {
4934  ossimNotify(ossimNotifyLevel_DEBUG) << "\nadjusted rect: " << adjustedRect << "\n";
4935  if (m_geom.valid())
4936  {
4938  }
4939  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited...\n";
4940  }
4941 }
T max(T a, T b)
Definition: ossimCommon.h:236
bool valid() const
std::ostream & print(std::ostream &out) const
Prints contents to output stream.
double y
bool localToWorld(const ossimDpt &local_pt, ossimGpt &world_pt) const
Exposes the 3D projection from image to world coordinates.
The image geometry.
void applyScale(const ossimDpt &scale, bool recenterTiePoint)
Changes the GSD and image size to reflect the scale provided.
double x
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
bool padThumbnail() const
int ossim_int32
◆ intiailizeProjectionTiePoint()
void ossimChipperUtil::intiailizeProjectionTiePoint ( )
private
Sets the projection tie point to the scene bounding rect corner.
Note
Definition at line 2490 of file ossimChipperUtil.cpp.
2491 {
2492  static const char MODULE[] = "ossimChipperUtil::initializeProjectionTiePoint()";
2493  if ( traceDebug() )
2494  {
2495  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
2496  }
2497
2498  // Get the map projection from the output geometry:
2500
2501  if ( mapProj.valid() )
2502  {
2503  //---
2504  // If the output is geographic of there are sensor model inputs, get the tie
2505  // using the ground point.
2506  //---
2507  if ( mapProj->isGeographic() || hasSensorModelInput() )
2508  {
2509  ossimGpt tiePoint;
2510  tiePoint.makeNan();
2511  getTiePoint(tiePoint);
2512
2513  if ( !tiePoint.hasNans() )
2514  {
2515  //---
2516  // The tie point coordinates currently reflect the UL edge of the UL pixel.
2517  // We'll need to shift the tie point bac from the edge to the center base on the
2518  // output gsd.
2519  //---
2520  ossimDpt half_pixel_shift = m_geom->getDegreesPerPixel() * 0.5;
2521  tiePoint.lat -= half_pixel_shift.lat;
2522  tiePoint.lon += half_pixel_shift.lon;
2523  mapProj->setUlTiePoints(tiePoint);
2524  }
2525  else
2526  {
2527  std::string errMsg = MODULE;
2528  errMsg += " tie point has nans!";
2529  throw( ossimException(errMsg) );
2530  }
2531
2532  if ( traceDebug() )
2533  {
2535  << "projection tie point: " << tiePoint << "\n" << MODULE << " exited...\n";
2536  }
2537  }
2538  else
2539  {
2540  //---
2541  // TODO: Add test for like input projections and use above geographic tie
2542  // code if not.
2543  //---
2544  ossimDpt tiePoint;
2545  tiePoint.makeNan();
2546  getTiePoint(tiePoint);
2547
2548  if ( !tiePoint.hasNans() )
2549  {
2550  //---
2551  // The tie point coordinates currently reflect the UL edge of the UL pixel.
2552  // We'll need to shift the tie point bac from the edge to the center base on the
2553  // output gsd.
2554  //---
2555  ossimDpt half_pixel_shift = m_geom->getMetersPerPixel() * 0.5;
2556  tiePoint.y -= half_pixel_shift.y;
2557  tiePoint.x += half_pixel_shift.x;
2558  mapProj->setUlTiePoints(tiePoint);
2559  }
2560  else
2561  {
2562  std::string errMsg = MODULE;
2563  errMsg += " tie point has nans!";
2564  throw( ossimException(errMsg) );
2565  }
2566
2567  if ( traceDebug() )
2568  {
2570  << "projection tie point: " << tiePoint << "\n" << MODULE << " exited...\n";
2571  }
2572  }
2573
2574  } // Matches: if ( mapProj.valid() )
2575  else
2576  {
2577  std::string errMsg = MODULE;
2578  errMsg += "m_projection is null!";
2579  throw( ossimException(errMsg) );
2580  }
2581 }
bool valid() const
Definition: ossimRefPtr.h:75
double y
void makeNan()
Definition: ossimGpt.h:130
double lat
ossim_float64 lon
Definition: ossimGpt.h:266
void getTiePoint(ossimGpt &tie)
Loops through all layers to get the upper left tie point.
double lon
The image geometry.
Definition: ossimGpt.h:135
double x
virtual void setUlTiePoints(const ossimGpt &gpt)
ossim_float64 lat
Definition: ossimGpt.h:265
void makeNan()
◆ isChipMode()
bool ossimChipperUtil::isChipMode ( ) const
private
Returns
true if operation is "chip" or identity; false, if not.
Definition at line 5350 of file ossimChipperUtil.cpp.
References m_operation, and OSSIM_CHIPPER_OP_CHIP.
Referenced by initializeIvtScale(), and initializeOutputProjection().
5351 {
5352  return (m_operation == OSSIM_CHIPPER_OP_CHIP);
5353 }
ossimChipperOperation m_operation
Enumerated operation to perform.
◆ isDemFile()
bool ossimChipperUtil::isDemFile ( const ossimFilename file) const
private
Returns
true if file extension is "hgt", "dem" or contains "dtN" (dted).
Definition at line 5168 of file ossimChipperUtil.cpp.
References ossimString::begin(), ossimString::downcase(), ossimFilename::ext(), and ossimString::size().
5169 {
5170  bool result = false;
5171  ossimString ext = file.ext();
5172  if ( ext.size() >= 2 )
5173  {
5174  ext.downcase();
5175  if ( ( ext == "hgt" ) || ( ext == "dem" ) ||
5176  ( ( (*ext.begin()) == 'd' ) && ( (*(ext.begin()+1)) == 't' ) ) )
5177  {
5178  result = true;
5179  }
5180  }
5181  return result;
5182 }
std::string::iterator begin()
Definition: ossimString.h:420
ossimString ext() const
◆ isSrcFile()
bool ossimChipperUtil::isSrcFile ( const ossimFilename file) const
private
Returns
true if file extension is "src"
Definition at line 5184 of file ossimChipperUtil.cpp.
References ossimString::downcase(), and ossimFilename::ext().
5185 {
5186  bool result = false;
5187  ossimString ext = file.ext();
5188  ext.downcase();
5189  if ( ext == "src" )
5190  {
5191  result = true;
5192  }
5193  return result;
5194 }
◆ isThreeBandOut()
bool ossimChipperUtil::isThreeBandOut ( ) const
private
Returns
true if three band out is true, false if not.
Definition at line 5016 of file ossimChipperUtil.cpp.
References keyIsTrue().
5017 {
5018  return keyIsTrue( THREE_BAND_OUT_KW );
5019 }
bool keyIsTrue(const std::string &key) const
◆ keyIsTrue()
bool ossimChipperUtil::keyIsTrue ( const std::string &  key) const
private
Returns
true if key is set to true; false, if not.
Definition at line 5355 of file ossimChipperUtil.cpp.
References ossimKeywordlist::findKey(), m_kwl, ossimString::toBool(), and ossimRefPtr< T >::valid().
Referenced by isThreeBandOut(), northUp(), padThumbnail(), snapTieToOrigin(), and upIsUp().
5356 {
5357  bool result = false;
5358  if ( m_kwl.valid() )
5359  {
5360  std::string value = m_kwl->findKey( key );
5361  if ( value.size() )
5362  {
5363  result = ossimString(value).toBool();
5364  }
5365  }
5366  return result;
5367 }
bool valid() const
bool toBool() const
String to numeric methods.
Hold all options passed into intialize.
◆ northUp()
bool ossimChipperUtil::northUp ( ) const
private
Returns
true if NORTH_UP_KW option is set; false, if not.
Definition at line 5345 of file ossimChipperUtil.cpp.
5346 {
5347  return keyIsTrue( std::string(NORTH_UP_KW) );
5348 }
◆ operator=()
const ossimChipperUtil & ossimChipperUtil::operator= ( const ossimChipperUtil rhs)
private
Hidden from use assignment operator.
Definition at line 164 of file ossimChipperUtil.cpp.
165 {
166  return *this;
167 }
◆ padThumbnail()
bool ossimChipperUtil::padThumbnail ( ) const
private
Returns
true if pad thumbnail is true, false if not.
Definition at line 5021 of file ossimChipperUtil.cpp.
5022 {
5023  return keyIsTrue( PAD_THUMBNAIL_KW );
5024 }
◆ propagateOutputProjectionToChains()
void ossimChipperUtil::propagateOutputProjectionToChains ( )
private
Note
Definition at line 3576 of file ossimChipperUtil.cpp.
Referenced by initializeOutputProjection().
3577 {
3578  static const char MODULE[] = "ossimChipperUtil::propagateOutputProjectionToChains()";
3579  if ( traceDebug() )
3580  {
3581  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
3582  }
3583
3584  std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator chainIdx;
3585
3586  // we need to make sure the outputs are refreshed so they can reset themselves
3587  // Needed when we are doing interactive update to the GSD and clip window
3589  ossimEventVisitor eventVisitor(refreshEvent.get());
3590  ossimViewInterfaceVisitor viewVisitor(m_geom.get());
3591  // Loop through dem layers.
3592  chainIdx = m_demLayer.begin();
3593  while ( chainIdx != m_demLayer.end() )
3594  {
3595  viewVisitor.reset();
3596  eventVisitor.reset();
3597  (*chainIdx)->accept(viewVisitor);
3598  (*chainIdx)->accept(eventVisitor);
3599
3600  ossimRefPtr<ossimImageRenderer> resampler = (*chainIdx)->getImageRenderer();
3601  if ( resampler.valid() )
3602  {
3603  //resampler->setView( m_geom.get() );
3604  // resampler->propagateEventToOutputs(refreshEvent);
3605  }
3606  else
3607  {
3608  std::string errMsg = MODULE;
3609  errMsg += " chain has no resampler!";
3610  throw( ossimException(errMsg) );
3611  }
3612  ++chainIdx;
3613  }
3614
3615  // Loop through image layers.
3616  chainIdx = m_imgLayer.begin();
3617  while ( chainIdx != m_imgLayer.end() )
3618  {
3619  ossimRefPtr<ossimImageRenderer> resampler = (*chainIdx)->getImageRenderer();
3620  eventVisitor.reset();
3621  viewVisitor.reset();
3622  (*chainIdx)->accept(viewVisitor);
3623  (*chainIdx)->accept(eventVisitor);
3624
3625  if ( resampler.valid() )
3626  {
3627  //resampler->setView( m_geom.get() );
3628  //resampler->propagateEventToOutputs(refreshEvent);
3629  }
3630  else
3631  {
3632  std::string errMsg = MODULE;
3633  errMsg += " chain has no resampler!";
3634  throw( ossimException(errMsg) );
3635  }
3636  ++chainIdx;
3637  }
3638
3639  if ( traceDebug() )
3640  {
3641  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited...\n";
3642  }
3643 }
bool valid() const
Visitor to update view and then propagate property event to outputs.
Definition: ossimVisitor.h:179
The image geometry.
virtual void accept(ossimVisitor &visitor)
We will add a visitor interface for all connectable objects.
◆ scaleToEightBit()
bool ossimChipperUtil::scaleToEightBit ( ) const
private
Returns
true if scale to eight bit option is set; false, if not.
Definition at line 5215 of file ossimChipperUtil.cpp.
References getOutputScalarType(), and OSSIM_UINT8.
5216 {
5217  bool result = false;
5218  if ( getOutputScalarType() == OSSIM_UINT8 )
5219  {
5220  result = true;
5221  }
5222  return result;
5223 }
Returns the scalar type from OUTPUT_RADIOMETRY_KW keyword if present.
8 bit unsigned integer
◆ setChainEntry()
bool ossimChipperUtil::setChainEntry ( ossimRefPtr< ossimSingleImageChain > &  chain,
ossim_uint32  entryIndex
) const
private
Sets entry for a chain.
Parameters
chainChain to set up.
entryIndexZero based index.
Returns
Definition at line 4357 of file ossimChipperUtil.cpp.
References ossimSingleImageChain::getImageHandler(), ossimImageHandler::setCurrentEntry(), and ossimRefPtr< T >::valid().
4359 {
4360  bool result = false;
4361  if ( chain.valid() )
4362  {
4364  if ( ih.valid() )
4365  {
4366  result = ih->setCurrentEntry( entryIndex );
4367  }
4368  }
4369  return result;
4370 }
ossimRefPtr< const ossimImageHandler > getImageHandler() const
bool valid() const
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
◆ setOptionsToChain()
void ossimChipperUtil::setOptionsToChain ( ossimIrect aoi,
private
Definition at line 1178 of file ossimChipperUtil.cpp.
References ossimRefPtr< T >::get(), getAreaOfInterest(), and m_source.
1180 {
1181  getAreaOfInterest(m_source.get(), aoi);
1182 }
ossimRefPtr< ossimImageSource > m_source
We need to support changing clips without doing a full initilization.
◆ setReaderProps()
void ossimChipperUtil::setReaderProps ( ossimImageHandler ih) const
private
Passes reader properties to single image handler if any.
Parameters
ihImage handler to set properties on.
Definition at line 5026 of file ossimChipperUtil.cpp.
References m_kwl, ossimKeywordlist::numberOf(), and ossimRefPtr< T >::valid().
5027 {
5028  if ( ih && m_kwl.valid() )
5029  {
5030  ossim_uint32 count = m_kwl->numberOf( READER_PROPERTY_KW.c_str() );
5031  for (ossim_uint32 i = 0; i < count; ++i)
5032  {
5033  ossimString key = READER_PROPERTY_KW;
5034  key += ossimString::toString(i);
5035  ossimString value = m_kwl->findKey( key.string() );
5036  if ( value.size() )
5037  {
5038  std::vector<ossimString> splitArray;
5039  value.split(splitArray, "=");
5040  if(splitArray.size() == 2)
5041  {
5043  new ossimStringProperty(splitArray[0], splitArray[1]);
5044
5045  ih->setProperty( prop );
5046  }
5047  }
5048  }
5049  }
5050 }
ossim_uint32 numberOf(const char *str) const
bool valid() const
Numeric to string methods.
◆ setupChainHistogram()
bool ossimChipperUtil::setupChainHistogram ( ossimRefPtr< ossimSingleImageChain > &  chain,
std::shared_ptr< ossimSrcRecord srcRecordPtr = 0
) const
private
Set up ossimHistogramRemapper for a chain.
Parameters
Returns
Definition at line 4214 of file ossimChipperUtil.cpp.
4216 {
4217  static const char MODULE[] = "ossimChipperUtil::setupChainHistogram(chain)";
4218  if ( traceDebug() )
4219  {
4220  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
4221  }
4222
4223  bool result = false;
4224
4227
4228  if ( chain.valid() )
4229  {
4232
4233  if ( ih.valid() && remapper.valid() &&
4235  {
4236  result = true;
4237  ossimString histCenterKw = m_kwl->findKey(HIST_CENTER_KW);
4238  if(histCenterKw.empty())
4239  {
4240  histCenterKw = "false";
4241  }
4242  bool roiStretch = ( m_kwl->hasKey( HIST_AOI_KW ) || m_kwl->hasKey( HIST_LLWH_KW ) ||
4243  histCenterKw.toBool() );
4244
4245  if ( !roiStretch )
4246  {
4247  bool openedHistogram = false;
4248  if ( remapper->getHistogramFile() == ossimFilename::NIL )
4249  {
4250  ossimFilename f;
4251  if(srcRecordPtr)
4252  {
4253  f = srcRecordPtr->getHistogramPath();
4254  }
4255  // Open histogram file.
4256  if(f.empty() || !f.exists())
4257  {
4258  f = ih->getFilenameWithThisExtension( ossimString("his") );
4259  if ( f.empty() || (f.exists() == false) )
4260  {
4261  // For backward compatibility check if single entry and _e0.his
4262  f = ih->getFilenameWithThisExtension( ossimString("his"), true );
4263  if(!f.exists()) f.clear();
4264  }
4265  }
4266
4267  if ( !f.empty() )
4268  {
4269  openedHistogram = remapper->openHistogram( f );
4270  if ( !openedHistogram && traceDebug() )
4271  {
4273  << MODULE << " WARNING:"
4274  << "\nCould not open: " << f << "\n";
4275  }
4276  }
4277
4278  if ( !openedHistogram )
4279  {
4280  //---
4281  // User requested a histogram operation but does not have
4282  // external histogram file. This will cause downstream code
4283  // to computer from center tile of image.
4284  //---
4285  roiStretch = true;
4286  }
4287  }
4288  }
4289
4290  // Enable and set mode:
4291  remapper->setEnableFlag(true);
4292  remapper->setStretchMode( mode );
4293
4294  if ( roiStretch )
4295  {
4296  ossimIrect aoi;
4297
4298  std::string value = m_kwl->findKey( HIST_AOI_KW );
4299  if ( value.size() )
4300  {
4301  result = getIrect( value, aoi );
4302  }
4303  else
4304  {
4305  value = m_kwl->findKey( HIST_LLWH_KW );
4306  if ( value.size() )
4307  {
4308  result = getIrect( chain, value, aoi );
4309  }
4310  else // Use center of image.
4311  {
4312  result = getIrect( chain, aoi );
4313  }
4314  }
4315
4316  if ( traceDebug() )
4317  {
4319  << "ROI of histogram: " << aoi << std::endl;
4320  }
4321
4322  if ( result )
4323  {
4324  //---
4325  // Note: both of these sections work.
4326  // Going with separate connection for now. drb - 20 Feb. 2016
4327  //---
4328 #if 1
4331  ihist->setAreaOfInterest( aoi );
4332  ihist->connectMyInputTo( remapper->getInput() );//ih.get());
4333  remapper->connectMyInputTo( ihist.get() );
4334 #else
4335  remapper->computeHistogram( aoi );
4336 #endif
4337  }
4338  }
4339
4340  if ( !result )
4341  {
4342  remapper->setEnableFlag(false);
4343  }
4344
4345  } // Matches: if ( ih.valid() && remapper.valid() && mode... )
4346
4347  } // Matches: if ( chain.valid() )
4348
4349  if ( traceDebug() )
4350  {
4351  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " exited...\n";
4352  }
4353
4354  return result;
4355 }
void clear()
Erases the entire container.
Definition: ossimString.h:432
bool getIrect(const std::string &s, ossimIrect &rect) const
Gets rect from string in the form of <x>,<y>,<w>,<h>.
static const ossimFilename NIL
This was taken from Wx widgets for performing touch and access date stamps.
Definition: ossimFilename.h:40
bool valid() const
ossimFilename getHistogramFile() const
Returns the currently opened histogram.
bool computeHistogram(const ossimIrect &roi)
Compute the histogram from input connection and region of interest.
bool hasKey(const std::string &key) const
Checks for key in map.
void setStretchMode(StretchMode mode, bool rebuildTableFlag=false)
Sets remap mode to mode.
bool exists() const
bool toBool() const
virtual void setEnableFlag(bool flag)
Definition: ossimSource.cpp:99
ossimRefPtr< const ossimHistogramRemapper > getHistogramRemapper() const
bool empty() const
Definition: ossimString.h:411
void setAreaOfInterest(const ossimIrect &rect)
ossimFilename getFilenameWithThisExtension(const ossimString &ext, bool set_e0_prefix=false) const
Returns the image file with extension set using supplentary directory for dirname if set...
bool openHistogram(const ossimFilename &histogram_file)
Open the histogram file.
◆ snapTieToOrigin()
bool ossimChipperUtil::snapTieToOrigin ( ) const
private
Returns
true if snap tie to origin option is set; false, if not.
Definition at line 5225 of file ossimChipperUtil.cpp.
5226 {
5227  return keyIsTrue( SNAP_TIE_TO_ORIGIN_KW );
5228 }
◆ upIsUp()
bool ossimChipperUtil::upIsUp ( ) const
private
Returns
true if UP_IS_UP_KW option is set; false, if not.
Definition at line 5329 of file ossimChipperUtil.cpp.
5330 {
5331  return keyIsTrue( std::string(UP_IS_UP_KW) );
5332 }
◆ usage()
void ossimChipperUtil::usage ( ossimArgumentParser ap)
private
Definition at line 5699 of file ossimChipperUtil.cpp.
References addArguments(), ossimInit::addOptions(), ossimArgumentParser::getApplicationName(), ossimArgumentParser::getApplicationUsage(), ossimInit::instance(), ossimNotify(), ossimNotifyLevel_INFO, ossimApplicationUsage::setApplicationName(), and ossimApplicationUsage::write().
5700 {
5701  // Add global usage options.
5703
5704  // Set app name.
5705  std::string appName = ap.getApplicationName();
5707
5708  // Add options.
5709  addArguments(ap);
5710
5711  // Write usage.
5713
5714  // Keeping single line in tact for examples for cut and paste purposes.
5716
5717  << "NOTES:\n"
5718  << "1) Never use same base name in the same directory! Example is you have a Chicago.tif\n"
5719  << " and you want a Chicago.jp2, output Chicago.jp2 to its own directory.\n"
5720
5721  << "\nExample commands:\n"
5722
5723  << "\n// File conversion: Convert geotiff to a jp2 file.\n"
5724  << appName << " --op chip -w ossim_kakadu_jp2 Chicago.tif outputs/Chicago.jp2\n"
5725
5726  << "\n// Orthorectification: Orthorectify a nitf with RPC model out to a geotiff.\n"
5727  << appName << " --op ortho 5V090205P0001912264B220000100282M_001508507.ntf outputs/ortho.tif\n"
5728
5729  << "\n// Mosaic: Mosaic multiple images together and output to a geotiff.\n"
5730  << appName << " --combiner-type ossimImageMosaic --op ortho f1.tif f2.tif f3.tif outputs/mosaic.tif\n"
5731
5732  << "\n// Mosaic: Feather Mosaic multiple images together and output to a geotiff.\n"
5733  << appName << " --combiner-type ossimFeatherMosaic --op ortho f1.tif f2.tif f3.tif outputs/feather.tif\n"
5734
5735  << "\n// Color relief: Colorize two DEMs from a lut, output to a geotiff.\n"
5736  << appName << " --op color-relief --color-table ossim-dem-color-table-template.kwl N37W123.hgt N38W123.hgt outputs/color-relief.tif\n"
5737
5738  << "\n// Color relief: Colorize two DEMs from a lut, output to a png thumbnail.\n"
5739  << appName << " --op color-relief --color-table ossim-dem-color-table-template.kwl -t 1024 -w ossim_png N37W123.hgt N38W123.hgt outputs/color-relief.png\n"
5740
5741  << "\n// Hill shade: Hill shade two DEMs, output to a geotiff.\n"
5742  << appName << " --color 255 255 255 --azimuth 270 --elevation 45 --exaggeration 2.0 --op hillshade N37W123.hgt N38W123.hgt outputs/hillshade.tif\n"
5743
5744  << "\n// Two color multi view with cut box. First image is old, second image is new:\n"
5745  << appName << " --cut-bbox-ll 28.092885092033352 -80.664539599998633 28.109128691071547 -80.626914963229325 --op 2cmv oldMLB.tif newMLB.tif outputs/2cmv-test1.tif\n"
5746
5747  << "\n// Ortho about point, 512x512, with histogram stretch, and 3,2,1 band order:\n"
5748  << appName << " --op ortho -b 3,2,1 --histogram-op auto-minmax --cut-center-llwh -42.819784401784275 147.265811350983 512 512 5V090205M0001912264B220000100072M_001508507.ntf orth.tif\n"
5749
5750  << "\n// Chip, in image space, about point, 512x512, with histogram stretch, and 3,2,1 band order:\n"
5751  << appName << " --op chip -b 3,2,1 --histogram-op auto-minmax --cut-center-llwh -42.819784401784275 147.265811350983 512 512 5V090205M0001912264B220000100072M_001508507.ntf chip.tif\n"
5752
5753  << "\n// Chip in image space, rotate \"up is up\"(-u option) about point, 512x512 with histogram stretch and 3,2,1 band order:\n"
5754  << appName << " --op chip -u -b 3,2,1 --histogram-op auto-minmax --cut-center-llwh -42.819784401784275 147.265811350983 512 512 5V090205M0001912264B220000100072M_001508507.ntf up-is-up-chip.tif\n"
5755
5756  << "\n// Chip in image space, rotate 39 degrees (-r option) about point, 1024x1024, scaled to eight bit:\n"
5757  << appName << " --op chip -r 39 --histogram-op auto-minmax --cut-center-llwh -42.883809539602893 147.331984112985765 1024 1024 --output-radiometry ossim_uint8 5V090205P0001912264B220000100282M_001508507.ntf outputs/r39.png\n"
5758
5759  << "\n// Above command where all options are in a keyword list:\n"
5760  << appName << " --options r39-options.kwl\n"
5761  << std::endl;
5762 }
void write(std::ostream &output, const UsageMap &um, unsigned int widthOfOutput=80)
std::string getApplicationName() const
return the application name, as specified by argv[0]
void addOptions(ossimArgumentParser &parser)
Definition: ossimInit.cpp:100
void addArguments(ossimArgumentParser &ap)
Adds application arguments to the argument parser.
ossimApplicationUsage * getApplicationUsage()
void setApplicationName(const ossimString &name)
static ossimInit * instance()
Definition: ossimInit.cpp:89
Member Data Documentation
◆ m_demLayer
std::vector< ossimRefPtr<ossimSingleImageChain> > ossimChipperUtil::m_demLayer
private
Definition at line 820 of file ossimChipperUtil.h.
Referenced by clear(), hasSensorModelInput(), initialize2CmvChain(), and initializePsmChain().
◆ m_geom
ossimRefPtr<ossimImageGeometry> ossimChipperUtil::m_geom
private
The image geometry.
In chip mode this will be from the input image. So this may or may not have a map projection. In any other mode it will the view or output geometry which will be a map projection.
Definition at line 811 of file ossimChipperUtil.h.
Referenced by addCrossHairAnnotation(), getChip(), getMapProjection(), and initializeIvtScale().
◆ m_imgLayer
std::vector< ossimRefPtr<ossimSingleImageChain> > ossimChipperUtil::m_imgLayer
private
Definition at line 823 of file ossimChipperUtil.h.
◆ m_ivt
ossimRefPtr<ossimImageViewAffineTransform> ossimChipperUtil::m_ivt
private
Only set/used in "chip"(identity) operation as the IVT for the resampler(ossimImageRenderer).
Definition at line 817 of file ossimChipperUtil.h.
Referenced by addCrossHairAnnotation(), and initializeIvtScale().
◆ m_kwl
ossimRefPtr<ossimKeywordlist> ossimChipperUtil::m_kwl
private
◆ m_operation
ossimChipperOperation ossimChipperUtil::m_operation
private
Definition at line 798 of file ossimChipperUtil.h.
Referenced by hasBumpShadeArg(), and isChipMode().
◆ m_source
ossimRefPtr<ossimImageSource> ossimChipperUtil::m_source
private
we will save the ImageSource pointer on first initialization
Definition at line 834 of file ossimChipperUtil.h.
Referenced by getChip(), and setOptionsToChain().
◆ m_srcKwl
ossimRefPtr<ossimKeywordlist> ossimChipperUtil::m_srcKwl
private
Definition at line 804 of file ossimChipperUtil.h.
Referenced by getNumberOfInputs().
◆ m_writer
ossimRefPtr<ossimImageFileWriter> ossimChipperUtil::m_writer
mutableprivate
We need access to the writer so we can support aborting.
Definition at line 828 of file ossimChipperUtil.h.
Referenced by abort(), and clear().
